[geos-commits] r4158 - trunk/tests/unit/capi
svn_geos at osgeo.org svn_geos at osgeo.org
Tue Mar 1 05:43:09 PST 2016
Author: mloskot
Date: 2016-03-01 05:43:09 -0800 (Tue, 01 Mar 2016)
New Revision: 4158
   trunk/tests/unit/capi/GEOSContainsTest.cpp
Unify GEOSContains test cases added in r4156 with corresponding tests in GEOSPreparedGeometryTest
Modified: trunk/tests/unit/capi/GEOSContainsTest.cpp
--- trunk/tests/unit/capi/GEOSContainsTest.cpp	2016-03-01 13:38:48 UTC (rev 4157)
+++ trunk/tests/unit/capi/GEOSContainsTest.cpp	2016-03-01 13:43:09 UTC (rev 4158)
@@ -171,30 +171,54 @@
     // Test outer rectangle contains inner rectangle with one coincident vertex
     // and two vertices of the inner rectangle are on the boundary (lay on segments)
     // of the outer rectangle.
+    // Precision model should not affect the containment test result.
     template<>
     template<>
     void object::test<5>()
-        geos::geom::PrecisionModel pm; // (1e+13);
-        geos::geom::GeometryFactory::unique_ptr factory = geos::geom::GeometryFactory::create(&pm);
-        geos::io::WKBReader reader(*factory);
         // Coincident vertext at -753.167968418005 93709.4279185742
         //POLYGON ((-753.167968418005 93754.0955183194,-816.392328351464 93754.0955183194,-816.392328351464 93709.4279185742,-753.167968418005 93709.4279185742,-753.167968418005 93754.0955183194))
         std::string const outer("01030000800100000005000000bd70d3ff578987c09e373e87a1e3f6400000000000000000a9f60b7d238389c09e373e87a1e3f6400000000000000000a9f60b7d238389c09625c1d8d6e0f6400000000000000000bd70d3ff578987c09625c1d8d6e0f6400000000000000000bd70d3ff578987c09e373e87a1e3f6400000000000000000");
-        std::istringstream sOuter(outer);
-        geom1_ = reinterpret_cast<GEOSGeometry*>(reader.readHEX(sOuter));
         //POLYGON ((-753.167968418005 93747.6909727677,-799.641978447015 93747.6909727677,-799.641978447015 93709.4279185742,-753.167968418005 93709.4279185742,-753.167968418005 93747.6909727677))
         std::string const inner("01030000800100000005000000bd70d3ff578987c0f875390e3be3f6400000000000000000579598c522fd88c0f875390e3be3f6400000000000000000579598c522fd88c09625c1d8d6e0f6400000000000000000bd70d3ff578987c09625c1d8d6e0f6400000000000000000bd70d3ff578987c0f875390e3be3f6400000000000000000");
-        std::istringstream sInner(inner);
-        geom2_ = reinterpret_cast<GEOSGeometry*>(reader.readHEX(sInner));
-        ensure(0 != geom1_);
-        ensure(0 != geom2_);
-        int ret = GEOSContains(geom1_, geom2_);
-        ensure_equals(ret, 1);
-        ret = GEOSContains(geom2_, geom1_);
-        ensure_equals(ret, 0);
+        // A contains B if precision is limited to 1e+10
+            geos::geom::PrecisionModel pm(1e+10);
+            geos::geom::GeometryFactory::unique_ptr factory = geos::geom::GeometryFactory::create(&pm);
+            geos::io::WKBReader reader(*factory);
+            std::istringstream sOuter(outer);
+            geom1_ = reinterpret_cast<GEOSGeometry*>(reader.readHEX(sOuter));
+            std::istringstream sInner(inner);
+            geom2_ = reinterpret_cast<GEOSGeometry*>(reader.readHEX(sInner));
+            ensure(0 != geom1_);
+            ensure(0 != geom2_);
+            int ret = GEOSContains(geom1_, geom2_);
+            ensure_equals(ret, 1);
+            ret = GEOSContains(geom2_, geom1_);
+            ensure_equals(ret, 0);
+        // A contains B if FLOATING PM is used with extended precision
+            geos::geom::PrecisionModel pm;
 } // namespace tut
More information about the geos-commits mailing list
