[geos-commits] r4218 - trunk
Mateusz Loskot
mateusz at loskot.net
Thu Jun 9 09:25:04 PDT 2016
Author: mloskot
Date: 2016-06-09 09:25:03 -0700 (Thu, 09 Jun 2016)
New Revision: 4218
trunk/CMakeLists.txt
Fix CMake syntax.
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt 2016-06-09 15:34:14 UTC (rev 4217)
+++ trunk/CMakeLists.txt 2016-06-09 16:25:03 UTC (rev 4218)
@@ -267,7 +267,7 @@
# CI builds (Travis CI, AppVeyor, etc.) perform git clone, not svn checkout.
# So, CI environment needs a dummy revision to generate the required header.
- if (DEFINED ENV{CI}
+ if (DEFINED ENV{CI})
set(Project_WC_REVISION 999999)
endif()
More information about the geos-commits
