[geos-commits] r4107 - branches/3.5
svn_geos at osgeo.org
Mon Oct 5 05:55:03 PDT 2015
Author: mloskot
Date: 2015-10-05 05:55:03 -0700 (Mon, 05 Oct 2015)
New Revision: 4107
branches/3.5/NEWS
Revert accidental removal of whitespaces in r4106.
Modified: branches/3.5/NEWS
--- branches/3.5/NEWS 2015-10-05 09:45:38 UTC (rev 4106)
+++ branches/3.5/NEWS 2015-10-05 12:55:03 UTC (rev 4107)
@@ -26,15 +26,15 @@
2013-08-25
- Bug fixes / improvements
- - Use a double for PrecisionModel scale, avoiding overflows
+ - Use a double for PrecisionModel scale, avoiding overflows
should fix 32-bit regression failures (#652)
- isnan workaround OS detection missing NetBSD, DragonFly, Sun nuance (#650)
- Do not distribute platform.h and version.h, but install both (#601)
- - Non-standard ChangeLog file in 3.4.0 and 3.4.1 releases (#654)
+ - Non-standard ChangeLog file in 3.4.0 and 3.4.1 releases (#654)
- new travis bot (#657)
- accept multiple Nan representations (#656)
Changes in 3.4.1
2013-08-17
@@ -60,7 +60,7 @@
- C++ API changes:
- New noding::GeometryNoder class
- - Added BufferOp::setSingleSided
+ - Added BufferOp::setSingleSided
- Signature of most functions taking a Label changed to take it
by reference rather than pointer.
- Signature of most functions taking an IntersectionMatrix changed
@@ -68,13 +68,13 @@
- GraphComponent::label is now a Label value (from a pointer)
- NodedSegmentString takes ownership of CoordinateSenuence now
- io::Writer's toString() returns by const ref, write() takes a const ref
- - Unify prototypes of WKTReader and WKBReader constructor (#310)
- - GeometryCollection::computeEnvelopInternal and
+ - Unify prototypes of WKTReader and WKBReader constructor (#310)
+ - GeometryCollection::computeEnvelopInternal and
GeometryCollection::compareToSameClass are marked virtual (#478)
- - A point interpolated from a line does not always intersect
- the same line (#323)
+ - A point interpolated from a line does not always intersect
+ the same line (#323)
- Port ConvexHull robustness fix from JTS-1.13 (#457)
- Improve Overlay robustness by reducing input precision on topology
exception and by refusing to accept unnoded output (#459)
@@ -88,8 +88,8 @@
- Fix EMPTY return from single-point lines and zero-length polygons (#612)
- CMakeLists.txt, tools/geos_svn_revision_cmake.h.in: Add
geos_svn_revision.h generator to CMake config (#643)
- - Makefile.vc 'clean' step leaks obj files (#607)
+ - Makefile.vc 'clean' step leaks obj files (#607)
Changes in 3.3.8
2013-02-28
@@ -100,7 +100,7 @@
- Fix centroid computation for collections with empty components (#582)
Changes in 3.3.7
-2013-01-22
+2013-01-22
- Fix abort in RightmostEdgeFinder (#605)
@@ -199,10 +199,10 @@
the polygonizer
- CAPI: GEOSOrientationIndex
- CAPI: GEOSSharedPaths to find shared paths and their orientation
- - CAPI: GEOSSnap
- - CAPI: GEOSRelatePatternMatch
- - CAPI: GEOSCovers, GEOSCoveredBy (#396)
- - CAPI: GEOSRelateBoundaryNodeRule (#399)
+ - CAPI: GEOSSnap
+ - CAPI: GEOSRelatePatternMatch
+ - CAPI: GEOSCovers, GEOSCoveredBy (#396)
+ - CAPI: GEOSRelateBoundaryNodeRule (#399)
- CAPI: GEOSGeom_getCoordinateDimension() (#311)
- CAPI: GEOSWKTWriter_setOutputDimension, GEOSWKTWriter_setOld3D (#292)
- PHP: new PHP5 bindings based on CAPI
@@ -225,13 +225,13 @@
- Fix NodedSegmentString to handle zero-length line segments correctly
(via safeOctant)
- Fixed buffer OffsetCurveSetBuilder to handle "flat" rings correctly
- - Added illegal state check in LineSegment::pointAlongOffset()
+ - Added illegal state check in LineSegment::pointAlongOffset()
- Improved performance of RectangleIntersects by always using
segment-scanning and refining SegmentIntersectionTester
- Reduce memory use in PreparedGeometry predicates (#342)
- Fix infinite loop in RobustDeterminant with nan/inf input (#357)
-Changes in 3.2.0
+Changes in 3.2.0
2009-12-14
- Add Single-sided buffer operation
@@ -253,7 +253,7 @@
- PreparedGeometry operations for very fast predicate testing.
- Intersects()
- - Covers()
+ - Covers()
- CoveredBy()
- ContainsProperly()
- Easier builds under MSVC and OpenSolaris
@@ -280,7 +280,7 @@
- Added GEOSSimplify() and GEOSTopologyPreserveSimplify()
to the C API
- Added closed ring checks in IsValidOp
- - Multi-input support in XMLTester
+ - Multi-input support in XMLTester
- HEXWKB I/O
- Envelope(string) ctor
- Ruby interface
@@ -329,7 +329,7 @@
contains() ops
- Inlined all planarGraphComponent class
- More iterators returning methods and inlining in planargraph.
- - Obsoleted toInternalGeometry/fromInternalGeometry
+ - Obsoleted toInternalGeometry/fromInternalGeometry
- Improved buffering speed and robustness by using Snap Rounding
- Semantic changes
@@ -375,7 +375,7 @@
result of overlaying polygons containing touching holes (#13)
- Fixed integer conversion bug
- Fixed PointLocator handling of LinearRings
- - Added missing ::clone() methods for Multi* geoms
+ - Added missing ::clone() methods for Multi* geoms
- (Partial) Detailed list of changes:
- Changed SegmentNode to contain a *real* Coordinate (not a pointer)
@@ -399,7 +399,7 @@
- CoordinateSequence API changes:
- point index and size related functions
use unsigned int rather then int
- - Changed EdgeEndStar to maintain a single container for EdgeEnds
+ - Changed EdgeEndStar to maintain a single container for EdgeEnds
- Changed PlanarGraph::addEdges to take a const vector by ref
rathern then a non-const vector by pointer
- Changed EdgeList::addAll to take a const vector by ref
@@ -424,17 +424,17 @@
- Support for MingW builds
- Bugfix in Polygonizer chocking on invalid LineString inputs
-- CAPI: small leak removed in GEOSHasZ()
+- CAPI: small leak removed in GEOSHasZ()
Changes in 2.2.0
- Performance improvement in OverlayOp::insertUniqueEdge()
- CoordinateSequence copy removal in EdgeRing
-- Minor memory allocation improvements
+- Minor memory allocation improvements
- Higher dimensions interface for CoordinateSequence
- Added getCoordinatesRO for Point class
- NEW WKB IO
-- NEW Simplified and stabler C API
+- NEW Simplified and stabler C API
Changes in 2.1.4
@@ -531,3 +531,4 @@
been dropped. You have to use GeometryFactory instead.
- WKTWriter default constructor has been dropped. You need
to initialize it with an explicit GeometryFactory
More information about the geos-commits
