[geos-commits] r4154 - trunk/tests/unit/operation/overlay
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Feb 29 12:43:50 PST 2016
Author: mloskot
Date: 2016-02-29 12:43:50 -0800 (Mon, 29 Feb 2016)
New Revision: 4154
   trunk/tests/unit/operation/overlay/OverlayOpUnionTest.cpp
Add clean-up missing from r4153.
It should fix the failing build on Travis SI.
Modified: trunk/tests/unit/operation/overlay/OverlayOpUnionTest.cpp
--- trunk/tests/unit/operation/overlay/OverlayOpUnionTest.cpp	2016-02-29 17:59:06 UTC (rev 4153)
+++ trunk/tests/unit/operation/overlay/OverlayOpUnionTest.cpp	2016-02-29 20:43:50 UTC (rev 4154)
@@ -32,7 +32,7 @@
     typedef test_group<test_overlayopunion_data> group;
     typedef group::object object;
-    group test_issimpleop_group("geos::operation::OverlayOp::UNION");
+    group test_overlayopunion_group("geos::operation::OverlayOp::UNION");
     // Test Cases
More information about the geos-commits mailing list
