[geos-commits] r4168 - in trunk: include/geos/geom src/geom
svn_geos at osgeo.org
Sun Mar 6 15:28:40 PST 2016
Author: mloskot
Date: 2016-03-06 15:28:40 -0800 (Sun, 06 Mar 2016)
New Revision: 4168
trunk/include/geos/geom/Coordinate.h
trunk/include/geos/geom/Geometry.h
trunk/src/geom/Coordinate.cpp
trunk/src/geom/Geometry.cpp
Rename class private members according to _x naming convention.
Modified: trunk/include/geos/geom/Coordinate.h
--- trunk/include/geos/geom/Coordinate.h 2016-03-06 13:51:05 UTC (rev 4167)
+++ trunk/include/geos/geom/Coordinate.h 2016-03-06 23:28:40 UTC (rev 4168)
@@ -7,7 +7,7 @@
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
+ * by the Free Software Foundation.
* See the COPYING file for more information.
@@ -44,7 +44,7 @@
* Unlike objects of type Point (which contain additional
* information such as an envelope, a precision model, and spatial
* reference system information), a Coordinate only contains
- * ordinate values and accessor methods.
+ * ordinate values and accessor methods.
* Coordinate objects are two-dimensional points, with an additional
* z-ordinate. JTS does not support any operations on the z-ordinate except
@@ -54,14 +54,14 @@
* The standard comparison functions will ignore the z-ordinate.
-// Define the following to make assignments and copy constructions
+// Define the following to make assignments and copy constructions
// NON-inline (will let profilers report usages)
//#define PROFILE_COORDINATE_COPIES 1
class GEOS_DLL Coordinate {
private:
- static Coordinate nullCoord;
+ static Coordinate _nullCoord;
public:
/// A set of const Coordinate pointers
@@ -101,7 +101,7 @@
/// TODO: deprecate this, move logic to CoordinateLessThen instead
int compareTo(const Coordinate& other) const;
- /// 3D comparison
+ /// 3D comparison
bool equals3D(const Coordinate& other) const;
/// Returns a string of the form <I>(x,y,z)</I> .
Modified: trunk/include/geos/geom/Geometry.h
--- trunk/include/geos/geom/Geometry.h 2016-03-06 13:51:05 UTC (rev 4167)
+++ trunk/include/geos/geom/Geometry.h 2016-03-06 23:28:40 UTC (rev 4168)
@@ -9,7 +9,7 @@
@@ -147,17 +147,17 @@
* that the coordinates of an intersection point may contain twice as many bits
* of precision as the coordinates of the input line segments. In order to
* represent these constructed points explicitly, JTS must truncate them to fit
- * the PrecisionModel.
+ * the PrecisionModel.
* Unfortunately, truncating coordinates moves them slightly. Line segments
* which would not be coincident in the exact result may become coincident in
* the truncated representation. This in turn leads to "topology collapses" --
* situations where a computed element has a lower dimension than it would in
- * the exact result.
+ * the exact result.
* When JTS detects topology collapses during the computation of spatial
* analysis methods, it will throw an exception. If possible the exception will
- * report the location of the collapse.
+ * report the location of the collapse.
* equals(Object) and hashCode are not overridden, so that when two
* topologically equal Geometries are added to HashMaps and HashSets, they
@@ -193,7 +193,7 @@
* @return the factory for this geometry
- const GeometryFactory* getFactory() const { return factory; }
+ const GeometryFactory* getFactory() const { return _factory; }
* \brief
@@ -201,14 +201,14 @@
* a Geometry.
* An example use might be to add an object representing a
* Coordinate Reference System.
* Note that user data objects are not present in geometries created
* by construction methods.
* @param newUserData an object, the semantics for which are
* defined by the application using this Geometry
- void setUserData(void* newUserData) { userData=newUserData; }
+ void setUserData(void* newUserData) { _userData=newUserData; }
* \brief
@@ -216,7 +216,7 @@
* @return the user data object, or <code>null</code> if none set
- void* getUserData() { return userData; }
+ void* getUserData() { return _userData; }
* \brief
@@ -264,7 +264,7 @@
virtual std::size_t getNumPoints() const=0; //Abstract
/// Returns false if the Geometry not simple.
- virtual bool isSimple() const;
+ virtual bool isSimple() const;
/// Return a string representation of this Geometry type
virtual std::string getGeometryType() const=0; //Abstract
@@ -308,7 +308,7 @@
* Returns the boundary, or an empty geometry of appropriate
* dimension if this <code>Geometry</code> is empty.
- * (In the case of zero-dimensional geometries,
+ * (In the case of zero-dimensional geometries,
* an empty GeometryCollection is returned.)
* For a discussion of this function, see the OpenGIS Simple
* Features Specification. As stated in SFS Section 2.1.13.1,
@@ -335,7 +335,7 @@
* Tests whether this geometry is disjoint from the specified geometry.
* The <code>disjoint</code> predicate has the following equivalent
* definitions:
* - The two geometries have no point in common
@@ -362,7 +362,7 @@
* Tests whether this geometry crosses the specified geometry.
* The <code>crosses</code> predicate has the following equivalent
* definitions:
* - The geometries have some but not all interior points in common.
@@ -372,7 +372,7 @@
* - <code>[0********]</code> (for L/L situations)
* For any other combination of dimensions this predicate returns
* <code>false</code>.
* The SFS defined this predicate only for P/L, P/A, L/L, and L/A
* situations.
* JTS extends the definition to apply to L/P, A/P and A/L situations
@@ -438,10 +438,10 @@
/** \brief
* Returns <code>true</code> if this geometry covers the
* specified geometry.
* The <code>covers</code> predicate has the following
* equivalent definitions:
* - Every point of the other geometry is a point of this geometry.
* - The DE-9IM Intersection Matrix for the two geometries is
* <code>T*****FF*</code>
@@ -450,7 +450,7 @@
* or <code>****T*FF*</code>
* - <code>g.coveredBy(this)</code>
* (<code>covers</code> is the inverse of <code>coveredBy</code>)
* If either geometry is empty, the value of this predicate
* is <tt>false</tt>.
@@ -463,10 +463,10 @@
* As an added benefit, <code>covers</code> is more amenable to
* optimization, and hence should be more performant.
- * @param g
+ * @param g
* the <code>Geometry</code> with which to compare this
* <code>Geometry</code>
* @return <code>true</code> if this <code>Geometry</code>
* covers <code>g</code>
@@ -490,10 +490,10 @@
* or <code>[**F*TF***]</code>
* - <code>g.covers(this)</code>
* (<code>coveredBy</code> is the converse of <code>covers</code>)
* This predicate is similar to {@link #within},
* but is more inclusive (i.e. returns <tt>true</tt> for more cases).
@@ -514,7 +514,7 @@
virtual std::string toString() const;
virtual std::string toText() const;
/// Returns a buffer region around this Geometry having the given width.
/// @throws util::TopologyException if a robustness error occurs
@@ -534,7 +534,7 @@
* Computes a buffer area around this geometry having the given
* width and with a specified accuracy of approximation for circular
* arcs, and using a specified end cap style.
* Buffer area boundaries can contain circular arcs.
* To represent these arcs using linear geometry they must be
* approximated with line segments.
@@ -542,16 +542,16 @@
* The <code>quadrantSegments</code> argument allows controlling the
* accuracy of the approximation by specifying the number of line
* segments used to represent a quadrant of a circle
* The end cap style specifies the buffer geometry that will be
* created at the ends of linestrings. The styles provided are:
* - BufferOp::CAP_ROUND - (default) a semi-circle
* - BufferOp::CAP_BUTT - a straight line perpendicular to the
* end segment
* - BufferOp::CAP_SQUARE - a half-square
* @param distance the width of the buffer
* (may be positive, negative or 0)
@@ -600,9 +600,9 @@
* Computes the union of all the elements of this geometry. Heterogeneous
* {@link GeometryCollection}s are fully supported.
* The result obeys the following contract:
* - Unioning a set of {@link LineString}s has the effect of fully noding
* and dissolving the linework.
* - Unioning a set of {@link Polygon}s will always
@@ -676,7 +676,7 @@
* Apply a fiter to each component of this geometry.
* The filter is expected to provide a .filter(const Geometry*)
* method.
* I intend similar templated methods to replace
* all the virtual apply_rw and apply_ro functions...
* --strk(2005-02-06);
@@ -766,7 +766,7 @@
/// The bounding box of this Geometry
mutable std::auto_ptr<Envelope> envelope;
/// Returns true if the array contains any non-empty Geometrys.
static bool hasNonEmptyElements(const std::vector<Geometry *>* geometries);
@@ -844,9 +844,9 @@
/// Externally owned
- const GeometryFactory *factory;
+ const GeometryFactory* _factory;
- void* userData;
+ void* _userData;
/// \brief
Modified: trunk/src/geom/Coordinate.cpp
--- trunk/src/geom/Coordinate.cpp 2016-03-06 13:51:05 UTC (rev 4167)
+++ trunk/src/geom/Coordinate.cpp 2016-03-06 23:28:40 UTC (rev 4168)
@@ -7,7 +7,7 @@
@@ -28,12 +28,12 @@
namespace geos {
namespace geom { // geos::geom
-Coordinate Coordinate::nullCoord=Coordinate(DoubleNotANumber,DoubleNotANumber,DoubleNotANumber);
+Coordinate Coordinate::_nullCoord=Coordinate(DoubleNotANumber,DoubleNotANumber,DoubleNotANumber);
Coordinate&
Coordinate::getNull()
- return nullCoord;
+ return _nullCoord;
string
Modified: trunk/src/geom/Geometry.cpp
--- trunk/src/geom/Geometry.cpp 2016-03-06 13:51:05 UTC (rev 4167)
+++ trunk/src/geom/Geometry.cpp 2016-03-06 23:28:40 UTC (rev 4168)
@@ -109,21 +109,21 @@
Geometry::Geometry(const GeometryFactory *newFactory)
envelope(NULL),
- factory(newFactory),
- userData(NULL)
+ _factory(newFactory),
+ _userData(NULL)
- if ( factory == NULL ) {
- factory = GeometryFactory::getDefaultInstance();
+ if ( _factory == NULL ) {
+ _factory = GeometryFactory::getDefaultInstance();
- SRID=factory->getSRID();
- factory->addRef();
+ SRID=_factory->getSRID();
+ _factory->addRef();
Geometry::Geometry(const Geometry &geom)
SRID(geom.getSRID()),
- factory(geom.factory),
- userData(NULL)
+ _factory(geom._factory),
+ _userData(NULL)
if ( geom.envelope.get() )
@@ -132,8 +132,8 @@
//factory=geom.factory;
//envelope(new Envelope(*(geom.envelope.get())));
//SRID=geom.getSRID();
- //userData=NULL;
+ //_userData=NULL;
bool
@@ -578,7 +578,7 @@
v->push_back(other->clone());
- out = factory->buildGeometry(v);
+ out = _factory->buildGeometry(v);
return out;
#endif
@@ -642,7 +642,7 @@
- return factory->buildGeometry(v);
+ return _factory->buildGeometry(v);
return BinaryOp(this, other, overlayOp(OverlayOp::opSYMDIFFERENCE)).release();
@@ -810,7 +810,7 @@
Geometry::~Geometry()
- factory->dropRef();
+ _factory->dropRef();
bool
@@ -870,7 +870,7 @@
const PrecisionModel*
Geometry::getPrecisionModel() const
- return factory->getPrecisionModel();
+ return _factory->getPrecisionModel();
} // namespace geos::geom
More information about the geos-commits
