[geos-commits] r4175 - trunk/tests/unit/geom/Geometry
svn_geos at osgeo.org
Fri Mar 11 22:40:45 PST 2016
Author: mloskot
Date: 2016-03-11 22:40:45 -0800 (Fri, 11 Mar 2016)
New Revision: 4175
trunk/tests/unit/geom/Geometry/coversTest.cpp
Add test for Geometry::touches
Modified: trunk/tests/unit/geom/Geometry/coversTest.cpp
--- trunk/tests/unit/geom/Geometry/coversTest.cpp 2016-03-07 23:15:10 UTC (rev 4174)
+++ trunk/tests/unit/geom/Geometry/coversTest.cpp 2016-03-12 06:40:45 UTC (rev 4175)
@@ -1,12 +1,11 @@
-// Test Suite for Geometry's covers(), coveredBy() and contains() functions
+// Test Suite for Geometry's touches() functions
// tut
#include <tut.hpp>
// geos
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/Geometry.h>
-#include <geos/geom/Polygon.h>
#include <geos/io/WKTReader.h>
// std
#include <memory>
@@ -18,108 +17,96 @@
// Test Group
-struct test_contains_data
+struct test_touches_data
- typedef std::auto_ptr<geos::geom::Geometry> GeomAutoPtr;
- typedef geos::geom::GeometryFactory GeometryFactory;
+ typedef std::auto_ptr<geos::geom::Geometry> GeomAutoPtr;
+ typedef geos::geom::GeometryFactory GeometryFactory;
- geos::geom::GeometryFactory::unique_ptr factory;
- geos::io::WKTReader reader;
+ geos::geom::GeometryFactory::unique_ptr factory;
+ geos::io::WKTReader reader;
- test_contains_data()
- : factory(GeometryFactory::create())
- , reader(factory.get())
+ test_touches_data()
+ : factory(GeometryFactory::create())
+ , reader(factory.get())
-typedef test_group<test_contains_data> group;
+typedef test_group<test_touches_data> group;
typedef group::object object;
-group test_contains_data("geos::geom::Geometry::covers");
+group test_touches_data("geos::geom::Geometry::touches");
// Test Cases
-// 1 - Boundaries touch, still g1 covers g2
+// 1 - Point/Point do not touch
template<>
template<>
void object::test<1>()
- GeomAutoPtr g1(reader.read(
- "POLYGON ((0 0, 0 100, 100 100, 100 0, 0 0))"
- GeomAutoPtr g2(reader.read(
- "POLYGON ((0 0, 0 100, 90 90, 90 0, 0 0))"
+ GeomAutoPtr g1(reader.read(
+ "POINT (0 0)"
- ensure( g1->covers(g2.get()) );
- ensure( g2->coveredBy(g1.get()) );
+ GeomAutoPtr g2(reader.read(
+ "POINT (0 0)"
+ ensure(!g1->touches(g2.get()));
+ ensure(!g2->touches(g1.get()));
-// 2 - Polygon covers line (laying on it's boundary)
+// 2 - Line/Point do not touch if point is not on boundary
template<>
template<>
void object::test<2>()
- "LINESTRING (0 0, 0 100)"
+ "LINESTRING(0 0, 1 1, 0 2)"
- ensure( ! g1->contains(g2.get()) );
+ "POINT (1 1)"
-// 3 - Line covers point (laying on it's boundary or interior)
+// 3 - Line/Point touch
template<>
template<>
void object::test<3>()
- "POINT(0 0)"
+ "POINT (0 2)"
- g2.reset(reader.read(
- "POINT(0 2)"
- ensure( g1->contains(g2.get()) );
+ ensure(g1->touches(g2.get()));
+ ensure(g2->touches(g1.get()));
-// 4 - http://trac.osgeo.org/geos/ticket/580
+// 4 - Line/Point touch (FP coordinates)
template<>
template<>
void object::test<4>()
- "POLYGON ((-1.183864 52.951915, -1.183862 52.951903, -1.183890 52.951900, -1.183924 52.951897, -1.183958 52.951894, -1.183954 52.951880, -1.183954 52.951878, -1.183932 52.951841, -1.183904 52.951844, -1.183870 52.951847, -1.183832 52.951852, -1.183824 52.951838, -1.183820 52.951830, -1.183870 52.951819, -1.183886 52.951815, -1.183890 52.951819, -1.183929 52.951810, -1.183909 52.951776, -1.183861 52.951787, -1.183853 52.951788, -1.183842 52.951770, -1.183970 52.951742, -1.183983 52.951763, -1.183963 52.951768, -1.183975 52.951788, -1.183994 52.951785, -1.184009 52.951807, -1.184002 52.951808, -1.184009 52.951835, -1.183990 52.951836, -1.183990 52.951836, -1.183990 52.951838, -1.184001 52.951880, -1.184018 52.951954, -1.184020 52.951956, -1.183998 52.951957, -1.183998 52.951956, -1.183996 52.951948, -1.183970 52.951906, -1.183936 52.951909, -1.183864 52.951915))"
- "POINT (-1.183972 52.951871)"
+ "LINESTRING (-612844.96290006 279079.117329031,-257704.820935236 574364.179187424)"
+ "POINT (-257704.820935236 574364.179187424)"
} // namespace tut
More information about the geos-commits
