[geos-commits] r4236 - trunk/docker/build-test
Sandro Santilli
strk at kbt.io
Tue Jul 19 11:26:07 PDT 2016
Author: strk
Date: 2016-07-19 11:26:07 -0700 (Tue, 19 Jul 2016)
New Revision: 4236
trunk/docker/build-test/Dockerfile
Reduce size of build-test image
Modified: trunk/docker/build-test/Dockerfile
--- trunk/docker/build-test/Dockerfile 2016-07-16 07:41:27 UTC (rev 4235)
+++ trunk/docker/build-test/Dockerfile 2016-07-19 18:26:07 UTC (rev 4236)
@@ -2,5 +2,4 @@
RUN apk add --update automake g++ gcc libtool
RUN apk add --update make
RUN apk add --update autoconf
-RUN apk add --update git
More information about the geos-commits
