[geos-commits] r4109 - in trunk: . capi php php/test src/geom/util tests/unit/capi
svn_geos at osgeo.org
Tue Oct 13 04:20:53 PDT 2015
Author: strk
Date: 2015-10-13 04:20:53 -0700 (Tue, 13 Oct 2015)
New Revision: 4109
trunk/NEWS
trunk/capi/geos_c.cpp
trunk/capi/geos_c.h.in
trunk/capi/geos_ts_c.cpp
trunk/php/geos.c
trunk/php/test/test.php
trunk/src/geom/util/GeometryEditor.cpp
trunk/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
Add a GEOSGeom_setPrecision funciton in C-API and PHP
Also fixes a bug in GeometryEditor that failed to update
GeometryFactory for empty polygons (#749)
Modified: trunk/NEWS
--- trunk/NEWS 2015-10-07 07:20:22 UTC (rev 4108)
+++ trunk/NEWS 2015-10-13 11:20:53 UTC (rev 4109)
@@ -3,6 +3,7 @@
- New things:
- CAPI: GEOSGeom_setPrecision (#713) - PHP: Geometry->setPrecision
+ - CAPI: GEOSGeom_getPrecision - PHP: Geometry->getPrecision
- Improvements:
- C++ API changes:
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp 2015-10-07 07:20:22 UTC (rev 4108)
+++ trunk/capi/geos_c.cpp 2015-10-13 11:20:53 UTC (rev 4109)
@@ -844,6 +844,12 @@
return GEOSGeom_setPrecision_r(handle, g, gridSize, flags);
+double
+GEOSGeom_getPrecision(const GEOSGeometry *g)
+ return GEOSGeom_getPrecision_r(handle, g);
int
GEOSGeom_getDimensions(const Geometry *g)
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in 2015-10-07 07:20:22 UTC (rev 4108)
+++ trunk/capi/geos_c.h.in 2015-10-13 11:20:53 UTC (rev 4109)
@@ -969,6 +969,16 @@
const GEOSGeometry *g,
double gridSize, int flags);
+ * Get a geometry's precision
+ * @return the size of the geometry's precision grid, 0 for FLOATING
+ * precision or -1 on exception
+extern double GEOS_DLL GEOSGeom_getPrecision_r(
+ GEOSContextHandle_t handle,
+ const GEOSGeometry *g);
/* Return -1 on exception */
extern int GEOS_DLL GEOSGetNumInteriorRings_r(GEOSContextHandle_t handle,
const GEOSGeometry* g);
@@ -1720,6 +1730,9 @@
const GEOSGeometry *g, double gridSize, int flags);
+extern double GEOS_DLL GEOSGeom_getPrecision(const GEOSGeometry *g);
+/* Return -1 on exception */
extern int GEOS_DLL GEOSGetNumInteriorRings(const GEOSGeometry* g);
/* Return -1 on exception, Geometry must be a LineString. */
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2015-10-07 07:20:22 UTC (rev 4108)
+++ trunk/capi/geos_ts_c.cpp 2015-10-13 11:20:53 UTC (rev 4109)
@@ -4285,6 +4285,43 @@
return NULL;
+double
+GEOSGeom_getPrecision_r(GEOSContextHandle_t extHandle, const GEOSGeometry *g)
+ using namespace geos::geom;
+ assert(0 != g);
+ if ( 0 == extHandle )
+ return -1;
+ GEOSContextHandleInternal_t *handle = 0;
+ handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ if ( 0 == handle->initialized )
+ return -1;
+ try
+ const PrecisionModel *pm = g->getPrecisionModel();
+ double cursize = pm->isFloating() ? 0 : 1.0/pm->getScale();
+ return cursize;
+ catch (const std::exception &e)
+ handle->ERROR_MESSAGE("%s", e.what());
+ catch (...)
+ handle->ERROR_MESSAGE("Unknown exception thrown");
+ return -1;
int
GEOSGeom_getDimensions_r(GEOSContextHandle_t extHandle, const Geometry *g)
Modified: trunk/php/geos.c
--- trunk/php/geos.c 2015-10-07 07:20:22 UTC (rev 4108)
+++ trunk/php/geos.c 2015-10-13 11:20:53 UTC (rev 4109)
@@ -205,6 +205,7 @@
PHP_METHOD(Geometry, simplify); /* also does topology-preserving */
PHP_METHOD(Geometry, normalize);
PHP_METHOD(Geometry, setPrecision);
+PHP_METHOD(Geometry, getPrecision);
PHP_METHOD(Geometry, extractUniquePoints);
PHP_METHOD(Geometry, disjoint);
PHP_METHOD(Geometry, touches);
@@ -272,6 +273,7 @@
PHP_ME(Geometry, simplify, NULL, 0)
PHP_ME(Geometry, normalize, NULL, 0)
PHP_ME(Geometry, setPrecision, NULL, 0)
+ PHP_ME(Geometry, getPrecision, NULL, 0)
PHP_ME(Geometry, extractUniquePoints, NULL, 0)
PHP_ME(Geometry, disjoint, NULL, 0)
PHP_ME(Geometry, touches, NULL, 0)
@@ -1070,6 +1072,22 @@
+ * double GEOSGeometry::getPrecision()
+ GEOSGeometry *geom;
+ double prec;
+ geom = (GEOSGeometry*)getRelay(getThis(), Geometry_ce_ptr);
+ prec = GEOSGeom_getPrecision(geom);
+ if ( prec < 0 ) RETURN_NULL(); /* should get an exception first */
+ RETURN_DOUBLE(prec);
* GEOSGeometry GEOSGeometry::normalize()
Modified: trunk/php/test/test.php
--- trunk/php/test/test.php 2015-10-07 07:20:22 UTC (rev 4108)
+++ trunk/php/test/test.php 2015-10-13 11:20:53 UTC (rev 4109)
@@ -1367,32 +1367,38 @@
$this->assertEquals(
'LINESTRING (0 0, 4 4, 6 10, 10 0, 10 10, 6 12, 0 10)'
, $writer->write($g));
+ $this->assertEquals($g->getPrecision(), 2);
$g = $g->setPrecision(0);
+ $this->assertEquals($g->getPrecision(), 0);
$g = $g->setPrecision(8);
'LINESTRING (0 0, 8 8, 8 0, 8 8, 8 16, 0 8)'
+ $this->assertEquals($g->getPrecision(), 8);
$g = $g->setPrecision(10);
'LINESTRING (0 0, 10 10, 10 0, 10 10, 10 20, 0 10)'
+ $this->assertEquals($g->getPrecision(), 10);
$g = $g->setPrecision(20);
'LINESTRING (0 0, 20 20, 20 0, 20 20, 0 20)'
+ $this->assertEquals($g->getPrecision(), 20);
$g = $reader->read('POLYGON((0 0, 2 0, 2 2, 0 2, 0 0))');
'POLYGON EMPTY'
public function testGeometry_extractUniquePoints()
Modified: trunk/src/geom/util/GeometryEditor.cpp
--- trunk/src/geom/util/GeometryEditor.cpp 2015-10-07 07:20:22 UTC (rev 4108)
+++ trunk/src/geom/util/GeometryEditor.cpp 2015-10-13 11:20:53 UTC (rev 4109)
@@ -111,7 +111,13 @@
if (newPolygon->isEmpty()) {
//RemoveSelectedPlugIn relies on this behaviour. [Jon Aquino]
- return newPolygon;
+ if ( newPolygon->getFactory() != factory ) {
+ Polygon *ret = factory->createPolygon(NULL, NULL);
+ delete newPolygon;
+ return ret;
+ } else {
+ return newPolygon;
Geometry* editResult = edit(newPolygon->getExteriorRing(),operation);
Modified: trunk/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
--- trunk/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp 2015-10-07 07:20:22 UTC (rev 4108)
+++ trunk/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp 2015-10-13 11:20:53 UTC (rev 4109)
@@ -90,9 +90,13 @@
geom1_ = fromWKT("POLYGON EMPTY");
ensure(geom1_);
+ double scale = GEOSGeom_getPrecision(geom1_);
+ ensure_equals(scale, 0.0);
geom3_ = GEOSGeom_setPrecision(geom1_, 2.0, 0);
ensure(geom3_);
ensure_equals(toWKT(geom3_), std::string("POLYGON EMPTY"));
+ scale = GEOSGeom_getPrecision(geom3_);
+ ensure_equals(scale, 2.0);
template<>
@@ -138,6 +142,10 @@
geom3_ = GEOSIntersection(geom1_, geom2_);
ensure(geom3_);
ensure_equals(toWKT(geom3_), std::string("POINT (3 20)"));
+ ensure_equals(scale, 0.5);
+ scale = GEOSGeom_getPrecision(geom2_);
// Retain (or not) topology
More information about the geos-commits
