[geos-commits] r4179 - in trunk/tests/unit/geom/prep: . PreparedGeometry
svn_geos at osgeo.org
Fri Mar 11 23:35:49 PST 2016
Author: mloskot
Date: 2016-03-11 23:35:49 -0800 (Fri, 11 Mar 2016)
New Revision: 4179
Added:
trunk/tests/unit/geom/prep/PreparedGeometry/
trunk/tests/unit/geom/prep/PreparedGeometry/touchesTest.cpp
Add test for PreparedGeometry::touches
Added: trunk/tests/unit/geom/prep/PreparedGeometry/touchesTest.cpp
--- trunk/tests/unit/geom/prep/PreparedGeometry/touchesTest.cpp (rev 0)
+++ trunk/tests/unit/geom/prep/PreparedGeometry/touchesTest.cpp 2016-03-12 07:35:49 UTC (rev 4179)
@@ -0,0 +1,134 @@
+// Test Suite for PreparedGeometry's touches() functions
+// tut
+#include <tut.hpp>
+#include <utility.h>
+// geos
+#include <geos/geom/prep/PreparedGeometryFactory.h>
+#include <geos/geom/prep/PreparedGeometry.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Geometry.h>
+#include <geos/io/WKTReader.h>
+// std
+#include <memory>
+using namespace geos::geom;
+namespace tut {
+// Test Group
+struct test_preparedgeometrytouches_data
+ typedef std::auto_ptr<geos::geom::prep::PreparedGeometry> PrepGeomAutoPtr;
+ typedef geos::geom::GeometryFactory GeometryFactory;
+ geos::geom::GeometryFactory::unique_ptr factory;
+ geos::io::WKTReader reader;
+ GeometryPtr g1;
+ GeometryPtr g2;
+ PreparedGeometryPtr pg1;
+ PreparedGeometryPtr pg2;
+ test_preparedgeometrytouches_data()
+ : factory(GeometryFactory::create())
+ , reader(factory.get())
+ , g1(0)
+ , g2(0)
+ , pg1(0)
+ , pg2(0)
+ ~test_preparedgeometrytouches_data()
+ prep::PreparedGeometryFactory::destroy(pg1);
+ prep::PreparedGeometryFactory::destroy(pg2);
+ factory->destroyGeometry(g1);
+ factory->destroyGeometry(g2);
+typedef test_group<test_preparedgeometrytouches_data> group;
+typedef group::object object;
+group test_preparedgeometrytouches_data("geos::geom::prep::PreparedGeometry::touches");
+// Test Cases
+// 1 - Point/Point do not touch
+template<>
+template<>
+void object::test<1>()
+ g1 = reader.read(
+ "POINT (0 0)"
+ g2 = reader.read(
+ "POINT (0 0)"
+ pg1 = prep::PreparedGeometryFactory::prepare(g1);
+ pg2 = prep::PreparedGeometryFactory::prepare(g2);
+ ensure(!pg1->touches(g2));
+ ensure(!pg2->touches(g1));
+// 2 - Line/Point do not touch if point is not on boundary
+template<>
+template<>
+void object::test<2>()
+ g1 = reader.read(
+ "LINESTRING(0 0, 1 1, 0 2)"
+ g2 = reader.read(
+ "POINT (1 1)"
+// 3 - Line/Point touch
+template<>
+template<>
+void object::test<3>()
+ g1 = reader.read(
+ g2 = reader.read(
+ "POINT (0 2)"
+ ensure(pg1->touches(g2));
+ ensure(pg2->touches(g1));
+// 4 - Line/Point touch (FP coordinates)
+template<>
+template<>
+void object::test<4>()
+ g1 = reader.read(
+ "LINESTRING (-612844.96290006 279079.117329031,-257704.820935236 574364.179187424)"
+ g2 = reader.read(
+ "POINT (-257704.820935236 574364.179187424)"
+} // namespace tut
More information about the geos-commits
