[geos-commits] r4101 - branches/3.5/src/operation/buffer
svn_geos at osgeo.org
Sun Oct 4 09:08:31 PDT 2015
Author: strk
Date: 2015-10-04 09:08:31 -0700 (Sun, 04 Oct 2015)
New Revision: 4101
branches/3.5/src/operation/buffer/BufferBuilder.cpp
Fix a few potential (one confirmed) leak in single sided buffer
See #747
Modified: branches/3.5/src/operation/buffer/BufferBuilder.cpp
--- branches/3.5/src/operation/buffer/BufferBuilder.cpp 2015-10-04 14:09:49 UTC (rev 4100)
+++ branches/3.5/src/operation/buffer/BufferBuilder.cpp 2015-10-04 16:08:31 UTC (rev 4101)
@@ -151,7 +151,7 @@
BufferParameters modParams = bufParams;
modParams.setEndCapStyle(BufferParameters::CAP_FLAT);
modParams.setSingleSided(false); // ignore parameter for areal-only geometries
- Geometry* buf = 0;
+ std::auto_ptr<Geometry> buf;
// This is a (temp?) hack to workaround the fact that
// BufferBuilder BufferParamaters are immutable after
@@ -159,11 +159,11 @@
// style to FLAT for single-sided buffering
BufferBuilder tmp(modParams);
- buf = tmp.buffer( l, distance );
+ buf.reset( tmp.buffer( l, distance ) );
// Create MultiLineStrings from this polygon.
- Geometry* bufLineString = buf->getBoundary();
+ std::auto_ptr<Geometry> bufLineString ( buf->getBoundary() );
#ifdef GEOS_DEBUG_SSB
std::cerr << "input|" << *l << std::endl;
@@ -219,8 +219,8 @@
for (size_t i=0, n=curveList.size(); i<n; ++i) delete curveList[i];
curveList.clear();
- Geometry* singleSided = geomFact->createMultiLineString(
- singleSidedNodedEdges );
+ std::auto_ptr<Geometry> singleSided ( geomFact->createMultiLineString(
+ singleSidedNodedEdges ) );
std::cerr << "edges|" << *singleSided << std::endl;
@@ -233,7 +233,7 @@
// diverge from original offset curves due to the addition of
// intersections with caps and joins curves
using geos::operation::overlay::snap::SnapOverlayOp;
- Geometry* intersectedLines = SnapOverlayOp::overlayOp(*singleSided, *bufLineString, OverlayOp::opINTERSECTION).release();
+ std::auto_ptr<Geometry> intersectedLines = SnapOverlayOp::overlayOp(*singleSided, *bufLineString, OverlayOp::opINTERSECTION);
std::cerr << "intersection" << "|" << *intersectedLines << std::endl;
@@ -241,7 +241,7 @@
// Merge result lines together.
LineMerger lineMerge;
- lineMerge.add( intersectedLines );
+ lineMerge.add( intersectedLines.get() );
std::auto_ptr< std::vector< LineString* > > mergedLines (
lineMerge.getMergedLineStrings() );
@@ -338,10 +338,10 @@
// Clean up.
if ( noder != workingNoder ) delete noder;
- geomFact->destroyGeometry( buf );
- geomFact->destroyGeometry( bufLineString );
- geomFact->destroyGeometry( singleSided );
- geomFact->destroyGeometry( intersectedLines );
+ buf.reset();
+ bufLineString.reset();
+ singleSided.reset();
+ intersectedLines.reset();
if ( mergedLinesGeom->size() > 1 )
More information about the geos-commits
