[geos-commits] r4177 - trunk/tests/unit/geom/Geometry
svn_geos at osgeo.org
Fri Mar 11 22:49:53 PST 2016
Author: mloskot
Date: 2016-03-11 22:49:53 -0800 (Fri, 11 Mar 2016)
New Revision: 4177
Added:
trunk/tests/unit/geom/Geometry/touchesTest.cpp
Add test for Geometry::touches
Added: trunk/tests/unit/geom/Geometry/touchesTest.cpp
--- trunk/tests/unit/geom/Geometry/touchesTest.cpp (rev 0)
+++ trunk/tests/unit/geom/Geometry/touchesTest.cpp 2016-03-12 06:49:53 UTC (rev 4177)
@@ -0,0 +1,111 @@
+// Test Suite for Geometry's touches() functions
+// tut
+#include <tut.hpp>
+// geos
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Geometry.h>
+#include <geos/io/WKTReader.h>
+// std
+#include <memory>
+#include <string>
+namespace tut {
+// Test Group
+struct test_touches_data
+ typedef std::auto_ptr<geos::geom::Geometry> GeomAutoPtr;
+ typedef geos::geom::GeometryFactory GeometryFactory;
+ geos::geom::GeometryFactory::unique_ptr factory;
+ geos::io::WKTReader reader;
+ test_touches_data()
+ : factory(GeometryFactory::create())
+ , reader(factory.get())
+typedef test_group<test_touches_data> group;
+typedef group::object object;
+group test_touches_data("geos::geom::Geometry::touches");
+// Test Cases
+// 1 - Point/Point do not touch
+template<>
+template<>
+void object::test<1>()
+ GeomAutoPtr g1(reader.read(
+ "POINT (0 0)"
+ GeomAutoPtr g2(reader.read(
+ "POINT (0 0)"
+ ensure(!g1->touches(g2.get()));
+ ensure(!g2->touches(g1.get()));
+// 2 - Line/Point do not touch if point is not on boundary
+template<>
+template<>
+void object::test<2>()
+ "LINESTRING(0 0, 1 1, 0 2)"
+ "POINT (1 1)"
+// 3 - Line/Point touch
+template<>
+template<>
+void object::test<3>()
+ "POINT (0 2)"
+ ensure(g1->touches(g2.get()));
+ ensure(g2->touches(g1.get()));
+// 4 - Line/Point touch (FP coordinates)
+template<>
+template<>
+void object::test<4>()
+ "LINESTRING (-612844.96290006 279079.117329031,-257704.820935236 574364.179187424)"
+ "POINT (-257704.820935236 574364.179187424)"
+} // namespace tut
More information about the geos-commits
