[geos-commits] r4308 - in trunk: src/io tests/unit/io
Sandro Santilli
strk at kbt.io
Thu Dec 1 06:50:01 PST 2016
Author: strk
Date: 2016-12-01 06:50:01 -0800 (Thu, 01 Dec 2016)
New Revision: 4308
trunk/src/io/WKBWriter.cpp
trunk/tests/unit/io/WKBWriterTest.cpp
Fixed WKB representation of empty polygon.
Patch by Sergey Fedoseev
Closes #680.
Modified: trunk/src/io/WKBWriter.cpp
--- trunk/src/io/WKBWriter.cpp 2016-11-22 10:49:34 UTC (rev 4307)
+++ trunk/src/io/WKBWriter.cpp 2016-12-01 14:50:01 UTC (rev 4308)
@@ -163,6 +163,11 @@
writeGeometryType(WKBConstants::wkbPolygon, g.getSRID());
writeSRID(g.getSRID());
+ if (g.isEmpty()) {
+ writeInt(0);
+ return;
std::size_t nholes = g.getNumInteriorRing();
writeInt(nholes+1);
Modified: trunk/tests/unit/io/WKBWriterTest.cpp
--- trunk/tests/unit/io/WKBWriterTest.cpp 2016-11-22 10:49:34 UTC (rev 4307)
+++ trunk/tests/unit/io/WKBWriterTest.cpp 2016-12-01 14:50:01 UTC (rev 4308)
@@ -159,6 +159,30 @@
+ // 5 - Check WKB representation of empty polygon
+ // See http://trac.osgeo.org/geos/ticket/680
+ template<>
+ template<>
+ void object::test<5>()
+ geos::geom::Geometry *geom = wktreader.read("POLYGON EMPTY");
+ geom->setSRID(4326);
+ std::stringstream result_stream;
+ wkbwriter.setOutputDimension( 2 );
+ wkbwriter.setByteOrder( 1 );
+ wkbwriter.setIncludeSRID( 1 );
+ wkbwriter.writeHEX( *geom, result_stream );
+ std::string actual = result_stream.str();
+ ensure_equals( actual, "0103000020E610000000000000" );
+ geos::geom::Geometry *geom2 = wkbreader.readHEX(result_stream);
+ assert( geom->equals(geom2) );
+ delete geom;
+ delete geom2;
} // namespace tut
More information about the geos-commits
