[geos-commits] r4104 - trunk/src/geomgraph
svn_geos at osgeo.org
Mon Oct 5 02:38:40 PDT 2015
Author: mloskot
Date: 2015-10-05 02:38:40 -0700 (Mon, 05 Oct 2015)
New Revision: 4104
trunk/src/geomgraph/PlanarGraph.cpp
Use std::auto_ptr to simplify r4100 fix of a memory leak potential
Modified: trunk/src/geomgraph/PlanarGraph.cpp
--- trunk/src/geomgraph/PlanarGraph.cpp 2015-10-04 16:09:41 UTC (rev 4103)
+++ trunk/src/geomgraph/PlanarGraph.cpp 2015-10-05 09:38:40 UTC (rev 4104)
@@ -133,6 +133,8 @@
void
PlanarGraph::add(EdgeEnd* e)
+ // It is critical to add the edge to the edgeEndList first,
+ // then it is safe to follow with any potentially throwing operations.
assert(edgeEndList);
edgeEndList->push_back(e);
@@ -210,23 +212,14 @@
// PlanarGraph destructor will delete all DirectedEdges
// in edgeEndList, which is where these are added
// by the ::add(EdgeEnd) call
- DirectedEdge *de1=new DirectedEdge(e, true);
- DirectedEdge *de2=new DirectedEdge(e, false);
- de1->setSym(de2);
- de2->setSym(de1);
+ std::auto_ptr<DirectedEdge> de1(new DirectedEdge(e, true));
+ std::auto_ptr<DirectedEdge> de2(new DirectedEdge(e, false));
+ de1->setSym(de2.get());
+ de2->setSym(de1.get());
- // ::add may throw, then de2 will not be registered for deletion
- try
- add(de1);
- catch (...)
- delete de2;
- // no need to delete de1 which has already been registered in edgeEndList
- throw;
- add(de2);
+ // First, ::add takes the ownership, then follows with operations that may throw.
+ add(de1.release());
+ add(de2.release());
More information about the geos-commits
