[geos-commits] r4199 - trunk
Sandro Santilli
strk at keybit.net
Sat Apr 23 07:47:41 PDT 2016
Author: strk
Date: 2016-04-23 07:47:41 -0700 (Sat, 23 Apr 2016)
New Revision: 4199
Removed:
trunk/README
trunk/README.md
Merge README into README.md
Thanks Mike Toews for the kickstart on this
Deleted: trunk/README
--- trunk/README 2016-04-23 13:16:23 UTC (rev 4198)
+++ trunk/README 2016-04-23 14:47:41 UTC (rev 4199)
@@ -1,105 +0,0 @@
-BUILDING, TESTING, INSTALLING
-Unix
-Using Autotools:
- ./autogen.sh # in ${srcdir}, if obtained from SVN
- ${srcdir}/configure # in build dir
-Using CMake:
- cmake ${srcdir} # in build dir
-Now, all versions:
- make
- make check
- make install # as root
- ldconfig # as root
-Win32
-If you use Microsoft Visual C++ (7.1 or later) compiler, you can build
-GEOS using NMAKE program and provided makefile.vc files.
-If you are building from SVN checkout, first run: autogen.bat
-Then:
- nmake /f makefile.vc MSVC_VER=1400
-where 1400 is version number of Visual C++ compiler, here Visual C++ 8.0
-from Visual Studio 2005 (supported versions are 1300, 1310, 1400 and 1500).
-The bootstrap.bat step is required to generate a couple of header files.
-In order to build debug configuration of GEOS, additional flag DEBUG=1
-is required:
- nmake /f makefile.vc MSVC_VER=1400 DEBUG=1
-CLIENT APPLICATIONS
-Using the C interface (recommended)
-To compile programs against the C lib (recommended):
- CFLAGS += `geos-config --cflags`
- LDFLAGS += `geos-config --ldflags` -lgeos_c
- #include <geos_c.h>
-Example usage:
- capi/geostest.c contains basic usage examples.
-Using the C++ interface (discouraged)
-NB: The C++ interface should not be used directly; the geos project
-views it as a bug for another program to use the C++ interface or even
-to directly link against the C++ library. The C++ library name will
-change on every minor release because it is too hard to know if there
-have been ABI changes. (The C libary uses the C++ interface, but the
-C library follows normal ABI-change-sensitive versioning, so programs
-that link only against the C library should work without relinking
-when geos is upgraded.)
-To compile programs against the C++ lib:
- #include <geos.h>
-Example usage:
- doc/example.cpp contains basic usage examples.
-Scripting language bindings
-Ruby bindings are fully supported. To build, use the --enable-ruby option
-when configuring:
- ./configure ... --enable-ruby
-PHP bindings are fully supported. To build, use the --enable-php option
-when configuring:
- ./configure ... --enable-php
-Since version 3.0, the Python bindings are unsupported. Recommended options:
- 1. Become or recruit a new maintainer.
- 2. Use Shapely (http://pypi.python.org/pypi/Shapely) with Python
- versions 2.4 or greater.
- 3. Simply call functions from libgeos_c via Python ctypes.
-DOCUMENTATION
- cd doc; make doxygen-html
- http://trac.osgeo.org/geos
Modified: trunk/README.md
--- trunk/README.md 2016-04-23 13:16:23 UTC (rev 4198)
+++ trunk/README.md 2016-04-23 14:47:41 UTC (rev 4199)
@@ -1,5 +1,12 @@
+GEOS -- Geometry Engine, Open Source
+Project homepage: http://geos.osgeo.org/
+## Build status
Debbie:
(http://debbie.postgis.net:8080/view/GEOS/job/GEOS_Trunk/)
Travis:
@@ -11,7 +18,104 @@
(https://drone.io/github.com/libgeos/libgeos/latest)
-This file is here to play nicely with modern code repositories.
-Actual readme is [here](README).
+## Building, testing, installing
-Project homepage: http://geos.osgeo.org/
+### Unix
+Using Autotools:
+ ./autogen.sh # in ${srcdir}, if obtained from SVN or GIT
+ ${srcdir}/configure # in build dir
+Using CMake:
+ cmake ${srcdir} # in build dir
+Now, all versions:
+ make
+ make check
+ make install # as root
+ ldconfig # as root
+### Microsoft Windows
+If you use Microsoft Visual C++ (7.1 or later) compiler, you can build
+GEOS using NMAKE program and provided `makefile.vc` files.
+If you are building from SVN or GIT checkout, first run: `autogen.bat`
+Then:
+ nmake /f makefile.vc MSVC_VER=1400
+where 1400 is version number of Visual C++ compiler, here Visual C++ 8.0
+from Visual Studio 2005 (supported versions are 1300, 1310, 1400 and 1500).
+The bootstrap.bat step is required to generate a couple of header files.
+In order to build debug configuration of GEOS, additional flag `DEBUG=1`
+is required:
+ nmake /f makefile.vc MSVC_VER=1400 DEBUG=1
+## Client applications
+### Using the C interface (recommended)
+To compile programs against the C lib (recommended):
+ CFLAGS += `geos-config --cflags`
+ LDFLAGS += `geos-config --ldflags` -lgeos_c
+ #include <geos_c.h>
+Example usage:
+ capi/geostest.c contains basic usage examples.
+### Using the C++ interface (discouraged)
+NB: The C++ interface should not be used directly; the GEOS project
+views it as a bug for another program to use the C++ interface or even
+to directly link against the C++ library. The C++ library name will
+change on every minor release because it is too hard to know if there
+have been ABI changes. (The C library uses the C++ interface, but the
+C library follows normal ABI-change-sensitive versioning, so programs
+that link only against the C library should work without relinking
+when GEOS is upgraded.)
+To compile programs against the C++ lib:
+ #include <geos.h>
+Basic usage examples can be found in `doc/example.cpp`.
+### Scripting language bindings
+Ruby bindings are fully supported. To build, use the `--enable-ruby` option
+when configuring:
+ ./configure ... --enable-ruby
+PHP bindings are fully supported. To build, use the `--enable-php` option
+when configuring:
+ ./configure ... --enable-php
+Since version 3.0, the Python bindings are unsupported. Recommended options:
+ 1. Become or recruit a new maintainer.
+ 2. Use [Shapely](http://pypi.python.org/pypi/Shapely) with Python
+ versions 2.4 or greater.
+ 3. Simply call functions from libgeos_c via Python ctypes.
+## Documentation
+To build Doxygen documentation:
+ cd doc
+ make doxygen-html
More information about the geos-commits
