[geos-commits] r4185 - trunk/capi
Sandro Santilli
strk at keybit.net
Tue Apr 19 09:26:55 PDT 2016
Author: strk
Date: 2016-04-19 09:26:54 -0700 (Tue, 19 Apr 2016)
New Revision: 4185
trunk/capi/geos_ts_c.cpp
Trim trailing whitespaces (as per .editorconfig)
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2016-04-19 16:04:38 UTC (rev 4184)
+++ trunk/capi/geos_ts_c.cpp 2016-04-19 16:26:54 UTC (rev 4185)
@@ -8,7 +8,7 @@
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
+ * by the Free Software Foundation.
* See the COPYING file for more information.
* Author: Sandro Santilli <strk at keybit.net>
@@ -17,23 +17,23 @@
#include <geos/platform.h> // for FINITE
-#include <geos/geom/Geometry.h>
-#include <geos/geom/prep/PreparedGeometry.h>
-#include <geos/geom/prep/PreparedGeometryFactory.h>
-#include <geos/geom/GeometryCollection.h>
-#include <geos/geom/Polygon.h>
-#include <geos/geom/Point.h>
-#include <geos/geom/MultiPoint.h>
-#include <geos/geom/MultiLineString.h>
-#include <geos/geom/MultiPolygon.h>
-#include <geos/geom/LinearRing.h>
-#include <geos/geom/LineString.h>
-#include <geos/geom/PrecisionModel.h>
-#include <geos/geom/GeometryFactory.h>
-#include <geos/geom/CoordinateSequenceFactory.h>
-#include <geos/geom/Coordinate.h>
-#include <geos/geom/IntersectionMatrix.h>
-#include <geos/geom/Envelope.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/prep/PreparedGeometry.h>
+#include <geos/geom/prep/PreparedGeometryFactory.h>
+#include <geos/geom/GeometryCollection.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/Point.h>
+#include <geos/geom/MultiPoint.h>
+#include <geos/geom/MultiLineString.h>
+#include <geos/geom/MultiPolygon.h>
+#include <geos/geom/LinearRing.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/CoordinateSequenceFactory.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/IntersectionMatrix.h>
+#include <geos/geom/Envelope.h>
#include <geos/index/strtree/STRtree.h>
#include <geos/index/strtree/GeometryItemDistance.h>
#include <geos/index/ItemVisitor.h>
@@ -71,7 +71,7 @@
#include <geos/util/Interrupt.h>
#include <geos/util/UniqueCoordinateArrayFilter.h>
#include <geos/util/Machine.h>
-#include <geos/version.h>
+#include <geos/version.h>
// This should go away
#include <cmath> // finite
@@ -90,7 +90,7 @@
#pragma warning(disable : 4099)
#endif
-// Some extra magic to make type declarations in geos_c.h work -
+// Some extra magic to make type declarations in geos_c.h work -
// for cross-checking of types in header.
#define GEOSGeometry geos::geom::Geometry
#define GEOSPreparedGeometry geos::geom::prep::PreparedGeometry
@@ -291,7 +291,7 @@
assert(0 != out);
// we haven't been checking allocation before ticket #371
if (0 == out)
@@ -398,13 +398,13 @@
finishGEOS_r(extHandle);
-void
-GEOSFree_r (GEOSContextHandle_t extHandle, void* buffer)
+void
+GEOSFree_r (GEOSContextHandle_t extHandle, void* buffer)
assert(0 != extHandle);
- free(buffer);
+ free(buffer);
// relate()-related functions
@@ -475,7 +475,7 @@
handle->ERROR_MESSAGE("Unknown exception thrown");
return 2;
@@ -507,7 +507,7 @@
return 2;
@@ -539,7 +539,7 @@
return 2;
@@ -571,7 +571,7 @@
return 2;
@@ -607,7 +607,7 @@
return 2;
@@ -639,7 +639,7 @@
return 2;
@@ -671,7 +671,7 @@
return 2;
@@ -703,7 +703,7 @@
return 2;
@@ -741,7 +741,7 @@
return 2;
@@ -780,7 +780,7 @@
return 2;
@@ -808,7 +808,7 @@
return 0;
char *result = gstrdup(im->toString());
delete im;
@@ -824,7 +824,7 @@
return NULL;
@@ -874,7 +874,7 @@
if (0 == im) return 0;
delete im;
@@ -890,7 +890,7 @@
return NULL;
@@ -941,7 +941,7 @@
return 2;
@@ -1118,7 +1118,7 @@
return 2;
@@ -1152,7 +1152,7 @@
return 0;
@@ -1186,7 +1186,7 @@
return 0;
@@ -1220,7 +1220,7 @@
return 0;
@@ -1254,7 +1254,7 @@
return 0;
@@ -1288,7 +1288,7 @@
return 0;
@@ -1320,7 +1320,7 @@
return NULL;
@@ -1356,7 +1356,7 @@
return NULL;
@@ -1437,7 +1437,7 @@
return NULL;
@@ -1475,7 +1475,7 @@
return NULL;
@@ -1521,7 +1521,7 @@
return NULL;
@@ -1560,7 +1560,7 @@
return NULL;
@@ -1591,7 +1591,7 @@
return 2;
@@ -1697,7 +1697,7 @@
return NULL;
@@ -1729,7 +1729,7 @@
return -1;
@@ -1765,7 +1765,7 @@
return NULL;
@@ -1796,7 +1796,7 @@
return NULL;
@@ -1828,7 +1828,7 @@
return NULL;
@@ -1884,7 +1884,7 @@
return NULL;
@@ -1930,7 +1930,7 @@
return NULL;
@@ -1973,7 +1973,7 @@
return NULL;
@@ -2005,7 +2005,7 @@
return NULL;
@@ -2106,7 +2106,7 @@
return NULL;
@@ -2138,7 +2138,7 @@
return NULL;
@@ -2196,7 +2196,7 @@
catch (const std::exception &e)
#if VERBOSE_EXCEPTIONS
- std::ostringstream s;
+ std::ostringstream s;
s << "Exception on GEOSUnion with following inputs:" << std::endl;
s << "A: "<<g1->toString() << std::endl;
s << "B: "<<g2->toString() << std::endl;
@@ -2208,7 +2208,7 @@
return NULL;
@@ -2235,7 +2235,7 @@
s << "Exception on GEOSUnaryUnion with following inputs:" << std::endl;
@@ -2247,7 +2247,7 @@
return NULL;
@@ -2274,7 +2274,7 @@
@@ -2286,7 +2286,7 @@
return NULL;
@@ -2308,7 +2308,7 @@
try
const geos::geom::MultiPolygon *p = dynamic_cast<const geos::geom::MultiPolygon *>(g1);
- if ( ! p )
+ if ( ! p )
handle->ERROR_MESSAGE("Invalid argument (must be a MultiPolygon)");
return NULL;
@@ -2325,7 +2325,7 @@
return NULL;
@@ -2350,7 +2350,7 @@
if ( ! ret )
const GeometryFactory* gf = handle->geomFactory;
- // return an empty point
+ // return an empty point
return gf->createPoint();
return ret;
@@ -2363,7 +2363,7 @@
return NULL;
@@ -2393,7 +2393,7 @@
s << "Exception on GEOSClipByRect with following inputs:" << std::endl;
@@ -2405,7 +2405,7 @@
return NULL;
@@ -2418,7 +2418,7 @@
GEOSContextHandleInternal_t *handle = 0;
- // FIXME: mloskot: Does this try-catch around delete means that
+ // FIXME: mloskot: Does this try-catch around delete means that
// destructors in GEOS may throw? If it does, this is a serious
// violation of "never throw an exception from a destructor" principle
@@ -2508,12 +2508,12 @@
return -1;
- * Return -1 on exception, 0 otherwise.
+ * Return -1 on exception, 0 otherwise.
* Converts Geometry to normal form (or canonical form).
int
@@ -2546,7 +2546,7 @@
return -1;
@@ -2583,7 +2583,7 @@
return -1;
@@ -2616,7 +2616,7 @@
return -1;
@@ -2652,7 +2652,7 @@
return NULL;
@@ -3021,7 +3021,7 @@
try
const Polygon *p = dynamic_cast<const Polygon *>(g1);
- if ( ! p )
+ if ( ! p )
handle->ERROR_MESSAGE("Invalid argument (must be a Polygon)");
return NULL;
@@ -3036,7 +3036,7 @@
return NULL;
@@ -3062,7 +3062,7 @@
try
- if ( ! p )
+ if ( ! p )
return NULL;
@@ -3077,7 +3077,7 @@
return NULL;
@@ -3114,7 +3114,7 @@
return NULL;
@@ -3136,7 +3136,7 @@
#ifdef GEOS_DEBUG
char buf[256];
sprintf(buf, "createCollection: requested type %d", type);
- handle->NOTICE_MESSAGE("%s", buf);// TODO: Can handle->NOTICE_MESSAGE format that directly?
+ handle->NOTICE_MESSAGE("%s", buf);// TODO: Can handle->NOTICE_MESSAGE format that directly?
#endif
try
@@ -3161,9 +3161,9 @@
default:
handle->ERROR_MESSAGE("Unsupported type request for GEOSGeom_createEmptyCollection_r");
g = 0;
return g;
@@ -3197,7 +3197,7 @@
char buf[256];
sprintf(buf, "PostGIS2GEOS_collection: requested type %d, ngeoms: %d",
type, ngeoms);
#endif
try
@@ -3224,9 +3224,9 @@
handle->ERROR_MESSAGE("Unsupported type request for PostGIS2GEOS_collection");
delete vgeoms;
g = 0;
return g;
@@ -3289,7 +3289,7 @@
// or add a wrapper which semantic is similar to:
// std::vector<as_polygon<Geometry*> >
std::vector<Geometry*> *polyvec = new std::vector<Geometry *>(polys->size());
for (std::size_t i = 0; i < polys->size(); ++i)
(*polyvec)[i] = (*polys)[i];
@@ -3563,7 +3563,7 @@
return 0;
@@ -3579,7 +3579,7 @@
return GEOS_JTS_PORT;
-char
+char
GEOSHasZ_r(GEOSContextHandle_t extHandle, const Geometry *g)
assert(0 != g);
@@ -3720,7 +3720,7 @@
return NULL;
@@ -3754,7 +3754,7 @@
return 0;
@@ -3805,7 +3805,7 @@
return NULL;
@@ -3843,7 +3843,7 @@
return 0;
@@ -3897,7 +3897,7 @@
return 0;
@@ -3935,7 +3935,7 @@
return 0;
@@ -4006,7 +4006,7 @@
const Point *p = dynamic_cast<const Point *>(g);
- if ( p )
+ if ( p )
return p->getCoordinatesRO();
@@ -4022,7 +4022,7 @@
return 0;
@@ -4054,7 +4054,7 @@
return NULL;
@@ -4074,7 +4074,7 @@
try
const GeometryFactory *gf = handle->geomFactory;
return gf->createPoint(cs);
@@ -4106,7 +4106,7 @@
try
return gf->createLinearRing(cs);
@@ -4119,7 +4119,7 @@
return NULL;
@@ -4139,7 +4139,7 @@
try
return gf->createLineString();
@@ -4152,7 +4152,7 @@
return NULL;
@@ -4172,7 +4172,7 @@
try
return gf->createLineString(cs);
@@ -4185,7 +4185,7 @@
return NULL;
@@ -4217,7 +4217,7 @@
return NULL;
@@ -4242,7 +4242,7 @@
try
using geos::geom::LinearRing;
std::vector<Geometry *> *vholes = new std::vector<Geometry *>(holes, holes + nholes);
LinearRing *nshell = dynamic_cast<LinearRing *>(shell);
@@ -4264,7 +4264,7 @@
return NULL;
@@ -4297,7 +4297,7 @@
return NULL;
@@ -4422,7 +4422,7 @@
return 0;
@@ -4453,7 +4453,7 @@
return 0;
@@ -4486,7 +4486,7 @@
return NULL;
@@ -4519,7 +4519,7 @@
return NULL;
@@ -4553,7 +4553,7 @@
return NULL;
@@ -4630,7 +4630,7 @@
return 0;
@@ -4663,7 +4663,7 @@
return 0;
@@ -4741,7 +4741,7 @@
return NULL;
@@ -4900,7 +4900,7 @@
return NULL;
@@ -4993,7 +4993,7 @@
return 0;
@@ -5002,7 +5002,7 @@
assert(0 != reader);
assert(0 != hex);
if ( 0 == extHandle )
return 0;
@@ -5017,7 +5017,7 @@
try
- std::string hexstring(reinterpret_cast<const char*>(hex), size);
+ std::string hexstring(reinterpret_cast<const char*>(hex), size);
std::istringstream is(std::ios_base::binary);
is.str(hexstring);
is.seekg(0, std::ios::beg); // rewind reader pointer
@@ -5033,7 +5033,7 @@
return 0;
@@ -5066,7 +5066,7 @@
return NULL;
@@ -5206,7 +5206,7 @@
GEOSWKBWriter_getOutputDimension_r(GEOSContextHandle_t extHandle, const GEOSWKBWriter* writer)
assert(0 != writer);
return 0;
@@ -5345,7 +5345,7 @@
return static_cast<char>(ret);
@@ -5376,7 +5376,7 @@
-// Prepared Geometry
+// Prepared Geometry
const geos::geom::prep::PreparedGeometry*
@@ -5408,7 +5408,7 @@
return prep;
@@ -5472,7 +5472,7 @@
return 2;
- try
+ try
bool result = pg->contains(g);
return result;
@@ -5485,7 +5485,7 @@
return 2;
@@ -5508,7 +5508,7 @@
return 2;
- try
+ try
bool result = pg->containsProperly(g);
return result;
@@ -5521,7 +5521,7 @@
return 2;
@@ -5544,7 +5544,7 @@
return 2;
- try
+ try
bool result = pg->coveredBy(g);
return result;
@@ -5557,7 +5557,7 @@
return 2;
@@ -5580,7 +5580,7 @@
return 2;
- try
+ try
bool result = pg->covers(g);
return result;
@@ -5593,7 +5593,7 @@
return 2;
@@ -5616,7 +5616,7 @@
return 2;
- try
+ try
bool result = pg->crosses(g);
return result;
@@ -5629,7 +5629,7 @@
return 2;
@@ -5652,7 +5652,7 @@
return 2;
- try
+ try
bool result = pg->disjoint(g);
return result;
@@ -5665,7 +5665,7 @@
return 2;
@@ -5688,7 +5688,7 @@
return 2;
- try
+ try
bool result = pg->intersects(g);
return result;
@@ -5701,7 +5701,7 @@
return 2;
@@ -5724,7 +5724,7 @@
return 2;
- try
+ try
bool result = pg->overlaps(g);
return result;
@@ -5737,7 +5737,7 @@
return 2;
@@ -5760,7 +5760,7 @@
return 2;
- try
+ try
bool result = pg->touches(g);
return result;
@@ -5773,7 +5773,7 @@
return 2;
@@ -5796,7 +5796,7 @@
return 2;
- try
+ try
bool result = pg->within(g);
return result;
@@ -5809,7 +5809,7 @@
return 2;
@@ -5847,7 +5847,7 @@
return tree;
@@ -5897,7 +5897,7 @@
-void
+void
GEOSSTRtree_query_r(GEOSContextHandle_t extHandle,
geos::index::strtree::STRtree *tree,
const geos::geom::Geometry *g,
@@ -6020,7 +6020,7 @@
return NULL;
-void
+void
GEOSSTRtree_iterate_r(GEOSContextHandle_t extHandle,
GEOSQueryCallback callback,
@@ -6088,7 +6088,7 @@
return 2;
- try
+ try
bool result = tree->remove(g->getEnvelopeInternal(), item);
return result;
@@ -6101,7 +6101,7 @@
return 2;
@@ -6153,7 +6153,7 @@
const Geometry *p)
if ( 0 == extHandle ) return -1.0;
- GEOSContextHandleInternal_t *handle =
+ GEOSContextHandleInternal_t *handle =
reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
if ( handle->initialized == 0 ) return -1.0;
@@ -6181,7 +6181,7 @@
GEOSInterpolate_r(GEOSContextHandle_t extHandle, const Geometry *g, double d)
if ( 0 == extHandle ) return 0;
if ( handle->initialized == 0 ) return 0;
@@ -6320,7 +6320,7 @@
SharedPathsOp::PathList forw, back;
try {
SharedPathsOp::sharedPathsOp(*g1, *g2, forw, back);
SharedPathsOp::clearEdges(forw);
@@ -6439,7 +6439,7 @@
GEOSBufferParams_destroy_r(GEOSContextHandle_t extHandle, BufferParameters* p)
(void)extHandle;
- delete p;
+ delete p;
int
@@ -6609,7 +6609,7 @@
return NULL;
@@ -6645,30 +6645,30 @@
return NULL;
-Geometry*
+Geometry*
GEOSVoronoiDiagram_r(GEOSContextHandle_t extHandle, const Geometry *g1, const Geometry *env, double tolerance ,int onlyEdges)
if ( 0 == extHandle ) return NULL;
- GEOSContextHandleInternal_t *handle = 0;
+ GEOSContextHandleInternal_t *handle = 0;
handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
if ( 0 == handle->initialized ) return NULL;
using geos::triangulate::VoronoiDiagramBuilder;
- try
+ try
VoronoiDiagramBuilder builder;
builder.setSites(*g1);
builder.setTolerance(tolerance);
if(env) builder.setClipEnvelope(env->getEnvelopeInternal());
if(onlyEdges) return builder.getDiagramEdges(*g1->getFactory()).release();
else return builder.getDiagram(*g1->getFactory()).release();
catch(const std::exception &e)
handle->ERROR_MESSAGE("%s", e.what());
catch(...)
handle->ERROR_MESSAGE("Unknow exception thrown");
More information about the geos-commits
