[geos-commits] r4156 - trunk/tests/unit/capi
svn_geos at osgeo.org
Tue Mar 1 05:33:51 PST 2016
Author: mloskot
Date: 2016-03-01 05:33:51 -0800 (Tue, 01 Mar 2016)
New Revision: 4156
trunk/tests/unit/capi/GEOSContainsTest.cpp
trunk/tests/unit/capi/GEOSPreparedGeometryTest.cpp
Add test for polygon containment where two polygons share some of vertices or vertices of inner polygon lay on boundary of outer polygon.
Tests also compare results depending on used precision model.
Modified: trunk/tests/unit/capi/GEOSContainsTest.cpp
--- trunk/tests/unit/capi/GEOSContainsTest.cpp 2016-02-29 20:45:01 UTC (rev 4155)
+++ trunk/tests/unit/capi/GEOSContainsTest.cpp 2016-03-01 13:33:51 UTC (rev 4156)
@@ -4,6 +4,8 @@
#include <tut.hpp>
// geos
#include <geos_c.h>
+#include <geos/io/WKBReader.h>
+#include <geos/geom/PrecisionModel.h>
// std
#include <cstdarg>
#include <cstdio>
@@ -115,6 +117,80 @@
ensure_equals(int(r2), 0);
+ // Test outer polygon contains inner polygon with two coincident vertices
+ // with results compared depending on precision used with FIXED PMs.
+ template<>
+ template<>
+ void object::test<4>()
+ // Coincident vertives of both polygons at
+ // -700.67089999181 93743.4218587986, -713.450135807349 93754.1677576647,
+ std::string const outer("01030000800100000009000000af9dd0005ee585c0f802efbff6e2f6400000000000000000955acde0994b86c039a922afa2e3f64000000000000000002af6fb4f5d1887c07adb1c4071e3f6400000000000000000e5962b388d4f87c0bd3aeda7bae2f640000000000000000087c61344030887c07d585e6ff6e1f6400000000000000000fc8a31b5166186c0230588b20ae1f640000000000000000034733daf050186c0ed9f3ac98ae1f6400000000000000000f190aef659b385c0df2876538ce2f6400000000000000000af9dd0005ee585c0f802efbff6e2f6400000000000000000");
+ std::string const inner("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");
+ // A contains B if precision is limited to 1e+10
+ geos::geom::PrecisionModel pm(1e+10);
+ geos::geom::GeometryFactory::unique_ptr factory = geos::geom::GeometryFactory::create(&pm);
+ geos::io::WKBReader reader(*factory);
+ std::istringstream sOuter(outer);
+ geom1_ = reinterpret_cast<GEOSGeometry*>(reader.readHEX(sOuter));
+ std::istringstream sInner(inner);
+ geom2_ = reinterpret_cast<GEOSGeometry*>(reader.readHEX(sInner));
+ ensure(0 != geom1_);
+ ensure(0 != geom2_);
+ int ret = GEOSContains(geom1_, geom2_);
+ ensure_equals(ret, 1);
+ ret = GEOSContains(geom2_, geom1_);
+ ensure_equals(ret, 0);
+ // A does NOT contain B if precision is extended to 1e+11 or beyond
+ geos::geom::PrecisionModel pm(1e+11);
+ // Test outer rectangle contains inner rectangle with one coincident vertex
+ // and two vertices of the inner rectangle are on the boundary (lay on segments)
+ // of the outer rectangle.
+ template<>
+ template<>
+ void object::test<5>()
+ geos::geom::PrecisionModel pm; // (1e+13);
+ // Coincident vertext at -753.167968418005 93709.4279185742
+ //POLYGON ((-753.167968418005 93754.0955183194,-816.392328351464 93754.0955183194,-816.392328351464 93709.4279185742,-753.167968418005 93709.4279185742,-753.167968418005 93754.0955183194))
+ std::string const outer("01030000800100000005000000bd70d3ff578987c09e373e87a1e3f6400000000000000000a9f60b7d238389c09e373e87a1e3f6400000000000000000a9f60b7d238389c09625c1d8d6e0f6400000000000000000bd70d3ff578987c09625c1d8d6e0f6400000000000000000bd70d3ff578987c09e373e87a1e3f6400000000000000000");
+ //POLYGON ((-753.167968418005 93747.6909727677,-799.641978447015 93747.6909727677,-799.641978447015 93709.4279185742,-753.167968418005 93709.4279185742,-753.167968418005 93747.6909727677))
+ std::string const inner("01030000800100000005000000bd70d3ff578987c0f875390e3be3f6400000000000000000579598c522fd88c0f875390e3be3f6400000000000000000579598c522fd88c09625c1d8d6e0f6400000000000000000bd70d3ff578987c09625c1d8d6e0f6400000000000000000bd70d3ff578987c0f875390e3be3f6400000000000000000");
} // namespace tut
Modified: trunk/tests/unit/capi/GEOSPreparedGeometryTest.cpp
--- trunk/tests/unit/capi/GEOSPreparedGeometryTest.cpp 2016-02-29 20:45:01 UTC (rev 4155)
+++ trunk/tests/unit/capi/GEOSPreparedGeometryTest.cpp 2016-03-01 13:33:51 UTC (rev 4156)
@@ -257,7 +257,115 @@
- // TODO: add lots of more tests
+ template<>
+ template<>
+ void object::test<10>()
+ geos::geom::PrecisionModel pm(1e+10); // NOTE: higher precision fails this test case
+ prepGeom1_ = GEOSPrepare(geom1_);
+ ensure(0 != prepGeom1_);
+ int ret = GEOSPreparedContains(prepGeom1_, geom2_);
+ ret = GEOSPreparedContainsProperly(prepGeom1_, geom2_);
+ // Precision model should not affect the containment test result.
+ template<>
+ template<>
+ void object::test<11>()
+ // A contains B if FLOATING PM is used with extended precision
} // namespace tut
More information about the geos-commits
