[geos-commits] r4263 - trunk
Sandro Santilli
strk at kbt.io
Tue Oct 25 08:28:38 PDT 2016
Author: strk
Date: 2016-10-25 08:28:37 -0700 (Tue, 25 Oct 2016)
New Revision: 4263
trunk/ChangeLog
Update ChangeLog for 3.6.0 release
Modified: trunk/ChangeLog
--- trunk/ChangeLog 2016-10-25 15:05:21 UTC (rev 4262)
+++ trunk/ChangeLog 2016-10-25 15:28:37 UTC (rev 4263)
@@ -1,3 +1,1999 @@
+2016-10-25 15:05 Sandro Santilli <strk at kbt.io>
+ * [r4262] NEWS: Tweak NEWS, in preparation for 3.6.0 release
+2016-10-04 07:38 Sandro Santilli <strk at kbt.io>
+ * [r4261] src/operation/overlay/snap/LineStringSnapper.cpp: And
+ more trailing spaces
+2016-10-04 07:04 Sandro Santilli <strk at kbt.io>
+ * [r4260] include/geos/operation/overlay/snap/LineStringSnapper.h:
+ Remove more trailing blanks
+2016-10-04 06:59 Sandro Santilli <strk at kbt.io>
+ * [r4259] src/operation/overlay/snap/GeometrySnapper.cpp: Drop
+ trailing blanks
+2016-09-27 16:39 Sandro Santilli <strk at kbt.io>
+ * [r4258] capi/geos_c.h.in: wrong GEOS_DLL position
+ Should not be type* GEOS_DLL function(), but type GEOS_DLL
+ *function().
+ Doesn't build on windows before the modif
+ Patch by @bartoli
+ Closes https://github.com/libgeos/libgeos/pull/70
+2016-09-07 13:06 Sandro Santilli <strk at kbt.io>
+ * [r4257] include/geos/geom/Geometry.h,
+ include/geos/geom/LineString.h: Fix documentation typos.
+ Courtesy of Todd Trimble <todd.trimble at gmail.com>
+2016-09-07 13:05 Sandro Santilli <strk at kbt.io>
+ * [r4256] tests/unit/capi/GEOSGeom_createCollection.cpp: Fix
+ initialization order warning
+2016-09-07 13:03 Sandro Santilli <strk at kbt.io>
+ * [r4255] CMakeLists.txt: CMake: generate geos_svn_revision.h in
+ binary directory if not exists
+ Patch by Rashad Kanavath <rashad.kanavath at c-s.fr>
+2016-09-07 12:57 Sandro Santilli <strk at kbt.io>
+ * [r4254] NEWS, capi/geos_c.cpp, capi/geos_c.h.in,
+ capi/geos_ts_c.cpp, include/geos/geom/Geometry.h,
+ tests/unit/Makefile.am, tests/unit/capi/GEOSUserDataTest.cpp: Add
+ GEOSGeom_setUserData and GEOSGeom_getUserData
+2016-09-02 11:10 Sandro Santilli <strk at kbt.io>
+ * [r4253] CMakeLists.txt, src/CMakeLists.txt: Add option to build
+ static and shared. (default is build both)
+ Fixes #788
+2016-09-02 11:09 Sandro Santilli <strk at kbt.io>
+ * [r4252] authors.svn: Fix my email address
+2016-08-24 09:28 Mateusz Loskot <mateusz at loskot.net>
+ * [r4251] CMakeLists.txt: CMake now sets GEOS_BUILD_PACKAGED to
+ FALSE on CI services
+2016-08-24 08:58 Mateusz Loskot <mateusz at loskot.net>
+ * [r4250] CMakeLists.txt: Add CMake ${PROJECT_BINARY_DIR} to
+ include directories for
+ geos_ts.cpp which does #include "../geos_svn_revision.h", whereas
+ CMake generates geos_svn_revision.h in build directory, to not to
+ pollute source tree.
+2016-08-24 08:57 Mateusz Loskot <mateusz at loskot.net>
+ * [r4249] build.bat: Add convenient build.bat for Visual Studio and
+ CMake users:
+ * Runs CMake to configure 32-bit or 64-bit build with the latest
+ release of Visual Studio.
+ * Runs MSBuild to build the generated solution.
+2016-08-03 19:22 Mateusz Loskot <mateusz at loskot.net>
+ * [r4245] src/Makefile.vc: Add missing .cpp files added in r4203
+2016-08-03 19:17 Mateusz Loskot <mateusz at loskot.net>
+ * [r4244] nmake.opt: Add NMAKE version from VS2015 Update 3
+2016-07-21 19:06 Sandro Santilli <strk at kbt.io>
+ * [r4243] .drone.yml: Only run "make check", not "make distcheck"
+ ... distcheck can be run manually just before a release
+2016-07-21 18:40 Sandro Santilli <strk at kbt.io>
+ * [r4242] .drone.yml, docker/README, docker/build-test/Dockerfile,
+ docker/build-test/Makefile: Remove docker config
+ Docker configurations are not hosted on
+ https://git.osgeo.org/gogs/geos/geos-docker/
+2016-07-21 18:34 Sandro Santilli <strk at kbt.io>
+ * [r4241] src/operation/buffer/BufferOp.cpp: Do not define unused
+ function
+2016-07-21 18:25 Sandro Santilli <strk at kbt.io>
+ * [r4240] .drone.yml: Fix test-image variable use
+2016-07-21 18:20 Sandro Santilli <strk at kbt.io>
+ * [r4239] .drone.yml: Turn off optimization while building, reduce
+ clone depth
+2016-07-19 18:31 Sandro Santilli <strk at kbt.io>
+ * [r4238] web/index.html, web/style.css: Remove website content
+ Moved to https://git.osgeo.org/gogs/geos/website
+ (was obsoleted and unused anyway)
+2016-07-19 18:26 Sandro Santilli <strk at kbt.io>
+ * [r4237] .gitignore, Makefile.am, NEWS, README.md, configure.ac,
+ php/Makefile.am, php/README, php/TODO, php/geos.c,
+ php/php_geos.h, php/test/Makefile.am, php/test/crashme.php,
+ php/test/test.php: Remove PHP bindings, leave refs to separate
+ repository
+ Closes #765
+ * [r4236] docker/build-test/Dockerfile: Reduce size of build-test
+ image
+2016-07-16 07:41 Sandro Santilli <strk at kbt.io>
+ * [r4235] README.md: Add link to build status table on trac
+2016-07-16 07:25 Sandro Santilli <strk at kbt.io>
+ * [r4234] .gitignore, docker, docker/README, docker/build-test,
+ docker/build-test/Dockerfile, docker/build-test/Makefile: Add
+ configuration to make dockers for build-testing GEOS
+2016-07-15 19:38 Sandro Santilli <strk at kbt.io>
+ * [r4233] README.md: Add OSGeo/Drone badge
+2016-07-15 16:38 Sandro Santilli <strk at kbt.io>
+ * [r4231] .drone.yml: Add a "make check" step to the drone config
+2016-07-15 15:25 Sandro Santilli <strk at kbt.io>
+ * [r4230] README.md: Adds all the currently supported Visual Studio
+ versions
+ Patch by gmasetti at ccom.unh.edu
+2016-07-14 10:38 Sandro Santilli <strk at kbt.io>
+ * [r4224] include/geos/platform.h.in: Fully qualify isnan call when
+ HAVE_ISNAN is defined
+ Fixes build with GCC-5.3.0 and higher.
+ Closes #784
+2016-07-12 17:28 Sandro Santilli <strk at kbt.io>
+ * [r4221] .drone.yml: Add .drone.yml
+2016-07-09 05:34 Sandro Santilli <strk at kbt.io>
+ * [r4220] tests/perf/Makefile.am: Add missing LIBS
+ Thanks Andrew Watkins for spotting this
+2016-06-29 14:01 Mateusz Loskot <mateusz at loskot.net>
+ * [r4219] tests/unit/capi/GEOSMinimumClearanceTest.cpp: Compare inf
+ == inf instead of ensure_equals(inf, inf).
+ The latter compares the difference, but inf minus inf result is
+ indeterminate.
+2016-06-09 16:25 Mateusz Loskot <mateusz at loskot.net>
+ * [r4218] CMakeLists.txt: Fix CMake syntax.
+2016-06-09 15:34 Mateusz Loskot <mateusz at loskot.net>
+ * [r4217] CMakeLists.txt: CI builds (Travis CI, AppVeyor, etc.)
+ perform git clone, not svn checkout.
+ So, CI environment needs a dummy revision (e.g. 999999) to
+ generate the required header.
+2016-06-08 07:53 Mateusz Loskot <mateusz at loskot.net>
+ * [r4216] README.md: Fix Markdown syntax for build status table.
+2016-06-08 00:08 Mateusz Loskot <mateusz at loskot.net>
+ * [r4215] appveyor.yml: AppVeyor: add some colours
+2016-06-07 23:58 Mateusz Loskot <mateusz at loskot.net>
+ * [r4214] README.md: Add AppVeyor and Drone.io badge status.
+ Reformat build status into table by service X branch.
+2016-06-07 23:29 Mateusz Loskot <mateusz at loskot.net>
+ * [r4213] appveyor.yml: AppVeyor: Fix CMake build folder location
+2016-06-07 23:21 Mateusz Loskot <mateusz at loskot.net>
+ * [r4212] appveyor.yml: First stab at AppVeyor configuration
+2016-06-07 09:35 Mateusz Loskot <mateusz at loskot.net>
+ * [r4211] ., CMakeLists.txt: Merged revision(s) 4210 from
+ branches/3.5:
+ Update CMake configuration based on trunk/CMakeLists.txt
+2016-06-07 08:32 Mateusz Loskot <mateusz at loskot.net>
+ * [r4209] capi/geos_c.h.in,
+ include/geos/index/strtree/GeometryItemDistance.h,
+ include/geos/precision/MinimumClearance.h, src/Makefile.vc: Fix
+ Visual C++ builds with NMAKE and CMake (Ticket #777):
+ * Correct __declspec specifier placement in C API function
+ prototypes.
+ * Add GEOS_DLL missing from new classes added recently.
+ * Update makefile.vc with implementation files added recently.
+2016-05-12 09:39 Sandro Santilli <strk at kbt.io>
+ * [r4208] README.md: Revert "Cips"
+ This reverts commit c816b6747129a59f82c6ebc9a952bc11b32a48f6.
+ Sorry, was a debug commit pushed in error
+ * [r4207] README.md: Use https for debbie links
+2016-05-12 09:26 Sandro Santilli <strk at kbt.io>
+ * [r4205] README.md: Cips
+2016-04-25 20:04 Sandro Santilli <strk at kbt.io>
+ * [r4204] include/geos/operation/distance/FacetSequence.h,
+ include/geos/operation/distance/FacetSequenceTreeBuilder.h,
+ src/operation/distance/FacetSequence.cpp,
+ src/operation/distance/FacetSequenceTreeBuilder.cpp,
+ src/precision/MinimumClearance.cpp: Include hash in Last Port for
+ MinimumClearance classes
+2016-04-25 18:06 Sandro Santilli <strk at kbt.io>
+ * [r4203] NEWS, capi/geos_c.cpp, capi/geos_c.h.in,
+ capi/geos_ts_c.cpp, include/geos/index/strtree/BoundablePair.h,
+ include/geos/index/strtree/STRtree.h,
+ include/geos/operation/distance/FacetSequence.h,
+ include/geos/operation/distance/Makefile.am,
+ include/geos/precision/Makefile.am,
+ src/index/strtree/BoundablePair.cpp,
+ src/index/strtree/STRtree.cpp,
+ src/operation/distance/Makefile.am, src/precision/Makefile.am,
+ src/precision/MinimumClearance.cpp, tests/unit/Makefile.am,
+ tests/unit/capi/GEOSMinimumClearanceTest.cpp: Implement
+ GEOSMinimumClearance and GEOSMinimumClearanceLine
+ Includes tests and C-API exposure.
+ Patch by Daniel Baston <dbaston at maponics.com>
+ via https://github.com/libgeos/libgeos/pull/65
+ Closes #776
+2016-04-24 17:27 Sandro Santilli <strk at kbt.io>
+ * [r4202] .gitignore, Makefile.am, autogen.sh: Symlink README to
+ README.md at autogen.sh time
+ Should fix distcheck
+2016-04-23 15:24 Sandro Santilli <strk at kbt.io>
+ * [r4201] Makefile.am: Add rule to make README from README.md
+ README is a standard GNU file that ends up in the distribution
+2016-04-23 15:02 Sandro Santilli <strk at kbt.io>
+ * [r4200] README.md: Drop drone.io badge
+ The service times out before our tests complete, not a good one.
+2016-04-23 14:47 Sandro Santilli <strk at kbt.io>
+ * [r4199] README, README.md: Merge README into README.md
+ Thanks Mike Toews for the kickstart on this
+2016-04-23 13:16 Sandro Santilli <strk at kbt.io>
+ * [r4198] tests/unit/capi/GEOSSTRtreeTest.cpp: Correctly initialize
+ strtree in test
+ Patch by dbaston
+2016-04-22 17:57 Sandro Santilli <strk at kbt.io>
+ * [r4197] include/geos/index/strtree/Makefile.am: Fix distcheck
+ (#768)
+ Patch by Daniel Baston <dbaston at gmail.com>
+2016-04-22 16:56 Sandro Santilli <strk at kbt.io>
+ * [r4196] README.md: Add drone.io badge
+2016-04-22 16:24 Sandro Santilli <strk at kbt.io>
+ * [r4195] README.md: Add Debbie badge
+2016-04-22 15:15 Sandro Santilli <strk at kbt.io>
+ * [r4191] README.md: Add project homepage url
+ * [r4190] .travis.yml: Fix typo
+ * [r4189] README.md: Put build badges on the same line
+2016-04-22 14:41 Sandro Santilli <strk at kbt.io>
+ * [r4188] README.md: Add gitlab-ci badge
+2016-04-22 14:40 Sandro Santilli <strk at kbt.io>
+ * [r4187] .gitlab-ci.yml: Add gitlab-ci configuration
+2016-04-19 16:27 Sandro Santilli <strk at kbt.io>
+ * [r4186] capi/geos_ts_c.cpp: Move CustomItemDistance defn some
+ contexts higher
+2016-04-19 16:26 Sandro Santilli <strk at kbt.io>
+ * [r4185] capi/geos_ts_c.cpp: Trim trailing whitespaces (as per
+ .editorconfig)
+2016-04-19 16:04 Sandro Santilli <strk at kbt.io>
+ * [r4184] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp,
+ include/geos/index/strtree/BoundablePair.h,
+ include/geos/index/strtree/ItemDistance.h,
+ src/index/strtree/AbstractSTRtree.cpp,
+ src/index/strtree/GeometryItemDistance.cpp,
+ src/index/strtree/Makefile.am, src/index/strtree/STRtree.cpp,
+ tests/unit/Makefile.am, tests/unit/capi/GEOSSTRtreeTest.cpp: Add
+ GEOSSTRtree_nearest API
+ Includes tests for the new API and pre-existing STRtree API
+ Closes #768
+ via https://github.com/libgeos/libgeos/pull/61
+2016-04-12 15:17 Sandro Santilli <strk at kbt.io>
+ * [r4183] include/geos/geom/LineSegment.h: Fix 'Segemnt' typo.
+ Patch by Todd Trimble <todd.trimble at gmail.com>
+ Closes https://github.com/libgeos/libgeos/pull/63
+ * [r4182] include/geos/geom/LineSegment.h: Match .h declaration
+ parameter name with .cpp definitiion.
+ See https://github.com/libgeos/libgeos/pull/63
+2016-04-06 10:50 Sandro Santilli <strk at kbt.io>
+ * [r4181] .editorconfig: Stub an EditorConfig file
+ See http://editorconfig.org
+2016-04-05 15:26 Sandro Santilli <strk at kbt.io>
+ * [r4180] nmake.opt: Handle nmake builds with the latest MSVC
+ Patch by Jeff McKenna
+ Closes #775
+2016-03-12 07:35 Mateusz Loskot <mateusz at loskot.net>
+ * [r4179] tests/unit/geom/prep/PreparedGeometry,
+ tests/unit/geom/prep/PreparedGeometry/touchesTest.cpp: Add test
+ for PreparedGeometry::touches
+2016-03-12 07:19 Mateusz Loskot <mateusz at loskot.net>
+ * [r4178] tests/unit/geom/Geometry/touchesTest.cpp: Remove unused
+ header
+2016-03-12 06:49 Mateusz Loskot <mateusz at loskot.net>
+ * [r4177] tests/unit/geom/Geometry/touchesTest.cpp: Add test for
+ Geometry::touches
+ * [r4176] tests/unit/geom/Geometry/coversTest.cpp: Revert r4175
+ (wrong file)
+2016-03-12 06:40 Mateusz Loskot <mateusz at loskot.net>
+ * [r4175] tests/unit/geom/Geometry/coversTest.cpp: Add test for
+ Geometry::touches
+2016-03-07 23:15 Mateusz Loskot <mateusz at loskot.net>
+ * [r4174] tests/xmltester/CMakeLists.txt: Update CMakeLists.txt
+ after bugXXX.xml moved into tickets subfolder
+2016-03-07 13:11 Sandro Santilli <strk at kbt.io>
+ * [r4173] Makefile.am: Add "valgrindcheck" Makefile rule, currently
+ fails
+2016-03-07 10:21 Sandro Santilli <strk at kbt.io>
+ * [r4170] .travis.yml: Report build activity in #postgis-activity
+ (not #postgis)
+ Also do not use notices
+ * [r4169] configure.ac: Look for isnan in std:: namespace
+ Tested with gcc 4.8.4
+2016-03-06 23:28 Mateusz Loskot <mateusz at loskot.net>
+ * [r4168] include/geos/geom/Coordinate.h,
+ include/geos/geom/Geometry.h, src/geom/Coordinate.cpp,
+ src/geom/Geometry.cpp: Rename class private members according to
+ _x naming convention.
+2016-03-06 13:51 Mateusz Loskot <mateusz at loskot.net>
+ * [r4167] src/algorithm/Centroid.cpp,
+ src/geomgraph/EdgeEndStar.cpp,
+ src/operation/buffer/BufferBuilder.cpp: Clean up a bunch of
+ MSVC++ 14.0 warning C4456: declaration of 'x' hides previous
+ local declaration
+2016-03-06 13:40 Mateusz Loskot <mateusz at loskot.net>
+ * [r4166] .travis.yml: Change Travis CI webhook notifications to
+ 'always'
+2016-03-06 08:29 Mateusz Loskot <mateusz at loskot.net>
+ * [r4165] src/operation/buffer/BufferBuilder.cpp,
+ tests/unit/geom/GeometryFactoryTest.cpp: Clean up some compiler
+ warnings on truncating conversions between size_t and double or
+ unsigned in
+2016-03-06 00:04 Mateusz Loskot <mateusz at loskot.net>
+ * [r4164] .travis.yml: Clean up to address some issues reported by
+ lint.travis-ci.org.
+ Enable mailing list notification.
+ Add Gitter notification.
+2016-03-05 23:40 Mateusz Loskot <mateusz at loskot.net>
+ * [r4163] tests/unit/geom/GeometryComponentFilterTest.cpp,
+ tests/unit/geom/GeometryFilterTest.cpp: Fix repeated test groups
+ definitions (introduced in r4162).
+2016-03-05 23:23 Mateusz Loskot <mateusz at loskot.net>
+ * [r4162] tests/unit/geom/GeometryComponentFilterTest.cpp,
+ tests/unit/geom/GeometryFilterTest.cpp: Add test for
+ GeometryFilter class.
+ Add test for GeometryComponentFilter class.
+ Both tests are based on common filter with intention to compare
+ behaviour both GeometryFilter vs GeometryComponentFilter,
+ with related discussion at
+ http://lists.osgeo.org/pipermail/geos-devel/2016-March/007441.html
+2016-03-02 12:34 Mateusz Loskot <mateusz at loskot.net>
+ * [r4161] tests/unit/operation/linemerge/LineMergerTest.cpp:
+ Describe test cases
+2016-03-02 12:29 Mateusz Loskot <mateusz at loskot.net>
+ * [r4160] tests/unit/operation/linemerge/LineMergerTest.cpp,
+ tests/unit/operation/overlay/OverlayOpUnionTest.cpp: Test merging
+ MultiLineString result of union.
+ Remove unnecessary FIXED precision model from the triangle test
+ in OverlayOpUnionTest.cpp.
+ Add comment to link corresponding tests in OverlayOpUnionTest.cpp
+ and LineMergerTest.cpp.
+2016-03-01 15:22 Mateusz Loskot <mateusz at loskot.net>
+ * [r4159] tests/unit/operation/overlay/OverlayOpUnionTest.cpp: Add
+ comment explaining the expected test result
+ Since the union operation makes no effort to simplify and
+ drop nodes of degree 2 from the built topology,
+ do not expect GEOS_LINESTRING.
+ https://lists.osgeo.org/pipermail/geos-devel/2016-March/007429.html
+2016-03-01 13:43 Mateusz Loskot <mateusz at loskot.net>
+ * [r4158] tests/unit/capi/GEOSContainsTest.cpp: Unify GEOSContains
+ test cases added in r4156 with corresponding tests in
+ GEOSPreparedGeometryTest
+2016-03-01 13:38 Mateusz Loskot <mateusz at loskot.net>
+ * [r4157] tests/unit/capi/GEOSContainsTest.cpp: Test check
+ refinement missing from r4156
+2016-03-01 13:33 Mateusz Loskot <mateusz at loskot.net>
+ * [r4156] tests/unit/capi/GEOSContainsTest.cpp,
+ tests/unit/capi/GEOSPreparedGeometryTest.cpp: Add test for
+ polygon containment where two polygons share some of vertices or
+ vertices of inner polygon lay on boundary of outer polygon.
+ Tests also compare results depending on used precision model.
+2016-02-29 20:45 Mateusz Loskot <mateusz at loskot.net>
+ * [r4155] tests/unit/Makefile.am: Add OverlayOpUnionTest.cpp to
+ Makefile.am
+2016-02-29 20:43 Mateusz Loskot <mateusz at loskot.net>
+ * [r4154] tests/unit/operation/overlay/OverlayOpUnionTest.cpp: Add
+ clean-up missing from r4153.
+ It should fix the failing build on Travis SI.
+2016-02-29 17:59 Mateusz Loskot <mateusz at loskot.net>
+ * [r4153] tests/unit/operation/overlay/OverlayOpUnionTest.cpp: Add
+ basic test for geos::operation::OverlayOp with UNION.
+ Test union of four segments (linestrings) of a suqare.
+2016-02-29 16:20 Mateusz Loskot <mateusz at loskot.net>
+ * [r4152] capi/geos_ts_c.cpp,
+ src/operation/intersection/RectangleIntersectionBuilder.cpp,
+ src/operation/overlay/PolygonBuilder.cpp: Fix build with
+ preprocessor symbol GEOS_DEBUG defined.
+2016-02-24 11:39 Sandro Santilli <strk at kbt.io>
+ * [r4149] include/geos/algorithm/PointLocator.h,
+ src/algorithm/PointLocator.cpp, src/geom/prep/PreparedPoint.cpp,
+ tests/unit/algorithm/PointLocatorTest.cpp: Fix incorrect return
+ from PreparedPoint::intersects
+ Includes unit test
+ Patch by Daniel Baston via
+ https://github.com/libgeos/libgeos/pull/60
+ See #764
+ Reverts r4081
+2016-02-22 17:06 Sandro Santilli <strk at kbt.io>
+ * [r4147] src/algorithm/RobustDeterminant.cpp: ! FINITE already
+ includes NAN, duplicate test unneeded
+2016-02-17 11:40 Mateusz Loskot <mateusz at loskot.net>
+ * [r4146] tests/unit/capi/GEOSGeom_createCollection.cpp: #include
+ <array> only if C++0x is available (refines r4145)
+2016-02-17 11:15 Mateusz Loskot <mateusz at loskot.net>
+ * [r4145] tests/unit/capi/GEOSGeom_createCollection.cpp: Enable
+ test case using std::array only if C++0x is available.
+2016-02-17 10:52 Mateusz Loskot <mateusz at loskot.net>
+ * [r4144] tests/unit/capi/GEOSGeom_createCollection.cpp: Add test
+ for GEOSGeom_createCollection function
+2016-02-05 07:59 Sandro Santilli <strk at kbt.io>
+ * [r4142] src/io/StringTokenizer.cpp: Include <limits> in
+ StringTokenizer
+ Patch by Jeff Mckenna
+ See #766
+2016-01-20 00:03 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r4141] include/geos/geomgraph/GeometryGraph.h,
+ include/geos/geomgraph/index/SegmentIntersector.h,
+ include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h,
+ src/geomgraph/GeometryGraph.cpp,
+ src/geomgraph/index/SegmentIntersector.cpp,
+ src/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
+ src/operation/valid/ConsistentAreaTester.cpp,
+ src/operation/valid/IsValidOp.cpp: #757, fix memory exhaustion
+ case in isvalid
+2015-12-31 08:24 Sandro Santilli <strk at kbt.io>
+ * [r4138] NEWS: Add missing 3.3.9 section
+2015-12-18 17:15 Sandro Santilli <strk at kbt.io>
+ * [r4136] tests/xmltester/XMLTester.cpp: Add support for
+ "relatestring" test operation
+2015-12-17 05:41 Sandro Santilli <strk at kbt.io>
+ * [r4135] CMakeLists.txt: Fix cmake build with Visual Studio 2015
+ Patch by Stefan Hacker <stefan.hacker at ptvgroup.com>
+ Closes https://github.com/libgeos/libgeos/pull/49
+2015-12-14 17:17 Sandro Santilli <strk at kbt.io>
+ * [r4129] src/operation/overlay/snap/LineStringSnapper.cpp,
+ tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp: Fix
+ snapping of last segment in a closed linestring
+ See #758
+ * [r4128]
+ Enable a commented-out test (works)
+2015-12-14 12:05 Sandro Santilli <strk at kbt.io>
+ * [r4127] tests/unit/io/WKBWriterTest.cpp: Tweak WKB output test to
+ do what's really said in the comments
+2015-12-14 11:54 Sandro Santilli <strk at kbt.io>
+ * [r4126] tests/unit/io/WKBReaderTest.cpp: Add test for parsing
+ EWKB
+2015-11-30 20:30 Sandro Santilli <strk at kbt.io>
+ * [r4125] tests/unit/capi/GEOSMinimumWidthTest.cpp: Add another
+ test for GEOSMinimumWidth
+ * [r4124] NEWS, capi/geos_c.cpp, capi/geos_c.h.in,
+ capi/geos_ts_c.cpp, tests/unit/Makefile.am,
+ tests/unit/capi/GEOSMinimumDiameterTest.cpp,
+ tests/unit/capi/GEOSMinimumWidthTest.cpp: Rename
+ GEOSMinimumDiameter to GEOSMinimumWidth, add docs
+ Patch by Nyall Dawson
+2015-11-30 12:01 Sandro Santilli <strk at kbt.io>
+ * [r4123] NEWS, capi/geos_c.cpp, capi/geos_c.h.in,
+ capi/geos_ts_c.cpp, include/geos/algorithm/MinimumDiameter.h,
+ src/algorithm/MinimumDiameter.cpp, tests/unit/Makefile.am,
+ tests/unit/algorithm/MinimumDiameterTest.cpp,
+ tests/unit/capi/GEOSMinimumRectangleTest.cpp: Port
+ MinimumDiameter::getMinimumRectangle algorithm from JTS
+ Also add GEOSMinimumRotatedRectangle and GEOSMinimumDiameter
+ to C API, and re-sync MinimumDiameter with JTS r966.
+ Includes testcases.
+ Fixes #729.
+ Patch by: Nyall Dawson <nyall.dawson at gmail.com>
+ Signed-off-by: Sandro Santilli <strk at keybit.net>
+2015-11-30 10:06 Sandro Santilli <strk at kbt.io>
+ * [r4122] capi/geos_ts_c.cpp,
+ include/geos/algorithm/SIRtreePointInRing.h,
+ src/algorithm/SIRtreePointInRing.cpp: Fix some leaks identified
+ by Coverity
+ Patch by Nyall Dawson <nyall.dawson at gmail.com>
+2015-11-30 10:00 Sandro Santilli <strk at kbt.io>
+ * [r4121] include/geos/triangulate/quadedge/Vertex.h,
+ src/triangulate/quadedge/Vertex.cpp: Fix incorrect logic in
+ Vertex::classify, sync to r705
+2015-11-21 12:59 Sandro Santilli <strk at kbt.io>
+ * [r4119] include/geos/triangulate/quadedge/QuadEdgeSubdivision.h,
+ src/triangulate/quadedge/QuadEdgeSubdivision.cpp: use std::vector
+ instead of std::list to avoid size() bottleneck
+ https://github.com/libgeos/libgeos/pull/55
+2015-11-16 10:53 Sandro Santilli <strk at kbt.io>
+ * [r4118] include/geos/geomgraph/EdgeEnd.h,
+ include/geos/geomgraph/EdgeEndStar.h, src/geomgraph/EdgeEnd.cpp,
+ src/geomgraph/EdgeEndStar.cpp: Fix output operator for
+ EdgeEndStar
+2015-11-13 19:10 Sandro Santilli <strk at kbt.io>
+ * [r4117] include/geos/geomgraph/EdgeEndStar.h,
+ src/operation/relate/RelateComputer.cpp: Add output operator for
+ EdgeEndStar
+2015-11-04 20:30 Mateusz Loskot <mateusz at loskot.net>
+ * [r4114] include/geos/platform.h.cmake: Add #define NOMINMAX for
+ Visual C++
+2015-11-03 09:17 Sandro Santilli <strk at kbt.io>
+ * [r4113] tests/unit/Makefile.am,
+ tests/unit/capi/GEOSEqualsTest.cpp: Add test for GEOSEquals
+ Includes disabled test for #752
+2015-11-02 12:52 Mateusz Loskot <mateusz at loskot.net>
+ * [r4112] CMakeLists.txt: CMake should not try to generate
+ geos_svn_revision.h if GEOS is built from packaged sources.
+ Fixes #753
+2015-10-31 09:23 Sandro Santilli <strk at kbt.io>
+ * [r4111] include/geos/geom/GeometryFactory.h,
+ src/geom/Geometry.cpp, src/geom/GeometryFactory.cpp: Make
+ GeometryFactory refcount geometry-agnostic
+2015-10-13 11:20 Sandro Santilli <strk at kbt.io>
+ * [r4109] NEWS, capi/geos_c.cpp, capi/geos_c.h.in,
+ capi/geos_ts_c.cpp, php/geos.c, php/test/test.php,
+ src/geom/util/GeometryEditor.cpp,
+ tests/unit/capi/GEOSGeom_setPrecisionTest.cpp: Add a
+ GEOSGeom_setPrecision funciton in C-API and PHP
+ Also fixes a bug in GeometryEditor that failed to update
+ GeometryFactory for empty polygons (#749)
+2015-10-07 07:20 Sandro Santilli <strk at kbt.io>
+ * [r4108] CMakeLists.txt, capi/geos_c.h.in, configure.ac: Fix CAPI
+ versioning (broke in r4085, after release)
+2015-10-05 09:38 Mateusz Loskot <mateusz at loskot.net>
+ * [r4104] src/geomgraph/PlanarGraph.cpp: Use std::auto_ptr to
+ simplify r4100 fix of a memory leak potential
+2015-10-04 16:09 Sandro Santilli <strk at kbt.io>
+ * [r4103] src/operation/buffer/BufferBuilder.cpp: Fix a few
+ potential (one confirmed) leak in single sided buffer
+ See #747
+2015-10-04 14:09 Mateusz Loskot <mateusz at loskot.net>
+ * [r4100] src/geomgraph/PlanarGraph.cpp: Make adding edges a bit
+ more exception safe and helps to avoid memory leaks when
+ PlanarGraph::add(de1) throws, leaving de2 behind.
+ This also fixes memory leak in case of self-union with NaN
+ coordinates, revealed by GEOSUnaryUnionTest/test<9>.
+2015-10-03 21:57 Mateusz Loskot <mateusz at loskot.net>
+ * [r4099] tests/unit/triangulate/DelaunayTest.cpp: Fix memory leaks
+ (two) due to misuse of CoordinateArraySequence
+2015-10-03 21:37 Mateusz Loskot <mateusz at loskot.net>
+ * [r4098] src/algorithm/CGAlgorithms.cpp,
+ src/algorithm/LineIntersector.cpp,
+ src/algorithm/locate/IndexedPointInAreaLocator.cpp,
+ src/geom/LineSegment.cpp, src/io/WKTWriter.cpp,
+ src/noding/snapround/HotPixel.cpp,
+ src/operation/buffer/BufferBuilder.cpp,
+ src/operation/buffer/BufferOp.cpp,
+ src/operation/overlay/snap/GeometrySnapper.cpp,
+ src/operation/overlay/validate/OverlayResultValidator.cpp: Clean
+ up Windows-specific extra parenthesis around std::min/std::max
+ which worked around min/max macros causing syntax error. The
+ workaround is no loner necessary since NOMINMAX placement has
+ been corrected.
+2015-10-03 21:21 Mateusz Loskot <mateusz at loskot.net>
+ * [r4097] CMakeLists.txt, include/geos/timeval.h: Move
+ Windows-specific NOMINMAX preprocessor definition from CMake to
+ timeval.h.
+ Assume timeval.h is the only place where Windows-specific headers
+ are included.
+2015-10-03 20:58 Mateusz Loskot <mateusz at loskot.net>
+ * [r4096] CMakeLists.txt: Clean up CMake variables mismatch
+2015-10-03 20:29 Mateusz Loskot <mateusz at loskot.net>
+ * [r4095] CMakeLists.txt: Tell CMake to use GEOS instead geos.
+2015-10-03 20:23 Mateusz Loskot <mateusz at loskot.net>
+ * [r4094] CMakeLists.txt: Remove CDash configuration which
+ generates unnecessary targets (Experimental, Nightly, Continuous)
+2015-10-03 13:38 Mateusz Loskot <mateusz at loskot.net>
+ * [r4093] src/operation/intersection: Ignore .obj and some other
+ patterns
+2015-10-02 16:47 Sandro Santilli <strk at kbt.io>
+ * [r4092] NEWS, capi/geos_c.cpp, capi/geos_c.h.in,
+ GEOSGeom_setPrecision function to C-API (#713)
+ Include unit tests and PHP bindings
+2015-10-02 09:59 Sandro Santilli <strk at kbt.io>
+ * [r4091] NEWS, doc/example.cpp, include/geos/geom/BinaryOp.h,
+ include/geos/geom/GeometryFactory.h,
+ include/geos/operation/valid/ConnectedInteriorTester.h,
+ include/geos/precision/GeometryPrecisionReducer.h,
+ src/geom/Geometry.cpp, src/geom/GeometryFactory.cpp,
+ src/operation/valid/ConnectedInteriorTester.cpp,
+ src/precision/GeometryPrecisionReducer.cpp,
+ tests/bigtest/TestSweepLineSpeed.cpp, tests/bigtest/bug234.cpp,
+ tests/perf/operation/buffer/IteratedBufferStressTest.cpp,
+ tests/perf/operation/predicate/RectangleIntersectsPerfTest.cpp,
+ tests/unit/algorithm/ConvexHullTest.cpp,
+ tests/unit/algorithm/PointLocatorTest.cpp,
+ tests/unit/algorithm/RobustLineIntersectionTest.cpp,
+ tests/unit/algorithm/RobustLineIntersectorTest.cpp,
+ tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp,
+ tests/unit/capi/GEOSPreparedGeometryTest.cpp,
+ tests/unit/geom/Geometry/clone.cpp,
+ tests/unit/geom/Geometry/coversTest.cpp,
+ tests/unit/geom/Geometry/equalsTest.cpp,
+ tests/unit/geom/Geometry/isRectangleTest.cpp,
+ tests/unit/geom/Geometry/normalize.cpp,
+ tests/unit/geom/GeometryFactoryTest.cpp,
+ tests/unit/geom/LineStringTest.cpp,
+ tests/unit/geom/LinearRingTest.cpp,
+ tests/unit/geom/MultiPointTest.cpp,
+ tests/unit/geom/PointTest.cpp, tests/unit/geom/PolygonTest.cpp,
+ tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp,
+ tests/unit/geom/util/GeometryExtracterTest.cpp,
+ tests/unit/io/WKBReaderTest.cpp, tests/unit/io/WKBWriterTest.cpp,
+ tests/unit/io/WKTReaderTest.cpp, tests/unit/io/WKTWriterTest.cpp,
+ tests/unit/linearref/LengthIndexedLineTest.cpp,
+ tests/unit/noding/OrientedCoordinateArray.cpp,
+ tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp,
+ tests/unit/operation/IsSimpleOpTest.cpp,
+ tests/unit/operation/buffer/BufferBuilderTest.cpp,
+ tests/unit/operation/buffer/BufferOpTest.cpp,
+ tests/unit/operation/distance/DistanceOpTest.cpp,
+ tests/unit/operation/intersection/RectangleIntersectionTest.cpp,
+ tests/unit/operation/linemerge/LineMergerTest.cpp,
+ tests/unit/operation/linemerge/LineSequencerTest.cpp,
+ tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp,
+ tests/unit/operation/overlay/validate/FuzzyPointLocatorTest.cpp,
+ tests/unit/operation/overlay/validate/OffsetPointGeneratorTest.cpp,
+ tests/unit/operation/overlay/validate/OverlayResultValidatorTest.cpp,
+ tests/unit/operation/polygonize/PolygonizeTest.cpp,
+ tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp,
+ tests/unit/operation/union/CascadedPolygonUnionTest.cpp,
+ tests/unit/operation/union/UnaryUnionOpTest.cpp,
+ tests/unit/operation/valid/IsValidTest.cpp,
+ tests/unit/operation/valid/ValidClosedRingTest.cpp,
+ tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp,
+ tests/unit/precision/GeometryPrecisionReducerTest.cpp,
+ tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp,
+ tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp,
+ tests/unit/simplify/TopologyPreservingSimplifierTest.cpp,
+ tests/unit/triangulate/DelaunayTest.cpp,
+ tests/unit/triangulate/VoronoiTest.cpp,
+ tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp,
+ tests/unit/util/UniqueCoordinateArrayFilterTest.cpp,
+ tests/xmltester/SimpleWKTTester.cpp,
+ tests/xmltester/XMLTester.cpp, tests/xmltester/XMLTester.h:
+ Prevent stack allocation of GeometryFactory
+ Geometry factory objects can be created by static methods
+ returning a smart pointer with automatic ownership transfer
+ semantic. The so-created GeometryFactory will be kept alive
+ as long as Geometry objects referencing it will be alive.
+2015-10-01 15:22 Sandro Santilli <strk at kbt.io>
+ * [r4090] src/operation/buffer/BufferBuilder.cpp: Fix a memory leak
+ in bufferLineSingleSided
+ The leak was exposed by an existing unit test
+2015-09-10 08:49 Sandro Santilli <strk at kbt.io>
+ * [r4089] .travis.yml: 64bit builds do not fail anymore on travis
+2015-08-16 22:19 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r4085] CMakeLists.txt, HOWTO_RELEASE, NEWS, capi/geos_c.h.in,
+ configure.ac, include/geos/version.h.vc: Bump trunk versions to
+ 3.6
+2015-08-14 18:19 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r4082] include/geos/operation/intersection,
+ src/operation/intersection: Ignore build artefacts
+2015-08-12 18:55 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r4081] src/geom/prep/PreparedPoint.cpp: Fix corner case of
+ comparing preparedpoint to point
+2015-08-12 16:57 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r4080] src/algorithm/ConvexHull.cpp: Include interrupt header,
+ dummy
+2015-08-12 16:52 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r4079] src/algorithm/ConvexHull.cpp: Add some interrupt checks
+ to ConvexHull
+2015-08-12 13:42 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r4078] include/geos/geom/prep/PreparedPoint.h,
+ src/geom/prep/PreparedPoint.cpp: Quiet clang warning and match
+ const signatures on PreparedPolygon
+2015-08-12 13:34 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r4077] configure.ac: Quiet 64-bit errors in OSX build by
+ preferring longlongint defn of 64bit to longint
+2015-08-12 00:22 Regina Obe <lr at pcorp.us>
+ * [r4076] src/inlines.cpp: #736 3.5.0-dev compilation errors on
+ MinGW - okay committed too fast. This one works but may screw up
+ real mingw people
+2015-08-11 23:27 Regina Obe <lr at pcorp.us>
+ * [r4075] src/inlines.cpp: #736 3.5.0-dev compilation errors on
+ MinGW
+2015-08-06 15:17 Mateusz Loskot <mateusz at loskot.net>
+ * [r4072] .travis.yml: Allow failure for CMake x64 build on Travis
+ CI.
+ This should eliminate unimportant signal and keep the core GEOS
+ builds green.
+2015-08-05 14:37 Mateusz Loskot <mateusz at loskot.net>
+ * [r4069] tools/ci/before_install.sh,
+ tools/ci/before_install_autotools.sh,
+ tools/ci/before_install_cmake.sh: Delete scripts no longer used
+ in container-based Travis CI
+2015-08-05 14:16 Mateusz Loskot <mateusz at loskot.net>
+ * [r4068] .travis.yml: First stab at migrating travis builds to
+ container architecture (#739)
+2015-08-04 08:29 Sandro Santilli <strk at kbt.io>
+ * [r4067] NEWS, php/geos.c, php/test/test.php: Expose clipByRect to
+ PHP bindings (#734)
+2015-07-28 21:08 Mateusz Loskot <mateusz at loskot.net>
+ * [r4064] src/algorithm/LineIntersector.cpp, src/io/WKTWriter.cpp,
+ src/operation/buffer/OffsetCurveSetBuilder.cpp: Include
+ <geos/platform.h> which defines NOMINMAX on Windows/VC++.
+ Closes ticket #701.
+2015-07-28 20:59 Mateusz Loskot <mateusz at loskot.net>
+ * [r4063] src/Makefile.vc, src/dirlist.mk: Add
+ operation/intersection/*.cpp to NMAKE makefiles
+2015-07-28 20:45 Mateusz Loskot <mateusz at loskot.net>
+ * [r4062] nmake.opt: Add NMAKE version from released Visual Studio
+ 2015
+2015-07-20 17:31 Sandro Santilli <strk at kbt.io>
+ * [r4061] capi/geos_ts_c.cpp: Initialize all members of
+ GEOSContextHandle_HS on construction
+2015-07-20 17:25 Sandro Santilli <strk at kbt.io>
+ * [r4060] NEWS, capi/geos_c.h.in, capi/geos_ts_c.cpp: Extend error
+ and notice notification with threadsafe variants (#663)
+ Patch by Pepijn Van Eeckhoudt <pepijn at vaneeckhoudt.net>
+ Tested by Alessandro Furieri <a.furieri at lqt.it>
+2015-07-19 13:04 Sandro Santilli <strk at kbt.io>
+ * [r4059]
+ src/operation/intersection/RectangleIntersectionBuilder.cpp: Add
+ missing include (thanks Alessandro Furieri)
+2015-07-07 09:28 Mateusz Loskot <mateusz at loskot.net>
+ * [r4058] nmake.opt: Update nmake.opt to recognize NMAKE
+ 11.00.50522.1.
+ Fixes #578.
+2015-05-18 09:50 Mateusz Loskot <mateusz at loskot.net>
+ * [r4057] ., nmake.opt: Merged revision(s) 4056 from branches/3.4:
+ Fixed build configuration for NMAKE with Visual Leak Detector
+ enabled (#715)
+2015-04-30 18:35 Mateusz Loskot <mateusz at loskot.net>
+ * [r4054] nmake.opt: Add NMAKE version from Visual Studio 2015 RC
+2015-04-20 16:59 Sandro Santilli <strk at kbt.io>
+ * [r4053] tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp: Fix
+ unused variables warnings
+ * [r4052] NEWS, include/geos/geom/CoordinateArraySequenceFactory.h,
+ include/geos/geom/CoordinateArraySequenceFactory.inl,
+ include/geos/geom/CoordinateSequenceFactory.h,
+ src/geom/CoordinateSequence.cpp, src/geom/LineString.cpp,
+ src/geom/Point.cpp, src/geom/Polygon.cpp,
+ src/geomgraph/EdgeRing.cpp, src/io/WKTReader.cpp,
+ src/operation/linemerge/EdgeString.cpp,
+ src/operation/polygonize/EdgeRing.cpp,
+ tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp: Cleanup
+ CoordinateSequenceFactory interface
+ Adds method for creating empty sequence.
+ Syncronizes CoordinateArraySequenceFactory methods.
+ Patch by Sandro Mani,
+ see https://github.com/libgeos/libgeos/pull/46
+2015-04-16 06:18 Mateusz Loskot <mateusz at loskot.net>
+ * [r4051] tests/unit/capi/GEOSPreparedGeometryTest.cpp: Replace
+ geos.h with specific headers from C++ API.
+ Replace WKBReader with GEOSGeomFromHEX_buf where the former is
+ unnecessary.
+ This addresses Sandro's review comment from
+ https://github.com/libgeos/libgeos/commit/7196b9a2e5a3ebc393a1810f6c7d841a00b50844#commitcomment-10731724
+2015-04-10 07:37 Sandro Santilli <strk at kbt.io>
+ * [r4050] tests/unit/Makefile.am: Enable GEOSisClosed test
+ * [r4049] NEWS, capi/geos_ts_c.cpp,
+ tests/unit/capi/GEOSisClosedTest.cpp: Support for
+ MultiLineString->isClosed() in C API
+ Includes tests for GEOSisClosed() in C API
+ Patch by Benjamin Morel <benjamin.morel at gmail.com>
+2015-03-02 11:22 Sandro Santilli <strk at kbt.io>
+ * [r4048] src/operation/overlay/OverlayOp.cpp,
+ tests/unit/Makefile.am, tests/unit/capi/GEOSIntersectionTest.cpp:
+ Fix memory leak in extent-limited overlay operations
+ The leak was introduced by recent enhancement of the class to
+ support extent-limited operation. It was spotted by Mick Orridge
+ who also provided the testcase, thanks !
+ Fixes #719
+2015-02-03 10:11 Sandro Santilli <strk at kbt.io>
+ * [r4047] README.md: Add github-friendly README.md file
+ contains travis build status and reference to actual README
+2015-01-23 10:36 Sandro Santilli <strk at kbt.io>
+ * [r4046] tests/xmltester/Makefile.am,
+ tests/xmltester/tests/ticket/bug569.xml: Add (succeeding) test
+ for reported bug #569
+2015-01-19 10:59 Sandro Santilli <strk at kbt.io>
+ * [r4040] include/geos/algorithm/RayCrossingCounter.h,
+ src/algorithm/CGAlgorithms.cpp,
+ src/algorithm/RayCrossingCounter.cpp,
+ tests/xmltester/Makefile.am,
+ tests/xmltester/tests/ticket/bug716.xml: Improve robustness of
+ intersection testing (#716)
+ RayCrossingCounter uses orientationIndex to handle floating point
+ precision errors the same way as LineIntersector.
+ Includes testcase for ticket #716 with CW and CCW polygons
+ Patch by Asmund Tokheim <tokheim at outlook.com>
+2014-12-05 09:37 Mateusz Loskot <mateusz at loskot.net>
+ * [r4038] tests/unit/algorithm/RobustLineIntersectorTest.cpp,
+ tests/unit/capi/GEOSPreparedGeometryTest.cpp: Add two test cases,
+ point-on-segment and point-on-vertex.
+ Curious detail of the tests is that points of interest have
+ nearly exact X of tested points, the values differ after 14th
+ decimal place.
+ The tests provided test geometries for intersection with and
+ without coordinates trimming after the 14th place (as per Martin
+ Davis suggestion).
+ It has been extensively discussed in Ticket #591 and
+ https://github.com/libgeos/libgeos/pull/40 with Martin Davis'
+ input.
+2014-11-26 15:33 Mateusz Loskot <mateusz at loskot.net>
+ * [r4037] src/io/StringTokenizer.cpp: Fix MSVC handling of strtod
+ (Thanks to Paul Kohut for the patch submitted as part of
+ https://github.com/libgeos/libgeos/pull/31/)
+ Apparently, it solves the long running INF/NAN parsing issues on
+ Windows and enables GEOSisValidDetail test pass again.
+ It should also solve problems reported as part of ticket #509.
+2014-11-26 14:58 Mateusz Loskot <mateusz at loskot.net>
+ * [r4036] CMakeLists.txt, cmake/modules/GenerateSourceGroups.cmake,
+ include/CMakeLists.txt, src/CMakeLists.txt, tests/CMakeLists.txt,
+ tests/unit/CMakeLists.txt: Add GenerateSourceGroups macro.
+ Attempt to generate source_group for IDEs reflecting folders
+ structure.
+ No functional changes to build configuration included.
+2014-11-12 16:42 Sandro Santilli <strk at kbt.io>
+ * [r4035] tools/svn_repo_revision.sh: Fix revision extracter for
+ calls from external build dir
+2014-11-12 12:08 Sandro Santilli <strk at kbt.io>
+ * [r4034] tests/xmltester/XMLTester.cpp: Add interruptability
+ support to XMLTester (trigger with SIGTERM)
+2014-11-12 10:02 Sandro Santilli <strk at kbt.io>
+ * [r4033] .gitignore: Ignore more generated files
+2014-11-11 10:19 Sandro Santilli <strk at kbt.io>
+ * [r4031] src/geomgraph/GeometryGraph.cpp,
+ src/geomgraph/PlanarGraph.cpp,
+ src/operation/relate/RelateComputer.cpp: Further enhance RelateOp
+ interruptibility (#711)
+ Adds interruptibility calls in GeometryGraph and RelateComputer
+ Funded by CartoDB
+2014-11-10 09:57 Sandro Santilli <strk at kbt.io>
+ * [r4030] src/geomgraph/index/SimpleMCSweepLineIntersector.cpp:
+ Make RelateComputer interruptible (#711)
+ Injects interruptibility calls in SimpleMCSweepLineIntersector
+ Funded by CartoDB
+2014-11-04 18:15 Sandro Santilli <strk at kbt.io>
+ * [r4027] php/geos.c, php/test/test.php: Fix build of PHP bindings
+ with PHP < 5.3.99 (#709)
+ Tested with php 5.3.2
+ Thanks KayMadejski for the report
+2014-09-25 16:25 Sandro Santilli <strk at kbt.io>
+ * [r4026]
+ tests/unit/operation/intersection/RectangleIntersectionTest.cpp:
+ Reduce max number of tests to 255, in case it makes clang happier
+ See https://travis-ci.org/libgeos/libgeos/jobs/36269669
+2014-09-25 15:32 Sandro Santilli <strk at kbt.io>
+ * [r4025] src/operation/intersection/RectangleIntersection.cpp,
+ Fix another boundary bug in RectangleIntersection
+2014-09-25 15:21 Sandro Santilli <strk at kbt.io>
+ * [r4024] src/operation/intersection/RectangleIntersection.cpp: Fix
+ bug in RectangleIntersection on finding rect fully contained
+ * [r4023] src/operation/intersection/RectangleIntersection.cpp: Fix
+ bug in RectangleIntersection (was cought by testsuite too!)
+2014-09-25 15:17 Sandro Santilli <strk at kbt.io>
+ * [r4022] src/geomgraph/GeometryGraph.cpp,
+ src/operation/overlay/OverlayOp.cpp: Remove debugging lines,
+ reduce cost of envelope filter
+ ... when the filter envelope fully convers the geometry envelope
+2014-09-25 10:46 Sandro Santilli <strk at kbt.io>
+ * [r4021] NEWS, capi/geos_c.cpp, capi/geos_c.h.in,
+ capi/geos_ts_c.cpp, configure.ac,
+ include/geos/operation/Makefile.am,
+ include/geos/operation/intersection,
+ include/geos/operation/intersection/Makefile.am,
+ include/geos/operation/intersection/Rectangle.h,
+ include/geos/operation/intersection/RectangleIntersection.h,
+ include/geos/operation/intersection/RectangleIntersectionBuilder.h,
+ src/geom/Geometry.cpp, src/operation/Makefile.am,
+ src/operation/intersection,
+ src/operation/intersection/Makefile.am,
+ src/operation/intersection/Rectangle.cpp,
+ src/operation/intersection/RectangleIntersection.cpp,
+ tests/unit/Makefile.am, tests/unit/capi/GEOSClipByRectTest.cpp,
+ tests/unit/operation/intersection,
+ Add optimized RectangleIntersection functionality
+ Includes:
+ C++ API, with tests
+ C-API GEOSClipByRect, with tests
+ Initial C++ code provided by Mika Heiskanen.
+ Modified by me to work with arbitrarily ordered polygon ring
+ vertices.
+ See #699 for background
+2014-09-24 07:52 Sandro Santilli <strk at kbt.io>
+ * [r4019] php/geos.c: Fixed compilation against thread-safe PHP
+ (ZTS)
+ Closes #541
+ Patch-by: Benjamin Morel <benjamin.morel at gmail.com>
+2014-09-23 08:17 Sandro Santilli <strk at kbt.io>
+ * [r4018] include/geos/operation/overlay/OverlayOp.h,
+ src/operation/overlay/OverlayOp.cpp: Further speedup
+ difference/intersection at the validating phase
+ This avoids to insert to the output graph edges which do not
+ intersect
+ the target envelope.
+2014-09-23 07:55 Sandro Santilli <strk at kbt.io>
+ * [r4017] NEWS, include/geos/geomgraph/GeometryGraph.h,
+ include/geos/geomgraph/GeometryGraph.inl,
+ include/geos/operation/overlay/OverlayOp.h,
+ src/operation/overlay/OverlayOp.cpp: OverlayOp: restrict
+ intersection computations to the target extent
+ Speeds up INTERSECTION and DIFFERENCE operations between
+ geometries
+ with small bounding box overlap.
+2014-09-22 14:13 Sandro Santilli <strk at kbt.io>
+ * [r4016] php/test/test.php: Refactored PHP bindings tests
+2014-09-22 07:42 Sandro Santilli <strk at kbt.io>
+ * [r4015] NEWS, php/geos.c, php/test/test.php: Add
+ WKBReader::read() & WKBWriter::write() PHP bindings
+ Includes tests.
+2014-09-19 13:50 Sandro Santilli <strk at kbt.io>
+ * [r4014] tests/xmltester/XMLTester.cpp,
+ tests/xmltester/XMLTester.h: Report time it took to run each test
+2014-09-19 08:11 Sandro Santilli <strk at kbt.io>
+ * [r4013] php/test/test.php: Normalize voronoi diagram results for
+ comparing to expected output
+2014-09-19 08:02 Sandro Santilli <strk at kbt.io>
+ * [r4012] src/operation/overlay/Makefile.am,
+ src/planargraph/Makefile.am, tests/unit/Makefile.am,
+ tests/xmltester/Makefile.am: Add AUTOMAKE_OPTIONS =
+ subdir-objects, to please automake 1.14.1
+2014-09-17 16:14 Sandro Santilli <strk at kbt.io>
+ * [r4011] php/test/test.php: Accept differently-structured but
+ point-set equivalent intersection result
+2014-09-17 07:36 Sandro Santilli <strk at kbt.io>
+ * [r4010] tests/xmltester/tests/testLeaksBig.xml: Remove more
+ duplicated tests
+ Tests were found in TestFunctionAA.xml, TestFunctionLA.xml
+ TestFunctionPA.xml TestFunctionPL.xml TestFunctionPP.xml
+ TestFunctionLLPrec.xml, TestRelatePP.xml
+2014-09-16 16:53 Sandro Santilli <strk at kbt.io>
+ * [r4009] tests/xmltester/tests/testLeaksBig.xml: Remove duplicated
+ tests
+ The removed tests are already present in other xml files under
+ general/
+ There's more to drop here too...
+2014-09-16 15:37 Sandro Santilli <strk at kbt.io>
+ * [r4008] tests/unit/capi/GEOSVoronoiDiagramTest.cpp: Add some
+ tolerance to VoronoiDiagram tester
+2014-09-16 15:00 Sandro Santilli <strk at kbt.io>
+ * [r4007] src/triangulate/quadedge/QuadEdgeSubdivision.cpp,
+ tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp: Do
+ not output duplicated vertices from QuadEdgeSubdivision class
+ (#705)
+ Includes testcase
+2014-09-16 09:52 Sandro Santilli <strk at kbt.io>
+ * [r4006] tests/unit/Makefile.am,
+ tests/unit/geom/Geometry/normalize.cpp: Add tests for
+ Geometry->normalize()
+2014-09-16 08:50 Sandro Santilli <strk at kbt.io>
+ * [r4005] tests/unit/triangulate/VoronoiTest.cpp: Have VoronoiTest
+ print expected/obtained on failure
+2014-09-15 16:09 Sandro Santilli <strk at kbt.io>
+ * [r4004] NEWS, php/geos.c, php/test/test.php: Expose
+ Geometry->normalize() method in PHP binding
+2014-09-15 14:29 Sandro Santilli <strk at kbt.io>
+ * [r4003] tests/unit/capi/GEOSVoronoiDiagramTest.cpp: Normalize
+ result before comparing
+2014-09-12 14:35 Sandro Santilli <strk at kbt.io>
+ * [r4002] .gitignore: More ignores...
+2014-09-09 14:46 Sandro Santilli <strk at kbt.io>
+ * [r4001] src/geom/Envelope.cpp, src/geom/Geometry.cpp,
+ tests/unit/Makefile.am, tests/unit/geom/EnvelopeTest.cpp,
+ tests/unit/geom/PointTest.cpp: Fix Empty to Empty equals response
+ (#703)
+2014-08-25 07:42 Sandro Santilli <strk at kbt.io>
+ * [r3996] include/geos/platform.h.in: Fix OpenBSD build (#700)
+2014-08-09 03:13 Regina Obe <lr at pcorp.us>
+ * [r3995] CMakeLists.txt: #698 patch to support MSVC12 and MSVC13
+2014-06-30 20:16 Sandro Santilli <strk at kbt.io>
+ * [r3992] tests/xmltester/tests/general/MISSING: TestUnaryUnion.xml
+ was ported
+2014-06-30 14:11 Sandro Santilli <strk at kbt.io>
+ * [r3991] NEWS, capi/geos_c.h.in: Allow C-API users to hide
+ non-reentrant section
+ Define GEOS_USE_ONLY_R_API to obtain a compile-time error when
+ trying to use non-reentrant functions.
+ Patch by Even Rouault (#695)
+2014-06-29 14:50 Sandro Santilli <strk at kbt.io>
+ * [r3990] include/geos/util/IllegalArgumentException.h,
+ include/geos/util/UnsupportedOperationException.h: Typoes fixed
+ in comments
+ Patches by Jochen Topf:
+ https://github.com/libgeos/libgeos/pull/34
+ https://github.com/libgeos/libgeos/pull/35
+2014-06-20 08:39 Sandro Santilli <strk at kbt.io>
+ * [r3989] include/geos/geom/prep/PreparedPoint.h,
+ src/geom/prep/PreparedPoint.cpp: Revert "Fix
+ PreparedPoint::intersects signature to match the upper virtual"
+ This reverts commit r3988
+ The non-broken signature introduces a discrepancy between
+ PreparedPoint::intersects and Point::intersects
+ See http://trac.osgeo.org/geos/ticket/694
+2014-06-20 07:48 Sandro Santilli <strk at kbt.io>
+ * [r3988] include/geos/geom/prep/PreparedPoint.h,
+ src/geom/prep/PreparedPoint.cpp: Fix PreparedPoint::intersects
+ signature to match the upper virtual
+ Thanks Mikhail Veltishchev for pointing out
+ See https://github.com/libgeos/libgeos/pull/33
+2014-06-20 07:39 Sandro Santilli <strk at kbt.io>
+ * [r3987] macros/ruby.m4, swig/ruby/Makefile.am,
+ swig/ruby/geos_wrap.cxx: Update ruby binding build scripts
+ Build succeeds with ruby1.9.1-dev.
+ Swig wrapper updated.
+ See https://github.com/libgeos/libgeos/pull/22
+2014-06-20 07:28 Sandro Santilli <strk at kbt.io>
+ * [r3986] include/geos/index/strtree/Interval.h,
+ src/index/strtree/Interval.cpp, src/index/strtree/SIRtree.cpp:
+ Clean up strtree::Interval interface
+ Set const-correctness, drop useless copy-ctor-like method
+2014-05-21 16:08 Sandro Santilli <strk at kbt.io>
+ * [r3985] .gitignore, capi/geos_c.cpp, capi/geos_c.h.in,
+ swig/python/geos.py, swig/python/geos_wrap.cxx,
+ tests/unit/capi/GEOSVoronoiDiagramTest.cpp: Change
+ GEOSVoronoiDiagram signature to accept optional clip extent
+ With this change I'll consider voronoi API final
+2014-05-21 14:21 Sandro Santilli <strk at kbt.io>
+ * [r3984] php/geos.c, php/test/test.php: Expose
+ Geometry.voronoiDiagram in PHP interface
+ * [r3983] capi/geos_ts_c.cpp,
+ include/geos/triangulate/VoronoiDiagramBuilder.h,
+ include/geos/triangulate/quadedge/QuadEdgeSubdivision.h,
+ src/triangulate/VoronoiDiagramBuilder.cpp,
+ src/triangulate/quadedge/QuadEdgeSubdivision.cpp,
+ tests/unit/capi/GEOSVoronoiDiagramTest.cpp: Fix
+ GEOSVoronoiDiagram on requesting edges only
+ Before this fix asking for edges would return the edges of
+ the triangle used as abase for the Voronoi diagram.
+ After, we return the actual voronoi cell edges.
+2014-05-07 17:32 Mateusz Loskot <mateusz at loskot.net>
+ * [r3981] nmake.opt, src/algorithm/LineIntersector.cpp,
+ src/operation/buffer/OffsetCurveSetBuilder.cpp: Apply minimal
+ changes to enable building with Visual Studio 2013 (Ticket #691)
+2014-03-29 10:37 Sandro Santilli <strk at kbt.io>
+ * [r3978] src/operation/polygonize/EdgeRing.cpp: Polygonizer: do
+ not pretend all exceptions are due to edge invalidity
+2014-03-28 21:13 Sandro Santilli <strk at kbt.io>
+ * [r3977] src/operation/polygonize/Polygonizer.cpp: Make polygonize
+ operation interruptable
+2014-03-17 14:17 Sandro Santilli <strk at kbt.io>
+ * [r3976] src/Makefile.vc: Fix nmake build (#689)
+2014-03-16 16:08 Sandro Santilli <strk at kbt.io>
+ * [r3975] tests/unit/geom/CoordinateArraySequenceTest.cpp,
+ tests/unit/io/WKBWriterTest.cpp: Include <cmath> from unit tests
+ (#686)
+2014-02-11 09:01 Sandro Santilli <strk at kbt.io>
+ * [r3974] capi/Makefile.am: Include AM_CPPFLAGS in target-specific
+ CPPFLAGS
+ Attempt to fix build on travis (with automake 1.11.3)
+ See http://travis-ci.org/libgeos/libgeos/jobs/18602776#L2519
+2014-02-10 18:39 Sandro Santilli <strk at kbt.io>
+ * [r3973] capi/Makefile.am, doc/Makefile.am, src/Makefile.am,
+ src/algorithm/Makefile.am, src/algorithm/distance/Makefile.am,
+ src/algorithm/locate/Makefile.am, src/geom/Makefile.am,
+ src/geom/prep/Makefile.am, src/geom/util/Makefile.am,
+ src/geomgraph/Makefile.am, src/geomgraph/index/Makefile.am,
+ src/index/bintree/Makefile.am, src/index/chain/Makefile.am,
+ src/index/intervalrtree/Makefile.am,
+ src/index/quadtree/Makefile.am, src/index/strtree/Makefile.am,
+ src/index/sweepline/Makefile.am, src/io/Makefile.am,
+ src/linearref/Makefile.am, src/noding/Makefile.am,
+ src/noding/snapround/Makefile.am, src/operation/Makefile.am,
+ src/operation/buffer/Makefile.am,
+ src/operation/linemerge/Makefile.am,
+ src/operation/overlay/Makefile.am,
+ src/operation/polygonize/Makefile.am,
+ src/operation/predicate/Makefile.am,
+ src/operation/relate/Makefile.am,
+ src/operation/sharedpaths/Makefile.am,
+ src/operation/union/Makefile.am, src/operation/valid/Makefile.am,
+ src/planargraph/Makefile.am, src/precision/Makefile.am,
+ src/simplify/Makefile.am, src/triangulate/Makefile.am,
+ src/triangulate/quadedge/Makefile.am, src/util/Makefile.am,
+ swig/ruby/Makefile.am, tests/bigtest/Makefile.am,
+ tests/geostest/Makefile.am, tests/perf/Makefile.am,
+ tests/perf/capi/Makefile.am,
+ tests/perf/operation/buffer/Makefile.am,
+ tests/perf/operation/predicate/Makefile.am,
+ tests/thread/Makefile.am, tests/unit/Makefile.am,
+ tests/xmltester/Makefile.am: Rename INCLUDES to AM_CPPFLAGS
+ Fixes aclocal 1.13.3 warning:
+ 'INCLUDES' is the old name for 'AM_CPPFLAGS' (or '*_CPPFLAGS')
+ Also tested with aclocal 1.11.1
+2014-02-10 18:37 Sandro Santilli <strk at kbt.io>
+ * [r3972] configure.ac, configure.in: Renamed configure.in to
+ configure.ac (#683)
+ Tested with GNU automake 1.13.3 and 1.11.1
+2014-02-10 12:49 Mateusz Loskot <mateusz at loskot.net>
+ * [r3971] src/inlines.cpp: Replace use of non-existent DLL_EXPORT
+ with GEOS_DLL_EXPORT (Ticket #681)
+2013-12-10 10:01 Sandro Santilli <strk at kbt.io>
+ * [r3966] swig/ruby/Makefile.am: Fix Ruby automake
+ There is a typo or error in the automake file that prevents the
+ Ruby
+ library from being found or properly linked in.
+ Patch by "J. Ryan Earl" <oss at jryanearl.us>
+ See https://github.com/libgeos/libgeos/pull/32
+2013-12-10 09:11 Sandro Santilli <strk at kbt.io>
+ * [r3964] src/io/WKBReader.cpp, tests/unit/io/WKBReaderTest.cpp:
+ Throw a ParseException on missing chars from HEXWKB string (#675)
+ Includes testcase.
+2013-11-19 17:28 Mateusz Loskot <mateusz at loskot.net>
+ * [r3963] nmake.opt: Add NMAKE version from VS2012 Update 4
+2013-11-19 12:30 Sandro Santilli <strk at kbt.io>
+ * [r3962] src/triangulate/VoronoiDiagramBuilder.cpp,
+ Prefer std::max over fmax (#674)
+ Should fix MSVC11 builds.
+ Patches by Twiddeldidu.
+2013-11-19 08:58 Sandro Santilli <strk at kbt.io>
+ * [r3961] configure.in: Do not try to build python and ruby
+ bindings without swig (#673)
+2013-11-19 08:26 Sandro Santilli <strk at kbt.io>
+ * [r3960] include/geos/geom/Geometry.h,
+ include/geos/geom/util/ComponentCoordinateExtracter.h,
+ include/geos/geom/util/LinearComponentExtracter.h,
+ include/geos/geom/util/PointExtracter.h,
+ include/geos/geom/util/PolygonExtracter.h, src/geom/Geometry.cpp,
+ src/geom/util/ComponentCoordinateExtracter.cpp,
+ src/geom/util/LinearComponentExtracter.cpp,
+ src/geom/util/Makefile.am, src/geom/util/PointExtracter.cpp,
+ src/geom/util/PolygonExtracter.cpp: Define
+ ComponentCoordinateExtracter classes in .cpp file (#535)
+ This is a workaround for a bug in GCC 4.4 failing to properly
+ encode inheritance info in the shared library when the class is
+ fully inlined.
+ Patch by Daniel Komisar <dkomisar at mak.com>
+2013-09-13 17:03 Sandro Santilli <strk at kbt.io>
+ * [r3959] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp,
+ tests/unit/capi/GEOSVoronoiDiagramTest.cpp: Added onlyEdges
+ parameter to GEOSVoronoiDiagram (#627)
+ Contributed by Vishal Tiwari
+2013-09-13 11:41 Sandro Santilli <strk at kbt.io>
+ * [r3957] include/geos/platform.h.in: Temptative fix for ISFINITE
+ imple with UP-UX 11.23 build (#664)
+2013-09-13 09:32 Sandro Santilli <strk at kbt.io>
+ * [r3956] .gitignore: ignore generated svn revision header
+2013-09-13 09:09 Sandro Santilli <strk at kbt.io>
+ * [r3955] NEWS, include/geos/triangulate/VoronoiDiagramBuilder.h,
+ tests/unit/triangulate/VoronoiTest.cpp: Cleanup
+ VoronoiDiagramBuilder interface, add NEWS item (#627)
+ Cleanups involved removing all explicit "delete" calls trough
+ auto_ptr uses, moving some allocations from heap to stack and
+ reducing object copies.
+2013-09-13 08:20 Sandro Santilli <strk at kbt.io>
+ * [r3954] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp,
+ tests/unit/capi/GEOSVoronoiDiagramBuilderTest.cpp,
+ tests/unit/capi/GEOSVoronoiDiagramTest.cpp: Rename CAPI method
+ GEOSVoronoiDiagramBuilder to GEOSVoronoiDiagram
+ See #627
+2013-09-13 07:56 Sandro Santilli <strk at kbt.io>
+ * [r3953] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp,
+ tests/unit/capi/GEOSVoronoiDiagramBuilderTest.cpp: capi Voronoi
+ Diagram Builder + tests
+2013-09-10 15:40 Sandro Santilli <strk at kbt.io>
+ * [r3952] src/triangulate/VoronoiDiagramBuilder.cpp: Remove
+ unneeded include
+2013-09-10 15:08 Sandro Santilli <strk at kbt.io>
+ * [r3951] include/geos/triangulate/Makefile.am,
+ src/triangulate/Makefile.am,
+ tests/unit/Makefile.am, tests/unit/triangulate/VoronoiTest.cpp:
+ VoronoiDigramBuilder class + test
+ See https://github.com/libgeos/libgeos/pull/25
+2013-09-10 07:06 Sandro Santilli <strk at kbt.io>
+ * [r3946] COPYING: Fix FSF address in license file (#662)
+2013-09-07 21:41 Sandro Santilli <strk at kbt.io>
+ * [r3945]
+ tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp: Hush
+ still-reachable valgrind report by avoiding singletons
+2013-09-07 20:11 Sandro Santilli <strk at kbt.io>
+ * [r3944] include/geos/triangulate/quadedge/QuadEdgeSubdivision.h,
+ Voronoi APIs added to QuadEdgeSubdivision class, with test added
+2013-09-04 23:14 Mateusz Loskot <mateusz at loskot.net>
+ * [r3942] .travis.yml: Remove myself from travis-ci notification
+ targets
+2013-09-02 12:14 Sandro Santilli <strk at kbt.io>
+ * [r3934] .gitignore, .travis.yml, tools/ci/before_install.sh,
+ tools/ci/script.sh: Add 32-bit build in travis-ci config (#658)
+ - Add 32-bit builds to Travis CI matrix
+ - Install gcc-multilib on Travis CI for -m32
+ - Add IRC use_notice to Travis CI notifications
+ - Set on_success and on_failure separately for IRC and email
+ - Ignore _build - convenient for CMake builds
+ Patch by Mateusz Loskot
+2013-08-31 10:38 Mateusz Loskot <mateusz at loskot.net>
+ * [r3933] .: Ignore geos_svn_revision.h, compile and test-driver
+ files
+2013-08-28 12:48 Mateusz Loskot <mateusz at loskot.net>
+ * [r3932] include/geos/triangulate/quadedge/QuadEdge.h,
+ include/geos/triangulate/quadedge/QuadEdgeSubdivision.h: Declare
+ QuadEdge and QuadEdgeSubdivision constructors as virtual to
+ correct deleting object of polymorphic type.
+2013-08-28 12:46 Mateusz Loskot <mateusz at loskot.net>
+ * [r3931] tests/xmltester/XMLTester.cpp: Untabify
+2013-08-28 12:35 Mateusz Loskot <mateusz at loskot.net>
+ * [r3930] src/operation/polygonize/EdgeRing.cpp,
+ src/triangulate/IncrementalDelaunayTriangulator.cpp,
+ src/triangulate/quadedge/QuadEdgeSubdivision.cpp: * Replace
+ while(true) with canonical for(;;)
+ * Warnings clean-up
+ * Untabify
+2013-08-28 12:32 Mateusz Loskot <mateusz at loskot.net>
+ * [r3929] include/geos/geom/BinaryOp.h: Add explicit cast from
+ double to long unsigned int
+2013-08-28 12:31 Mateusz Loskot <mateusz at loskot.net>
+ * [r3928] tests/xmltester/XMLTester.cpp: Clean unsafe mix of type
+ 'int' and type 'bool' in operation
+2013-08-28 12:00 Mateusz Loskot <mateusz at loskot.net>
+ * [r3927] tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp,
+ tests/unit/tut/tut.hpp: Disable copy ctor and assignment operator
+ where relevant.
+2013-08-28 11:59 Mateusz Loskot <mateusz at loskot.net>
+ * [r3926] tests/unit/capi/GEOSNodeTest.cpp: Replace implicit
+ boolean conversion with explicit nullptr test
+2013-08-28 11:58 Mateusz Loskot <mateusz at loskot.net>
+ * [r3925] include/geos/geom/BinaryOp.h: Ignore unused label
+2013-08-26 00:12 Regina Obe <lr at pcorp.us>
+ * [r3924] NEWS: copy over 3.4 branch news items
+2013-08-22 07:12 Sandro Santilli <strk at kbt.io>
+ * [r3914] .travis.yml, tools/ci, tools/ci/before_install.sh,
+ tools/ci/before_install_cmake.sh, tools/ci/common.sh,
+ tools/ci/script.sh, tools/ci/script_autotools.sh,
+ tools/ci/script_cmake.sh: Configure Travis CI for GEOS (#657)
+ Configurations for GCC and clang with both Autotools and CMake.
+ Enable IRC notifications
+ Contributed by Mateusz Loskot <mateusz at loskot.net>
+2013-08-22 07:09 Sandro Santilli <strk at kbt.io>
+ * [r3913] NEWS: Stub 3.5.0 section
+2013-08-22 07:07 Sandro Santilli <strk at kbt.io>
+ * [r3912] include/geos/geom/Triangle.h, src/geom/Triangle.cpp,
+ tests/unit/geom/TriangleTest.cpp: circumcentre() and det()
+ methods added to class Triangle
+ Includes test for circumcentre()
+2013-08-22 06:19 Sandro Santilli <strk at kbt.io>
+ * [r3910] tests/unit/capi/GEOSisValidDetailTest.cpp: Accept
+ multiple NaN representations (#656)
+2013-08-21 13:54 Sandro Santilli <strk at kbt.io>
+ * [r3908] CMakeLists.txt: Set JTS_PORT for CMake in sync with
+ others
+ .. we should really reduce the number of places version is set
+2013-08-21 13:47 Sandro Santilli <strk at kbt.io>
+ * [r3907] include/geos/geom/BinaryOp.h: Use a double for
+ PrecisionModel scale, avoiding overflows
+ Fixes #652
+2013-08-21 10:53 Regina Obe <lr at pcorp.us>
+ * [r3902] include/geos/platform.h.in: #650 isnan workaround OS
+ detection missing NetBSD, DragonFly, Sun nuance
+2013-08-20 12:15 Sandro Santilli <strk at kbt.io>
+ * [r3901] include/geos/triangulate/quadedge/Vertex.h,
+ src/triangulate/quadedge/Vertex.cpp: Change operator< for Vertex
+ to be inlined and use Coordinate operator<
+ * [r3900] tests/unit/triangulate/quadedge/VertexTest.cpp: Simplify
+ Vertext test
+ * [r3899] include/geos/triangulate/quadedge/Vertex.h,
+ src/triangulate/quadedge/Vertex.cpp, tests/unit/Makefile.am,
+ tests/unit/triangulate/quadedge/VertexTest.cpp: operator< for
+ Vertex added
+ Includes test
+ Path by Vishal Tiwari
+2013-08-19 14:12 Sandro Santilli <strk at kbt.io>
+ * [r3896] include/geos/Makefile.am: Install but do not distribute
+ generated headers
+ These are platform.h and version.h
+ Fixes bug #601 and the lack of C++ headers install in
+ releases 3.4.0 and 3.4.1
+2013-08-17 03:17 Regina Obe <lr at pcorp.us>
+ * [r3889] CMakeLists.txt: #644 Can't build using cmake with tar
+ ball
+ only do svn check if there is a .svn file in
+ source folder to ensure it works with tar ball
+2013-08-16 15:25 Sandro Santilli <strk at kbt.io>
+ * [r3885] src/operation/overlay/snap/LineStringSnapper.cpp,
+ tests/unit/capi/GEOSSnapTest.cpp: Fix assertion failure in
+ snapping code (#649)
+ The bug affected attempts to snapping lines to the points
+ of a rectangle with a side smaller than the tolerance.
+2013-08-14 06:09 Regina Obe <lr at pcorp.us>
+ * [r3883] CMakeLists.txt, HOWTO_RELEASE: update HOWTO_RELEASE to
+ include bumping revision numbrs in CMake and also bump numbers in
+ CMake.
+2013-08-11 11:42 Sandro Santilli <strk at kbt.io>
+ * [r3879] tests/xmltester/testrunner.sh, tools/geos-config.in: Set
+ correct eol-style for geos-config and testrunner (#645)
+2013-08-11 11:24 Sandro Santilli <strk at kbt.io>
+ * [r3878] include/geos/platform.h.in: Set LF eol-style property for
+ platform.h.in (#645)
+2013-08-11 04:20 Regina Obe <lr at pcorp.us>
+ * [r3877] capi/geos_c.h.in: bump to 3.5.0 and capi to next
+2013-08-11 04:17 Regina Obe <lr at pcorp.us>
+ * [r3876] NEWS: update date on news
+2013-08-11 03:54 Regina Obe <lr at pcorp.us>
+ * [r3873] configure.in, include/geos/version.h.vc: bump all
+ revisions with plan we will have Voronoi ported over (strk change
+ if I did this wrong)
+2013-08-11 03:44 Regina Obe <lr at pcorp.us>
+ * [r3870] include/geos/version.h.vc: update version numbers to
+ agree with configure.in - huh why are the version numbers all old
+ in this file?
+2013-08-11 03:41 Regina Obe <lr at pcorp.us>
+ * [r3869] configure.in: get rid of dev in version# in prep for
+ 3.4.0 release
+2013-08-11 03:37 Regina Obe <lr at pcorp.us>
+ * [r3868] ChangeLog: update change log in prep for 3.4.0 release
2013-08-08 04:25 Regina Obe <lr at pcorp.us>
* [r3867] ChangeLog, NEWS: update news and change log in prep for
@@ -8,17 +2004,17 @@
* [r3866] include/geos/Makefile.am: #601 do not incude platform.h
in tar ball.
-2013-08-04 12:27 Sandro Santilli <strk at keybit.net>
+2013-08-04 12:27 Sandro Santilli <strk at kbt.io>
* [r3864] src/triangulate/DelaunayTriangulationBuilder.cpp: Avoid
Coordinate copies in DelaunayTriangulationBuilder::envelope
-2013-08-04 12:23 Sandro Santilli <strk at keybit.net>
+2013-08-04 12:23 Sandro Santilli <strk at kbt.io>
* [r3863] tests/unit/triangulate/DelaunayTest.cpp: Simplify
testcase for DelaunayTriangulationBuilder::envelope
-2013-08-04 11:58 Sandro Santilli <strk at keybit.net>
+2013-08-04 11:58 Sandro Santilli <strk at kbt.io>
* [r3862] include/geos/triangulate/DelaunayTriangulationBuilder.h,
src/triangulate/DelaunayTriangulationBuilder.cpp,
@@ -62,7 +2058,7 @@
* [r3854] authors.svn: add myself to author list
-2013-07-31 09:42 Sandro Santilli <strk at keybit.net>
+2013-07-31 09:42 Sandro Santilli <strk at kbt.io>
* [r3853] NEWS, include/geos/geom/BinaryOp.h,
@@ -81,14 +2077,14 @@
Fixes bug #459
-2013-07-31 08:34 Sandro Santilli <strk at keybit.net>
+2013-07-31 08:34 Sandro Santilli <strk at kbt.io>
* [r3852] tests/xmltester/tests/buffer.xml: Do not expect invalid
output from buffer
The test verification code is tollerant, but better fix this
-2013-07-31 08:30 Sandro Santilli <strk at keybit.net>
+2013-07-31 08:30 Sandro Santilli <strk at kbt.io>
* [r3851] tests/xmltester/tests/ticket/bug275.xml: Turn test for
ticket 275 into an "area test".
@@ -98,12 +2094,12 @@
is about the same as the sum of area of symdifference + area of
intersection.
-2013-07-25 21:00 Sandro Santilli <strk at keybit.net>
+2013-07-25 21:00 Sandro Santilli <strk at kbt.io>
* [r3850] include/geos/geom/CoordinateList.h: Fix
CoordinateList.closeRing() use of past-the-end operator
-2013-07-25 20:51 Sandro Santilli <strk at keybit.net>
+2013-07-25 20:51 Sandro Santilli <strk at kbt.io>
* [r3849] include/geos/geom/CoordinateList.h,
tests/unit/geom/CoordinateListTest.cpp: closeRing() method added
@@ -111,7 +2107,7 @@
Patch by Vishal Tiwari <hi.vishal123 at gmail.com>
-2013-07-23 11:01 Sandro Santilli <strk at keybit.net>
+2013-07-23 11:01 Sandro Santilli <strk at kbt.io>
* [r3848] capi/geos_c.cpp, capi/geos_c.h.in: Cosmetic changes into
the CAPI code, by Mike Toews
@@ -128,46 +2124,46 @@
- Clip trailing white space, and other white space consistencies
- Other minor rearrangements for consistency
-2013-07-17 16:07 Sandro Santilli <strk at keybit.net>
+2013-07-17 16:07 Sandro Santilli <strk at kbt.io>
* [r3846] src/operation/buffer/OffsetCurveBuilder.cpp,
tests/unit/capi/GEOSOffsetCurveTest.cpp: Make GEOSOffsetCurve
survive single-point input (with an exception)
-2013-07-17 15:58 Sandro Santilli <strk at keybit.net>
+2013-07-17 15:58 Sandro Santilli <strk at kbt.io>
* [r3845] src/operation/buffer/BufferInputLineSimplifier.cpp,
src/operation/buffer/OffsetSegmentGenerator.cpp,
tests/unit/capi/GEOSOffsetCurveTest.cpp: Fix OffsetCurve op in
presence of duplicated vertices (#602)
-2013-07-17 13:05 Sandro Santilli <strk at keybit.net>
+2013-07-17 13:05 Sandro Santilli <strk at kbt.io>
* [r3844] src/simplify/LineSegmentIndex.cpp: Fix LineSegmentVisitor
copy ctor (#636)
-2013-07-15 15:21 Sandro Santilli <strk at keybit.net>
+2013-07-15 15:21 Sandro Santilli <strk at kbt.io>
* [r3840] src/geom/GeometryCollection.cpp,
tests/unit/io/WKBWriterTest.cpp: Drop SRID from
geometrycollection elements (#583)
-2013-07-12 12:37 Sandro Santilli <strk at keybit.net>
+2013-07-12 12:37 Sandro Santilli <strk at kbt.io>
* [r3839] tests/unit/geom/Geometry/coversTest.cpp: Add test for
#580 (successful)
-2013-07-11 15:58 Sandro Santilli <strk at keybit.net>
+2013-07-11 15:58 Sandro Santilli <strk at kbt.io>
* [r3837] tests/unit/capi/GEOSOffsetCurveTest.cpp: Fix memory leak
in testcase
-2013-07-11 15:54 Sandro Santilli <strk at keybit.net>
+2013-07-11 15:54 Sandro Santilli <strk at kbt.io>
* [r3836] tests/unit/capi/GEOSOffsetCurveTest.cpp: Drop carriage
returns
-2013-07-11 15:34 Sandro Santilli <strk at keybit.net>
+2013-07-11 15:34 Sandro Santilli <strk at kbt.io>
* [r3835] include/geos/triangulate/quadedge/QuadEdge.h,
@@ -176,30 +2172,30 @@
tests/unit/triangulate/DelaunayTest.cpp: Fix memory in
QuadEdgeSubdivision (#604)
-2013-07-11 08:21 Sandro Santilli <strk at keybit.net>
+2013-07-11 08:21 Sandro Santilli <strk at kbt.io>
* [r3834] NEWS, php/geos.c, php/test/test.php: Expose Delaunay
triangulation to PHP API (#567)
-2013-07-11 07:36 Sandro Santilli <strk at keybit.net>
+2013-07-11 07:36 Sandro Santilli <strk at kbt.io>
* [r3833] php/test/test.php: Fix test after changes in
PointOnSurface
-2013-07-11 05:49 Sandro Santilli <strk at keybit.net>
+2013-07-11 05:49 Sandro Santilli <strk at kbt.io>
* [r3832] NEWS, tools/geos-config.in: Add --cclibs, --static-clibs
and --static-cclibs to geos-config (#497)
-2013-07-11 05:46 Sandro Santilli <strk at keybit.net>
+2013-07-11 05:46 Sandro Santilli <strk at kbt.io>
* [r3831] NEWS: Add 3.3.1 to 3.3.8 section
-2013-07-11 05:42 Sandro Santilli <strk at keybit.net>
+2013-07-11 05:42 Sandro Santilli <strk at kbt.io>
* [r3830] NEWS: Cleanup NEWS file confused in r3816
-2013-07-05 14:56 Sandro Santilli <strk at keybit.net>
+2013-07-05 14:56 Sandro Santilli <strk at kbt.io>
* [r3829] include/geos/linearref/Makefile.am: Fix install location
of linearref headers (#624)
@@ -209,7 +2205,7 @@
* [r3827] nmake.opt: Add NMAKE version from Visual Studio 2012
Update 3 RTM
-2013-06-26 16:27 Sandro Santilli <strk at keybit.net>
+2013-06-26 16:27 Sandro Santilli <strk at kbt.io>
* [r3826] src/noding/snapround/HotPixel.cpp,
tests/unit/noding/snapround/HotPixelTest.cpp: Fix typo in
@@ -279,12 +2275,12 @@
left-side flag to initialise the side segments.
* Corresponding test case attached.
-2013-06-11 12:42 Sandro Santilli <strk at keybit.net>
+2013-06-11 12:42 Sandro Santilli <strk at kbt.io>
* [r3816] NEWS, include/geos/profiler.h: Fix for mingw64 compile,
by Regina Obe (#630)
-2013-06-07 09:29 Sandro Santilli <strk at keybit.net>
+2013-06-07 09:29 Sandro Santilli <strk at kbt.io>
* [r3814] src/operation/overlay/snap/LineStringSnapper.cpp:
Simplify code looking for closer vertex snap
@@ -325,7 +2321,7 @@
* [r3809] include/geos/operation/buffer/OffsetSegmentString.h:
Correct return type of OffsetSegmentString::size() to be size_t
-2013-06-06 20:18 Sandro Santilli <strk at keybit.net>
+2013-06-06 20:18 Sandro Santilli <strk at kbt.io>
* [r3808] examples/CPCLException.cpp,
examples/CoordinateSequencesExample.cpp,
@@ -334,7 +2330,7 @@
examples/CustomPointCoordinateSequence.cpp, examples/Makefile.am:
Drop obsoleted files
-2013-06-06 16:39 Sandro Santilli <strk at keybit.net>
+2013-06-06 16:39 Sandro Santilli <strk at kbt.io>
* [r3807] src/operation/overlay/snap/LineStringSnapper.cpp: Drop
commented out / disabled code
@@ -349,14 +2345,14 @@
* [r3805] CMakeLists.txt: Make Visual C++ 11.0 recognised by CMake
configuration
-2013-06-03 07:36 Sandro Santilli <strk at keybit.net>
+2013-06-03 07:36 Sandro Santilli <strk at kbt.io>
* [r3803] src/geom/prep/PreparedPolygonIntersects.cpp:
Short-circuit prepared polygon/point intersection
Reduces memory fragmentation for area-puntal ops
-2013-05-30 20:16 Sandro Santilli <strk at keybit.net>
+2013-05-30 20:16 Sandro Santilli <strk at kbt.io>
* [r3800] include/geos/operation/overlay/snap/LineStringSnapper.h,
@@ -373,14 +2369,14 @@
tools"
(CIG Z3B06FA6D7).
-2013-05-23 17:21 Sandro Santilli <strk at keybit.net>
+2013-05-23 17:21 Sandro Santilli <strk at kbt.io>
* [r3799] Makefile.am, tools/svn_repo_revision.sh: Create
geos_svn_revision.h in the source tree
It's a generated source, should always be in the tarball anyway
-2013-05-23 15:51 Sandro Santilli <strk at keybit.net>
+2013-05-23 15:51 Sandro Santilli <strk at kbt.io>
* [r3798] tools/Makefile.am: Distribute svn_repo_revision.sh
@@ -405,14 +2401,14 @@
* Add MSVC_VLD_DIR option to nmake.opt to enable/disable VLD
* Add optional #include <vld.h> to Geometry.cpp
-2013-03-15 18:48 Sandro Santilli <strk at keybit.net>
+2013-03-15 18:48 Sandro Santilli <strk at kbt.io>
* [r3793] tests/unit/algorithm/RobustLineIntersectionTest.cpp,
tests/unit/capi/GEOSConvexHullTest.cpp,
tests/unit/capi/GEOSUnaryUnionTest.cpp: Fix memory leaks in unit
tests
-2013-03-15 18:05 Sandro Santilli <strk at keybit.net>
+2013-03-15 18:05 Sandro Santilli <strk at kbt.io>
* [r3792] NEWS, capi/geos_c.cpp, capi/geos_c.h.in,
@@ -427,16 +2423,16 @@
* [r3791] nmake.opt: Add x64 NMAKE version from Visual Studio 2012
Update 1
-2013-03-12 16:20 Sandro Santilli <strk at keybit.net>
+2013-03-12 16:20 Sandro Santilli <strk at kbt.io>
* [r3790] macros/ruby.m4: Fix "puts puts" typo in ruby macro (#625)
-2013-03-11 11:19 Sandro Santilli <strk at keybit.net>
+2013-03-11 11:19 Sandro Santilli <strk at kbt.io>
* [r3789] tests/unit/algorithm/RobustLineIntersectionTest.cpp: Port
new RobustLineIntersection test from JTS
-2013-03-08 17:51 Sandro Santilli <strk at keybit.net>
+2013-03-08 17:51 Sandro Santilli <strk at kbt.io>
* [r3787] include/geos/algorithm/LineIntersector.h,
@@ -463,7 +2459,7 @@
* [r3784] nmake.opt: Add NMAKE version from Visual Studio 2012
Update 1
-2013-03-08 13:02 Sandro Santilli <strk at keybit.net>
+2013-03-08 13:02 Sandro Santilli <strk at kbt.io>
* [r3781] include/geos/algorithm/InteriorPointArea.h,
src/algorithm/Centroid.cpp, src/algorithm/InteriorPointArea.cpp,
@@ -473,17 +2469,17 @@
Ports SafeBisector for InteriorPointArea from JTS
-2013-03-05 14:46 Sandro Santilli <strk at keybit.net>
+2013-03-05 14:46 Sandro Santilli <strk at kbt.io>
* [r3779] capi/geos_ts_c.cpp: Speedup GEOSWKBWriter_read_r (#621)
Patch by Daniel Zeitlin
-2013-03-01 11:58 Sandro Santilli <strk at keybit.net>
+2013-03-01 11:58 Sandro Santilli <strk at kbt.io>
* [r3778] HOWTO_RELEASE: Add wiki update and announce steps
-2013-02-28 09:40 Sandro Santilli <strk at keybit.net>
+2013-02-28 09:40 Sandro Santilli <strk at kbt.io>
* [r3773] src/algorithm/CentroidArea.cpp,
@@ -492,7 +2488,7 @@
Fixes bug #582
-2013-02-25 11:41 Sandro Santilli <strk at keybit.net>
+2013-02-25 11:41 Sandro Santilli <strk at kbt.io>
* [r3772] macros/ruby.m4, swig/ruby/geos_wrap.cxx: Update
macros/ruby.m4 for ruby 1.9.x
@@ -502,13 +2498,13 @@
Patch by Kashif Rasul <kashif.rasul at gmail.com>
-2013-02-25 11:11 Sandro Santilli <strk at keybit.net>
+2013-02-25 11:11 Sandro Santilli <strk at kbt.io>
* [r3771] include/geos/platform.h.in: Fix build under cygwin (#595)
Thanks Jason Huntley
-2013-02-25 11:04 Sandro Santilli <strk at keybit.net>
+2013-02-25 11:04 Sandro Santilli <strk at kbt.io>
* [r3770] include/geos/io/WKTReader.h,
include/geos/io/WKTReader.inl: Deprecate WKTReader constructor
@@ -518,19 +2514,19 @@
WKBReader
Closes #310
-2013-02-25 10:37 Sandro Santilli <strk at keybit.net>
+2013-02-25 10:37 Sandro Santilli <strk at kbt.io>
* [r3769] NEWS, include/geos/io/Writer.h, src/io/Writer.cpp,
tests/unit/io/WriterTest.cpp: New ::reserve(size_t) method for
io::Writer class
-2013-02-25 10:34 Sandro Santilli <strk at keybit.net>
+2013-02-25 10:34 Sandro Santilli <strk at kbt.io>
* [r3768] NEWS, include/geos/io/Writer.h, src/io/Writer.cpp,
tests/unit/Makefile.am, tests/unit/io/WriterTest.cpp: io::Writer:
take and give strings by const ref, use .append, testcase
-2013-02-21 10:29 Sandro Santilli <strk at keybit.net>
+2013-02-21 10:29 Sandro Santilli <strk at kbt.io>
* [r3767] src/io/WKTWriter.cpp: WKTWriter::appendCoordinate
optimisation
@@ -548,30 +2544,30 @@
include/geos/triangulate/quadedge, src/triangulate,
src/triangulate/quadedge: Update svn:ignore property
-2013-02-01 06:31 Sandro Santilli <strk at keybit.net>
+2013-02-01 06:31 Sandro Santilli <strk at kbt.io>
* [r3762] include/geos/io/CLocalizer.h: Add header guard to
CLocalizer (#619)
-2013-02-01 06:28 Sandro Santilli <strk at keybit.net>
+2013-02-01 06:28 Sandro Santilli <strk at kbt.io>
* [r3760] include/geos/linearref/LocationIndexOfLine.h,
src/linearref/LocationIndexOfLine.cpp: Fix header guard and port
info in LocatioNIndexOfLine (#618)
-2013-02-01 06:25 Sandro Santilli <strk at keybit.net>
+2013-02-01 06:25 Sandro Santilli <strk at kbt.io>
* [r3758] include/geos/geom/util/GeometryExtracter.h: Fix header
guard in GeometryExtracter (#617)
-2013-01-25 17:19 Sandro Santilli <strk at keybit.net>
+2013-01-25 17:19 Sandro Santilli <strk at kbt.io>
* [r3755] src/operation/valid/IsValidOp.cpp: IsValidOp: throw
proper error on nested shells (#608)
Thanks geomworx
-2013-01-17 12:07 Sandro Santilli <strk at keybit.net>
+2013-01-17 12:07 Sandro Santilli <strk at kbt.io>
* [r3751] include/geos/geom/BinaryOp.h,
@@ -589,7 +2585,7 @@
which is the same behavior JTS exposes. The (bogus) test for it
is disabled by this commit.
-2013-01-14 16:15 Sandro Santilli <strk at keybit.net>
+2013-01-14 16:15 Sandro Santilli <strk at kbt.io>
* [r3749] NEWS, include/geos/algorithm/Centroid.h,
include/geos/algorithm/CentroidArea.h,
@@ -603,19 +2599,19 @@
This commit ports new Centroid class from JTS (#612)
-2013-01-14 11:16 Sandro Santilli <strk at keybit.net>
+2013-01-14 11:16 Sandro Santilli <strk at kbt.io>
* [r3748] include/geos/algorithm/InteriorPointArea.h,
tests/xmltester/tests/general/TestInteriorPoint.xml: Fix EMPTY
return from zero-area polygon (#613)
-2013-01-14 11:12 Sandro Santilli <strk at keybit.net>
+2013-01-14 11:12 Sandro Santilli <strk at kbt.io>
* [r3747] tests/xmltester/XMLTester.cpp: Have XMLTester use POINT
EMPTY for a null return from getInteriorPoint
-2013-01-14 09:50 Sandro Santilli <strk at keybit.net>
+2013-01-14 09:50 Sandro Santilli <strk at kbt.io>
* [r3744] include/geos/util/Interrupt.h, src/util/Interrupt.cpp:
Move static class members of Interrupt out of header (#611)
@@ -631,7 +2627,7 @@
* [r3742] nmake.opt: Report general and custom flags separately
-2013-01-11 14:58 Sandro Santilli <strk at keybit.net>
+2013-01-11 14:58 Sandro Santilli <strk at kbt.io>
* [r3741] src/algorithm/InteriorPointLine.cpp,
tests/unit/capi/GEOSPointOnSurfaceTest.cpp: Fix
@@ -642,26 +2638,26 @@
* [r3740] tests/unit/io/WKTReaderTest.cpp: Added test<7>() for the
poorly reported bug ticket #610 - bug not reproducible.
-2012-12-06 08:23 Sandro Santilli <strk at keybit.net>
+2012-12-06 08:23 Sandro Santilli <strk at kbt.io>
* [r3737] configure.in: See if AC_CONFIG_HEADERS makes winnie
happier
... and also how many other builds it breaks, if any
-2012-12-06 08:04 Sandro Santilli <strk at keybit.net>
+2012-12-06 08:04 Sandro Santilli <strk at kbt.io>
* [r3736] src/Makefile.vc: Add missing classes to build script for
evil compiler
Curtesy of Geoff Evans
-2012-12-05 09:06 Sandro Santilli <strk at keybit.net>
+2012-12-05 09:06 Sandro Santilli <strk at kbt.io>
* [r3734] src/operation/buffer/BufferOp.cpp: Add note about
rounding in fixed precision buffer op (#605)
-2012-12-05 07:56 Sandro Santilli <strk at keybit.net>
+2012-12-05 07:56 Sandro Santilli <strk at kbt.io>
* [r3733] src/operation/buffer/BufferOp.cpp: Do not reduce
precision below 6 significant digits.
@@ -669,11 +2665,11 @@
Avoids gross results (preferring an exception)
See http://trac.osgeo.org/geos/ticket/605
-2012-12-04 21:50 Sandro Santilli <strk at keybit.net>
+2012-12-04 21:50 Sandro Santilli <strk at kbt.io>
* [r3731] NEWS: Add note about BufferOp robustness improvement
-2012-12-04 21:22 Sandro Santilli <strk at keybit.net>
+2012-12-04 21:22 Sandro Santilli <strk at kbt.io>
* [r3728] src/operation/buffer/BufferOp.cpp,
@@ -682,7 +2678,7 @@
Fixes #605, adds test for it
-2012-12-04 19:26 Sandro Santilli <strk at keybit.net>
+2012-12-04 19:26 Sandro Santilli <strk at kbt.io>
* [r3727] src/operation/buffer/RightmostEdgeFinder.cpp: Fix an
abort in Buffer op (RightmostEdgeFinder)
@@ -692,23 +2688,23 @@
seems to occur when noding isn't correct.
-2012-12-04 17:23 Sandro Santilli <strk at keybit.net>
+2012-12-04 17:23 Sandro Santilli <strk at kbt.io>
* [r3726] tests/unit/Makefile.am,
tests/unit/noding/OrientedCoordinateArray.cpp: Add unit test for
-2012-11-15 15:55 Sandro Santilli <strk at keybit.net>
+2012-11-15 15:55 Sandro Santilli <strk at kbt.io>
* [r3720] tests/xmltester/Makefile.am,
tests/xmltester/tests/ticket/bug599.xml: Add automated test for
#599 (succeeds)
-2012-10-26 14:01 Sandro Santilli <strk at keybit.net>
+2012-10-26 14:01 Sandro Santilli <strk at kbt.io>
* [r3719] Makefile.am: Fix building outside the source tree
-2012-09-10 10:34 Sandro Santilli <strk at keybit.net>
+2012-09-10 10:34 Sandro Santilli <strk at kbt.io>
* [r3716] NEWS, src/triangulate/quadedge/QuadEdgeSubdivision.cpp,
tests/unit/triangulate/DelaunayTest.cpp: Add Z support in
@@ -716,27 +2712,27 @@
Thanks Benjamin Campbell
-2012-09-10 09:23 Sandro Santilli <strk at keybit.net>
+2012-09-10 09:23 Sandro Santilli <strk at kbt.io>
* [r3715] tests/xmltester/tests/ticket/bug586.xml: Tweak the test
for bug 586 to succeed while still being small
-2012-09-10 08:00 Sandro Santilli <strk at keybit.net>
+2012-09-10 08:00 Sandro Santilli <strk at kbt.io>
* [r3712] tests/xmltester/Makefile.am,
tests/xmltester/tests/ticket/bug586.xml: Add test for bug #586
-2012-09-10 07:56 Sandro Santilli <strk at keybit.net>
+2012-09-10 07:56 Sandro Santilli <strk at kbt.io>
* [r3711] include/geos/geom/BinaryOp.h: Do not try to fix valid
geometries (#586)
-2012-09-07 12:01 Sandro Santilli <strk at keybit.net>
+2012-09-07 12:01 Sandro Santilli <strk at kbt.io>
* [r3710] swig/python/geos.py, swig/python/geos_wrap.cxx:
Regenerate swig files with swig 2.0.4
-2012-09-06 18:22 Sandro Santilli <strk at keybit.net>
+2012-09-06 18:22 Sandro Santilli <strk at kbt.io>
* [r3708] php/README, php/test/test.php: Add support for phpunit
3.6 (not loosing support for 3.4)
@@ -751,38 +2747,38 @@
* [r3705] src/Makefile.vc: Updated NMAKE makefile with recently
added source files (Ticket #574)
-2012-07-26 22:43 Sandro Santilli <strk at keybit.net>
+2012-07-26 22:43 Sandro Santilli <strk at kbt.io>
* [r3704] include/geos/Makefile.am: Don't live triangulate includes
out of build (#573)
Thanks Sandro Furieri
-2012-06-27 10:53 Sandro Santilli <strk at keybit.net>
+2012-06-27 10:53 Sandro Santilli <strk at kbt.io>
* [r3703] tests/unit/capi/GEOSDelaunayTriangulationTest.cpp: Add
test for Delaunay triangulation with a tolerance
-2012-06-27 10:43 Sandro Santilli <strk at keybit.net>
+2012-06-27 10:43 Sandro Santilli <strk at kbt.io>
* [r3702] NEWS, capi/geos_c.cpp, capi/geos_c.h.in,
capi/geos_ts_c.cpp, tests/unit/Makefile.am,
tests/unit/capi/GEOSDelaunayTriangulationTest.cpp: Expose
Delaunay triangulation to C-API (#565)
* [r3701] include/geos/triangulate/DelaunayTriangulationBuilder.h,
src/triangulate/DelaunayTriangulationBuilder.cpp: Const-correct
getTriangles / getEdges and move to proper namespace
* [r3700]
include/geos/triangulate/IncrementalDelaunayTriangulator.h:
indent
-2012-06-27 09:23 Sandro Santilli <strk at keybit.net>
+2012-06-27 09:23 Sandro Santilli <strk at kbt.io>
* [r3699] include/geos/triangulate/DelaunayTriangulationBuilder.h,
include/geos/triangulate/IncrementalDelaunayTriangulator.h,
@@ -818,12 +2814,12 @@
* [r3695] tests/perf, tests/perf/operation/predicate: Updated
svn:ignore for tests/perf
-2012-06-26 17:17 Sandro Santilli <strk at keybit.net>
+2012-06-26 17:17 Sandro Santilli <strk at kbt.io>
* [r3694] include/geos/triangulate/DelaunayTriangulationBuilder.h:
typo
-2012-06-26 17:11 Sandro Santilli <strk at keybit.net>
+2012-06-26 17:11 Sandro Santilli <strk at kbt.io>
* [r3693] NEWS, configure.in, include/geos/triangulate,
@@ -866,11 +2862,11 @@
The SOVERSION is now set with CAPI_VERSION_CURRENT -
CAPI_VERSION_AGE (Ticket #446)
-2012-06-25 15:17 Sandro Santilli <strk at keybit.net>
+2012-06-25 15:17 Sandro Santilli <strk at kbt.io>
* [r3691] HOWTO_RELEASE: Add tarball verification step
-2012-06-25 10:19 Sandro Santilli <strk at keybit.net>
+2012-06-25 10:19 Sandro Santilli <strk at kbt.io>
* [r3684] capi/geos_ts_c.cpp, tests/unit/Makefile.am,
tests/unit/capi/GEOSPointOnSurfaceTest.cpp: Always return POINT
@@ -882,37 +2878,37 @@
[CMake] Set SOVERSION property on C API shared library using
CAPI_INTERFACE_* values (Ticket #446).
-2012-06-22 15:44 Sandro Santilli <strk at keybit.net>
+2012-06-22 15:44 Sandro Santilli <strk at kbt.io>
* [r3680] include/geos/algorithm/CentroidArea.h: Add note about
handling of degenerate polygons
-2012-06-22 15:32 Sandro Santilli <strk at keybit.net>
+2012-06-22 15:32 Sandro Santilli <strk at kbt.io>
* [r3679] capi/geos_ts_c.cpp,
tests/unit/capi/GEOSGetCentroidTest.cpp: Always return POINT from
GEOSGetCentroid, even for EMPTY (#560)
-2012-06-22 15:03 Sandro Santilli <strk at keybit.net>
+2012-06-22 15:03 Sandro Santilli <strk at kbt.io>
* [r3677] include/geos/algorithm/CentroidArea.h,
src/algorithm/CentroidArea.cpp, tests/unit/Makefile.am,
tests/unit/capi/GEOSGetCentroidTest.cpp: Port robustness fix to
CentroidArea (#559)
-2012-06-11 09:18 Sandro Santilli <strk at keybit.net>
+2012-06-11 09:18 Sandro Santilli <strk at kbt.io>
* [r3673] tests/xmltester/Makefile.am: Retain GEOS_INLINE define
while building XMLTester (#319, #472)
-2012-06-07 15:11 Sandro Santilli <strk at keybit.net>
+2012-06-07 15:11 Sandro Santilli <strk at kbt.io>
* [r3672] capi/geos_c.cpp, capi/geos_c.h.in,
include/geos/util/Interrupt.h, src/util/Interrupt.cpp,
tests/unit/capi/GEOSInterruptTest.cpp: Allow chaining interrupt
callbacks, drop arg parameter
-2012-06-07 15:10 Sandro Santilli <strk at keybit.net>
+2012-06-07 15:10 Sandro Santilli <strk at kbt.io>
* [r3671] capi/geos_ts_c.cpp,
tests/unit/capi/GEOSInterruptTest.cpp: Revert the interrupt
@@ -921,29 +2917,29 @@
Once you set a callback why would you want it unregistered on
initGEOS ? You will not want that....
-2012-06-07 14:41 Sandro Santilli <strk at keybit.net>
+2012-06-07 14:41 Sandro Santilli <strk at kbt.io>
* [r3670] src/util/Interrupt.cpp: Clear interruption request flag
just before interrupting
-2012-06-07 10:24 Sandro Santilli <strk at keybit.net>
+2012-06-07 10:24 Sandro Santilli <strk at kbt.io>
* [r3669] capi/geos_c.h.in: Drop orphaned custom allocation
signatures from C-API header
-2012-06-07 10:23 Sandro Santilli <strk at keybit.net>
+2012-06-07 10:23 Sandro Santilli <strk at kbt.io>
* [r3668] tests/unit/capi/GEOSInterruptTest.cpp: Test that initGEOS
clears the interrupt callback
Also explicitly cleanup the callback after each test.
* [r3667] capi/geos_ts_c.cpp: Unregister the interrupt request on
initGEOS
-2012-06-07 10:07 Sandro Santilli <strk at keybit.net>
+2012-06-07 10:07 Sandro Santilli <strk at kbt.io>
* [r3666] NEWS, capi/geos_c.cpp, capi/geos_c.h.in,
@@ -952,54 +2948,54 @@
This is to enhance flexibility of the interruption request model.
-2012-06-06 14:15 Sandro Santilli <strk at keybit.net>
+2012-06-06 14:15 Sandro Santilli <strk at kbt.io>
* [r3665] tests/unit/Makefile.am,
tests/unit/capi/GEOSConvexHullTest.cpp: Enable
capi::GEOSConvexHull test, and fix it (#555)
-2012-06-06 07:03 Sandro Santilli <strk at keybit.net>
+2012-06-06 07:03 Sandro Santilli <strk at kbt.io>
* [r3663] README, src/Makefile.am: Clarify problems with linking
against C++ api (#553)
Path by Greg Troxel.
-2012-05-29 19:23 Sandro Santilli <strk at keybit.net>
+2012-05-29 19:23 Sandro Santilli <strk at kbt.io>
* [r3657] include/geos/algorithm/distance/PointPairDistance.h: No
need to forward declare Coordinate (full definition included)
* [r3656] include/geos/geom/Coordinate.h,
include/geos/geom/Coordinate.inl: Do not define an empty
destructor for Coordinate
-2012-05-29 16:41 Sandro Santilli <strk at keybit.net>
+2012-05-29 16:41 Sandro Santilli <strk at kbt.io>
* [r3655] Makefile.am: Make sure to build geos_svn_config.h
-2012-05-29 10:04 Sandro Santilli <strk at keybit.net>
+2012-05-29 10:04 Sandro Santilli <strk at kbt.io>
* [r3654] Makefile.am, capi/geos_ts_c.cpp: Include SVN revision in
GEOSversion output
* [r3653] tools/svn_repo_revision.sh: Fix revision file path
-2012-05-29 09:48 Sandro Santilli <strk at keybit.net>
+2012-05-29 09:48 Sandro Santilli <strk at kbt.io>
* [r3652] tools/svn_repo_revision.sh: Fix test for directory
existance
-2012-05-29 09:45 Sandro Santilli <strk at keybit.net>
+2012-05-29 09:45 Sandro Santilli <strk at kbt.io>
* [r3651] tools/svn_repo_revision.sh: Add script to fetch SVN
revision from git or SVN
-2012-05-29 08:42 Sandro Santilli <strk at keybit.net>
+2012-05-29 08:42 Sandro Santilli <strk at kbt.io>
* [r3650] doc/example.cpp, examples/CPCLException.cpp,
@@ -1395,7 +3391,7 @@
tests/xmltester/CTS.cpp, tests/xmltester/SimpleWKTTester.cpp,
tests/xmltester/Stackwalker.h: Drop embedded RCS logs
-2012-05-28 12:29 Sandro Santilli <strk at keybit.net>
+2012-05-28 12:29 Sandro Santilli <strk at kbt.io>
* [r3649] NEWS,
include/geos/operation/buffer/BufferInputLineSimplifier.h,
@@ -1409,12 +3405,12 @@
Thanks ylan for the patch
-2012-05-28 07:48 Sandro Santilli <strk at keybit.net>
+2012-05-28 07:48 Sandro Santilli <strk at kbt.io>
* [r3648] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
Rename interrupt request/cancel methods, cancel interrupt in init
-2012-05-25 15:50 Sandro Santilli <strk at keybit.net>
+2012-05-25 15:50 Sandro Santilli <strk at kbt.io>
* [r3647] NEWS, capi/geos_ts_c.cpp,
include/geos/util/CustomAllocators.h,
@@ -1425,17 +3421,17 @@
It wasn't well done. Pity.
-2012-05-25 15:26 Sandro Santilli <strk at keybit.net>
+2012-05-25 15:26 Sandro Santilli <strk at kbt.io>
* [r3646] capi/geos_c.cpp, capi/geos_c.h.in: Expose interrupt
request cancel to the C-API
-2012-05-25 12:26 Sandro Santilli <strk at keybit.net>
+2012-05-25 12:26 Sandro Santilli <strk at kbt.io>
* [r3645] include/geos/util/Interrupt.h: Add method to cancel an
interruption request in util::Interrupt
-2012-05-25 12:15 Sandro Santilli <strk at keybit.net>
+2012-05-25 12:15 Sandro Santilli <strk at kbt.io>
* [r3644] src/noding/MCIndexNoder.cpp: Add strategic check for
interrupt in MCIndexNoder loop
@@ -1443,7 +3439,7 @@
Greatly increases interruptability of buffer operations in
presence of many polygons.
-2012-05-25 10:54 Sandro Santilli <strk at keybit.net>
+2012-05-25 10:54 Sandro Santilli <strk at kbt.io>
* [r3643] src/operation/buffer/BufferBuilder.cpp,
src/operation/overlay/OverlayOp.cpp: Check for interruption in
@@ -1455,7 +3451,7 @@
The checks could as well be put within graph operation loops or
Coordinate constructors...
* [r3642] capi/geos_c.cpp, capi/geos_c.h.in,
include/geos/util/Interrupt.h, include/geos/util/Makefile.am,
@@ -1470,7 +3466,7 @@
effective
way to request interruption of running GEOS operations.
-2012-05-24 06:00 Sandro Santilli <strk at keybit.net>
+2012-05-24 06:00 Sandro Santilli <strk at kbt.io>
* [r3641] include/geos/geom/Geometry.h, src/geom/Geometry.cpp:
Don't call GeometryFactory::getDefaultInstance() at startup
@@ -1520,7 +3516,7 @@
* [r3635] capi/geos_ts_c.cpp: Missing namespace prevented Visual
C++ compiler to find GEOSAllocator and GEOSFreer
-2012-05-16 16:47 Sandro Santilli <strk at keybit.net>
+2012-05-16 16:47 Sandro Santilli <strk at kbt.io>
* [r3633] src/util/CustomAllocators.cpp,
tests/unit/capi/GEOSCustomAllocatorTest.cpp: Fix CustomAllocators
@@ -1528,7 +3524,7 @@
Improve the unit test for it
-2012-05-16 12:20 Sandro Santilli <strk at keybit.net>
+2012-05-16 12:20 Sandro Santilli <strk at kbt.io>
* [r3632] src/geom/GeometryFactory.cpp: Lazily create default
GeometryFactory instance (#540)
@@ -1536,7 +3532,7 @@
Seems to fix a problem with mismatch of allocator and deallocator
for the static object
* [r3631] NEWS, capi/geos_c.cpp, capi/geos_c.h.in,
capi/geos_ts_c.cpp, include/geos/util/CustomAllocators.h,
@@ -1552,12 +3548,12 @@
* [r3630] tests/unit/capi/GEOSConvexHullTest.cpp: New test for
C-API convex hull func.
-2012-05-14 19:03 Sandro Santilli <strk at keybit.net>
+2012-05-14 19:03 Sandro Santilli <strk at kbt.io>
* [r3629] src/operation/polygonize/EdgeRing.cpp: Reduce calls to
ptNotInList, greatly speeding up Polygonizer (#545)
-2012-05-09 18:02 Sandro Santilli <strk at keybit.net>
+2012-05-09 18:02 Sandro Santilli <strk at kbt.io>
* [r3627] include/geos/simplify/TaggedLineStringSimplifier.h,
include/geos/simplify/TopologyPreservingSimplifier.h,
@@ -1566,17 +3562,17 @@
tests/unit/simplify/TopologyPreservingSimplifierTest.cpp: Fix
TopologyPreservingSimplifier invalid output on closed line (#508)
-2012-05-09 16:28 Sandro Santilli <strk at keybit.net>
+2012-05-09 16:28 Sandro Santilli <strk at kbt.io>
* [r3625] php/geos.c: Add support for PHP 5.4 (#513) -- thanks
voxik
-2012-05-08 18:41 Sandro Santilli <strk at keybit.net>
+2012-05-08 18:41 Sandro Santilli <strk at kbt.io>
* [r3623] src/geom/Geometry.cpp: Envelope-based short-circuit for
Geometry->symDifference (#543)
-2012-05-08 17:39 Sandro Santilli <strk at keybit.net>
+2012-05-08 17:39 Sandro Santilli <strk at kbt.io>
* [r3621] capi/geos_ts_c.cpp, tests/xmltester/XMLTester.cpp:
Geometry methods do use BinaryOp internally + shortcuts (#542)
@@ -1584,43 +3580,43 @@
This commit changes both XMLTester and C-API to not use BinaryOp
directly but rather rely on geometry methods to do that.
-2012-05-04 14:51 Sandro Santilli <strk at keybit.net>
+2012-05-04 14:51 Sandro Santilli <strk at kbt.io>
* [r3619] include/geos/noding/GeometryNoder.h,
src/noding/GeometryNoder.cpp: Correct include directives for
GeometryNoder (#538)
-2012-05-04 08:24 Sandro Santilli <strk at keybit.net>
+2012-05-04 08:24 Sandro Santilli <strk at kbt.io>
* [r3618] acsite.m4: Update PGAC_TYPE_64BIT_INT for better
cross-compiler support (#534)
-2012-05-03 10:08 Sandro Santilli <strk at keybit.net>
+2012-05-03 10:08 Sandro Santilli <strk at kbt.io>
* [r3616] tests/perf/ClassSizes.cpp: Check size of "intt64"
-2012-04-27 07:01 Sandro Santilli <strk at keybit.net>
+2012-04-27 07:01 Sandro Santilli <strk at kbt.io>
* [r3615] NEWS, php/geos.c, php/test/test.php: Expose GEOSNode to
PHP api
-2012-04-12 09:07 Sandro Santilli <strk at keybit.net>
+2012-04-12 09:07 Sandro Santilli <strk at kbt.io>
* [r3614] src/geomgraph/Node.cpp,
tests/unit/capi/GEOSUnaryUnionTest.cpp: Throw an exception rather
than aborting on NaN overlay input (#530)
-2012-04-10 17:01 Sandro Santilli <strk at keybit.net>
+2012-04-10 17:01 Sandro Santilli <strk at kbt.io>
* [r3612] src/noding/snapround/HotPixel.cpp: Abort if HotPixel is
constructed with zero scale (#529)
-2012-04-10 15:58 Sandro Santilli <strk at keybit.net>
+2012-04-10 15:58 Sandro Santilli <strk at kbt.io>
* [r3611] tests/xmltester/Makefile.am,
tests/xmltester/tests/ticket/bug527.xml: Add test for bug #527
-2012-04-10 15:16 Sandro Santilli <strk at keybit.net>
+2012-04-10 15:16 Sandro Santilli <strk at kbt.io>
* [r3609] include/geos/operation/union/UnaryUnionOp.h: Have
UnaryUnion use BinaryOp for the simple case
@@ -1628,12 +3624,12 @@
See ticket #527 -- there's no infinite loop triggered by our
testsuite...
-2012-04-10 15:04 Sandro Santilli <strk at keybit.net>
+2012-04-10 15:04 Sandro Santilli <strk at kbt.io>
* [r3607] include/geos/geom/BinaryOp.h: Reduce CommonBitsRemover
harmful effects during overlay op (#527)
-2012-04-10 08:38 Sandro Santilli <strk at keybit.net>
+2012-04-10 08:38 Sandro Santilli <strk at kbt.io>
* [r3605] NEWS, include/geos/precision/GeometryPrecisionReducer.h,
include/geos/precision/Makefile.am,
@@ -1646,14 +3642,14 @@
tests/unit/precision/GeometryPrecisionReducerTest.cpp: Port
GeometryPrecisionReducer, include testcase
-2012-04-06 19:04 Sandro Santilli <strk at keybit.net>
+2012-04-06 19:04 Sandro Santilli <strk at kbt.io>
* [r3604] src/geom/GeometryFactory.cpp: Deep copy Geometry with
GeometryFactory.createGeometry()
Uses the CoordinateSequenceFactory of the factory
-2012-04-06 19:03 Sandro Santilli <strk at keybit.net>
+2012-04-06 19:03 Sandro Santilli <strk at kbt.io>
* [r3603] include/geos/geom/CoordinateArraySequence.h,
@@ -1664,7 +3660,7 @@
src/geom/CoordinateSequenceFactory.cpp: Add CoordinateSequence
deep copy trhough CoordinateSequenceFactory
-2012-04-05 17:07 Sandro Santilli <strk at keybit.net>
+2012-04-05 17:07 Sandro Santilli <strk at kbt.io>
* [r3602] tests/unit/capi/GEOSNodeTest.cpp: Normalize noded
geometry before comparing with expected value
@@ -1672,40 +3668,40 @@
In this way we can change the noding implementation w/out
breaking the tests.
-2012-04-05 16:56 Sandro Santilli <strk at keybit.net>
+2012-04-05 16:56 Sandro Santilli <strk at kbt.io>
* [r3601] swig/python/geos_wrap.cxx: Regnerate geos wrapper with
correct version for this branch
-2012-04-05 16:47 Sandro Santilli <strk at keybit.net>
+2012-04-05 16:47 Sandro Santilli <strk at kbt.io>
* [r3599] swig/python/geos.py, swig/python/geos_wrap.cxx:
Regenerate swig wrappers with SWIG 1.3.40
-2012-04-05 14:53 Sandro Santilli <strk at keybit.net>
+2012-04-05 14:53 Sandro Santilli <strk at kbt.io>
* [r3598] src/noding/snapround/SimpleSnapRounder.cpp: Fix
SimpleSnapRounder::getNodedSubstrings, fix leak on exception
-2012-04-05 14:37 Sandro Santilli <strk at keybit.net>
+2012-04-05 14:37 Sandro Santilli <strk at kbt.io>
* [r3597] src/noding/GeometryNoder.cpp: Clean memory on exception
-2012-04-05 14:23 Sandro Santilli <strk at keybit.net>
+2012-04-05 14:23 Sandro Santilli <strk at kbt.io>
* [r3596] include/geos/noding/NodedSegmentString.h: Generalize
NodedSegmentString::getNodedSubstrings
-2012-04-05 14:14 Sandro Santilli <strk at keybit.net>
+2012-04-05 14:14 Sandro Santilli <strk at kbt.io>
* [r3595] tests/unit/capi/GEOSNodeTest.cpp: Ensure GEOSNode doesn't
throw an exception with current tests
-2012-04-05 13:43 Sandro Santilli <strk at keybit.net>
+2012-04-05 13:43 Sandro Santilli <strk at kbt.io>
* [r3594] NEWS: Add note about GEOSNode
-2012-04-05 13:40 Sandro Santilli <strk at keybit.net>
+2012-04-05 13:40 Sandro Santilli <strk at kbt.io>
* [r3593] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp,
@@ -1716,35 +3712,35 @@
Includes a new GeometryNoder C++ class and regression testing.
-2012-04-05 12:05 Sandro Santilli <strk at keybit.net>
+2012-04-05 12:05 Sandro Santilli <strk at kbt.io>
* [r3592] src/noding/IteratedNoder.cpp: Fix memory leak with
IteratedNoder
-2012-04-05 11:07 Sandro Santilli <strk at keybit.net>
+2012-04-05 11:07 Sandro Santilli <strk at kbt.io>
* [r3591] include/geos/noding/IteratedNoder.h,
src/noding/IteratedNoder.cpp: Update port info and cleanup
IteratedNoder
-2012-04-05 10:30 Sandro Santilli <strk at keybit.net>
+2012-04-05 10:30 Sandro Santilli <strk at kbt.io>
* [r3590] include/geos/geomgraph/EdgeList.h,
include/geos/noding/OrientedCoordinateArray.h: Make
OrientedCoordinateArray comparable
* [r3589] include/geos/noding/OrientedCoordinateArray.h,
src/noding/OrientedCoordinateArray.cpp: Make
OrientedCoordinateArray assignable
-2012-04-03 14:23 Sandro Santilli <strk at keybit.net>
+2012-04-03 14:23 Sandro Santilli <strk at kbt.io>
* [r3588] include/geos/noding/OrientedCoordinateArray.h: Make
OrientedCoordinateArray copyable
-2012-04-03 12:59 Sandro Santilli <strk at keybit.net>
+2012-04-03 12:59 Sandro Santilli <strk at kbt.io>
* [r3587] include/geos/noding/snapround/MCIndexSnapRounder.h:
Const-correct PrecisionModel use in MCIndexSnapRounder
@@ -1758,12 +3754,12 @@
* [r3583] capi/geos_c.h.in: Sync up versions advertised in capi to
those in configure.in
-2012-03-27 08:37 Sandro Santilli <strk at keybit.net>
+2012-03-27 08:37 Sandro Santilli <strk at kbt.io>
* [r3576] src/operation/overlay/snap/LineStringSnapper.cpp:
Indent..
-2012-03-22 08:39 Sandro Santilli <strk at keybit.net>
+2012-03-22 08:39 Sandro Santilli <strk at kbt.io>
* [r3575] src/simplify/TaggedLineString.cpp,
src/simplify/TaggedLineStringSimplifier.cpp,
@@ -2373,17 +4369,17 @@
* [r3562] tests/unit/capi/GEOSisValidDetailTest.cpp: Missing
<cctype> header for toupper. Fixed Visual C++ warning.
-2012-01-06 21:53 Sandro Santilli <strk at keybit.net>
+2012-01-06 21:53 Sandro Santilli <strk at kbt.io>
* [r3561] src/operation/buffer/BufferOp.cpp: Forward port: Fix MSVC
compilation of ambiguous log() call #506
-2011-12-16 14:15 Sandro Santilli <strk at keybit.net>
+2011-12-16 14:15 Sandro Santilli <strk at kbt.io>
* [r3555] src/operation/overlay/snap/LineStringSnapper.cpp: Make
debugging output of LineStringSnapper more readable
-2011-12-15 14:36 Sandro Santilli <strk at keybit.net>
+2011-12-15 14:36 Sandro Santilli <strk at kbt.io>
* [r3553] include/geos/geom/BinaryOp.h,
@@ -2392,11 +4388,11 @@
Adds regression test. This is a GEOS-only approach.
-2011-12-15 11:34 Sandro Santilli <strk at keybit.net>
+2011-12-15 11:34 Sandro Santilli <strk at kbt.io>
* [r3550] include/geos/operation/overlay/OverlayOp.h: indent
-2011-12-15 08:59 Sandro Santilli <strk at keybit.net>
+2011-12-15 08:59 Sandro Santilli <strk at kbt.io>
* [r3548] include/geos/geom/BinaryOp.h: Fix build with
CBR_BEFORE_SNAPPING undefined
@@ -2407,17 +4403,17 @@
for #500 to fix clang's complaint about a missing default
initialization
-2011-12-12 10:10 Sandro Santilli <strk at keybit.net>
+2011-12-12 10:10 Sandro Santilli <strk at kbt.io>
* [r3544] src/algorithm/CGAlgorithms.cpp: Apply Shoelace formula
for area calculation (#485)
-2011-12-12 09:59 Sandro Santilli <strk at keybit.net>
+2011-12-12 09:59 Sandro Santilli <strk at kbt.io>
* [r3542] macros/geos.m4, tools/geos-config.in: Add --clibs to
geos-config and GEOS_C_LIBS to geos.m4 (#497)
-2011-12-09 10:54 Sandro Santilli <strk at keybit.net>
+2011-12-09 10:54 Sandro Santilli <strk at kbt.io>
* [r3540] include/geos/geom/Geometry.h,
include/geos/operation/overlay/snap/GeometrySnapper.h,
@@ -2426,11 +4422,11 @@
src/operation/overlay/snap/SnapOverlayOp.cpp: Fix C++11 build by
avoiding std::pair<auto_ptr> (#491)
-2011-12-09 10:04 Sandro Santilli <strk at keybit.net>
+2011-12-09 10:04 Sandro Santilli <strk at kbt.io>
* [r3536] .gitignore: Ignore built performance tests
* [r3535] src/operation/buffer/BufferOp.cpp,
tests/unit/operation/buffer/BufferOpTest.cpp,
@@ -2443,7 +4439,7 @@
http://trac.osgeo.org/geos/wiki/BufferRobustness
They include #495 and #494
-2011-12-09 08:48 Sandro Santilli <strk at keybit.net>
+2011-12-09 08:48 Sandro Santilli <strk at kbt.io>
* [r3534] include/geos/operation/union/CascadedPolygonUnion.h,
src/operation/union/CascadedPolygonUnion.cpp,
@@ -2456,7 +4452,7 @@
This is to avoid failures and provide more desirable behaviour.
Includes automated testing. Closes ticket #499.
-2011-12-07 15:13 Sandro Santilli <strk at keybit.net>
+2011-12-07 15:13 Sandro Santilli <strk at kbt.io>
* [r3530] include/geos/noding/snapround/MCIndexPointSnapper.h,
include/geos/noding/snapround/MCIndexSnapRounder.h,
@@ -2464,7 +4460,7 @@
src/noding/snapround/MCIndexSnapRounder.cpp: Update port info for
MCIndexPointSnapper and MCIndexSnapRounder
-2011-12-07 11:17 Sandro Santilli <strk at keybit.net>
+2011-12-07 11:17 Sandro Santilli <strk at kbt.io>
* [r3529] tests/unit/Makefile.am,
tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp: Add a
@@ -2472,7 +4468,7 @@
The test would fail before the fix in r3528
-2011-12-06 17:26 Sandro Santilli <strk at keybit.net>
+2011-12-06 17:26 Sandro Santilli <strk at kbt.io>
* [r3528] include/geos/noding/snapround/HotPixel.h,
src/noding/snapround/HotPixel.cpp, tests/unit/Makefile.am,
@@ -2480,12 +4476,12 @@
tests/unit/noding/snapround/HotPixelTest.cpp: HotPixel: do not
invalidate reference to original point. Fixes #498.
-2011-12-02 09:42 Sandro Santilli <strk at keybit.net>
+2011-12-02 09:42 Sandro Santilli <strk at kbt.io>
* [r3525] tests/xmltester/tests/safe/buffer-1.01.xml: Add
<resultMatcher> tag to make the test runnable with JTS
-2011-11-30 09:45 Sandro Santilli <strk at keybit.net>
+2011-11-30 09:45 Sandro Santilli <strk at kbt.io>
* [r3523] include/geos/noding/snapround/MCIndexSnapRounder.h,
src/noding/snapround/MCIndexSnapRounder.cpp,
@@ -2495,12 +4491,12 @@
Fixes bug #473 (RightmostEdgeFinder assertion failure).
Includes regression test.
-2011-11-29 14:01 Sandro Santilli <strk at keybit.net>
+2011-11-29 14:01 Sandro Santilli <strk at kbt.io>
* [r3522] src/geom/Coordinate.cpp: Use 18 significant digits for
TopologyException point coordinates
-2011-11-28 08:53 Sandro Santilli <strk at keybit.net>
+2011-11-28 08:53 Sandro Santilli <strk at kbt.io>
* [r3520] src/operation/buffer/BufferBuilder.cpp,
@@ -2509,7 +4505,7 @@
Includes regression test, provided by SAFE.
-2011-11-24 22:07 Sandro Santilli <strk at keybit.net>
+2011-11-24 22:07 Sandro Santilli <strk at kbt.io>
* [r3518] macros/ruby.m4, swig/ruby/Makefile.am,
swig/ruby/geos_wrap.cxx, swig/ruby/ruby.i: Fix to get swig/ruby
@@ -2523,12 +4519,12 @@
Studio 11(Developer Preview).
* Added related _NMAKE_VER case to nmake.opt.
-2011-11-04 20:41 Sandro Santilli <strk at keybit.net>
+2011-11-04 20:41 Sandro Santilli <strk at kbt.io>
* [r3515] tests/unit/capi/GEOSisValidDetailTest.cpp: Allow any case
in NaN for testcase purposes (#486)
-2011-11-04 17:59 Sandro Santilli <strk at keybit.net>
+2011-11-04 17:59 Sandro Santilli <strk at kbt.io>
* [r3514] src/operation/union/UnaryUnionOp.cpp,
tests/unit/operation/union/UnaryUnionOpTest.cpp,
@@ -2542,7 +4538,7 @@
* [r3511] tests/perf, tests/perf/capi,
tests/perf/operation/predicate: Updated svn:ignore property
-2011-10-27 07:04 Sandro Santilli <strk at keybit.net>
+2011-10-27 07:04 Sandro Santilli <strk at kbt.io>
* [r3510] TODO: Add JTS triangulation api item
@@ -2554,18 +4550,18 @@
reported by Markus Meyer.
* TODO: if possible, replace sample WKT with WKT from Markus.
-2011-10-26 16:14 Sandro Santilli <strk at keybit.net>
+2011-10-26 16:14 Sandro Santilli <strk at kbt.io>
* [r3508] tests/unit/Makefile.am,
tests/unit/operation/buffer/BufferParametersTest.cpp: Add test
for BufferParameters class
-2011-10-26 14:16 Sandro Santilli <strk at keybit.net>
+2011-10-26 14:16 Sandro Santilli <strk at kbt.io>
* [r3505] authors.svn: Add missing entries in the author file.
Order alphabetically.
* [r3504] NEWS: Add missing CAPI additions of 3.3.0 to NEWS file
@@ -2646,7 +4642,7 @@
* Visual C++ build on Windows x86-32 is all green and happy
throwing ok:737
-2011-09-23 12:14 Sandro Santilli <strk at keybit.net>
+2011-09-23 12:14 Sandro Santilli <strk at kbt.io>
* [r3484] NEWS, include/geos/linearref/LengthIndexedLine.h,
include/geos/linearref/LengthLocationMap.h,
@@ -2665,7 +4661,7 @@
Includes test. This is a port of JTS changesets 463, 464 and 465
* [r3483] tests/unit/linearref/LengthIndexedLineTest.cpp: Port
updates to the LenghtIndexedLineTest testcase (see #323)
@@ -4067,7 +6063,7 @@
tools/Makefile.am, tools/geos-config.in: Removed Subversion
svn:keywords property (#480)
-2011-09-21 08:11 Sandro Santilli <strk at keybit.net>
+2011-09-21 08:11 Sandro Santilli <strk at kbt.io>
* [r3475] swig/geos.i.in, swig/python/Makefile.am: Fix out-of-place
build for python binding (#332)
@@ -4089,19 +6085,19 @@
* [r3469] tests/unit/capi/GEOSisValidDetailTest.cpp: Disable unit
test relying on C99 feature if GEOS built using Visual C++
-2011-09-17 15:53 Sandro Santilli <strk at keybit.net>
+2011-09-17 15:53 Sandro Santilli <strk at kbt.io>
* [r3468] include/geos/platform.h.in: Use the global isnan from
math.h for Solaris (#461)
-2011-09-12 07:47 Sandro Santilli <strk at keybit.net>
+2011-09-12 07:47 Sandro Santilli <strk at kbt.io>
* [r3465] src/algorithm/InteriorPointArea.cpp,
tests/unit/algorithm/InteriorPointAreaTest.cpp: Fix memory leak
on invalid geometry in InteriorPointArea (#475)
-2011-08-24 14:55 Sandro Santilli <strk at keybit.net>
+2011-08-24 14:55 Sandro Santilli <strk at kbt.io>
* [r3463] include/geos/operation/buffer/OffsetSegmentGenerator.h,
include/geos/operation/relate/RelateComputer.h,
@@ -4109,40 +6105,40 @@
src/operation/relate/RelateComputer.cpp: Fix warnings on MSVC
2008 64 Bit (#470)
-2011-08-20 21:02 Sandro Santilli <strk at keybit.net>
+2011-08-20 21:02 Sandro Santilli <strk at kbt.io>
* [r3461] src/geom/GeometryCollection.cpp, src/geom/LineString.cpp,
src/geom/Point.cpp, src/geom/Polygon.cpp, tests/unit/Makefile.am,
tests/unit/geom/Geometry/clone.cpp: Forward port fix for #464
(Geometry.clone SRID copy)
-2011-08-19 09:42 Sandro Santilli <strk at keybit.net>
+2011-08-19 09:42 Sandro Santilli <strk at kbt.io>
* [r3458] src/planargraph/DirectedEdge.cpp: Fix missing return from
DirectedEdge output operator
-2011-08-19 09:41 Sandro Santilli <strk at keybit.net>
+2011-08-19 09:41 Sandro Santilli <strk at kbt.io>
* [r3457] tests/perf/Makefile.am, tests/perf/capi/Makefile.am: Fix
out-of-source builds
-2011-08-06 09:10 Sandro Santilli <strk at keybit.net>
+2011-08-06 09:10 Sandro Santilli <strk at kbt.io>
* [r3456] include/geos/noding/BasicSegmentString.h,
src/inlines.cpp: Drop dangling references to SegmentString.inl
(ticket #467)
-2011-07-27 13:55 Sandro Santilli <strk at keybit.net>
+2011-07-27 13:55 Sandro Santilli <strk at kbt.io>
* [r3455] tests/perf/ClassSizes.cpp, tests/perf/Makefile.am: Add
test file printing sizes of some classes
-2011-07-27 13:29 Sandro Santilli <strk at keybit.net>
+2011-07-27 13:29 Sandro Santilli <strk at kbt.io>
* [r3454] src/operation/buffer/BufferBuilder.cpp: Earlier release
of input segment strings, earlier release of buffer subgraphs.
-2011-07-27 08:12 Sandro Santilli <strk at keybit.net>
+2011-07-27 08:12 Sandro Santilli <strk at kbt.io>
* [r3453] include/geos/noding/Noder.h,
include/geos/noding/SegmentNodeList.h,
@@ -4151,7 +6147,7 @@
transfer ownership of noded segment strings to caller. Delete
them as soon as converted to Edges in BufferOp.
-2011-07-26 16:36 Sandro Santilli <strk at keybit.net>
+2011-07-26 16:36 Sandro Santilli <strk at kbt.io>
* [r3452] include/geos/noding/Makefile.am,
include/geos/noding/SegmentString.h,
@@ -4159,7 +6155,7 @@
src/noding/SegmentString.cpp: Update class documentation and port
info. Drop empty .inl file.
-2011-07-26 16:23 Sandro Santilli <strk at keybit.net>
+2011-07-26 16:23 Sandro Santilli <strk at kbt.io>
* [r3451] NEWS, include/geos/noding/NodedSegmentString.h,
@@ -4177,7 +6173,7 @@
tests/unit/noding/SegmentNodeTest.cpp: Have NodedSegmentString
take ownership of CoordinateSequence
-2011-07-26 15:09 Sandro Santilli <strk at keybit.net>
+2011-07-26 15:09 Sandro Santilli <strk at kbt.io>
* [r3450] NEWS, include/geos/geomgraph/DirectedEdge.h,
include/geos/geomgraph/DirectedEdge.inl,
@@ -4220,53 +6216,53 @@
geomgraph::Label by value (less extra-heap), cleanups and port
sync.
-2011-07-21 09:54 Sandro Santilli <strk at keybit.net>
+2011-07-21 09:54 Sandro Santilli <strk at kbt.io>
* [r3449] include/geos/geomgraph/Label.h, src/geomgraph/Label.cpp:
Make geomgraph::Label non virtual, implement assignment operator,
drop old logs, sync port info.
* [r3448] include/geos/geomgraph/TopologyLocation.h,
src/geomgraph/TopologyLocation.cpp: Add assignment operator to
TopologyLocation, drop old logs, sync port info
-2011-07-20 15:40 Sandro Santilli <strk at keybit.net>
+2011-07-20 15:40 Sandro Santilli <strk at kbt.io>
* [r3444] include/geos/algorithm/ConvexHull.h,
include/geos/algorithm/ConvexHull.inl,
src/algorithm/ConvexHull.cpp: Port JTS robustness fix for
ConvexHull (ticket #457)
-2011-07-20 14:32 Sandro Santilli <strk at keybit.net>
+2011-07-20 14:32 Sandro Santilli <strk at kbt.io>
* [r3443] tests/xmltester/XMLTester.cpp: Allow XML tests not to
specify a precision model, defaulting to floating
This allows running some JTS tests w/out touching them
-2011-07-20 14:19 Sandro Santilli <strk at keybit.net>
+2011-07-20 14:19 Sandro Santilli <strk at kbt.io>
* [r3442] tests/unit/Makefile.am,
tests/unit/capi/GEOSDistanceTest.cpp: Add unit test for bug #337.
-2011-07-20 14:04 Sandro Santilli <strk at keybit.net>
+2011-07-20 14:04 Sandro Santilli <strk at kbt.io>
* [r3441] tests/xmltester/Makefile.am: Reset CXXFLAGS for building
XMLTester, should fix bug #319 (non-c++98 tinyxml)
-2011-07-20 11:45 Sandro Santilli <strk at keybit.net>
+2011-07-20 11:45 Sandro Santilli <strk at kbt.io>
* [r3439] src/operation/buffer/BufferBuilder.cpp,
tests/unit/capi/GEOSOffsetCurveTest.cpp: Have GEOSOffsetCurve
with distance 0 return the input (fixes bug #454)
-2011-07-20 09:12 Sandro Santilli <strk at keybit.net>
+2011-07-20 09:12 Sandro Santilli <strk at kbt.io>
* [r3438] NEWS: Add note about new BufferOp interface
-2011-07-20 09:03 Sandro Santilli <strk at keybit.net>
+2011-07-20 09:03 Sandro Santilli <strk at kbt.io>
* [r3437] include/geos/operation/buffer/BufferOp.h: Add
setSingleSided interface to BufferOp-accessible BufferParam
@@ -4274,68 +6270,68 @@
Patch by Tai Meng <tai.meng at safe.com>
-2011-07-20 08:46 Sandro Santilli <strk at keybit.net>
+2011-07-20 08:46 Sandro Santilli <strk at kbt.io>
* [r3436] include/geos/planargraph/DirectedEdge.h,
src/planargraph/DirectedEdge.cpp: Add output operator for
planargraph::DirectedEdge class
* [r3435] src/algorithm/RobustDeterminant.cpp: Drop unused variable
* [r3434] tests/unit/operation/polygonize/PolygonizeTest.cpp: Add
port info
* [r3433] tests/unit/Makefile.am, tests/unit/operation/polygonize,
tests/unit/operation/polygonize/PolygonizeTest.cpp: Port JTS unit
test for Polygonizer class (very light..)
-2011-07-07 08:33 Sandro Santilli <strk at keybit.net>
+2011-07-07 08:33 Sandro Santilli <strk at kbt.io>
* [r3432] src/operation/buffer/BufferParameters.cpp: Include
platform.h, fixing SOLARIS build. Patch by Tai Meng
<tai.meng at safe.com>.
-2011-07-06 07:02 Sandro Santilli <strk at keybit.net>
+2011-07-06 07:02 Sandro Santilli <strk at kbt.io>
* [r3429] include/geos/geomgraph/GeometryGraph.h,
include/geos/geomgraph/GeometryGraph.inl,
src/geomgraph/GeometryGraph.cpp: Nodes always have labels (ported
JTS fix to GeometryGraph::insertBoundaryPoint). Update port info.
* [r3428] include/geos/geomgraph/Node.h, src/geomgraph/Node.cpp:
Update port info for geomgraph::Node after GEOS fix was ported to
JTS
-2011-07-05 13:59 Sandro Santilli <strk at keybit.net>
+2011-07-05 13:59 Sandro Santilli <strk at kbt.io>
* [r3427] Makefile.am: svn update before running svn2cl
-2011-07-05 11:07 Sandro Santilli <strk at keybit.net>
+2011-07-05 11:07 Sandro Santilli <strk at kbt.io>
* [r3425] src/operation/valid/IndexedNestedRingTester.cpp,
src/operation/valid/IndexedNestedRingTester.h: Update port info
for IndexedNestedRingTester class
-2011-07-05 10:58 Sandro Santilli <strk at keybit.net>
+2011-07-05 10:58 Sandro Santilli <strk at kbt.io>
* [r3424] NEWS: Changes of 3.3.1 do not belong in trunk (aimed at
3.4.0)
-2011-07-05 10:56 Sandro Santilli <strk at keybit.net>
+2011-07-05 10:56 Sandro Santilli <strk at kbt.io>
* [r3423] src/operation/valid/IndexedNestedRingTester.cpp,
tests/xmltester/tests/general/TestValid.xml: Fix #449 (Assertion
fails checking validity of polygon) the JTS way.
* [r3422] src/operation/valid/IndexedNestedRingTester.cpp,
@@ -4346,74 +6342,74 @@
This reverts commit 7d2306c8dca2f0f1c5722640758578c1d59c7295.
-2011-07-05 09:52 Sandro Santilli <strk at keybit.net>
+2011-07-05 09:52 Sandro Santilli <strk at kbt.io>
* [r3417] src/algorithm/MinimumDiameter.cpp: Initialize
MinimumDiamiter::minPtIndex in the constructor, to make static
analisys tools happier
* [r3416] src/index/sweepline/SweepLineIndex.cpp: Initialize
SweepLineIndex::indexBuilt in ctor
* [r3415] include/geos/algorithm/LineIntersector.h: Initialize
LineIntersector::isProperVar in constructor (not really needed
but makes less noise under static analisys tools)
* [r3414] include/geos/geom/prep/PreparedPoint.h,
src/geom/prep/PreparedPoint.cpp: Fix bogus override of
PreparedGeometry::intersect by PreparedPoint
* [r3413] src/index/quadtree/Node.cpp: Assert that the variable
used as array index is not negative before using it (quadtree)
* [r3412] src/geomgraph/GeometryGraph.cpp: Avoid segfalting when an
added node has no label in GeometryGraph::insertBoundaryPoint.
See
https://sourceforge.net/tracker/?func=detail&aid=3353879&group_id=128875&atid=713120
* [r3411] src/geomgraph/Node.cpp: Avoid segfaulting when
Node.setLabelBoundary is called against a node with null label.
See
https://sourceforge.net/tracker/?func=detail&aid=3353871&group_id=128875&atid=713120
* [r3410] src/index/bintree/Node.cpp: Assert that the variable used
as array index is not negative before using it.
-2011-07-05 09:51 Sandro Santilli <strk at keybit.net>
+2011-07-05 09:51 Sandro Santilli <strk at kbt.io>
* [r3409] src/util/Profiler.cpp: Do not dereference past-the-end
iterator on invalid call
-2011-07-01 08:22 Sandro Santilli <strk at keybit.net>
+2011-07-01 08:22 Sandro Santilli <strk at kbt.io>
* [r3398] tests/unit/capi/GEOSBufferTest.cpp: Add test for ticket
#455 (bad result from the deprecated GEOSSingleSidedBuffer). It
passes here in trunk, good!
* [r3397] NEWS: NEWS item about #449
-2011-06-27 11:45 Sandro Santilli <strk at keybit.net>
+2011-06-27 11:45 Sandro Santilli <strk at kbt.io>
* [r3394] configure.in: Bump versions up assuming a new minor
release will come out from trunk. Closes #453
-2011-06-09 15:28 Sandro Santilli <strk at keybit.net>
+2011-06-09 15:28 Sandro Santilli <strk at kbt.io>
* [r3392] src/operation/valid/IndexedNestedRingTester.cpp,
@@ -4421,19 +6417,19 @@
validity, do not abort if every vertex of an hole is also a
vertex of another one. Fixes bug #449, including regress testing.
-2011-06-02 20:18 Sandro Santilli <strk at keybit.net>
+2011-06-02 20:18 Sandro Santilli <strk at kbt.io>
* [r3390] php/test/test.php: Refine test for #448
-2011-06-02 20:13 Sandro Santilli <strk at keybit.net>
+2011-06-02 20:13 Sandro Santilli <strk at kbt.io>
* [r3389] php/test/test.php: Add test for bug #448
-2011-05-30 12:50 Sandro Santilli <strk at keybit.net>
+2011-05-30 12:50 Sandro Santilli <strk at kbt.io>
* [r3387] ChangeLog: Update for release
-2011-05-30 12:48 Sandro Santilli <strk at keybit.net>
+2011-05-30 12:48 Sandro Santilli <strk at kbt.io>
* [r3386] NEWS, configure.in: Set version to 3.3.0 (final) - Set
release date to 2011-05-30
@@ -4460,16 +6456,16 @@
tests/xmltester/CMakeLists.txt: Applied supplementary tests.patch
for 85 from William
-2011-05-27 14:04 Sandro Santilli <strk at keybit.net>
+2011-05-27 14:04 Sandro Santilli <strk at kbt.io>
* [r3381] src/Makefile.am: The mac framework info.plist.in from
r3376 didn't make it into the rc2 tarball.
-2011-05-23 10:04 Sandro Santilli <strk at keybit.net>
+2011-05-23 10:04 Sandro Santilli <strk at kbt.io>
* [r3378] ChangeLog: updated for 3.3.0rc2 release
-2011-05-23 09:58 Sandro Santilli <strk at keybit.net>
+2011-05-23 09:58 Sandro Santilli <strk at kbt.io>
* [r3377] configure.in: Set version to 3.3.0rc2
@@ -4485,7 +6481,7 @@
Added OS X framework build option to CMake configuration (Ticket
#385)
-2011-05-20 08:02 Sandro Santilli <strk at keybit.net>
+2011-05-20 08:02 Sandro Santilli <strk at kbt.io>
* [r3374] tests/perf/capi/memleak_mp_prep.c: add missing return
from main
@@ -4503,19 +6499,19 @@
src/operation/overlay/PolygonBuilder.cpp: Updates for Makefile.vc
builds and issues when building NDEBUG and no inlining
-2011-05-19 14:58 Sandro Santilli <strk at keybit.net>
+2011-05-19 14:58 Sandro Santilli <strk at kbt.io>
* [r3371] tests/perf/capi/Makefile.am: Fix build of prepared geoms
memleak tester on system w/out geos installed
-2011-05-18 19:59 Sandro Santilli <strk at keybit.net>
+2011-05-18 19:59 Sandro Santilli <strk at kbt.io>
* [r3370] include/geos/platform.h.in,
src/algorithm/RobustDeterminant.cpp: Do not assume isfinite is in
std:: namespace to fix #444; Have RobustDeterminant use a broad
'using namespace std' to fix #442 in another way.
-2011-05-17 20:44 Sandro Santilli <strk at keybit.net>
+2011-05-17 20:44 Sandro Santilli <strk at kbt.io>
* [r3369] Makefile.am, capi/Makefile.am, include/Makefile.am,
include/geos/Makefile.am, src/Makefile.am, tests/Makefile.am,
@@ -4523,7 +6519,7 @@
tests/xmltester/Makefile.am, tools/Makefile.am: Distribute cmake
build scripts. Fixes bug #441.
-2011-05-17 17:04 Sandro Santilli <strk at keybit.net>
+2011-05-17 17:04 Sandro Santilli <strk at kbt.io>
* [r3368] include/geos/noding/snapround/MCIndexSnapRounder.h,
include/geos/noding/snapround/MCIndexSnapRounder.inl,
@@ -4531,7 +6527,7 @@
Remove inlines machinery from MCIndexSnapRounder. Possibly fixes
ticket #222.
-2011-05-17 16:50 Sandro Santilli <strk at keybit.net>
+2011-05-17 16:50 Sandro Santilli <strk at kbt.io>
* [r3367] include/geos/geom/Coordinate.h,
include/geos/geom/Coordinate.inl, src/geom/Coordinate.cpp: Remove
@@ -4542,7 +6538,7 @@
* [r3366] include/geos/geom/util/SineStarFactory.h: Fixed buggy
self-assignment in SineStarFactory::setNumArms
-2011-05-16 11:46 Sandro Santilli <strk at keybit.net>
+2011-05-16 11:46 Sandro Santilli <strk at kbt.io>
* [r3365] include/geos/platform.h.in: Quality ::finite and
::isfinite symbols, when available, into the std:: namespace.
@@ -4570,106 +6566,106 @@
std::isfinite as possibly non-existing on some platforms - rather
fix platform.h if needed.
-2011-05-12 10:11 Sandro Santilli <strk at keybit.net>
+2011-05-12 10:11 Sandro Santilli <strk at kbt.io>
* [r3361] NEWS: Add note about #357 fix
-2011-05-12 09:56 Sandro Santilli <strk at keybit.net>
+2011-05-12 09:56 Sandro Santilli <strk at kbt.io>
* [r3360] src/algorithm/RobustDeterminant.cpp,
tests/unit/capi/GEOSIntersectsTest.cpp: Have RobustDeterminant
throw an IllegalArgument if passed any infinite or nan value.
Fixes bug #357. Includes regress test.
-2011-05-12 07:39 Sandro Santilli <strk at keybit.net>
+2011-05-12 07:39 Sandro Santilli <strk at kbt.io>
* [r3359] NEWS: Add note about the memory usage reduction in
prepared geoms (#342)
-2011-05-12 07:21 Sandro Santilli <strk at keybit.net>
+2011-05-12 07:21 Sandro Santilli <strk at kbt.io>
* [r3358] src/noding/MCIndexSegmentSetMutualIntersector.cpp:
Reserve vector space, use ::size_type for vector indices.
-2011-05-12 07:18 Sandro Santilli <strk at keybit.net>
+2011-05-12 07:18 Sandro Santilli <strk at kbt.io>
* [r3357] include/geos/noding/MCIndexSegmentSetMutualIntersector.h,
src/noding/MCIndexSegmentSetMutualIntersector.cpp: Don't let
MCIndexSegmentSetMutualIntersector grow in memory on every new
::process call. Fixes bug #342.
-2011-05-12 07:14 Sandro Santilli <strk at keybit.net>
+2011-05-12 07:14 Sandro Santilli <strk at kbt.io>
* [r3356] include/geos/index/chain/MonotoneChainBuilder.h,
src/index/chain/MonotoneChainBuilder.cpp: Port info for
-2011-05-12 06:20 Sandro Santilli <strk at keybit.net>
+2011-05-12 06:20 Sandro Santilli <strk at kbt.io>
* [r3355] src/geom/prep/PreparedLineStringIntersects.cpp: Fix a
memory leak in PreparedLineStringIntersects::isAnyPointInRing
-2011-05-12 06:16 Sandro Santilli <strk at keybit.net>
+2011-05-12 06:16 Sandro Santilli <strk at kbt.io>
* [r3354] src/geom/prep/PreparedLineString.cpp: Drop commented out
code
-2011-05-12 06:13 Sandro Santilli <strk at keybit.net>
+2011-05-12 06:13 Sandro Santilli <strk at kbt.io>
* [r3353] include/geos/geom/prep/PreparedLineStringIntersects.h,
src/geom/prep/PreparedLineStringIntersects.cpp: Port info for
PreparedLineStringIntersects, and avoid polluting the global
namespace
-2011-05-12 06:10 Sandro Santilli <strk at keybit.net>
+2011-05-12 06:10 Sandro Santilli <strk at kbt.io>
* [r3352] include/geos/geom/prep/AbstractPreparedPolygonContains.h,
src/geom/prep/AbstractPreparedPolygonContains.cpp: Reduce heap
allocations in AbstractPreparedPolygonContains
-2011-05-11 17:59 Sandro Santilli <strk at keybit.net>
+2011-05-11 17:59 Sandro Santilli <strk at kbt.io>
* [r3351] include/geos/noding/FastSegmentSetIntersectionFinder.h,
src/noding/FastSegmentSetIntersectionFinder.cpp: Port info for
* [r3350] include/geos/noding/MCIndexSegmentSetMutualIntersector.h,
src/noding/MCIndexSegmentSetMutualIntersector.cpp: Port info for
-2011-05-11 17:25 Sandro Santilli <strk at keybit.net>
+2011-05-11 17:25 Sandro Santilli <strk at kbt.io>
* [r3349] configure.in, tests/perf/Makefile.am, tests/perf/capi,
tests/perf/capi/Makefile.am, tests/perf/capi/memleak_mp_prep.c,
tests/perf/capi/memleak_mp_prep.sh: Import test for bug #342. It
is not automated as it's not general (requires bash)
-2011-05-11 10:00 Sandro Santilli <strk at keybit.net>
+2011-05-11 10:00 Sandro Santilli <strk at kbt.io>
* [r3348] HOWTO_RELEASE: Producing a bzip2 tarball is easier than
described
-2011-05-11 09:54 Sandro Santilli <strk at keybit.net>
+2011-05-11 09:54 Sandro Santilli <strk at kbt.io>
* [r3346] ChangeLog, NEWS: Updated for 3.0.0rc1 release
-2011-05-11 09:48 Sandro Santilli <strk at keybit.net>
+2011-05-11 09:48 Sandro Santilli <strk at kbt.io>
* [r3345] php/geos.c, php/test/test.php: Add Geometry.offsetCurve
to PHP binding
-2011-05-11 09:47 Sandro Santilli <strk at keybit.net>
+2011-05-11 09:47 Sandro Santilli <strk at kbt.io>
* [r3344] php/geos.c, php/test/test.php: Add single-sided buffering
support in PHP binding
-2011-05-11 09:15 Sandro Santilli <strk at keybit.net>
+2011-05-11 09:15 Sandro Santilli <strk at kbt.io>
* [r3343] configure.in: Set version to 3.0.0rc1
-2011-05-10 18:10 Sandro Santilli <strk at keybit.net>
+2011-05-10 18:10 Sandro Santilli <strk at kbt.io>
* [r3342] src/operation/buffer/BufferBuilder.cpp,
@@ -4677,13 +6673,13 @@
right-turning curve can do that). Regress test one such case,
taken from http://trac.osgeo.org/postgis/ticket/413.
-2011-05-10 11:11 Sandro Santilli <strk at keybit.net>
+2011-05-10 11:11 Sandro Santilli <strk at kbt.io>
* [r3341] tests/unit/Makefile.am,
tests/unit/capi/GEOSIntersectsTest.cpp: Add test for 357 (doesn't
succeed at failing)
-2011-05-10 09:51 Sandro Santilli <strk at keybit.net>
+2011-05-10 09:51 Sandro Santilli <strk at kbt.io>
* [r3340] include/geos/algorithm/LineIntersector.h,
include/geos/geomgraph/EdgeIntersection.h,
@@ -4693,7 +6689,7 @@
to compute edge distance." (r3334). Simple double in HCoordinate
made #350 pass anyway.
* [r3339] src/algorithm/HCoordinate.cpp: Drop
STORE_INTERMEDIATE_COMPUTATION_VALUES macro and protected
@@ -4702,24 +6698,24 @@
testsuite (our and postgis') I think it makes sense to have the
code as close as possible to the JTS one.
-2011-05-10 09:50 Sandro Santilli <strk at keybit.net>
+2011-05-10 09:50 Sandro Santilli <strk at kbt.io>
* [r3338] include/geos/algorithm/HCoordinate.h,
src/algorithm/HCoordinate.cpp: Update port info
* [r3337] tests/xmltester/tests/ticket/bug350.xml,
tests/xmltester/tests/ticket/bug398.xml: Expect the same results
given by JTS
* [r3336] include/geos/algorithm/HCoordinate.h,
src/algorithm/HCoordinate.cpp: Bring hcoordinate back to double
precision (from long double)
-2011-05-09 11:57 Sandro Santilli <strk at keybit.net>
+2011-05-09 11:57 Sandro Santilli <strk at kbt.io>
* [r3335] tests/xmltester/Makefile.am,
tests/xmltester/tests/ticket/bug350.xml: Automate test for
@@ -4728,7 +6724,7 @@
close enough. Unfortunately both GEOS and JTS use an exact match
for comparison so we won't be able to share this test.
* [r3334] include/geos/algorithm/LineIntersector.h,
@@ -4737,18 +6733,18 @@
src/geomgraph/EdgeIntersectionList.cpp: Use long double to
compute edge distance. Makes noding more robust, fixes bug #350.
-2011-05-06 18:51 Sandro Santilli <strk at keybit.net>
+2011-05-06 18:51 Sandro Santilli <strk at kbt.io>
* [r3333] include/geos/geomgraph/EdgeIntersection.h,
src/geomgraph/EdgeIntersection.cpp, src/geomgraph/Makefile.am:
Turn EdgeIntersection into a concrete, fully-inlined, C++ class.
* [r3332] include/geos/geomgraph/index/MonotoneChain.h: Describe
MonotoneChain
* [r3331] src/geomgraph/Edge.cpp,
@@ -4756,7 +6752,7 @@
Edge, EdgeIntersection and EdgeIntersectionList closer to JTS,
for easier comparison
* [r3330] include/geos/geomgraph/EdgeIntersection.h,
include/geos/geomgraph/EdgeIntersectionList.h,
@@ -4764,38 +6760,38 @@
src/geomgraph/EdgeIntersectionList.cpp: Output operator for
* [r3329] include/geos/geomgraph/GeometryGraph.h,
src/geomgraph/GeometryGraph.cpp: Drop book keeping of segment
intersectors, as we're transferring their ownership to caller
anyway
-2011-05-06 08:57 Sandro Santilli <strk at keybit.net>
+2011-05-06 08:57 Sandro Santilli <strk at kbt.io>
* [r3328] tests/xmltester/tests/ticket/bug350.xml: Re-add also the
original data in test for bug350, so nothing gets lost.
* [r3327] src/geomgraph/GeometryGraph.cpp: Use logical (not
bitwise) AND, use dynamic_cast to map JTS's instanceof operator
* [r3326] tests/xmltester/tests/ticket/bug350.xml: Modify test for
bug350 so to use pre-snapped geometries. Shows that the problem
is not in snapping code, but after that (ie: JTS succeeds at fist
shot on this new input)
-2011-05-04 17:45 Sandro Santilli <strk at keybit.net>
+2011-05-04 17:45 Sandro Santilli <strk at kbt.io>
* [r3325] src/geom/prep/AbstractPreparedPolygonContains.cpp,
tests/unit/capi/GEOSPreparedGeometryTest.cpp: Fix regression
accidentally introduced by commit r3322 (Sean's). Add automated
test for it (was found trough PostGIS regression test)
-2011-05-04 16:30 Sandro Santilli <strk at keybit.net>
+2011-05-04 16:30 Sandro Santilli <strk at kbt.io>
* [r3324] src/operation/buffer/OffsetCurveBuilder.cpp: Drop useless
and unavailable include
@@ -4812,7 +6808,7 @@
src/geom/prep/PreparedPolygon.cpp: Add missing prepared geometry
predicates to C API (#436)
-2011-04-28 16:39 Sandro Santilli <strk at keybit.net>
+2011-04-28 16:39 Sandro Santilli <strk at kbt.io>
* [r3321] .gitignore, NEWS,
include/geos/operation/predicate/RectangleIntersects.h,
@@ -4821,30 +6817,30 @@
src/operation/predicate/SegmentIntersectionTester.cpp: Improve
performance of RectangleIntersects (of one order of magnitude).
-2011-04-28 16:38 Sandro Santilli <strk at keybit.net>
+2011-04-28 16:38 Sandro Santilli <strk at kbt.io>
* [r3320]
tests/perf/operation/predicate/RectangleIntersectsPerfTest.cpp:
More concise output from performance tester
-2011-04-28 15:09 Sandro Santilli <strk at keybit.net>
+2011-04-28 15:09 Sandro Santilli <strk at kbt.io>
* [r3319] src/noding/ScaledNoder.cpp,
src/operation/buffer/BufferOp.cpp: Hush uncontrolled debugging
prints
-2011-04-28 15:08 Sandro Santilli <strk at keybit.net>
+2011-04-28 15:08 Sandro Santilli <strk at kbt.io>
* [r3318] include/geos/operation/relate/RelateComputer.h,
src/operation/relate/RelateComputer.cpp: Plug leak on exception
in RelateComputer (exposed by running doc/example)
* [r3317] src/geom/Geometry.cpp: Do not leak on exception during
relational geometry predicates
-2011-04-28 14:16 Sandro Santilli <strk at keybit.net>
+2011-04-28 14:16 Sandro Santilli <strk at kbt.io>
* [r3316] configure.in, tests/perf/operation/Makefile.am,
tests/perf/operation/predicate,
@@ -4852,17 +6848,17 @@
Port RectangleIntersects performance test from JTS-1.12
* [r3315] src/operation/predicate/RectangleIntersects.cpp: Do not
leak memory during rectangle intersects predicate
* [r3314] src/operation/overlay/OverlayOp.cpp: Drop unneeded
include
-2011-04-28 10:04 Sandro Santilli <strk at keybit.net>
+2011-04-28 10:04 Sandro Santilli <strk at kbt.io>
* [r3313] doc/example.cpp, include/geos/geom/util/Makefile.am,
include/geos/geom/util/SineStarFactory.h,
@@ -4872,25 +6868,25 @@
geos::geom::util::SineStarFactory from JTS-1.12, useful for
profile-test RectangleIntersects.
* [r3312] src/geomgraph/EdgeIntersectionList.cpp,
src/geomgraph/NodeMap.cpp, src/operation/valid/IsValidOp.cpp:
Trim old embedded history log (from CVS times)
-2011-04-27 16:42 Sandro Santilli <strk at keybit.net>
+2011-04-27 16:42 Sandro Santilli <strk at kbt.io>
* [r3311] include/geos/algorithm/CGAlgorithms.h,
src/algorithm/CGAlgorithms.cpp, tests/unit/Makefile.am,
tests/unit/algorithm/CGAlgorithms/signedAreaTest.cpp: Improve
speed of Geometry.getArea, unit-test it.
-2011-04-27 15:52 Sandro Santilli <strk at keybit.net>
+2011-04-27 15:52 Sandro Santilli <strk at kbt.io>
* [r3310] tools/findclassfiles: Match full class names, not
partial. Allow specifying a package name.
-2011-04-27 15:47 Sandro Santilli <strk at keybit.net>
+2011-04-27 15:47 Sandro Santilli <strk at kbt.io>
* [r3309] include/geos/operation/linemerge/EdgeString.h,
include/geos/operation/linemerge/LineMergeDirectedEdge.h,
@@ -4906,52 +6902,52 @@
src/operation/linemerge/LineSequencer.cpp: Sync linemerge package
to JTS-1.12 (nothing changed)
-2011-04-27 15:33 Sandro Santilli <strk at keybit.net>
+2011-04-27 15:33 Sandro Santilli <strk at kbt.io>
* [r3308] tools/findclassfiles: Utility script to help with editing
all files of a class
-2011-04-27 15:18 Sandro Santilli <strk at keybit.net>
+2011-04-27 15:18 Sandro Santilli <strk at kbt.io>
* [r3307] include/geos/algorithm/Angle.h, src/algorithm/Angle.cpp,
tests/unit/Makefile.am, tests/unit/algorithm/AngleTest.cpp: Sync
Angle class to JTS-1.12, port unit testing for it.
-2011-04-27 14:13 Sandro Santilli <strk at keybit.net>
+2011-04-27 14:13 Sandro Santilli <strk at kbt.io>
* [r3306] include/geos/operation/buffer/OffsetCurveSetBuilder.h,
src/operation/buffer/OffsetCurveSetBuilder.cpp,
tests/unit/capi/GEOSBufferTest.cpp: Add test for singlesided
buffer (areal). Fix premature exit from OffsetCurveSetBuilder.
-2011-04-27 13:38 Sandro Santilli <strk at keybit.net>
+2011-04-27 13:38 Sandro Santilli <strk at kbt.io>
* [r3305] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp,
tests/unit/capi/GEOSOffsetCurveTest.cpp: Drop one argument from
GEOSOffsetCurve. Tell right/left from width/distance sign (<0 for
right side)
-2011-04-27 13:06 Sandro Santilli <strk at keybit.net>
+2011-04-27 13:06 Sandro Santilli <strk at kbt.io>
* [r3304] tests/unit/Makefile.am,
tests/unit/capi/GEOSBufferTest.cpp,
tests/unit/capi/GEOSOffsetCurveTest.cpp: Put OffsetCurveTest in
its own file (old singleside test + a couple more tests)
* [r3303] NEWS, capi/geos_c.cpp, capi/geos_c.h.in,
capi/geos_ts_c.cpp: Add GEOSBufferParams type and
GEOSBufferWithParams function to have an extensible buffer
operation. Allows areal single sided buffer.
-2011-04-27 11:13 Sandro Santilli <strk at keybit.net>
+2011-04-27 11:13 Sandro Santilli <strk at kbt.io>
* [r3302] NEWS, capi/geos_c.cpp, capi/geos_c.h.in,
capi/geos_ts_c.cpp: Add GEOSOffsetCurve C-API interface
deprecating GEOSSingleSidedBuffer
-2011-04-27 09:42 Sandro Santilli <strk at keybit.net>
+2011-04-27 09:42 Sandro Santilli <strk at kbt.io>
* [r3301] include/geos/operation/buffer/BufferBuilder.h,
include/geos/operation/buffer/BufferSubgraph.h,
@@ -4967,29 +6963,29 @@
src/operation/buffer/OffsetSegmentGenerator.cpp: Refactored
offset curve generation (from JTS-1.12)
* [r3300] include/geos/operation/buffer/BufferParameters.h,
src/operation/buffer/BufferParameters.cpp: Sync BufferParameters
class to JTS r378 (isSingleSided property)
* [r3299] include/geos/operation/buffer/BufferOp.h,
src/operation/buffer/BufferOp.cpp: Sync BufferOp class to JTS
r378. Do not port the unused isSingleSided property.
-2011-04-23 10:30 Sandro Santilli <strk at keybit.net>
+2011-04-23 10:30 Sandro Santilli <strk at kbt.io>
* [r3298] NEWS: Add note about GEOSCascadedUnion deprecation
-2011-04-23 10:28 Sandro Santilli <strk at keybit.net>
+2011-04-23 10:28 Sandro Santilli <strk at kbt.io>
* [r3297] capi/geos_c.h.in: Mark GEOSUnionCascaded as deprecated,
GEOSUnaryUnion does the same thing w/out refusin to deal with
lines, points, collections
-2011-04-23 10:03 Sandro Santilli <strk at keybit.net>
+2011-04-23 10:03 Sandro Santilli <strk at kbt.io>
* [r3296] include/geos/operation/union/CascadedUnion.h,
include/geos/operation/union/Makefile.am, php/test/test.php,
@@ -5004,27 +7000,27 @@
of it, tweak expected results from other tests (output components
reordered).
-2011-04-22 22:26 Sandro Santilli <strk at keybit.net>
+2011-04-22 22:26 Sandro Santilli <strk at kbt.io>
* [r3295] tests/xmltester/XMLTester.cpp: Use equals() to compare
expected/obtained results of "Union" operation. This matches JTS
and prevents being too strict about equality.
-2011-04-22 18:46 Sandro Santilli <strk at keybit.net>
+2011-04-22 18:46 Sandro Santilli <strk at kbt.io>
* [r3294] include/geos/operation/union/CascadedPolygonUnion.h,
include/geos/operation/union/GeometryListHolder.h,
include/geos/operation/union/Makefile.am: Put GeometryListHolder
in its own header file.
-2011-04-22 13:51 Sandro Santilli <strk at keybit.net>
+2011-04-22 13:51 Sandro Santilli <strk at kbt.io>
* [r3293] include/geos/io/WKTWriter.h, src/io/WKTWriter.cpp,
tests/unit/io/WKTWriterTest.cpp: Use stringstream to format
strings rather than printf-like statements. Simplifies things a
lot.
-2011-04-22 13:04 Sandro Santilli <strk at keybit.net>
+2011-04-22 13:04 Sandro Santilli <strk at kbt.io>
* [r3292] include/geos/geom/PrecisionModel.h,
include/geos/geom/PrecisionModel.inl,
@@ -5034,7 +7030,7 @@
Sync PrecisionModel to JTS-1.12, add unit testing, fix
getMaximumPrecisionDigit to behave as documented (JTS doesn't).
-2011-04-20 17:13 Sandro Santilli <strk at keybit.net>
+2011-04-20 17:13 Sandro Santilli <strk at kbt.io>
* [r3291] include/geos/operation/buffer/OffsetCurveSetBuilder.h,
@@ -5043,7 +7039,7 @@
OffsetCurveSetBuilder::isErodedCompletely implementation to JTS,
fixing bug #434
-2011-04-20 15:55 Sandro Santilli <strk at keybit.net>
+2011-04-20 15:55 Sandro Santilli <strk at kbt.io>
* [r3290] tests/xmltester/Makefile.am,
tests/xmltester/tests/bug176.xml,
@@ -5070,11 +7066,11 @@
tests/xmltester/tests/ticket/bug398.xml: Move per-ticket
testcases under their own directory
-2011-04-20 15:42 Sandro Santilli <strk at keybit.net>
+2011-04-20 15:42 Sandro Santilli <strk at kbt.io>
* [r3289] configure.in: Set JTS port version to 1.12
-2011-04-19 07:57 Sandro Santilli <strk at keybit.net>
+2011-04-19 07:57 Sandro Santilli <strk at kbt.io>
* [r3288] tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp: Add test
for IsCCW against the two almost-collapsed rings resulting by
@@ -5082,12 +7078,12 @@
#398. This is done after confirmation of same results in JTS (1
bit makes the difference between CCW and CW orientation).
-2011-04-18 21:45 Sandro Santilli <strk at keybit.net>
+2011-04-18 21:45 Sandro Santilli <strk at kbt.io>
* [r3287] tests/unit/operation/distance/DistanceOpTest.cpp: Add the
actual ->distance() call to the test for bug #367
-2011-04-18 21:28 Sandro Santilli <strk at keybit.net>
+2011-04-18 21:28 Sandro Santilli <strk at kbt.io>
* [r3286] src/operation/overlay/PolygonBuilder.cpp,
tests/xmltester/Makefile.am: Throw a TopologyException, rather
@@ -5095,63 +7091,63 @@
list. Fixes bug #398. Enables automated test for it. Note that
JTS fails the test now, triggering the failed assertion.
* [r3285] tests/xmltester/tests/bug398.xml: Expect a result
with/out the collapsed ring in the test for bug 398. Funny
enough, this makes JTS react by failing the assertion I was
tracking...
-2011-04-18 21:01 Sandro Santilli <strk at keybit.net>
+2011-04-18 21:01 Sandro Santilli <strk at kbt.io>
* [r3284] src/operation/overlay/PolygonBuilder.cpp: Avoid more heap
allocations in PolygonBuilder
-2011-04-18 15:08 Sandro Santilli <strk at keybit.net>
+2011-04-18 15:08 Sandro Santilli <strk at kbt.io>
* [r3283] include/geos/operation/overlay/PolygonBuilder.h,
src/operation/overlay/PolygonBuilder.cpp: Reduce heap allocations
in PolygonBuilder, rewrite some private interfaces to deal with
refs rather than pointers
* [r3282] src/operation/overlay/PolygonBuilder.cpp: Use
PlanarGraph::linkResultDirectedEdges rather than rewriting it
inline
* [r3281] include/geos/geomgraph/PlanarGraph.h,
src/geomgraph/PlanarGraph.cpp: Turn
PlanarGraph::linkResultDirectedEdges into a templated method
-2011-04-13 11:52 Sandro Santilli <strk at keybit.net>
+2011-04-13 11:52 Sandro Santilli <strk at kbt.io>
* [r3280] tests/unit/geom/CoordinateArraySequenceTest.cpp: Add test
for bug #435
-2011-04-13 11:32 Sandro Santilli <strk at keybit.net>
+2011-04-13 11:32 Sandro Santilli <strk at kbt.io>
* [r3279] php/Makefile.am: Fix path to CAPI includes for PHP
binding
-2011-04-13 10:44 Sandro Santilli <strk at keybit.net>
+2011-04-13 10:44 Sandro Santilli <strk at kbt.io>
* [r3278] src/geom/CoordinateArraySequence.cpp: Drop coordinate
dimension cache after read-write filtering. Fixes ticket #435.
-2011-04-13 08:26 Sandro Santilli <strk at keybit.net>
+2011-04-13 08:26 Sandro Santilli <strk at kbt.io>
* [r3277] .gitignore, Makefile.am, author.sh: Drop author.sh, add a
rule to create authors.git instead
-2011-04-13 07:37 Sandro Santilli <strk at keybit.net>
+2011-04-13 07:37 Sandro Santilli <strk at kbt.io>
* [r3276] author.sh: Add script to be used with git-svn
--authors-prog
-2011-03-26 14:02 Sandro Santilli <strk at keybit.net>
+2011-03-26 14:02 Sandro Santilli <strk at kbt.io>
* [r3275] include/geos/simplify/TaggedLineString.h,
src/index/chain/MonotoneChainBuilder.cpp,
@@ -5160,7 +7156,7 @@
src/simplify/TaggedLineStringSimplifier.cpp: fix missing size_t
with gcc 4.6
* [r3274] include/geos/index/chain/MonotoneChainBuilder.h,
include/geos/operation/valid/SimpleNestedRingTester.h,
@@ -5168,7 +7164,7 @@
src/index/bintree/Root.cpp, src/index/strtree/AbstractNode.cpp:
fixed missing NULL with gcc 4.6
* [r3273] include/geos/operation/overlay/OverlayNodeFactory.h: fix
uninitialized const caused by missing constructor
@@ -5179,82 +7175,82 @@
src/CMakeLists.txt: Added source_group properties to support
source browsers in various IDEs
-2011-03-16 22:29 Sandro Santilli <strk at keybit.net>
+2011-03-16 22:29 Sandro Santilli <strk at kbt.io>
* [r3271] capi/geos_ts_c.cpp: Use GEOSVALID flag correctly, thanks
Mat for spotting this.
-2011-03-11 14:40 Sandro Santilli <strk at keybit.net>
+2011-03-11 14:40 Sandro Santilli <strk at kbt.io>
* [r3270] tests/xmltester/tests/bug350.xml: Add XML test for bug
#350
-2011-03-11 14:24 Sandro Santilli <strk at keybit.net>
+2011-03-11 14:24 Sandro Santilli <strk at kbt.io>
* [r3269] tests/xmltester/tests/bug398.xml: Add XML test for bug398
(not automatically run, as it fails)
* [r3268] tests/xmltester/XMLTester.cpp: Tell more about XML
loading failures
-2011-03-08 09:04 Sandro Santilli <strk at keybit.net>
+2011-03-08 09:04 Sandro Santilli <strk at kbt.io>
* [r3267] tests/unit/capi/GEOSRelateBoundaryNodeRuleTest.cpp: Add
test for invalid boundary node rule value
-2011-03-04 17:05 Sandro Santilli <strk at keybit.net>
+2011-03-04 17:05 Sandro Santilli <strk at kbt.io>
* [r3266] php/geos.c, php/test/test.php: PHP: add
relateBoundaryNodeRule method to GEOSGeometry object
-2011-03-04 16:38 Sandro Santilli <strk at keybit.net>
+2011-03-04 16:38 Sandro Santilli <strk at kbt.io>
* [r3265] NEWS: Add note aboute GEOSRelateBoundaryNodeRule
-2011-03-04 16:31 Sandro Santilli <strk at keybit.net>
+2011-03-04 16:31 Sandro Santilli <strk at kbt.io>
* [r3264] tests/unit/Makefile.am,
GEOSRelateBoundaryNodeRule test, ticket #399 [RT-SIGTA]
-2011-03-04 16:30 Sandro Santilli <strk at keybit.net>
+2011-03-04 16:30 Sandro Santilli <strk at kbt.io>
* [r3263] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
GEOSRelateBoundaryNodeRule, ticket #399 [RT-SIGTA]
* [r3262] include/geos/algorithm/BoundaryNodeRule.h: Indenting..
-2011-03-02 13:45 Sandro Santilli <strk at keybit.net>
+2011-03-02 13:45 Sandro Santilli <strk at kbt.io>
* [r3261] NEWS, tests/unit/operation/distance/DistanceOpTest.cpp:
Tweak unit test to expect distance 0 between an empty an anything
else. Report the change in NEWS file.
* [r3260] tests/xmltester/Makefile.am,
tests/xmltester/XMLTester.cpp,
tests/xmltester/tests/general/TestDistance.xml: Add support for
"distance" op in XMLTester, and import JTS TestDistance.xml
* [r3259] include/geos/operation/distance/DistanceOp.h,
src/operation/distance/DistanceOp.cpp: Fixed Geometry.distance()
and DistanceOp to return 0.0 for empty inputs (JTS-1.11)
-2011-03-02 13:13 Sandro Santilli <strk at keybit.net>
+2011-03-02 13:13 Sandro Santilli <strk at kbt.io>
* [r3258] include/geos/operation/valid/IsValidOp.h,
src/operation/valid/IsValidOp.cpp,
tests/xmltester/tests/general/TestValid.xml: Sync IsValidOp and
related XML testcase to JTS-1.12
-2011-03-02 12:46 Sandro Santilli <strk at keybit.net>
+2011-03-02 12:46 Sandro Santilli <strk at kbt.io>
* [r3257] NEWS, include/geos/geom/LineSegment.h,
include/geos/geom/LineSegment.inl,
@@ -5262,7 +7258,7 @@
include/geos/util/Makefile.am, src/geom/LineSegment.cpp: Added
check for illegal state in offsetPoint method
-2011-03-02 09:24 Sandro Santilli <strk at keybit.net>
+2011-03-02 09:24 Sandro Santilli <strk at kbt.io>
* [r3256] src/geomgraph/Edge.cpp: Fix debug build
@@ -5367,44 +7363,44 @@
- Visual C++ linker has mysterious problems with exporting them
from DLL.
-2011-02-28 14:36 Sandro Santilli <strk at keybit.net>
+2011-02-28 14:36 Sandro Santilli <strk at kbt.io>
* [r3252] src/operation/buffer/BufferOp.cpp,
tests/xmltester/Makefile.am: Fix BufferOp::bufferFixedPrecision
to use snap-rounding noder. Fixes bug #356.
-2011-02-28 12:19 Sandro Santilli <strk at keybit.net>
+2011-02-28 12:19 Sandro Santilli <strk at kbt.io>
* [r3251] src/operation/buffer/BufferBuilder.cpp: Cleanup debugging
output. Previous version didn't really print the _noded_ output
at all.
-2011-02-28 11:43 Sandro Santilli <strk at keybit.net>
+2011-02-28 11:43 Sandro Santilli <strk at kbt.io>
* [r3250] NEWS, php/geos.c, php/test/test.php: Expose and test
covers/coveredBy to PHP binding
-2011-02-28 11:32 Sandro Santilli <strk at keybit.net>
+2011-02-28 11:32 Sandro Santilli <strk at kbt.io>
* [r3249] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
GEOSCovers and GEOSCoveredBy (ticket #396) by Alessandro Furieri
-2011-02-25 16:05 Sandro Santilli <strk at keybit.net>
+2011-02-25 16:05 Sandro Santilli <strk at kbt.io>
* [r3248] tests/xmltester/tests/bug356.xml: be explicit about
quadrant segments
-2011-02-25 10:22 Sandro Santilli <strk at keybit.net>
+2011-02-25 10:22 Sandro Santilli <strk at kbt.io>
* [r3247] tests/xmltester/tests/bug356.xml: Add test for ticket
#356 (not run, as it fails)
-2011-02-23 17:13 Sandro Santilli <strk at keybit.net>
+2011-02-23 17:13 Sandro Santilli <strk at kbt.io>
* [r3246] src/operation/buffer/BufferInputLineSimplifier.cpp,
src/operation/buffer/BufferInputLineSimplifier.h: JTS-1.12 sync
-2011-02-23 16:46 Sandro Santilli <strk at keybit.net>
+2011-02-23 16:46 Sandro Santilli <strk at kbt.io>
* [r3245] include/geos/operation/buffer/BufferBuilder.h,
@@ -5421,77 +7417,77 @@
src/operation/buffer/RightmostEdgeFinder.cpp,
src/operation/buffer/SubgraphDepthLocater.cpp: Update port info
-2011-02-23 16:21 Sandro Santilli <strk at keybit.net>
+2011-02-23 16:21 Sandro Santilli <strk at kbt.io>
* [r3244] include/geos/operation/buffer/OffsetCurveBuilder.h,
src/operation/buffer/OffsetCurveBuilder.cpp,
src/operation/buffer/OffsetCurveSetBuilder.cpp: Update port info
* [r3243] NEWS, src/operation/buffer/OffsetCurveSetBuilder.cpp,
tests/xmltester/tests/general/TestBuffer.xml: Fixed buffer
OffsetCurveSetBuilder to handle "flat" rings correctly
-2011-02-23 15:45 Sandro Santilli <strk at keybit.net>
+2011-02-23 15:45 Sandro Santilli <strk at kbt.io>
* [r3242] include/geos/operation/buffer/OffsetCurveSetBuilder.h,
src/operation/buffer/OffsetCurveSetBuilder.cpp: Don't bother
adding ring if it is "flat" and will disappear in the output
(from TS r261)
* [r3241] NEWS, include/geos/geom/LinearRing.h,
src/geom/LinearRing.cpp, tests/unit/geom/LinearRingTest.cpp: Sync
LinearRing to JTS-1.12: empty LinearRing are closed by definition
now
-2011-02-23 14:37 Sandro Santilli <strk at keybit.net>
+2011-02-23 14:37 Sandro Santilli <strk at kbt.io>
* [r3240] include/geos/noding/snapround/MCIndexPointSnapper.h,
src/noding/snapround/MCIndexPointSnapper.cpp: Update port info
for MCIndexPointSnapper
* [r3239] include/geos/noding/snapround/SimpleSnapRounder.h,
src/noding/snapround/SimpleSnapRounder.cpp: Update port info for
SimpleSnapRounder
* [r3238] include/geos/noding/snapround/MCIndexSnapRounder.h,
MCIndexSnapRounder (and remove testing-only check)
* [r3237] include/geos/noding/snapround/HotPixel.h,
include/geos/noding/snapround/HotPixel.inl,
src/noding/snapround/HotPixel.cpp: Sync HotPixel to JTS-1.12
(doxygen + privatization of a method..)
-2011-02-23 11:05 Sandro Santilli <strk at keybit.net>
+2011-02-23 11:05 Sandro Santilli <strk at kbt.io>
* [r3236] tests/xmltester/Makefile.am,
tests/xmltester/tests/bug366.xml: Run test for bug366 (succeeds)
-2011-02-23 10:25 Sandro Santilli <strk at keybit.net>
+2011-02-23 10:25 Sandro Santilli <strk at kbt.io>
* [r3235] tests/unit/noding/SegmentPointComparatorTest.cpp: Port
JTS unit tests for SegmentPointComparator
* [r3234] include/geos/noding/Makefile.am,
include/geos/noding/SegmentPointComparator.h,
src/noding/SegmentNode.cpp: Take SegmentPointComparator out of
implelmentation file, to allow for unit-testing.
-2011-02-23 09:37 Sandro Santilli <strk at keybit.net>
+2011-02-23 09:37 Sandro Santilli <strk at kbt.io>
* [r3233] NEWS, include/geos/noding/NodedSegmentString.h,
src/noding/NodedSegmentString.cpp,
@@ -5499,18 +7495,18 @@
NodedSegmentString to handle zero-length line segments correctly
(via safeOctant)
-2011-02-22 21:22 Sandro Santilli <strk at keybit.net>
+2011-02-22 21:22 Sandro Santilli <strk at kbt.io>
* [r3232] include/geos/geom/Lineal.h,
include/geos/geom/Polygonal.h, include/geos/geom/Puntal.h: Export
Puntal, Lineal and Polygonal symbols
-2011-02-22 17:53 Sandro Santilli <strk at keybit.net>
+2011-02-22 17:53 Sandro Santilli <strk at kbt.io>
* [r3231] tests/unit/operation/linemerge/LineMergerTest.cpp: Fix
linemerge test (wrong initial copy)
-2011-02-21 17:30 Sandro Santilli <strk at keybit.net>
+2011-02-21 17:30 Sandro Santilli <strk at kbt.io>
* [r3230] include/geos/operation/linemerge/LineSequencer.h,
src/operation/linemerge/LineSequencer.cpp,
@@ -5518,12 +7514,12 @@
tests/unit/operation/linemerge/LineSequencerTest.cpp: Add
LineSequencer unit test, fix memory leaks in the class.
* [r3229] include/geos/operation/linemerge/LineSequencer.h: Add
templated geometry adder to LineSequencer class
-2011-02-21 16:14 Sandro Santilli <strk at keybit.net>
+2011-02-21 16:14 Sandro Santilli <strk at kbt.io>
* [r3228] NEWS, include/geos/operation/linemerge/EdgeString.h,
include/geos/operation/linemerge/LineMergeEdge.h,
@@ -5539,17 +7535,17 @@
single unique coordinate; reduce some heap allocations; add unit
testing for Linemerger
* [r3227] include/geos/operation/linemerge/LineSequencer.h,
linemerge::LineSequencer to JTS-1.12
-2011-02-21 14:02 Sandro Santilli <strk at keybit.net>
+2011-02-21 14:02 Sandro Santilli <strk at kbt.io>
* [r3226] NEWS: Add note about SnapIfNeededOverlayOp change
* [r3225] include/geos/operation/overlay/snap/GeometrySnapper.h,
include/geos/operation/overlay/snap/LineStringSnapper.h,
@@ -5558,7 +7554,7 @@
src/operation/overlay/snap/LineStringSnapper.cpp,
src/operation/overlay/snap/SnapOverlayOp.cpp: Update port info
-2011-02-21 12:03 Sandro Santilli <strk at keybit.net>
+2011-02-21 12:03 Sandro Santilli <strk at kbt.io>
* [r3224]
include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h,
@@ -5577,35 +7573,35 @@
* [r3222] capi/geos_ts_c.cpp: gstrdup may throw since r3088 thus
should no longer be declared as C function
-2011-02-15 15:24 Sandro Santilli <strk at keybit.net>
+2011-02-15 15:24 Sandro Santilli <strk at kbt.io>
* [r3221] capi/geos_ts_c.cpp,
tests/unit/capi/GEOSisValidDetailTest.cpp: Allow passing NULL for
"reason" and "location" arguments of GEOSisValidDetail [RT-SIGTA]
-2011-02-15 15:15 Sandro Santilli <strk at keybit.net>
+2011-02-15 15:15 Sandro Santilli <strk at kbt.io>
* [r3220] php/geos.c, php/test/test.php: Adapt PHP binding to the
new GEOSisValidDetail interface
* [r3219] NEWS, capi/geos_c.cpp, capi/geos_c.h.in,
capi/geos_ts_c.cpp, tests/unit/Makefile.am,
tests/unit/capi/GEOSisValidDetailTest.cpp: Add a 'flags'
parameter to GEOSisValidDetail.
-2011-02-15 15:14 Sandro Santilli <strk at keybit.net>
+2011-02-15 15:14 Sandro Santilli <strk at kbt.io>
* [r3218] php/Makefile.am: Make sure php binding are built _before_
the corresponding test is run
-2011-02-13 22:31 Sandro Santilli <strk at keybit.net>
+2011-02-13 22:31 Sandro Santilli <strk at kbt.io>
* [r3217] src/operation/overlay/snap/LineStringSnapper.cpp: Guard
againts empty vectors before decrementing .end()
-2011-02-13 22:30 Sandro Santilli <strk at keybit.net>
+2011-02-13 22:30 Sandro Santilli <strk at kbt.io>
* [r3216] include/geos/geom/CoordinateList.h: Add an .empty()
interface to CoordinateList
@@ -5628,7 +7624,7 @@
test case submitted with Ticket #367. No segmentation fault in
distance() method observed under Visual C++ 10.0
-2011-02-13 20:03 Sandro Santilli <strk at keybit.net>
+2011-02-13 20:03 Sandro Santilli <strk at kbt.io>
* [r3212] src/geom/Geometry.cpp: Always use BinaryOp for overlay
operations accessible from Geometry
@@ -5667,61 +7663,61 @@
* [r3207] include/geos/geom/BinaryOp.h: Fixed missing or ambiguous
declarations of TopologyException (Ticket #394)
-2011-02-12 08:54 Sandro Santilli <strk at keybit.net>
+2011-02-12 08:54 Sandro Santilli <strk at kbt.io>
* [r3206] src/geom/Geometry.cpp, tests/xmltester/Makefile.am,
tests/xmltester/tests/bug360.xml: Have Geometry::Union use
BinaryOp rather than SnapIfNeededOverlayOp. Improves robustness
(fixes bug #360, test for which is enabled with this commit)
-2011-02-11 15:59 Sandro Santilli <strk at keybit.net>
+2011-02-11 15:59 Sandro Santilli <strk at kbt.io>
* [r3205] tests/xmltester/tests/bug344.xml: Add description
-2011-02-11 10:51 Sandro Santilli <strk at keybit.net>
+2011-02-11 10:51 Sandro Santilli <strk at kbt.io>
* [r3204] tests/xmltester/tests/bug360.xml: XML version of test for
bug #360
-2011-02-11 10:28 Sandro Santilli <strk at keybit.net>
+2011-02-11 10:28 Sandro Santilli <strk at kbt.io>
* [r3203] src/operation/union/PointGeometryUnion.cpp: Optimize
container->container copy, on Mat's suggestion
-2011-02-11 09:58 Sandro Santilli <strk at keybit.net>
+2011-02-11 09:58 Sandro Santilli <strk at kbt.io>
* [r3202] php/geos.c, php/test/test.php: PHP support or UnaryUnion
* [r3201] NEWS, capi/geos_c.cpp, capi/geos_c.h.in,
tests/unit/capi/GEOSUnaryUnionTest.cpp: GEOSUnaryUnion C-API
interface (and test)
-2011-02-10 21:05 Sandro Santilli <strk at keybit.net>
+2011-02-10 21:05 Sandro Santilli <strk at kbt.io>
* [r3200] tests/xmltester/Makefile.am,
tests/xmltester/tests/general/TestUnaryUnion.xml: Add support for
UnaryUnion testing in XML format, import the JTS xml test for it
* [r3199] tests/unit/operation/union/UnaryUnionOpTest.cpp: Add test
exposing the std::copy bug of two commits ago
* [r3198] include/geos/geom/Geometry.h, src/geom/Geometry.cpp:
Expose unary union trought Geometry.Union()
* [r3197] src/operation/union/PointGeometryUnion.cpp: Can't just
std::copy over an empty container. Need a back_inserter !
-2011-02-10 15:51 Sandro Santilli <strk at keybit.net>
+2011-02-10 15:51 Sandro Santilli <strk at kbt.io>
* [r3196] include/geos/operation/union/UnaryUnionOp.h,
@@ -5729,7 +7725,7 @@
tests/unit/operation/union/UnaryUnionOpTest.cpp: Add unit test
for UnaryUnionOp (and fix interface bug)
-2011-02-10 14:14 Sandro Santilli <strk at keybit.net>
+2011-02-10 14:14 Sandro Santilli <strk at kbt.io>
* [r3195] include/geos/operation/union/Makefile.am,
@@ -5737,17 +7733,17 @@
src/operation/union/UnaryUnionOp.cpp: UnaryUnionOp port from
JTS-1.12
-2011-02-10 14:10 Sandro Santilli <strk at keybit.net>
+2011-02-10 14:10 Sandro Santilli <strk at kbt.io>
* [r3194] tests/unit/operation/union/CascadedPolygonUnionTest.cpp:
Oops, didn't want to commit this one.
-2011-02-10 14:05 Sandro Santilli <strk at keybit.net>
+2011-02-10 14:05 Sandro Santilli <strk at kbt.io>
* [r3193] include/geos/operation/union/CascadedPolygonUnion.h: Fix
dynamic cast
-2011-02-10 13:48 Sandro Santilli <strk at keybit.net>
+2011-02-10 13:48 Sandro Santilli <strk at kbt.io>
* [r3192] include/geos/operation/union/CascadedPolygonUnion.h,
@@ -5755,7 +7751,7 @@
template interface to CascadedPolygonUnion to relax requirements
on used container
-2011-02-10 11:09 Sandro Santilli <strk at keybit.net>
+2011-02-10 11:09 Sandro Santilli <strk at kbt.io>
* [r3191] include/geos/geom/Geometry.h,
include/geos/geom/Geometry.inl,
@@ -5765,12 +7761,12 @@
Introduce a templated version of GeometryFactory::buildGeometry,
and test it.
* [r3190] src/operation/sharedpaths/SharedPathsOp.cpp: Include
required GeometryFactory header (it's used)
-2011-02-07 17:52 Sandro Santilli <strk at keybit.net>
+2011-02-07 17:52 Sandro Santilli <strk at kbt.io>
* [r3189] include/geos/geom/util/GeometryExtracter.h,
include/geos/geom/util/Makefile.am, tests/unit/Makefile.am,
@@ -5778,11 +7774,11 @@
tests/unit/geom/util/GeometryExtracterTest.cpp: Port
GeometryExtracter from JTS-1.12
-2011-02-07 17:00 Sandro Santilli <strk at keybit.net>
+2011-02-07 17:00 Sandro Santilli <strk at kbt.io>
* [r3188] src/operation/union/PointGeometryUnion.cpp: Fix casts
-2011-02-07 15:41 Sandro Santilli <strk at keybit.net>
+2011-02-07 15:41 Sandro Santilli <strk at kbt.io>
* [r3187] include/geos/operation/union/Makefile.am,
include/geos/operation/union/PointGeometryUnion.h,
@@ -5790,13 +7786,13 @@
src/operation/union/PointGeometryUnion.cpp: PointGeometryUnion
port
-2011-02-07 15:39 Sandro Santilli <strk at keybit.net>
+2011-02-07 15:39 Sandro Santilli <strk at kbt.io>
* [r3186] include/geos/geom/Lineal.h,
Include definition of base class
* [r3185] NEWS, include/geos/geom/GeometryCollection.h,
include/geos/geom/LineString.h, include/geos/geom/Lineal.h,
@@ -5810,19 +7806,19 @@
Geometry derivates. This commit introduces virtual inheritance
and 3 diamonds.
-2011-02-04 12:27 Sandro Santilli <strk at keybit.net>
+2011-02-04 12:27 Sandro Santilli <strk at kbt.io>
* [r3184] src/operation/union/CascadedPolygonUnion.cpp:
dynamic_cast Polygon to Geometry before converting to void
pointer. This is safer, altought the whole void pointer use
should be dropped for real safety.
-2011-02-04 12:26 Sandro Santilli <strk at keybit.net>
+2011-02-04 12:26 Sandro Santilli <strk at kbt.io>
* [r3183] include/geos/index/strtree/AbstractSTRtree.h: Avoid
useless reinterpret_cast
-2011-02-04 10:12 Sandro Santilli <strk at keybit.net>
+2011-02-04 10:12 Sandro Santilli <strk at kbt.io>
* [r3182] src/algorithm/MinimumDiameter.cpp, src/geom/Geometry.cpp,
@@ -5837,7 +7833,7 @@
tests/unit/operation/union/CascadedPolygonUnionTest.cpp: Even
more static casts drops
-2011-02-04 08:50 Sandro Santilli <strk at keybit.net>
+2011-02-04 08:50 Sandro Santilli <strk at kbt.io>
* [r3181] src/geom/GeometryFactory.cpp, src/geom/LineString.cpp,
src/geom/Polygon.cpp, src/geom/util/GeometryEditor.cpp,
@@ -5848,12 +7844,12 @@
tests/unit/geom/LinearRingTest.cpp,
tests/unit/geom/PolygonTest.cpp: Drop more static casts
-2011-02-03 21:50 Sandro Santilli <strk at keybit.net>
+2011-02-03 21:50 Sandro Santilli <strk at kbt.io>
* [r3180] tests/unit/geom/MultiPointTest.cpp,
tests/unit/geom/PointTest.cpp: Don't downcast with static_cast
-2011-02-03 19:59 Sandro Santilli <strk at keybit.net>
+2011-02-03 19:59 Sandro Santilli <strk at kbt.io>
* [r3179] include/geos/geom/util/GeometryEditor.h,
include/geos/geom/util/GeometryTransformer.h,
@@ -5866,46 +7862,46 @@
src/operation/valid/RepeatedPointTester.cpp: reduce static casts
-2011-02-03 19:58 Sandro Santilli <strk at keybit.net>
+2011-02-03 19:58 Sandro Santilli <strk at kbt.io>
* [r3178] include/geos/geom/Coordinate.h: provide standard strict
weak ordering operator for Coordinate
* [r3177] include/geos/geom/util/GeometryCombiner.h,
src/geom/util/GeometryCombiner.cpp: A step toward better
const-correctness in GeometryCombiner interface
* [r3176] include/geos/geom/util/GeometryCombiner.h: Document
ownerhips of GeometryCombiner inputs
-2011-02-03 08:15 Sandro Santilli <strk at keybit.net>
+2011-02-03 08:15 Sandro Santilli <strk at kbt.io>
* [r3175] src/geom/GeometryFactory.cpp: Oops.. fix the newly added
interface to create MultiPoint from a vector of coordinates
-2011-02-02 19:24 Sandro Santilli <strk at keybit.net>
+2011-02-02 19:24 Sandro Santilli <strk at kbt.io>
* [r3174] include/geos/algorithm/PointLocator.h,
src/algorithm/PointLocator.cpp: Check PointLocator sync with
JTS-1.12
-2011-02-02 19:23 Sandro Santilli <strk at keybit.net>
+2011-02-02 19:23 Sandro Santilli <strk at kbt.io>
* [r3173] include/geos/geom/GeometryFactory.h,
src/geom/GeometryFactory.cpp: Add interface to create MultiPoint
from Coordinate vector
-2011-02-02 17:57 Sandro Santilli <strk at keybit.net>
+2011-02-02 17:57 Sandro Santilli <strk at kbt.io>
* [r3172] include/geos/geom/util/GeometryCombiner.h,
src/geom/util/GeometryCombiner.cpp: Check GeometryCombiner
against JTS-1.12
-2011-02-02 17:41 Sandro Santilli <strk at keybit.net>
+2011-02-02 17:41 Sandro Santilli <strk at kbt.io>
* [r3171] include/geos/geom/LineString.h,
include/geos/geom/Lineal.h, include/geos/geom/Makefile.am,
@@ -5919,11 +7915,11 @@
src/geom/Point.cpp, src/geom/Polygon.cpp: Add Puntal, Lineal and
Polygonal "interfaces"
-2011-01-27 18:01 Sandro Santilli <strk at keybit.net>
+2011-01-27 18:01 Sandro Santilli <strk at kbt.io>
* [r3170] NEWS: Add release date of 3.2.0 (more than an year ago..)
-2011-01-27 10:16 Sandro Santilli <strk at keybit.net>
+2011-01-27 10:16 Sandro Santilli <strk at kbt.io>
* [r3169] php/test/test.php: Don't use is_null on unexistant array
elements [#393]
@@ -5938,24 +7934,24 @@
* [r3167] tests/xmltester/CMakeLists.txt: Updated CMake
configuration to call xmltester from runtime output directory.
-2010-12-26 21:20 Sandro Santilli <strk at keybit.net>
+2010-12-26 21:20 Sandro Santilli <strk at kbt.io>
* [r3166] tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp:
remove warning in testcase
-2010-12-26 20:32 Sandro Santilli <strk at keybit.net>
+2010-12-26 20:32 Sandro Santilli <strk at kbt.io>
* [r3165] include/geos/operation/sharedpaths/SharedPathsOp.h:
Declare SharedPathsOp class as noncopyable. Hopefully fixes
VC2008 warning. [RT-SIGTA]
-2010-12-24 14:27 Sandro Santilli <strk at keybit.net>
+2010-12-24 14:27 Sandro Santilli <strk at kbt.io>
* [r3164] include/geos/algorithm/InteriorPointLine.h,
src/algorithm/InteriorPointLine.cpp: Record port info for
InteriorPointLine
-2010-12-22 16:28 Sandro Santilli <strk at keybit.net>
+2010-12-22 16:28 Sandro Santilli <strk at kbt.io>
* [r3163] src/operation/sharedpaths/SharedPathsOp.cpp,
tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp: Fix
@@ -5963,19 +7959,19 @@
the first-last point of a closed line. Fixes ticket #391.
-2010-12-22 09:42 Sandro Santilli <strk at keybit.net>
+2010-12-22 09:42 Sandro Santilli <strk at kbt.io>
* [r3162] .gitignore, php/geos.c, php/test/test.php: Expose
GEOSRelateMatch to PHP api.
-2010-12-21 08:55 Sandro Santilli <strk at keybit.net>
+2010-12-21 08:55 Sandro Santilli <strk at kbt.io>
* [r3161] NEWS, capi/geos_c.cpp, capi/geos_c.h.in,
tests/unit/capi/GEOSRelatePatternMatchTest.cpp: Add
GEOSRelatePatternMatch C-API interface [RT-SIGTA]
-2010-12-20 11:34 Sandro Santilli <strk at keybit.net>
+2010-12-20 11:34 Sandro Santilli <strk at kbt.io>
* [r3160] include/geos/platform.h.in: MinGW32 fixes by Sandro
Furieri
@@ -5985,93 +7981,93 @@
* [r3159] include/geos/operation/sharedpaths, php, php/test,
src/operation/sharedpaths: Updated svn:ignore properties.
-2010-12-06 15:00 Sandro Santilli <strk at keybit.net>
+2010-12-06 15:00 Sandro Santilli <strk at kbt.io>
* [r3158] include/geos/operation/overlay/snap/GeometrySnapper.h:
typo
-2010-12-03 17:26 Sandro Santilli <strk at keybit.net>
+2010-12-03 17:26 Sandro Santilli <strk at kbt.io>
* [r3157]
tests/unit/operation/overlay/snap/LineStringSnapperTest.cpp: Add
test for src-vertex snapping allowance
-2010-12-03 14:02 Sandro Santilli <strk at keybit.net>
+2010-12-03 14:02 Sandro Santilli <strk at kbt.io>
* [r3156] include/geos/geom/CoordinateList.h: Update copyright
-2010-12-03 13:57 Sandro Santilli <strk at keybit.net>
+2010-12-03 13:57 Sandro Santilli <strk at kbt.io>
* [r3155] include/geos/geom/CoordinateList.h,
tests/unit/geom/CoordinateListTest.cpp: Add method to insert
coordinats into a CoordinateList w/out allowing duplicates (fixes
issue #387)
-2010-12-03 10:58 Sandro Santilli <strk at keybit.net>
+2010-12-03 10:58 Sandro Santilli <strk at kbt.io>
* [r3154]
Another test for snapping (empty sequence vs. non-empty snaps)
-2010-12-03 10:52 Sandro Santilli <strk at keybit.net>
+2010-12-03 10:52 Sandro Santilli <strk at kbt.io>
* [r3153] src/operation/overlay/snap/LineStringSnapper.cpp: update
dox
-2010-12-03 10:49 Sandro Santilli <strk at keybit.net>
+2010-12-03 10:49 Sandro Santilli <strk at kbt.io>
* [r3152] include/geos/operation/overlay/snap/LineStringSnapper.h,
src/operation/overlay/snap/LineStringSnapper.cpp: Take the
allowSnappingToSourceVertices support in
-2010-12-03 08:36 Sandro Santilli <strk at keybit.net>
+2010-12-03 08:36 Sandro Santilli <strk at kbt.io>
* [r3151] tests/unit/Makefile.am,
tests/unit/capi/GEOSSharedPathsTest.cpp: Add test for
GEOSSharedPaths C-API interface
-2010-12-02 18:06 Sandro Santilli <strk at keybit.net>
+2010-12-02 18:06 Sandro Santilli <strk at kbt.io>
* [r3150] tests/unit/capi/GEOSSnapTest.cpp: Another test, and a
leak plug (in the test)
-2010-12-02 16:49 Sandro Santilli <strk at keybit.net>
+2010-12-02 16:49 Sandro Santilli <strk at kbt.io>
* [r3149] NEWS: Add GEOSSnap item
-2010-12-02 16:48 Sandro Santilli <strk at keybit.net>
+2010-12-02 16:48 Sandro Santilli <strk at kbt.io>
* [r3148] php/geos.c, php/test/test.php: Expose GEOSSnap to PHP
interface
-2010-12-02 16:44 Sandro Santilli <strk at keybit.net>
+2010-12-02 16:44 Sandro Santilli <strk at kbt.io>
* [r3147] tests/unit/Makefile.am, tests/unit/capi/GEOSSnapTest.cpp:
Add test for C-API GEOSSnap interface
-2010-12-02 15:07 Sandro Santilli <strk at keybit.net>
+2010-12-02 15:07 Sandro Santilli <strk at kbt.io>
* [r3146] capi/geos_c.cpp, capi/geos_ts_c.cpp: OOps.. this one
build
-2010-12-02 14:52 Sandro Santilli <strk at keybit.net>
+2010-12-02 14:52 Sandro Santilli <strk at kbt.io>
* [r3145] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
Expose snapping to the C-API
-2010-12-02 14:29 Sandro Santilli <strk at keybit.net>
+2010-12-02 14:29 Sandro Santilli <strk at kbt.io>
* [r3144]
tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp: Allow
testing snapping something different from a single polygon..
-2010-12-02 14:16 Sandro Santilli <strk at keybit.net>
+2010-12-02 14:16 Sandro Santilli <strk at kbt.io>
* [r3143]
tests/unit/operation/overlay/snap/GeometrySnapperTest.cpp: tab to
8 spaces
-2010-12-02 10:32 Sandro Santilli <strk at keybit.net>
+2010-12-02 10:32 Sandro Santilli <strk at kbt.io>
* [r3142] include/geos/operation/overlay/snap/LineStringSnapper.h,
@@ -6079,107 +8075,107 @@
Bring LineStringSnapper forward to r309 (JTS-1.11+): avoid
snapping final point of closed rings.
-2010-12-02 09:38 Sandro Santilli <strk at keybit.net>
+2010-12-02 09:38 Sandro Santilli <strk at kbt.io>
* [r3141] include/geos/operation/overlay/snap/GeometrySnapper.h,
src/operation/overlay/snap/GeometrySnapper.cpp: update copyright
date
-2010-12-02 09:36 Sandro Santilli <strk at keybit.net>
+2010-12-02 09:36 Sandro Santilli <strk at kbt.io>
* [r3140] include/geos/operation/overlay/snap/GeometrySnapper.h,
src/operation/overlay/snap/GeometrySnapper.cpp: Take
GeometrySnapper forward to r309 (JTS-1.11+): add self-snapping
-2010-11-30 08:31 Sandro Santilli <strk at keybit.net>
+2010-11-30 08:31 Sandro Santilli <strk at kbt.io>
* [r3139] include/geos/operation/sharedpaths/SharedPathsOp.h,
src/operation/sharedpaths/SharedPathsOp.cpp: Hope this is the
last one... (RT credit tweaks)
-2010-11-29 13:45 Sandro Santilli <strk at keybit.net>
+2010-11-29 13:45 Sandro Santilli <strk at kbt.io>
* [r3138] include/geos/operation/sharedpaths/SharedPathsOp.h,
src/operation/sharedpaths/SharedPathsOp.cpp: Full credit line
[RT-SIGTA]
-2010-11-29 11:08 Sandro Santilli <strk at keybit.net>
+2010-11-29 11:08 Sandro Santilli <strk at kbt.io>
* [r3137] NEWS: SharedPaths in NEWS [RT-SIGTA]
-2010-11-29 10:51 Sandro Santilli <strk at keybit.net>
+2010-11-29 10:51 Sandro Santilli <strk at kbt.io>
* [r3136] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp,
php/geos.c, php/test/test.php: Merge branch 'rt'
-2010-11-29 09:43 Sandro Santilli <strk at keybit.net>
+2010-11-29 09:43 Sandro Santilli <strk at kbt.io>
* [r3135] NEWS, include/geos/operation/sharedpaths/SharedPathsOp.h,
src/operation/sharedpaths/SharedPathsOp.cpp: Write RT credit and
NEWS itam
-2010-11-29 09:34 Sandro Santilli <strk at keybit.net>
+2010-11-29 09:34 Sandro Santilli <strk at kbt.io>
* [r3134] src/operation/sharedpaths/SharedPathsOp.cpp: drop unused
include
* [r3133] src/operation/sharedpaths/SharedPathsOp.cpp,
tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp: Test
equal lines
* [r3132] include/geos/operation/sharedpaths/SharedPathsOp.h,
tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp: Have
SharedPathsOp throw an exception on illegal (non-lineal) arg
* [r3131] tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp:
Add tests for multiline-multiline both single dir and mixed dirs
* [r3130] tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp:
Add two tests of mixed direction shared paths
* [r3129] include/geos/operation/sharedpaths/SharedPathsOp.h:
Document that the direction of the returned paths is the one
these paths have on the first geometry given
-2010-11-29 09:33 Sandro Santilli <strk at keybit.net>
+2010-11-29 09:33 Sandro Santilli <strk at kbt.io>
* [r3128] tests/unit/Makefile.am, tests/unit/operation/sharedpaths,
tests/unit/operation/sharedpaths/SharedPathsOpTest.cpp: Initial
tests for SharedPathsOp
* [r3127] include/geos/operation/sharedpaths/SharedPathsOp.h,
src/operation/sharedpaths/SharedPathsOp.cpp: Paths are always
LINESTRING types
* [r3126] .gitignore: forgot aclocal.m4
* [r3125] .vimrc,
src/operation/sharedpaths/SharedPathsOp.cpp: Complete
implementation of SharedPathsOp
* [r3124] .gitignore: more ignores
* [r3123] configure.in, include/geos/operation/Makefile.am,
include/geos/operation/sharedpaths/Makefile.am,
@@ -6188,32 +8184,32 @@
src/operation/sharedpaths/SharedPathsOp.cpp: Build sharedpaths
lib/namespace
-2010-11-29 09:32 Sandro Santilli <strk at keybit.net>
+2010-11-29 09:32 Sandro Santilli <strk at kbt.io>
* [r3122] configure.in: Add support for 'maintainer mode'
* [r3121] .gitignore: ignores
* [r3120] include/geos/operation/sharedpaths,
src/operation/sharedpaths,
src/operation/sharedpaths/SharedPathsOp.cpp: Stub SharedPathsOp
* [r3119] tests/xmltester/tests/rt,
tests/xmltester/tests/rt/TestSameDirection.xml: stub tet for
SameDirection predicate
-2010-11-24 09:00 Sandro Santilli <strk at keybit.net>
+2010-11-24 09:00 Sandro Santilli <strk at kbt.io>
* [r3118] TODO: typo
-2010-10-25 15:12 Sandro Santilli <strk at keybit.net>
+2010-10-25 15:12 Sandro Santilli <strk at kbt.io>
* [r3117] configure.in: Don't try to configure missing files (fixes
bug #382)
@@ -6278,25 +8274,25 @@
* [r3105] autogen.bat: Updated GEOS_HEADERS location. Thanks to
Andrea Peri for reporting.
-2010-08-27 18:23 Sandro Santilli <strk at keybit.net>
+2010-08-27 18:23 Sandro Santilli <strk at kbt.io>
* [r3104] tests/xmltester/Makefile.am,
tests/xmltester/tests/bug358.xml: Add test for 358 in the loop
(now fixed).
-2010-08-27 15:58 Sandro Santilli <strk at keybit.net>
+2010-08-27 15:58 Sandro Santilli <strk at kbt.io>
* [r3103] tests/xmltester/tests/bug375.xml: Drop duplicated
testcase
-2010-08-27 15:55 Sandro Santilli <strk at keybit.net>
+2010-08-27 15:55 Sandro Santilli <strk at kbt.io>
* [r3102] include/geos/geom/BinaryOp.h,
tests/xmltester/Makefile.am: Check validity of CommonBitsOp
return, as JTS does. Check output validity for all tests, do not
run the now-throwing tests also known to be bogus in JTS.
-2010-08-27 15:43 Sandro Santilli <strk at keybit.net>
+2010-08-27 15:43 Sandro Santilli <strk at kbt.io>
* [r3101] tests/xmltester/Makefile.am,
tests/xmltester/tests/bug358.xml, tests/xmltester/tests/failure,
@@ -6307,12 +8303,12 @@
copied over the latter. Won't run that test for now, so to get in
sync with JTS as next step.
-2010-08-27 15:27 Sandro Santilli <strk at keybit.net>
+2010-08-27 15:27 Sandro Santilli <strk at kbt.io>
* [r3100] tests/xmltester/tests/bug375.xml: Add proper arg1 and
arg2 attributes (for JTS support)
-2010-08-27 14:13 Sandro Santilli <strk at keybit.net>
+2010-08-27 14:13 Sandro Santilli <strk at kbt.io>
* [r3099] include/geos/geom/BinaryOp.h: Add code to check validity
of CommonBits removal policy op (known as EnhancedPreicionOp in
@@ -6322,7 +8318,7 @@
before going on with this as to whether we can accept to return
invalid geometries or not..
-2010-08-27 13:53 Sandro Santilli <strk at keybit.net>
+2010-08-27 13:53 Sandro Santilli <strk at kbt.io>
* [r3098] tests/xmltester/Makefile.am,
tests/xmltester/testrunner.sh, tests/xmltester/tests/bug358.xml,
@@ -6338,27 +8334,27 @@
(to
review for correct expected otuput)
-2010-08-27 13:00 Sandro Santilli <strk at keybit.net>
+2010-08-27 13:00 Sandro Santilli <strk at kbt.io>
* [r3097] tests/xmltester/XMLTester.cpp,
tests/xmltester/XMLTester.h: Have --test-valid-output influence
test results
-2010-08-27 10:22 Sandro Santilli <strk at keybit.net>
+2010-08-27 10:22 Sandro Santilli <strk at kbt.io>
* [r3096] README: Add note about configuring for php support
-2010-08-27 09:04 Sandro Santilli <strk at keybit.net>
+2010-08-27 09:04 Sandro Santilli <strk at kbt.io>
* [r3095] tests/xmltester/XMLTester.cpp,
tests/xmltester/XMLTester.h: const-correctness
-2010-08-27 06:17 Sandro Santilli <strk at keybit.net>
+2010-08-27 06:17 Sandro Santilli <strk at kbt.io>
* [r3094] tests/xmltester/XMLTester.cpp: Have --test-valid-output
test actual result, not the expected one (more useful)
-2010-08-26 23:11 Sandro Santilli <strk at keybit.net>
+2010-08-26 23:11 Sandro Santilli <strk at kbt.io>
* [r3093] tests/xmltester/tests/bug334.xml,
tests/xmltester/tests/bug344.xml: Fix name of the test to match
@@ -6369,12 +8365,12 @@
* [r3092] src/operation/buffer/BufferBuilder.cpp: Fixed a filtering
distance problem in bufferLineSingleSided. (#372)
-2010-08-23 15:10 Sandro Santilli <strk at keybit.net>
+2010-08-23 15:10 Sandro Santilli <strk at kbt.io>
* [r3091] include/geos/geom/BinaryOp.h: Add more debugging calls
(for bug #358)
-2010-08-23 13:38 Sandro Santilli <strk at keybit.net>
+2010-08-23 13:38 Sandro Santilli <strk at kbt.io>
* [r3090] include/geos/geom/BinaryOp.h: Snapping heuristic was
never really dropping common bits. Now it does.
@@ -6402,45 +8398,45 @@
bufferLineSingleSided crash and fixed OGC validation on rare
cases. (#364)
-2010-07-15 15:54 Sandro Santilli <strk at keybit.net>
+2010-07-15 15:54 Sandro Santilli <strk at kbt.io>
* [r3086] php/TODO: Updated
-2010-07-15 09:15 Sandro Santilli <strk at keybit.net>
+2010-07-15 09:15 Sandro Santilli <strk at kbt.io>
* [r3085] NEWS: Add item about the new PHP5 binding
-2010-07-15 09:13 Sandro Santilli <strk at keybit.net>
+2010-07-15 09:13 Sandro Santilli <strk at kbt.io>
* [r3084] php/geos.c, php/test/test.php: PHP: Drop debug lines from
serialization code, add test for
serialization
-2010-07-15 09:07 Sandro Santilli <strk at keybit.net>
+2010-07-15 09:07 Sandro Santilli <strk at kbt.io>
* [r3083] configure.in: Fix logic bug in phpunit check
-2010-07-14 08:38 Sandro Santilli <strk at keybit.net>
+2010-07-14 08:38 Sandro Santilli <strk at kbt.io>
* [r3082] php/TODO, php/geos.c: Serialization/deserialization
support for GEOSGeometry type
-2010-07-13 11:03 Sandro Santilli <strk at keybit.net>
+2010-07-13 11:03 Sandro Santilli <strk at kbt.io>
* [r3081] configure.in, php/test/Makefile.am: Cleanup PHP-specific
dependency handling and reporting
-2010-07-08 20:54 Sandro Santilli <strk at keybit.net>
+2010-07-08 20:54 Sandro Santilli <strk at kbt.io>
* [r3080] src/geom/Polygon.cpp, tests/unit/io/WKTReaderTest.cpp:
Object passed for ownership transfer in the constructor shouldn't
be deleted when construction fails. Fixes bug #361
-2010-07-01 21:49 Sandro Santilli <strk at keybit.net>
+2010-07-01 21:49 Sandro Santilli <strk at kbt.io>
* [r3079] NEWS: Note the bugfix in news file
-2010-07-01 21:44 Sandro Santilli <strk at keybit.net>
+2010-07-01 21:44 Sandro Santilli <strk at kbt.io>
* [r3078] include/geos/operation/polygonize/EdgeRing.h,
include/geos/operation/polygonize/PolygonizeGraph.h,
@@ -6453,13 +8449,13 @@
reported in list. This commit also takes the chance to reduce
some heap allocations.
-2010-07-01 20:49 Sandro Santilli <strk at keybit.net>
+2010-07-01 20:49 Sandro Santilli <strk at kbt.io>
* [r3077] include/geos/operation/polygonize/EdgeRing.h,
src/operation/polygonize/EdgeRing.cpp: Minor optimizations /
strictnesses
-2010-07-01 20:03 Sandro Santilli <strk at keybit.net>
+2010-07-01 20:03 Sandro Santilli <strk at kbt.io>
* [r3076] include/geos/operation/polygonize/EdgeRing.h,
src/operation/polygonize/EdgeRing.cpp: Drop useless
@@ -6471,7 +8467,7 @@
tests/unit/capi/GEOSGeom_extractUniquePointsTest.cpp,
tests/unit/geom/PointTest.cpp: fix memory leaks
-2010-06-24 14:10 Sandro Santilli <strk at keybit.net>
+2010-06-24 14:10 Sandro Santilli <strk at kbt.io>
* [r3074] php/geos.c, php/test/test.php: PHP:
GEOSWKTWriter::getOutputDimension and test
@@ -6482,43 +8478,43 @@
tests/unit/capi/GEOSGeomToWKTTest.cpp: added
GEOSWKTWriter_getOutputDimension and test (#354)
-2010-06-24 09:42 Sandro Santilli <strk at keybit.net>
+2010-06-24 09:42 Sandro Santilli <strk at kbt.io>
* [r3072] php/TODO: Update
-2010-06-24 09:41 Sandro Santilli <strk at keybit.net>
+2010-06-24 09:41 Sandro Santilli <strk at kbt.io>
* [r3071] php/geos.c, php/test/test.php: WKBReader: construct and
readHEX; improve WKTReader test to include 'Z' label
-2010-06-24 09:20 Sandro Santilli <strk at keybit.net>
+2010-06-24 09:20 Sandro Santilli <strk at kbt.io>
* [r3070] php/geos.c, php/test/test.php:
WKBWriter::{set,get}IncludeSRID (and test)
-2010-06-24 09:07 Sandro Santilli <strk at keybit.net>
+2010-06-24 09:07 Sandro Santilli <strk at kbt.io>
* [r3069] php/geos.c, php/test/test.php:
WKBWriter::{get,set}ByteOrder, improve tests for writeHEX
-2010-06-24 09:01 Sandro Santilli <strk at keybit.net>
+2010-06-24 09:01 Sandro Santilli <strk at kbt.io>
* [r3068] capi/geos_ts_c.cpp, include/geos/io/WKBWriter.h,
src/io/WKBWriter.cpp: Make WKBWriter::setByteOrder check for
argument and throw IllegalArgumentException when appropriate.
Make sure C-API wrapper catches those.
-2010-06-24 08:28 Sandro Santilli <strk at keybit.net>
+2010-06-24 08:28 Sandro Santilli <strk at kbt.io>
* [r3067] php/geos.c, php/test/test.php: PHP: WKBWriter: ctor,
getOutputDimension, setOutputDimension, writeHEX and tests
-2010-06-24 08:27 Sandro Santilli <strk at keybit.net>
+2010-06-24 08:27 Sandro Santilli <strk at kbt.io>
* [r3066] capi/geos_ts_c.cpp: Properly catch exceptions from
WKTWriter::setOutputDimension and WKBWriter::setOutputDimension
* [r3065] include/geos/io/WKBWriter.h, include/geos/io/WKTWriter.h,
src/io/WKBWriter.cpp, src/io/WKTWriter.cpp: Make
@@ -6529,255 +8525,255 @@
WKTWriter class, which wasn't meant to be a virtual class (no
virtual dtor anyway)
-2010-06-23 09:48 Sandro Santilli <strk at keybit.net>
+2010-06-23 09:48 Sandro Santilli <strk at kbt.io>
* [r3064] NEWS: Log ABI change
-2010-06-23 09:47 Sandro Santilli <strk at keybit.net>
+2010-06-23 09:47 Sandro Santilli <strk at kbt.io>
* [r3063] include/geos/geom/Geometry.h, src/geom/Geometry.cpp:
Const-correct Geometry::isWithinDistance. Thanks to Yabo, see
ticket #349
-2010-06-23 09:31 Sandro Santilli <strk at keybit.net>
+2010-06-23 09:31 Sandro Santilli <strk at kbt.io>
* [r3062] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp,
php/geos.c: There's no point for GEOSisValidDetail to take output
parameter as const pointer
-2010-06-23 09:23 Sandro Santilli <strk at keybit.net>
+2010-06-23 09:23 Sandro Santilli <strk at kbt.io>
* [r3061] include/geos/operation/buffer/OffsetCurveVertexList.h,
src/geom/CoordinateArraySequence.cpp,
src/geom/GeometryFactory.cpp, src/io/WKTWriter.cpp: Fix for 4.4.3
builds, patch by Yabo (see ticket #351)
-2010-06-21 14:31 Sandro Santilli <strk at keybit.net>
+2010-06-21 14:31 Sandro Santilli <strk at kbt.io>
* [r3060] php/TODO, php/geos.c, src/geom/GeometryCollection.cpp,
src/geom/LineString.cpp, src/geom/Polygon.cpp: Switch back to
unchecked getGeometryN, getPointN and getInteriorRingN, check
them at the PHP level, for performance sake in C-land.
-2010-06-21 10:30 Sandro Santilli <strk at keybit.net>
+2010-06-21 10:30 Sandro Santilli <strk at kbt.io>
* [r3059] php/TODO, php/geos.c, php/test/test.php: Rename
getGeometryN to geometryN, for interface consistency
-2010-06-21 10:21 Sandro Santilli <strk at keybit.net>
+2010-06-21 10:21 Sandro Santilli <strk at kbt.io>
* [r3058] php/TODO, php/geos.c, php/test/test.php: area, length,
distance, hausdorffDistance; fix leaks in pointN, startPoint and
endPoint
-2010-06-21 02:02 Sandro Santilli <strk at keybit.net>
+2010-06-21 02:02 Sandro Santilli <strk at kbt.io>
* [r3057] php/geos.c, php/test/test.php: startPoint, endPoint
-2010-06-21 01:58 Sandro Santilli <strk at keybit.net>
+2010-06-21 01:58 Sandro Santilli <strk at kbt.io>
* [r3056] php/geos.c, php/test/test.php: pointN
-2010-06-21 01:57 Sandro Santilli <strk at keybit.net>
+2010-06-21 01:57 Sandro Santilli <strk at kbt.io>
* [r3055] src/geom/LineString.cpp: LineString::getPointN is part of
the API, check before segfaulting..
-2010-06-21 01:49 Sandro Santilli <strk at keybit.net>
+2010-06-21 01:49 Sandro Santilli <strk at kbt.io>
* [r3054] php/geos.c, php/test/test.php: coordinateDimension()
-2010-06-21 01:46 Sandro Santilli <strk at keybit.net>
+2010-06-21 01:46 Sandro Santilli <strk at kbt.io>
* [r3053] php/TODO, php/geos.c, php/test/test.php: dimension() [
spatial ]
-2010-06-21 01:43 Sandro Santilli <strk at keybit.net>
+2010-06-21 01:43 Sandro Santilli <strk at kbt.io>
* [r3052] php/geos.c, php/test/test.php: numCoordinates
-2010-06-21 01:39 Sandro Santilli <strk at keybit.net>
+2010-06-21 01:39 Sandro Santilli <strk at kbt.io>
* [r3051] php/geos.c, php/test/test.php: exteriorRing
-2010-06-21 01:36 Sandro Santilli <strk at keybit.net>
+2010-06-21 01:36 Sandro Santilli <strk at kbt.io>
* [r3050] php/TODO, php/geos.c, php/test/test.php: numPoints, getX,
getY, interiorRingN
-2010-06-21 01:34 Sandro Santilli <strk at keybit.net>
+2010-06-21 01:34 Sandro Santilli <strk at kbt.io>
* [r3049] src/geom/Polygon.cpp: Make getInteriorRingN checked (API)
-2010-06-21 01:05 Sandro Santilli <strk at keybit.net>
+2010-06-21 01:05 Sandro Santilli <strk at kbt.io>
* [r3048] php/geos.c, php/test/test.php: numInteriorRings
-2010-06-21 00:56 Sandro Santilli <strk at keybit.net>
+2010-06-21 00:56 Sandro Santilli <strk at kbt.io>
* [r3047] php/test/test.php: Test null-return from unexistent
offset
-2010-06-21 00:53 Sandro Santilli <strk at keybit.net>
+2010-06-21 00:53 Sandro Santilli <strk at kbt.io>
* [r3046] src/geom/GeometryCollection.cpp: Geometry::getGeometryN
is an API function, so make it safe/checked
-2010-06-21 00:44 Sandro Santilli <strk at keybit.net>
+2010-06-21 00:44 Sandro Santilli <strk at kbt.io>
* [r3045] php/geos.c, php/test/test.php: getGeometryN
-2010-06-21 00:06 Sandro Santilli <strk at keybit.net>
+2010-06-21 00:06 Sandro Santilli <strk at kbt.io>
* [r3044] php/test/test.php: Test numGeometries
-2010-06-21 00:01 Sandro Santilli <strk at keybit.net>
+2010-06-21 00:01 Sandro Santilli <strk at kbt.io>
* [r3043] php/geos.c, php/test/test.php: getSRID, setSRID
-2010-06-20 23:53 Sandro Santilli <strk at keybit.net>
+2010-06-20 23:53 Sandro Santilli <strk at kbt.io>
* [r3042] php/geos.c, php/test/test.php: typeName, typeId
-2010-06-20 23:40 Sandro Santilli <strk at keybit.net>
+2010-06-20 23:40 Sandro Santilli <strk at kbt.io>
* [r3041] php/geos.c, php/test/test.php: Geometry type constants
-2010-06-20 23:35 Sandro Santilli <strk at keybit.net>
+2010-06-20 23:35 Sandro Santilli <strk at kbt.io>
* [r3040] php/geos.c, php/test/test.php: isSimple, isRing, hasZ,
isClosed
-2010-06-20 22:59 Sandro Santilli <strk at keybit.net>
+2010-06-20 22:59 Sandro Santilli <strk at kbt.io>
* [r3039] php/geos.c, php/test/test.php: checkValidity (isValid in
disguise)
-2010-06-20 21:10 Sandro Santilli <strk at keybit.net>
+2010-06-20 21:10 Sandro Santilli <strk at kbt.io>
* [r3038] php/TODO, php/geos.c, php/test/test.php: isEmpty
-2010-06-20 21:00 Sandro Santilli <strk at keybit.net>
+2010-06-20 21:00 Sandro Santilli <strk at kbt.io>
* [r3037] php/geos.c, php/test/test.php: Relational operators +
equalsExact
-2010-06-20 19:05 Sandro Santilli <strk at keybit.net>
+2010-06-20 19:05 Sandro Santilli <strk at kbt.io>
* [r3036] php/geos.c, php/test/test.php: Simplify (also
topology-preserving), ExtractUniquePoints
-2010-06-20 17:00 Sandro Santilli <strk at keybit.net>
+2010-06-20 17:00 Sandro Santilli <strk at kbt.io>
* [r3035] php/geos.c, php/test/Makefile.am, php/test/test.php:
GEOSLineMerge
-2010-06-20 09:13 Sandro Santilli <strk at keybit.net>
+2010-06-20 09:13 Sandro Santilli <strk at kbt.io>
* [r3034] php/geos.c, php/test/test.php: Make GEOSPolygonize a free
function rather than a method on GEOSGeometry. This is to allow
extending it to accept differnet kind of args, like arrays of
GEOSGeometry for example..
-2010-06-20 09:02 Sandro Santilli <strk at keybit.net>
+2010-06-20 09:02 Sandro Santilli <strk at kbt.io>
* [r3033] php/TODO: Add serialize/unserialize TODO item
-2010-06-20 08:50 Sandro Santilli <strk at keybit.net>
+2010-06-20 08:50 Sandro Santilli <strk at kbt.io>
* [r3032] php/TODO, php/geos.c: Geometry.__toString for easier
debuggin
-2010-06-20 08:32 Sandro Santilli <strk at keybit.net>
+2010-06-20 08:32 Sandro Santilli <strk at kbt.io>
* [r3031] php/TODO, php/geos.c, php/test/test.php: Polygonize
(testing need further review for a possible bug in core lib)
-2010-06-19 21:38 Sandro Santilli <strk at keybit.net>
+2010-06-19 21:38 Sandro Santilli <strk at kbt.io>
* [r3030] php/test/test.php: Use the "T" char for IM9 pattern
sometime (for fun and proof)
-2010-06-19 21:36 Sandro Santilli <strk at keybit.net>
+2010-06-19 21:36 Sandro Santilli <strk at kbt.io>
* [r3029] php/geos.c, php/test/test.php: relate, relatePattern
-2010-06-19 18:27 Sandro Santilli <strk at keybit.net>
+2010-06-19 18:27 Sandro Santilli <strk at kbt.io>
* [r3028] php/geos.c, php/test/test.php:
Geometry->{pointOnSurface,centroid}
-2010-06-19 18:13 Sandro Santilli <strk at keybit.net>
+2010-06-19 18:13 Sandro Santilli <strk at kbt.io>
* [r3027] php/geos.c, php/test/test.php: More Geometry methods:
envelope, intersection, convexHull, difference, symDifference,
boundary, union (including cascaded)
-2010-06-19 17:14 Sandro Santilli <strk at keybit.net>
+2010-06-19 17:14 Sandro Santilli <strk at kbt.io>
* [r3026] php/geos.c, php/test/test.php: Export buffer costants and
method
-2010-06-19 13:27 Sandro Santilli <strk at keybit.net>
+2010-06-19 13:27 Sandro Santilli <strk at kbt.io>
* [r3025] php/test/test.php: Test typed empty geoms too for IO
-2010-06-19 13:17 Sandro Santilli <strk at keybit.net>
+2010-06-19 13:17 Sandro Santilli <strk at kbt.io>
* [r3024] php/geos.c, php/test/test.php: Add second optional
argument to Geometry->project and Geometry->interpolate to
request normalization
-2010-06-19 13:08 Sandro Santilli <strk at keybit.net>
+2010-06-19 13:08 Sandro Santilli <strk at kbt.io>
* [r3023] capi/geos_c.h.in: Document GEOSInterpolate
-2010-06-19 13:06 Sandro Santilli <strk at keybit.net>
+2010-06-19 13:06 Sandro Santilli <strk at kbt.io>
* [r3022] php/geos.c, php/test/test.php: Add
GEOSGeometry->interpolate()
-2010-06-19 12:42 Sandro Santilli <strk at keybit.net>
+2010-06-19 12:42 Sandro Santilli <strk at kbt.io>
* [r3021] capi/geos_ts_c.cpp: Handle exceptions in GEOSInterpolate
-2010-06-19 12:30 Sandro Santilli <strk at keybit.net>
+2010-06-19 12:30 Sandro Santilli <strk at kbt.io>
* [r3020] php/test/Makefile.am: Better automake integration of unit
test
-2010-06-19 12:28 Sandro Santilli <strk at keybit.net>
+2010-06-19 12:28 Sandro Santilli <strk at kbt.io>
* [r3019] src/linearref/LinearLocation.cpp: Handle illegal argument
to LinearLocation::getCoordinate
-2010-06-19 12:20 Sandro Santilli <strk at keybit.net>
+2010-06-19 12:20 Sandro Santilli <strk at kbt.io>
* [r3018] capi/geos_c.h.in: document GEOSProject
-2010-06-19 11:34 Sandro Santilli <strk at keybit.net>
+2010-06-19 11:34 Sandro Santilli <strk at kbt.io>
* [r3017] php/TODO, php/geos.c, php/test/Makefile.am,
php/test/test.php: Complete implementation of WKTWriter
interfaces, add phpunit-based testing, add .project interface to
Geometry
-2010-06-19 11:32 Sandro Santilli <strk at keybit.net>
+2010-06-19 11:32 Sandro Santilli <strk at kbt.io>
* [r3016] configure.in: Check for PHP and PHPUNIT (for testing php
bindings)
-2010-06-19 11:25 Sandro Santilli <strk at keybit.net>
+2010-06-19 11:25 Sandro Santilli <strk at kbt.io>
* [r3015] capi/geos_ts_c.cpp: Handle exceptions from
LenghtIndexedLine::project
-2010-06-19 11:23 Sandro Santilli <strk at keybit.net>
+2010-06-19 11:23 Sandro Santilli <strk at kbt.io>
* [r3014] src/linearref/LinearIterator.cpp: The thrown error shall
make sense...
-2010-06-19 11:16 Sandro Santilli <strk at keybit.net>
+2010-06-19 11:16 Sandro Santilli <strk at kbt.io>
* [r3013] src/linearref/LinearIterator.cpp: Throw an exception on
first non-linestring component, rather than segfaulting la
@@ -6785,67 +8781,67 @@
this way we *migh
* be supporting collections with only linestrings)
-2010-06-19 11:14 Sandro Santilli <strk at keybit.net>
+2010-06-19 11:14 Sandro Santilli <strk at kbt.io>
* [r3012] include/geos/linearref/LengthIndexOfPoint.h,
include/geos/linearref/LinearIterator.h: Dox cleanup
-2010-06-18 16:15 Sandro Santilli <strk at keybit.net>
+2010-06-18 16:15 Sandro Santilli <strk at kbt.io>
* [r3011] php/geos.c, php/test/test.php: WKTWriter::setTrim
-2010-06-18 16:12 Sandro Santilli <strk at keybit.net>
+2010-06-18 16:12 Sandro Santilli <strk at kbt.io>
* [r3010] php/Makefile.am: Ubuntu 8.10 version of gcc needs
-std=gnu99 to digest Zend headers :(
-2010-06-18 15:09 Sandro Santilli <strk at keybit.net>
+2010-06-18 15:09 Sandro Santilli <strk at kbt.io>
* [r3009] Makefile.am, doc/Makefile.am: Add 'doxygen' rule (and
'apidoc' alias) to top-level Makefile.am
-2010-06-18 14:43 Sandro Santilli <strk at keybit.net>
+2010-06-18 14:43 Sandro Santilli <strk at kbt.io>
* [r3008] php/TODO: tip for test
-2010-06-18 14:20 Sandro Santilli <strk at keybit.net>
+2010-06-18 14:20 Sandro Santilli <strk at kbt.io>
* [r3007] Makefile.am, configure.in, php, php/Makefile.am,
php/README, php/TODO, php/geos.c, php/php_geos.h, php/test,
php/test/Makefile.am, php/test/crashme.php, php/test/test.php:
Initial go at PHP5 bindings. Can only read and write WKT so far.
-2010-06-18 10:29 Sandro Santilli <strk at keybit.net>
+2010-06-18 10:29 Sandro Santilli <strk at kbt.io>
* [r3006] configure.in: Do not set user FLAGS, se project flags
instead.
For the whole story, see:
http://www.gnu.org/software/hello/manual/automake/Flag-Variables-Ordering.html
-2010-06-18 09:57 Sandro Santilli <strk at keybit.net>
+2010-06-18 09:57 Sandro Santilli <strk at kbt.io>
* [r3005] doc/Makefile.am: Fix automake override
-2010-06-18 09:52 Sandro Santilli <strk at keybit.net>
+2010-06-18 09:52 Sandro Santilli <strk at kbt.io>
* [r3004] autogen.sh: Add -Woverride option to automake invocation,
to catch Makefile.am errors (there's one)
-2010-06-16 10:39 Sandro Santilli <strk at keybit.net>
+2010-06-16 10:39 Sandro Santilli <strk at kbt.io>
* [r3003] swig/geos.i.in: Drop carriage returns
-2010-06-16 09:45 Sandro Santilli <strk at keybit.net>
+2010-06-16 09:45 Sandro Santilli <strk at kbt.io>
* [r3002] swig/Makefile.am: OOps, tabs instead of spaces confuse
automake
-2010-06-16 09:31 Sandro Santilli <strk at keybit.net>
+2010-06-16 09:31 Sandro Santilli <strk at kbt.io>
* [r3001] swig/Makefile.am: Always distribute swig bindings, closes
bug #352
-2010-06-16 09:25 Sandro Santilli <strk at keybit.net>
+2010-06-16 09:25 Sandro Santilli <strk at kbt.io>
* [r3000] macros/ac_pkg_swig.m4: Fix swig macro so it doesn't think
version 2.0.0 is < 1.3.37
@@ -6939,11 +8935,11 @@
tests/unit/noding/NodedSegmentStringTest.cpp: preserve dimension
as part of CoordinateArraySequence and while reading WKT (#345)
-2010-05-15 12:47 Sandro Santilli <strk at keybit.net>
+2010-05-15 12:47 Sandro Santilli <strk at kbt.io>
* [r2989] src/operation/buffer/OffsetCurveBuilder.cpp: Minor tweaks
-2010-05-15 12:31 Sandro Santilli <strk at keybit.net>
+2010-05-15 12:31 Sandro Santilli <strk at kbt.io>
* [r2988] include/geos/operation/buffer/Makefile.am,
@@ -6955,18 +8951,18 @@
headers dir, add a .reset() method to reduce memory allocations,
use the new interface.
-2010-05-15 12:30 Sandro Santilli <strk at keybit.net>
+2010-05-15 12:30 Sandro Santilli <strk at kbt.io>
* [r2987] include/geos/geom/CoordinateArraySequence.h,
src/geom/CoordinateArraySequence.cpp: Add clear() method to
CoordinateArraySequence, inline empty()
-2010-05-04 21:29 Sandro Santilli <strk at keybit.net>
+2010-05-04 21:29 Sandro Santilli <strk at kbt.io>
* [r2986] README: Add 'ldconfig' step, seems to be a recurring
issue with builders...
-2010-05-02 09:35 Sandro Santilli <strk at keybit.net>
+2010-05-02 09:35 Sandro Santilli <strk at kbt.io>
* [r2985] capi/geos_c.h.in: Add a note about 2d nature of
extractUniquePoints
@@ -6976,19 +8972,19 @@
* [r2982] nmake.opt: * Updated nmake.opt with NMake version from
Visual Studio 2010 release.
-2010-04-17 22:16 Sandro Santilli <strk at keybit.net>
+2010-04-17 22:16 Sandro Santilli <strk at kbt.io>
* [r2977] HOWTO_RELEASE, capi/geos_c.h.in: Also set version for the
systems not using autoconf, and update paths in HOWTO_RELEASE
file
-2010-04-17 22:14 Sandro Santilli <strk at keybit.net>
+2010-04-17 22:14 Sandro Santilli <strk at kbt.io>
* [r2976] configure.in: As we're still maintaining 3.2 branch, and
since new CAPI interface were added, bump CAPI lib interface
version up. We'll be 1.7.0 there from now on.
-2010-04-17 15:34 Sandro Santilli <strk at keybit.net>
+2010-04-17 15:34 Sandro Santilli <strk at kbt.io>
* [r2974] NEWS, capi/geos_c.cpp: Have initGEOS(..) return a
singleton, as used to be up to 3.0.0
@@ -7124,54 +9120,54 @@
* [r2948] nmake.opt: nmake.opt: Added missing GEOS_DLL_EXPORT to
CPPFLAGS (ported from branches/3.2)
-2010-03-19 15:13 Sandro Santilli <strk at keybit.net>
+2010-03-19 15:13 Sandro Santilli <strk at kbt.io>
* [r2946] NEWS, capi/geos_ts_c.cpp: Improve formatting for
GEOSisValidReason_r (#329)
-2010-03-18 18:39 Sandro Santilli <strk at keybit.net>
+2010-03-18 18:39 Sandro Santilli <strk at kbt.io>
* [r2944] include/geos/operation/valid/IsValidOp.h,
src/operation/valid/IsValidOp.cpp: Forw-port a better fix for
#333 (false positive valid geoms)
-2010-03-16 13:13 Sandro Santilli <strk at keybit.net>
+2010-03-16 13:13 Sandro Santilli <strk at kbt.io>
* [r2941] capi/geos_ts_c.cpp: Fix ST_IsValidDetail (broke by last
commit)
-2010-03-16 12:32 Sandro Santilli <strk at keybit.net>
+2010-03-16 12:32 Sandro Santilli <strk at kbt.io>
* [r2940] capi/geos_ts_c.cpp: Now that IsValidOp doesn't cache the
'checked' status it is better to trigger a single check rather
than two (also fix leaks)
-2010-03-14 10:13 Sandro Santilli <strk at keybit.net>
+2010-03-14 10:13 Sandro Santilli <strk at kbt.io>
* [r2939] include/geos/util/Makefile.am: Install Machine.h
-2010-03-13 22:07 Sandro Santilli <strk at keybit.net>
+2010-03-13 22:07 Sandro Santilli <strk at kbt.io>
* [r2938] capi/geos_ts_c.cpp,
tests/unit/capi/GEOSOrientationIndex.cpp: Fix
GEOSOrientationIndex implementation and testcase. Closes ticket
#335.
-2010-03-12 07:54 Sandro Santilli <strk at keybit.net>
+2010-03-12 07:54 Sandro Santilli <strk at kbt.io>
* [r2937] NEWS, capi/geos_c.cpp, capi/geos_c.h.in,
tests/unit/capi/GEOSOrientationIndex.cpp: Expose
GEOSOrientationIndex to C-API
-2010-03-10 09:34 Sandro Santilli <strk at keybit.net>
+2010-03-10 09:34 Sandro Santilli <strk at kbt.io>
* [r2936] include/geos/operation/valid/IsValidOp.h,
tests/xmltester/tests/general/TestValid.xml: Sync TestValid xml
from JTS, review IsValidOp to be in sync with current JTS trunk.
-2010-03-07 11:39 Sandro Santilli <strk at keybit.net>
+2010-03-07 11:39 Sandro Santilli <strk at kbt.io>
* [r2935] README: Apply slightly modified patch by mwtoews (#344)
@@ -7181,66 +9177,66 @@
cmake/cmake_uninstall.cmake.in script and configured make
uninstall target for CMake configuration (#317)
-2010-03-03 07:21 Sandro Santilli <strk at keybit.net>
+2010-03-03 07:21 Sandro Santilli <strk at kbt.io>
* [r2933] capi/geos_c.h.in: Improve documentation for
GEOSPOlygonize_full
-2010-03-02 21:04 Sandro Santilli <strk at keybit.net>
+2010-03-02 21:04 Sandro Santilli <strk at kbt.io>
* [r2932] NEWS, include/geos/operation/valid/IsValidOp.h,
tests/xmltester/tests/general/TestValid.xml: Fix false positive
return from IsValidOp (#333)
-2010-02-28 19:01 Sandro Santilli <strk at keybit.net>
+2010-02-28 19:01 Sandro Santilli <strk at kbt.io>
* [r2931] src/geom/LineString.cpp: Minor tweak
-2010-02-28 18:55 Sandro Santilli <strk at keybit.net>
+2010-02-28 18:55 Sandro Santilli <strk at kbt.io>
* [r2930] NEWS, capi/geos_c.cpp, capi/geos_c.h.in: Provide
non-rehentrant version of empty geometries constructors
-2010-02-28 17:02 Sandro Santilli <strk at keybit.net>
+2010-02-28 17:02 Sandro Santilli <strk at kbt.io>
* [r2929] NEWS: extractUniquePoints comes in non-reentrant version
too
-2010-02-25 07:50 Sandro Santilli <strk at keybit.net>
+2010-02-25 07:50 Sandro Santilli <strk at kbt.io>
* [r2928] NEWS: Update with GEOSPolygonize_full item
-2010-02-23 20:00 Sandro Santilli <strk at keybit.net>
+2010-02-23 20:00 Sandro Santilli <strk at kbt.io>
* [r2927] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
GEOSPolygonize_full [RT-SIGTA]
-2010-02-22 22:21 Sandro Santilli <strk at keybit.net>
+2010-02-22 22:21 Sandro Santilli <strk at kbt.io>
* [r2926] include/geos/operation/polygonize/Polygonizer.h,
src/operation/polygonize/Polygonizer.cpp: LineStringAdder
heap-allocation removal
-2010-02-22 22:17 Sandro Santilli <strk at keybit.net>
+2010-02-22 22:17 Sandro Santilli <strk at kbt.io>
* [r2925] NEWS, include/geos/operation/polygonize/Polygonizer.h,
src/operation/polygonize/Polygonizer.cpp: Drop heap allocation of
invalidRingLines vector
-2010-02-22 22:06 Sandro Santilli <strk at keybit.net>
+2010-02-22 22:06 Sandro Santilli <strk at kbt.io>
* [r2924] include/geos/operation/polygonize/Polygonizer.h,
src/operation/polygonize/Polygonizer.cpp: More heap allocations
bite the dust...
-2010-02-22 21:51 Sandro Santilli <strk at keybit.net>
+2010-02-22 21:51 Sandro Santilli <strk at kbt.io>
* [r2923] NEWS, include/geos/operation/polygonize/Polygonizer.h,
src/operation/polygonize/Polygonizer.cpp: Drop HEAP allocation
for dangles vector too, and document all these API changes
-2010-02-22 21:41 Sandro Santilli <strk at keybit.net>
+2010-02-22 21:41 Sandro Santilli <strk at kbt.io>
* [r2922] capi/geos_ts_c.cpp,
include/geos/operation/polygonize/PolygonizeEdge.h,
@@ -7248,7 +9244,7 @@
src/operation/polygonize/Polygonizer.cpp: Avoid heap allocation
of a vector for cut edges, bits of additional documentation
-2010-02-22 21:29 Sandro Santilli <strk at keybit.net>
+2010-02-22 21:29 Sandro Santilli <strk at kbt.io>
* [r2921] include/geos/operation/polygonize/Polygonizer.h: Try to
document current behaviour (very bad behaviour indeed...)
@@ -7258,18 +9254,18 @@
* [r2920] CMakeLists.txt: Another patch from Gavin Heavyside to
enable GEOS as a dependency of a project with CMake
-2010-02-21 17:05 Sandro Santilli <strk at keybit.net>
+2010-02-21 17:05 Sandro Santilli <strk at kbt.io>
* [r2919] NEWS, capi/geos_c.h.in, capi/geos_ts_c.cpp: Allow
GEOSGetGeometryN calls against single geometries
-2010-02-21 16:27 Sandro Santilli <strk at keybit.net>
+2010-02-21 16:27 Sandro Santilli <strk at kbt.io>
* [r2918] capi/geos_c.cpp, capi/geos_c.h.in: Expose the
non-reentrant version too (I know, I was against, but it's too
much work on the postgis side for that right now)
-2010-02-21 15:03 Sandro Santilli <strk at keybit.net>
+2010-02-21 15:03 Sandro Santilli <strk at kbt.io>
* [r2917] NEWS, capi/geos_c.h.in, capi/geos_ts_c.cpp,
@@ -7281,13 +9277,13 @@
* [r2916] CMakeLists.txt: Patch from Gavin Heavyside that enables
CMake to build GEOS as a dependency of user-defined project
-2010-02-17 14:04 Sandro Santilli <strk at keybit.net>
+2010-02-17 14:04 Sandro Santilli <strk at kbt.io>
* [r2915] src/geom/CoordinateArraySequence.cpp: Throw an
IllegalArgumentException when setOrdinate is called with unknown
ordinate index
-2010-02-14 14:01 Sandro Santilli <strk at keybit.net>
+2010-02-14 14:01 Sandro Santilli <strk at kbt.io>
* [r2913] NEWS: Add GEOSPolygonizer_getCutEdges NEWS item where it
belongs
@@ -7297,29 +9293,29 @@
* [r2912] capi/CMakeLists.txt: Fixed but in CMake configuration
which installed geos_c.h in incorrect location (#330)
-2010-02-11 18:15 Sandro Santilli <strk at keybit.net>
+2010-02-11 18:15 Sandro Santilli <strk at kbt.io>
* [r2911] NEWS: Update
-2010-02-11 08:33 Sandro Santilli <strk at keybit.net>
+2010-02-11 08:33 Sandro Santilli <strk at kbt.io>
* [r2910] capi/geos_c.h.in, capi/geos_ts_c.cpp,
tests/unit/capi/GEOSGeom_create.cpp: Complete set of typed-empty
constructors and tests for them [RT-SIGTA]
-2010-02-11 08:18 Sandro Santilli <strk at keybit.net>
+2010-02-11 08:18 Sandro Santilli <strk at kbt.io>
* [r2909] capi/geos_c.h.in, capi/geos_ts_c.cpp: Go for consistency
with reentrant interfaces [RT-SIGTA]
-2010-02-11 00:10 Sandro Santilli <strk at keybit.net>
+2010-02-11 00:10 Sandro Santilli <strk at kbt.io>
* [r2908] NEWS, capi/geos_c.h.in, capi/geos_ts_c.cpp,
tests/unit/Makefile.am, tests/unit/capi/GEOSGeom_create.cpp:
GEOSContext_setNoticeHandler, GEOSContext_setErrorHandler,
GEOSGeom_createEmptyPolygon_r (and test)
-2010-02-09 17:52 Sandro Santilli <strk at keybit.net>
+2010-02-09 17:52 Sandro Santilli <strk at kbt.io>
* [r2907] doc/Doxyfile.in: Fix to match new layout
@@ -7334,11 +9330,11 @@
* [r2905] CMakeLists.txt: Fixed CMake version comparison to disable
platform.h (#317)
-2010-02-05 14:54 Sandro Santilli <strk at keybit.net>
+2010-02-05 14:54 Sandro Santilli <strk at kbt.io>
* [r2904] capi/geos_c.h.in: Document ownership of created types
-2010-02-05 14:39 Sandro Santilli <strk at keybit.net>
+2010-02-05 14:39 Sandro Santilli <strk at kbt.io>
* [r2903] NEWS, capi/geos_c.cpp, capi/geos_c.h.in,
capi/geos_ts_c.cpp: New CAPI interface: GEOSisValidDetail ( tell
@@ -7880,11 +9876,11 @@
source/headers/geos/version.h.vc: Update version numbers on trunk
to 3.3 series
-2009-12-14 19:06 Sandro Santilli <strk at keybit.net>
+2009-12-14 19:06 Sandro Santilli <strk at kbt.io>
* [r2826] ChangeLog: Updated
-2009-12-14 18:58 Sandro Santilli <strk at keybit.net>
+2009-12-14 18:58 Sandro Santilli <strk at kbt.io>
* [r2825] source/headers/geos/geom.h: Don't mention 'troubles' in
documentation (some like it not)
@@ -7896,11 +9892,11 @@
dropping geometry tag in string representation of geometry
* Improved message carried by TopologyException
-2009-12-11 13:17 Sandro Santilli <strk at keybit.net>
+2009-12-11 13:17 Sandro Santilli <strk at kbt.io>
* [r2823] ChangeLog: Updated
-2009-12-11 13:10 Sandro Santilli <strk at keybit.net>
+2009-12-11 13:10 Sandro Santilli <strk at kbt.io>
* [r2822] source/geom/prep/BasicPreparedGeometry.cpp: Fix memory
leak in BasicPreparedGeometry::isAnyTargetComponentInTest (issue
@@ -7934,31 +9930,31 @@
* [r2815] build/msvc10/Makefile.am: build/msvc10: fixed list of
EXTRA_DIST files
-2009-12-08 17:51 Sandro Santilli <strk at keybit.net>
+2009-12-08 17:51 Sandro Santilli <strk at kbt.io>
* [r2814] tests/geostest/.deps/geostest.Po: This shouldn't be in
the repository !
-2009-12-08 17:50 Sandro Santilli <strk at keybit.net>
+2009-12-08 17:50 Sandro Santilli <strk at kbt.io>
* [r2813] source/algorithm/NonRobustLineIntersector.cpp,
source/algorithm/RobustLineIntersector.cpp: Remove
deprecated/unused files
-2009-12-08 17:42 Sandro Santilli <strk at keybit.net>
+2009-12-08 17:42 Sandro Santilli <strk at kbt.io>
* [r2812]
source/headers/geos/geom/prep/PreparedLineStringIntersects.h:
Drop useless (and leaking) heap allocation exposed by the new
prepared linestring intersection test
* [r2811] source/geom/prep/PreparedLineString.cpp,
source/headers/geos/geom/prep/PreparedLineString.h: Add missing
destructor of PreparedLineString (closes ticket #305)
-2009-12-08 17:39 Sandro Santilli <strk at keybit.net>
+2009-12-08 17:39 Sandro Santilli <strk at kbt.io>
* [r2810] tests/unit/capi/GEOSPreparedGeometryTest.cpp: Add test
with Prepared linestrings, for the sake of testing the leak
@@ -8560,16 +10556,16 @@
tests to Visual Studio 2008 project
* Replaced call to isnan() missing in Visual C++ with ISNAN macro
-2009-11-29 10:09 Sandro Santilli <strk at keybit.net>
+2009-11-29 10:09 Sandro Santilli <strk at kbt.io>
* [r2749] ChangeLog: updated
-2009-11-26 21:42 Sandro Santilli <strk at keybit.net>
+2009-11-26 21:42 Sandro Santilli <strk at kbt.io>
* [r2748] source/headers/geos/platform.h.in: Add ISNAN support in
platform.h.in
-2009-11-26 21:34 Sandro Santilli <strk at keybit.net>
+2009-11-26 21:34 Sandro Santilli <strk at kbt.io>
* [r2747] source/geom/util/LinearComponentExtracter.cpp,
source/geom/util/Makefile.am,
@@ -8581,12 +10577,12 @@
source/util/UnsupportedOperationException.cpp: Remove
unreferenced files from the repository
-2009-11-26 21:28 Sandro Santilli <strk at keybit.net>
+2009-11-26 21:28 Sandro Santilli <strk at kbt.io>
* [r2746] build/msvc90/geos_lib/geos_lib.vcproj: Remove reference
to files not needing to go in the dll
-2009-11-26 21:21 Sandro Santilli <strk at keybit.net>
+2009-11-26 21:21 Sandro Santilli <strk at kbt.io>
* [r2745] source/geom/CoordinateSequenceFactory.cpp,
source/geom/Makefile.am,
@@ -8615,21 +10611,21 @@
build/msvc90/geos_xmltester/Makefile.am: Fix missing components
in tarball (#300)
-2009-11-24 18:05 Sandro Santilli <strk at keybit.net>
+2009-11-24 18:05 Sandro Santilli <strk at kbt.io>
* [r2736] ChangeLog: updated
-2009-11-23 18:17 Sandro Santilli <strk at keybit.net>
+2009-11-23 18:17 Sandro Santilli <strk at kbt.io>
* [r2735] tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp:
Coordiante->Coordinate
-2009-11-23 18:06 Sandro Santilli <strk at keybit.net>
+2009-11-23 18:06 Sandro Santilli <strk at kbt.io>
* [r2734] source/geom/Geometry.cpp: Avoid reallocations in Union
short-circuit
-2009-11-20 19:58 Sandro Santilli <strk at keybit.net>
+2009-11-20 19:58 Sandro Santilli <strk at kbt.io>
* [r2733] source/headers/geos/planargraph/NodeMap.h,
source/headers/geos/planargraph/PlanarGraph.h,
@@ -8638,14 +10634,14 @@
source/planargraph/NodeMap.cpp: Don't force heap allocation of
vectors for getting nodes of a NodeMap
-2009-11-19 21:30 Sandro Santilli <strk at keybit.net>
+2009-11-19 21:30 Sandro Santilli <strk at kbt.io>
* [r2732]
source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h,
source/noding/MCIndexSegmentSetMutualIntersector.cpp: Don't
heap-allocate std::vector in MCIndexSegmentSetMutualIntersector
-2009-11-19 21:06 Sandro Santilli <strk at keybit.net>
+2009-11-19 21:06 Sandro Santilli <strk at kbt.io>
* [r2731] source/headers/geos/operation/overlay/MaximalEdgeRing.h,
source/headers/geos/operation/valid/ConnectedInteriorTester.h,
@@ -8653,7 +10649,7 @@
source/operation/valid/ConnectedInteriorTester.cpp: Don't force
heap allocation when building edge rings for isValidOp
-2009-11-19 20:29 Sandro Santilli <strk at keybit.net>
+2009-11-19 20:29 Sandro Santilli <strk at kbt.io>
* [r2730]
source/headers/geos/operation/polygonize/PolygonizeGraph.h,
@@ -8663,14 +10659,14 @@
dangles (moved allocation higher, in Polygonizer, so needs a
second pass)
-2009-11-19 20:20 Sandro Santilli <strk at keybit.net>
+2009-11-19 20:20 Sandro Santilli <strk at kbt.io>
* [r2729]
source/operation/polygonize/PolygonizeGraph.cpp: don't
heap-allocate vectors in findLabeledEdgeRings
-2009-11-19 19:57 Sandro Santilli <strk at keybit.net>
+2009-11-19 19:57 Sandro Santilli <strk at kbt.io>
* [r2728]
@@ -8680,14 +10676,14 @@
of vector used for 'cut-lines' containment out of PolygonizeGraph
(but into Polygonizer)
-2009-11-19 19:31 Sandro Santilli <strk at keybit.net>
+2009-11-19 19:31 Sandro Santilli <strk at kbt.io>
* [r2727]
source/operation/polygonize/PolygonizeGraph.cpp: Don't force
heap-allocation of vectors for finding/labeling edge rings
-2009-11-19 19:19 Sandro Santilli <strk at keybit.net>
+2009-11-19 19:19 Sandro Santilli <strk at kbt.io>
* [r2726]
@@ -8697,14 +10693,14 @@
PolygonizeGraph::getEdgeRings signature so not to force heap
allocation of std::vector, update Polygonizer accordingly
-2009-11-19 19:06 Sandro Santilli <strk at keybit.net>
+2009-11-19 19:06 Sandro Santilli <strk at kbt.io>
* [r2725]
source/operation/polygonize/PolygonizeGraph.cpp: Do not
heap-allocate vector of Node when finding intersections
-2009-11-19 18:52 Sandro Santilli <strk at keybit.net>
+2009-11-19 18:52 Sandro Santilli <strk at kbt.io>
* [r2724] source/headers/geos/index/strtree/AbstractNode.h,
source/index/strtree/AbstractNode.cpp: Don not allocate the
@@ -8728,23 +10724,23 @@
warning thrown by Visual C++ about mixed class and struct keyword
(#269)
-2009-11-17 20:29 Sandro Santilli <strk at keybit.net>
+2009-11-17 20:29 Sandro Santilli <strk at kbt.io>
* [r2716] tests/unit/Makefile.am: Include capi::GEOSGeomFromWKB
test in geos_unit build (should also distribute as side-effect)
-2009-11-11 23:05 Sandro Santilli <strk at keybit.net>
+2009-11-11 23:05 Sandro Santilli <strk at kbt.io>
* [r2713] HOWTO_RELEASE, Makefile.am: Change ChangeLog generation
rule so it doesn't mess with make dist. Reflect in HOW_TO_RELEASE
-2009-11-10 23:54 Sandro Santilli <strk at keybit.net>
+2009-11-10 23:54 Sandro Santilli <strk at kbt.io>
* [r2712] HOWTO_RELEASE, Makefile.am: Make ChangeLog target
non-phony to keep 'distcheck' happy. Reorganize HOW_TO_RELEASE
steps.
-2009-11-10 22:58 Sandro Santilli <strk at keybit.net>
+2009-11-10 22:58 Sandro Santilli <strk at kbt.io>
* [r2711] ChangeLog, HOWTO_RELEASE, NEWS: Package stuff for release
@@ -8810,37 +10806,37 @@
* [r2701] ChangeLog, source/headers/geos/geom/Geometry.h: Fixed
typo in getCentroid function comment in Geometry.h.
-2009-10-23 13:04 Sandro Santilli <strk at keybit.net>
+2009-10-23 13:04 Sandro Santilli <strk at kbt.io>
* [r2700] source/headers/geos/linearref/LinearLocation.h,
source/linearref/LinearLocation.cpp: Have
LinearLocation::getSegment return by auto_ptr to encode ownership
transfer. Fixes leak reported in #296.
-2009-10-23 12:58 Sandro Santilli <strk at keybit.net>
+2009-10-23 12:58 Sandro Santilli <strk at kbt.io>
* [r2699] source/headers/geos/linearref/LinearLocation.h,
source/linearref/LinearLocation.cpp: Fix port info, add standard
protection notes
-2009-10-23 10:21 Sandro Santilli <strk at keybit.net>
+2009-10-23 10:21 Sandro Santilli <strk at kbt.io>
* [r2698] source/headers/geos/linearref/LinearGeometryBuilder.h,
source/linearref/LinearGeometryBuilder.cpp: Add destructor to
LinearGeometryBuilder fixing memory leaks there.
-2009-10-23 10:13 Sandro Santilli <strk at keybit.net>
+2009-10-23 10:13 Sandro Santilli <strk at kbt.io>
* [r2697] source/linearref/LinearGeometryBuilder.cpp: Fix memory
access error (#283)
-2009-10-23 10:03 Sandro Santilli <strk at keybit.net>
+2009-10-23 10:03 Sandro Santilli <strk at kbt.io>
* [r2696] source/headers/geos/linearref/LinearGeometryBuilder.h,
source/linearref/LinearGeometryBuilder.cpp: Fix port info for
-2009-10-23 09:53 Sandro Santilli <strk at keybit.net>
+2009-10-23 09:53 Sandro Santilli <strk at kbt.io>
* [r2695] source/headers/geos/linearref/LinearGeometryBuilder.h,
source/linearref/LinearGeometryBuilder.cpp: Cleanup
@@ -8848,7 +10844,7 @@
add note about suspicious things (not written but noted that the
class seems to lack a destructor..)
-2009-10-23 09:43 Sandro Santilli <strk at keybit.net>
+2009-10-23 09:43 Sandro Santilli <strk at kbt.io>
* [r2694] source/headers/geos/linearref/LocationIndexOfLine.h,
source/linearref/LengthIndexedLine.cpp,
@@ -8857,51 +10853,51 @@
ownership of return from LocationIndexOfLine::indicesOf, fix
mismatch delete/delete[] in core and unit test
-2009-10-23 09:34 Sandro Santilli <strk at keybit.net>
+2009-10-23 09:34 Sandro Santilli <strk at kbt.io>
* [r2693] source/headers/geos/algorithm/BoundaryNodeRule.h: Add
virtual dtor to virtual class
-2009-10-23 09:33 Sandro Santilli <strk at keybit.net>
+2009-10-23 09:33 Sandro Santilli <strk at kbt.io>
* [r2692] tests/xmltester/tinyxml/tinyxmlparser.cpp: add some
parens to hush gcc warning
-2009-10-23 09:00 Sandro Santilli <strk at keybit.net>
+2009-10-23 09:00 Sandro Santilli <strk at kbt.io>
* [r2691] tests/unit/Makefile.am: Fix static building of C-api
demo/tests
-2009-10-23 08:34 Sandro Santilli <strk at keybit.net>
+2009-10-23 08:34 Sandro Santilli <strk at kbt.io>
* [r2690] tests/xmltester/Makefile.am: Run the last
available-but-no-automatically-run test: test.xml
-2009-10-22 18:18 Sandro Santilli <strk at keybit.net>
+2009-10-22 18:18 Sandro Santilli <strk at kbt.io>
* [r2689] tests/xmltester/tests/buffer.xml,
tests/xmltester/tests/buffer_snapround.xml: Merge
buffer_snapround.xml into buffer.xml
-2009-10-22 17:13 Sandro Santilli <strk at keybit.net>
+2009-10-22 17:13 Sandro Santilli <strk at kbt.io>
* [r2688] tests/xmltester/Makefile.am: A quick check reveals that
the tests in buffer.xml are not really duplicated elsewhere so we
run that test too now as part of make check
-2009-10-22 17:07 Sandro Santilli <strk at keybit.net>
+2009-10-22 17:07 Sandro Santilli <strk at kbt.io>
* [r2687] tests/xmltester/tests/buffer.xml: Give buffer.xml cases a
somewhat more helpful description, fix 4 expected results after
eye-checking. This is still not automatically run case it might
contain duplicated tests from elsewhere (to be checked).
-2009-10-22 16:30 Sandro Santilli <strk at keybit.net>
+2009-10-22 16:30 Sandro Santilli <strk at kbt.io>
* [r2686] tests/xmltester/XMLTester.cpp: Don't segfault on EOF
inside <op> tag
-2009-10-20 16:59 Sandro Santilli <strk at keybit.net>
+2009-10-20 16:59 Sandro Santilli <strk at kbt.io>
* [r2685] source/headers/geos/index/strtree/AbstractSTRtree.h,
source/index/strtree/STRtree.cpp: Commit MingW bug workaround
@@ -8915,33 +10911,33 @@
tests/xmltester/tests/buffer_snapround.xml: not well-formed XML,
fixed missing attribute.
-2009-10-17 14:47 Sandro Santilli <strk at keybit.net>
+2009-10-17 14:47 Sandro Santilli <strk at kbt.io>
* [r2683] ChangeLog: updated
-2009-10-17 14:43 Sandro Santilli <strk at keybit.net>
+2009-10-17 14:43 Sandro Santilli <strk at kbt.io>
* [r2682] NEWS: updated
-2009-10-17 14:35 Sandro Santilli <strk at keybit.net>
+2009-10-17 14:35 Sandro Santilli <strk at kbt.io>
* [r2681] source/algorithm/distance/DistanceToPoint.cpp: Half the
calls to the virtual CoordinateSequence::getAt when computing
line distances
-2009-10-17 13:40 Sandro Santilli <strk at keybit.net>
+2009-10-17 13:40 Sandro Santilli <strk at kbt.io>
* [r2680] source/geom/CoordinateArraySequence.cpp: Drop pointless
asserts. We'd abort anyway if vector is null. For the
out-of-range case the GNU c++ lib helps debugging with an
environment variable
-2009-10-17 13:04 Sandro Santilli <strk at keybit.net>
+2009-10-17 13:04 Sandro Santilli <strk at kbt.io>
* [r2679] source/noding/OrientedCoordinateArray.cpp: Add note of
private/static nature of implemented methods
-2009-10-17 12:28 Sandro Santilli <strk at keybit.net>
+2009-10-17 12:28 Sandro Santilli <strk at kbt.io>
* [r2678] source/geom/CoordinateArraySequence.cpp,
source/geom/Polygon.cpp,
@@ -8950,7 +10946,7 @@
toVector method for CoordinateSequence (ie: no memory management
issues). Use it from Polygon::getCoordinates.
-2009-10-17 12:02 Sandro Santilli <strk at keybit.net>
+2009-10-17 12:02 Sandro Santilli <strk at kbt.io>
* [r2677] source/geom/Polygon.cpp: Don't allocate too much space
for polygon points vector. Fixes bug #294.
@@ -8960,7 +10956,7 @@
* [r2676] tests/xmltester/tests/fme.xml: xmltester/tests: missing
double quotes around XML attribute value in fme.xml.
-2009-10-14 20:42 Sandro Santilli <strk at keybit.net>
+2009-10-14 20:42 Sandro Santilli <strk at kbt.io>
* [r2675] ChangeLog: regenerate ChangeLog
@@ -9003,67 +10999,67 @@
* [r2669] source/Makefile.vc, source/dirlist.mk: add new
directories and source (#288)
-2009-10-08 08:56 Sandro Santilli <strk at keybit.net>
+2009-10-08 08:56 Sandro Santilli <strk at kbt.io>
* [r2668] ChangeLog: regenerate ChangeLog now that we have all
names in
-2009-10-08 08:47 Sandro Santilli <strk at keybit.net>
+2009-10-08 08:47 Sandro Santilli <strk at kbt.io>
* [r2667] authors.svn: Add other missing names/addresses
-2009-10-08 08:40 Sandro Santilli <strk at keybit.net>
+2009-10-08 08:40 Sandro Santilli <strk at kbt.io>
* [r2666] ChangeLog, ChangeLog.svn, Makefile.am: Automatically
generate the ChangeLog file, forget ChangeLog.svn.
-2009-10-08 08:38 Sandro Santilli <strk at keybit.net>
+2009-10-08 08:38 Sandro Santilli <strk at kbt.io>
* [r2665] source/operation/overlay/snap/SnapIfNeededOverlayOp.cpp:
Don't signal topology exception when it triggers snapping
-2009-10-08 08:37 Sandro Santilli <strk at keybit.net>
+2009-10-08 08:37 Sandro Santilli <strk at kbt.io>
* [r2664] authors.svn: Add yury, fernando and sean
-2009-10-08 08:17 Sandro Santilli <strk at keybit.net>
+2009-10-08 08:17 Sandro Santilli <strk at kbt.io>
* [r2663] tests/unit/Makefile.am: Distribute all of TUT
-2009-10-08 07:56 Sandro Santilli <strk at keybit.net>
+2009-10-08 07:56 Sandro Santilli <strk at kbt.io>
* [r2662] capi/geos_c.h.in, source/headers/geos/version.h.vc:
Properly set version for win target
-2009-10-07 07:53 Sandro Santilli <strk at keybit.net>
+2009-10-07 07:53 Sandro Santilli <strk at kbt.io>
* [r2661] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp,
tests/unit/capi/GEOSBufferTest.cpp: Expose single-sided buffering
in C-API (see ticket #258)
-2009-10-05 21:36 Sandro Santilli <strk at keybit.net>
+2009-10-05 21:36 Sandro Santilli <strk at kbt.io>
* [r2659] source/algorithm/distance/DistanceToPoint.cpp,
source/headers/geos/algorithm/distance/DistanceToPoint.h: Drop
use of static data in DistanceToPoint class (for thread-safety)
-2009-10-05 19:29 Sandro Santilli <strk at keybit.net>
+2009-10-05 19:29 Sandro Santilli <strk at kbt.io>
* [r2658] source/operation/buffer/BufferBuilder.cpp: release memory
earlier, and closer to allocation
-2009-10-05 19:04 Sandro Santilli <strk at keybit.net>
+2009-10-05 19:04 Sandro Santilli <strk at kbt.io>
* [r2657] source/operation/buffer/BufferBuilder.cpp: Finish
plugging leaks. Make check runs with no leaks.
-2009-10-05 18:42 Sandro Santilli <strk at keybit.net>
+2009-10-05 18:42 Sandro Santilli <strk at kbt.io>
* [r2656]
source/headers/geos/operation/buffer/OffsetCurveBuilder.h:
another memory management doc
-2009-10-05 18:40 Sandro Santilli <strk at keybit.net>
+2009-10-05 18:40 Sandro Santilli <strk at kbt.io>
* [r2655]
source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
@@ -9071,35 +11067,35 @@
source/operation/buffer/OffsetCurveSetBuilder.cpp: Document more
memory management issues
-2009-10-05 17:20 Sandro Santilli <strk at keybit.net>
+2009-10-05 17:20 Sandro Santilli <strk at kbt.io>
* [r2654] source/operation/buffer/BufferBuilder.cpp,
source/operation/buffer/OffsetCurveBuilder.cpp: More memory leak
fixes in single-sided buffering implementation
-2009-10-05 16:58 Sandro Santilli <strk at keybit.net>
+2009-10-05 16:58 Sandro Santilli <strk at kbt.io>
* [r2653] source/operation/buffer/BufferBuilder.cpp: Plug some
memory leaks in single sided buffering implementation
-2009-10-05 16:44 Sandro Santilli <strk at keybit.net>
+2009-10-05 16:44 Sandro Santilli <strk at kbt.io>
* [r2652] source/headers/geos/operation/linemerge/LineMerger.h:
Document ownership of return from
LineMerger::getMergedLineStrings
-2009-10-05 16:40 Sandro Santilli <strk at keybit.net>
+2009-10-05 16:40 Sandro Santilli <strk at kbt.io>
* [r2651] .vimrc: Alright, there's no standard style yet so this
file is made empty, but good to have for reference
-2009-10-01 10:30 Sandro Santilli <strk at keybit.net>
+2009-10-01 10:30 Sandro Santilli <strk at kbt.io>
* [r2650] source/operation/buffer/BufferBuilder.cpp: Throw an
exception rather than returning NULL if input to single-sided
buffer code is invalid
-2009-10-01 09:10 Sandro Santilli <strk at keybit.net>
+2009-10-01 09:10 Sandro Santilli <strk at kbt.io>
* [r2649] source/operation/buffer/BufferBuilder.cpp,
tests/xmltester/Makefile.am, tests/xmltester/tests/safe,
@@ -9110,82 +11106,82 @@
rather than forcing a MULTI; import 2 tests from the SAFE
testsuite
-2009-10-01 09:01 Sandro Santilli <strk at keybit.net>
+2009-10-01 09:01 Sandro Santilli <strk at kbt.io>
* [r2648] tests/xmltester/safe_to_xml.sh: Better parse style
parameter
-2009-10-01 08:46 Sandro Santilli <strk at keybit.net>
+2009-10-01 08:46 Sandro Santilli <strk at kbt.io>
* [r2647] tests/xmltester/safe_to_xml.sh: Add utility script to
import tests from SAFE software
-2009-10-01 08:42 Sandro Santilli <strk at keybit.net>
+2009-10-01 08:42 Sandro Santilli <strk at kbt.io>
* [r2646] tests/xmltester/XMLTester.cpp: Don't segfault on xml
tests missing precision model specification
-2009-10-01 07:24 Sandro Santilli <strk at keybit.net>
+2009-10-01 07:24 Sandro Santilli <strk at kbt.io>
* [r2645] tests/xmltester/tests/singlesidedbuffer.xml: Re-enable
the now succeeding test for sharp edges line single sided
buffering
-2009-10-01 07:23 Sandro Santilli <strk at keybit.net>
+2009-10-01 07:23 Sandro Santilli <strk at kbt.io>
* [r2644] source/operation/buffer/BufferBuilder.cpp: Use FLAT/BUTT
endcaps when doing single sided buffering
-2009-10-01 07:06 Sandro Santilli <strk at keybit.net>
+2009-10-01 07:06 Sandro Santilli <strk at kbt.io>
* [r2643] source/operation/buffer/OffsetCurveBuilder.cpp: Fix
trimming of left/right curves (ie: don't include the endcap)
-2009-10-01 06:33 Sandro Santilli <strk at keybit.net>
+2009-10-01 06:33 Sandro Santilli <strk at kbt.io>
* [r2642] source/operation/buffer/BufferBuilder.cpp: Use snapped
intersection between full buffer boundary and single-sided offset
curves
-2009-09-30 22:18 Sandro Santilli <strk at keybit.net>
+2009-09-30 22:18 Sandro Santilli <strk at kbt.io>
* [r2641] tests/xmltester/SingleSidedBufferResultMatcher.cpp: Check
hausdorff distance in both directions, or an expected output line
longer than the obtained one would be found as correct
-2009-09-30 20:27 Sandro Santilli <strk at keybit.net>
+2009-09-30 20:27 Sandro Santilli <strk at kbt.io>
* [r2640] source/operation/buffer/BufferBuilder.cpp: Some debugging
for single sided buffers
-2009-09-30 19:18 Sandro Santilli <strk at keybit.net>
+2009-09-30 19:18 Sandro Santilli <strk at kbt.io>
* [r2639] tests/xmltester/tests/singlesidedbuffer.xml: Another
simple test for single-sided buffer (horizontal line, both
directions)
-2009-09-30 19:07 Sandro Santilli <strk at keybit.net>
+2009-09-30 19:07 Sandro Santilli <strk at kbt.io>
* [r2638] tests/xmltester/tests/singlesidedbuffer.xml: Another
simple test for a vertical line, opposite direction from previous
-2009-09-30 19:05 Sandro Santilli <strk at keybit.net>
+2009-09-30 19:05 Sandro Santilli <strk at kbt.io>
* [r2637] tests/xmltester/tests/singlesidedbuffer.xml: Add test for
single sided buffer on simple, vertical, line (this one succeeds
both left and right)
-2009-09-30 18:57 Sandro Santilli <strk at keybit.net>
+2009-09-30 18:57 Sandro Santilli <strk at kbt.io>
* [r2636] .vimrc: VIM setting for GEOS source code style (3-spaces
tabs)
-2009-09-30 14:14 Sandro Santilli <strk at keybit.net>
+2009-09-30 14:14 Sandro Santilli <strk at kbt.io>
* [r2635] autogen.sh: Don't use non-standard escape sequences with
'echo'
-2009-09-28 10:35 Sandro Santilli <strk at keybit.net>
+2009-09-28 10:35 Sandro Santilli <strk at kbt.io>
* [r2634] tests/xmltester/Makefile.am,
tests/xmltester/XMLTester.cpp, tests/xmltester/XMLTester.h,
@@ -9198,28 +11194,28 @@
tests/xmltester/tinyxml/tinyxmlparser.cpp: Replace
no-commercial-use licenced MarkupSTL with tinyXML
-2009-09-28 10:34 Sandro Santilli <strk at keybit.net>
+2009-09-28 10:34 Sandro Santilli <strk at kbt.io>
* [r2633] tests/xmltester/tests/singlesidedbuffer.xml: Temporarly
disable failing single sided buffer test
-2009-09-28 10:10 Sandro Santilli <strk at keybit.net>
+2009-09-28 10:10 Sandro Santilli <strk at kbt.io>
* [r2632] tests/xmltester/SingleSidedBufferResultMatcher.cpp: Oops,
it seems I just don't want a test to fail ;)
-2009-09-28 10:09 Sandro Santilli <strk at keybit.net>
+2009-09-28 10:09 Sandro Santilli <strk at kbt.io>
* [r2631] tests/xmltester/SingleSidedBufferResultMatcher.cpp: Don't
give a false success if one of the expected/obtained geometry is
empty
-2009-09-28 09:03 Sandro Santilli <strk at keybit.net>
+2009-09-28 09:03 Sandro Santilli <strk at kbt.io>
* [r2630] source/geom/PrecisionModel.cpp: Add offsets to
PrecisionModel text output
-2009-09-28 07:02 Sandro Santilli <strk at keybit.net>
+2009-09-28 07:02 Sandro Santilli <strk at kbt.io>
* [r2629] tests/xmltester/Makefile.am,
tests/xmltester/SingleSidedBufferResultMatcher.cpp,
@@ -9230,7 +11226,7 @@
Enable the single sided buffer test provided by swong in ticket
#215 with minor tweak (expect multilinestring).
-2009-09-27 20:43 Sandro Santilli <strk at keybit.net>
+2009-09-27 20:43 Sandro Santilli <strk at kbt.io>
* [r2628] source/headers/geos/operation/buffer/BufferBuilder.h,
@@ -9275,7 +11271,7 @@
Updated C++ TUT Framework to latest revision (147) of its SVN
trunk
-2009-08-15 13:26 Sandro Santilli <strk at keybit.net>
+2009-08-15 13:26 Sandro Santilli <strk at kbt.io>
* [r2620] source/headers/geos/linearref/ExtractLineByLocation.h,
source/headers/geos/linearref/LengthIndexOfPoint.h,
@@ -9359,20 +11355,20 @@
geos::index::strtree::AbstractSTRtree::iterate (#277) Schuyler
Erle
-2009-07-06 17:35 Sandro Santilli <strk at keybit.net>
+2009-07-06 17:35 Sandro Santilli <strk at kbt.io>
* [r2610] tests/xmltester/Makefile.am,
tests/xmltester/tests/bug275.xml: Add automated XML test for
issue #275. Succeeds here.
-2009-07-05 15:58 Sandro Santilli <strk at keybit.net>
+2009-07-05 15:58 Sandro Santilli <strk at kbt.io>
* [r2609] build/msvc90/geos_c_dll/geos_c_dll.vcproj,
build/msvc90/geos_lib/geos_lib.vcproj,
build/msvc90/geos_unit/geos_unit.vcproj: Apply
fix-msvc90-only2.patch by Sanak from issue #273
-2009-07-04 16:19 Sandro Santilli <strk at keybit.net>
+2009-07-04 16:19 Sandro Santilli <strk at kbt.io>
* [r2608] source/headers/geos/export.h,
source/headers/geos/platform.h.in: Apply fix-mingw.patch by Sanak
@@ -9382,7 +11378,7 @@
* [r2607] Makefile.am: Include nmake.opt in 'dist' target (#274)
-2009-06-26 21:59 Sandro Santilli <strk at keybit.net>
+2009-06-26 21:59 Sandro Santilli <strk at kbt.io>
* [r2605] source/headers/geos/operation/buffer/BufferOp.h: Fix typo
reported in ticket #272
@@ -9419,52 +11415,52 @@
* [r2598] source/Makefile.vc: fix up syntax of the makefile related
to the patch for #257
-2009-06-22 19:14 Sandro Santilli <strk at keybit.net>
+2009-06-22 19:14 Sandro Santilli <strk at kbt.io>
* [r2597] tests/unit/capi/GEOSBufferTest.cpp: Add tests for limited
mitre join (now working)
-2009-06-22 19:02 Sandro Santilli <strk at keybit.net>
+2009-06-22 19:02 Sandro Santilli <strk at kbt.io>
* [r2596] source/headers/geos/operation/buffer/BufferParameters.h:
Fix bug in BufferParameters::setMitreLimit
-2009-06-20 21:29 Sandro Santilli <strk at keybit.net>
+2009-06-20 21:29 Sandro Santilli <strk at kbt.io>
* [r2595] configure.in: Bump versions (core 3.2.0, capi 1.6.0, port
1.10.0)
-2009-06-20 08:53 Sandro Santilli <strk at keybit.net>
+2009-06-20 08:53 Sandro Santilli <strk at kbt.io>
* [r2594] tests/unit/Makefile.am,
GEOSBufferWithStyle
-2009-06-19 22:32 Sandro Santilli <strk at keybit.net>
+2009-06-19 22:32 Sandro Santilli <strk at kbt.io>
* [r2593] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
Extend the C-API interface to expose a GEOSBufferWithStyle (and
corresponding thread-safe version) and related enums.
-2009-06-16 15:49 Sandro Santilli <strk at keybit.net>
+2009-06-16 15:49 Sandro Santilli <strk at kbt.io>
* [r2592] source/algorithm/RobustDeterminant.cpp,
source/headers/geos/algorithm/RobustDeterminant.h: Sync
RobustDeterminant to JTS-1.10 (r1.15 was just commented-out code)
-2009-06-16 15:46 Sandro Santilli <strk at keybit.net>
+2009-06-16 15:46 Sandro Santilli <strk at kbt.io>
* [r2591] source/algorithm/RobustDeterminant.cpp,
RobustDeterminant to revision 1.14
-2009-06-16 15:43 Sandro Santilli <strk at keybit.net>
+2009-06-16 15:43 Sandro Santilli <strk at kbt.io>
* [r2590] source/algorithm/RobustDeterminant.cpp,
source/headers/geos/algorithm/RobustDeterminant.h: Port info for
RobustDeterminant
-2009-06-16 15:33 Sandro Santilli <strk at keybit.net>
+2009-06-16 15:33 Sandro Santilli <strk at kbt.io>
* [r2589] source/headers/geos/operation/buffer/BufferBuilder.h,
@@ -9484,7 +11480,7 @@
* [r2580] source/headers/geos/Makefile.am: operation.h in
Makefile.am twice. (#261)
-2009-06-15 14:03 Sandro Santilli <strk at keybit.net>
+2009-06-15 14:03 Sandro Santilli <strk at kbt.io>
* [r2579] source/headers/geos/io/ByteOrderDataInStream.h,
source/headers/geos/io/ByteOrderDataInStream.inl,
@@ -9506,30 +11502,30 @@
source/io/WKTReader.cpp, source/io/WKTWriter.cpp,
source/io/Writer.cpp: Port info in the geos::io namespace
-2009-06-15 13:19 Sandro Santilli <strk at keybit.net>
+2009-06-15 13:19 Sandro Santilli <strk at kbt.io>
* [r2578] source/io/WKTWriter.cpp: Put CLocalizer in the correct
function. Fixes #260 for the writing part.
-2009-06-15 10:13 Sandro Santilli <strk at keybit.net>
+2009-06-15 10:13 Sandro Santilli <strk at kbt.io>
* [r2577] capi/geos_ts_c.cpp: Stop explicitly using the CLocalizer
now that it is done within WKTReader and WKTWriter (see bug
#260). Some deep testing about this would be good. Make check
worked for me with comma-using locale.
-2009-06-15 10:06 Sandro Santilli <strk at keybit.net>
+2009-06-15 10:06 Sandro Santilli <strk at kbt.io>
* [r2576] source/io/WKTReader.cpp, source/io/WKTWriter.cpp: Use C
locale while reading/writing WKT. Fixes bug #260.
-2009-06-15 06:57 Sandro Santilli <strk at keybit.net>
+2009-06-15 06:57 Sandro Santilli <strk at kbt.io>
* [r2575] tests/xmltester/Makefile.am,
tests/xmltester/tests/bug176.xml: Add XML version of the testcase
provided for bug #176
-2009-06-08 22:10 Sandro Santilli <strk at keybit.net>
+2009-06-08 22:10 Sandro Santilli <strk at kbt.io>
* [r2572]
@@ -9550,14 +11546,14 @@
source/operation/valid/TopologyValidationError.cpp: JTS-1.10 port
sync. The whole 'operation' namespace is complete on this.
-2009-06-08 21:53 Sandro Santilli <strk at keybit.net>
+2009-06-08 21:53 Sandro Santilli <strk at kbt.io>
* [r2571]
source/headers/geos/operation/union/CascadedPolygonUnion.h,
source/operation/union/CascadedPolygonUnion.cpp: Port info for
operation::union
-2009-06-08 17:15 Sandro Santilli <strk at keybit.net>
+2009-06-08 17:15 Sandro Santilli <strk at kbt.io>
* [r2570]
source/headers/geos/operation/predicate/RectangleIntersects.h,
@@ -9566,14 +11562,14 @@
source/operation/predicate/SegmentIntersectionTester.cpp: Sync to
JTS-1.10 (port info in SegmentIntersectionTester was wrong, btw)
-2009-06-08 17:12 Sandro Santilli <strk at keybit.net>
+2009-06-08 17:12 Sandro Santilli <strk at kbt.io>
* [r2569]
source/headers/geos/operation/predicate/RectangleContains.h,
source/operation/predicate/RectangleContains.cpp: Sync
RectangleContains to JTS-1.10
-2009-06-08 17:02 Sandro Santilli <strk at keybit.net>
+2009-06-08 17:02 Sandro Santilli <strk at kbt.io>
* [r2568]
@@ -9582,7 +11578,7 @@
source/operation/predicate/SegmentIntersectionTester.cpp: Port
info for operation::predicate (we're at JTS-1.7 here)
-2009-06-08 16:58 Sandro Santilli <strk at keybit.net>
+2009-06-08 16:58 Sandro Santilli <strk at kbt.io>
* [r2567] source/headers/geos/operation/polygonize/EdgeRing.h,
source/headers/geos/operation/polygonize/PolygonizeDirectedEdge.h,
@@ -9596,7 +11592,7 @@
source/operation/polygonize/Polygonizer.cpp: Port info for
polygonize operation
-2009-06-08 16:46 Sandro Santilli <strk at keybit.net>
+2009-06-08 16:46 Sandro Santilli <strk at kbt.io>
* [r2566]
source/headers/geos/operation/overlay/validate/FuzzyPointLocator.h,
@@ -9607,13 +11603,13 @@
source/operation/overlay/validate/OverlayResultValidator.cpp:
Port info and sync for operation::overlay::validate
-2009-06-08 16:26 Sandro Santilli <strk at keybit.net>
+2009-06-08 16:26 Sandro Santilli <strk at kbt.io>
* [r2565] source/headers/geos/operation/overlay/LineBuilder.h,
source/operation/overlay/LineBuilder.cpp: sync LineBuilder to
JTS-1.10, completing overlay port
-2009-06-08 16:09 Sandro Santilli <strk at keybit.net>
+2009-06-08 16:09 Sandro Santilli <strk at kbt.io>
* [r2564] source/headers/geos/operation/overlay/EdgeSetNoder.h,
source/headers/geos/operation/overlay/ElevationMatrix.h,
@@ -9632,7 +11628,7 @@
source/operation/overlay/PointBuilder.cpp: Complete port info in
overlay package
-2009-06-08 15:43 Sandro Santilli <strk at keybit.net>
+2009-06-08 15:43 Sandro Santilli <strk at kbt.io>
* [r2563] source/headers/geos/operation/linemerge/LineMerger.h,
source/headers/geos/planargraph/GraphComponent.h,
@@ -9640,7 +11636,7 @@
static methods in GraphComponent and make use of them in
LineMerger making it able to be called incrementally (JTS-1.10)
-2009-06-08 15:28 Sandro Santilli <strk at keybit.net>
+2009-06-08 15:28 Sandro Santilli <strk at kbt.io>
* [r2562] source/headers/geos/operation/linemerge/EdgeString.h,
source/headers/geos/operation/linemerge/LineMergeDirectedEdge.h,
@@ -9657,20 +11653,20 @@
operation::linemerge (a single class is still at JTS-1.7, needs
changes in GeometryGraphComponent.h to go up)
-2009-06-08 10:37 Sandro Santilli <strk at keybit.net>
+2009-06-08 10:37 Sandro Santilli <strk at kbt.io>
* [r2561]
source/headers/geos/operation/distance/GeometryLocation.h,
source/operation/distance/GeometryLocation.cpp: GeometryLocation
sync to JTS-1.10 (docs)
-2009-06-08 10:29 Sandro Santilli <strk at keybit.net>
+2009-06-08 10:29 Sandro Santilli <strk at kbt.io>
* [r2560] source/headers/geos/operation/distance/DistanceOp.h,
source/operation/distance/DistanceOp.cpp: DistanceOp sync to
JTS-1.10 (renames, docs...)
-2009-06-08 10:07 Sandro Santilli <strk at keybit.net>
+2009-06-08 10:07 Sandro Santilli <strk at kbt.io>
* [r2559] source/headers/geos/operation/buffer/BufferBuilder.h,
source/headers/geos/operation/buffer/BufferOp.h,
@@ -9693,12 +11689,12 @@
source/operation/buffer/SubgraphDepthLocater.cpp: Update port
info for buffer package (it's really JTS-1.10)
-2009-06-08 09:40 Sandro Santilli <strk at keybit.net>
+2009-06-08 09:40 Sandro Santilli <strk at kbt.io>
* [r2558] configure.in: Warn at configure time if 64bit integer
type isn't found. See bug #202.
-2009-06-08 09:30 Sandro Santilli <strk at keybit.net>
+2009-06-08 09:30 Sandro Santilli <strk at kbt.io>
* [r2557] source/headers/geos/Makefile.am,
source/headers/geos/algorithm/Makefile.am,
@@ -9775,7 +11771,7 @@
documented as being unstable after all so let's give users the
power to hurt themselves :)
-2009-06-06 22:22 Sandro Santilli <strk at keybit.net>
+2009-06-06 22:22 Sandro Santilli <strk at kbt.io>
* [r2556] build/msvc90/geos_c_dll/geos_c_dll.vcproj,
@@ -10021,12 +12017,12 @@
C++ exports by Ragi Y. Burhum. See
http://lists.osgeo.org/pipermail/geos-devel/2009-June/004190.html
-2009-06-06 22:17 Sandro Santilli <strk at keybit.net>
+2009-06-06 22:17 Sandro Santilli <strk at kbt.io>
* [r2555] tests/xmltester/SimpleWKTTester.cpp: fix headers
inclusion warnings
-2009-06-06 21:14 Sandro Santilli <strk at keybit.net>
+2009-06-06 21:14 Sandro Santilli <strk at kbt.io>
* [r2554] build/msvc90/geos_lib/geos_lib.vcproj,
capi/geos_ts_c.cpp, configure.in,
@@ -10050,7 +12046,7 @@
autoconf checks for finite() and isfinite() and makes use of them
for unix systems (platform.h)
-2009-06-06 00:55 Sandro Santilli <strk at keybit.net>
+2009-06-06 00:55 Sandro Santilli <strk at kbt.io>
* [r2553]
source/headers/geos/operation/distance/ConnectedElementLocationFilter.h,
@@ -10062,22 +12058,22 @@
source/operation/distance/GeometryLocation.cpp: Complete port
info and headers exposion for operation::distance package
-2009-06-05 18:18 Sandro Santilli <strk at keybit.net>
+2009-06-05 18:18 Sandro Santilli <strk at kbt.io>
* [r2552] source/headers/geos/operation/overlay/OverlayOp.h,
source/operation/overlay/OverlayOp.cpp: JTS-1.10 OverlayOp
-2009-06-05 18:12 Sandro Santilli <strk at keybit.net>
+2009-06-05 18:12 Sandro Santilli <strk at kbt.io>
* [r2551] source/headers/geos/geomgraph/EdgeNodingValidator.h: Add
missing static function
-2009-06-05 18:02 Sandro Santilli <strk at keybit.net>
+2009-06-05 18:02 Sandro Santilli <strk at kbt.io>
* [r2550] source/headers/geos/operation/overlay/MaximalEdgeRing.h,
source/operation/overlay/MaximalEdgeRing.cpp: JTS-1.10 sync
-2009-06-05 17:50 Sandro Santilli <strk at keybit.net>
+2009-06-05 17:50 Sandro Santilli <strk at kbt.io>
* [r2549] source/headers/geos/operation/GeometryGraphOperation.h,
source/headers/geos/operation/relate/RelateOp.h,
@@ -10085,13 +12081,13 @@
source/operation/relate/RelateOp.cpp: Boundary Node Rule support
in relateOp. JTS-1.10.
-2009-06-05 13:44 Sandro Santilli <strk at keybit.net>
+2009-06-05 13:44 Sandro Santilli <strk at kbt.io>
* [r2548] source/geomgraph/EdgeList.cpp, source/geomgraph/Node.cpp,
source/headers/geos/geomgraph/Node.h: geomgraph package fully
sync'ed to JTS-1.10 now
-2009-06-05 13:41 Sandro Santilli <strk at keybit.net>
+2009-06-05 13:41 Sandro Santilli <strk at kbt.io>
* [r2547] source/geomgraph/EdgeEnd.cpp,
source/geomgraph/EdgeEndStar.cpp,
@@ -10103,14 +12099,14 @@
source/operation/valid/ConsistentAreaTester.cpp: added
BoundaryNodeRule capability to EdgeEnds
-2009-06-05 12:42 Sandro Santilli <strk at keybit.net>
+2009-06-05 12:42 Sandro Santilli <strk at kbt.io>
* [r2546] source/geomgraph/GeometryGraph.cpp,
source/headers/geos/geomgraph/GeometryGraph.h,
source/headers/geos/geomgraph/GeometryGraph.inl: Add support for
custom BoundaryNodeRule bringing GeometryGraph to JTS-1.10
-2009-06-05 12:07 Sandro Santilli <strk at keybit.net>
+2009-06-05 12:07 Sandro Santilli <strk at kbt.io>
* [r2545] source/geomgraph/DirectedEdgeStar.cpp,
source/geomgraph/Edge.cpp,
@@ -10133,7 +12129,7 @@
source/headers/geos/geomgraph/TopologyLocation.h: Complete port
info in geomgraph package
-2009-06-05 11:03 Sandro Santilli <strk at keybit.net>
+2009-06-05 11:03 Sandro Santilli <strk at kbt.io>
* [r2544] source/geomgraph/Depth.cpp,
@@ -10152,7 +12148,7 @@
geomgraph package (unfinished); fix compiler warning in
GeometryGraph and make code more readable;
-2009-06-05 10:23 Sandro Santilli <strk at keybit.net>
+2009-06-05 10:23 Sandro Santilli <strk at kbt.io>
* [r2543] source/headers/geos/operation/relate/EdgeEndBuilder.h,
source/headers/geos/operation/relate/EdgeEndBundle.h,
@@ -10173,15 +12169,15 @@
header exposion info. Relate op results partially in JTS-1.7
still.
-2009-06-05 09:36 Sandro Santilli <strk at keybit.net>
+2009-06-05 09:36 Sandro Santilli <strk at kbt.io>
* [r2542] source/headers/geos/geom.h: typo in doxygen index page
-2009-06-05 09:35 Sandro Santilli <strk at keybit.net>
+2009-06-05 09:35 Sandro Santilli <strk at kbt.io>
* [r2541] source/headers/geos/geom.h: Fix doxygen link
-2009-06-05 09:28 Sandro Santilli <strk at keybit.net>
+2009-06-05 09:28 Sandro Santilli <strk at kbt.io>
* [r2540] source/algorithm/locate/IndexedPointInAreaLocator.cpp,
source/headers/geos/algorithm/locate/IndexedPointInAreaLocator.h,
@@ -10191,7 +12187,7 @@
ownership, fix callers tracking allocations to avoid leaks. Fixes
bug #227.
-2009-06-05 09:15 Sandro Santilli <strk at keybit.net>
+2009-06-05 09:15 Sandro Santilli <strk at kbt.io>
* [r2539] ChangeLog.svn, Makefile.am: Allow generating ChangeLog
from external build tree
@@ -10217,7 +12213,7 @@
inaccessible constructor of incomplete type NodedSegmentString -
header missing.
-2009-06-04 13:59 Sandro Santilli <strk at keybit.net>
+2009-06-04 13:59 Sandro Santilli <strk at kbt.io>
* [r2536] tests/xmltester/XMLTester.cpp: Add support for testing
@@ -10240,12 +12236,12 @@
* [r2515] NEWS: Add single-sided item
-2009-05-21 10:08 Sandro Santilli <strk at keybit.net>
+2009-05-21 10:08 Sandro Santilli <strk at kbt.io>
* [r2514] ChangeLog.svn, Makefile.am, authors.svn: Add Mat's and
Paul's entries, make ChangeLog.svn rule phony
-2009-05-21 09:56 Sandro Santilli <strk at keybit.net>
+2009-05-21 09:56 Sandro Santilli <strk at kbt.io>
* [r2513] ChangeLog.svn, Makefile.am, authors.svn: Add a rule to
generate a ChangeLog using svn2cl. The authors.svn file will be
@@ -10268,17 +12264,17 @@
* [r2506] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in,
capi/geos_ts_c.cpp: Added GEOSFree() and GEOSFree_r() (#249)
-2009-05-12 17:47 Sandro Santilli <strk at keybit.net>
+2009-05-12 17:47 Sandro Santilli <strk at kbt.io>
* [r2505] NEWS: Add note about single-sided buffer
-2009-05-12 16:49 Sandro Santilli <strk at keybit.net>
+2009-05-12 16:49 Sandro Santilli <strk at kbt.io>
* [r2504] tests/xmltester/Makefile.am,
tests/xmltester/tests/bug244.xml: Never fail bug #244 again
(regression testcase added)
-2009-05-12 16:48 Sandro Santilli <strk at keybit.net>
+2009-05-12 16:48 Sandro Santilli <strk at kbt.io>
* [r2503] source/operation/buffer/SubgraphDepthLocater.cpp: Have
DepthSegment hold a real LineSegment, not a reference.
@@ -10286,43 +12282,43 @@
to multiple DepthSegments, messing everything up. This fixes bug
#244.
-2009-05-12 15:38 Sandro Santilli <strk at keybit.net>
+2009-05-12 15:38 Sandro Santilli <strk at kbt.io>
* [r2502] source/geomgraph/DirectedEdge.cpp,
source/headers/geos/geomgraph/DirectedEdge.h,
source/headers/geos/geomgraph/DirectedEdge.inl: Port info
-2009-05-08 16:30 Sandro Santilli <strk at keybit.net>
+2009-05-08 16:30 Sandro Santilli <strk at kbt.io>
* [r2501] source/headers/geos/operation/overlay/PolygonBuilder.h,
source/operation/overlay/PolygonBuilder.cpp: Update port info
-2009-05-08 12:47 Sandro Santilli <strk at keybit.net>
+2009-05-08 12:47 Sandro Santilli <strk at kbt.io>
* [r2500] capi/geos_c.h.in: When included in a C++ environment,
include <cstddef> and use std::size_t. Patch by Mateusz Loskot,
ticket #252.
-2009-05-08 12:46 Sandro Santilli <strk at keybit.net>
+2009-05-08 12:46 Sandro Santilli <strk at kbt.io>
* [r2499] source/operation/distance/DistanceOp.cpp: Oops, forgot to
update the static closedPoints signature..
-2009-05-08 12:29 Sandro Santilli <strk at keybit.net>
+2009-05-08 12:29 Sandro Santilli <strk at kbt.io>
* [r2498] NEWS: Note the withinDistance addition to DistanceOp
-2009-05-08 12:27 Sandro Santilli <strk at keybit.net>
+2009-05-08 12:27 Sandro Santilli <strk at kbt.io>
* [r2497] tests/unit/operation/distance/DistanceOpTest.cpp: Add the
complete set of tests for closedPoints
-2009-05-08 12:11 Sandro Santilli <strk at keybit.net>
+2009-05-08 12:11 Sandro Santilli <strk at kbt.io>
* [r2496] source/headers/geos/operation/distance/DistanceOp.h:
Document semantic of a null return from closestPoints
-2009-05-08 12:09 Sandro Santilli <strk at keybit.net>
+2009-05-08 12:09 Sandro Santilli <strk at kbt.io>
* [r2495] source/headers/geos/operation/distance/DistanceOp.h,
source/operation/distance/DistanceOp.cpp: Don't wipe out closest
@@ -10332,33 +12328,33 @@
cleanups), and to rename a function to follow current JTS naming
(more renames to come for proper sync)
-2009-05-08 10:10 Sandro Santilli <strk at keybit.net>
+2009-05-08 10:10 Sandro Santilli <strk at kbt.io>
* [r2494] source/headers/geos/operation/distance/DistanceOp.h,
source/operation/distance/DistanceOp.cpp: Add isWithinDistance()
to DistanceOp, reaching rev 1.17 of JTS
-2009-05-08 09:39 Sandro Santilli <strk at keybit.net>
+2009-05-08 09:39 Sandro Santilli <strk at kbt.io>
* [r2493] source/headers/geos/operation/distance/DistanceOp.h,
source/operation/distance/DistanceOp.cpp: Port info for
DistanceOp
-2009-05-08 08:44 Sandro Santilli <strk at keybit.net>
+2009-05-08 08:44 Sandro Santilli <strk at kbt.io>
* [r2492] capi/geos_c.h.in: Always include stddef.h. Closes bug
#213
-2009-05-07 16:15 Sandro Santilli <strk at keybit.net>
+2009-05-07 16:15 Sandro Santilli <strk at kbt.io>
* [r2491] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
Add "thread-safe" version of GEOSGeom_setSRID. Closes bug #242.
-2009-05-07 16:00 Sandro Santilli <strk at keybit.net>
+2009-05-07 16:00 Sandro Santilli <strk at kbt.io>
* [r2490] tests/bigtest/bug234.cpp: minor debug output improvement
-2009-05-07 15:57 Sandro Santilli <strk at keybit.net>
+2009-05-07 15:57 Sandro Santilli <strk at kbt.io>
* [r2489] source/geomgraph/GeometryGraph.cpp,
tests/bigtest/Makefile.am, tests/bigtest/README,
@@ -10366,35 +12362,35 @@
GeometryGraph. Fixes bug #234. Add non-automated test for it, and
README file in the directory containing it...
-2009-05-07 15:36 Sandro Santilli <strk at keybit.net>
+2009-05-07 15:36 Sandro Santilli <strk at kbt.io>
* [r2488] tests/xmltester/Makefile.am,
tests/xmltester/tests/bug188.xml: Add XML testcase for bug 188
* [r2487] tests/xmltester/XMLTester.cpp: remove code duplication on
buffer result validation
-2009-05-07 08:52 Sandro Santilli <strk at keybit.net>
+2009-05-07 08:52 Sandro Santilli <strk at kbt.io>
* [r2486] source/geom/CoordinateSequenceFactory.cpp,
source/headers/geos/geom/CoordinateSequenceFactory.h: Port info,
doxygen cleanups
-2009-05-07 08:45 Sandro Santilli <strk at keybit.net>
+2009-05-07 08:45 Sandro Santilli <strk at kbt.io>
* [r2485] tests/unit/capi/GEOSCoordSeqTest.cpp: Add test for
creating a CoordinateSequence with at least 2 dimension
-2009-05-06 20:47 Sandro Santilli <strk at keybit.net>
+2009-05-06 20:47 Sandro Santilli <strk at kbt.io>
* [r2484] capi/geos_c.h.in, capi/geos_ts_c.cpp: Fix bug #135, give
an hint about GEOSGeom_getDimensions being related to
GEOSCoordSeq_getDimensions, fix signed vs. unsigned compiler
warning.
-2009-05-06 20:22 Sandro Santilli <strk at keybit.net>
+2009-05-06 20:22 Sandro Santilli <strk at kbt.io>
* [r2483] tests/xmltester/markup/MarkupSTL.cpp: Fix compilation
warnings thrown by GCC 4.3.x. Patch by Mateus, closes bug #92.
@@ -10404,19 +12400,19 @@
* [r2482] source/headers/geos/operation/overlay/snap: Updated
svn:ignore property.
-2009-05-06 17:54 Sandro Santilli <strk at keybit.net>
+2009-05-06 17:54 Sandro Santilli <strk at kbt.io>
* [r2481] source/headers/geos/noding/SegmentNodeList.h,
source/noding/SegmentNodeList.cpp:
findCollapsesFromExistingVertices: don't choke on sets of < 2
points. Fixes bug #219.
-2009-05-06 17:52 Sandro Santilli <strk at keybit.net>
+2009-05-06 17:52 Sandro Santilli <strk at kbt.io>
* [r2480] source/operation/buffer/BufferBuilder.cpp: minor
indentation thing
-2009-05-06 17:42 Sandro Santilli <strk at keybit.net>
+2009-05-06 17:42 Sandro Santilli <strk at kbt.io>
* [r2479] source/headers/geos/geom/Makefile.am,
source/headers/geos/index/chain/MonotoneChain.h,
@@ -10430,14 +12426,14 @@
MonotoneChainOverlapAction, reduce heap allocations. Cascade
changes.
-2009-05-06 17:14 Sandro Santilli <strk at keybit.net>
+2009-05-06 17:14 Sandro Santilli <strk at kbt.io>
* [r2478]
source/headers/geos/index/chain/MonotoneChainOverlapAction.h,
source/index/chain/MonotoneChainOverlapAction.cpp: Port info (to
be worked on for heap allocations reduction)
-2009-05-06 17:10 Sandro Santilli <strk at keybit.net>
+2009-05-06 17:10 Sandro Santilli <strk at kbt.io>
* [r2477] source/algorithm/MCPointInRing.cpp,
source/headers/geos/algorithm/MCPointInRing.h,
@@ -10448,7 +12444,7 @@
MonotoneChainSelectAction port review, heap allocation reduced,
const-corrected.
-2009-05-06 16:44 Sandro Santilli <strk at keybit.net>
+2009-05-06 16:44 Sandro Santilli <strk at kbt.io>
* [r2476] source/algorithm/MCPointInRing.cpp,
source/headers/geos/index/SpatialIndex.h,
@@ -10466,51 +12462,51 @@
changes. Possibly discovered a leak in MCPointInRing algorithm,
needs some unit testing.
-2009-05-06 16:36 Sandro Santilli <strk at keybit.net>
+2009-05-06 16:36 Sandro Santilli <strk at kbt.io>
* [r2475] source/headers/geos/index/bintree/Interval.h,
source/index/bintree/Interval.cpp: Const-correctness for bintree
Interval
-2009-05-06 15:47 Sandro Santilli <strk at keybit.net>
+2009-05-06 15:47 Sandro Santilli <strk at kbt.io>
* [r2474] source/headers/geos/index/chain/MonotoneChain.h,
source/index/chain/MonotoneChain.cpp: Port MonotoneChain up to
JTS-1.10, plus minor dox improvement (memory-oriented)
-2009-05-06 15:31 Sandro Santilli <strk at keybit.net>
+2009-05-06 15:31 Sandro Santilli <strk at kbt.io>
* [r2473] source/headers/geos/index/chain/MonotoneChainBuilder.h,
source/index/chain/MonotoneChainBuilder.cpp: Port
MonotoneChainBuilder up to JTS-1.10. Tweak some signatures to use
stricter signedness.
-2009-05-06 14:55 Sandro Santilli <strk at keybit.net>
+2009-05-06 14:55 Sandro Santilli <strk at kbt.io>
* [r2472] source/headers/geos/index/chain/MonotoneChainBuilder.h,
source/index/chain/MonotoneChainBuilder.cpp: Port to 1.9, fixing
an out of boundary access in findEdgeEnd
-2009-05-06 14:42 Sandro Santilli <strk at keybit.net>
+2009-05-06 14:42 Sandro Santilli <strk at kbt.io>
* [r2471] source/headers/geos/index/chain/MonotoneChainBuilder.h,
source/index/chain/MonotoneChainBuilder.cpp: Add port info. We're
4 revision old (catching up next)
-2009-05-05 14:28 Sandro Santilli <strk at keybit.net>
+2009-05-05 14:28 Sandro Santilli <strk at kbt.io>
* [r2470] source/geom/Envelope.cpp,
source/headers/geos/geom/Envelope.h,
source/headers/geos/geom/Envelope.inl: Sync Envelope to JTS-1.10
-2009-05-05 10:30 Sandro Santilli <strk at keybit.net>
+2009-05-05 10:30 Sandro Santilli <strk at kbt.io>
* [r2469] tests/xmltester/XMLTester.cpp: Add compile-time support
to skip use of BinaryOp thus engaging SnapIfNeededOverlayOp used
by Geometry methods. Shows that BinaryOp (GEOS-specific original
work) gives better numerical stability.
-2009-05-05 10:14 Sandro Santilli <strk at keybit.net>
+2009-05-05 10:14 Sandro Santilli <strk at kbt.io>
* [r2468] configure.in, source/headers/geos/geom/BinaryOp.h,
source/headers/geos/operation/overlay/Makefile.am,
@@ -10534,23 +12530,23 @@
GeometrySnapper/LineStringSnapper classes in an unexpected
directory. Move them where they belong, sync with JTS-1.10.
-2009-05-05 00:04 Sandro Santilli <strk at keybit.net>
+2009-05-05 00:04 Sandro Santilli <strk at kbt.io>
* [r2467] source/geom/util/GeometryTransformer.cpp: Fix memory leak
on exception
-2009-05-04 23:43 Sandro Santilli <strk at keybit.net>
+2009-05-04 23:43 Sandro Santilli <strk at kbt.io>
* [r2466] source/operation/IsSimpleOp.cpp: Fix memory bug
-2009-05-04 23:23 Sandro Santilli <strk at keybit.net>
+2009-05-04 23:23 Sandro Santilli <strk at kbt.io>
* [r2465] source/geom/Geometry.cpp,
source/headers/geos/geom/Geometry.h,
source/headers/geos/geom/Geometry.inl: Geometry up to 1.112 with
a minor bugfix and performance improvement in Geometry::covers
-2009-05-04 23:04 Sandro Santilli <strk at keybit.net>
+2009-05-04 23:04 Sandro Santilli <strk at kbt.io>
* [r2464] source/geom/Geometry.cpp,
@@ -10561,7 +12557,7 @@
JTS-ported) doing about the same thing as the SnapIfNeededOp
class.
-2009-05-04 22:03 Sandro Santilli <strk at keybit.net>
+2009-05-04 22:03 Sandro Santilli <strk at kbt.io>
* [r2463] source/headers/geos/operation/overlay/Makefile.am,
source/headers/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h,
@@ -10570,7 +12566,7 @@
source/operation/overlay/snap/SnapIfNeededOverlayOp.cpp: Port
-2009-05-04 21:28 Sandro Santilli <strk at keybit.net>
+2009-05-04 21:28 Sandro Santilli <strk at kbt.io>
* [r2462]
source/headers/geos/operation/overlay/FuzzyPointLocator.h,
@@ -10600,7 +12596,7 @@
tests/unit/operation/overlay/validate/OverlayResultValidatorTest.cpp:
Move overlay.validate package files where they belong
-2009-05-04 21:02 Sandro Santilli <strk at keybit.net>
+2009-05-04 21:02 Sandro Santilli <strk at kbt.io>
* [r2461] source/headers/geos/operation/overlay/Makefile.am,
source/headers/geos/operation/overlay/snap/GeometrySnapper.h,
@@ -10611,7 +12607,7 @@
overlay.snap.SnapOverlayOp, update GeometrySnapper to be more
useful
-2009-05-04 19:54 Sandro Santilli <strk at keybit.net>
+2009-05-04 19:54 Sandro Santilli <strk at kbt.io>
* [r2460] source/headers/geos/operation/overlay/Makefile.am,
@@ -10619,7 +12615,7 @@
source/operation/overlay/snap/GeometrySnapper.cpp: Port
overlay.snap.GeometrySnapper
-2009-05-04 19:51 Sandro Santilli <strk at keybit.net>
+2009-05-04 19:51 Sandro Santilli <strk at kbt.io>
* [r2459]
source/headers/geos/operation/overlay/snap/LineStringSnapper.h,
@@ -10628,7 +12624,7 @@
fix typo making it clone snap points rather than source points on
snapping...
-2009-05-02 11:01 Sandro Santilli <strk at keybit.net>
+2009-05-02 11:01 Sandro Santilli <strk at kbt.io>
* [r2458] source/headers/geos/operation/overlay/Makefile.am,
source/headers/geos/operation/overlay/snap,
@@ -10638,7 +12634,7 @@
source/operation/overlay/snap/LineStringSnapper.cpp: Port
overlay.snap.LineStringSnapper from JTS-1.10
-2009-05-02 10:59 Sandro Santilli <strk at keybit.net>
+2009-05-02 10:59 Sandro Santilli <strk at kbt.io>
* [r2457] source/geom/CoordinateArraySequence.cpp,
source/headers/geos/geom/CoordinateArraySequence.h,
@@ -10648,7 +12644,7 @@
CoordinateList of JTS, historically bound to CoordinateSequence
in GEOS. Add test for that interface.
-2009-05-02 09:44 Sandro Santilli <strk at keybit.net>
+2009-05-02 09:44 Sandro Santilli <strk at kbt.io>
* [r2456] tests/xmltester/Makefile.am,
tests/xmltester/tests/general/MISSING,
@@ -10656,18 +12652,18 @@
last portable JTS general test, add a file with info about what's
missing
-2009-05-02 09:42 Sandro Santilli <strk at keybit.net>
+2009-05-02 09:42 Sandro Santilli <strk at kbt.io>
* [r2455] tests/xmltester/tests/testLeaksBig.xml: Drop test also
found in TestFunctionPLPrec.xml
-2009-05-02 09:40 Sandro Santilli <strk at keybit.net>
+2009-05-02 09:40 Sandro Santilli <strk at kbt.io>
* [r2454] tests/xmltester/XMLTester.cpp: Add support for testing
within, covers and coveredby. Properly use 'arg1' and 'arg2' for
these tests.
-2009-05-02 09:25 Sandro Santilli <strk at keybit.net>
+2009-05-02 09:25 Sandro Santilli <strk at kbt.io>
* [r2453] tests/xmltester/Makefile.am,
tests/xmltester/tests/general/TestWithinDistance.xml,
@@ -10675,7 +12671,7 @@
TestWithinDistance.xml test, drop duplicates from
testLeaksBig.xml
-2009-05-02 09:20 Sandro Santilli <strk at keybit.net>
+2009-05-02 09:20 Sandro Santilli <strk at kbt.io>
* [r2452] tests/xmltester/Makefile.am,
tests/xmltester/tests/general/TestFunctionAA.xml,
@@ -10690,19 +12686,19 @@
tests/xmltester/tests/general/TestFunctionPP.xml: More tests from
JTS (TestFunction*)
-2009-05-02 09:17 Sandro Santilli <strk at keybit.net>
+2009-05-02 09:17 Sandro Santilli <strk at kbt.io>
* [r2451] tests/xmltester/Makefile.am,
tests/xmltester/tests/general/TestBoundary.xml: Boundary test
-2009-05-02 09:16 Sandro Santilli <strk at keybit.net>
+2009-05-02 09:16 Sandro Santilli <strk at kbt.io>
* [r2450] tests/xmltester/Makefile.am,
tests/xmltester/tests/general/TestConvexHull-big.xml,
tests/xmltester/tests/general/TestConvexHull.xml: ConvexHull
tests
-2009-05-02 09:11 Sandro Santilli <strk at keybit.net>
+2009-05-02 09:11 Sandro Santilli <strk at kbt.io>
* [r2449] tests/xmltester/Makefile.am,
@@ -10716,7 +12712,7 @@
tests/xmltester/tests/general/TestRelatePP.xml: Add support for
testing 'contains' in XMLTester, add all Relate tests from JTS
-2009-05-02 09:01 Sandro Santilli <strk at keybit.net>
+2009-05-02 09:01 Sandro Santilli <strk at kbt.io>
* [r2448] tests/xmltester/Makefile.am,
tests/xmltester/tests/TestBuffer.xml,
@@ -10738,7 +12734,7 @@
tests/xmltester/tests/general/TestValid2.xml: More organization
of xml tests: 'general' subdir following JTS
-2009-05-02 08:44 Sandro Santilli <strk at keybit.net>
+2009-05-02 08:44 Sandro Santilli <strk at kbt.io>
* [r2447] tests/xmltester/Makefile.am, tests/xmltester/tests/stmlf,
tests/xmltester/tests/stmlf-cases-20061020.xml,
@@ -10747,7 +12743,7 @@
tests/xmltester/tests/stmlf/stmlf-cases-20070119.xml: Put stml
testcases under their own dir (like in JTS)
-2009-05-02 08:37 Sandro Santilli <strk at keybit.net>
+2009-05-02 08:37 Sandro Santilli <strk at kbt.io>
* [r2446] tests/xmltester/Makefile.am,
tests/xmltester/tests/TestRobustOverlayFixed.xml,
@@ -10759,90 +12755,90 @@
TestRobustRelate.xml from JTS, organize robust-related tests as
in JTS repository.
-2009-04-30 12:42 Sandro Santilli <strk at keybit.net>
+2009-04-30 12:42 Sandro Santilli <strk at kbt.io>
* [r2444] source/headers/geos/noding/snapround/SimpleSnapRounder.h:
drop duplicated (and old) port info
-2009-04-30 12:33 Sandro Santilli <strk at keybit.net>
+2009-04-30 12:33 Sandro Santilli <strk at kbt.io>
* [r2443] NEWS, source/geom/Geometry.cpp,
source/headers/geos/geom/Geometry.inl: Update port info
-2009-04-30 12:17 Sandro Santilli <strk at keybit.net>
+2009-04-30 12:17 Sandro Santilli <strk at kbt.io>
* [r2442] source/geom/Point.cpp, source/headers/geos/geom/Point.h:
Point full up to JTS-1.0 (rev 1.37) : adds reverse()
-2009-04-30 12:07 Sandro Santilli <strk at keybit.net>
+2009-04-30 12:07 Sandro Santilli <strk at kbt.io>
* [r2441] source/geom/LineString.cpp,
source/headers/geos/geom/LineString.h: LineString to rev 1.46 :
don't override isSimple, always return MultiPoint as bondary
-2009-04-30 11:47 Sandro Santilli <strk at keybit.net>
+2009-04-30 11:47 Sandro Santilli <strk at kbt.io>
* [r2440] source/geom/Polygon.cpp,
source/headers/geos/geom/Polygon.h: Polygon to rev 1.50
(getBoundary always return MultiLineString)
-2009-04-30 11:42 Sandro Santilli <strk at keybit.net>
+2009-04-30 11:42 Sandro Santilli <strk at kbt.io>
* [r2439] source/geom/MultiPoint.cpp,
source/headers/geos/geom/MultiPoint.h: MultiPoint up to rev 1.30
(drop isSimple override)
-2009-04-30 11:36 Sandro Santilli <strk at keybit.net>
+2009-04-30 11:36 Sandro Santilli <strk at kbt.io>
* [r2438] source/geom/MultiLineString.cpp,
source/headers/geos/geom/MultiLineString.h,
source/headers/geos/geom/MultiLineString.inl: MultiLineString
port info and sync to 1.40 (don't override isSimple)
-2009-04-30 11:29 Sandro Santilli <strk at keybit.net>
+2009-04-30 11:29 Sandro Santilli <strk at kbt.io>
* [r2437] source/geom/MultiPolygon.cpp,
source/headers/geos/geom/MultiPolygon.h,
source/headers/geos/geom/MultiPolygon.inl: MultiPolygon up to rev
1.34 (getBoundary always returns a MultiLineString now)
-2009-04-30 11:19 Sandro Santilli <strk at keybit.net>
+2009-04-30 11:19 Sandro Santilli <strk at kbt.io>
* [r2436] source/geom/GeometryCollection.cpp,
source/headers/geos/geom/GeometryCollection.h: Oops, *now* we're
at 1.14 (drop isSimple, rely on the one in base class)
-2009-04-30 11:15 Sandro Santilli <strk at keybit.net>
+2009-04-30 11:15 Sandro Santilli <strk at kbt.io>
* [r2435] source/geom/GeometryCollection.cpp,
source/headers/geos/geom/GeometryCollection.h,
source/headers/geos/geom/GeometryCollection.inl: Port info. It's
at 1.41 now, JTS is at 1.42
-2009-04-30 11:03 Sandro Santilli <strk at keybit.net>
+2009-04-30 11:03 Sandro Santilli <strk at kbt.io>
* [r2434] source/geom/Geometry.cpp,
source/headers/geos/geom/Geometry.inl: Geometry class up to JTS
rev 1.104 (need reach 1.127...)
-2009-04-30 10:59 Sandro Santilli <strk at keybit.net>
+2009-04-30 10:59 Sandro Santilli <strk at kbt.io>
* [r2433] NEWS: Add some info about things changed (might have
missed something)
-2009-04-30 10:51 Sandro Santilli <strk at keybit.net>
+2009-04-30 10:51 Sandro Santilli <strk at kbt.io>
* [r2432] source/headers/geos/operation/IsSimpleOp.h,
source/operation/IsSimpleOp.cpp: Sync to rev 1.22 (JTS-1.10)
-2009-04-30 10:47 Sandro Santilli <strk at keybit.net>
+2009-04-30 10:47 Sandro Santilli <strk at kbt.io>
* [r2431] source/headers/geos/operation.h: EndpointInfo.h header is
gone (it's always been private in JTS)
-2009-04-30 10:46 Sandro Santilli <strk at keybit.net>
+2009-04-30 10:46 Sandro Santilli <strk at kbt.io>
* [r2430] source/headers/geos/operation/EndpointInfo.h,
@@ -10850,26 +12846,26 @@
source/operation/IsSimpleOp.cpp: Port revision 1.9 of IsSimplOp :
allow inspecting non-simple location coordinate.
-2009-04-30 10:43 Sandro Santilli <strk at keybit.net>
+2009-04-30 10:43 Sandro Santilli <strk at kbt.io>
* [r2429] source/geomgraph/EdgeIntersection.cpp,
source/headers/geos/geomgraph/EdgeIntersection.h: Sync to
revision 1.5 (JTS-1.10) : add accessors
-2009-04-30 09:54 Sandro Santilli <strk at keybit.net>
+2009-04-30 09:54 Sandro Santilli <strk at kbt.io>
* [r2428] source/headers/geos/operation/IsSimpleOp.h,
source/operation/IsSimpleOp.cpp: port to rev 1.8 (use of
BoundaryNodeRule)
-2009-04-30 09:49 Sandro Santilli <strk at keybit.net>
+2009-04-30 09:49 Sandro Santilli <strk at kbt.io>
* [r2427] tests/xmltester/Makefile.am,
tests/xmltester/tests/TestSimple.xml,
tests/xmltester/tests/testLeaksBig.xml: Import TestSimple.xml
from JTS, drop duplicated tests from testLeaksBig.xml
-2009-04-30 09:26 Sandro Santilli <strk at keybit.net>
+2009-04-30 09:26 Sandro Santilli <strk at kbt.io>
* [r2426] source/algorithm/BoundaryNodeRule.cpp,
source/algorithm/Makefile.am,
@@ -10878,7 +12874,7 @@
algorithm::BoundaryNodeRule from JTS-1.10 (needed for IsSimpleOp
sync)
-2009-04-30 08:33 Sandro Santilli <strk at keybit.net>
+2009-04-30 08:33 Sandro Santilli <strk at kbt.io>
* [r2425] source/headers/geos/operation/IsSimpleOp.h,
source/operation/IsSimpleOp.cpp: Port info, and sync from 1.14 to
@@ -10912,13 +12908,13 @@
tests does not reproduce the problem, so it likely has been fixed
or the bug is somewhere else (i.e. Django layers).
-2009-04-29 09:44 Sandro Santilli <strk at keybit.net>
+2009-04-29 09:44 Sandro Santilli <strk at kbt.io>
* [r2421] source/headers/geos/util/GeometricShapeFactory.h,
source/util/GeometricShapeFactory.cpp: Sync GeometricShapeFactory
to JTS-1.10 (createArcPolygon added)
-2009-04-29 08:56 Sandro Santilli <strk at keybit.net>
+2009-04-29 08:56 Sandro Santilli <strk at kbt.io>
* [r2420] source/geom/prep/AbstractPreparedPolygonContains.cpp,
source/geom/prep/PreparedPolygonContainsProperly.cpp,
@@ -10932,14 +12928,14 @@
source/headers/geos/geom/prep/PreparedPolygonPredicate.h: Bring
all geom::prep package in sync with JTS-1.10
-2009-04-29 08:22 Sandro Santilli <strk at keybit.net>
+2009-04-29 08:22 Sandro Santilli <strk at kbt.io>
* [r2419] source/geom/prep/BasicPreparedGeometry.cpp,
source/headers/geos/geom/prep/BasicPreparedGeometry.h: Sync
BasicPreparedGeometry to JTS-1.10 (short-circuit in
containsProperly)
-2009-04-29 08:15 Sandro Santilli <strk at keybit.net>
+2009-04-29 08:15 Sandro Santilli <strk at kbt.io>
* [r2418] source/geom/prep/AbstractPreparedPolygonContains.cpp,
@@ -10970,17 +12966,17 @@
port information for geom::prep package. Next stop: sync to
JTS-1.10.
-2009-04-27 19:47 Sandro Santilli <strk at keybit.net>
+2009-04-27 19:47 Sandro Santilli <strk at kbt.io>
* [r2417] tests/unit/capi/GEOSGeomToWKTTest.cpp: Plug last one. All
heap blocks were freed -- no leaks are possible.
-2009-04-27 19:42 Sandro Santilli <strk at keybit.net>
+2009-04-27 19:42 Sandro Santilli <strk at kbt.io>
* [r2416] tests/unit/algorithm/RobustLineIntersectorTest.cpp: Fix
leak in testcase
-2009-04-27 19:38 Sandro Santilli <strk at keybit.net>
+2009-04-27 19:38 Sandro Santilli <strk at kbt.io>
* [r2415] source/headers/geos/index/quadtree/Node.h,
source/headers/geos/index/quadtree/Root.h,
@@ -10988,41 +12984,41 @@
Refactor signatures to make ownership transfers more explicit.
Fixed another leak in Node::insertNode.
-2009-04-27 19:22 Sandro Santilli <strk at keybit.net>
+2009-04-27 19:22 Sandro Santilli <strk at kbt.io>
* [r2414] source/index/quadtree/NodeBase.cpp: Fix memory leak in
NodeBase::remove, exposed by unit testing
-2009-04-27 15:52 Sandro Santilli <strk at keybit.net>
+2009-04-27 15:52 Sandro Santilli <strk at kbt.io>
* [r2413] source/headers/geos/index/quadtree/Root.h,
source/index/quadtree/Root.cpp: Port info for quadtree::root
-2009-04-27 15:47 Sandro Santilli <strk at keybit.net>
+2009-04-27 15:47 Sandro Santilli <strk at kbt.io>
* [r2412] source/headers/geos/index/quadtree/Node.h,
source/index/quadtree/Node.cpp: Port info for quadtree::Node
-2009-04-27 15:39 Sandro Santilli <strk at keybit.net>
+2009-04-27 15:39 Sandro Santilli <strk at kbt.io>
* [r2411] source/headers/geos/index/quadtree/IntervalSize.h,
source/index/quadtree/IntervalSize.cpp: Port info and check,
doxygen.
-2009-04-27 15:30 Sandro Santilli <strk at keybit.net>
+2009-04-27 15:30 Sandro Santilli <strk at kbt.io>
* [r2410] source/headers/geos/index/quadtree/Quadtree.h,
source/index/quadtree/Quadtree.cpp: Sync to JTS-1.10, reduce heap
allocations and pointers usage. Includes a bugfix in
collectStats.
-2009-04-27 15:00 Sandro Santilli <strk at keybit.net>
+2009-04-27 15:00 Sandro Santilli <strk at kbt.io>
* [r2409] source/headers/geos/index/quadtree/DoubleBits.h,
source/index/quadtree/DoubleBits.cpp: DoubleBits didn't change in
JTS, update port info accordingly
-2009-04-27 14:58 Sandro Santilli <strk at keybit.net>
+2009-04-27 14:58 Sandro Santilli <strk at kbt.io>
* [r2408] source/headers/geos/index/quadtree/Node.h,
source/headers/geos/index/quadtree/NodeBase.h,
@@ -11032,7 +13028,7 @@
port sync, add port info, drop unneeded pointers and virtuals,
document objects ownership.
-2009-04-25 00:23 Sandro Santilli <strk at keybit.net>
+2009-04-25 00:23 Sandro Santilli <strk at kbt.io>
* [r2407] source/headers/geos/index/SpatialIndex.h,
source/headers/geos/index/quadtree/Key.h,
@@ -11042,12 +13038,12 @@
allocations and port info for quadtree::Key class, a few more
cleanups in user classes, to be continued.
-2009-04-24 23:44 Sandro Santilli <strk at keybit.net>
+2009-04-24 23:44 Sandro Santilli <strk at kbt.io>
* [r2406] source/index/quadtree/Quadtree.cpp: Fix memory leak in
Quadtree::remove
-2009-04-23 15:26 Sandro Santilli <strk at keybit.net>
+2009-04-23 15:26 Sandro Santilli <strk at kbt.io>
* [r2405] source/headers/geos/operation/buffer/BufferBuilder.h,
@@ -11056,50 +13052,50 @@
source/operation/buffer/OffsetCurveVertexList.h: Apply
Single-sided buffer patch, issue #215. UNTESTED.
-2009-04-21 16:11 Sandro Santilli <strk at keybit.net>
+2009-04-21 16:11 Sandro Santilli <strk at kbt.io>
* [r2404] tests/unit/Makefile.am,
tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp:
Port ValidSelfTouchingRingFormingHoleTest
-2009-04-21 15:30 Sandro Santilli <strk at keybit.net>
+2009-04-21 15:30 Sandro Santilli <strk at kbt.io>
* [r2403] tests/unit/Makefile.am,
tests/unit/operation/valid/ValidClosedRingTest.cpp: Port
ValidClosedRingTest
-2009-04-21 15:13 Sandro Santilli <strk at keybit.net>
+2009-04-21 15:13 Sandro Santilli <strk at kbt.io>
* [r2402] source/geom/LineString.cpp,
source/headers/geos/geom/LineString.h: ::reverse returns a
Geometry now (to be available up in base class)
-2009-04-21 15:12 Sandro Santilli <strk at keybit.net>
+2009-04-21 15:12 Sandro Santilli <strk at kbt.io>
* [r2401] source/geom/LinearRing.cpp,
source/headers/geos/geom/LinearRing.h,
tests/unit/geom/LinearRingTest.cpp: Sync LinearRing to JTS-1.10
(fixing a bug in isClosed)
-2009-04-21 14:03 Sandro Santilli <strk at keybit.net>
+2009-04-21 14:03 Sandro Santilli <strk at kbt.io>
* [r2400] tests/unit/Makefile.am, tests/unit/operation/valid,
tests/unit/operation/valid/IsValidTest.cpp: Port IsValidOp unit
test
-2009-04-21 11:14 Sandro Santilli <strk at keybit.net>
+2009-04-21 11:14 Sandro Santilli <strk at kbt.io>
* [r2399] configure.in: Configure for CXX, not C. Should fix
unknown tag and link issues on telascience.
-2009-04-21 09:06 Sandro Santilli <strk at keybit.net>
+2009-04-21 09:06 Sandro Santilli <strk at kbt.io>
* [r2398] configure.in: Add an AC_LIBTOOL_LANG_C_CONFIG call right
before the AC_LIBTOOL_COMPILER_OPTION calls. Seems to fix
compiler selection on telascience (whereas AC_LANG and
AC_LANG_PUSH didn't work)
-2009-04-20 20:32 Sandro Santilli <strk at keybit.net>
+2009-04-20 20:32 Sandro Santilli <strk at kbt.io>
* [r2397] tests/xmltester/BufferResultMatcher.cpp,
tests/xmltester/BufferResultMatcher.h: Use JTS heuristic for
@@ -11110,7 +13106,7 @@
* [r2396] tests/perf, tests/perf/operation,
tests/perf/operation/buffer: Updated svn:ignore patterns.
-2009-04-20 10:37 Sandro Santilli <strk at keybit.net>
+2009-04-20 10:37 Sandro Santilli <strk at kbt.io>
* [r2395] configure.in, tests/Makefile.am, tests/perf,
tests/perf/Makefile.am, tests/perf/operation,
@@ -11119,7 +13115,7 @@
tests/perf/operation/buffer/Makefile.am: Port
IteratedBufferStessTest
-2009-04-20 09:37 Sandro Santilli <strk at keybit.net>
+2009-04-20 09:37 Sandro Santilli <strk at kbt.io>
* [r2394] source/geomgraph/Quadrant.cpp,
source/headers/geos/geomgraph/Quadrant.h: Add named constants,
@@ -11131,116 +13127,116 @@
source/headers/geos/algorithm/distance: Updated svn:ignore
patterns.
-2009-04-18 07:55 Sandro Santilli <strk at keybit.net>
+2009-04-18 07:55 Sandro Santilli <strk at kbt.io>
* [r2392] tests/xmltester/XMLTester.cpp: Use BufferResultMatcher
for buffer operations. No failures.
-2009-04-18 07:49 Sandro Santilli <strk at keybit.net>
+2009-04-18 07:49 Sandro Santilli <strk at kbt.io>
* [r2391] tests/xmltester/tests/TestBigNastyBuffer.xml: Imported
cleaned-up version of fme.xml -- this one fails (the one we have
is actually expecting a wrong result)
-2009-04-18 07:46 Sandro Santilli <strk at keybit.net>
+2009-04-18 07:46 Sandro Santilli <strk at kbt.io>
* [r2390] tests/xmltester/BufferResultMatcher.cpp: Don't densify
coordinates if buffer distance is 0
-2009-04-17 16:50 Sandro Santilli <strk at keybit.net>
+2009-04-17 16:50 Sandro Santilli <strk at kbt.io>
* [r2389]
tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp:
comment out debugging lines
-2009-04-17 16:49 Sandro Santilli <strk at keybit.net>
+2009-04-17 16:49 Sandro Santilli <strk at kbt.io>
* [r2388] tests/unit/Makefile.am, tests/unit/algorithm/distance,
Port DiscreteHausdorffDistance unit test
-2009-04-17 16:47 Sandro Santilli <strk at keybit.net>
+2009-04-17 16:47 Sandro Santilli <strk at kbt.io>
* [r2387] source/algorithm/distance/DiscreteHausdorffDistance.cpp,
source/headers/geos/algorithm/distance/DiscreteHausdorffDistance.h:
Offline some more
-2009-04-17 16:46 Sandro Santilli <strk at keybit.net>
+2009-04-17 16:46 Sandro Santilli <strk at kbt.io>
* [r2386]
source/headers/geos/algorithm/distance/PointPairDistance.h: Fix
typo
-2009-04-17 16:26 Sandro Santilli <strk at keybit.net>
+2009-04-17 16:26 Sandro Santilli <strk at kbt.io>
* [r2385] source/algorithm/distance/DiscreteHausdorffDistance.cpp,
Add missing implementation bits
-2009-04-17 15:47 Sandro Santilli <strk at keybit.net>
+2009-04-17 15:47 Sandro Santilli <strk at kbt.io>
* [r2384] tests/xmltester/BufferResultMatcher.cpp,
tests/xmltester/BufferResultMatcher.h,
tests/xmltester/XMLTester.cpp: Port BufferResultMatcher. Gives 31
new failures !!
-2009-04-17 15:37 Sandro Santilli <strk at keybit.net>
+2009-04-17 15:37 Sandro Santilli <strk at kbt.io>
* [r2383] source/headers/geos/geom/BinaryOp.h,
tests/xmltester/Makefile.am, tests/xmltester/XMLTester.cpp:
proper inline check_valid source/headers/geos/geom/BinaryOp.h
-2009-04-17 15:34 Sandro Santilli <strk at keybit.net>
+2009-04-17 15:34 Sandro Santilli <strk at kbt.io>
* [r2382] source/headers/geos/geom/BinaryOp.h: Header guard
-2009-04-17 13:59 Sandro Santilli <strk at keybit.net>
+2009-04-17 13:59 Sandro Santilli <strk at kbt.io>
* [r2381] source/algorithm/LineIntersector.cpp,
source/headers/geos/algorithm/LineIntersector.h,
tests/unit/algorithm/RobustLineIntersectorTest.cpp: renamed
intersection constants
-2009-04-17 09:56 Sandro Santilli <strk at keybit.net>
+2009-04-17 09:56 Sandro Santilli <strk at kbt.io>
* [r2380] configure.in: Add debugging output of variables used by
AC_LIBTOOL_COMPILER_OPTION. Surprisingly, the buildbots try to
use a fortran compiler there
-2009-04-17 07:50 Sandro Santilli <strk at keybit.net>
+2009-04-17 07:50 Sandro Santilli <strk at kbt.io>
* [r2379] configure.in: Differentiate variable used in
AC_LIBTOOL_COMPILE_OPTION for proper use of configuration cache
-2009-04-16 18:05 Sandro Santilli <strk at keybit.net>
+2009-04-16 18:05 Sandro Santilli <strk at kbt.io>
* [r2378] configure.in: Use -ffloat-store flag when available. See
http://lists.osgeo.org/pipermail/geos-devel/2009-April/004089.html
-2009-04-16 12:56 Sandro Santilli <strk at keybit.net>
+2009-04-16 12:56 Sandro Santilli <strk at kbt.io>
* [r2377] source/headers/geos/algorithm/LineIntersector.h: Make
enum values explicit, as JTS tests rely on those..
-2009-04-16 12:54 Sandro Santilli <strk at keybit.net>
+2009-04-16 12:54 Sandro Santilli <strk at kbt.io>
* [r2376] tests/unit/Makefile.am,
tests/unit/algorithm/RobustLineIntersectorTest.cpp: Port
RobustLineIntersectorTest from JTS
-2009-04-16 12:08 Sandro Santilli <strk at keybit.net>
+2009-04-16 12:08 Sandro Santilli <strk at kbt.io>
* [r2375] tests/unit/algorithm/RobustLineIntersectionTest.cpp:
better isolation of test-specific functions
-2009-04-16 10:48 Sandro Santilli <strk at keybit.net>
+2009-04-16 10:48 Sandro Santilli <strk at kbt.io>
* [r2374] tests/unit/Makefile.am,
tests/unit/algorithm/RobustLineIntersectionTest.cpp: Port
RobustLineIntersectionTest (mostly failing, but reported by
Martin Davis to be expected)
-2009-04-15 15:58 Sandro Santilli <strk at keybit.net>
+2009-04-15 15:58 Sandro Santilli <strk at kbt.io>
* [r2373] source/algorithm/distance/DiscreteHausdorffDistance.cpp,
@@ -11252,12 +13248,12 @@
source/headers/geos/algorithm/distance/Makefile.am: New class
rename, following JTS
-2009-04-15 12:56 Sandro Santilli <strk at keybit.net>
+2009-04-15 12:56 Sandro Santilli <strk at kbt.io>
* [r2372] source/algorithm/HCoordinate.cpp: typo in disabled
section
-2009-04-15 11:17 Sandro Santilli <strk at keybit.net>
+2009-04-15 11:17 Sandro Santilli <strk at kbt.io>
* [r2371] source/headers/geos/index/quadtree/Key.h,
@@ -11265,17 +13261,17 @@
management in quadtree indexing; fix a potential leak in
quadtree::Key
-2009-04-15 10:43 Sandro Santilli <strk at keybit.net>
+2009-04-15 10:43 Sandro Santilli <strk at kbt.io>
* [r2370] source/headers/geos/index/quadtree/NodeBase.h: Document
ownership of quadtree::NodeBase subnodes
-2009-04-15 10:18 Sandro Santilli <strk at keybit.net>
+2009-04-15 10:18 Sandro Santilli <strk at kbt.io>
* [r2369] tests/unit/util/UniqueCoordinateArrayFilterTest.cpp: Fix
memory leak in unit test
-2009-04-15 10:02 Sandro Santilli <strk at keybit.net>
+2009-04-15 10:02 Sandro Santilli <strk at kbt.io>
* [r2368] source/headers/geos/geom/CoordinateSequence.h,
source/headers/geos/geom/util/CoordinateOperation.h,
@@ -11283,14 +13279,14 @@
SimpleGeometryPrecisionReducer, improve memory management docs
where topic.
-2009-04-15 09:29 Sandro Santilli <strk at keybit.net>
+2009-04-15 09:29 Sandro Santilli <strk at kbt.io>
* [r2367] source/headers/geos/operation/distance/DistanceOp.h,
tests/unit/operation/distance/DistanceOpTest.cpp: Document
ownership of DistanceOp::closestPoints return, fix leak in unit
test.
-2009-04-15 09:25 Sandro Santilli <strk at keybit.net>
+2009-04-15 09:25 Sandro Santilli <strk at kbt.io>
* [r2366] source/geomgraph/EdgeRing.cpp,
source/headers/geos/geomgraph/EdgeRing.h,
@@ -11302,22 +13298,22 @@
stmlf-cases-20061020.xml testcase. This commit also adds some
doc-only throw specs related to the bug.
-2009-04-15 07:52 Sandro Santilli <strk at keybit.net>
+2009-04-15 07:52 Sandro Santilli <strk at kbt.io>
* [r2365] source/operation/valid/IndexedNestedRingTester.cpp: Fix
memory leaks in IsValid operation
-2009-04-15 00:27 Sandro Santilli <strk at keybit.net>
+2009-04-15 00:27 Sandro Santilli <strk at kbt.io>
* [r2364] source/algorithm/HCoordinate.cpp: Explain why unrolled
computation is turned off, and keep it off
-2009-04-15 00:14 Sandro Santilli <strk at keybit.net>
+2009-04-15 00:14 Sandro Santilli <strk at kbt.io>
* [r2363] source/operation/buffer/BufferInputLineSimplifier.cpp:
Fix typo in computing angleOrientation
-2009-04-14 19:11 Sandro Santilli <strk at keybit.net>
+2009-04-14 19:11 Sandro Santilli <strk at kbt.io>
* [r2362] source/algorithm/HCoordinate.cpp,
@@ -11326,7 +13322,7 @@
mitred join buffer test from JTS (failed with the unrolled comp,
to be further inspected).
-2009-04-14 16:43 Sandro Santilli <strk at keybit.net>
+2009-04-14 16:43 Sandro Santilli <strk at kbt.io>
* [r2361] configure.in, source/algorithm/Makefile.am,
source/algorithm/distance,
@@ -11342,7 +13338,7 @@
source/headers/geos/geom/CoordinateSequenceFilter.h: Port the
algorithm::distance package from JTS 1.9
-2009-04-14 15:25 Sandro Santilli <strk at keybit.net>
+2009-04-14 15:25 Sandro Santilli <strk at kbt.io>
* [r2360] source/geom/Geometry.cpp,
@@ -11359,19 +13355,19 @@
support, fix default GeometryComponentFilter moving the logic to
the correct place (a Geometry private class).
-2009-04-14 13:35 Sandro Santilli <strk at keybit.net>
+2009-04-14 13:35 Sandro Santilli <strk at kbt.io>
* [r2359] source/algorithm/LineIntersector.cpp,
source/headers/geos/algorithm/LineIntersector.h: Sync
(Robust)LineIntersector to JTS-1.9
-2009-04-14 13:23 Sandro Santilli <strk at keybit.net>
+2009-04-14 13:23 Sandro Santilli <strk at kbt.io>
* [r2358] source/algorithm/CGAlgorithms.cpp,
source/headers/geos/algorithm/CGAlgorithms.h: Sync CGAlgorithms
with JTS-1.9
-2009-04-14 12:55 Sandro Santilli <strk at keybit.net>
+2009-04-14 12:55 Sandro Santilli <strk at kbt.io>
* [r2357] source/algorithm/RayCrossingCounter.cpp,
@@ -11380,13 +13376,13 @@
when unneeded; add a locatePointInRing taking a vector of
coordinate pointers, for use by CGAlgorithms
-2009-04-14 12:42 Sandro Santilli <strk at keybit.net>
+2009-04-14 12:42 Sandro Santilli <strk at kbt.io>
* [r2356] source/algorithm/RayCrossingCounter.cpp,
source/headers/geos/algorithm/RayCrossingCounter.h: Update port
info, checked against JTS-1.9
-2009-04-14 11:03 Sandro Santilli <strk at keybit.net>
+2009-04-14 11:03 Sandro Santilli <strk at kbt.io>
* [r2355] tests/xmltester/Makefile.am,
tests/xmltester/TestBuffer.xml,
@@ -11433,17 +13429,17 @@
tests/xmltester/tests/testLeaksBig.xml: Move XML tests under
their own directory
-2009-04-14 10:50 Sandro Santilli <strk at keybit.net>
+2009-04-14 10:50 Sandro Santilli <strk at kbt.io>
* [r2354] source/operation/buffer/BufferBuilder.cpp: Fix memory
leak in BufferBuilder (due to just-ported short-circuit)
-2009-04-14 10:27 Sandro Santilli <strk at keybit.net>
+2009-04-14 10:27 Sandro Santilli <strk at kbt.io>
* [r2353] tests/xmltester/XMLTester.cpp: Add support for
bufferMitredJoin tests
-2009-04-14 09:53 Sandro Santilli <strk at keybit.net>
+2009-04-14 09:53 Sandro Santilli <strk at kbt.io>
* [r2352] tests/xmltester/Makefile.am,
@@ -11456,27 +13452,27 @@
arg3 for quadrant segments); copy buffer-related tests from jts:
they succeed w/out editing.
-2009-04-14 09:22 Sandro Santilli <strk at keybit.net>
+2009-04-14 09:22 Sandro Santilli <strk at kbt.io>
* [r2351]
source/headers/geos/operation/buffer/SubgraphDepthLocater.h,
info of SubgraphDepthLocater
-2009-04-14 09:19 Sandro Santilli <strk at keybit.net>
+2009-04-14 09:19 Sandro Santilli <strk at kbt.io>
* [r2350]
source/headers/geos/operation/buffer/RightmostEdgeFinder.h,
source/operation/buffer/RightmostEdgeFinder.cpp: Update port info
for RightmostEdgeFinder (checked)
-2009-04-14 09:14 Sandro Santilli <strk at keybit.net>
+2009-04-14 09:14 Sandro Santilli <strk at kbt.io>
* [r2349] source/headers/geos/operation/buffer/BufferSubgraph.h,
source/operation/buffer/BufferSubgraph.cpp: Sync BufferSubgraph
to JTS-1.9
-2009-04-14 08:52 Sandro Santilli <strk at keybit.net>
+2009-04-14 08:52 Sandro Santilli <strk at kbt.io>
* [r2348]
source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
@@ -11484,7 +13480,7 @@
OffsetCurveBuilder from JTS-1.9. Twenty time faster completion of
fme.xml testcase !
-2009-04-10 20:22 Sandro Santilli <strk at keybit.net>
+2009-04-10 20:22 Sandro Santilli <strk at kbt.io>
* [r2347] source/operation/buffer/BufferInputLineSimplifier.cpp,
source/operation/buffer/BufferInputLineSimplifier.h,
@@ -11496,7 +13492,7 @@
* [r2346] configure.in: Do not generate Makefile for
tests/unit/tut. Fixed bug reported as #247.
-2009-04-10 12:08 Sandro Santilli <strk at keybit.net>
+2009-04-10 12:08 Sandro Santilli <strk at kbt.io>
* [r2345] source/geom/LineSegment.cpp,
source/headers/geos/geom/LineSegment.h,
@@ -11576,14 +13572,14 @@
Moved tests/tut to tests/unit/tut. Preparing for update to latest
version of C++ TUT Framework.
-2009-04-09 16:22 Sandro Santilli <strk at keybit.net>
+2009-04-09 16:22 Sandro Santilli <strk at kbt.io>
* [r2342] source/algorithm/Angle.cpp, source/algorithm/Makefile.am,
source/headers/geos/algorithm/Angle.h,
source/headers/geos/algorithm/Makefile.am: Port algorithm.Angle
from JTS-1.9
-2009-04-09 11:45 Sandro Santilli <strk at keybit.net>
+2009-04-09 11:45 Sandro Santilli <strk at kbt.io>
* [r2341] source/headers/geos/operation/buffer/BufferBuilder.h,
@@ -11595,12 +13591,12 @@
OffsetCurveBuilder to use of BufferParameter (needs more work for
JTS-sync).
-2009-04-09 10:21 Sandro Santilli <strk at keybit.net>
+2009-04-09 10:21 Sandro Santilli <strk at kbt.io>
* [r2340] source/headers/geos/operation/buffer/BufferParameters.h:
typo
-2009-04-09 09:45 Sandro Santilli <strk at keybit.net>
+2009-04-09 09:45 Sandro Santilli <strk at kbt.io>
* [r2339] source/headers/geos/operation/buffer/BufferParameters.h,
source/headers/geos/operation/buffer/Makefile.am,
@@ -11608,14 +13604,14 @@
source/operation/buffer/Makefile.am: Port BufferParameters from
JTS-1.9
-2009-04-09 08:54 Sandro Santilli <strk at keybit.net>
+2009-04-09 08:54 Sandro Santilli <strk at kbt.io>
* [r2338] source/operation/buffer/OffsetCurveBuilder.cpp,
source/operation/buffer/OffsetCurveVertexList.h: Sync port of
OffsetCurveVertexList to JTS-1.9, improve memory management
documentation (would need some refactoring/love)
-2009-04-08 16:52 Sandro Santilli <strk at keybit.net>
+2009-04-08 16:52 Sandro Santilli <strk at kbt.io>
* [r2337] source/geomgraph/EdgeList.cpp,
source/headers/geos/geomgraph/EdgeList.h,
@@ -11623,17 +13619,17 @@
duplicate edge detection performance (JTS-1.9 sync) - fme.xml
runs 3 times as fast now.
-2009-04-08 16:17 Sandro Santilli <strk at keybit.net>
+2009-04-08 16:17 Sandro Santilli <strk at kbt.io>
* [r2332] source/noding/OrientedCoordinateArray.cpp: const
correctness
-2009-04-08 15:38 Sandro Santilli <strk at keybit.net>
+2009-04-08 15:38 Sandro Santilli <strk at kbt.io>
* [r2329] capi/geos_c.h.in: Fix documentation for GEOSPrepare,
GEOSPrepare_r
-2009-04-08 14:54 Sandro Santilli <strk at keybit.net>
+2009-04-08 14:54 Sandro Santilli <strk at kbt.io>
* [r2328] source/headers/geos/noding/Makefile.am,
source/headers/geos/noding/OrientedCoordinateArray.h,
@@ -11641,7 +13637,7 @@
OrientedCoordinateArray ported from JTS
-2009-04-08 14:41 Sandro Santilli <strk at keybit.net>
+2009-04-08 14:41 Sandro Santilli <strk at kbt.io>
* [r2327] source/geom/CoordinateSequence.cpp,
source/headers/geos/geom/CoordinateSequence.h: Add
@@ -11649,39 +13645,39 @@
(GEOS puts all of them in CoordinateSequence for historical
reasons)
-2009-04-08 13:16 Sandro Santilli <strk at keybit.net>
+2009-04-08 13:16 Sandro Santilli <strk at kbt.io>
* [r2326] source/headers/geos/noding/snapround/SimpleSnapRounder.h,
source/noding/snapround/SimpleSnapRounder.cpp: Complete porting
of SimpleSnapRounder (refactoring for adding snapped nodes)
-2009-04-08 13:02 Sandro Santilli <strk at keybit.net>
+2009-04-08 13:02 Sandro Santilli <strk at kbt.io>
* [r2325] source/headers/geos/noding/SegmentStringUtil.h: Improve
documentation about memory usage for SegmentStringUtil class
-2009-04-08 12:58 Sandro Santilli <strk at keybit.net>
+2009-04-08 12:58 Sandro Santilli <strk at kbt.io>
* [r2324] tests/unit/Makefile.am,
tests/unit/capi/GEOSPreparedGeometryTest.cpp: Stub initial unit
tests for C-API's GEOSPreparedGeometry operations. Helped fixing
issue 147 of postgis
-2009-04-08 12:55 Sandro Santilli <strk at keybit.net>
+2009-04-08 12:55 Sandro Santilli <strk at kbt.io>
* [r2323] source/geom/prep/PreparedPolygonContainsProperly.cpp:
Don't access deleted memory. Fixes issue 147.
-2009-04-08 10:53 Sandro Santilli <strk at keybit.net>
+2009-04-08 10:53 Sandro Santilli <strk at kbt.io>
* [r2322] source/noding/snapround/HotPixel.cpp: Fix typo
-2009-04-08 10:06 Sandro Santilli <strk at keybit.net>
+2009-04-08 10:06 Sandro Santilli <strk at kbt.io>
* [r2321] tests/unit/noding/SegmentNodeTest.cpp: Add a couple more
tests to SegmentNode unit test
-2009-04-08 09:42 Sandro Santilli <strk at keybit.net>
+2009-04-08 09:42 Sandro Santilli <strk at kbt.io>
* [r2320] source/headers/geos/noding/NodableSegmentString.h,
source/headers/geos/noding/NodedSegmentString.h,
@@ -11692,7 +13688,7 @@
tests/unit/noding/SegmentPointComparatorTest.cpp: Port
SegmentNode to JTS-1.9
-2009-04-07 19:00 Sandro Santilli <strk at keybit.net>
+2009-04-07 19:00 Sandro Santilli <strk at kbt.io>
* [r2319] source/geomgraph/EdgeNodingValidator.cpp,
source/headers/geos/geomgraph/EdgeNodingValidator.h,
@@ -11732,30 +13728,30 @@
tests/unit/noding/SegmentStringTest.cpp: Refactor SegmentString
to be an abstract class, to be in sync with JTS-1.9.
-2009-04-07 12:36 Sandro Santilli <strk at keybit.net>
+2009-04-07 12:36 Sandro Santilli <strk at kbt.io>
* [r2318] source/operation/valid/IndexedNestedRingTester.cpp,
source/operation/valid/IndexedNestedRingTester.h: update
copyright notice
-2009-04-07 11:11 Sandro Santilli <strk at keybit.net>
+2009-04-07 11:11 Sandro Santilli <strk at kbt.io>
* [r2317] source/headers/geos/noding/snapround/HotPixel.h,
source/headers/geos/noding/snapround/HotPixel.inl,
source/noding/snapround/HotPixel.cpp: Sync HotPixel to JTS-1.9
(rev 1.3); fix a few bugs and use standard algorithms for min/max
-2009-04-07 10:48 Sandro Santilli <strk at keybit.net>
+2009-04-07 10:48 Sandro Santilli <strk at kbt.io>
* [r2316] source/headers/geos/noding/NodedSegmentString.h: Fix
signed vs. unsigned compiler warning
-2009-04-07 10:18 Sandro Santilli <strk at keybit.net>
+2009-04-07 10:18 Sandro Santilli <strk at kbt.io>
* [r2315] source/headers/geos/operation/valid/IsValidOp.h: Port
info, indenting
-2009-04-07 09:56 Sandro Santilli <strk at keybit.net>
+2009-04-07 09:56 Sandro Santilli <strk at kbt.io>
* [r2314] source/operation/valid/IndexedNestedRingTester.cpp,
source/operation/valid/IndexedNestedRingTester.h,
@@ -11763,12 +13759,12 @@
source/operation/valid/Makefile.am: Port IndexedNestedRingTester
and have IsValidOp use it, syncing the operation to JTS-1.9
-2009-04-07 09:55 Sandro Santilli <strk at keybit.net>
+2009-04-07 09:55 Sandro Santilli <strk at kbt.io>
* [r2313] source/headers/geos/noding/SegmentStringUtil.h: Update
port info, minor tweaks to doxygen comments
-2009-04-07 08:14 Sandro Santilli <strk at keybit.net>
+2009-04-07 08:14 Sandro Santilli <strk at kbt.io>
* [r2312] source/algorithm/HCoordinate.cpp,
source/headers/geos/algorithm/HCoordinate.h: Sync HCoordinate
@@ -13804,18 +15800,18 @@
* [r1977] ChangeLog, autogen.sh: Added detection of glibtoolize
under Mac OS X.
-2007-03-05 09:58 Sandro Santilli <strk at keybit.net>
+2007-03-05 09:58 Sandro Santilli <strk at kbt.io>
* [r1976] ChangeLog, tests/xmltester/Makefile.am,
tests/xmltester/hole_from_shell.xml,
tests/xmltester/hole_red.xml: Add new testcases by Carl Anderson
-2007-02-26 10:46 Sandro Santilli <strk at keybit.net>
+2007-02-26 10:46 Sandro Santilli <strk at kbt.io>
* [r1975] ChangeLog, source/inlines.cpp: Patch by Tom Elwertowski:
* source/inlines.cpp: fix for MingW32 builds.
-2007-02-21 10:14 Sandro Santilli <strk at keybit.net>
+2007-02-21 10:14 Sandro Santilli <strk at kbt.io>
* [r1974] ChangeLog,
source/operation/buffer/SubgraphDepthLocater.cpp: Patch by Carl
@@ -13828,14 +15824,14 @@
Fixes badguy3.xml
-2007-02-21 10:12 Sandro Santilli <strk at keybit.net>
+2007-02-21 10:12 Sandro Santilli <strk at kbt.io>
* [r1973] ChangeLog, tests/xmltester/Makefile.am,
tests/xmltester/badguy3.xml: * tests/xmltester/: Makefile.am,
badguy3.xml:
Added simplified version of nasty buffer bug test.
-2007-02-08 23:33 Sandro Santilli <strk at keybit.net>
+2007-02-08 23:33 Sandro Santilli <strk at kbt.io>
* [r1972] ChangeLog, configure.in: Patch by Mark Cave-Ayland:
@@ -13843,7 +15839,7 @@
set to false if a python binary is not found, as per
http://sources.redhat.com/automake/automake.html#Python.
-2007-02-07 00:34 Sandro Santilli <strk at keybit.net>
+2007-02-07 00:34 Sandro Santilli <strk at kbt.io>
* [r1971] ChangeLog,
source/headers/geos/index/strtree/AbstractNode.h,
@@ -13864,7 +15860,7 @@
operator for sorting child boundables in STRtree, this
fixes the heisenbug when building with inlines disabled.
-2007-02-06 02:05 Sandro Santilli <strk at keybit.net>
+2007-02-06 02:05 Sandro Santilli <strk at kbt.io>
* [r1970] ChangeLog,
tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp: *
@@ -13872,7 +15868,7 @@
Expect result of POLYGON simplification to always be
a polygon, even if collapsed to the empty geom.
-2007-02-06 01:57 Sandro Santilli <strk at keybit.net>
+2007-02-06 01:57 Sandro Santilli <strk at kbt.io>
* [r1969] ChangeLog,
@@ -13888,7 +15884,7 @@
* [r1967] ChangeLog, configure.in: 3.0.0rc4 tagging
-2007-02-01 11:11 Sandro Santilli <strk at keybit.net>
+2007-02-01 11:11 Sandro Santilli <strk at kbt.io>
* [r1966] ChangeLog,
@@ -13896,14 +15892,14 @@
operation::buffer::BufferOp: set MAX_PRECISION_DIGITS
so to match JTS.
-2007-01-26 01:19 Sandro Santilli <strk at keybit.net>
+2007-01-26 01:19 Sandro Santilli <strk at kbt.io>
* [r1965] ChangeLog, tests/xmltester/Makefile.am,
tests/xmltester/stmlf-cases-20070119.xml: * tests/xmltester/:
Makefile.am, stmlf-cases-20070119.xml:
New overlay test.
-2007-01-26 00:57 Sandro Santilli <strk at keybit.net>
+2007-01-26 00:57 Sandro Santilli <strk at kbt.io>
* [r1964] ChangeLog, source/operation/buffer/BufferBuilder.cpp,
tests/xmltester/XMLTester.cpp: * tests/xmltester/XMLTester.cpp:
@@ -13913,32 +15909,32 @@
remove repeated points from noded SegmentStrings, skip collapsed
edges.
-2007-01-17 11:59 Sandro Santilli <strk at keybit.net>
+2007-01-17 11:59 Sandro Santilli <strk at kbt.io>
* [r1963] ChangeLog, tests/xmltester/Makefile.am,
tests/xmltester/heisenbugs.xml: New testcase for bug fixed by
previous commit.
-2007-01-17 01:05 Sandro Santilli <strk at keybit.net>
+2007-01-17 01:05 Sandro Santilli <strk at kbt.io>
* [r1962] ChangeLog, source/index/strtree/STRtree.cpp: *
source/index/strtree/STRtree.cpp (yComparator):
Use static_cast<> and make code more readable.
A side effect seems to be fixing a segfault :!
-2007-01-17 00:45 Sandro Santilli <strk at keybit.net>
+2007-01-17 00:45 Sandro Santilli <strk at kbt.io>
* [r1961] ChangeLog, source/headers/geos/index/strtree/STRtree.h: *
source/headers/geos/index/strtree/STRtree.h (centreY):
const-corrected.
-2007-01-16 14:12 Sandro Santilli <strk at keybit.net>
+2007-01-16 14:12 Sandro Santilli <strk at kbt.io>
* [r1960] ChangeLog, tests/xmltester/XMLTester.cpp,
tests/xmltester/XMLTester.h: * tests/xmltester/XMLTester.cpp:
don't include catch-all headers.
-2007-01-09 17:34 Sandro Santilli <strk at keybit.net>
+2007-01-09 17:34 Sandro Santilli <strk at kbt.io>
* [r1959] ChangeLog,
@@ -13961,7 +15957,7 @@
to be smaller then 1/1000 of expected geometry
area.
-2007-01-09 15:08 Sandro Santilli <strk at keybit.net>
+2007-01-09 15:08 Sandro Santilli <strk at kbt.io>
* [r1958] ChangeLog, source/geom/CoordinateArraySequence.cpp,
@@ -13974,27 +15970,27 @@
(single virtual call vs. multiple); added front() and
back() methods.
-2007-01-09 10:27 Sandro Santilli <strk at keybit.net>
+2007-01-09 10:27 Sandro Santilli <strk at kbt.io>
* [r1957] ChangeLog, tests/xmltester/XMLTester.cpp: *
tests/xmltester/XMLTester.cpp: add areatest to buffer test
handler.
-2007-01-05 01:01 Sandro Santilli <strk at keybit.net>
+2007-01-05 01:01 Sandro Santilli <strk at kbt.io>
* [r1956] ChangeLog, configure.in: * configure.in: prepared for
version to 3.0.0rc4,
fixed swig python errors as suggested by hint
(AM_PATH_PYTHON).
-2007-01-04 22:43 Sandro Santilli <strk at keybit.net>
+2007-01-04 22:43 Sandro Santilli <strk at kbt.io>
* [r1955] ChangeLog, configure.in, swig/geos.i, swig/geos.i.in: *
configure.in, swig/geos.i.in, swig/geos.i:
geos.i generated at configure time from geos.i.in
(so we don't have to manually update versions there).
-2007-01-04 22:38 Sandro Santilli <strk at keybit.net>
+2007-01-04 22:38 Sandro Santilli <strk at kbt.io>
* [r1954] ChangeLog, swig/geos.i: Patch by dev-zero at gentoo dot
org:
@@ -14002,13 +15998,13 @@
* swig/geos.i: use unsigned int when CAPI signatures
expect unsigned int (not size_t).
-2007-01-03 20:11 Sandro Santilli <strk at keybit.net>
+2007-01-03 20:11 Sandro Santilli <strk at kbt.io>
* [r1953] ChangeLog, tests/xmltester/Makefile.am,
tests/xmltester/fme.xml: * tests/xmltester/: fme.xml,
Makefile.am: added buffer testcase.
-2007-01-03 20:06 Sandro Santilli <strk at keybit.net>
+2007-01-03 20:06 Sandro Santilli <strk at kbt.io>
* [r1952] ChangeLog, tests/xmltester/XMLTester.cpp: *
tests/xmltester/XMLTester.cpp: use a tolerance of 10E-6
@@ -14016,7 +16012,7 @@
projections); create sql tables with oid to work around a
bug in qgis 0.7.4.
-2007-01-03 19:18 Sandro Santilli <strk at keybit.net>
+2007-01-03 19:18 Sandro Santilli <strk at kbt.io>
* [r1951] ChangeLog, source/algorithm/HCoordinate.cpp,
source/inlines.cpp: Applied patch by Mark Cave-Ayland
@@ -14025,32 +16021,32 @@
* source/inlines.cpp, source/algorithm/HCoordinate.cpp:
Fixes for MingW builds. See geos-devel/2007-January/002766.html.
-2007-01-03 14:56 Sandro Santilli <strk at keybit.net>
+2007-01-03 14:56 Sandro Santilli <strk at kbt.io>
* [r1950] ChangeLog, source/operation/buffer/BufferOp.cpp: *
source/operation/buffer/BufferOp.cpp (bufferReducedPrecision):
Fixed computation of reduced PrecisionModel scale.
-2006-12-18 20:04 Sandro Santilli <strk at keybit.net>
+2006-12-18 20:04 Sandro Santilli <strk at kbt.io>
* [r1949] ChangeLog, tests/xmltester/robustness.xml: *
tests/xmltester/robustness.xml: added
testcase reported to fail with 2.2.3 on
postgis-users/2006-November/014013.html.
-2006-12-18 18:44 Sandro Santilli <strk at keybit.net>
+2006-12-18 18:44 Sandro Santilli <strk at kbt.io>
* [r1948] ChangeLog, source/headers/geos/geom/BinaryOp.h,
source/headers/geos/precision/GeometrySnapper.h,
source/precision/GeometrySnapper.cpp: Geometry snapping synced
with JTS.
-2006-12-18 14:27 Sandro Santilli <strk at keybit.net>
+2006-12-18 14:27 Sandro Santilli <strk at kbt.io>
* [r1947] ChangeLog, HOWTO_RELEASE: * HOWTO_RELEASE: add
ChangeLog's release mark step.
-2006-12-18 14:19 Sandro Santilli <strk at keybit.net>
+2006-12-18 14:19 Sandro Santilli <strk at kbt.io>
* [r1946] ChangeLog, source/precision/GeometrySnapper.cpp,
@@ -14060,7 +16056,7 @@
* tests/xmltester/: Makefile.am, TestRobustOverlayFixed.xml:
new test for fixed precision snapping.
-2006-12-15 10:50 Sandro Santilli <strk at keybit.net>
+2006-12-15 10:50 Sandro Santilli <strk at kbt.io>
* [r1945] ChangeLog: release 3.0.0rc3 marked
@@ -14074,7 +16070,7 @@
source/Makefile.vc: Updated makefile and project files for Visual
C++.
-2006-12-13 10:55 Sandro Santilli <strk at keybit.net>
+2006-12-13 10:55 Sandro Santilli <strk at kbt.io>
* [r1941] ChangeLog,
@@ -14085,7 +16081,7 @@
source/operation/overlay/OverlayResultValidator.cpp: Updated port
information.
-2006-12-13 10:51 Sandro Santilli <strk at keybit.net>
+2006-12-13 10:51 Sandro Santilli <strk at kbt.io>
* [r1940] ChangeLog,
@@ -14095,7 +16091,7 @@
precision::GeometrySnapper, precision::LineStringSnapper:
Updated port information.
-2006-12-11 17:42 Sandro Santilli <strk at keybit.net>
+2006-12-11 17:42 Sandro Santilli <strk at kbt.io>
* [r1939] ChangeLog,
@@ -14121,7 +16117,7 @@
* source/headers/geos/geomgraph/EdgeNodingValidator.h:
use a FastNodingValidator rather then a simple NodingValidator.
-2006-12-07 10:45 Sandro Santilli <strk at keybit.net>
+2006-12-07 10:45 Sandro Santilli <strk at kbt.io>
* [r1938] ChangeLog, source/algorithm/LineIntersector.cpp,
source/headers/geos/algorithm/CentralEndpointIntersector.h,
@@ -14160,7 +16156,7 @@
* [r1933] build/msvc80/geos_unit/geos_unit.vcproj: Added CAPI tests
to VC++ project.
-2006-12-05 10:42 Sandro Santilli <strk at keybit.net>
+2006-12-05 10:42 Sandro Santilli <strk at kbt.io>
* [r1932] ChangeLog, source/headers/geos/geom/BinaryOp.h,
source/operation/overlay/OverlayOp.cpp: *
@@ -14171,21 +16167,21 @@
* source/headers/geos/geom/BinaryOp.h: be quiet if not in DEBUG
mode.
-2006-12-05 09:59 Sandro Santilli <strk at keybit.net>
+2006-12-05 09:59 Sandro Santilli <strk at kbt.io>
* [r1931] ChangeLog, source/headers/geos/noding/NodingValidator.h,
source/noding/NodingValidator.cpp: * noding::NodingValidator.h:
throw TopologyException
rather then a generic GEOSException.
-2006-12-04 12:41 Sandro Santilli <strk at keybit.net>
+2006-12-04 12:41 Sandro Santilli <strk at kbt.io>
* [r1930] ChangeLog,
source/headers/geos/geomgraph/EdgeNodingValidator.h: *
fix members initialization order.
-2006-12-04 11:38 Sandro Santilli <strk at keybit.net>
+2006-12-04 11:38 Sandro Santilli <strk at kbt.io>
* [r1929] ChangeLog, source/geomgraph/EdgeNodingValidator.cpp,
@@ -14193,7 +16189,7 @@
to use references args instead of pointers for
method that doesn't handle NULLs anyway.
-2006-12-04 10:31 Sandro Santilli <strk at keybit.net>
+2006-12-04 10:31 Sandro Santilli <strk at kbt.io>
* [r1928] ChangeLog,
source/simplify/DouglasPeuckerLineSimplifier.cpp,
@@ -14206,31 +16202,31 @@
* source/simplify/DouglasPeuckerLineSimplifier.cpp (simplify):
don't try to simplify empty coordinate lists. Fixes bug #134.
-2006-12-04 10:14 Sandro Santilli <strk at keybit.net>
+2006-12-04 10:14 Sandro Santilli <strk at kbt.io>
* [r1927] ChangeLog, tests/unit/capi/GEOSCoordSeq.cpp: Other tests
using setOrdinate instead of set{X,Y,Z}
-2006-12-04 10:12 Sandro Santilli <strk at keybit.net>
+2006-12-04 10:12 Sandro Santilli <strk at kbt.io>
* [r1926] ChangeLog, source/geom/CoordinateArraySequence.cpp: *
source/geom/CoordinateArraySequence.cpp (setOrdinate): fix bug
#133.
-2006-12-04 10:00 Sandro Santilli <strk at keybit.net>
+2006-12-04 10:00 Sandro Santilli <strk at kbt.io>
* [r1925] ChangeLog, tests/unit/capi/GEOSCoordSeq.cpp: *
tests/unit/capi/GEOSCoordSeq.cpp: add test for bug #133
(failing).
-2006-12-04 09:57 Sandro Santilli <strk at keybit.net>
+2006-12-04 09:57 Sandro Santilli <strk at kbt.io>
* [r1924] ChangeLog,
tests/unit/geom/CoordinateArraySequenceTest.cpp: *
tests/unit/geom/CoordinateArraySequenceTest.cpp: added tests for
setOrdinate()
-2006-11-30 14:49 Sandro Santilli <strk at keybit.net>
+2006-11-30 14:49 Sandro Santilli <strk at kbt.io>
* [r1923] ChangeLog, capi/geos_c.cpp, tests/unit/Makefile.am,
tests/unit/capi, tests/unit/capi/GEOSCoordSeq.cpp: * tests/unit/:
@@ -14248,24 +16244,24 @@
build/msvc80/geos_unit/geos_unit.vcproj: Added Visual C++ 2005
project files.
-2006-11-23 20:17 Sandro Santilli <strk at keybit.net>
+2006-11-23 20:17 Sandro Santilli <strk at kbt.io>
* [r1921] ChangeLog, source/geom/Point.cpp: * source/geom/Point.cpp
(equalsExact): don't segfault on empty points. Fixes bug #132.
-2006-11-23 12:25 Sandro Santilli <strk at keybit.net>
+2006-11-23 12:25 Sandro Santilli <strk at kbt.io>
* [r1920] tests/xmltester/stmlf-cases-20061020.xml: Added short
descripion of testcases provenience
-2006-11-22 20:29 Sandro Santilli <strk at keybit.net>
+2006-11-22 20:29 Sandro Santilli <strk at kbt.io>
* [r1919] ChangeLog, tests/xmltester/Makefile.am,
tests/xmltester/stmlf-cases-20061020.xml: * tests/xmltester/:
stmlf-cases-20061020.xml, Makefile.am: add more robustness
testcases.
-2006-11-22 12:26 Sandro Santilli <strk at keybit.net>
+2006-11-22 12:26 Sandro Santilli <strk at kbt.io>
* [r1918] ChangeLog, autogen.sh: Patch by dron at ak4719.spb.edu:
@@ -14277,7 +16273,7 @@
* [r1917] source/Makefile.vc: Fixed path to geos_c.h in
source/makefile.vc.
-2006-11-15 18:26 Sandro Santilli <strk at keybit.net>
+2006-11-15 18:26 Sandro Santilli <strk at kbt.io>
* [r1916] ChangeLog, capi/Makefile.am, capi/geos_c.h.vc.in,
configure.in, source/Makefile.vc,
@@ -14290,12 +16286,12 @@
* source/headers/geos/Makefile.am: distribute version.h
* capi/Makefile.am: distribute geos_c.h
-2006-11-15 14:42 Sandro Santilli <strk at keybit.net>
+2006-11-15 14:42 Sandro Santilli <strk at kbt.io>
* [r1915] ChangeLog, capi/geos_c.h.in: * capi/geos_c.h.in:
hopefully fixed GEOS_DLL use.
-2006-11-15 11:28 Sandro Santilli <strk at keybit.net>
+2006-11-15 11:28 Sandro Santilli <strk at kbt.io>
* [r1914] ChangeLog, capi/geos_c.cpp: * capi/geos_c.cpp
(GEOSGeom_getDimensions): Fix a segfault on empty geometry input
@@ -14307,7 +16303,7 @@
in MACRO substitutions. Somehow GNU version replaced .vc version
during file shuffles to get macros in.
-2006-11-10 18:24 Sandro Santilli <strk at keybit.net>
+2006-11-10 18:24 Sandro Santilli <strk at kbt.io>
* [r1912] ChangeLog: fixed timewarp
@@ -14333,16 +16329,16 @@
* [r1907] capi/geos_c.h.vc: update
-2006-11-09 09:10 Sandro Santilli <strk at keybit.net>
+2006-11-09 09:10 Sandro Santilli <strk at kbt.io>
* [r1906] ChangeLog, tests/xmltester/XMLTester.cpp: *
test/xmltester/XMLTester.cpp: improved 'testarea' test.
-2006-11-08 11:54 Sandro Santilli <strk at keybit.net>
+2006-11-08 11:54 Sandro Santilli <strk at kbt.io>
* [r1905] ChangeLog: added 'release-separator' tag
-2006-11-08 11:51 Sandro Santilli <strk at keybit.net>
+2006-11-08 11:51 Sandro Santilli <strk at kbt.io>
* [r1904] ChangeLog, tests/xmltester/Makefile.am,
tests/xmltester/robustness.xml: * tests/xmltester/robustness.xml:
@@ -14352,14 +16348,14 @@
* tests/xmltester/Makefile.am: robustness.xml is now safe
to run, so run it on make check.
-2006-11-08 10:40 Sandro Santilli <strk at keybit.net>
+2006-11-08 10:40 Sandro Santilli <strk at kbt.io>
* [r1903] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
source/headers/geos/geom/BinaryOp.h: enable
COMMONBITS-removal heuristic so it is attempted
before geometry snapping.
-2006-11-05 20:34 Sandro Santilli <strk at keybit.net>
+2006-11-05 20:34 Sandro Santilli <strk at kbt.io>
* [r1900] ChangeLog, capi/Makefile.am: * capi/Makefile.am:
distribute files needed for testing, proper cleanup (make
@@ -14379,51 +16375,51 @@
* [r1897] swig/geos.i: Fixes for changes in header files.
-2006-11-03 12:35 Sandro Santilli <strk at keybit.net>
+2006-11-03 12:35 Sandro Santilli <strk at kbt.io>
* [r1896] capi/testrunner.sh: redirect 'diff' output to stderr
-2006-11-03 10:54 Sandro Santilli <strk at keybit.net>
+2006-11-03 10:54 Sandro Santilli <strk at kbt.io>
* [r1895] ChangeLog, capi/testrunner.sh: hopefully fixed proper
quoting
-2006-11-03 10:30 Sandro Santilli <strk at keybit.net>
+2006-11-03 10:30 Sandro Santilli <strk at kbt.io>
* [r1894] ChangeLog, capi/testrunner.sh: Report non-zero return
from ./geostest run
-2006-11-02 10:08 Sandro Santilli <strk at keybit.net>
+2006-11-02 10:08 Sandro Santilli <strk at kbt.io>
* [r1893] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
source/headers/geos/geom/BinaryOp.h: disable debugging output by
default.
-2006-11-02 10:02 Sandro Santilli <strk at keybit.net>
+2006-11-02 10:02 Sandro Santilli <strk at kbt.io>
* [r1892] ChangeLog, capi/geostest.c: * capi/geostest.c: updated to
use the new GEOSGeometry typedef, so to build w/out warnings and
fully respecting current const specification.
-2006-11-02 09:48 Sandro Santilli <strk at keybit.net>
+2006-11-02 09:48 Sandro Santilli <strk at kbt.io>
* [r1891] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: *
capi/geos_c.cpp, capi/geos_c.h.in: const-corrected and documented
GEOSPolygonize function.
-2006-11-02 09:38 Sandro Santilli <strk at keybit.net>
+2006-11-02 09:38 Sandro Santilli <strk at kbt.io>
* [r1890] ChangeLog, capi/test.expected, capi/testrunner.sh: *
capi/test.expected: updated expected version
* capi/testrunner.sh: be happy with geostest running w/out
segfaulting, still run diff for reference.
-2006-11-02 09:33 Sandro Santilli <strk at keybit.net>
+2006-11-02 09:33 Sandro Santilli <strk at kbt.io>
* [r1889] ChangeLog, configure.in: * configure.in: updated versions
to 3.0.0rc2 / CAPI-1.3.0
-2006-11-02 08:32 Sandro Santilli <strk at keybit.net>
+2006-11-02 08:32 Sandro Santilli <strk at kbt.io>
* [r1888] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: Patch by
Markus Schaber <schabi at logix-tt.com>:
@@ -14435,7 +16431,7 @@
* capi/geos_c.cpp: define GEOSGeometry and GEOSCoordSequence
for cross-checking of types in header.
-2006-10-30 15:14 Sandro Santilli <strk at keybit.net>
+2006-10-30 15:14 Sandro Santilli <strk at kbt.io>
* [r1887] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: Patch by
@@ -14444,16 +16440,16 @@
* capi/geos_c.h.in: let the enum visible by geos_c.cpp
now that there are no more name clashes.
-2006-10-30 13:20 Sandro Santilli <strk at keybit.net>
+2006-10-30 13:20 Sandro Santilli <strk at kbt.io>
* [r1886] capi/geos_c.cpp: removed useless GEOSGeomTypes define
-2006-10-30 13:00 Sandro Santilli <strk at keybit.net>
+2006-10-30 13:00 Sandro Santilli <strk at kbt.io>
* [r1885] ChangeLog, source/operation/overlay/OverlayOp.cpp: reduce
default verbosity
-2006-10-30 12:49 Sandro Santilli <strk at keybit.net>
+2006-10-30 12:49 Sandro Santilli <strk at kbt.io>
* [r1884] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: *
capi/geos_c.cpp:
@@ -14469,13 +16465,13 @@
Added a comment explaining ou #ifndef magic;
Unified the two #ifndef into a single one.
-2006-10-30 10:29 Sandro Santilli <strk at keybit.net>
+2006-10-30 10:29 Sandro Santilli <strk at kbt.io>
* [r1883] ChangeLog, capi/Makefile.am, capi/test.expected,
capi/testrunner.sh: * capi/: test.expected, testrunner.sh,
Makefile.am: Added a run of ./geostest as part of 'make check'
-2006-10-30 10:15 Sandro Santilli <strk at keybit.net>
+2006-10-30 10:15 Sandro Santilli <strk at kbt.io>
* [r1882] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: Patch
submitted by Markus Schaber <schabi at logix-tt.com> ( reviewed and
@@ -14487,13 +16483,13 @@
declarations and implementation for consistency, fixed geos_c.cpp
accordingly (const-correctness, mainly).
-2006-10-30 09:49 Sandro Santilli <strk at keybit.net>
+2006-10-30 09:49 Sandro Santilli <strk at kbt.io>
* [r1881] ChangeLog, capi/geostest.c: * capi/geostest.c: added some
checks of return from CAPI functions returning GEOSGeom (not all,
just a few)
-2006-10-27 11:54 Sandro Santilli <strk at keybit.net>
+2006-10-27 11:54 Sandro Santilli <strk at kbt.io>
* [r1880] ChangeLog, source/algorithm/InteriorPointLine.cpp,
@@ -14510,20 +16506,20 @@
then filter_rw, as it doesn't change the Geometry, propagated
change to internal interfaces (add methods)
-2006-10-26 09:22 Sandro Santilli <strk at keybit.net>
+2006-10-26 09:22 Sandro Santilli <strk at kbt.io>
* [r1879] ChangeLog, capi/geos_c.h.in: * capi/geos_c.h.in: reverted
all changes of 'int' types
to 'size_t' types (the lib never changed, and still expects
ints)
-2006-10-24 16:54 Sandro Santilli <strk at keybit.net>
+2006-10-24 16:54 Sandro Santilli <strk at kbt.io>
* [r1878] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
source/headers/geos/geom/BinaryOp.h: try original geoms first by
default.
-2006-10-24 16:53 Sandro Santilli <strk at keybit.net>
+2006-10-24 16:53 Sandro Santilli <strk at kbt.io>
* [r1877] ChangeLog,
source/headers/geos/operation/overlay/OverlayResultValidator.h,
@@ -14531,7 +16527,7 @@
operation::overlay::OverlayResultValidator.cpp (isValid): run the
test even if inputs and output are not areal.
-2006-10-24 16:49 Sandro Santilli <strk at keybit.net>
+2006-10-24 16:49 Sandro Santilli <strk at kbt.io>
* [r1876] ChangeLog,
@@ -14540,7 +16536,7 @@
components from consideration when testing the location of
points.
-2006-10-24 10:16 Sandro Santilli <strk at keybit.net>
+2006-10-24 10:16 Sandro Santilli <strk at kbt.io>
* [r1875] ChangeLog,
@@ -14548,7 +16544,7 @@
precision::GeometrySnapper: snapPrecisionFactor augmented from
10e-12 to 10e-10.
-2006-10-24 09:49 Sandro Santilli <strk at keybit.net>
+2006-10-24 09:49 Sandro Santilli <strk at kbt.io>
* [r1874] ChangeLog,
source/headers/geos/precision/LineStringSnapper.h,
@@ -14558,14 +16554,14 @@
segment *intersects* the snap points, consider a distance
of exactly snapTolerance as non-tolerated (got in sync with JTS)
-2006-10-23 10:23 Sandro Santilli <strk at keybit.net>
+2006-10-23 10:23 Sandro Santilli <strk at kbt.io>
* [r1873] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
source/headers/geos/geom/BinaryOp.h (SnapOp): document and add
optional CBR step (snap after applying common bits removal - this
is the default); (check_valid): add validity checker function.
-2006-10-20 11:18 Sandro Santilli <strk at keybit.net>
+2006-10-20 11:18 Sandro Santilli <strk at kbt.io>
* [r1872] ChangeLog, source/headers/geos/noding/SegmentString.h,
source/noding/ScaledNoder.cpp, source/noding/SegmentString.cpp: *
@@ -14573,7 +16569,7 @@
* noding::ScaledNoder: notify possible coordinates change to
SegmentString after removing repeated points.
-2006-10-19 18:26 Sandro Santilli <strk at keybit.net>
+2006-10-19 18:26 Sandro Santilli <strk at kbt.io>
* [r1871] ChangeLog, configure.in: * configure.in: use 'expr' for
arithmetics (more portable)
@@ -14592,40 +16588,40 @@
* [r1868] makefile.vc: Added top-level makefile.vc.
-2006-10-18 14:28 Sandro Santilli <strk at keybit.net>
+2006-10-18 14:28 Sandro Santilli <strk at kbt.io>
* [r1867] .: fixed svn:ignore property
-2006-10-18 12:08 Sandro Santilli <strk at keybit.net>
+2006-10-18 12:08 Sandro Santilli <strk at kbt.io>
* [r1866] ChangeLog, source/operation/overlay/OverlayOp.cpp:
disable non-JTS overlay result validators (to more closely track
JTS at this stage)
-2006-10-17 14:26 Sandro Santilli <strk at keybit.net>
+2006-10-17 14:26 Sandro Santilli <strk at kbt.io>
* [r1865] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
source/headers/geos/geom/BinaryOp.h (SnapOp): fixed horrible
bug applying overlay of first geom to itself :(
-2006-10-17 10:15 Sandro Santilli <strk at keybit.net>
+2006-10-17 10:15 Sandro Santilli <strk at kbt.io>
* [r1864] capi/geos_c.h.in: really fixed 'extra tokens at end of
#endif directive' warning
-2006-10-17 10:10 Sandro Santilli <strk at keybit.net>
+2006-10-17 10:10 Sandro Santilli <strk at kbt.io>
* [r1863] capi/geos_c.h.in: fixed 'extra tokens at end of #endif
directive' warning
-2006-10-17 08:44 Sandro Santilli <strk at keybit.net>
+2006-10-17 08:44 Sandro Santilli <strk at kbt.io>
* [r1862] ChangeLog, capi/Makefile.am: * capi/Makefile.am: don't
directly link geostest against
both libgeos.so and libstdc++ (should be derived by
libgeos_c.so).
-2006-10-12 15:33 Sandro Santilli <strk at keybit.net>
+2006-10-12 15:33 Sandro Santilli <strk at kbt.io>
* [r1861] ChangeLog, tests/bigtest/GeometryTestFactory.cpp,
tests/bigtest/TestSweepLineSpeed.cpp, tests/bigtest/bigtest.h: *
@@ -14633,13 +16629,13 @@
tests/bigtest/TestSweepLineSpeed.cpp: fixed header inclusion, to
reduce compiler noise.
-2006-10-09 16:39 Sandro Santilli <strk at keybit.net>
+2006-10-09 16:39 Sandro Santilli <strk at kbt.io>
* [r1860] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
source/headers/geos/geom/BinaryOp.h: always snap geoms to
each-other before applying an overlay (temp hack).
-2006-10-09 16:35 Sandro Santilli <strk at keybit.net>
+2006-10-09 16:35 Sandro Santilli <strk at kbt.io>
* [r1859] ChangeLog, source/operation/overlay/OverlayOp.cpp: *
source/operation/overlay/OverlayOp.cpp: enable all overlay result
@@ -14650,7 +16646,7 @@
* [r1858] ChangeLog, capi/geos_c.h.in, capi/geos_c.h.vc: Added
inclusion guards to geos_c.h files.
-2006-10-05 09:46 Sandro Santilli <strk at keybit.net>
+2006-10-05 09:46 Sandro Santilli <strk at kbt.io>
* [r1857] ChangeLog, tests/xmltester/XMLTester.cpp: increment
areatest verbosity (needs -v -v)
@@ -14660,15 +16656,15 @@
* [r1856] ChangeLog, capi/geos_c.cpp: GEOSEnvelope wasn't in the
PROTOTYPES section in geos_c.cpp
-2006-09-27 07:48 Sandro Santilli <strk at keybit.net>
+2006-09-27 07:48 Sandro Santilli <strk at kbt.io>
* [r1855] HOWTO_RELEASE: updated tag item
-2006-09-27 07:43 Sandro Santilli <strk at keybit.net>
+2006-09-27 07:43 Sandro Santilli <strk at kbt.io>
* [r1854] HOWTO_RELEASE: added info about svn tags
-2006-09-19 06:54 Sandro Santilli <strk at keybit.net>
+2006-09-19 06:54 Sandro Santilli <strk at kbt.io>
* [r1853] source/operation/overlay/OffsetPointGenerator.cpp: Added
<algorithm> include
@@ -14680,33 +16676,33 @@
Bavarian State Ministry of Agriculture and Forestry and the State
Survey of Bavaria.
-2006-09-08 09:38 Sandro Santilli <strk at keybit.net>
+2006-09-08 09:38 Sandro Santilli <strk at kbt.io>
* [r1850] TODO: updated
-2006-09-08 09:31 Sandro Santilli <strk at keybit.net>
+2006-09-08 09:31 Sandro Santilli <strk at kbt.io>
* [r1849] source/operation/overlay/OverlayResultValidator.cpp: more
debugging output
-2006-09-08 09:21 Sandro Santilli <strk at keybit.net>
+2006-09-08 09:21 Sandro Santilli <strk at kbt.io>
* [r1848] tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp,
tests/unit/operation/overlay/OverlayResultValidatorTest.cpp: More
testcases
-2006-09-07 18:07 Sandro Santilli <strk at keybit.net>
+2006-09-07 18:07 Sandro Santilli <strk at kbt.io>
* [r1847] tests/unit/Makefile.am,
tests/unit/operation/overlay/OverlayResultValidatorTest.cpp: New
unit test for OverlayResultValidator class
* [r1846] source/operation/overlay/OverlayResultValidator.cpp: more
debugging output
-2006-09-07 17:52 Sandro Santilli <strk at keybit.net>
+2006-09-07 17:52 Sandro Santilli <strk at kbt.io>
* [r1845]
@@ -14714,18 +16710,18 @@
addVertices private method (unused, as in JTS, but possibly
useful in the future)
-2006-09-07 17:41 Sandro Santilli <strk at keybit.net>
+2006-09-07 17:41 Sandro Santilli <strk at kbt.io>
* [r1844] source/operation/overlay/OverlayResultValidator.cpp:
Added debugging code
-2006-09-07 17:35 Sandro Santilli <strk at keybit.net>
+2006-09-07 17:35 Sandro Santilli <strk at kbt.io>
* [r1843]
tests/unit/operation/overlay/OffsetPointGeneratorTest.cpp: more
testcases (added test for max distance of offset points)
-2006-09-07 15:28 Sandro Santilli <strk at keybit.net>
+2006-09-07 15:28 Sandro Santilli <strk at kbt.io>
* [r1842] tests/unit/algorithm/PointLocatorTest.cpp,
tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp,
@@ -14750,13 +16746,13 @@
tests/unit/precision/LineStringSnapperTest.cpp: removed
svn:executable prop from all .cpp files
-2006-09-07 15:22 Sandro Santilli <strk at keybit.net>
+2006-09-07 15:22 Sandro Santilli <strk at kbt.io>
* [r1841] tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp,
removed svn:executable property
-2006-09-07 15:21 Sandro Santilli <strk at keybit.net>
+2006-09-07 15:21 Sandro Santilli <strk at kbt.io>
* [r1840] tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp:
testing execute bit state
@@ -14766,80 +16762,80 @@
* [r1839] tests/unit/operation/distance/DistanceOpTest.cpp: Set
svn:keyword for $ expansion.
-2006-09-07 11:34 Sandro Santilli <strk at keybit.net>
+2006-09-07 11:34 Sandro Santilli <strk at kbt.io>
* [r1838] source/operation/overlay/OverlayOp.cpp: Cleaned up
OverlayResultValidator call (still disabled due to bugs)
-2006-09-07 11:27 Sandro Santilli <strk at keybit.net>
+2006-09-07 11:27 Sandro Santilli <strk at kbt.io>
* [r1837] source/operation/overlay/OverlayResultValidator.cpp:
blindly return positive result if any input or output is not an
area
-2006-09-07 11:08 Sandro Santilli <strk at keybit.net>
+2006-09-07 11:08 Sandro Santilli <strk at kbt.io>
* [r1836] tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp:
new test for FuzzyPointLocator
-2006-09-07 10:30 Sandro Santilli <strk at keybit.net>
+2006-09-07 10:30 Sandro Santilli <strk at kbt.io>
* [r1835] source/headers/geos/geom/Location.h: Explicit values to
LocationValue enum items. Removed CVS Log
-2006-09-07 09:33 Sandro Santilli <strk at keybit.net>
+2006-09-07 09:33 Sandro Santilli <strk at kbt.io>
* [r1834] doc/example.cpp: Removed catch-all headers inclusion and
use of obsoleted Unload class
-2006-09-07 09:24 Sandro Santilli <strk at keybit.net>
+2006-09-07 09:24 Sandro Santilli <strk at kbt.io>
* [r1833] README: updated
-2006-09-07 09:23 Sandro Santilli <strk at keybit.net>
+2006-09-07 09:23 Sandro Santilli <strk at kbt.io>
* [r1832]
source/headers/geos/operation/overlay/OverlayResultValidator.h:
comment cleanup
-2006-09-07 09:01 Sandro Santilli <strk at keybit.net>
+2006-09-07 09:01 Sandro Santilli <strk at kbt.io>
* [r1831] source/headers/geos/operation/distance/DistanceOp.h:
Comments about ownership (and lifetime) of returned objects
-2006-09-07 08:59 Sandro Santilli <strk at keybit.net>
+2006-09-07 08:59 Sandro Santilli <strk at kbt.io>
* [r1830] tests/unit/Makefile.am, tests/unit/operation/distance,
tests/unit/operation/distance/DistanceOpTest.cpp: New DistanceOp
unit test
-2006-09-07 08:57 Sandro Santilli <strk at keybit.net>
+2006-09-07 08:57 Sandro Santilli <strk at kbt.io>
* [r1829] ChangeLog, source/operation/distance/DistanceOp.cpp:
(computeMinDistancePoints): fixed invalid reference.
-2006-09-07 08:23 Sandro Santilli <strk at keybit.net>
+2006-09-07 08:23 Sandro Santilli <strk at kbt.io>
* [r1828] ChangeLog, autogen.sh: don't giveup on automake failures
(testing)
-2006-09-06 18:44 Sandro Santilli <strk at keybit.net>
+2006-09-06 18:44 Sandro Santilli <strk at kbt.io>
* [r1827] source/operation/overlay/OverlayOp.cpp: Ops, overlay
result validation erroenously committed
-2006-09-06 18:41 Sandro Santilli <strk at keybit.net>
+2006-09-06 18:41 Sandro Santilli <strk at kbt.io>
* [r1826] ChangeLog, tests/unit/Makefile.am,
tests/unit/operation/overlay/OffsetPointGeneratorTest.cpp: new
test for OffsetPointGenerator class
-2006-09-06 18:37 Sandro Santilli <strk at keybit.net>
+2006-09-06 18:37 Sandro Santilli <strk at kbt.io>
* [r1825] source/operation/overlay/OffsetPointGenerator.cpp: Fixed
uninitialized memory bug
-2006-09-06 17:59 Sandro Santilli <strk at keybit.net>
+2006-09-06 17:59 Sandro Santilli <strk at kbt.io>
* [r1824] ChangeLog, source/operation/overlay/OverlayOp.cpp,
tests/unit/Makefile.am, tests/unit/operation,
@@ -14847,7 +16843,7 @@
tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp: new test
for FuzzyPointLocator class
-2006-09-06 17:48 Sandro Santilli <strk at keybit.net>
+2006-09-06 17:48 Sandro Santilli <strk at kbt.io>
* [r1823] tests/unit/precision/GeometrySnapperTest.cpp: updated
after GeometrySnapper interface change.
@@ -14861,7 +16857,7 @@
source/operation/overlay/OverlayResultValidator.cpp: Set $
expansion for new files in 'overlay' module.
-2006-09-06 17:22 Sandro Santilli <strk at keybit.net>
+2006-09-06 17:22 Sandro Santilli <strk at kbt.io>
* [r1821] ChangeLog,
source/headers/geos/operation/overlay/FuzzyPointLocator.h,
@@ -15397,31 +17393,31 @@
tests/xmltester/markup/MarkupSTL.h, tools/geos-config.in: Set
svn:keyword property for Id keyword expansion.
-2006-09-06 15:50 Sandro Santilli <strk at keybit.net>
+2006-09-06 15:50 Sandro Santilli <strk at kbt.io>
* [r1819]
source/operation/overlay/FuzzyPointLocator.cpp: Fixed comments
and includes
-2006-09-06 15:33 Sandro Santilli <strk at keybit.net>
+2006-09-06 15:33 Sandro Santilli <strk at kbt.io>
* [r1818] ChangeLog,
source/operation/overlay/FuzzyPointLocator.cpp: new helper class
for Overlay op validation.
-2006-09-06 15:21 Sandro Santilli <strk at keybit.net>
+2006-09-06 15:21 Sandro Santilli <strk at kbt.io>
* [r1817] source/headers/geos/geom/Geometry.h: (getBoundary) memory
allocations documented
-2006-09-05 16:18 Sandro Santilli <strk at keybit.net>
+2006-09-05 16:18 Sandro Santilli <strk at kbt.io>
* [r1816] ChangeLog: updated (last commit log was bogus, refer to
ChangeLog entry)
-2006-09-05 16:07 Sandro Santilli <strk at keybit.net>
+2006-09-05 16:07 Sandro Santilli <strk at kbt.io>
* [r1815] source/headers/geos/geom/BinaryOp.h,
@@ -15430,23 +17426,23 @@
(OverlayOp::checkObviouslyWrongResult): exceptions messages
rewording
-2006-08-31 23:13 Sandro Santilli <strk at keybit.net>
+2006-08-31 23:13 Sandro Santilli <strk at kbt.io>
* [r1814] ChangeLog, source/index/quadtree/Root.cpp:
(insertContained): fixed bug reported in
geos-devel/2006-August/002541.html
-2006-08-31 23:07 Sandro Santilli <strk at keybit.net>
+2006-08-31 23:07 Sandro Santilli <strk at kbt.io>
* [r1813] ChangeLog, configure.in: Reverted last two commits.
Darwin host on buildbot seems to have its own problems...
-2006-08-31 22:28 Sandro Santilli <strk at keybit.net>
+2006-08-31 22:28 Sandro Santilli <strk at kbt.io>
* [r1812] configure.in: Ops, it was AM_CONFIG_HEADER the old
version - still testing
-2006-08-31 22:21 Sandro Santilli <strk at keybit.net>
+2006-08-31 22:21 Sandro Santilli <strk at kbt.io>
* [r1811] ChangeLog, configure.in: AC_CONFIG_HEADERS =>
AM_CONFIG_HEADER (to support older automake versions)
@@ -15477,7 +17473,7 @@
correct definitions for compiling geos using MingW/msys on
Windows.
-2006-08-03 22:46 Sandro Santilli <strk at keybit.net>
+2006-08-03 22:46 Sandro Santilli <strk at kbt.io>
* [r1805] ChangeLog: try to keep text within 80 cols
@@ -15525,7 +17521,7 @@
* [r1797] .: Added svn:ignore property to ignore 'geos-3.0.0rc1'
dir (testing commit access to SVN).
-2006-07-26 19:06 Sandro Santilli <strk at keybit.net>
+2006-07-26 19:06 Sandro Santilli <strk at kbt.io>
* [r1795] .cvsignore, capi/.cvsignore, doc/.cvsignore,
macros/.cvsignore, source/.cvsignore,
@@ -15582,7 +17578,7 @@
tests/unit/.cvsignore, tests/xmltester/.cvsignore,
tools/.cvsignore: Removed .cvsignore files from repository
-2006-07-26 17:51 Sandro Santilli <strk at keybit.net>
+2006-07-26 17:51 Sandro Santilli <strk at kbt.io>
* [r1794] ChangeLog, capi/Makefile.am,
tests/xmltester/XMLTester.cpp: * capi/Makefile.am: forced link of
@@ -15590,12 +17586,12 @@
* tests/xmltester/XMLTester.cpp: added <cmath> include (for fabs
use)
-2006-07-26 15:28 Sandro Santilli <strk at keybit.net>
+2006-07-26 15:28 Sandro Santilli <strk at kbt.io>
* [r1776] ChangeLog, source/headers/geos/geom/BinaryOp.h: Added
geometry snapping heuristic
-2006-07-25 20:45 Sandro Santilli <strk at keybit.net>
+2006-07-25 20:45 Sandro Santilli <strk at kbt.io>
* [r1775] ChangeLog, autogen.sh: Made autogen.sh errors more
visible
@@ -15606,18 +17602,18 @@
http://geos.refractions.net/pipermail/geos-devel/2006-July/002463.html
for more info.
-2006-07-21 17:59 Sandro Santilli <strk at keybit.net>
+2006-07-21 17:59 Sandro Santilli <strk at kbt.io>
* [r1772] ChangeLog, tests/unit/Makefile.am,
tests/unit/precision/GeometrySnapperTest.cpp: Added test for
GeometrySnapper
* [r1771] source/precision/LineStringSnapper.cpp: Fixed
preprocessor directive use
-2006-07-21 17:09 Sandro Santilli <strk at keybit.net>
+2006-07-21 17:09 Sandro Santilli <strk at kbt.io>
* [r1770] ChangeLog,
@@ -15631,12 +17627,12 @@
precision::LineStringSnapper class + test
and precision::GeometrySnapper (w/out test)
-2006-07-21 17:05 Sandro Santilli <strk at keybit.net>
+2006-07-21 17:05 Sandro Santilli <strk at kbt.io>
* [r1769] ChangeLog, source/headers/geos/geom/CoordinateList.h:
added operator<< for CoordinateList class
-2006-07-21 17:00 Sandro Santilli <strk at keybit.net>
+2006-07-21 17:00 Sandro Santilli <strk at kbt.io>
* [r1768] ChangeLog, tests/unit/geom/LineSegmentTest.cpp: Added
another distance() test
@@ -15647,7 +17643,7 @@
source/headers/geos/io.h: Wrapped FIXME message with #warning
directive to shout about potential headers removal in future.
-2006-07-21 14:53 Sandro Santilli <strk at keybit.net>
+2006-07-21 14:53 Sandro Santilli <strk at kbt.io>
* [r1766] ChangeLog, source/headers/geos/geom/CoordinateList.h,
source/headers/geos/geom/Makefile.am, tests/unit/Makefile.am,
@@ -15655,12 +17651,12 @@
re-introduced, for list-based ops
(not strictly mapped to JTS version, not yet at least)
-2006-07-21 14:49 Sandro Santilli <strk at keybit.net>
+2006-07-21 14:49 Sandro Santilli <strk at kbt.io>
* [r1765] source/headers/geos/geom/LineSegment.h: Fixed typo in
comment
-2006-07-21 08:33 Sandro Santilli <strk at keybit.net>
+2006-07-21 08:33 Sandro Santilli <strk at kbt.io>
* [r1764] swig/ruby/test/Makefile.am: Removed blank space after
backslash (automake complained)
@@ -15982,16 +17978,16 @@
* [r1705] swig/geos.i, swig/ruby/ruby.i: Ported SWIG bindings to
use c-api.
-2006-07-10 22:29 Sandro Santilli <strk at keybit.net>
+2006-07-10 22:29 Sandro Santilli <strk at kbt.io>
* [r1704] tests/tut, tests/tut/.cvsignore: Added .cvsignore file
-2006-07-10 21:51 Sandro Santilli <strk at keybit.net>
+2006-07-10 21:51 Sandro Santilli <strk at kbt.io>
* [r1703] ChangeLog, capi/geos_c.cpp: don't use dynamic strings as
format arg the formatted message callbacks.
-2006-07-10 10:16 Sandro Santilli <strk at keybit.net>
+2006-07-10 10:16 Sandro Santilli <strk at kbt.io>
* [r1702] ChangeLog,
source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h:
@@ -16023,12 +18019,12 @@
tests/unit/noding/SegmentStringTest.cpp: Added new tests cases to
tests/unit/noding. Removed zero-to-pointer casts.
-2006-07-09 00:24 Sandro Santilli <strk at keybit.net>
+2006-07-09 00:24 Sandro Santilli <strk at kbt.io>
* [r1696] tests/xmltester/Makefile.am: Added testrunner to
CLEANFILES. make distcheck now succeeds.
-2006-07-08 00:33 Sandro Santilli <strk at keybit.net>
+2006-07-08 00:33 Sandro Santilli <strk at kbt.io>
* [r1693] ChangeLog, configure.in, source/geom/Geometry.cpp,
source/geom/GeometryFactory.cpp, source/geomgraph/EdgeRing.cpp,
@@ -16059,7 +18055,7 @@
* [r1690] macros/geos.m4: Fixed versions comparison in the
GEOS_UNIT macro.
-2006-07-07 19:33 Sandro Santilli <strk at keybit.net>
+2006-07-07 19:33 Sandro Santilli <strk at kbt.io>
* [r1689] ChangeLog, acsite.m4, configure.in: * acsite.m4: include
<inttypes.h> rather then <stdint.h>
@@ -16083,49 +18079,49 @@
full paths to geos-config passed to --with-geos. Fixed version
decoding.
-2006-07-05 22:54 Sandro Santilli <strk at keybit.net>
+2006-07-05 22:54 Sandro Santilli <strk at kbt.io>
* [r1685] ChangeLog, tests/unit/Makefile.am: distribute utility.h
-2006-07-05 22:19 Sandro Santilli <strk at keybit.net>
+2006-07-05 22:19 Sandro Santilli <strk at kbt.io>
* [r1684] ChangeLog, configure.in, tests/Makefile.am,
tests/tut/Makefile.am: distribute the TUT framework.
-2006-07-05 21:47 Sandro Santilli <strk at keybit.net>
+2006-07-05 21:47 Sandro Santilli <strk at kbt.io>
* [r1683] ChangeLog, tests/xmltester/Makefile.am: Distribute XML
tests and tester.
-2006-07-05 21:18 Sandro Santilli <strk at keybit.net>
+2006-07-05 21:18 Sandro Santilli <strk at kbt.io>
* [r1682] ChangeLog, source/operation/valid/Makefile.am: Fixed
missing SweeplineNestedRingTester.cpp file.
-2006-07-05 20:52 Sandro Santilli <strk at keybit.net>
+2006-07-05 20:52 Sandro Santilli <strk at kbt.io>
* [r1681] ChangeLog,
source/headers/geos/operation/linemerge/Makefile.am: Fixed
missing backslash, dropping headers from distribution.
-2006-07-05 20:20 Sandro Santilli <strk at keybit.net>
+2006-07-05 20:20 Sandro Santilli <strk at kbt.io>
* [r1680] TODO: updated
-2006-07-05 20:19 Sandro Santilli <strk at keybit.net>
+2006-07-05 20:19 Sandro Santilli <strk at kbt.io>
* [r1679] ChangeLog,
source/headers/geos/operation/overlay/OverlayOp.h,
source/operation/overlay/OverlayOp.cpp: added checks for
obviously wrong result of difference and intersection ops
-2006-06-27 15:59 Sandro Santilli <strk at keybit.net>
+2006-06-27 15:59 Sandro Santilli <strk at kbt.io>
* [r1677] ChangeLog, source/algorithm/HCoordinate.cpp: *
source/algorithm/HCoordinate.cpp: added support for MingW -ansi
builds.
-2006-06-27 15:26 Sandro Santilli <strk at keybit.net>
+2006-06-27 15:26 Sandro Santilli <strk at kbt.io>
* [r1676] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: *
capi/geos_c.cpp: fixed forward declaration of
@@ -16133,7 +18129,7 @@
* capi/geos_c.h.in: renamed GEOSGeomTypeId enum to GEOSGeomTypes,
to make VC++ 2005 happy.
-2006-06-19 23:33 Sandro Santilli <strk at keybit.net>
+2006-06-19 23:33 Sandro Santilli <strk at kbt.io>
* [r1675] ChangeLog, source/headers/geos/geom/CoordinateFilter.h,
source/headers/geos/noding/ScaledNoder.h,
@@ -16142,29 +18138,29 @@
source/noding/ScaledNoder.cpp: Don't *require* CoordinateFilters
to define both read-only and read-write methods.
-2006-06-19 22:52 Sandro Santilli <strk at keybit.net>
+2006-06-19 22:52 Sandro Santilli <strk at kbt.io>
* [r1674] ChangeLog, source/geom/Polygon.cpp: optimized loops
-2006-06-19 21:20 Sandro Santilli <strk at keybit.net>
+2006-06-19 21:20 Sandro Santilli <strk at kbt.io>
* [r1673] ChangeLog, source/geom/util/GeometryTransformer.cpp,
source/headers/geos/geom/util/GeometryTransformer.h: updated port
info
-2006-06-19 21:17 Sandro Santilli <strk at keybit.net>
+2006-06-19 21:17 Sandro Santilli <strk at kbt.io>
* [r1672] ChangeLog, source/geom/GeometryFactory.cpp,
source/headers/geos/geom/GeometryFactory.h,
source/headers/geos/geom/GeometryFactory.inl: port info and
doxygen dox.
-2006-06-19 20:48 Sandro Santilli <strk at keybit.net>
+2006-06-19 20:48 Sandro Santilli <strk at kbt.io>
* [r1671] ChangeLog, tests/xmltester/XMLTester.cpp: parseCase():
make sure to exit the <case> tag before returning
-2006-06-14 19:27 Sandro Santilli <strk at keybit.net>
+2006-06-14 19:27 Sandro Santilli <strk at kbt.io>
* [r1670] ChangeLog, source/geom/Coordinate.cpp,
source/headers/geos/geom/Coordinate.h,
@@ -16172,28 +18168,28 @@
synthetize copy ctor and assignment op for Coordinate class to
obtain better numerical stability.
-2006-06-14 19:19 Sandro Santilli <strk at keybit.net>
+2006-06-14 19:19 Sandro Santilli <strk at kbt.io>
* [r1669] ChangeLog, tests/xmltester/XMLTester.cpp: Added support
for "AreaTest" operations.
-2006-06-14 19:17 Sandro Santilli <strk at keybit.net>
+2006-06-14 19:17 Sandro Santilli <strk at kbt.io>
* [r1668] ChangeLog, source/operation/overlay/PolygonBuilder.cpp:
Fixed bug in findShell() needlessly erasing vector elements
-2006-06-14 15:38 Sandro Santilli <strk at keybit.net>
+2006-06-14 15:38 Sandro Santilli <strk at kbt.io>
* [r1667] source/operation/overlay/OverlayOp.cpp: Fixed
just-introduced bug
-2006-06-14 15:03 Sandro Santilli <strk at keybit.net>
+2006-06-14 15:03 Sandro Santilli <strk at kbt.io>
* [r1666] ChangeLog, source/operation/overlay/OverlayOp.cpp: *
source/operation/overlay/OverlayOp.cpp: use NodeMap::container
and related typedefs, removed (int) casts, optimized loops.
-2006-06-14 14:32 Sandro Santilli <strk at keybit.net>
+2006-06-14 14:32 Sandro Santilli <strk at kbt.io>
* [r1665] ChangeLog, source/geomgraph/EdgeEnd.cpp,
source/headers/geos/geomgraph/DirectedEdge.h,
@@ -16201,133 +18197,133 @@
source/headers/geos/geomgraph/EdgeEnd.h: EdgeEnd::getEdge() made
non-virtual and inlined.
-2006-06-14 13:59 Sandro Santilli <strk at keybit.net>
+2006-06-14 13:59 Sandro Santilli <strk at kbt.io>
* [r1664] ChangeLog, source/operation/overlay/PolygonBuilder.cpp:
Fixed bug in PolygonBuilder::placePolygonHoles, performance
improved as a side effect.
-2006-06-13 23:26 Sandro Santilli <strk at keybit.net>
+2006-06-13 23:26 Sandro Santilli <strk at kbt.io>
* [r1663] ChangeLog,
source/headers/geos/operation/overlay/PolygonBuilder.h,
source/operation/overlay/PolygonBuilder.cpp: cleanups
-2006-06-13 22:50 Sandro Santilli <strk at keybit.net>
+2006-06-13 22:50 Sandro Santilli <strk at kbt.io>
* [r1662] ChangeLog, source/headers/geos/io/WKTReader.inl: *
source/headers/geos/io/WKTReader.inl: added missing include for
GEOS_DEBUG set case, use stderr for debugging output.
-2006-06-13 22:19 Sandro Santilli <strk at keybit.net>
+2006-06-13 22:19 Sandro Santilli <strk at kbt.io>
* [r1661] ChangeLog, source/operation/overlay/LineBuilder.cpp:
fixed unused parameter warning
-2006-06-13 22:00 Sandro Santilli <strk at keybit.net>
+2006-06-13 22:00 Sandro Santilli <strk at kbt.io>
* [r1660] ChangeLog, source/headers/geos/geomgraph/GeometryGraph.h:
Changed GeometryGraph::lineEdgeMap set comparison function to be
pointer-based. Should be safe and much faster. Available tests
all succeed.
-2006-06-13 21:42 Sandro Santilli <strk at keybit.net>
+2006-06-13 21:42 Sandro Santilli <strk at kbt.io>
* [r1659] source/operation/overlay/OverlayOp.cpp: trimmed cvs log,
cleanups
-2006-06-13 21:40 Sandro Santilli <strk at keybit.net>
+2006-06-13 21:40 Sandro Santilli <strk at kbt.io>
* [r1658] source/geomgraph/GeometryGraph.cpp: Cleanups and some
more debugging lines
-2006-06-13 21:38 Sandro Santilli <strk at keybit.net>
+2006-06-13 21:38 Sandro Santilli <strk at kbt.io>
* [r1657] ChangeLog, source/geom/Geometry.cpp: Added self
comparison check in Geometry::compareTo().
-2006-06-13 19:16 Sandro Santilli <strk at keybit.net>
+2006-06-13 19:16 Sandro Santilli <strk at kbt.io>
* [r1656] ChangeLog: fixed mis-assigned commit
-2006-06-12 17:18 Sandro Santilli <strk at keybit.net>
+2006-06-12 17:18 Sandro Santilli <strk at kbt.io>
* [r1655] ChangeLog, source/simplify/LineSegmentIndex.cpp:
LineSegmentIndex: explicitly initialized parent class in
constructors.
-2006-06-12 17:15 Sandro Santilli <strk at keybit.net>
+2006-06-12 17:15 Sandro Santilli <strk at kbt.io>
* [r1654] ChangeLog, source/headers/geos/index/quadtree/Root.h,
source/headers/geos/operation/distance/ConnectedElementPointFilter.h,
source/headers/geos/operation/polygonize/Polygonizer.h: Removed
unused parameters warning
-2006-06-12 17:14 Sandro Santilli <strk at keybit.net>
+2006-06-12 17:14 Sandro Santilli <strk at kbt.io>
* [r1653] ChangeLog, source/headers/geos/geom/GeometryFilter.h:
added assert(0) version of filter_ro() and filter_rw() to allow
implementations to only defined the required one.
-2006-06-12 16:59 Sandro Santilli <strk at keybit.net>
+2006-06-12 16:59 Sandro Santilli <strk at kbt.io>
* [r1652] tests/bigtest/TestSweepLineSpeed.cpp,
tests/xmltester/SimpleWKTTester.cpp: Removed unused parameter
warnings
-2006-06-12 16:57 Sandro Santilli <strk at keybit.net>
+2006-06-12 16:57 Sandro Santilli <strk at kbt.io>
* [r1651] source/headers/geos/planargraph/Node.h: Added note about
ownership of return from getEdgesBetween()
-2006-06-12 16:55 Sandro Santilli <strk at keybit.net>
+2006-06-12 16:55 Sandro Santilli <strk at kbt.io>
* [r1650] ChangeLog, source/headers/geos/io/WKTWriter.h,
source/io/WKTWriter.cpp: fixed compiler warnings, fixed some
methods to omit unused parameters.
-2006-06-12 16:51 Sandro Santilli <strk at keybit.net>
+2006-06-12 16:51 Sandro Santilli <strk at kbt.io>
* [r1649] ChangeLog, source/geom/CoordinateSequence.cpp,
tests/unit/geom/CoordinateArraySequenceTest.cpp: Added equality
and inequality operators and tests
-2006-06-12 16:36 Sandro Santilli <strk at keybit.net>
+2006-06-12 16:36 Sandro Santilli <strk at kbt.io>
* [r1648] ChangeLog, source/geom/CoordinateSequence.cpp,
source/headers/geos/geom/CoordinateSequence.h: indentation, notes
about things to be fixed.
-2006-06-12 15:47 Sandro Santilli <strk at keybit.net>
+2006-06-12 15:47 Sandro Santilli <strk at kbt.io>
* [r1647] ChangeLog, source/planargraph/Node.cpp: implemented
missing getEdgesBetween() method (untested).
-2006-06-12 15:46 Sandro Santilli <strk at keybit.net>
+2006-06-12 15:46 Sandro Santilli <strk at kbt.io>
* [r1646] source/headers/geos/planargraph/DirectedEdge.h,
source/planargraph/DirectedEdge.cpp: provided a memory friendly
version of toEdges() method.
-2006-06-12 15:07 Sandro Santilli <strk at keybit.net>
+2006-06-12 15:07 Sandro Santilli <strk at kbt.io>
* [r1645] ChangeLog, source/geom/CoordinateArraySequence.cpp:
explicitly invoked CoordinateSequence (copy) ctor - suggested by
GCC warning.
-2006-06-12 15:06 Sandro Santilli <strk at keybit.net>
+2006-06-12 15:06 Sandro Santilli <strk at kbt.io>
* [r1644] source/headers/geos/geom/CoordinateSequence.h: Added
default ctor and copy ctor (protected)
-2006-06-12 13:57 Sandro Santilli <strk at keybit.net>
+2006-06-12 13:57 Sandro Santilli <strk at kbt.io>
* [r1643] ChangeLog, acsite.m4, configure.in,
source/headers/geos/platform.h.in: Check for int64_t type for
int64 typedef.
-2006-06-12 11:29 Sandro Santilli <strk at keybit.net>
+2006-06-12 11:29 Sandro Santilli <strk at kbt.io>
* [r1642] ChangeLog, source/algorithm/SimplePointInAreaLocator.cpp,
@@ -16371,7 +18367,7 @@
source/simplify/TaggedLineString.cpp, source/util/Profiler.cpp:
unsigned int => size_t
-2006-06-12 10:49 Sandro Santilli <strk at keybit.net>
+2006-06-12 10:49 Sandro Santilli <strk at kbt.io>
* [r1641] ChangeLog, source/algorithm/ConvexHull.cpp,
source/algorithm/PointLocator.cpp, source/geom/Envelope.cpp,
@@ -16390,12 +18386,12 @@
source/operation/linemerge/LineSequencer.cpp,
source/planargraph/PlanarGraph.cpp: unsigned int => size_t
-2006-06-12 10:39 Sandro Santilli <strk at keybit.net>
+2006-06-12 10:39 Sandro Santilli <strk at kbt.io>
* [r1640] ChangeLog, tests/xmltester/XMLTester.cpp: don't print
test file precision model if verbosity level < 2.
-2006-06-12 10:10 Sandro Santilli <strk at keybit.net>
+2006-06-12 10:10 Sandro Santilli <strk at kbt.io>
* [r1639] ChangeLog, NEWS, capi/geos_c.h.in,
@@ -16417,29 +18413,29 @@
getGeometryN() to take size_t rather then int, changed unsigned
int parameters to size_t.
-2006-06-09 08:28 Sandro Santilli <strk at keybit.net>
+2006-06-09 08:28 Sandro Santilli <strk at kbt.io>
* [r1638] tests/xmltester/SimpleWKTTester.cpp: Removed compiler
warning
-2006-06-09 08:17 Sandro Santilli <strk at keybit.net>
+2006-06-09 08:17 Sandro Santilli <strk at kbt.io>
* [r1637] ChangeLog, tests/unit/noding/SegmentStringTest.cpp:
removed signed/unsigned comparison warnings.
-2006-06-09 08:09 Sandro Santilli <strk at keybit.net>
+2006-06-09 08:09 Sandro Santilli <strk at kbt.io>
* [r1636] ChangeLog, tests/unit/geom/LinearRingTest.cpp,
tests/unit/geom/MultiPointTest.cpp,
tests/unit/geom/PolygonTest.cpp: removed signed/unsigned
-2006-06-09 08:02 Sandro Santilli <strk at keybit.net>
+2006-06-09 08:02 Sandro Santilli <strk at kbt.io>
* [r1635] ChangeLog, tests/unit/geom/LineStringTest.cpp: Fixed
signed/unsigned comparison tests
-2006-06-09 07:42 Sandro Santilli <strk at keybit.net>
+2006-06-09 07:42 Sandro Santilli <strk at kbt.io>
* [r1634] ChangeLog, source/geomgraph/GeometryGraph.cpp,
source/operation/buffer/OffsetCurveSetBuilder.cpp,
@@ -16452,7 +18448,7 @@
after Polygon ring accessor methods changed to work with size_t.
Small optimizations in loops.
-2006-06-09 06:41 Sandro Santilli <strk at keybit.net>
+2006-06-09 06:41 Sandro Santilli <strk at kbt.io>
* [r1633] ChangeLog: Added missing log for mloskot change
@@ -16461,13 +18457,13 @@
* [r1632] tests/unit/geom/DimensionTest.cpp: Fixed no-effect
warning in test<1> from DimensionTest.cpp.
-2006-06-08 18:18 Sandro Santilli <strk at keybit.net>
+2006-06-08 18:18 Sandro Santilli <strk at kbt.io>
* [r1631] ChangeLog, tests/unit/geom/GeometryFactoryTest.cpp: *
tests/unit/geom/GeometryFactoryTest.cpp: fixed compiler warnings
about signed/unsigned comparisons.
-2006-06-08 17:58 Sandro Santilli <strk at keybit.net>
+2006-06-08 17:58 Sandro Santilli <strk at kbt.io>
* [r1630] ChangeLog, NEWS, source/algorithm/CentroidArea.cpp,
source/geom/Polygon.cpp, source/geom/util/GeometryEditor.cpp,
@@ -16475,36 +18471,36 @@
Polygon::getNumInteriorRing() return size_t,
Polygon::interiorRingN() takes size_t.
-2006-06-08 17:46 Sandro Santilli <strk at keybit.net>
+2006-06-08 17:46 Sandro Santilli <strk at kbt.io>
* [r1629] ChangeLog,
tests/unit/geom/CoordinateArraySequenceTest.cpp: fix
signed/unsigned comparison warning.
-2006-06-08 15:55 Sandro Santilli <strk at keybit.net>
+2006-06-08 15:55 Sandro Santilli <strk at kbt.io>
* [r1628] ChangeLog, tests/xmltester/markup/MarkupSTL.cpp: *
tests/xmltester/markup/MarkupSTL.cpp: removed use of
allocator<char>, which brings in some incompatibilities with
libstdc++ 6.0.7 (gcc 4.0.2).
-2006-06-08 13:19 Sandro Santilli <strk at keybit.net>
+2006-06-08 13:19 Sandro Santilli <strk at kbt.io>
* [r1627] configure.in: Commented out ruby and python detection
-2006-06-08 12:58 Sandro Santilli <strk at keybit.net>
+2006-06-08 12:58 Sandro Santilli <strk at kbt.io>
* [r1626] tests/xmltester/Makefile.am,
tests/xmltester/testrunner.sh: Fixed xml testrunner rule
-2006-06-08 12:16 Sandro Santilli <strk at keybit.net>
+2006-06-08 12:16 Sandro Santilli <strk at kbt.io>
* [r1625] ChangeLog, tests/xmltester/Makefile.am,
tests/xmltester/testrunner.sh: added XML tests run to the 'make
check' rule.
-2006-06-08 11:20 Sandro Santilli <strk at keybit.net>
+2006-06-08 11:20 Sandro Santilli <strk at kbt.io>
* [r1624] ChangeLog,
source/headers/geos/geom/CoordinateSequenceFactory.h,
@@ -16519,22 +18515,22 @@
source/headers/geos/index/sweepline/SweepLineOverlapAction.h:
Added missing virtual destructor to abstract classes.
-2006-06-07 20:04 Sandro Santilli <strk at keybit.net>
+2006-06-07 20:04 Sandro Santilli <strk at kbt.io>
* [r1623] ChangeLog, configure.in: * configure.in: enforce -Wall
-ansi -pedantic -Wno-long-long to C and CXX flags.
-2006-06-07 19:45 Sandro Santilli <strk at keybit.net>
+2006-06-07 19:45 Sandro Santilli <strk at kbt.io>
* [r1622] swig/ruby/test/Makefile.am: Renamed (reserved) TESTS
variable to RUBY_TESTS
-2006-06-07 19:26 Sandro Santilli <strk at keybit.net>
+2006-06-07 19:26 Sandro Santilli <strk at kbt.io>
* [r1621] Makefile.am: Fixed SUBDIRS order, and added a NOTE about
maintaining it.
-2006-06-07 17:03 Sandro Santilli <strk at keybit.net>
+2006-06-07 17:03 Sandro Santilli <strk at kbt.io>
* [r1620] ChangeLog, Makefile.am, configure.in,
swig/python/Makefile.am, swig/ruby/Makefile.am,
@@ -16544,7 +18540,7 @@
process.
* configure.in: removed check for boost availability.
-2006-06-07 16:07 Sandro Santilli <strk at keybit.net>
+2006-06-07 16:07 Sandro Santilli <strk at kbt.io>
* [r1619] configure.in: Set release version to 3.0.0rc1
@@ -16567,18 +18563,18 @@
tests/unit/algorithm/CGAlgorithms/isPointInRing.cpp: Added new
test: CGAlgorithms/isPointInRing.cpp.
-2006-06-07 13:10 Sandro Santilli <strk at keybit.net>
+2006-06-07 13:10 Sandro Santilli <strk at kbt.io>
* [r1615] ChangeLog, source/headers/geos/geom.h: Removed Triangle.h
include from geom.h
-2006-06-07 13:08 Sandro Santilli <strk at keybit.net>
+2006-06-07 13:08 Sandro Santilli <strk at kbt.io>
* [r1614] ChangeLog, source/headers/geos/geom/Makefile.am: *
source/headers/geos/geom/Makefile.am: removed Triangle.h from
installed header set.
-2006-06-05 19:42 Sandro Santilli <strk at keybit.net>
+2006-06-05 19:42 Sandro Santilli <strk at kbt.io>
* [r1613] ChangeLog, source/headers/geos/Makefile.am,
source/headers/geos/algorithm/Makefile.am,
@@ -16619,7 +18615,7 @@
source/headers/geos/util.h, source/headers/geos/util/Makefile.am:
Fixed noinst_geos_HEADERS => noinst_HEADERS.
-2006-06-05 15:36 Sandro Santilli <strk at keybit.net>
+2006-06-05 15:36 Sandro Santilli <strk at kbt.io>
* [r1612] ChangeLog, NEWS, capi/geos_c.cpp,
source/geom/Geometry.cpp, source/headers/geos/noding.h,
@@ -16644,7 +18640,7 @@
fully qualified namespace for LineSegment because we're inside of
geos::simplify at the time
-2006-06-01 11:49 Sandro Santilli <strk at keybit.net>
+2006-06-01 11:49 Sandro Santilli <strk at kbt.io>
* [r1609] ChangeLog, source/headers/geos/geomgraph.h,
source/headers/geos/geomgraph/Makefile.am,
@@ -16662,7 +18658,7 @@
source/io/WKTWriter.cpp, source/io/Writer.cpp: Reduced installed
headers form geomgraph namespace
-2006-06-01 10:28 Sandro Santilli <strk at keybit.net>
+2006-06-01 10:28 Sandro Santilli <strk at kbt.io>
* [r1608] ChangeLog, source/headers/geos/index/bintree/Makefile.am,
source/headers/geos/index/chain/Makefile.am,
@@ -16678,7 +18674,7 @@
source/operation/valid/Makefile.am: Reduced number of installed
headers for the geos::index namespace
-2006-05-25 18:44 Sandro Santilli <strk at keybit.net>
+2006-05-25 18:44 Sandro Santilli <strk at kbt.io>
* [r1607] ChangeLog, tests/unit/geom/TriangleTest.cpp: *
tests/unit/geom/TriangleTest.cpp: take floating-point rounding
@@ -16694,20 +18690,20 @@
* [r1605] tests/tut/tut.h: Added specialization of ensure_equals
for double type.
-2006-05-24 16:29 Sandro Santilli <strk at keybit.net>
+2006-05-24 16:29 Sandro Santilli <strk at kbt.io>
* [r1604] ChangeLog, source/index/quadtree/DoubleBits.cpp: *
source/index/quadtree/DoubleBits.cpp: handled negative or zero
values in getExponent().
-2006-05-24 16:01 Sandro Santilli <strk at keybit.net>
+2006-05-24 16:01 Sandro Santilli <strk at kbt.io>
* [r1603] ChangeLog, tests/unit/utility.h: * tests/unit/utility.h:
fixed missing return from isSameStructure's specialization on
GeometryCollection, also fixed a signed/unsigned mismatch warning
there.
-2006-05-24 15:42 Sandro Santilli <strk at keybit.net>
+2006-05-24 15:42 Sandro Santilli <strk at kbt.io>
* [r1602] ChangeLog, source/util/CoordinateArrayFiter.cpp,
source/util/GEOSException.cpp, source/util/Makefile.am,
@@ -16717,7 +18713,7 @@
source/util/UniqueCoordinateArrayFilter.cpp: removed empty
implementation files.
-2006-05-24 15:32 Sandro Santilli <strk at keybit.net>
+2006-05-24 15:32 Sandro Santilli <strk at kbt.io>
* [r1601] ChangeLog,
source/headers/geos/simplify/TaggedLinesSimplifier.h: *
@@ -16725,7 +18721,7 @@
LineSegmentIndex.h include so that every use of the templated
simplify() function get all the required definitions.
-2006-05-24 15:17 Sandro Santilli <strk at keybit.net>
+2006-05-24 15:17 Sandro Santilli <strk at kbt.io>
* [r1600] ChangeLog, source/headers/geos/algorithm/Makefile.am,
@@ -16741,7 +18737,7 @@
source/headers/geos/planargraph/Makefile.am: Reduced number of
installed headers in geos/operation/ subdir
-2006-05-24 13:44 Sandro Santilli <strk at keybit.net>
+2006-05-24 13:44 Sandro Santilli <strk at kbt.io>
* [r1599] NEWS: Added a note about unit tests being introduced
@@ -16749,7 +18745,7 @@
* [r1598] ChangeLog: Added missing entries to ChangeLog.
-2006-05-24 11:41 Sandro Santilli <strk at keybit.net>
+2006-05-24 11:41 Sandro Santilli <strk at kbt.io>
* [r1597] ChangeLog,
source/headers/geos/simplify/TaggedLinesSimplifier.h,
@@ -16763,7 +18759,7 @@
class to more closely match JTS and use templated
functions.
-2006-05-24 08:32 Sandro Santilli <strk at keybit.net>
+2006-05-24 08:32 Sandro Santilli <strk at kbt.io>
* [r1596] ChangeLog, capi/geos_c.h.in: * capi/geos_c.h.in: #include
<stddef.h> to get size_t definition (only #ifndef __cplusplus)
@@ -16776,19 +18772,19 @@
TopologyPreservingSimplifierTest.cpp. Added new utility.cpp
helper for Unit Tests (implementes utils from JTS Unit Tests).
-2006-05-23 15:06 Sandro Santilli <strk at keybit.net>
+2006-05-23 15:06 Sandro Santilli <strk at kbt.io>
* [r1594] ChangeLog, source/headers/geos/geom/Coordinate.h: *
source/headers/geos/geom/Coordinate.h: added missing <string>
include.
-2006-05-23 14:44 Sandro Santilli <strk at keybit.net>
+2006-05-23 14:44 Sandro Santilli <strk at kbt.io>
* [r1593] ChangeLog, source/headers/geos/config.h: *
source/headers/geos/config.h: removed file which is not supposed
to be in the repository.
-2006-05-23 14:29 Sandro Santilli <strk at keybit.net>
+2006-05-23 14:29 Sandro Santilli <strk at kbt.io>
* [r1592] ChangeLog,
source/headers/geos/index/quadtree/DoubleBits.h,
@@ -16797,52 +18793,52 @@
source/index/quadtree/DoubleBits.cpp: const correctness and
documentation.
-2006-05-23 13:21 Sandro Santilli <strk at keybit.net>
+2006-05-23 13:21 Sandro Santilli <strk at kbt.io>
* [r1591] tests/unit/io/ByteOrderValuesTest.cpp: Added test for
put/get Long values
-2006-05-23 13:16 Sandro Santilli <strk at keybit.net>
+2006-05-23 13:16 Sandro Santilli <strk at kbt.io>
* [r1590] ChangeLog, source/io/WKBWriter.cpp: Fixed a bug in
WKBWriter::writeByteOrder() failing to consider machine's byte
order
-2006-05-23 12:57 Sandro Santilli <strk at keybit.net>
+2006-05-23 12:57 Sandro Santilli <strk at kbt.io>
* [r1589] tests/unit/geom/CoordinateTest.cpp: Fixed small typo in
label
-2006-05-23 12:33 Sandro Santilli <strk at keybit.net>
+2006-05-23 12:33 Sandro Santilli <strk at kbt.io>
* [r1588] ChangeLog, source/io/ByteOrderValues.cpp: *
source/io/ByteOrderValues.cpp: fixed bug in putLong() also
affecting putDouble()
-2006-05-23 12:23 Sandro Santilli <strk at keybit.net>
+2006-05-23 12:23 Sandro Santilli <strk at kbt.io>
* [r1587] ChangeLog, tests/unit/Makefile.am,
tests/unit/io/ByteOrderValuesTest.cpp: * tests/unit/Makefile.am,
tests/unit/io/ByteOrderValuesTest.cpp: unit test for
ByteOrderValues class.
-2006-05-23 11:07 Sandro Santilli <strk at keybit.net>
+2006-05-23 11:07 Sandro Santilli <strk at kbt.io>
* [r1586] ChangeLog, source/io/WKBWriter.cpp: *
source/io/WKBWriter.cpp: fixed bug in ::writeInt missing to
honour the requested byte order.
-2006-05-23 10:56 Sandro Santilli <strk at keybit.net>
+2006-05-23 10:56 Sandro Santilli <strk at kbt.io>
* [r1585] tests/unit/io/WKBReaderTest.cpp: Fixed top comment
-2006-05-23 10:48 Sandro Santilli <strk at keybit.net>
+2006-05-23 10:48 Sandro Santilli <strk at kbt.io>
* [r1584] ChangeLog, tests/unit/io/WKBReaderTest.cpp: *
tests/unit/io/WKBReaderTest.cpp: cleaned up and added both XDR
and NDR tests.
-2006-05-23 09:24 Sandro Santilli <strk at keybit.net>
+2006-05-23 09:24 Sandro Santilli <strk at kbt.io>
* [r1583] ChangeLog, source/headers/geos/io/WKBConstants.h,
source/io/ByteOrderValues.cpp: * source/io/ByteOrderValues.cpp:
@@ -16851,12 +18847,12 @@
* source/headers/geos/io/WKBConstants.h: added comments about
meaning of XDR/NDR.
-2006-05-22 15:08 Sandro Santilli <strk at keybit.net>
+2006-05-22 15:08 Sandro Santilli <strk at kbt.io>
* [r1582] source/headers/geos/util/GEOSException.h: Print colon
after exception name (as it has always been)
-2006-05-19 17:44 Sandro Santilli <strk at keybit.net>
+2006-05-19 17:44 Sandro Santilli <strk at kbt.io>
* [r1581] ChangeLog,
source/simplify/TopologyPreservingSimplifier.cpp: *
@@ -16865,45 +18861,45 @@
TopologyPreservingSimplifier helper class
(no more needed)
-2006-05-19 17:39 Sandro Santilli <strk at keybit.net>
+2006-05-19 17:39 Sandro Santilli <strk at kbt.io>
* [r1580] ChangeLog, tests/unit/geom/Geometry/coversTest.cpp: *
keep tests in 'tut' namespace.
-2006-05-19 16:38 Sandro Santilli <strk at keybit.net>
+2006-05-19 16:38 Sandro Santilli <strk at kbt.io>
* [r1579] ChangeLog, tests/xmltester/XMLTester.cpp: *
tests/xmltester/XMLTester.cpp: report
error on load of requested tests.
-2006-05-18 10:19 Sandro Santilli <strk at keybit.net>
+2006-05-18 10:19 Sandro Santilli <strk at kbt.io>
* [r1578] ChangeLog, source/headers/geos/geom.h: *
source/headers/geos/geom.h: fixed doxygen header for mainpage.
-2006-05-18 10:16 Sandro Santilli <strk at keybit.net>
+2006-05-18 10:16 Sandro Santilli <strk at kbt.io>
* [r1577] NEWS: Added note about the new BinaryOp class and its
uses.
-2006-05-18 10:13 Sandro Santilli <strk at keybit.net>
+2006-05-18 10:13 Sandro Santilli <strk at kbt.io>
* [r1576] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
source/headers/geos/geom/BinaryOp.h: added compile-time defines
to avoid precision-reduction and simplify based policies (default
to enabled).
-2006-05-18 09:32 Sandro Santilli <strk at keybit.net>
+2006-05-18 09:32 Sandro Santilli <strk at kbt.io>
* [r1575] NEWS: added note about new Geometry predicates
-2006-05-18 09:00 Sandro Santilli <strk at keybit.net>
+2006-05-18 09:00 Sandro Santilli <strk at kbt.io>
* [r1574] ChangeLog, tests/unit/geom/Geometry/coversTest.cpp: Added
tests for coveredBy(), fixed ChangeLog entry
-2006-05-18 08:56 Sandro Santilli <strk at keybit.net>
+2006-05-18 08:56 Sandro Santilli <strk at kbt.io>
* [r1573] ChangeLog, source/geom/Geometry.cpp,
source/headers/geos/geom/Geometry.h, tests/unit/Makefile.am,
@@ -16915,20 +18911,20 @@
added test for covers() predicates.
-2006-05-17 17:41 Sandro Santilli <strk at keybit.net>
+2006-05-17 17:41 Sandro Santilli <strk at kbt.io>
* [r1572] source/geom/IntersectionMatrix.cpp,
source/headers/geos/geom/IntersectionMatrix.h,
tests/unit/geom/IntersectionMatrixTest.cpp: Added output operator
+ test
-2006-05-17 17:24 Sandro Santilli <strk at keybit.net>
+2006-05-17 17:24 Sandro Santilli <strk at kbt.io>
* [r1571] ChangeLog, source/geom/IntersectionMatrix.cpp,
source/headers/geos/geom/IntersectionMatrix.h: Added port info,
fixed isCoveredBy() comment.
-2006-05-17 17:20 Sandro Santilli <strk at keybit.net>
+2006-05-17 17:20 Sandro Santilli <strk at kbt.io>
* [r1570] ChangeLog, source/geom/IntersectionMatrix.cpp,
@@ -16936,7 +18932,7 @@
isCoveredBy() public methods to IntersectionMatrix and associated
tests.
-2006-05-17 08:40 Sandro Santilli <strk at keybit.net>
+2006-05-17 08:40 Sandro Santilli <strk at kbt.io>
* [r1569] source/headers/geos/geom/BinaryOp.h: typo fixed to make
description more clear
@@ -16952,7 +18948,7 @@
tests/unit/geom/Geometry/isRectangleTest.cpp: Fixed line-ends in
isRectangleTest.cpp. Added new patterns to .cvsignore.
-2006-05-05 15:40 Sandro Santilli <strk at keybit.net>
+2006-05-05 15:40 Sandro Santilli <strk at kbt.io>
* [r1561] ChangeLog,
source/noding/snapround/MCIndexSnapRounder.cpp,
@@ -16960,13 +18956,13 @@
validation error throw an exception for SimpleSnapRounder
and MCIndexSnapRounder
-2006-05-05 14:34 Sandro Santilli <strk at keybit.net>
+2006-05-05 14:34 Sandro Santilli <strk at kbt.io>
* [r1560] ChangeLog, tests/unit/Makefile.am, tests/unit/noding,
tests/unit/noding/SegmentStringTest.cpp: New SegmentString unit
test
-2006-05-05 14:25 Sandro Santilli <strk at keybit.net>
+2006-05-05 14:25 Sandro Santilli <strk at kbt.io>
* [r1559] source/headers/geos/noding/SegmentString.h,
source/headers/geos/noding/SegmentString.inl,
@@ -16974,7 +18970,7 @@
.inl into .cpp, renamed private eiList to nodeList as in JTS,
added more assertion checking and fixed doxygen comments
-2006-05-05 10:19 Sandro Santilli <strk at keybit.net>
+2006-05-05 10:19 Sandro Santilli <strk at kbt.io>
* [r1558] ChangeLog, source/headers/geos/noding/SegmentString.h,
@@ -16982,13 +18978,13 @@
SegmentString::getContext(), new name is getData() to reflect
change in JTS
-2006-05-05 09:37 Sandro Santilli <strk at keybit.net>
+2006-05-05 09:37 Sandro Santilli <strk at kbt.io>
* [r1557] ChangeLog, source/headers/geos/geom.h: *
source/headers/geos/geom.h: fixed namespace qualification in
doxygen page about C++ interface.
-2006-05-04 15:49 Sandro Santilli <strk at keybit.net>
+2006-05-04 15:49 Sandro Santilli <strk at kbt.io>
* [r1556] ChangeLog, source/geom/GeometryCollection.cpp,
source/geom/LineString.cpp, source/geom/MultiLineString.cpp,
@@ -17007,7 +19003,7 @@
Geometry::getDimension() methods to return
Dimension::DimensionType (closes bug#93)
-2006-05-04 14:05 Sandro Santilli <strk at keybit.net>
+2006-05-04 14:05 Sandro Santilli <strk at kbt.io>
* [r1555] ChangeLog, source/geom/PrecisionModel.cpp,
source/headers/geos/noding/snapround/HotPixel.inl,
@@ -17017,62 +19013,62 @@
function for the whole GEOS codebase. Currently pointing at
util::java_math_round() being the last being used.
-2006-05-04 13:38 Sandro Santilli <strk at keybit.net>
+2006-05-04 13:38 Sandro Santilli <strk at kbt.io>
* [r1554] source/headers/geos/geomgraph/DirectedEdge.h: doxygen
comments cleanup
-2006-05-04 12:54 Sandro Santilli <strk at keybit.net>
+2006-05-04 12:54 Sandro Santilli <strk at kbt.io>
* [r1553] ChangeLog, source/headers/geos/geomgraph/NodeMap.h: Added
invariant tester for NodeMap class, fixed comment about ownership
of NodeFactory
-2006-05-04 12:33 Sandro Santilli <strk at keybit.net>
+2006-05-04 12:33 Sandro Santilli <strk at kbt.io>
* [r1552] source/operation/buffer/BufferSubgraph.cpp: Added some
comments about RightmostEdgeFinder only considering forward
DirectedEdge
-2006-05-04 12:19 Sandro Santilli <strk at keybit.net>
+2006-05-04 12:19 Sandro Santilli <strk at kbt.io>
* [r1551]
source/headers/geos/operation/buffer/RightmostEdgeFinder.h: Added
note about findEdge() only scanning for forward DirectedEdges
-2006-05-04 12:17 Sandro Santilli <strk at keybit.net>
+2006-05-04 12:17 Sandro Santilli <strk at kbt.io>
* [r1550] source/geomgraph/PlanarGraph.cpp: Added comment about
management of newly created DirectedEdges
-2006-05-04 10:15 Sandro Santilli <strk at keybit.net>
+2006-05-04 10:15 Sandro Santilli <strk at kbt.io>
* [r1549] ChangeLog,
source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h:
Doxygen comments
-2006-05-04 09:16 Sandro Santilli <strk at keybit.net>
+2006-05-04 09:16 Sandro Santilli <strk at kbt.io>
* [r1548] source/operation/buffer/BufferBuilder.cpp: Added JTS
debugging, for comparison with JTS
-2006-05-04 08:42 Sandro Santilli <strk at keybit.net>
+2006-05-04 08:42 Sandro Santilli <strk at kbt.io>
* [r1547] ChangeLog, source/headers/geos/geom/CoordinateSequence.h:
Added note about the CoordinateSequence::toVector() method.
-2006-05-04 08:35 Sandro Santilli <strk at keybit.net>
+2006-05-04 08:35 Sandro Santilli <strk at kbt.io>
* [r1546] ChangeLog, source/noding/SegmentNodeList.cpp:
noding/SegmentNodeList.cpp: cleanups, changed output operator to
be more similar to JTS
-2006-05-04 08:30 Sandro Santilli <strk at keybit.net>
+2006-05-04 08:30 Sandro Santilli <strk at kbt.io>
* [r1545] source/noding/ScaledNoder.cpp: removed use of
SegmentString::setCoordinates() [dropped]
-2006-05-04 08:29 Sandro Santilli <strk at keybit.net>
+2006-05-04 08:29 Sandro Santilli <strk at kbt.io>
* [r1544] ChangeLog, source/headers/geos/noding/SegmentString.h,
source/headers/geos/noding/SegmentString.inl: *
@@ -17081,59 +19077,59 @@
* source/headers/geos/noding/SegmentStrign.{h,inl}: removed new
setCoordinates() interface.
-2006-05-04 07:43 Sandro Santilli <strk at keybit.net>
+2006-05-04 07:43 Sandro Santilli <strk at kbt.io>
* [r1543] ChangeLog, source/headers/geos/noding/SegmentString.h,
source/noding/SegmentString.cpp: output operator for
SegmentString class
-2006-05-04 07:41 Sandro Santilli <strk at keybit.net>
+2006-05-04 07:41 Sandro Santilli <strk at kbt.io>
* [r1542] ChangeLog, source/headers/geos/noding/SegmentNodeList.h:
const-correct size() method for SegmentNodeList
-2006-05-04 06:36 Sandro Santilli <strk at keybit.net>
+2006-05-04 06:36 Sandro Santilli <strk at kbt.io>
* [r1541] source/headers/geos/noding/ScaledNoder.h: Extended
definition to take new CoordinateSequence tracking into account
-2006-05-03 20:05 Sandro Santilli <strk at keybit.net>
+2006-05-03 20:05 Sandro Santilli <strk at kbt.io>
* [r1540] ChangeLog, source/noding/ScaledNoder.cpp: Added SQL
debugging output
-2006-05-03 19:47 Sandro Santilli <strk at keybit.net>
+2006-05-03 19:47 Sandro Santilli <strk at kbt.io>
* [r1539] ChangeLog, source/geom/CoordinateSequence.cpp,
source/headers/geos/geom/CoordinateSequence.h: added operator<<
for CoordinateSequence
-2006-05-03 18:04 Sandro Santilli <strk at keybit.net>
+2006-05-03 18:04 Sandro Santilli <strk at kbt.io>
* [r1538] ChangeLog, source/headers/geos/noding/SegmentString.h,
source/headers/geos/noding/SegmentString.inl: added
SegmentString::setCoordinates() interface
-2006-05-03 17:54 Sandro Santilli <strk at keybit.net>
+2006-05-03 17:54 Sandro Santilli <strk at kbt.io>
* [r1537] source/noding/snapround/SimpleSnapRounder.cpp:
Uncommented correctness checker
-2006-05-03 17:51 Sandro Santilli <strk at keybit.net>
+2006-05-03 17:51 Sandro Santilli <strk at kbt.io>
* [r1536] source/noding/snapround/HotPixel.cpp: system headers
included after package headers
-2006-05-03 17:50 Sandro Santilli <strk at keybit.net>
+2006-05-03 17:50 Sandro Santilli <strk at kbt.io>
* [r1535] ChangeLog,
source/headers/geos/noding/snapround/HotPixel.h: Doxygen comments
-2006-05-03 17:48 Sandro Santilli <strk at keybit.net>
+2006-05-03 17:48 Sandro Santilli <strk at kbt.io>
* [r1534] source/headers/geos/nodingSnapround.h: Forgot a slash
* [r1533] ChangeLog, source/headers/geos/nodingSnapround.h: Doxygen
brief
@@ -17148,7 +19144,7 @@
separate from the normal lib
Add missing files
-2006-05-03 16:19 Sandro Santilli <strk at keybit.net>
+2006-05-03 16:19 Sandro Santilli <strk at kbt.io>
* [r1530] source/headers/geos/noding/SegmentString.h: fit in 80
columns
@@ -17162,7 +19158,7 @@
* [r1528] ChangeLog: *** empty log message ***
-2006-05-03 15:49 Sandro Santilli <strk at keybit.net>
+2006-05-03 15:49 Sandro Santilli <strk at kbt.io>
* [r1527] ChangeLog, source/noding/snapround/SimpleSnapRounder.cpp:
fixed bug in SimpleSnapRounder::computeSnaps, trying to access
@@ -17173,12 +19169,12 @@
* [r1526] source/Makefile.vc: add additional files and change names
where necessary
-2006-05-03 15:40 Sandro Santilli <strk at keybit.net>
+2006-05-03 15:40 Sandro Santilli <strk at kbt.io>
* [r1525] source/noding/ScaledNoder.cpp: test SegmentString
invariant before and after scaling
-2006-05-03 15:37 Sandro Santilli <strk at keybit.net>
+2006-05-03 15:37 Sandro Santilli <strk at kbt.io>
* [r1524] ChangeLog: Tabs for indent
@@ -17191,69 +19187,69 @@
* [r1522] source/headers/geos/version.h.vc: Maintain a version.h.vc
until we come up with a better solution
-2006-05-03 15:28 Sandro Santilli <strk at keybit.net>
+2006-05-03 15:28 Sandro Santilli <strk at kbt.io>
* [r1521] ChangeLog, configure.in: updated JTS_PORT to 1.7.1
-2006-05-03 15:26 Sandro Santilli <strk at keybit.net>
+2006-05-03 15:26 Sandro Santilli <strk at kbt.io>
* [r1520] ChangeLog, source/headers/geos/noding/SegmentString.h,
source/headers/geos/noding/SegmentString.inl: testInvariant made
public and always inlined
-2006-05-03 15:19 Sandro Santilli <strk at keybit.net>
+2006-05-03 15:19 Sandro Santilli <strk at kbt.io>
* [r1519] ChangeLog,
source/headers/geos/noding/snapround/HotPixel.inl: Changed
sym_round() to java_math_round()
-2006-05-03 15:12 Sandro Santilli <strk at keybit.net>
+2006-05-03 15:12 Sandro Santilli <strk at kbt.io>
* [r1518] source/noding/ScaledNoder.cpp: Oops, uninitialized value
fix
-2006-05-03 15:06 Sandro Santilli <strk at keybit.net>
+2006-05-03 15:06 Sandro Santilli <strk at kbt.io>
* [r1517] ChangeLog: Updated
* [r1516] source/headers/geos/noding/IntersectionFinderAdder.h:
Better doxygen comment
-2006-05-03 15:05 Sandro Santilli <strk at keybit.net>
+2006-05-03 15:05 Sandro Santilli <strk at kbt.io>
* [r1515] source/operation/buffer/RightmostEdgeFinder.cpp:
Assertions checking
-2006-05-03 15:04 Sandro Santilli <strk at keybit.net>
+2006-05-03 15:04 Sandro Santilli <strk at kbt.io>
* [r1514] source/headers/geos/noding/ScaledNoder.h: removed
reduntant port info
-2006-05-03 15:02 Sandro Santilli <strk at keybit.net>
+2006-05-03 15:02 Sandro Santilli <strk at kbt.io>
* [r1513] source/headers/geos/noding/snapround/SimpleSnapRounder.h,
source/noding/snapround/SimpleSnapRounder.cpp: moved some
implementations from header to .cpp file (taken out of inline)
-2006-05-03 15:00 Sandro Santilli <strk at keybit.net>
+2006-05-03 15:00 Sandro Santilli <strk at kbt.io>
* [r1512] source/headers/geos/noding/ScaledNoder.h,
source/noding/ScaledNoder.cpp: Fixed scale() function to remove
repeated points *after* rounding. Added brief doxygen class
description.
-2006-05-03 10:26 Sandro Santilli <strk at keybit.net>
+2006-05-03 10:26 Sandro Santilli <strk at kbt.io>
* [r1511] ChangeLog, source/operation/buffer/BufferOp.cpp: Fixed
misuse of precision model in noder (bufferFixedPrecision)
-2006-05-03 09:46 Sandro Santilli <strk at keybit.net>
+2006-05-03 09:46 Sandro Santilli <strk at kbt.io>
* [r1510] ChangeLog: buffer headers reduction item
-2006-05-03 09:45 Sandro Santilli <strk at keybit.net>
+2006-05-03 09:45 Sandro Santilli <strk at kbt.io>
* [r1509] source/headers/geos/opBuffer.h,
source/headers/geos/operation/buffer/Makefile.am: Do not install
@@ -17262,7 +19258,7 @@
SubgraphDepthLocater.h,
-2006-05-03 09:14 Sandro Santilli <strk at keybit.net>
+2006-05-03 09:14 Sandro Santilli <strk at kbt.io>
* [r1508] ChangeLog, source/headers/geos/noding/ScaledNoder.h,
@@ -17273,7 +19269,7 @@
source/headers/geos/noding/ScaledNoder.h: ported JTS bugfix in
scale method.
-2006-05-03 08:58 Sandro Santilli <strk at keybit.net>
+2006-05-03 08:58 Sandro Santilli <strk at kbt.io>
* [r1507] ChangeLog, source/geom/CoordinateArraySequence.cpp,
source/headers/geos/geom/CoordinateArraySequence.h,
@@ -17281,19 +19277,19 @@
tests/unit/geom/CoordinateArraySequenceTest.cpp: added new
non-static CoordinateSequence::removeRepeatedPoints() mutator.
-2006-05-02 16:22 Sandro Santilli <strk at keybit.net>
+2006-05-02 16:22 Sandro Santilli <strk at kbt.io>
* [r1506] ChangeLog, source/noding/ScaledNoder.cpp: *
source/noding/ScaledNoder.cpp: use java_math_round instead of
sym_round.
-2006-05-02 14:51 Sandro Santilli <strk at keybit.net>
+2006-05-02 14:51 Sandro Santilli <strk at kbt.io>
* [r1505] source/algorithm/CGAlgorithms.cpp,
source/headers/geos/algorithm/CGAlgorithms.h: Added port info and
fixed doxygen comments for CGAlgorithms class
-2006-05-02 14:32 Sandro Santilli <strk at keybit.net>
+2006-05-02 14:32 Sandro Santilli <strk at kbt.io>
* [r1503] ChangeLog, source/headers/geos/opPolygonize.h,
source/headers/geos/operation/polygonize/EdgeRing.h,
@@ -17302,7 +19298,7 @@
polygonize/EdgeRing class, polygonize/EdgeRing.h header
not installed.
-2006-05-02 14:22 Sandro Santilli <strk at keybit.net>
+2006-05-02 14:22 Sandro Santilli <strk at kbt.io>
* [r1502] ChangeLog, source/operation/polygonize/EdgeRing.cpp,
source/operation/polygonize/Makefile.am,
@@ -17310,20 +19306,20 @@
source/operation/polygonize/: polygonizeEdgeRing.cpp renamed to
EdgeRing.cpp, to follow JTS naming.
-2006-05-02 14:01 Sandro Santilli <strk at keybit.net>
+2006-05-02 14:01 Sandro Santilli <strk at kbt.io>
* [r1500] ChangeLog, source/io/WKBReader.cpp: *
source/io/WKBReader.cpp: fixed reads of XDR WKB.
-2006-04-28 12:09 Sandro Santilli <strk at keybit.net>
+2006-04-28 12:09 Sandro Santilli <strk at kbt.io>
* [r1497] tests/xmltester/Makefile.am: Added 'verbose-test' rule
-2006-04-28 12:08 Sandro Santilli <strk at keybit.net>
+2006-04-28 12:08 Sandro Santilli <strk at kbt.io>
* [r1496] NEWS: Added note about Geometry constructors
-2006-04-28 11:56 Sandro Santilli <strk at keybit.net>
+2006-04-28 11:56 Sandro Santilli <strk at kbt.io>
* [r1495] ChangeLog, source/geom/GeometryFactory.cpp,
@@ -17334,7 +19330,7 @@
* source/geom/Polygon.cpp: fixed getBoundary method to always
return a geometry composed by LineStrings (not LinearRings)
-2006-04-28 11:12 Sandro Santilli <strk at keybit.net>
+2006-04-28 11:12 Sandro Santilli <strk at kbt.io>
* [r1494] ChangeLog,
source/headers/geos/operation/predicate/RectangleIntersects.h,
@@ -17342,7 +19338,7 @@
source/operation/predicate/RectangleIntersects.cpp: removed
warnings related to change in getNumPoints() return type.
-2006-04-28 10:55 Sandro Santilli <strk at keybit.net>
+2006-04-28 10:55 Sandro Santilli <strk at kbt.io>
* [r1493] ChangeLog, source/geom/GeometryCollection.cpp,
@@ -17361,51 +19357,51 @@
getNumPoints() changed to return
size_t.
-2006-04-28 10:51 Sandro Santilli <strk at keybit.net>
+2006-04-28 10:51 Sandro Santilli <strk at kbt.io>
* [r1492] ChangeLog, tests/unit/geom/LineStringTest.cpp,
tests/unit/geom/PointTest.cpp, tests/unit/geom/PolygonTest.cpp:
Unit tests: only construct Geoms using GeometryFactory.
-2006-04-27 15:15 Sandro Santilli <strk at keybit.net>
+2006-04-27 15:15 Sandro Santilli <strk at kbt.io>
* [r1491] ChangeLog, source/headers/geos/geomgraph/Node.h: Z check
removed from invariant tester to avoid aborts due to differences
in FP computations.
-2006-04-27 15:07 Sandro Santilli <strk at keybit.net>
+2006-04-27 15:07 Sandro Santilli <strk at kbt.io>
* [r1490] source/geomgraph/PlanarGraph.cpp: use output operators in
debugging lines
-2006-04-27 15:06 Sandro Santilli <strk at keybit.net>
+2006-04-27 15:06 Sandro Santilli <strk at kbt.io>
* [r1489] ChangeLog, source/geomgraph/NodeMap.cpp: (addNode):
always use the Node Coordinate as a key in the map to reduce
likeliness of a premature deletion.
-2006-04-27 15:03 Sandro Santilli <strk at keybit.net>
+2006-04-27 15:03 Sandro Santilli <strk at kbt.io>
* [r1488] source/geomgraph/Node.cpp: standard algorithm used in
addZ() for vector seek
-2006-04-26 16:35 Sandro Santilli <strk at keybit.net>
+2006-04-26 16:35 Sandro Santilli <strk at kbt.io>
* [r1485] ChangeLog, source/io/StringTokenizer.cpp,
source/io/WKTReader.cpp, tests/xmltester/testLeaksBig.xml: Had
WKTReader accept correct form for MultiPoint
-2006-04-26 10:39 Sandro Santilli <strk at keybit.net>
+2006-04-26 10:39 Sandro Santilli <strk at kbt.io>
* [r1482] ChangeLog: Added mloskot item (bug#100)
-2006-04-26 10:26 Sandro Santilli <strk at keybit.net>
+2006-04-26 10:26 Sandro Santilli <strk at kbt.io>
* [r1481] ChangeLog, tools/geos-config.in: tools/geos-config.in:
fixed library path to use layout detected by autoconf
-2006-04-24 15:47 Sandro Santilli <strk at keybit.net>
+2006-04-24 15:47 Sandro Santilli <strk at kbt.io>
* [r1480] source/simplify/TopologyPreservingSimplifier.cpp: Public
constructors change made permanent
@@ -17427,29 +19423,29 @@
* [r1477] source/simplify/TopologyPreservingSimplifier.cpp:
Temporar fix of Bug #100. This report requires deeper analysis!.
-2006-04-21 17:04 Sandro Santilli <strk at keybit.net>
+2006-04-21 17:04 Sandro Santilli <strk at kbt.io>
* [r1476] ChangeLog, source/geom/PrecisionModel.cpp: Fixed
constructor by type to always initialize scale factor
-2006-04-20 16:21 Sandro Santilli <strk at keybit.net>
+2006-04-20 16:21 Sandro Santilli <strk at kbt.io>
* [r1475] ChangeLog, source/headers/geos/geom/BinaryOp.h: Added
missing debugging output
-2006-04-20 14:27 Sandro Santilli <strk at keybit.net>
+2006-04-20 14:27 Sandro Santilli <strk at kbt.io>
* [r1474] ChangeLog, source/algorithm/HCoordinate.cpp,
source/headers/geos/algorithm/HCoordinate.h: HCoordinate class
changed to use long double types internally, in order to improve
computation precision
-2006-04-20 14:16 Sandro Santilli <strk at keybit.net>
+2006-04-20 14:16 Sandro Santilli <strk at kbt.io>
* [r1473] source/headers/geos/algorithm/LineIntersector.h: Added
some more doxygen comments
-2006-04-20 11:11 Sandro Santilli <strk at keybit.net>
+2006-04-20 11:11 Sandro Santilli <strk at kbt.io>
* [r1472] ChangeLog, source/algorithm/HCoordinate.cpp:
source/algorithm/HCoordinate.cpp: added compile time define to
@@ -17457,89 +19453,89 @@
order to make the -ffloat-store gcc switch effective). Disabled
by default.
-2006-04-19 09:21 Sandro Santilli <strk at keybit.net>
+2006-04-19 09:21 Sandro Santilli <strk at kbt.io>
* [r1471] TODO: Added snapround and simplify tests items
-2006-04-19 09:20 Sandro Santilli <strk at keybit.net>
+2006-04-19 09:20 Sandro Santilli <strk at kbt.io>
* [r1470] NEWS: updated
-2006-04-14 15:34 Sandro Santilli <strk at keybit.net>
+2006-04-14 15:34 Sandro Santilli <strk at kbt.io>
* [r1469] ChangeLog, capi/geos_c.cpp: Had CAPI use new BinaryOp
class in an aim to reduce robustness problems
-2006-04-14 15:25 Sandro Santilli <strk at keybit.net>
+2006-04-14 15:25 Sandro Santilli <strk at kbt.io>
* [r1468] TODO: updated, somehow
-2006-04-14 15:19 Sandro Santilli <strk at keybit.net>
+2006-04-14 15:19 Sandro Santilli <strk at kbt.io>
* [r1467] ChangeLog, source/operation/overlay/OverlayOp.cpp:
removed precision reduction code (use BinaryOp for that)
-2006-04-14 15:06 Sandro Santilli <strk at keybit.net>
+2006-04-14 15:06 Sandro Santilli <strk at kbt.io>
* [r1466] source/headers/geos/geom/Makefile.am: Added BinaryOp.h
header
-2006-04-14 15:04 Sandro Santilli <strk at keybit.net>
+2006-04-14 15:04 Sandro Santilli <strk at kbt.io>
* [r1465] source/headers/geos/operation/overlay/OverlayOp.h: fixed
missing namespace qualification in overlay::overlayOp
-2006-04-14 14:57 Sandro Santilli <strk at keybit.net>
+2006-04-14 14:57 Sandro Santilli <strk at kbt.io>
* [r1464] ChangeLog, tests/xmltester/XMLTester.cpp: XMLTester
binary ops invoked using the new BinaryOp template function.
-2006-04-14 14:38 Sandro Santilli <strk at keybit.net>
+2006-04-14 14:38 Sandro Santilli <strk at kbt.io>
* [r1463] ChangeLog, source/headers/geos/geom/BinaryOp.h: new
geos::Geom::BinaryOp template function implementing various
heuristics aimed at making binary geometry ops work around
robustness issues.
-2006-04-14 14:35 Sandro Santilli <strk at keybit.net>
+2006-04-14 14:35 Sandro Santilli <strk at kbt.io>
* [r1462] ChangeLog,
source/headers/geos/operation/overlay/OverlayOp.h: Added
overlayOp() adapter for use in templates expecting binary ops
-2006-04-14 09:02 Sandro Santilli <strk at keybit.net>
+2006-04-14 09:02 Sandro Santilli <strk at kbt.io>
* [r1461] ChangeLog, source/algorithm/HCoordinate.cpp,
source/headers/geos/algorithm/HCoordinate.h: Hadded output
operator and debugging prints for HCoordinate.
-2006-04-13 23:57 Sandro Santilli <strk at keybit.net>
+2006-04-13 23:57 Sandro Santilli <strk at kbt.io>
* [r1460] source/operation/overlay/OverlayOp.cpp: Disables reduced
precision overlayOp (is broken)
-2006-04-13 23:42 Sandro Santilli <strk at keybit.net>
+2006-04-13 23:42 Sandro Santilli <strk at kbt.io>
* [r1459] source/operation/overlay/OverlayOp.cpp: Plugged
CommonBitsOp attempts in overlay op, before brute force precision
reduction (this is likely going to change)
-2006-04-13 23:28 Sandro Santilli <strk at keybit.net>
+2006-04-13 23:28 Sandro Santilli <strk at kbt.io>
* [r1458] source/precision/CommonBitsOp.cpp: "always build before
commit" (forgot a closing paren)
-2006-04-13 23:23 Sandro Santilli <strk at keybit.net>
+2006-04-13 23:23 Sandro Santilli <strk at kbt.io>
* [r1457] ChangeLog, source/headers/geos/precision/CommonBitsOp.h,
source/precision/CommonBitsOp.cpp: fixed bug in binary ops
failing to consistently reduce operands.
-2006-04-13 21:53 Sandro Santilli <strk at keybit.net>
+2006-04-13 21:53 Sandro Santilli <strk at kbt.io>
* [r1456] capi/geostest.c: fixed bug introduced by previous commit
-2006-04-13 21:52 Sandro Santilli <strk at keybit.net>
+2006-04-13 21:52 Sandro Santilli <strk at kbt.io>
* [r1455] source/headers/geos/simplify/TaggedLineString.h,
source/headers/geos/simplify/TaggedLineStringSimplifier.h,
@@ -17548,24 +19544,24 @@
source/simplify/TopologyPreservingSimplifier.cpp: Many debugging
lines and assertions added. Fixed bug in TaggedLineString class.
-2006-04-13 17:09 Sandro Santilli <strk at keybit.net>
+2006-04-13 17:09 Sandro Santilli <strk at kbt.io>
* [r1454] ChangeLog, capi/geos_c.cpp: Use default GeometryFactory
instance (finishGEOS() is a no-op now)
-2006-04-13 16:48 Sandro Santilli <strk at keybit.net>
+2006-04-13 16:48 Sandro Santilli <strk at kbt.io>
* [r1453] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in,
capi/geostest.c: Added GEOSSimplify and
GEOSTopologyPreserveSimplify interfaces. Removed compiler
warnings in geostest
-2006-04-13 16:44 Sandro Santilli <strk at keybit.net>
+2006-04-13 16:44 Sandro Santilli <strk at kbt.io>
* [r1452] source/simplify/DouglasPeuckerSimplifier.cpp: Fixed a bug
in DPTransformer handling of MultiPolygons
-2006-04-13 16:04 Sandro Santilli <strk at keybit.net>
+2006-04-13 16:04 Sandro Santilli <strk at kbt.io>
* [r1451] source/headers/geos/simplify/TaggedLineString.h,
source/headers/geos/simplify/TopologyPreservingSimplifier.h,
@@ -17573,12 +19569,12 @@
source/simplify/TopologyPreservingSimplifier.cpp: Made
TopologyPreservingSimplifier implementation successfully build
-2006-04-13 14:51 Sandro Santilli <strk at keybit.net>
+2006-04-13 14:51 Sandro Santilli <strk at kbt.io>
* [r1450] ChangeLog, tests/unit/io/WKBReaderTest.cpp: Forced NDR
output (to not rely on architecture). Removed CRs endings.
-2006-04-13 14:25 Sandro Santilli <strk at keybit.net>
+2006-04-13 14:25 Sandro Santilli <strk at kbt.io>
* [r1449] ChangeLog, source/geom/GeometryComponentFilter.cpp,
source/headers/geos/geom/GeometryComponentFilter.h,
@@ -17590,7 +19586,7 @@
TopologyPreservingSimplifier initial port
-2006-04-13 10:39 Sandro Santilli <strk at keybit.net>
+2006-04-13 10:39 Sandro Santilli <strk at kbt.io>
* [r1448] ChangeLog,
source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h,
@@ -17619,12 +19615,12 @@
copy operations has
the effect of "turning off" copying for the class.
-2006-04-12 17:24 Sandro Santilli <strk at keybit.net>
+2006-04-12 17:24 Sandro Santilli <strk at kbt.io>
* [r1445] ChangeLog: Added note about reduction of installed
headers in simplify namespace
-2006-04-12 17:19 Sandro Santilli <strk at keybit.net>
+2006-04-12 17:19 Sandro Santilli <strk at kbt.io>
* [r1444] ChangeLog, source/headers/geos/geom/LineSegment.h,
source/headers/geos/simplify/Makefile.am,
@@ -17637,7 +19633,7 @@
TaggedLineStringSimplifier class, made LineSegment class
polymorphic to fix derivation of TaggedLineSegment
-2006-04-12 15:20 Sandro Santilli <strk at keybit.net>
+2006-04-12 15:20 Sandro Santilli <strk at kbt.io>
* [r1443] ChangeLog,
source/headers/geos/simplify/LineSegmentIndex.h,
@@ -17647,7 +19643,7 @@
source/simplify/Makefile.am,
source/simplify/TaggedLineString.cpp: LineSegmentIndex class
-2006-04-12 14:22 Sandro Santilli <strk at keybit.net>
+2006-04-12 14:22 Sandro Santilli <strk at kbt.io>
* [r1442] ChangeLog, source/headers/geos/simplify/Makefile.am,
source/headers/geos/simplify/TaggedLineSegment.h,
@@ -17657,35 +19653,35 @@
source/simplify/TaggedLineString.cpp: Initial implementation of
TaggedLineSegment and TaggedLineString classes
-2006-04-12 12:20 Sandro Santilli <strk at keybit.net>
+2006-04-12 12:20 Sandro Santilli <strk at kbt.io>
* [r1441] source/operation/overlay/OverlayOp.cpp: Added support for
use of CommonBitsOp in reduced precision attempts
(compile-time option)
-2006-04-12 11:57 Sandro Santilli <strk at keybit.net>
+2006-04-12 11:57 Sandro Santilli <strk at kbt.io>
* [r1440] source/algorithm/LineIntersector.cpp: Fixed debugging
line
-2006-04-12 11:39 Sandro Santilli <strk at keybit.net>
+2006-04-12 11:39 Sandro Santilli <strk at kbt.io>
* [r1439] source/headers/geos/geom/GeometryFactory.h: Removed
Geometry.h and CoordinateSequence.h includes.
The former created a circular dependency.
-2006-04-12 11:17 Sandro Santilli <strk at keybit.net>
+2006-04-12 11:17 Sandro Santilli <strk at kbt.io>
* [r1438] ChangeLog, source/io/WKBReader.cpp: Fixed exceptions
constructors (were using operator+ with strings and const char*)
-2006-04-12 10:57 Sandro Santilli <strk at keybit.net>
+2006-04-12 10:57 Sandro Santilli <strk at kbt.io>
* [r1437] ChangeLog, source/headers/geos/io/WKBReader.h,
source/io/WKBReader.cpp: Added WKBReader default ctor using
default GeometryFactory instance
-2006-04-11 16:04 Sandro Santilli <strk at keybit.net>
+2006-04-11 16:04 Sandro Santilli <strk at kbt.io>
* [r1436] ChangeLog, source/geom/util/GeometryTransformer.cpp,
source/headers/geos/simplify/DouglasPeuckerSimplifier.h,
@@ -17696,12 +19692,12 @@
tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp:
geos::simplify::DouglasPeukerSimplifier class + unit test
-2006-04-11 12:56 Sandro Santilli <strk at keybit.net>
+2006-04-11 12:56 Sandro Santilli <strk at kbt.io>
* [r1435] source/headers/geos/geom/util/GeometryTransformer.h: used
typedef for auto_ptr<CoordinateSequence>
-2006-04-11 12:21 Sandro Santilli <strk at keybit.net>
+2006-04-11 12:21 Sandro Santilli <strk at kbt.io>
* [r1434] ChangeLog, source/geom/util/GeometryTransformer.cpp,
source/geom/util/Makefile.am,
@@ -17709,12 +19705,12 @@
source/headers/geos/geom/util/Makefile.am: GeometryTransformer
class ported
-2006-04-11 11:55 Sandro Santilli <strk at keybit.net>
+2006-04-11 11:55 Sandro Santilli <strk at kbt.io>
* [r1433] source/headers/geos/geom/CoordinateSequence.h: Added
CoordinateSequence::AutoPtr typedef
-2006-04-11 11:16 Sandro Santilli <strk at keybit.net>
+2006-04-11 11:16 Sandro Santilli <strk at kbt.io>
* [r1432] ChangeLog, source/geom/GeometryFactory.cpp,
source/geom/LineString.cpp, source/geom/LinearRing.cpp,
@@ -17723,12 +19719,12 @@
source/headers/geos/geom/LinearRing.h: Added LineString and
LinearRing constructors by auto_ptr
-2006-04-11 09:53 Sandro Santilli <strk at keybit.net>
+2006-04-11 09:53 Sandro Santilli <strk at kbt.io>
* [r1431] source/headers/geos/geom/GeometryList.h: Added missing
duplicated include sentinel
-2006-04-11 09:41 Sandro Santilli <strk at keybit.net>
+2006-04-11 09:41 Sandro Santilli <strk at kbt.io>
* [r1430] source/geom/GeometryList.cpp, source/geom/Makefile.am,
source/headers/geos/geom/GeometryList.h,
@@ -17736,17 +19732,17 @@
GeometryList class, to be used to manage
lists of Geometry pointers.
-2006-04-11 09:31 Sandro Santilli <strk at keybit.net>
+2006-04-11 09:31 Sandro Santilli <strk at kbt.io>
* [r1429] source/headers/geos/geom/Geometry.h: Added
Geometry::AutoPtr typedef
-2006-04-11 09:29 Sandro Santilli <strk at keybit.net>
+2006-04-11 09:29 Sandro Santilli <strk at kbt.io>
* [r1428] source/geom/Geometry.cpp: Fixed initialization list
(removed compiler warning)
-2006-04-10 18:15 Sandro Santilli <strk at keybit.net>
+2006-04-10 18:15 Sandro Santilli <strk at kbt.io>
* [r1427] ChangeLog, source/geom/Geometry.cpp,
source/geom/GeometryCollection.cpp, source/geom/LineString.cpp,
@@ -17761,7 +19757,7 @@
Changed computeEnvelopeInternal() signater to return
auto_ptr<Envelope>
-2006-04-10 17:35 Sandro Santilli <strk at keybit.net>
+2006-04-10 17:35 Sandro Santilli <strk at kbt.io>
* [r1426] ChangeLog, source/geom/LineString.cpp,
source/geom/LinearRing.cpp, source/geom/Point.cpp,
@@ -17773,40 +19769,40 @@
Point::coordinates to be wrapped
in an auto_ptr<>. This should close bugs #86 and #89
-2006-04-10 15:11 Sandro Santilli <strk at keybit.net>
+2006-04-10 15:11 Sandro Santilli <strk at kbt.io>
* [r1425] ChangeLog: First manual edit (will likely update later
tonight... with changes grouped
by date)
-2006-04-10 15:05 Sandro Santilli <strk at keybit.net>
+2006-04-10 15:05 Sandro Santilli <strk at kbt.io>
* [r1424] tests/xmltester/TestInteriorPoint.xml: Re-synced with JTS
version (so this actually *was* a bug :)
* [r1423] source/geom/Geometry.cpp: Fixed a bug introduced by
previous commit in getCentroid()
-2006-04-10 14:18 Sandro Santilli <strk at keybit.net>
+2006-04-10 14:18 Sandro Santilli <strk at kbt.io>
* [r1422] source/geom/Geometry.cpp: Fixed getCentroid(Coordinate&)
to round using PrecisionModel
all unit tests succeed.
-2006-04-10 13:40 Sandro Santilli <strk at keybit.net>
+2006-04-10 13:40 Sandro Santilli <strk at kbt.io>
* [r1421] source/headers/geos/io/WKTReader.h,
source/headers/geos/io/WKTReader.inl: Added default ctor for
WKTReader (using GeometryFactory's default instance)
-2006-04-10 13:13 Sandro Santilli <strk at keybit.net>
+2006-04-10 13:13 Sandro Santilli <strk at kbt.io>
* [r1420] tools/geos-config.in: Removed INLINE flags from
geos-config --libs
-2006-04-10 13:09 Sandro Santilli <strk at keybit.net>
+2006-04-10 13:09 Sandro Santilli <strk at kbt.io>
* [r1419] source/geom/Geometry.cpp,
@@ -17815,7 +19811,7 @@
Made Geometry::INTERNAL_GEOMETRY_FACTORY an alias for it
removed last deletion from Unload::Release class
-2006-04-10 12:05 Sandro Santilli <strk at keybit.net>
+2006-04-10 12:05 Sandro Santilli <strk at kbt.io>
* [r1418] source/Makefile.am, source/geom/LineSegment.cpp,
source/headers/geos/geom/LineSegment.inl,
@@ -17831,7 +19827,7 @@
functions in .inl files are still available out-of-line.
A side effect is this should fix MingW build.
-2006-04-10 11:34 Sandro Santilli <strk at keybit.net>
+2006-04-10 11:34 Sandro Santilli <strk at kbt.io>
* [r1417] tests/unit/algorithm/PointLocatorTest.cpp: Uncommented
required Geometry.h include (for use in auto_ptr)
@@ -17894,29 +19890,29 @@
tests/tut/tut_restartable.h: Added copyright notice to TUT files.
Small cleaning.
-2006-04-08 13:05 Sandro Santilli <strk at keybit.net>
+2006-04-08 13:05 Sandro Santilli <strk at kbt.io>
* [r1405] source/geomgraph/EdgeEnd.cpp: Added assertion
-2006-04-08 13:00 Sandro Santilli <strk at keybit.net>
+2006-04-08 13:00 Sandro Santilli <strk at kbt.io>
* [r1404] source/geomgraph/NodeMap.cpp: assertion checking,
mergeLabel() call fix (bug#91)
-2006-04-07 16:52 Sandro Santilli <strk at keybit.net>
+2006-04-07 16:52 Sandro Santilli <strk at kbt.io>
* [r1403] source/geomgraph/PlanarGraph.cpp,
source/headers/geos/geomgraph/PlanarGraph.h: Port info, doxygen
comments, assertion checking
-2006-04-07 16:01 Sandro Santilli <strk at keybit.net>
+2006-04-07 16:01 Sandro Santilli <strk at kbt.io>
* [r1402] source/geomgraph/Node.cpp,
source/headers/geos/geomgraph/Node.h: Port info, doxygen
comments, testInvariant(), many assertionss, handling of
the NULL EdgeEndStar member
-2006-04-07 13:26 Sandro Santilli <strk at keybit.net>
+2006-04-07 13:26 Sandro Santilli <strk at kbt.io>
* [r1401] tests/xmltester/XMLTester.cpp,
tests/xmltester/XMLTester.h: Use of auto_ptr<> to prevent
@@ -17953,7 +19949,7 @@
tests/unit/geom/PointTest.cpp: Added test nr 29 to PointTest (JTS
conformance). Removed inform() calls from GeometryFactoryTest.
-2006-04-07 09:54 Sandro Santilli <strk at keybit.net>
+2006-04-07 09:54 Sandro Santilli <strk at kbt.io>
* [r1395] source/algorithm/CentroidArea.cpp,
source/algorithm/CentroidPoint.cpp,
@@ -17969,27 +19965,27 @@
Geometry::getNumGeometries() changed to return 'unsigned int'
rather then 'int'
-2006-04-07 09:12 Sandro Santilli <strk at keybit.net>
+2006-04-07 09:12 Sandro Santilli <strk at kbt.io>
* [r1394] source/algorithm/LineIntersector.cpp: kept
isInSegmentEnvelopes() check even when not debugging
-2006-04-07 08:31 Sandro Santilli <strk at keybit.net>
+2006-04-07 08:31 Sandro Santilli <strk at kbt.io>
* [r1393] source/precision/EnhancedPrecisionOp.cpp: Debugging lines
-2006-04-07 08:30 Sandro Santilli <strk at keybit.net>
+2006-04-07 08:30 Sandro Santilli <strk at kbt.io>
* [r1392] source/headers/geos/precision/CommonBitsRemover.h: made
addCommonBits/removeCommonBits interface consistent, doxygen
comments
-2006-04-07 08:28 Sandro Santilli <strk at keybit.net>
+2006-04-07 08:28 Sandro Santilli <strk at kbt.io>
* [r1391] source/precision/CommonBitsRemover.cpp: debugging lines,
assertions
-2006-04-07 08:27 Sandro Santilli <strk at keybit.net>
+2006-04-07 08:27 Sandro Santilli <strk at kbt.io>
* [r1390] source/precision/CommonBitsOp.cpp: debugging blocks
@@ -18050,7 +20046,7 @@
tests/unit/geom/TriangleTest.cpp, tests/unit/io,
tests/unit/io/WKBReaderTest.cpp: Adding new Unit Tests.
-2006-04-06 23:35 Sandro Santilli <strk at keybit.net>
+2006-04-06 23:35 Sandro Santilli <strk at kbt.io>
* [r1384] AUTHORS: Added Mateusz Loskot
@@ -18083,25 +20079,25 @@
* [r1378] tests/tut/tut.h, tests/tut/tut_reporter.h: Add inform()
target in tut.h and new callbacks in tut_reporter.h
-2006-04-06 21:31 Sandro Santilli <strk at keybit.net>
+2006-04-06 21:31 Sandro Santilli <strk at kbt.io>
* [r1377] source/algorithm/LineIntersector.cpp,
source/headers/geos/algorithm/LineIntersector.h: Const
correctness for debugging function
-2006-04-06 21:30 Sandro Santilli <strk at keybit.net>
+2006-04-06 21:30 Sandro Santilli <strk at kbt.io>
* [r1376] source/headers/geos/util/math.h: Added missing rint_vc()
forward declaration
-2006-04-06 17:33 Sandro Santilli <strk at keybit.net>
+2006-04-06 17:33 Sandro Santilli <strk at kbt.io>
* [r1375] tests/unit/Makefile.am, tests/unit/index,
tests/unit/index/quadtree,
tests/unit/index/quadtree/DoubleBitsTest.cpp: Added unit test for
DoubleBits
-2006-04-06 14:36 Sandro Santilli <strk at keybit.net>
+2006-04-06 14:36 Sandro Santilli <strk at kbt.io>
* [r1374] source/headers/geos/precision/CommonBitsOp.h,
source/headers/geos/precision/CommonBitsRemover.h,
@@ -18111,62 +20107,62 @@
source/precision/EnhancedPrecisionOp.cpp: Cleanup in
geos::precision namespace (leaks plugged, auto_ptr use, ...)
-2006-04-06 12:58 Sandro Santilli <strk at keybit.net>
+2006-04-06 12:58 Sandro Santilli <strk at kbt.io>
* [r1373] source/geomgraph/DirectedEdge.cpp: Added printing of
EdgeRing if available
-2006-04-06 12:48 Sandro Santilli <strk at keybit.net>
+2006-04-06 12:48 Sandro Santilli <strk at kbt.io>
* [r1372]
source/headers/geos/operation/valid/ConnectedInteriorTester.h:
Added private vector to keep track of allocated MaximalEdgeRings
objects
-2006-04-06 12:47 Sandro Santilli <strk at keybit.net>
+2006-04-06 12:47 Sandro Santilli <strk at kbt.io>
* [r1371] source/geomgraph/EdgeEnd.cpp: Fixed output function
-2006-04-06 12:45 Sandro Santilli <strk at keybit.net>
+2006-04-06 12:45 Sandro Santilli <strk at kbt.io>
* [r1370] source/operation/valid/ConnectedInteriorTester.cpp:
Delayed deletion of newly allocated MaximalEdgeRings.
Existing 'valid' operation tests don't should instability with
this patch.
-2006-04-06 12:36 Sandro Santilli <strk at keybit.net>
+2006-04-06 12:36 Sandro Santilli <strk at kbt.io>
* [r1369] source/geom/PrecisionModel.cpp: removed spurious lines
from previous commi
-2006-04-06 12:34 Sandro Santilli <strk at keybit.net>
+2006-04-06 12:34 Sandro Santilli <strk at kbt.io>
* [r1368] source/geom/PrecisionModel.cpp,
source/headers/geos/geom/PrecisionModel.h,
source/headers/geos/geom/PrecisionModel.inl: Port info, more
debugging lines, doxygen comments
-2006-04-06 12:33 Sandro Santilli <strk at keybit.net>
+2006-04-06 12:33 Sandro Santilli <strk at kbt.io>
* [r1367] source/geom/GeometryFactory.cpp: More debugging lines
-2006-04-06 12:29 Sandro Santilli <strk at keybit.net>
+2006-04-06 12:29 Sandro Santilli <strk at kbt.io>
* [r1366] source/io/WKBReader.cpp: Fixed bogus static
PrecisionModel variable in ::readCoordinate().
-2006-04-06 09:41 Sandro Santilli <strk at keybit.net>
+2006-04-06 09:41 Sandro Santilli <strk at kbt.io>
* [r1365] source/geomgraph/EdgeRing.cpp,
source/headers/geos/geomgraph/EdgeRing.h: Added operator<<, added
pts!=NULL assertion in testInvariant() function
-2006-04-06 09:39 Sandro Santilli <strk at keybit.net>
+2006-04-06 09:39 Sandro Santilli <strk at kbt.io>
* [r1364] source/geomgraph/EdgeEnd.cpp,
source/headers/geos/geomgraph/EdgeEnd.h: Added operator<<
-2006-04-06 09:01 Sandro Santilli <strk at keybit.net>
+2006-04-06 09:01 Sandro Santilli <strk at kbt.io>
* [r1363] source/geomgraph/Label.cpp,
source/geomgraph/TopologyLocation.cpp,
@@ -18174,29 +20170,29 @@
source/headers/geos/geomgraph/TopologyLocation.h: Doxygen
comments, port info, operator<<, assertion checking
-2006-04-06 07:52 Sandro Santilli <strk at keybit.net>
+2006-04-06 07:52 Sandro Santilli <strk at kbt.io>
* [r1362] source/geomgraph/DirectedEdge.cpp: Fixed bug in ::print()
function
-2006-04-05 18:28 Sandro Santilli <strk at keybit.net>
+2006-04-05 18:28 Sandro Santilli <strk at kbt.io>
* [r1361] source/headers/geos/geomgraph/Edge.h,
source/headers/geos/geomgraph/EdgeRing.h: Moved testInvariant()
methods from private to public, added
some comments about them.
-2006-04-05 15:59 Sandro Santilli <strk at keybit.net>
+2006-04-05 15:59 Sandro Santilli <strk at kbt.io>
* [r1360] source/operation/overlay/OverlayOp.cpp: Removed dead code
-2006-04-05 14:33 Sandro Santilli <strk at keybit.net>
+2006-04-05 14:33 Sandro Santilli <strk at kbt.io>
* [r1359] tests/xmltester/markup/MarkupSTL.cpp,
tests/xmltester/markup/MarkupSTL.h: Removed annoying warnings
from external source
-2006-04-05 14:04 Sandro Santilli <strk at keybit.net>
+2006-04-05 14:04 Sandro Santilli <strk at kbt.io>
* [r1358] source/geom/Envelope.cpp,
source/headers/geos/geom/Envelope.h,
@@ -18205,19 +20201,19 @@
Drop init(Envelope&) method.
Port info and various cleanups.
-2006-04-05 10:25 Sandro Santilli <strk at keybit.net>
+2006-04-05 10:25 Sandro Santilli <strk at kbt.io>
* [r1357] source/geom/LineString.cpp,
source/headers/geos/geom/LineString.h: Fixed LineString
constructor to ensure deletion of CoordinateSequence
argument on exception throw
-2006-04-05 09:34 Sandro Santilli <strk at keybit.net>
+2006-04-05 09:34 Sandro Santilli <strk at kbt.io>
* [r1356] source/headers/geos/util/GEOSException.h: GEOSException
derived from std::exception again, hopefully the correct way now
-2006-04-05 09:20 Sandro Santilli <strk at keybit.net>
+2006-04-05 09:20 Sandro Santilli <strk at kbt.io>
* [r1355]
source/headers/geos/operation/buffer/RightmostEdgeFinder.h,
@@ -18226,42 +20222,42 @@
Fixed bug in getRightmostSide() method ( a "testing-only" corner
case )
-2006-04-04 16:07 Sandro Santilli <strk at keybit.net>
+2006-04-04 16:07 Sandro Santilli <strk at kbt.io>
* [r1353] source/geomgraph/DirectedEdgeStar.cpp: More assertion
checking, less overhead when built with NDEBUG defined
-2006-04-04 13:35 Sandro Santilli <strk at keybit.net>
+2006-04-04 13:35 Sandro Santilli <strk at kbt.io>
* [r1352] source/geomgraph/EdgeEndStar.cpp,
source/headers/geos/geomgraph/EdgeEndStar.h: Port info, assertion
checking, indentation
-2006-04-04 12:39 Sandro Santilli <strk at keybit.net>
+2006-04-04 12:39 Sandro Santilli <strk at kbt.io>
* [r1351] source/algorithm/LineIntersector.cpp: Changed
NotRepresentableCoordinate exception handler to throw
a TopologyException. This allows further handling.
-2006-04-04 11:37 Sandro Santilli <strk at keybit.net>
+2006-04-04 11:37 Sandro Santilli <strk at kbt.io>
* [r1350] source/algorithm/HCoordinate.cpp,
source/headers/geos/algorithm/HCoordinate.h: Port information +
initialization lists in ctors
-2006-04-04 11:28 Sandro Santilli <strk at keybit.net>
+2006-04-04 11:28 Sandro Santilli <strk at kbt.io>
* [r1349] source/algorithm/HCoordinate.cpp: NotRepresentable
condition detected using finite() from <cmath>
rather then using FINITE() macro. Made ::intersection() body
more readable.
-2006-04-04 09:53 Sandro Santilli <strk at keybit.net>
+2006-04-04 09:53 Sandro Santilli <strk at kbt.io>
* [r1348] source/headers/geos/geom/CoordinateSequence.h: Fixed
applyCoordinateFilter() templated function body
-2006-04-04 08:16 Sandro Santilli <strk at keybit.net>
+2006-04-04 08:16 Sandro Santilli <strk at kbt.io>
* [r1345] NEWS, doc/example.cpp,
source/algorithm/NotRepresentableException.cpp,
@@ -18293,14 +20289,14 @@
* [r1342] source/Makefile.vc: remove objects that no longer exist
default to MSVC_VER=1310
-2006-04-03 17:05 Sandro Santilli <strk at keybit.net>
+2006-04-03 17:05 Sandro Santilli <strk at kbt.io>
* [r1341] source/geomgraph/DirectedEdge.cpp,
source/geomgraph/EdgeEnd.cpp, source/geomgraph/Label.cpp,
source/headers/geos/geomgraph/EdgeEnd.h: Assertion checking, port
info, cleanups
-2006-04-03 15:54 Sandro Santilli <strk at keybit.net>
+2006-04-03 15:54 Sandro Santilli <strk at kbt.io>
* [r1340] source/headers/geos/operation/GeometryGraphOperation.h,
source/operation/GeometryGraphOperation.cpp: - getArgGeometry()
@@ -18309,12 +20305,12 @@
- minor assertions checking
- minor cleanups
-2006-04-03 14:07 Sandro Santilli <strk at keybit.net>
+2006-04-03 14:07 Sandro Santilli <strk at kbt.io>
* [r1339] source/headers/geos/geom/PrecisionModel.h: Commented out
obsoleted toInternal() method
-2006-04-03 13:58 Sandro Santilli <strk at keybit.net>
+2006-04-03 13:58 Sandro Santilli <strk at kbt.io>
* [r1337] macros/ac_pkg_swig.m4, macros/ac_python_devel.m4,
swig/geos.i, swig/python/Makefile.am, swig/python/python.i,
@@ -18325,14 +20321,14 @@
- Adds the -modern flag for SWIG when compiling a Python
extension
-2006-04-03 13:56 Sandro Santilli <strk at keybit.net>
+2006-04-03 13:56 Sandro Santilli <strk at kbt.io>
* [r1336]
source/headers/geos/precision/SimpleGeometryPrecisionReducer.h,
source/precision/SimpleGeometryPrecisionReducer.cpp: Made
externally-owned PrecisionModel const
-2006-04-03 10:56 Sandro Santilli <strk at keybit.net>
+2006-04-03 10:56 Sandro Santilli <strk at kbt.io>
* [r1334] source/geom/CoordinateSequenceFactory.cpp,
@@ -18346,13 +20342,13 @@
source/util/UnsupportedOperationException.cpp: Removed
implementation files build spec for fully-inlined classes
-2006-04-03 10:44 Sandro Santilli <strk at keybit.net>
+2006-04-03 10:44 Sandro Santilli <strk at kbt.io>
* [r1333] source/index/strtree/STRtree.cpp,
source/noding/snapround/MCIndexSnapRounder.cpp: Added missing
headers
-2006-04-03 10:16 Sandro Santilli <strk at keybit.net>
+2006-04-03 10:16 Sandro Santilli <strk at kbt.io>
* [r1332] configure.in, source/Makefile.am,
source/headers/geos/Makefile.am, source/headers/geos/simplify,
@@ -18364,25 +20360,25 @@
source/simplify/Makefile.am: DouglasPeuckerLineSimplifier class
port
-2006-04-03 08:43 Sandro Santilli <strk at keybit.net>
+2006-04-03 08:43 Sandro Santilli <strk at kbt.io>
* [r1331] source/headers/geos/index/strtree/STRtree.h,
source/index/strtree/STRtree.cpp: Added port info, minor cleanups
-2006-04-03 08:29 Sandro Santilli <strk at keybit.net>
+2006-04-03 08:29 Sandro Santilli <strk at kbt.io>
* [r1330] source/headers/geos/index/quadtree/Quadtree.h,
source/index/quadtree/Quadtree.cpp: Added port info, cleaned up
log message, minor assertion checking.
-2006-03-31 17:51 Sandro Santilli <strk at keybit.net>
+2006-03-31 17:51 Sandro Santilli <strk at kbt.io>
* [r1329] source/geom/GeometryFactory.cpp,
source/headers/geos/geom/GeometryFactory.h: A few assertion
checking, comments cleanup, use of initialization lists
in constructors, handled NULL parameters.
-2006-03-31 16:55 Sandro Santilli <strk at keybit.net>
+2006-03-31 16:55 Sandro Santilli <strk at kbt.io>
* [r1328] NEWS, source/geom/LineString.cpp,
source/headers/geos/geom/LineString.h: Added many assertions
@@ -18390,27 +20386,27 @@
Changed ::getCoordinate() to return NULL on empty geom.
Changed ::get{Start,End}Point() to return NULL on empty geom.
-2006-03-31 16:53 Sandro Santilli <strk at keybit.net>
+2006-03-31 16:53 Sandro Santilli <strk at kbt.io>
* [r1327] source/headers/geos/geom/Geometry.h: Added comment about
possible NULL return from getCoordinate()
-2006-03-31 11:03 Sandro Santilli <strk at keybit.net>
+2006-03-31 11:03 Sandro Santilli <strk at kbt.io>
* [r1325] source/geom/Geometry.cpp: Fixed NULL-GeometryFactory
constructor to use INTERNAL_GEOMETRY_FACTORY
(should fix bug #81)
-2006-03-30 09:26 Sandro Santilli <strk at keybit.net>
+2006-03-30 09:26 Sandro Santilli <strk at kbt.io>
* [r1324] source/headers/geos/io/WKTReader.h: minor cleanup
-2006-03-29 15:48 Sandro Santilli <strk at keybit.net>
+2006-03-29 15:48 Sandro Santilli <strk at kbt.io>
* [r1323] capi/geos_c.cpp: Added missing 'const' in catch
std::exception statements
-2006-03-29 15:23 Sandro Santilli <strk at keybit.net>
+2006-03-29 15:23 Sandro Santilli <strk at kbt.io>
* [r1322] source/geomgraph/DirectedEdge.cpp,
@@ -18419,18 +20415,18 @@
source/headers/geos/geomgraph/Makefile.am: Moved GeometryGraph
inlines from .h to .inl file
-2006-03-29 14:34 Sandro Santilli <strk at keybit.net>
+2006-03-29 14:34 Sandro Santilli <strk at kbt.io>
* [r1321] tests/xmltester/TestValid.xml: Sync'ed testfile with JTS
head
-2006-03-29 14:31 Sandro Santilli <strk at keybit.net>
+2006-03-29 14:31 Sandro Santilli <strk at kbt.io>
* [r1320] tests/unit/Makefile.am, tests/unit/algorithm,
tests/unit/algorithm/PointLocator.cpp,
tests/unit/io/WKBReader.cpp: Added PointLocator unit test
-2006-03-29 13:53 Sandro Santilli <strk at keybit.net>
+2006-03-29 13:53 Sandro Santilli <strk at kbt.io>
* [r1319] source/geomgraph/EdgeRing.cpp,
source/headers/geos/geomgraph/EdgeRing.h,
@@ -18440,13 +20436,13 @@
Invariant testing function and lots of exceptional assertions.
Removed useless heap allocations, and pointers usages.
-2006-03-29 11:52 Sandro Santilli <strk at keybit.net>
+2006-03-29 11:52 Sandro Santilli <strk at kbt.io>
* [r1318] source/algorithm/MCPointInRing.cpp,
source/headers/geos/algorithm/MCPointInRing.h: const correctness,
useless heap allocations removal
-2006-03-29 11:48 Sandro Santilli <strk at keybit.net>
+2006-03-29 11:48 Sandro Santilli <strk at kbt.io>
* [r1317]
source/headers/geos/operation/valid/QuadtreeNestedRingTester.h,
@@ -18454,47 +20450,47 @@
useless heap allocations in construction, enforced const
correctness
-2006-03-28 16:49 Sandro Santilli <strk at keybit.net>
+2006-03-28 16:49 Sandro Santilli <strk at kbt.io>
* [r1316] source/io/WKBReader.cpp: Reintroduced rewind of input
parameter in printHEX() [dropped by prev commit]
-2006-03-28 16:33 Sandro Santilli <strk at keybit.net>
+2006-03-28 16:33 Sandro Santilli <strk at kbt.io>
* [r1315] source/headers/geos/geom/GeometryFactory.h: Added note
about args responsibility in GeometryFactory constructor
-2006-03-28 16:11 Sandro Santilli <strk at keybit.net>
+2006-03-28 16:11 Sandro Santilli <strk at kbt.io>
* [r1314] tests/unit/io/WKBReader.cpp: swapped assert_equals() args
to get obtained/expected the right way.
-2006-03-28 15:27 Sandro Santilli <strk at keybit.net>
+2006-03-28 15:27 Sandro Santilli <strk at kbt.io>
* [r1313] source/io/WKBReader.cpp: Simplified printHEX()
implementation
-2006-03-28 15:19 Sandro Santilli <strk at keybit.net>
+2006-03-28 15:19 Sandro Santilli <strk at kbt.io>
* [r1312] doc/example.cpp: Added macros for sections skip (useful
in debugging)
-2006-03-28 14:45 Sandro Santilli <strk at keybit.net>
+2006-03-28 14:45 Sandro Santilli <strk at kbt.io>
* [r1311] tests/unit/Makefile.am, tests/unit/io,
tests/unit/io/WKBReader.cpp: Added simple test for WKB reader.
-2006-03-28 14:02 Sandro Santilli <strk at keybit.net>
+2006-03-28 14:02 Sandro Santilli <strk at kbt.io>
* [r1310] source/io/WKBReader.cpp: added missing header for
non-inlined builds
-2006-03-28 14:01 Sandro Santilli <strk at keybit.net>
+2006-03-28 14:01 Sandro Santilli <strk at kbt.io>
* [r1309] source/io/ByteOrderDataInStream.cpp: forgot to add in
previous commit
-2006-03-28 11:26 Sandro Santilli <strk at keybit.net>
+2006-03-28 11:26 Sandro Santilli <strk at kbt.io>
* [r1308] source/headers/geos/io/ByteOrderDataInStream.h,
source/headers/geos/io/ByteOrderDataInStream.inl,
@@ -18503,32 +20499,32 @@
ByteOrderDataInStream inlines moved to .inl file, updated
implementation files includes.
-2006-03-28 11:25 Sandro Santilli <strk at keybit.net>
+2006-03-28 11:25 Sandro Santilli <strk at kbt.io>
* [r1307] source/io/WKBWriter.cpp: Assertion checking
-2006-03-28 09:14 Sandro Santilli <strk at keybit.net>
+2006-03-28 09:14 Sandro Santilli <strk at kbt.io>
* [r1306] source/headers/geos/geom/LineSegment.h,
source/headers/geos/geom/LineSegment.inl: Headers inclusion fix.
-2006-03-28 08:57 Sandro Santilli <strk at keybit.net>
+2006-03-28 08:57 Sandro Santilli <strk at kbt.io>
* [r1305] source/headers/geos/geom/PrecisionModel.h,
source/headers/geos/geom/PrecisionModel.inl: Comments cleanup,
system headers included after project headers
-2006-03-28 08:40 Sandro Santilli <strk at keybit.net>
+2006-03-28 08:40 Sandro Santilli <strk at kbt.io>
* [r1304] configure.in: C-API lib version bumped to 1.1.1 (release
2.2.2 will ship 1.1.0)
-2006-03-27 17:59 Sandro Santilli <strk at keybit.net>
+2006-03-27 17:59 Sandro Santilli <strk at kbt.io>
* [r1302] source/operation/buffer/OffsetCurveBuilder.cpp: Fixed
small leak.
-2006-03-27 17:04 Sandro Santilli <strk at keybit.net>
+2006-03-27 17:04 Sandro Santilli <strk at kbt.io>
* [r1301]
source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
@@ -18536,7 +20532,7 @@
source/operation/buffer/OffsetCurveSetBuilder.cpp: Cleanups and
explicit initializations
-2006-03-27 16:02 Sandro Santilli <strk at keybit.net>
+2006-03-27 16:02 Sandro Santilli <strk at kbt.io>
* [r1300] source/geomgraph/EdgeRing.cpp,
@@ -18550,18 +20546,18 @@
file for MinimalEdgeRing, added many debugging blocks,
fixed memory leak in ConnectedInteriorTester (bug #59)
-2006-03-27 15:57 Sandro Santilli <strk at keybit.net>
+2006-03-27 15:57 Sandro Santilli <strk at kbt.io>
* [r1299] source/headers/geos/geom/Coordinate.h,
source/headers/geos/geom/Coordinate.inl: Commented need for
platform.h include
-2006-03-27 15:56 Sandro Santilli <strk at keybit.net>
+2006-03-27 15:56 Sandro Santilli <strk at kbt.io>
* [r1298] source/geom/Coordinate.cpp: Added missing platform.h
include (for ISNAN macro)
-2006-03-27 14:20 Sandro Santilli <strk at keybit.net>
+2006-03-27 14:20 Sandro Santilli <strk at kbt.io>
* [r1297]
source/headers/geos/operation/valid/ConnectedInteriorTester.h,
@@ -18569,7 +20565,7 @@
paranoid assertion checking and a note in header about
responsibility of return from buildMaximalEdgeRings()
-2006-03-27 10:37 Sandro Santilli <strk at keybit.net>
+2006-03-27 10:37 Sandro Santilli <strk at kbt.io>
* [r1296]
source/headers/geos/operation/valid/ConsistentAreaTester.h,
@@ -18577,55 +20573,55 @@
allocations and probability of error by making LineIntersector
and RelateNodeGraph part of ConsistentAreaTester class .
-2006-03-27 10:36 Sandro Santilli <strk at keybit.net>
+2006-03-27 10:36 Sandro Santilli <strk at kbt.io>
* [r1295] source/operation/valid/TopologyValidationError.cpp: added
missing space in exception message
-2006-03-27 10:34 Sandro Santilli <strk at keybit.net>
+2006-03-27 10:34 Sandro Santilli <strk at kbt.io>
* [r1294] source/headers/geos/geom/Coordinate.inl: moved external
includes after internal ones
-2006-03-27 09:50 Sandro Santilli <strk at keybit.net>
+2006-03-27 09:50 Sandro Santilli <strk at kbt.io>
* [r1293] tests/xmltester/Makefile.am,
tests/xmltester/TestValid2-big.xml: Added final isValid test from
JTS (floating version)
-2006-03-27 09:48 Sandro Santilli <strk at keybit.net>
+2006-03-27 09:48 Sandro Santilli <strk at kbt.io>
* [r1292] tests/xmltester/Makefile.am,
tests/xmltester/TestValid2.xml, tests/xmltester/testLeaksBig.xml:
Extracted TestValid2.xml from testLeaksBig.xml (target file is
taken from JTS source tree)
-2006-03-27 09:45 Sandro Santilli <strk at keybit.net>
+2006-03-27 09:45 Sandro Santilli <strk at kbt.io>
* [r1291] tests/xmltester/Makefile.am,
tests/xmltester/TestValid.xml, tests/xmltester/testLeaksBig.xml:
Added TestValid.xml test, taken from JTS source tree, already
present in testLeaksBig (from which tests were removed)
-2006-03-27 09:28 Sandro Santilli <strk at keybit.net>
+2006-03-27 09:28 Sandro Santilli <strk at kbt.io>
* [r1290] NEWS: added namespaces use and headers split
-2006-03-27 09:05 Sandro Santilli <strk at keybit.net>
+2006-03-27 09:05 Sandro Santilli <strk at kbt.io>
* [r1289] capi/geos_c.h.in: Added note about responsibility of
return from GEOSGeomType()
-2006-03-27 09:00 Sandro Santilli <strk at keybit.net>
+2006-03-27 09:00 Sandro Santilli <strk at kbt.io>
* [r1288] source/geom/CoordinateArraySequence.cpp: Bug #79 - Small
fix in CoordinateArraySequence::toString()
-2006-03-24 11:42 Sandro Santilli <strk at keybit.net>
+2006-03-24 11:42 Sandro Santilli <strk at kbt.io>
* [r1287] configure.in: reverted default of assertion checking
-2006-03-24 11:11 Sandro Santilli <strk at keybit.net>
+2006-03-24 11:11 Sandro Santilli <strk at kbt.io>
* [r1286] TODO, configure.in, tools/geos-config.in: Inlining
enabled by default, assertion checking disabled by default.
@@ -18633,17 +20629,17 @@
Had geos-config --cflags output appropriate inline flag if
required (-DGEOS_INLINE)
-2006-03-24 11:04 Sandro Santilli <strk at keybit.net>
+2006-03-24 11:04 Sandro Santilli <strk at kbt.io>
* [r1285] source/operation/linemerge/LineSequencer.cpp: Changed
assert() with Assert::isTrue in addReverseSubpath
-2006-03-24 10:44 Sandro Santilli <strk at keybit.net>
+2006-03-24 10:44 Sandro Santilli <strk at kbt.io>
* [r1284] source/operation/linemerge/LineSequencer.cpp: Fixed to
build with -DNDEBUG
-2006-03-24 09:52 Sandro Santilli <strk at keybit.net>
+2006-03-24 09:52 Sandro Santilli <strk at kbt.io>
* [r1283] TODO, capi/geos_c.cpp.bak,
source/algorithm/ConvexHull.cpp, source/geom/Coordinate.cpp,
@@ -18731,22 +20727,22 @@
source/operation/distance/DistanceOp.cpp: USE_INLINE =>
GEOS_INLINE
-2006-03-24 09:26 Sandro Santilli <strk at keybit.net>
+2006-03-24 09:26 Sandro Santilli <strk at kbt.io>
* [r1282] capi/geos_c.cpp: Bug #77 - Missing platform.h
-2006-03-24 09:25 Sandro Santilli <strk at keybit.net>
+2006-03-24 09:25 Sandro Santilli <strk at kbt.io>
* [r1281] source/noding/snapround/MCIndexPointSnapper.cpp,
source/operation/buffer/BufferBuilder.cpp: Bugs #77 and #76:
missing <algorithm>
-2006-03-24 09:23 Sandro Santilli <strk at keybit.net>
+2006-03-24 09:23 Sandro Santilli <strk at kbt.io>
* [r1280] tests/unit/geos_unit.cpp: Bug #78 - Small fixes and
cleaning
-2006-03-23 15:10 Sandro Santilli <strk at keybit.net>
+2006-03-23 15:10 Sandro Santilli <strk at kbt.io>
* [r1278] source/geom/Coordinate.cpp,
@@ -18759,7 +20755,7 @@
source/operation/overlay/OverlayOp.cpp: Dropped by-pointer
TopologyException constructor, various small cleanups
-2006-03-23 13:31 Sandro Santilli <strk at keybit.net>
+2006-03-23 13:31 Sandro Santilli <strk at kbt.io>
* [r1277] source/geomgraph/Edge.cpp,
source/geomgraph/EdgeIntersectionList.cpp,
@@ -18770,7 +20766,7 @@
source/index/quadtree/Quadtree.cpp: Fixed to allow build with
GEOS_DEBUG
-2006-03-23 12:12 Sandro Santilli <strk at keybit.net>
+2006-03-23 12:12 Sandro Santilli <strk at kbt.io>
* [r1276] source/geom/Geometry.cpp,
source/geom/MultiLineString.cpp, source/geom/MultiPolygon.cpp,
@@ -18785,24 +20781,24 @@
source/operation/distance/DistanceOp.cpp: Fixes to allow build
with -DUSE_INLINE
-2006-03-23 10:55 Sandro Santilli <strk at keybit.net>
+2006-03-23 10:55 Sandro Santilli <strk at kbt.io>
* [r1275] Makefile.am, configure.in: Temporarly excluded 'swig'
extension from distribution, to allow for
successufull 'dist' rule and distributed testing.
-2006-03-23 10:41 Sandro Santilli <strk at keybit.net>
+2006-03-23 10:41 Sandro Santilli <strk at kbt.io>
* [r1274] source/headers/geos/Makefile.am,
source/headers/geos/operation/relate/Makefile.am: Fixed automake
files
-2006-03-23 10:09 Sandro Santilli <strk at keybit.net>
+2006-03-23 10:09 Sandro Santilli <strk at kbt.io>
* [r1273] source/headers/geos/operation/predicate/Makefile.am:
Fixed missing backslash
-2006-03-23 09:17 Sandro Santilli <strk at keybit.net>
+2006-03-23 09:17 Sandro Santilli <strk at kbt.io>
* [r1272] configure.in, source/headers/geos/Makefile.am,
source/headers/geos/precision, source/headers/geos/precision.h,
@@ -18822,7 +20818,7 @@
source/precision/SimpleGeometryPrecisionReducer.cpp: precision.h
header split, minor optimizations
-2006-03-22 18:12 Sandro Santilli <strk at keybit.net>
+2006-03-22 18:12 Sandro Santilli <strk at kbt.io>
* [r1271] configure.in, source/algorithm/MCPointInRing.cpp,
@@ -18851,11 +20847,11 @@
source/operation/buffer/BufferBuilder.cpp,
source/operation/valid/IsValidOp.cpp: indexChain.h header split.
-2006-03-22 16:59 Sandro Santilli <strk at keybit.net>
+2006-03-22 16:59 Sandro Santilli <strk at kbt.io>
* [r1270] source/headers/geos/geosAlgorithm.h: cleaned up
-2006-03-22 16:58 Sandro Santilli <strk at keybit.net>
+2006-03-22 16:58 Sandro Santilli <strk at kbt.io>
* [r1269] source/geom/CoordinateArraySequence.cpp,
source/geom/CoordinateList.cpp,
@@ -18883,7 +20879,7 @@
CoordinateSequence
implementation, optimized out some memory allocations.
-2006-03-22 16:01 Sandro Santilli <strk at keybit.net>
+2006-03-22 16:01 Sandro Santilli <strk at kbt.io>
* [r1268] configure.in, source/algorithm/MCPointInRing.cpp,
source/headers/geos/algorithm/MCPointInRing.h,
@@ -18906,7 +20902,7 @@
tests/xmltester/XMLTester.cpp: indexBintree.h header split,
classes renamed to match JTS
-2006-03-22 14:28 Sandro Santilli <strk at keybit.net>
+2006-03-22 14:28 Sandro Santilli <strk at kbt.io>
* [r1267] source/index/quadtree/Key.cpp,
source/index/quadtree/Makefile.am,
@@ -18919,7 +20915,7 @@
source/index/quadtree/Root.cpp: Filenames renamed to match class
names (matching JTS)
-2006-03-22 12:22 Sandro Santilli <strk at keybit.net>
+2006-03-22 12:22 Sandro Santilli <strk at kbt.io>
* [r1266] configure.in, source/geomgraph/EdgeList.cpp,
source/headers/geos/index/Makefile.am,
@@ -18945,7 +20941,7 @@
source/operation/valid/QuadtreeNestedRingTester.cpp:
indexQuadtree.h split
-2006-03-22 11:19 Sandro Santilli <strk at keybit.net>
+2006-03-22 11:19 Sandro Santilli <strk at kbt.io>
* [r1265] capi/geos_c.cpp, configure.in,
@@ -18966,14 +20962,14 @@
source/operation/polygonize/polygonizeEdgeRing.cpp:
opPolygonize.h headers split.
-2006-03-22 11:18 Sandro Santilli <strk at keybit.net>
+2006-03-22 11:18 Sandro Santilli <strk at kbt.io>
* [r1264] source/operation/buffer/BufferSubgraph.cpp,
source/operation/buffer/OffsetCurveSetBuilder.cpp: Changed back
'unable to find edge to compute depths' from assertion to
TopologyException
-2006-03-22 10:13 Sandro Santilli <strk at keybit.net>
+2006-03-22 10:13 Sandro Santilli <strk at kbt.io>
* [r1263] capi/geos_c.cpp, configure.in,
source/headers/geos/opLinemerge.h,
@@ -18993,7 +20989,7 @@
source/operation/linemerge/LineMerger.cpp,
source/operation/linemerge/LineSequencer.cpp: opLinemerge.h split
-2006-03-21 21:42 Sandro Santilli <strk at keybit.net>
+2006-03-21 21:42 Sandro Santilli <strk at kbt.io>
* [r1262] configure.in, source/headers/geos/Makefile.am,
source/headers/geos/planargraph,
@@ -19038,7 +21034,7 @@
source/planargraph/planarSubgraph.cpp: planargraph.h header
split, planargraph:: classes renamed to match JTS symbols
-2006-03-21 17:55 Sandro Santilli <strk at keybit.net>
+2006-03-21 17:55 Sandro Santilli <strk at kbt.io>
* [r1261] configure.in, source/geom/Geometry.cpp,
source/headers/geos/opDistance.h,
@@ -19058,7 +21054,7 @@
source/operation/distance/GeometryLocation.cpp: opDistance.h
header split
-2006-03-21 17:11 Sandro Santilli <strk at keybit.net>
+2006-03-21 17:11 Sandro Santilli <strk at kbt.io>
* [r1260] configure.in, source/geom/Geometry.cpp,
source/headers/geos/opPredicate.h,
@@ -19074,7 +21070,7 @@
source/operation/predicate/SegmentIntersectionTester.cpp:
opPredicate.h header split
-2006-03-21 13:11 Sandro Santilli <strk at keybit.net>
+2006-03-21 13:11 Sandro Santilli <strk at kbt.io>
* [r1259] configure.in, source/geom/Geometry.cpp,
source/headers/geos/opRelate.h,
@@ -19101,7 +21097,7 @@
source/operation/valid/ConsistentAreaTester.cpp: opRelate.h
header split
-2006-03-21 11:20 Sandro Santilli <strk at keybit.net>
+2006-03-21 11:20 Sandro Santilli <strk at kbt.io>
* [r1258] tests/xmltester/TestInteriorPoint.xml: Changed expected
result to the obtained one :)
@@ -19109,7 +21105,7 @@
which an InteriorPoint is requested, both vertexes
are correct answer (equidistant from centroid).
-2006-03-21 11:12 Sandro Santilli <strk at keybit.net>
+2006-03-21 11:12 Sandro Santilli <strk at kbt.io>
* [r1257] source/algorithm/CGAlgorithms.cpp,
@@ -19134,7 +21130,7 @@
source/headers/geos/algorithm/SIRtreePointInRing.h: Cleanups:
headers inclusion and Log section
-2006-03-21 10:47 Sandro Santilli <strk at keybit.net>
+2006-03-21 10:47 Sandro Santilli <strk at kbt.io>
* [r1256] configure.in, source/headers/geos/index/Makefile.am,
source/headers/geos/index/strtree,
@@ -19155,12 +21151,12 @@
source/index/strtree/SIRtree.cpp,
source/index/strtree/STRtree.cpp: indexStrtree.h split
-2006-03-21 10:46 Sandro Santilli <strk at keybit.net>
+2006-03-21 10:46 Sandro Santilli <strk at kbt.io>
* [r1255] source/algorithm/RobustDeterminant.cpp: streamlined
header inclusion, put original copyright on top
-2006-03-21 10:01 Sandro Santilli <strk at keybit.net>
+2006-03-21 10:01 Sandro Santilli <strk at kbt.io>
* [r1254] configure.in, source/headers/geos/index/Makefile.am,
source/headers/geos/index/sweepline,
@@ -19179,7 +21175,7 @@
source/operation/valid/SweeplineNestedRingTester.cpp:
indexSweepline.h header split
-2006-03-20 18:18 Sandro Santilli <strk at keybit.net>
+2006-03-20 18:18 Sandro Santilli <strk at kbt.io>
* [r1253] capi/geos_c.cpp, configure.in,
source/headers/geos/Makefile.am, source/headers/geos/io,
@@ -19202,18 +21198,18 @@
source/io/Writer.cpp, source/operation/buffer/BufferSubgraph.cpp:
io.h header split
-2006-03-20 17:40 Sandro Santilli <strk at keybit.net>
+2006-03-20 17:40 Sandro Santilli <strk at kbt.io>
* [r1252] source/index/quadtree/DoubleBits.cpp: <cmath> included
when appropriate
-2006-03-20 17:27 Sandro Santilli <strk at keybit.net>
+2006-03-20 17:27 Sandro Santilli <strk at kbt.io>
* [r1251] source/headers/geos/geom/CoordinateSequence.h,
source/headers/geos/geom/GeometryFactory.h: Bug #72 - Missing
<vector> header
-2006-03-20 17:17 Sandro Santilli <strk at keybit.net>
+2006-03-20 17:17 Sandro Santilli <strk at kbt.io>
* [r1250] source/headers/geos/geomgraph/index/Makefile.am,
@@ -19222,7 +21218,7 @@
source/headers/geos/operation/overlay/Makefile.am,
source/headers/geos/operation/valid/Makefile.am: Fixed geosdir
-2006-03-20 16:57 Sandro Santilli <strk at keybit.net>
+2006-03-20 16:57 Sandro Santilli <strk at kbt.io>
* [r1249] configure.in, source/geom/Geometry.cpp,
source/headers/geos/Makefile.am, source/headers/geos/index,
@@ -19268,69 +21264,69 @@
spatialindex.h and opValid.h headers split
-2006-03-20 16:08 Sandro Santilli <strk at keybit.net>
+2006-03-20 16:08 Sandro Santilli <strk at kbt.io>
* [r1248] macros/ac_python_devel.m4: redirected find stderr to
/dev/null
-2006-03-20 13:20 Sandro Santilli <strk at keybit.net>
+2006-03-20 13:20 Sandro Santilli <strk at kbt.io>
* [r1247] source/operation/overlay/PolygonBuilder.cpp: Changed
assertion to TopologyException for the "orphaned" hole case
in order to allow for reduced precision ops to catch the case.
-2006-03-20 12:33 Sandro Santilli <strk at keybit.net>
+2006-03-20 12:33 Sandro Santilli <strk at kbt.io>
* [r1246] source/headers/geos/operation/overlay/PolygonBuilder.h,
source/operation/overlay/PolygonBuilder.cpp: Simplified some
privat methods to use refs instead of pointers, added
debugging section for failiures of holes/shells associations
-2006-03-20 12:32 Sandro Santilli <strk at keybit.net>
+2006-03-20 12:32 Sandro Santilli <strk at kbt.io>
* [r1245] source/headers/geos/geomgraph/EdgeRing.h: Added note
about responsibility of return from ::toPolygon
-2006-03-20 12:03 Sandro Santilli <strk at keybit.net>
+2006-03-20 12:03 Sandro Santilli <strk at kbt.io>
* [r1244] source/geom/Geometry.cpp,
source/headers/geos/geom/Geometry.h: Added operator<< for
Geometry, writing HEXWKB
-2006-03-20 11:42 Sandro Santilli <strk at keybit.net>
+2006-03-20 11:42 Sandro Santilli <strk at kbt.io>
* [r1243] source/noding/Octant.cpp,
source/operation/buffer/OffsetCurveBuilder.cpp,
source/operation/buffer/OffsetCurveSetBuilder.cpp: Added missing
<cmath> include
-2006-03-20 10:42 Sandro Santilli <strk at keybit.net>
+2006-03-20 10:42 Sandro Santilli <strk at kbt.io>
* [r1242] source/operation/predicate/RectangleContains.cpp,
source/operation/predicate/RectangleIntersects.cpp: Bug #61 -
Disambiguated geom::Polygon use
-2006-03-20 10:14 Sandro Santilli <strk at keybit.net>
+2006-03-20 10:14 Sandro Santilli <strk at kbt.io>
* [r1241] source/headers/geos/timeval.h: Bug #69 - Check for macro
WIN32_LEAN_AND_MEAN
-2006-03-20 10:13 Sandro Santilli <strk at keybit.net>
+2006-03-20 10:13 Sandro Santilli <strk at kbt.io>
* [r1240] source/operation/buffer/SubgraphDepthLocater.cpp: Bug #71
- Missing <algorithm>
-2006-03-20 10:12 Sandro Santilli <strk at keybit.net>
+2006-03-20 10:12 Sandro Santilli <strk at kbt.io>
* [r1239] source/headers/geos/geom/Coordinate.h: Bug #70 - Small
fix in fwd decl. of CoordinateLessThen
-2006-03-20 10:11 Sandro Santilli <strk at keybit.net>
+2006-03-20 10:11 Sandro Santilli <strk at kbt.io>
* [r1238] source/geom/GeometryFactory.cpp: Bug #67 - Debugging
helpers in GeometryFactory class
-2006-03-17 16:48 Sandro Santilli <strk at keybit.net>
+2006-03-17 16:48 Sandro Santilli <strk at kbt.io>
* [r1237] source/headers/geos/opRelate.h,
source/headers/geos/opValid.h, source/io/Unload.cpp,
@@ -19348,12 +21344,12 @@
opRelate.h
and opValid.h, updated .cpp files to allow build.
-2006-03-17 14:56 Sandro Santilli <strk at keybit.net>
+2006-03-17 14:56 Sandro Santilli <strk at kbt.io>
* [r1236] tests/xmltester/XMLTester.cpp: Fixed filename normalizer
for sql output
-2006-03-17 13:24 Sandro Santilli <strk at keybit.net>
+2006-03-17 13:24 Sandro Santilli <strk at kbt.io>
* [r1235] configure.in, source/geom/Geometry.cpp,
source/headers/geos/opOverlay.h,
@@ -19390,27 +21386,27 @@
implementation files. ElevationMatrixFilter code moved from own
file to ElevationMatrix.cpp (ideally a class-private).
-2006-03-16 13:30 Sandro Santilli <strk at keybit.net>
+2006-03-16 13:30 Sandro Santilli <strk at kbt.io>
* [r1234] tests/xmltester/linemerge.xml: Added missing testfile
-2006-03-16 13:29 Sandro Santilli <strk at keybit.net>
+2006-03-16 13:29 Sandro Santilli <strk at kbt.io>
* [r1233] tests/unit/Makefile.am, tests/unit/geom/LineSegment.cpp:
new unit test for LineSegment (adding tests would be helpful)
-2006-03-16 13:28 Sandro Santilli <strk at keybit.net>
+2006-03-16 13:28 Sandro Santilli <strk at kbt.io>
* [r1232] source/geom/LineSegment.cpp,
source/headers/geos/geom/LineSegment.inl: obsoleted
getCoordinate(), replaced by operator[]
-2006-03-16 13:27 Sandro Santilli <strk at keybit.net>
+2006-03-16 13:27 Sandro Santilli <strk at kbt.io>
* [r1231] README: Added notes about testing
-2006-03-16 10:47 Sandro Santilli <strk at keybit.net>
+2006-03-16 10:47 Sandro Santilli <strk at kbt.io>
* [r1230] tests/tut/tut.h, tests/tut/tut_reporter.h,
tests/tut/tut_restartable.h, tests/unit/geom/Envelope.cpp,
@@ -19418,17 +21414,17 @@
tests/unit/geos_unit.cpp: Bug #65 - Command line changes and EOL
fixes Unit Test
-2006-03-16 10:42 Sandro Santilli <strk at keybit.net>
+2006-03-16 10:42 Sandro Santilli <strk at kbt.io>
* [r1229] source/geom/Geometry.cpp: Bug #64 - Not all control paths
return a value in geos::geom::Geometry::getClassSortIndex
-2006-03-16 10:38 Sandro Santilli <strk at keybit.net>
+2006-03-16 10:38 Sandro Santilli <strk at kbt.io>
* [r1228] source/algorithm/LineIntersector.cpp: Bug #63 - Remove
unreferenced local variable warning
-2006-03-16 09:37 Sandro Santilli <strk at keybit.net>
+2006-03-16 09:37 Sandro Santilli <strk at kbt.io>
* [r1227] tests/tut, tests/tut/tut.h, tests/tut/tut_reporter.h,
tests/tut/tut_restartable.h, tests/unit/Makefile.am,
@@ -19437,33 +21433,33 @@
tests/unit/geom/Geometry/isRectangle.cpp,
tests/unit/geos_unit.cpp: Initial unit tests
-2006-03-15 18:59 Sandro Santilli <strk at keybit.net>
+2006-03-15 18:59 Sandro Santilli <strk at kbt.io>
* [r1226] source/headers/geos/operation/IsSimpleOp.h: Bug #62:
'struct' CoordinateLessThen in forward declaration
-2006-03-15 18:57 Sandro Santilli <strk at keybit.net>
+2006-03-15 18:57 Sandro Santilli <strk at kbt.io>
* [r1225] source/operation/buffer/SubgraphDepthLocater.cpp: small
cleanup
* [r1224] source/operation/buffer/BufferBuilder.cpp: cleanups in
DEBUG lines
-2006-03-15 18:56 Sandro Santilli <strk at keybit.net>
+2006-03-15 18:56 Sandro Santilli <strk at kbt.io>
* [r1223] source/operation/buffer/BufferOp.cpp: Temporary hack to
avoid snapround:: Noders (still using ScaledNoder wrapper)
to allow for buffer_snapround.xml test to succeed
-2006-03-15 18:55 Sandro Santilli <strk at keybit.net>
+2006-03-15 18:55 Sandro Santilli <strk at kbt.io>
* [r1222] tests/xmltester/buffer_snapround.xml: Added xml testfile
showing bug in snapround:: noders
-2006-03-15 18:44 Sandro Santilli <strk at keybit.net>
+2006-03-15 18:44 Sandro Santilli <strk at kbt.io>
* [r1221] doc/example.cpp, source/geom/Envelope.cpp,
source/geom/LineSegment.cpp, source/geom/PrecisionModel.cpp,
@@ -19475,19 +21471,19 @@
source/util/GeometricShapeFactory.cpp: Bug #60 - Missing <cmath>
header in some files
-2006-03-15 17:33 Sandro Santilli <strk at keybit.net>
+2006-03-15 17:33 Sandro Santilli <strk at kbt.io>
* [r1220] source/operation/buffer/BufferSubgraph.cpp: Changed
operator<< to use operator<< for Nodes
-2006-03-15 17:17 Sandro Santilli <strk at keybit.net>
+2006-03-15 17:17 Sandro Santilli <strk at kbt.io>
* [r1219] source/headers/geos/geomgraph/DirectedEdgeStar.h,
source/headers/geos/geomgraph/index/SweepLineEvent.h: Added
missing forward declarations
-2006-03-15 17:16 Sandro Santilli <strk at keybit.net>
+2006-03-15 17:16 Sandro Santilli <strk at kbt.io>
* [r1218] source/geomgraph/Depth.cpp,
@@ -19513,46 +21509,46 @@
source/geomgraph/index/SweepLineSegment.cpp: streamlined headers
inclusion
-2006-03-15 16:27 Sandro Santilli <strk at keybit.net>
+2006-03-15 16:27 Sandro Santilli <strk at kbt.io>
* [r1217] source/geomgraph/Node.cpp,
source/headers/geos/geomgraph/Node.h: operator<< for Node class
-2006-03-15 15:50 Sandro Santilli <strk at keybit.net>
+2006-03-15 15:50 Sandro Santilli <strk at kbt.io>
* [r1216]
source/headers/geos/operation/buffer/SubgraphDepthLocater.h,
source/operation/buffer/SubgraphDepthLocater.cpp: const
correctness, cleanups
-2006-03-15 15:27 Sandro Santilli <strk at keybit.net>
+2006-03-15 15:27 Sandro Santilli <strk at kbt.io>
* [r1215] source/headers/geos/geomgraph/DirectedEdge.h,
source/headers/geos/geomgraph/EdgeEnd.h: cleanups
-2006-03-15 15:26 Sandro Santilli <strk at keybit.net>
+2006-03-15 15:26 Sandro Santilli <strk at kbt.io>
* [r1214] source/geomgraph/DirectedEdge.cpp,
source/geomgraph/EdgeRing.cpp: Cleanups
-2006-03-15 13:03 Sandro Santilli <strk at keybit.net>
+2006-03-15 13:03 Sandro Santilli <strk at kbt.io>
* [r1213] source/operation/buffer/BufferBuilder.cpp: removed
leftover debugging line
-2006-03-15 12:54 Sandro Santilli <strk at keybit.net>
+2006-03-15 12:54 Sandro Santilli <strk at kbt.io>
* [r1212] source/headers/geos/opBuffer.h: Removed DepthSegment.h
include
* [r1211] source/headers/geos/operation/buffer/DepthSegment.h,
source/headers/geos/operation/buffer/Makefile.am: Removed public
DepthSegment definition (moved inside SubgraphDepthLocater
implementation)
-2006-03-15 12:52 Sandro Santilli <strk at keybit.net>
+2006-03-15 12:52 Sandro Santilli <strk at kbt.io>
* [r1210] source/operation/buffer/DepthSegment.cpp,
source/operation/buffer/Makefile.am,
@@ -19561,39 +21557,39 @@
as it was private to this file in JTS. Also, changed to reduce
copies of LineSegment copies.
-2006-03-15 11:45 Sandro Santilli <strk at keybit.net>
+2006-03-15 11:45 Sandro Santilli <strk at kbt.io>
* [r1209] source/headers/geos/operation/buffer/BufferSubgraph.h:
doxygen comments
-2006-03-15 11:44 Sandro Santilli <strk at keybit.net>
+2006-03-15 11:44 Sandro Santilli <strk at kbt.io>
* [r1208] source/operation/overlay/PolygonBuilder.cpp: debug
blocks, dumping SQL when GEOS_DEBUG > 1
-2006-03-15 11:42 Sandro Santilli <strk at keybit.net>
+2006-03-15 11:42 Sandro Santilli <strk at kbt.io>
* [r1207] source/operation/buffer/BufferBuilder.cpp: more debugging
lines, with two levels of debugging handled
-2006-03-15 11:39 Sandro Santilli <strk at keybit.net>
+2006-03-15 11:39 Sandro Santilli <strk at kbt.io>
* [r1206] source/operation/buffer/BufferSubgraph.cpp: comments
cleanup, changed computeDepths to use a list<> rather then a
vector (performance related)
-2006-03-15 10:40 Sandro Santilli <strk at keybit.net>
+2006-03-15 10:40 Sandro Santilli <strk at kbt.io>
* [r1205] doc/Doxyfile.in: Fixed to allow doxygen runs from
external builddir
-2006-03-15 09:51 Sandro Santilli <strk at keybit.net>
+2006-03-15 09:51 Sandro Santilli <strk at kbt.io>
* [r1204] source/headers/geos/noding/SegmentString.inl,
source/headers/geos/noding/SimpleNoder.h: streamlined header
usage
* [r1203] source/noding/IntersectionAdder.cpp,
source/noding/IntersectionFinderAdder.cpp,
@@ -19606,59 +21602,59 @@
source/noding/snapround/SimpleSnapRounder.cpp: streamlined
headers usage
-2006-03-15 09:13 Sandro Santilli <strk at keybit.net>
+2006-03-15 09:13 Sandro Santilli <strk at kbt.io>
* [r1202] source/geom/Polygon.cpp: updated port info
-2006-03-15 09:12 Sandro Santilli <strk at keybit.net>
+2006-03-15 09:12 Sandro Santilli <strk at kbt.io>
* [r1201] source/headers/geos/geom/Polygon.h: isSimple doc
-2006-03-14 17:46 Sandro Santilli <strk at keybit.net>
+2006-03-14 17:46 Sandro Santilli <strk at kbt.io>
* [r1200] source/headers/geos/util/Assert.h: Removed unrequired
include
-2006-03-14 17:10 Sandro Santilli <strk at keybit.net>
+2006-03-14 17:10 Sandro Santilli <strk at kbt.io>
* [r1199] source/operation/buffer/BufferSubgraph.cpp: cleanups
-2006-03-14 17:08 Sandro Santilli <strk at keybit.net>
+2006-03-14 17:08 Sandro Santilli <strk at kbt.io>
* [r1198] source/headers/geos/opOverlay.h,
source/operation/overlay/MaximalEdgeRing.cpp: comments cleanup,
integrity checks
-2006-03-14 16:55 Sandro Santilli <strk at keybit.net>
+2006-03-14 16:55 Sandro Santilli <strk at kbt.io>
* [r1197] source/operation/overlay/PolygonBuilder.cpp: oops,
GEOS_DEBUG default to 0
* [r1196] source/headers/geos/opOverlay.h,
source/operation/overlay/PolygonBuilder.cpp: comments cleanup
-2006-03-14 16:53 Sandro Santilli <strk at keybit.net>
+2006-03-14 16:53 Sandro Santilli <strk at kbt.io>
* [r1195] source/geomgraph/Edge.cpp: removed endline from printing
funx
-2006-03-14 16:08 Sandro Santilli <strk at keybit.net>
+2006-03-14 16:08 Sandro Santilli <strk at kbt.io>
* [r1194] source/headers/geos/operation/buffer/BufferBuilder.h,
source/operation/buffer/BufferBuilder.cpp: changed buildSubgraphs
signature to use refs rather then pointers, made it
const-correct. Reduced heap allocations in createSubgraphs()
-2006-03-14 15:46 Sandro Santilli <strk at keybit.net>
+2006-03-14 15:46 Sandro Santilli <strk at kbt.io>
* [r1193] source/geomgraph/PlanarGraph.cpp,
source/headers/geos/geomgraph/PlanarGraph.h: Added
PlanarGraph::getNodes(vector&) func, to reduce useless heap
allocations
-2006-03-14 15:32 Sandro Santilli <strk at keybit.net>
+2006-03-14 15:32 Sandro Santilli <strk at kbt.io>
* [r1192] source/geom/Coordinate.cpp,
@@ -19666,7 +21662,7 @@
source/geomgraph/Node.cpp: Cleaned up toString funx (more WKT
friendly)
-2006-03-14 14:16 Sandro Santilli <strk at keybit.net>
+2006-03-14 14:16 Sandro Santilli <strk at kbt.io>
* [r1191] source/headers/geos/operation/buffer/BufferSubgraph.h,
@@ -19674,7 +21670,7 @@
source/operation/overlay/PolygonBuilder.cpp: operator<< for
BufferSubgraph, more debugging calls
-2006-03-14 12:55 Sandro Santilli <strk at keybit.net>
+2006-03-14 12:55 Sandro Santilli <strk at kbt.io>
* [r1190] configure.in, source/geom/Geometry.cpp,
source/geomgraph/Label.cpp, source/geomgraph/Node.cpp,
@@ -19719,24 +21715,24 @@
source/operation/buffer/BufferOp.cpp: Headers split:
geomgraphindex.h, nodingSnapround.h
-2006-03-14 11:03 Sandro Santilli <strk at keybit.net>
+2006-03-14 11:03 Sandro Santilli <strk at kbt.io>
* [r1189] source/geomgraph/Edge.cpp, source/geomgraph/EdgeList.cpp,
source/headers/geos/geomgraph/EdgeList.h: Added operator<< for
Edge and EdgeList
-2006-03-14 00:37 Sandro Santilli <strk at keybit.net>
+2006-03-14 00:37 Sandro Santilli <strk at kbt.io>
* [r1188] source/headers/geos/operation/buffer/Makefile.am: Fixed
include filenames
-2006-03-14 00:36 Sandro Santilli <strk at keybit.net>
+2006-03-14 00:36 Sandro Santilli <strk at kbt.io>
* [r1187] source/operation/buffer/BufferOp.cpp: Reduced 'buffer'
headers inclusion
-2006-03-14 00:19 Sandro Santilli <strk at keybit.net>
+2006-03-14 00:19 Sandro Santilli <strk at kbt.io>
* [r1186] source/headers/geos/opBuffer.h,
source/headers/geos/operation/buffer,
@@ -19760,12 +21756,12 @@
split, streamlined headers in some (not all) files in
operation/buffer/
-2006-03-13 22:33 Sandro Santilli <strk at keybit.net>
+2006-03-13 22:33 Sandro Santilli <strk at kbt.io>
* [r1185] source/headers/geos/geom/LineSegment.h: Added missing
-2006-03-13 21:54 Sandro Santilli <strk at keybit.net>
+2006-03-13 21:54 Sandro Santilli <strk at kbt.io>
* [r1184] source/geom/Coordinate.cpp,
source/geom/CoordinateSequence.cpp,
@@ -19775,7 +21771,7 @@
source/geom/IntersectionMatrix.cpp, source/geom/LineSegment.cpp,
source/geom/Triangle.cpp: Streamlined headers inclusion.
-2006-03-13 21:19 Sandro Santilli <strk at keybit.net>
+2006-03-13 21:19 Sandro Santilli <strk at kbt.io>
* [r1183] source/headers/geos/noding/ScaledNoder.h,
source/noding/ScaledNoder.cpp: Fixed bug in ScaledNoder scaling
@@ -19783,98 +21779,98 @@
design). Tests are still failing so this possibly needs some
other fix. Streamlined includes by implementation file.
-2006-03-13 21:14 Sandro Santilli <strk at keybit.net>
+2006-03-13 21:14 Sandro Santilli <strk at kbt.io>
* [r1182] source/headers/geos/noding/SegmentString.h: Added missing
-2006-03-13 21:13 Sandro Santilli <strk at keybit.net>
+2006-03-13 21:13 Sandro Santilli <strk at kbt.io>
* [r1181] source/headers/geos/geom/CoordinateFilter.h: Added
comment about possible refactoring
-2006-03-11 16:58 Sandro Santilli <strk at keybit.net>
+2006-03-11 16:58 Sandro Santilli <strk at kbt.io>
* [r1180] source/headers/geos/opBuffer.h,
source/operation/buffer/OffsetCurveBuilder.cpp: Fixed bug in
OffsetCurveBuilder::getCoordinates.
-2006-03-10 15:50 Sandro Santilli <strk at keybit.net>
+2006-03-10 15:50 Sandro Santilli <strk at kbt.io>
* [r1179] source/geomgraph/EdgeRing.cpp: Changed 'found null
Directed Edge' from an Assertion to a TopologyException, to give
'precision-reducing' overlay operation a chance to handle it (it
seems to work)
-2006-03-10 13:07 Sandro Santilli <strk at keybit.net>
+2006-03-10 13:07 Sandro Santilli <strk at kbt.io>
* [r1178] source/geomgraph/EdgeRing.cpp: fine-tuned includes,
reverted Assert=>assert due to user-input based failure
-2006-03-10 12:50 Sandro Santilli <strk at keybit.net>
+2006-03-10 12:50 Sandro Santilli <strk at kbt.io>
* [r1177] configure.in, tests/unit/Makefile.am,
tests/unit/envelope_class_test.cpp: boost detection code fix,
first UTF source for testing purposes
-2006-03-10 12:43 Sandro Santilli <strk at keybit.net>
+2006-03-10 12:43 Sandro Santilli <strk at kbt.io>
* [r1176] TODO: updated
-2006-03-10 12:09 Sandro Santilli <strk at keybit.net>
+2006-03-10 12:09 Sandro Santilli <strk at kbt.io>
* [r1175] configure.in: Update configure script to work with new
boost.m4 file
-2006-03-10 11:49 Sandro Santilli <strk at keybit.net>
+2006-03-10 11:49 Sandro Santilli <strk at kbt.io>
* [r1174] macros/boost.m4: Updated boost detection macro
-2006-03-10 11:41 Sandro Santilli <strk at keybit.net>
+2006-03-10 11:41 Sandro Santilli <strk at kbt.io>
* [r1173] source/index/quadtree/QuadTreeNodeBase.cpp: Added missing
<algorithm> include (bug#56)
-2006-03-10 11:10 Sandro Santilli <strk at keybit.net>
+2006-03-10 11:10 Sandro Santilli <strk at kbt.io>
* [r1172] configure.in, macros/boost.m4, tests/Makefile.am,
tests/unit, tests/unit/.cvsignore, tests/unit/Makefile.am:
Initial boost detection code
-2006-03-10 11:09 Sandro Santilli <strk at keybit.net>
+2006-03-10 11:09 Sandro Santilli <strk at kbt.io>
* [r1171] source/operation/valid/ConnectedInteriorTester.cpp:
Comments cleanup
-2006-03-10 10:48 Sandro Santilli <strk at keybit.net>
+2006-03-10 10:48 Sandro Santilli <strk at kbt.io>
* [r1170] source/Makefile.vc: Bug #58 - Patch to makefile.vc after
big refactoring commit
-2006-03-10 10:44 Sandro Santilli <strk at keybit.net>
+2006-03-10 10:44 Sandro Santilli <strk at kbt.io>
* [r1169] source/operation/buffer/BufferBuilder.cpp,
source/operation/overlay/ElevationMatrixFilter.cpp,
source/precision/EnhancedPrecisionOp.cpp: Unreferenced exception
objects cleanup (#52)
-2006-03-10 10:37 Sandro Santilli <strk at keybit.net>
+2006-03-10 10:37 Sandro Santilli <strk at kbt.io>
* [r1168] source/geomgraph/index/SimpleSweepLineIntersector.cpp:
Added missing <algorithm> include (#55)
-2006-03-10 10:34 Sandro Santilli <strk at keybit.net>
+2006-03-10 10:34 Sandro Santilli <strk at kbt.io>
* [r1167] source/geom/Polygon.cpp: Added missing <algorithm>
include (#54)
-2006-03-09 18:22 Sandro Santilli <strk at keybit.net>
+2006-03-09 18:22 Sandro Santilli <strk at kbt.io>
* [r1166] tests/xmltester/Makefile.am,
tests/xmltester/TestIsValid.xml: Added isvalid test for latest
validop patch
-2006-03-09 18:18 Sandro Santilli <strk at keybit.net>
+2006-03-09 18:18 Sandro Santilli <strk at kbt.io>
* [r1165] source/headers/geos/opOverlay.h,
@@ -19884,13 +21880,13 @@
implementation.
Applied patch to IsValid operation from JTS-1.7.1
-2006-03-09 17:40 Sandro Santilli <strk at keybit.net>
+2006-03-09 17:40 Sandro Santilli <strk at kbt.io>
* [r1164] source/headers/geos/opBuffer.h,
source/operation/buffer/OffsetCurveBuilder.cpp: Fixed bug#33
(hopefully)
-2006-03-09 16:46 Sandro Santilli <strk at keybit.net>
+2006-03-09 16:46 Sandro Santilli <strk at kbt.io>
* [r1163] configure.in, source/algorithm/CGAlgorithms.cpp,
@@ -20106,92 +22102,92 @@
tests/xmltester/XMLTester.cpp, tests/xmltester/buffer.xml:
geos::geom namespace definition, first pass at headers split
-2006-03-09 16:18 Sandro Santilli <strk at keybit.net>
+2006-03-09 16:18 Sandro Santilli <strk at kbt.io>
* [r1162] tests/xmltester/Makefile.am: Fixed to allow tests from
external build tree (thanks Norman:)
-2006-03-09 16:01 Sandro Santilli <strk at keybit.net>
+2006-03-09 16:01 Sandro Santilli <strk at kbt.io>
* [r1161] source/geomgraph/Position.cpp,
source/operation/overlay/ElevationMatrixFilter.cpp: Fixed
debugging lines
-2006-03-09 15:50 Sandro Santilli <strk at keybit.net>
+2006-03-09 15:50 Sandro Santilli <strk at kbt.io>
* [r1160] source/operation/overlay/OverlayOp.cpp: Fixed debugging
lines, added missing header
-2006-03-09 15:47 Sandro Santilli <strk at keybit.net>
+2006-03-09 15:47 Sandro Santilli <strk at kbt.io>
* [r1159] source/operation/linemerge/LineMergeGraph.cpp: Fixed
debugging lines
-2006-03-09 15:39 Sandro Santilli <strk at keybit.net>
+2006-03-09 15:39 Sandro Santilli <strk at kbt.io>
* [r1158] source/index/quadtree/QuadTreeKey.cpp,
source/index/quadtree/QuadTreeRoot.cpp,
source/noding/SegmentNodeList.cpp: Fixed debugging lines
-2006-03-09 14:48 Sandro Santilli <strk at keybit.net>
+2006-03-09 14:48 Sandro Santilli <strk at kbt.io>
* [r1157] capi/Makefile.am: Added missing INCLUDES line
-2006-03-07 14:21 Sandro Santilli <strk at keybit.net>
+2006-03-07 14:21 Sandro Santilli <strk at kbt.io>
* [r1156] tests/xmltester/XMLTester.cpp: Leak plugged, tweeked
output to be nice with --sql-output
-2006-03-07 14:20 Sandro Santilli <strk at keybit.net>
+2006-03-07 14:20 Sandro Santilli <strk at kbt.io>
* [r1155] source/headers/geos/opBuffer.h,
source/operation/buffer/OffsetCurveBuilder.cpp: Big deal of heap
allocations reduction
-2006-03-07 14:18 Sandro Santilli <strk at keybit.net>
+2006-03-07 14:18 Sandro Santilli <strk at kbt.io>
* [r1154] source/util/Profiler.cpp: Profiler singleton implemented
with a function-static Profiler instance
-2006-03-07 12:42 Sandro Santilli <strk at keybit.net>
+2006-03-07 12:42 Sandro Santilli <strk at kbt.io>
* [r1153] tests/xmltester/buffer.xml: addedvalidity test for a case
with invalid input
-2006-03-07 12:41 Sandro Santilli <strk at keybit.net>
+2006-03-07 12:41 Sandro Santilli <strk at kbt.io>
* [r1152] tests/xmltester/XMLTester.cpp,
tests/xmltester/XMLTester.h: Added --wkb-output and made
--sql-output compatible with -v
-2006-03-07 11:22 Sandro Santilli <strk at keybit.net>
+2006-03-07 11:22 Sandro Santilli <strk at kbt.io>
* [r1151] tests/xmltester/XMLTester.cpp: table name for sqlOutput
normalized
-2006-03-07 11:06 Sandro Santilli <strk at keybit.net>
+2006-03-07 11:06 Sandro Santilli <strk at kbt.io>
* [r1150] tests/xmltester/XMLTester.cpp,
tests/xmltester/XMLTester.h: Added --sql-output switch for
debugging
-2006-03-07 10:46 Sandro Santilli <strk at keybit.net>
+2006-03-07 10:46 Sandro Santilli <strk at kbt.io>
* [r1149] tests/xmltester/XMLTester.cpp: verbose validity errors
-2006-03-06 21:27 Sandro Santilli <strk at keybit.net>
+2006-03-06 21:27 Sandro Santilli <strk at kbt.io>
* [r1148] doc/example.cpp, source/headers/geos/geom.h,
source/headers/geos/opRelate.h, tests/xmltester/XMLTester.cpp:
Cascading fixed after Unload definition moved to geos::io
namespace
-2006-03-06 19:43 Sandro Santilli <strk at keybit.net>
+2006-03-06 19:43 Sandro Santilli <strk at kbt.io>
* [r1147] source/headers/geos/unload.h: Fixed Unload class
definition namespace (geos::io)
-2006-03-06 19:40 Sandro Santilli <strk at keybit.net>
+2006-03-06 19:40 Sandro Santilli <strk at kbt.io>
* [r1146] capi/geos_c.cpp, doc/example.cpp,
@@ -20268,7 +22264,7 @@
tests/xmltester/XMLTester.cpp: geos::util namespace. New
GeometryCollection::iterator interface, many cleanups.
-2006-03-06 15:23 Sandro Santilli <strk at keybit.net>
+2006-03-06 15:23 Sandro Santilli <strk at kbt.io>
* [r1145] capi/geos_c.cpp, doc/example.cpp,
source/geom/Geometry.cpp, source/headers/geos/io.h,
@@ -20280,74 +22276,74 @@
tests/xmltester/XMLTester.cpp, tests/xmltester/XMLTester.h,
tests/xmltester/buffer.xml: geos::io namespace
-2006-03-06 14:30 Sandro Santilli <strk at keybit.net>
+2006-03-06 14:30 Sandro Santilli <strk at kbt.io>
* [r1143] capi/geos_c.cpp: Validity error include Coordinate
-2006-03-06 13:27 Sandro Santilli <strk at keybit.net>
+2006-03-06 13:27 Sandro Santilli <strk at kbt.io>
* [r1142] source/geom/Polygon.cpp: Cleaned up equalsExact
-2006-03-06 13:26 Sandro Santilli <strk at keybit.net>
+2006-03-06 13:26 Sandro Santilli <strk at kbt.io>
* [r1141] tests/xmltester/XMLTester.cpp: Fixed equalsExact check,
and also reduced tolerance
-2006-03-06 12:47 Sandro Santilli <strk at keybit.net>
+2006-03-06 12:47 Sandro Santilli <strk at kbt.io>
* [r1140] source/headers/geos/opValid.h,
source/operation/valid/IsValidOp.cpp: TopologyValidationError
error names (enum) renamed to avoid conflicts.
-2006-03-06 12:16 Sandro Santilli <strk at keybit.net>
+2006-03-06 12:16 Sandro Santilli <strk at kbt.io>
* [r1139] tests/xmltester/robustness.xml: Added second case for
Union
-2006-03-06 12:11 Sandro Santilli <strk at keybit.net>
+2006-03-06 12:11 Sandro Santilli <strk at kbt.io>
* [r1138] source/operation/overlay/OverlayOp.cpp: precision.h =>
geos/precision.h (#48)
-2006-03-06 11:39 Sandro Santilli <strk at keybit.net>
+2006-03-06 11:39 Sandro Santilli <strk at kbt.io>
* [r1137] tests/xmltester/robustness.xml: Added test extracted from
data provided by Guillaume Sueur
-2006-03-06 11:34 Sandro Santilli <strk at keybit.net>
+2006-03-06 11:34 Sandro Santilli <strk at kbt.io>
* [r1136] source/headers/geos/geom.h: Dropped
unused/unmaintained/platform-problematic serial version info for
classes (#47)
-2006-03-06 11:17 Sandro Santilli <strk at keybit.net>
+2006-03-06 11:17 Sandro Santilli <strk at kbt.io>
* [r1135] capi/geos_c.cpp: added a compile-time option to get
VERBOSE_EXCEPTION (print args on exceptions)
* [r1134] source/operation/overlay/OverlayOp.cpp: precision
reducing overlayOp made compile-time optional
-2006-03-06 11:05 Sandro Santilli <strk at keybit.net>
+2006-03-06 11:05 Sandro Santilli <strk at kbt.io>
* [r1133] tests/xmltester/XMLTester.cpp,
tests/xmltester/XMLTester.h: Added input and output validity test
facilities
-2006-03-03 14:01 Sandro Santilli <strk at keybit.net>
+2006-03-03 14:01 Sandro Santilli <strk at kbt.io>
* [r1132] source/operation/overlay/OverlayOp.cpp: Experimental
precision-reducing overlayOp
-2006-03-03 13:50 Sandro Santilli <strk at keybit.net>
+2006-03-03 13:50 Sandro Santilli <strk at kbt.io>
* [r1131] source/algorithm/InteriorPointLine.cpp,
source/headers/geos/geom.h, source/headers/geos/geosAlgorithm.h:
Cleaned up InteriorPointLine class
-2006-03-03 10:46 Sandro Santilli <strk at keybit.net>
+2006-03-03 10:46 Sandro Santilli <strk at kbt.io>
* [r1130] capi/geos_c.cpp, doc/example.cpp,
@@ -20469,16 +22465,16 @@
Removed 'using namespace' from headers, added missing headers in
.cpp files, removed useless includes in headers (bug#46)
-2006-03-02 18:17 Sandro Santilli <strk at keybit.net>
+2006-03-02 18:17 Sandro Santilli <strk at kbt.io>
* [r1129] tests/xmltester/Makefile.am,
tests/xmltester/robustness.xml: Added robustness testcases
-2006-03-02 16:22 Sandro Santilli <strk at keybit.net>
+2006-03-02 16:22 Sandro Santilli <strk at kbt.io>
* [r1128] tests/xmltester/XMLTester.cpp: Updated copyright notice
-2006-03-02 16:21 Sandro Santilli <strk at keybit.net>
+2006-03-02 16:21 Sandro Santilli <strk at kbt.io>
* [r1127] source/geomgraph/PlanarGraph.cpp,
source/headers/geos/geomUtil.h, source/headers/geos/precision.h,
@@ -20489,7 +22485,7 @@
geos::precision namespace added
-2006-03-02 14:53 Sandro Santilli <strk at keybit.net>
+2006-03-02 14:53 Sandro Santilli <strk at kbt.io>
* [r1126] source/geomgraph/index/SweepLineEvent.cpp,
source/headers/geos/geomgraphindex.h,
@@ -20497,7 +22493,7 @@
source/index/sweepline/indexSweepLineEvent.cpp:
SweepLineEvent::DELETE=>DELETE_EVENT, INSERT=>INSERT_EVENT (#45)
-2006-03-02 14:34 Sandro Santilli <strk at keybit.net>
+2006-03-02 14:34 Sandro Santilli <strk at kbt.io>
* [r1125] source/headers/geos/geomgraph.h,
source/headers/geos/operation.h, source/io/Unload.cpp,
@@ -20507,11 +22503,11 @@
GeometryGraphOperation::li made a non-static member, and not more
a pointer
-2006-03-02 14:21 Sandro Santilli <strk at keybit.net>
+2006-03-02 14:21 Sandro Santilli <strk at kbt.io>
* [r1124] capi/geos_c.cpp: DEBUG => GEOS_DEBUG [#44]
-2006-03-02 12:12 Sandro Santilli <strk at keybit.net>
+2006-03-02 12:12 Sandro Santilli <strk at kbt.io>
* [r1123] source/algorithm/LineIntersector.cpp,
source/geomgraph/DirectedEdgeStar.cpp, source/geomgraph/Edge.cpp,
@@ -20550,60 +22546,60 @@
to GEOS_DEBUG, all wrapped in #ifndef block to allow global
override (bug#43)
-2006-03-02 11:03 Sandro Santilli <strk at keybit.net>
+2006-03-02 11:03 Sandro Santilli <strk at kbt.io>
* [r1122] tests/xmltester/XMLTester.cpp: Added assertion in relate
test handler
-2006-03-02 11:00 Sandro Santilli <strk at keybit.net>
+2006-03-02 11:00 Sandro Santilli <strk at kbt.io>
* [r1121] source/geom/IntersectionMatrix.cpp,
source/headers/geos/geom.h: Changed IntersectionMatrix funx
taking strings to take const string& instead
-2006-03-02 10:25 Sandro Santilli <strk at keybit.net>
+2006-03-02 10:25 Sandro Santilli <strk at kbt.io>
* [r1120] tests/xmltester/XMLTester.cpp,
tests/xmltester/buffer.xml: Added support for FLOATING_SINGLE
precisionmodel in XML tests
-2006-03-02 10:03 Sandro Santilli <strk at keybit.net>
+2006-03-02 10:03 Sandro Santilli <strk at kbt.io>
* [r1119] capi/Makefile.am, capi/geos_c.cpp: Removed use of strdup,
changed GEOSjtsport() to return const char* instead of char* (is
not advertised in headerfile, so no compatibility problems)
-2006-03-02 09:51 Sandro Santilli <strk at keybit.net>
+2006-03-02 09:51 Sandro Santilli <strk at kbt.io>
* [r1118] source/operation/overlay/OverlayOp.cpp: Fixes in DEBUG
lines (bug#42)
-2006-03-02 09:49 Sandro Santilli <strk at keybit.net>
+2006-03-02 09:49 Sandro Santilli <strk at kbt.io>
* [r1117] source/headers/geos/LineSegment.inl: Changed LineSegment
output to use 'LINESEGMENT' label rather then 'LINESTRING'
* [r1116] source/headers/geos/timeval.h: WINCE implmentation of
gettimeofday (bug#40)
-2006-03-02 09:46 Sandro Santilli <strk at keybit.net>
+2006-03-02 09:46 Sandro Santilli <strk at kbt.io>
* [r1115] source/operation/buffer/SubgraphDepthLocater.cpp: cleaned
up debugging lines
-2006-03-01 18:44 Sandro Santilli <strk at keybit.net>
+2006-03-01 18:44 Sandro Santilli <strk at kbt.io>
* [r1114] NEWS: added note about getInteriorPoint() possibly
returning NULL
-2006-03-01 18:43 Sandro Santilli <strk at keybit.net>
+2006-03-01 18:43 Sandro Santilli <strk at kbt.io>
* [r1113] capi/geos_c.cpp: Handled new NULL return from
Geometry::getInteriorPoint()
-2006-03-01 18:37 Sandro Santilli <strk at keybit.net>
+2006-03-01 18:37 Sandro Santilli <strk at kbt.io>
* [r1112] source/algorithm/InteriorPointLine.cpp,
source/algorithm/InteriorPointPoint.cpp,
@@ -20614,14 +22610,14 @@
Fixed bugs in InteriorPoint* and getCentroid() inserted by
previous commits.
-2006-03-01 18:19 Sandro Santilli <strk at keybit.net>
+2006-03-01 18:19 Sandro Santilli <strk at kbt.io>
* [r1111] tests/xmltester/Makefile.am,
tests/xmltester/TestCentroid.xml,
tests/xmltester/testLeaksBig.xml: getCentroid() test moved from
testLeaksBig.xml to TestCentroid.xml (synced with JTS-1.7)
-2006-03-01 18:15 Sandro Santilli <strk at keybit.net>
+2006-03-01 18:15 Sandro Santilli <strk at kbt.io>
* [r1110] tests/xmltester/Makefile.am,
tests/xmltester/TestInteriorPoint.xml,
@@ -20629,12 +22625,12 @@
tests out of testLeaksBig.xml and into TestInteriorPoint.xml
(synced with JTS-1.7).
-2006-03-01 18:14 Sandro Santilli <strk at keybit.net>
+2006-03-01 18:14 Sandro Santilli <strk at kbt.io>
* [r1109] tests/xmltester/XMLTester.cpp: Handled NULL return from
-2006-03-01 17:16 Sandro Santilli <strk at keybit.net>
+2006-03-01 17:16 Sandro Santilli <strk at kbt.io>
* [r1108] source/algorithm/CentroidArea.cpp,
source/algorithm/CentroidLine.cpp,
@@ -20653,26 +22649,26 @@
Reduced heap allocations in Centroid{Area,Line,Point} and
InteriorPoint{Area,Line,Point}.
-2006-03-01 16:42 Sandro Santilli <strk at keybit.net>
+2006-03-01 16:42 Sandro Santilli <strk at kbt.io>
* [r1107] source/Makefile.vc: Fixed include name (Bug#41)
-2006-03-01 16:01 Sandro Santilli <strk at keybit.net>
+2006-03-01 16:01 Sandro Santilli <strk at kbt.io>
* [r1106] source/noding/SegmentNodeList.cpp: Fixed const
correctness of operator<<(ostream&, SegmentNodeList&) [bug#37]
-2006-03-01 13:49 Sandro Santilli <strk at keybit.net>
+2006-03-01 13:49 Sandro Santilli <strk at kbt.io>
* [r1105] source/index/quadtree/Quadtree.cpp: Fixed debug lines
(bug#36)
-2006-03-01 13:48 Sandro Santilli <strk at keybit.net>
+2006-03-01 13:48 Sandro Santilli <strk at kbt.io>
* [r1104] tests/xmltester/Stackwalker.cpp: Fixed missing type
specifier (bug#35)
-2006-03-01 13:06 Sandro Santilli <strk at keybit.net>
+2006-03-01 13:06 Sandro Santilli <strk at kbt.io>
* [r1103] tests/xmltester/Makefile.am,
tests/xmltester/XMLTester.cpp, tests/xmltester/buffer.xml: Used
@@ -20682,17 +22678,17 @@
and obtained
results from buffer operations.
-2006-03-01 12:12 Sandro Santilli <strk at keybit.net>
+2006-03-01 12:12 Sandro Santilli <strk at kbt.io>
* [r1102] tests/xmltester/XMLTester.cpp: Fixed a bug in verbose
output preventing geometry arg 'A' from being properly printed
-2006-03-01 11:47 Sandro Santilli <strk at keybit.net>
+2006-03-01 11:47 Sandro Santilli <strk at kbt.io>
* [r1101] source/Makefile.vc: Applied patch by Mateusz Loskot (Bug
#39)
-2006-03-01 10:48 Sandro Santilli <strk at keybit.net>
+2006-03-01 10:48 Sandro Santilli <strk at kbt.io>
* [r1100] source/headers/geos/opValid.h,
source/operation/valid/TopologyValidationError.cpp: Changed
@@ -20700,37 +22696,37 @@
char*'
to reduce dynamic memory allocations.
-2006-03-01 10:39 Sandro Santilli <strk at keybit.net>
+2006-03-01 10:39 Sandro Santilli <strk at kbt.io>
* [r1099] source/headers/geos/unload.h, source/io/Unload.cpp: ctor
and dtor made private and inlined
-2006-03-01 09:56 Sandro Santilli <strk at keybit.net>
+2006-03-01 09:56 Sandro Santilli <strk at kbt.io>
* [r1098] tests/xmltester/XMLTester.cpp: Case insensitive operation
names and geometry arguments names (a/b)
-2006-03-01 09:43 Sandro Santilli <strk at keybit.net>
+2006-03-01 09:43 Sandro Santilli <strk at kbt.io>
* [r1097] tests/xmltester/XMLTester.cpp: Unrecognized tests always
printed (was only printed when verbose before)
-2006-03-01 08:52 Sandro Santilli <strk at keybit.net>
+2006-03-01 08:52 Sandro Santilli <strk at kbt.io>
* [r1096] source/dirlist.mk: File to be included by Makefile.vc
-2006-02-28 19:22 Sandro Santilli <strk at keybit.net>
+2006-02-28 19:22 Sandro Santilli <strk at kbt.io>
* [r1095] source/headers/geos/opBuffer.h,
source/operation/buffer/OffsetCurveBuilder.cpp: Fixed in-place
definition of static members in OffsetCurveBuilder (bug#33)
-2006-02-28 19:18 Sandro Santilli <strk at keybit.net>
+2006-02-28 19:18 Sandro Santilli <strk at kbt.io>
* [r1094] tests/xmltester/XMLTester.cpp: Added cctype include (bug
#34)
-2006-02-28 17:44 Sandro Santilli <strk at keybit.net>
+2006-02-28 17:44 Sandro Santilli <strk at kbt.io>
* [r1093] source/geom/Coordinate.cpp, source/headers/geos/geom.h,
source/headers/geos/noding.h, source/noding/SegmentNode.cpp,
@@ -20743,12 +22739,12 @@
temporary
as Martin Davis review would really be needed there.
-2006-02-28 15:34 Sandro Santilli <strk at keybit.net>
+2006-02-28 15:34 Sandro Santilli <strk at kbt.io>
* [r1092] tests/xmltester/XMLTester.cpp: Fix for VC++ builds (Bug
#32)
-2006-02-28 14:34 Sandro Santilli <strk at keybit.net>
+2006-02-28 14:34 Sandro Santilli <strk at kbt.io>
* [r1091] source/geom/Coordinate.cpp,
@@ -20768,22 +22764,22 @@
tests/xmltester/buffer.xml: Added many assertions and debugging
output hunting for a bug in BufferOp
-2006-02-28 14:05 Sandro Santilli <strk at keybit.net>
+2006-02-28 14:05 Sandro Santilli <strk at kbt.io>
* [r1090] source/geomgraph/Edge.cpp: Fixed a bug in a debugging
line
-2006-02-28 13:08 Sandro Santilli <strk at keybit.net>
+2006-02-28 13:08 Sandro Santilli <strk at kbt.io>
* [r1089] source/headers/geos/noding.h: Added missing definition of
IteratedNoder::MAX_ITER, moving it to private access level
-2006-02-28 11:15 Sandro Santilli <strk at keybit.net>
+2006-02-28 11:15 Sandro Santilli <strk at kbt.io>
* [r1088] tests/xmltester/markup/MarkupSTL.cpp: Fixed strchr use
(Bug #30)
-2006-02-28 11:11 Sandro Santilli <strk at keybit.net>
+2006-02-28 11:11 Sandro Santilli <strk at kbt.io>
* [r1087] capi/geos_c.cpp: Fixed typo in GEOSLenght function
@@ -20792,19 +22788,19 @@
* [r1085] NEWS, capi/geos_c.cpp, capi/geos_c.h.in: added
GEOSLength(), GEOSEnvelope() to the C API
-2006-02-27 14:41 Sandro Santilli <strk at keybit.net>
+2006-02-27 14:41 Sandro Santilli <strk at kbt.io>
* [r1076] tests/xmltester/XMLTester.cpp: More verbose handling of
exceptions
-2006-02-27 11:53 Sandro Santilli <strk at keybit.net>
+2006-02-27 11:53 Sandro Santilli <strk at kbt.io>
* [r1075] source/geomgraph/DirectedEdgeStar.cpp,
source/headers/geos/geomgraph.h: DirectedEdgeStar made more safe
trough assert(), use of standard iterator and
dynamic casts substituting static ones.
-2006-02-27 09:05 Sandro Santilli <strk at keybit.net>
+2006-02-27 09:05 Sandro Santilli <strk at kbt.io>
* [r1074] source/algorithm/LineIntersector.cpp,
@@ -20816,7 +22812,7 @@
source/operation/overlay/OverlayOp.cpp: Doxygen comments, a few
inlines and general cleanups
-2006-02-24 16:20 Sandro Santilli <strk at keybit.net>
+2006-02-24 16:20 Sandro Santilli <strk at kbt.io>
* [r1073] source/geom/PrecisionModel.cpp,
source/headers/geos/nodingSnapround.h,
@@ -20828,7 +22824,7 @@
Moved rint_vc to math.cpp (geos::util namespace), to be renamed
to something more meaningful
-2006-02-24 15:39 Sandro Santilli <strk at keybit.net>
+2006-02-24 15:39 Sandro Santilli <strk at kbt.io>
* [r1072] source/geom/Coordinate.cpp, source/headers/geos/geom.h,
@@ -20841,11 +22837,11 @@
- Fixed bug in planarGraphComponent::setMarked
- Added linemerge.xml test (single test, should grow a bit)
-2006-02-24 12:19 Sandro Santilli <strk at keybit.net>
+2006-02-24 12:19 Sandro Santilli <strk at kbt.io>
* [r1071] doc/Doxyfile.in: Fixed typo in config file
-2006-02-23 23:17 Sandro Santilli <strk at keybit.net>
+2006-02-23 23:17 Sandro Santilli <strk at kbt.io>
* [r1070] source/geom/Coordinate.cpp, source/geom/Envelope.cpp,
source/geom/GeometryFactory.cpp, source/geom/LineSegment.cpp,
@@ -20866,12 +22862,12 @@
file
- Misc cleanups
-2006-02-23 20:32 Sandro Santilli <strk at keybit.net>
+2006-02-23 20:32 Sandro Santilli <strk at kbt.io>
* [r1069] tests/xmltester/XMLTester.cpp: Added support for
LineMerge tests. Exception printed on stderr.
-2006-02-23 20:05 Sandro Santilli <strk at keybit.net>
+2006-02-23 20:05 Sandro Santilli <strk at kbt.io>
* [r1068] source/headers/geos/noding.h,
@@ -20882,12 +22878,12 @@
constructor making memory checker go crazy, more
doxygen-friendly comments, miscellaneous cleanups
-2006-02-23 20:03 Sandro Santilli <strk at keybit.net>
+2006-02-23 20:03 Sandro Santilli <strk at kbt.io>
* [r1067] doc/Doxyfile.in: updated to also show undocumented
methods
-2006-02-23 11:54 Sandro Santilli <strk at keybit.net>
+2006-02-23 11:54 Sandro Santilli <strk at kbt.io>
* [r1066] source/geom/MultiLineString.cpp,
source/geom/TopologyException.cpp, source/geom/Triangle.cpp,
@@ -20934,7 +22930,7 @@
- Added an XML test for snaprounding buffer (shows leaks, working
on it)
-2006-02-21 16:53 Sandro Santilli <strk at keybit.net>
+2006-02-21 16:53 Sandro Santilli <strk at kbt.io>
* [r1065] source/algorithm/MCPointInRing.cpp,
source/headers/geos/indexChain.h, source/headers/geos/noding.h,
@@ -20949,7 +22945,7 @@
MCIndexPointSnapper, MCIndexSnapRounder
-2006-02-20 21:04 Sandro Santilli <strk at keybit.net>
+2006-02-20 21:04 Sandro Santilli <strk at kbt.io>
* [r1064] source/headers/geos/geomgraph.h,
source/headers/geos/indexQuadtree.h,
@@ -20961,7 +22957,7 @@
source/index/strtree/STRtree.cpp: - namespace geos::index
- SpatialIndex interface synced
-2006-02-20 10:14 Sandro Santilli <strk at keybit.net>
+2006-02-20 10:14 Sandro Santilli <strk at kbt.io>
* [r1063] ChangeLog, doc/Doxyfile.in,
@@ -21010,7 +23006,7 @@
namespaces geos::index::*
- Doxygen documentation cleanup
-2006-02-19 19:46 Sandro Santilli <strk at keybit.net>
+2006-02-19 19:46 Sandro Santilli <strk at kbt.io>
* [r1062] NEWS, capi/geos_c.cpp, configure.in, doc/example.cpp,
@@ -21161,7 +23157,7 @@
for most GEOS internal code (uncomplete, but working). Dir-level
libs for index/ subdirs.
-2006-02-18 21:08 Sandro Santilli <strk at keybit.net>
+2006-02-18 21:08 Sandro Santilli <strk at kbt.io>
* [r1061] NEWS, source/geom/Geometry.cpp,
source/geomgraph/EdgeNodingValidator.cpp,
@@ -21190,17 +23186,17 @@
- Simplified internal interaces of OffsetCurveBuilder and
-2006-02-16 08:41 Sandro Santilli <strk at keybit.net>
+2006-02-16 08:41 Sandro Santilli <strk at kbt.io>
* [r1060] source/noding/NodingValidator.cpp: Fixed include:
"util.h" => "geos/util.h"
* [r1059] source/headers/geos/nodingSnapround.h: added <cmath>
include for round()
-2006-02-16 08:19 Sandro Santilli <strk at keybit.net>
+2006-02-16 08:19 Sandro Santilli <strk at kbt.io>
* [r1058] source/noding/IntersectionAdder.cpp: Missed from last
commit
@@ -21209,7 +23205,7 @@
* [r1057] capi/geos_c.h.in: added GEOSGeomType
-2006-02-15 17:19 Sandro Santilli <strk at keybit.net>
+2006-02-15 17:19 Sandro Santilli <strk at kbt.io>
* [r1056] NEWS, source/geomgraph/EdgeNodingValidator.cpp,
source/headers/geos/geom.h, source/headers/geos/geomgraph.h,
@@ -21218,7 +23214,7 @@
synced with JTS-1.7, added CoordinateSequence::operator[]
and size() to easy port maintainance.
-2006-02-15 14:59 Sandro Santilli <strk at keybit.net>
+2006-02-15 14:59 Sandro Santilli <strk at kbt.io>
* [r1055] source/headers/geos/noding.h,
source/noding/SegmentNode.cpp, source/noding/SegmentNodeList.cpp,
@@ -21227,7 +23223,7 @@
noding/SegmentString.cpp
-2006-02-14 13:28 Sandro Santilli <strk at keybit.net>
+2006-02-14 13:28 Sandro Santilli <strk at kbt.io>
* [r1054] NEWS, configure.in, source/algorithm/LineIntersector.cpp,
source/headers/geos/geosAlgorithm.h,
@@ -21260,7 +23256,7 @@
Buffer op optimized by using new snaprounding code.
Leaks fixed in XMLTester.
-2006-02-09 15:52 Sandro Santilli <strk at keybit.net>
+2006-02-09 15:52 Sandro Santilli <strk at kbt.io>
* [r1053] capi/geos_c.cpp, capi/geos_c.cpp.bak, configure.in,
doc/example.cpp, source/algorithm/CGAlgorithms.cpp,
@@ -21320,7 +23316,7 @@
* [r1051] capi/geos_c.cpp, capi/geos_c.h.in, capi/geostest.c: added
GEOSArea() to the C API
-2006-02-09 13:44 Sandro Santilli <strk at keybit.net>
+2006-02-09 13:44 Sandro Santilli <strk at kbt.io>
* [r1050] source/geom/Geometry.cpp, source/headers/geos/geom.h,
source/io/WKBReader.cpp: Added support for SRID in input WKB,
@@ -21332,7 +23328,7 @@
* [r1049] source/io/WKBReader.cpp: Botched last fix. Hopefully this
is better.
-2006-02-09 01:13 Sandro Santilli <strk at keybit.net>
+2006-02-09 01:13 Sandro Santilli <strk at kbt.io>
* [r1048] ChangeLog, source/operation/linemerge/LineSequencer.cpp:
Added missing <limits> include
@@ -21343,7 +23339,7 @@
consuming WKB for 'POLYGON EMPTY' with numRings==0.
http://bugzilla.remotesensing.org/show_bug.cgi?id=1064
-2006-02-08 17:18 Sandro Santilli <strk at keybit.net>
+2006-02-08 17:18 Sandro Santilli <strk at kbt.io>
* [r1046] NEWS, source/geom/Envelope.cpp, source/geom/Geometry.cpp,
source/geom/LineString.cpp, source/geom/MultiLineString.cpp,
@@ -21364,11 +23360,11 @@
- Obsoleted toInternalGeometry/fromInternalGeometry
- More const-correctness in Buffer "package"
-2006-02-08 13:07 Sandro Santilli <strk at keybit.net>
+2006-02-08 13:07 Sandro Santilli <strk at kbt.io>
* [r1045] NEWS: Added note about new LineSequencer class
-2006-02-08 12:59 Sandro Santilli <strk at keybit.net>
+2006-02-08 12:59 Sandro Santilli <strk at kbt.io>
* [r1044] source/headers/geos/geom.h,
@@ -21392,20 +23388,20 @@
- Added const versions of some planarDirectedEdgeStar methods.
- Added containers typedefs for planarDirectedEdgeStar
-2006-02-07 13:26 Sandro Santilli <strk at keybit.net>
+2006-02-07 13:26 Sandro Santilli <strk at kbt.io>
* [r1043] source/Makefile.am: Added missing geomgraph SUBDIR
-2006-02-07 12:02 Sandro Santilli <strk at keybit.net>
+2006-02-07 12:02 Sandro Santilli <strk at kbt.io>
* [r1042] tests/xmltester/Makefile.am: Removed TestConvexHull.xml
file (already included in testLeaksBig.xml
-2006-02-06 11:27 Sandro Santilli <strk at keybit.net>
+2006-02-06 11:27 Sandro Santilli <strk at kbt.io>
* [r1041] tests, tests/.cvsignore: new entry
-2006-02-05 17:14 Sandro Santilli <strk at keybit.net>
+2006-02-05 17:14 Sandro Santilli <strk at kbt.io>
* [r1040] NEWS, source/headers/geos/planargraph.h,
source/planargraph/Makefile.am, source/planargraph/algorithm,
@@ -21418,7 +23414,7 @@
- More iterators returning methods, inlining and cleanups
in planargraph.
-2006-02-04 00:54 Sandro Santilli <strk at keybit.net>
+2006-02-04 00:54 Sandro Santilli <strk at kbt.io>
* [r1039] ChangeLog, NEWS, source/headers/geos/geom.h,
@@ -21431,21 +23427,21 @@
- Renamed TESTS variable to XMLTESTS to not confuse 'make check'
rule
-2006-02-03 09:26 Sandro Santilli <strk at keybit.net>
+2006-02-03 09:26 Sandro Santilli <strk at kbt.io>
* [r1038] source/geom/util/ShortCircuitedGeometryVisitor.cpp: Added
missing file
-2006-02-02 02:20 Sandro Santilli <strk at keybit.net>
+2006-02-02 02:20 Sandro Santilli <strk at kbt.io>
* [r1037] source/geom/Polygon.cpp: Fixed bug in isRectangle()
failing to detect rectangles.
-2006-02-01 22:22 Sandro Santilli <strk at keybit.net>
+2006-02-01 22:22 Sandro Santilli <strk at kbt.io>
* [r1036] NEWS: updated
-2006-02-01 22:21 Sandro Santilli <strk at keybit.net>
+2006-02-01 22:21 Sandro Santilli <strk at kbt.io>
* [r1035] source/geom/Geometry.cpp, source/geom/Polygon.cpp,
source/geom/util/Makefile.am, source/headers/geos/geom.h,
@@ -21457,34 +23453,34 @@
rectangle-based optimizations of intersects() and contains() ops
- Inlined all planarGraphComponent class
-2006-01-31 21:42 Sandro Santilli <strk at keybit.net>
+2006-01-31 21:42 Sandro Santilli <strk at kbt.io>
* [r1034] source/Makefile.vc: Added DepthSegment object
-2006-01-31 21:36 Sandro Santilli <strk at keybit.net>
+2006-01-31 21:36 Sandro Santilli <strk at kbt.io>
* [r1033] swig/geos.i: Fixes error in calling read_hex from
scripting languages.
-2006-01-31 21:35 Sandro Santilli <strk at keybit.net>
+2006-01-31 21:35 Sandro Santilli <strk at kbt.io>
* [r1032] capi/Makefile.in: Erroneusly ended in CVS
-2006-01-31 21:17 Sandro Santilli <strk at keybit.net>
+2006-01-31 21:17 Sandro Santilli <strk at kbt.io>
* [r1031] source/operation/predicate/RectangleContains.cpp: Added
missing file from last commits
-2006-01-31 19:11 Sandro Santilli <strk at keybit.net>
+2006-01-31 19:11 Sandro Santilli <strk at kbt.io>
* [r1030] source/bigtest: Another left-over from cleanups
-2006-01-31 19:10 Sandro Santilli <strk at keybit.net>
+2006-01-31 19:10 Sandro Santilli <strk at kbt.io>
* [r1029] source/capi, source/test: Removed leftover files in
obsoleted dirs
-2006-01-31 19:07 Sandro Santilli <strk at keybit.net>
+2006-01-31 19:07 Sandro Santilli <strk at kbt.io>
* [r1028] Makefile.am, NEWS, README, capi, capi/.cvsignore,
capi/Makefile.am, capi/Makefile.in, capi/geos_c.cpp,
@@ -21659,19 +23655,19 @@
* [r1026] ChangeLog, source/algorithm/LineIntersector.cpp: fixed up
some debug messages
-2006-01-30 16:55 Sandro Santilli <strk at keybit.net>
+2006-01-30 16:55 Sandro Santilli <strk at kbt.io>
* [r1025] macros/ac_python_devel.m4, swig/python/Makefile.am,
swig/python/example.py, swig/python/geos.pth,
swig/python/python.i, swig/ruby/test/geos_tests.rb: More patches
from Charlie Savage
-2006-01-27 08:58 Sandro Santilli <strk at keybit.net>
+2006-01-27 08:58 Sandro Santilli <strk at kbt.io>
* [r1024] configure.in: Python and Ruby build disable by default
(until we've properly tested it)
-2006-01-27 08:25 Sandro Santilli <strk at keybit.net>
+2006-01-27 08:25 Sandro Santilli <strk at kbt.io>
* [r1023] macros/ac_python_devel.m4, swig/python/Makefile.am,
swig/ruby/ruby.i: * Ruby - removes dependency on renames.i file
@@ -21684,89 +23680,89 @@
extension can
be built
-2006-01-22 22:48 Sandro Santilli <strk at keybit.net>
+2006-01-22 22:48 Sandro Santilli <strk at kbt.io>
* [r1022] TODO: Added Safe's performance improvement idea for
CoordinateSequence
-2006-01-21 16:11 Sandro Santilli <strk at keybit.net>
+2006-01-21 16:11 Sandro Santilli <strk at kbt.io>
* [r1021] NEWS: updated
-2006-01-21 16:08 Sandro Santilli <strk at keybit.net>
+2006-01-21 16:08 Sandro Santilli <strk at kbt.io>
* [r1020] source/io/ByteOrderValues.cpp: Fixed integer conversion
bug (ported from JTS-1.7).
Added last port information.
-2006-01-21 16:04 Sandro Santilli <strk at keybit.net>
+2006-01-21 16:04 Sandro Santilli <strk at kbt.io>
* [r1019] source/test/hexwkb.xml: Added endian specification to
case descriptions.
All tests are Little Endian, should add the same
tests with Big Endian format.
-2006-01-20 19:28 Sandro Santilli <strk at keybit.net>
+2006-01-20 19:28 Sandro Santilli <strk at kbt.io>
* [r1018] source/operation/overlay/PolygonBuilder.cpp: Updated port
information
-2006-01-20 19:21 Sandro Santilli <strk at keybit.net>
+2006-01-20 19:21 Sandro Santilli <strk at kbt.io>
* [r1017] source/operation/overlay/PolygonBuilder.cpp: Fixed bug
#13
-2006-01-20 19:11 Sandro Santilli <strk at keybit.net>
+2006-01-20 19:11 Sandro Santilli <strk at kbt.io>
* [r1016] source/operation/valid/IsValidOp.cpp,
source/operation/valid/TopologyValidationError.cpp: Updated last
port info
-2006-01-20 17:20 Sandro Santilli <strk at keybit.net>
+2006-01-20 17:20 Sandro Santilli <strk at kbt.io>
* [r1015] configure.in, macros/ruby.m4, swig/python/Makefile.am,
swig/ruby/Makefile.am, swig/ruby/example.rb, swig/ruby/renames.i,
swig/ruby/test/Makefile.am, swig/ruby/test/example.rb,
swig/ruby/test/test_envelope.rb: More SWIG/python/ruby patches
-2006-01-20 00:59 Sandro Santilli <strk at keybit.net>
+2006-01-20 00:59 Sandro Santilli <strk at kbt.io>
* [r1014] source/io/WKBReader.cpp: Better debugging
* [r1013] source/test/hexwkb.xml: PrecisionModel made FLOATING
-2006-01-18 17:49 Sandro Santilli <strk at keybit.net>
+2006-01-18 17:49 Sandro Santilli <strk at kbt.io>
* [r1012] source/test/XMLTester.cpp, source/test/XMLTester.h:
Reworked XMLTester to be quiet by default. Use -v switch to make
it verbose.
-2006-01-18 17:47 Sandro Santilli <strk at keybit.net>
+2006-01-18 17:47 Sandro Santilli <strk at kbt.io>
* [r1011] source/test/hexwkb.xml: Added GEOMETRYCOLLECTION test
* [r1010] source/test/Makefile.am: Added another local test to the
test rule
-2006-01-18 17:46 Sandro Santilli <strk at keybit.net>
+2006-01-18 17:46 Sandro Santilli <strk at kbt.io>
* [r1009] source/io/WKTWriter.cpp: Fixed leak in
::writeFormatted(Geometry *)
-2006-01-18 17:45 Sandro Santilli <strk at keybit.net>
+2006-01-18 17:45 Sandro Santilli <strk at kbt.io>
* [r1008] source/io/WKBReader.cpp: more debugging lines
-2006-01-18 13:23 Sandro Santilli <strk at keybit.net>
+2006-01-18 13:23 Sandro Santilli <strk at kbt.io>
* [r1007] source/io/WKBReader.cpp: Set binary flag for stringstream
used in ::readHEX()
-2006-01-18 12:54 Sandro Santilli <strk at keybit.net>
+2006-01-18 12:54 Sandro Santilli <strk at kbt.io>
* [r1006] source/test/Makefile.am, source/test/XMLTester.cpp,
source/test/XMLTester.h, source/test/hexwkb.xml: Added HEXWKB
@@ -21774,11 +23770,11 @@
and a 'test' rule running the locally-available tests and showing
result summay.
-2006-01-18 10:02 Sandro Santilli <strk at keybit.net>
+2006-01-18 10:02 Sandro Santilli <strk at kbt.io>
* [r1005] macros/ac_python_devel.m4: Added missing macro file
-2006-01-17 12:03 Sandro Santilli <strk at keybit.net>
+2006-01-17 12:03 Sandro Santilli <strk at kbt.io>
* [r1004] configure.in, macros/ac_pkg_swig.m4: Modified
AC_PROG_SWIG macro to set SWIG to the empty string
@@ -21786,7 +23782,7 @@
SWIG version 1.3.28 or up required in order to build SWIG-based
extensions.
-2006-01-16 18:34 Sandro Santilli <strk at keybit.net>
+2006-01-16 18:34 Sandro Santilli <strk at kbt.io>
* [r1003] autogen.sh, configure.in, macros/ac_pkg_swig.m4,
macros/python.m4, swig/python, swig/python/.cvsignore,
@@ -21794,7 +23790,7 @@
swig/ruby/Makefile.am: Added initial conditional build of python
and ruby wrappers
-2006-01-15 23:01 Sandro Santilli <strk at keybit.net>
+2006-01-15 23:01 Sandro Santilli <strk at kbt.io>
* [r1001] NEWS, configure.in, swig/Makefile.am, swig/geos.i,
swig/ruby, swig/ruby/.cvsignore, swig/ruby/Makefile,
@@ -21803,7 +23799,7 @@
swig/ruby/test/Makefile.am: Added bare build/install/dist scripts
support for ruby interface
-2006-01-15 21:23 Sandro Santilli <strk at keybit.net>
+2006-01-15 21:23 Sandro Santilli <strk at kbt.io>
* [r1000] swig/ruby/test, swig/ruby/test/geos_tests.rb,
swig/ruby/test/test_combinations.rb,
@@ -21812,32 +23808,32 @@
swig/ruby/test/test_relations.rb, swig/ruby/test/test_simple.rb:
Initial import of ruby unit tests
-2006-01-15 21:22 Sandro Santilli <strk at keybit.net>
+2006-01-15 21:22 Sandro Santilli <strk at kbt.io>
* [r999] source/geom/Envelope.cpp, source/headers/geos/geom.h:
Added Envelope constructor by string (accepting what's returned
by ::toString)
-2006-01-15 21:19 Sandro Santilli <strk at keybit.net>
+2006-01-15 21:19 Sandro Santilli <strk at kbt.io>
* [r998] source/headers/geos/io.h, source/io/WKBReader.cpp,
source/io/WKBWriter.cpp: Added WKBWriter::writeHEX() and
WKBReader::readHEX()
-2006-01-12 11:44 Sandro Santilli <strk at keybit.net>
+2006-01-12 11:44 Sandro Santilli <strk at kbt.io>
* [r997] NEWS: synced after 2.2.1 release
* [r996] source/capi/geos_c.cpp: Removed double call to ::isValid
-2006-01-08 15:39 Sandro Santilli <strk at keybit.net>
+2006-01-08 15:39 Sandro Santilli <strk at kbt.io>
* [r994] source/capi/geos_c.cpp: Changed finite() function call
with FINITE() macro.
-2006-01-08 15:24 Sandro Santilli <strk at keybit.net>
+2006-01-08 15:24 Sandro Santilli <strk at kbt.io>
* [r993] source/geomgraph/EdgeIntersectionList.cpp,
source/geomgraph/GeometryGraph.cpp, source/geomgraph/NodeMap.cpp,
@@ -21854,30 +23850,30 @@
defined M_PI when undef as suggested by Charlie Savage.
Removed <stdio.h> include from GeometricShapeFactory.cpp.
-2005-12-22 12:46 Sandro Santilli <strk at keybit.net>
+2005-12-22 12:46 Sandro Santilli <strk at kbt.io>
* [r992] swig/README.txt, swig/geos.i, swig/ruby,
swig/ruby/Makefile, swig/ruby/README.txt, swig/ruby/example.rb,
swig/ruby/renames.i, swig/ruby/ruby.i: Imported Charlie Savage
new ruby wrapper and swig changes
-2005-12-14 11:22 Sandro Santilli <strk at keybit.net>
+2005-12-14 11:22 Sandro Santilli <strk at kbt.io>
* [r991] HOWTO_RELEASE: Added a note about the need to *always*
increment CAPI version
-2005-12-14 02:32 Sandro Santilli <strk at keybit.net>
+2005-12-14 02:32 Sandro Santilli <strk at kbt.io>
* [r990] HOWTO_RELEASE, source/algorithm/ConvexHull.cpp: New entry
-2005-12-13 23:59 Sandro Santilli <strk at keybit.net>
+2005-12-13 23:59 Sandro Santilli <strk at kbt.io>
* [r989] source/capi/geos_c.h.in: Removed INTERFACE_* defines
(obsoleted).
Made GEOSCoordSeq_clone() arg const (won't change ABI, it's C
world, lucky ;)
-2005-12-13 23:03 Sandro Santilli <strk at keybit.net>
+2005-12-13 23:03 Sandro Santilli <strk at kbt.io>
* [r988] source/capi/geos_c.cpp: Removed conditional blocks based
on GEOS version (we're always
@@ -21885,7 +23881,7 @@
INTERFACE_LAST
and INTERFACE_CURREN were taken off geos/version.h
-2005-12-12 09:32 Sandro Santilli <strk at keybit.net>
+2005-12-12 09:32 Sandro Santilli <strk at kbt.io>
* [r987] configure.in, source/geom/Makefile.am,
source/headers/geos/version.h.in: Switched to -release mode for
@@ -21894,47 +23890,47 @@
Removed GEOS_FIRST_INTERFACE and GEOS_LAST_INTERFACE defines
from geos/version.h.
-2005-12-11 10:41 Sandro Santilli <strk at keybit.net>
+2005-12-11 10:41 Sandro Santilli <strk at kbt.io>
* [r984] source/operation/overlay/ElevationMatrix.cpp,
premature initialization of average Z value in
-2005-12-11 10:38 Sandro Santilli <strk at keybit.net>
+2005-12-11 10:38 Sandro Santilli <strk at kbt.io>
* [r983] configure.in: Fixed mungled versions (1.0.0/3.0.1 =>
1.0.1/3.0.0)
-2005-12-10 16:07 Sandro Santilli <strk at keybit.net>
+2005-12-10 16:07 Sandro Santilli <strk at kbt.io>
* [r981] source/capi/geos_c.cpp: Unkown -> Unknown typo fix
-2005-12-09 13:24 Sandro Santilli <strk at keybit.net>
+2005-12-09 13:24 Sandro Santilli <strk at kbt.io>
* [r980] configure.in: Capi lib version set to 1.0.1 (due to leak
fix in GEOSHasZ)
-2005-12-09 11:36 Sandro Santilli <strk at keybit.net>
+2005-12-09 11:36 Sandro Santilli <strk at kbt.io>
* [r977] NEWS, source/capi/geos_c.cpp,
source/operation/polygonize/PolygonizeGraph.cpp: Small leak
plugged in CAPI::GEOSHasZ() and in
invalid input to PolygonizeGraph (again)
-2005-12-09 10:32 Sandro Santilli <strk at keybit.net>
+2005-12-09 10:32 Sandro Santilli <strk at kbt.io>
* [r974] source/operation/polygonize/Polygonizer.cpp: Cleaned up
debugging line left over from previous commit
-2005-12-09 10:03 Sandro Santilli <strk at keybit.net>
+2005-12-09 10:03 Sandro Santilli <strk at kbt.io>
* [r972] NEWS, source/operation/polygonize/PolygonizeGraph.cpp,
source/operation/polygonize/Polygonizer.cpp: Fixed a bug making
PolygonizeGraph choking on invalid LineStrings.
Minor optimizations in Polygonizer loops.
-2005-12-08 14:14 Sandro Santilli <strk at keybit.net>
+2005-12-08 14:14 Sandro Santilli <strk at kbt.io>
* [r971] NEWS, source/geom/DefaultCoordinateSequence.cpp,
source/geom/GeometryCollection.cpp, source/geom/LineString.cpp,
@@ -21952,7 +23948,7 @@
Changed CoordinateFilter::filter_rw to be a const method: updated
all apply_rw() methods to take a const CoordinateFilter.
-2005-12-08 01:39 Sandro Santilli <strk at keybit.net>
+2005-12-08 01:39 Sandro Santilli <strk at kbt.io>
* [r970] NEWS, source/headers/geos/noding.h,
source/noding/Noder.cpp, source/noding/SegmentString.cpp:
@@ -21960,17 +23956,17 @@
Adde getter for const and non-const references of it (dropping
get by pointer)
-2005-12-08 01:11 Sandro Santilli <strk at keybit.net>
+2005-12-08 01:11 Sandro Santilli <strk at kbt.io>
* [r969] source/geomgraph/EdgeIntersectionList.cpp: minor
optimizations in loops
-2005-12-08 00:24 Sandro Santilli <strk at keybit.net>
+2005-12-08 00:24 Sandro Santilli <strk at kbt.io>
* [r968] source/geomgraph/EdgeIntersectionList.cpp: Reduced
coordinate assignments in ::createSplitEdge
-2005-12-08 00:03 Sandro Santilli <strk at keybit.net>
+2005-12-08 00:03 Sandro Santilli <strk at kbt.io>
* [r967] NEWS, source/headers/geos/opOverlay.h,
source/operation/overlay/LineBuilder.cpp:
@@ -21979,12 +23975,12 @@
Small optimizations in LineBuilder loops, cleanups in LineBuilder
class dox.
-2005-12-07 23:36 Sandro Santilli <strk at keybit.net>
+2005-12-07 23:36 Sandro Santilli <strk at kbt.io>
* [r966] source/geomgraph/EdgeIntersection.cpp: standard
indentation
-2005-12-07 22:52 Sandro Santilli <strk at keybit.net>
+2005-12-07 22:52 Sandro Santilli <strk at kbt.io>
* [r965] NEWS, source/geom/DefaultCoordinateSequence.cpp,
source/geom/LineString.cpp, source/headers/geos/geom.h: Added
@@ -21995,30 +23991,30 @@
Undefined PROFILE_COORDINATE_COPIES (erroneously left defined by
previous commit)
-2005-12-07 21:55 Sandro Santilli <strk at keybit.net>
+2005-12-07 21:55 Sandro Santilli <strk at kbt.io>
* [r964] source/geom/CoordinateSequence.cpp: Optimized memory
allocations in ::removeRepeatedPoints
-2005-12-07 20:52 Sandro Santilli <strk at keybit.net>
+2005-12-07 20:52 Sandro Santilli <strk at kbt.io>
* [r963] source/geomgraph/GeometryGraph.cpp: minor container
methods call reduction
-2005-12-07 20:51 Sandro Santilli <strk at keybit.net>
+2005-12-07 20:51 Sandro Santilli <strk at kbt.io>
* [r962] source/geomgraph/EdgeEndStar.cpp: removed dead code
* [r961] source/geomgraph/DirectedEdgeStar.cpp: minor cleanups
-2005-12-07 20:49 Sandro Santilli <strk at keybit.net>
+2005-12-07 20:49 Sandro Santilli <strk at kbt.io>
* [r960] source/geomgraph/Edge.cpp: Oops, removed Coordinate copies
introduced by recent code cleanups
-2005-12-07 19:18 Sandro Santilli <strk at keybit.net>
+2005-12-07 19:18 Sandro Santilli <strk at kbt.io>
* [r959] NEWS, source/geomgraph/EdgeList.cpp,
source/geomgraph/PlanarGraph.cpp, source/headers/geos/geom.h,
@@ -22031,69 +24027,69 @@
Optimized polygon vector allocations in
OverlayOp::computeOverlay.
-2005-12-06 10:24 Sandro Santilli <strk at keybit.net>
+2005-12-06 10:24 Sandro Santilli <strk at kbt.io>
* [r958] Makefile.am, NEWS, configure.in, source/capi/Makefile.am,
source/geom/Makefile.am: Added acsite.m4 to distribution.
Added macros and flags required to build on mingw arch.
-2005-11-30 16:07 Sandro Santilli <strk at keybit.net>
+2005-11-30 16:07 Sandro Santilli <strk at kbt.io>
* [r955] source/capi, source/capi/.cvsignore: Added geos_c.h
-2005-11-30 16:03 Sandro Santilli <strk at keybit.net>
+2005-11-30 16:03 Sandro Santilli <strk at kbt.io>
* [r951] tools/geos-config.in: Added --ldflags
-2005-11-30 16:01 Sandro Santilli <strk at keybit.net>
+2005-11-30 16:01 Sandro Santilli <strk at kbt.io>
* [r949] README: Updated with C-API usage
-2005-11-30 11:27 Sandro Santilli <strk at keybit.net>
+2005-11-30 11:27 Sandro Santilli <strk at kbt.io>
* [r945] doc/example.cpp: catch std::exception by ref
-2005-11-30 11:25 Sandro Santilli <strk at keybit.net>
+2005-11-30 11:25 Sandro Santilli <strk at kbt.io>
* [r944] doc/example.cpp: includes cleanup
-2005-11-29 23:01 Sandro Santilli <strk at keybit.net>
+2005-11-29 23:01 Sandro Santilli <strk at kbt.io>
* [r942] NEWS: updated moving some items to 2.2.0
-2005-11-29 15:45 Sandro Santilli <strk at keybit.net>
+2005-11-29 15:45 Sandro Santilli <strk at kbt.io>
* [r936] source/geomgraph/TopologyLocation.cpp,
source/headers/geos/geomgraph.h: Fixed signedness of
TopologyLocation methods, cleanups.
-2005-11-29 15:16 Sandro Santilli <strk at keybit.net>
+2005-11-29 15:16 Sandro Santilli <strk at kbt.io>
* [r935] ChangeLog, source/algorithm/MinimumDiameter.cpp,
source/headers/geos/geosAlgorithm.h: Fixed sign-related warnings
and signatures.
-2005-11-29 14:49 Sandro Santilli <strk at keybit.net>
+2005-11-29 14:49 Sandro Santilli <strk at kbt.io>
* [r934] NEWS: More info
-2005-11-29 14:44 Sandro Santilli <strk at keybit.net>
+2005-11-29 14:44 Sandro Santilli <strk at kbt.io>
* [r933] NEWS: Updated
-2005-11-29 14:39 Sandro Santilli <strk at keybit.net>
+2005-11-29 14:39 Sandro Santilli <strk at kbt.io>
* [r932] source/geomgraph/Edge.cpp,
source/headers/geos/geomgraph.h: Removed number of points cache
in Edge, replaced with local caches.
* [r931] source/geom/CoordinateSequence.cpp,
source/geom/DefaultCoordinateSequence.cpp: More signed/unsigned
fixes
-2005-11-29 13:39 Sandro Santilli <strk at keybit.net>
+2005-11-29 13:39 Sandro Santilli <strk at kbt.io>
* [r930] source/headers/geos/geom.h, source/headers/geos/io.h:
Moved byte typedef from geom.h to io.h.
@@ -22101,11 +24097,11 @@
Changed CoordinateSequenceFactory::create(siz,dims) to use
unsigned for dims.
-2005-11-29 11:18 Sandro Santilli <strk at keybit.net>
+2005-11-29 11:18 Sandro Santilli <strk at kbt.io>
* [r929] NEWS: organized changes info
-2005-11-29 00:48 Sandro Santilli <strk at keybit.net>
+2005-11-29 00:48 Sandro Santilli <strk at kbt.io>
* [r928] source/geomgraph/DirectedEdgeStar.cpp,
source/geomgraph/EdgeEndStar.cpp, source/geomgraph/Node.cpp,
@@ -22118,22 +24114,22 @@
abstraction
with scoped typedefs.
-2005-11-28 18:37 Sandro Santilli <strk at keybit.net>
+2005-11-28 18:37 Sandro Santilli <strk at kbt.io>
* [r927] source/geom/LineString.cpp: Minor warning removal
-2005-11-25 12:22 Sandro Santilli <strk at keybit.net>
+2005-11-25 12:22 Sandro Santilli <strk at kbt.io>
* [r926] NEWS, source/test/XMLTester.cpp, source/test/XMLTester.h:
Made XMLTester able to run multiple test files and keep overall
counters.
-2005-11-25 11:40 Sandro Santilli <strk at keybit.net>
+2005-11-25 11:40 Sandro Santilli <strk at kbt.io>
* [r925] source/precision/SimpleGeometryPrecisionReducer.cpp:
Another getSize in for loop, another int-unsigned int warning
-2005-11-25 11:31 Sandro Santilli <strk at keybit.net>
+2005-11-25 11:31 Sandro Santilli <strk at kbt.io>
* [r924] source/algorithm/InteriorPointArea.cpp,
source/noding/NodingValidator.cpp, source/noding/SimpleNoder.cpp,
@@ -22147,34 +24143,34 @@
source/operation/valid/RepeatedPointTester.cpp: Removed all
CoordinateSequence::getSize() calls embedded in for loops.
-2005-11-25 11:30 Sandro Santilli <strk at keybit.net>
+2005-11-25 11:30 Sandro Santilli <strk at kbt.io>
* [r923] source/geomgraph/Edge.cpp: Fix in ::equals() - this
finally passes testLeaksBig.xml tests
-2005-11-25 09:57 Sandro Santilli <strk at keybit.net>
+2005-11-25 09:57 Sandro Santilli <strk at kbt.io>
* [r922] source/geom/GeometryCollection.cpp: Fixed bug in
getCoordinates() [ introduced by previous commit ]
-2005-11-24 23:43 Sandro Santilli <strk at keybit.net>
+2005-11-24 23:43 Sandro Santilli <strk at kbt.io>
* [r921] source/geomgraph/Edge.cpp,
source/headers/geos/geomgraph.h: Yes another fix, sorry. Missing
const-correctness.
-2005-11-24 23:24 Sandro Santilli <strk at keybit.net>
+2005-11-24 23:24 Sandro Santilli <strk at kbt.io>
* [r920] source/geomgraph/Edge.cpp,
source/headers/geos/geomgraph.h: Fixed equals() function [
optimized in previous commit, but unchecked ]
* [r919] NEWS: Added note about CoordinateSequence signed->unsigned
change in API
-2005-11-24 23:09 Sandro Santilli <strk at keybit.net>
+2005-11-24 23:09 Sandro Santilli <strk at kbt.io>
* [r918] source/algorithm/CGAlgorithms.cpp,
@@ -22197,14 +24193,14 @@
to avoid calling getSize() in loops.
Update of all callers is not complete yet.
-2005-11-24 23:07 Sandro Santilli <strk at keybit.net>
+2005-11-24 23:07 Sandro Santilli <strk at kbt.io>
* [r917] source/algorithm/CentroidLine.cpp,
source/headers/geos/geosAlgorithm.h: CentroidLine made concrete
class (only destructor was virtual) - avoided heap allocation for
owned Coordinate centSum
-2005-11-21 16:03 Sandro Santilli <strk at keybit.net>
+2005-11-21 16:03 Sandro Santilli <strk at kbt.io>
* [r916] source/algorithm/CentroidArea.cpp,
source/algorithm/ConvexHull.cpp,
@@ -22272,7 +24268,7 @@
storage. LineIntersector changed to reflect
the above change.
-2005-11-18 00:55 Sandro Santilli <strk at keybit.net>
+2005-11-18 00:55 Sandro Santilli <strk at kbt.io>
* [r915] source/geomgraph/EdgeRing.cpp,
source/headers/geos/geomgraph.h, source/headers/geos/opOverlay.h,
@@ -22289,7 +24285,7 @@
Removed heap allocations for EdgeRing containers.
Initialization lists and cleanups.
-2005-11-16 22:21 Sandro Santilli <strk at keybit.net>
+2005-11-16 22:21 Sandro Santilli <strk at kbt.io>
* [r913] source/geomgraph/EdgeEnd.cpp,
source/geomgraph/EdgeIntersection.cpp,
@@ -22299,7 +24295,7 @@
source/operation/valid/IsValidOp.cpp: enforced const-correctness
and use of initializer lists.
-2005-11-16 15:49 Sandro Santilli <strk at keybit.net>
+2005-11-16 15:49 Sandro Santilli <strk at kbt.io>
* [r912] source/geomgraph/Edge.cpp,
@@ -22315,7 +24311,7 @@
source/operation/valid/IsValidOp.cpp: Reduced gratuitous heap
allocations.
-2005-11-15 18:30 Sandro Santilli <strk at keybit.net>
+2005-11-15 18:30 Sandro Santilli <strk at kbt.io>
* [r911] source/algorithm/LineIntersector.cpp,
@@ -22323,7 +24319,7 @@
source/headers/geos/geosAlgorithm.h: Removed dead code
-2005-11-15 12:14 Sandro Santilli <strk at keybit.net>
+2005-11-15 12:14 Sandro Santilli <strk at kbt.io>
* [r909] source/headers/geos/opOverlay.h,
source/headers/geos/opPolygonize.h,
@@ -22342,7 +24338,7 @@
allocations, made use of references when appropriate,
small optimizations here and there.
-2005-11-15 10:04 Sandro Santilli <strk at keybit.net>
+2005-11-15 10:04 Sandro Santilli <strk at kbt.io>
* [r908] source/geomgraph/index/MonotoneChain.cpp,
source/geomgraph/index/MonotoneChainEdge.cpp,
@@ -22356,12 +24352,12 @@
Enforced const-correctness, changed some interfaces
to use references rather then pointers when appropriate.
-2005-11-15 10:02 Sandro Santilli <strk at keybit.net>
+2005-11-15 10:02 Sandro Santilli <strk at kbt.io>
* [r907] source/geom/LineString.cpp: optimized envelope computation
reducing virtual calls
-2005-11-14 18:14 Sandro Santilli <strk at keybit.net>
+2005-11-14 18:14 Sandro Santilli <strk at kbt.io>
* [r906] source/geomgraph/Depth.cpp,
@@ -22378,12 +24374,12 @@
Enforced const-correctness on GraphComponent.
Cleanups.
-2005-11-10 16:26 Sandro Santilli <strk at keybit.net>
+2005-11-10 16:26 Sandro Santilli <strk at kbt.io>
* [r904] source/io/WKBReader.cpp: Fixed printHEX (was printing one
char past the WKB)
-2005-11-10 15:20 Sandro Santilli <strk at keybit.net>
+2005-11-10 15:20 Sandro Santilli <strk at kbt.io>
* [r903] source/headers/geos/geomUtil.h,
@@ -22391,43 +24387,43 @@
source/headers/geos/indexStrtree.h, source/headers/geos/noding.h,
source/headers/geos/precision.h: Made virtual overloads explicit.
-2005-11-10 10:47 Sandro Santilli <strk at keybit.net>
+2005-11-10 10:47 Sandro Santilli <strk at kbt.io>
* [r902] source/geom/MultiPoint.cpp, source/headers/geos/geom.h:
Renamed MultiPoint::getCoordinate(int) to
MultiPoint::getCoordinateN(int)
to avoid hiding of Geometry::getCoordinate().
-2005-11-10 10:24 Sandro Santilli <strk at keybit.net>
+2005-11-10 10:24 Sandro Santilli <strk at kbt.io>
* [r901] source/headers/geos/util.h,
source/util/CoordinateArrayFiter.cpp: Fixed virtual overload of
CoordinateArrayFilter::filter*
-2005-11-10 09:33 Sandro Santilli <strk at keybit.net>
+2005-11-10 09:33 Sandro Santilli <strk at kbt.io>
* [r900] source/geom/LineString.cpp, source/headers/geos/geom.h:
Removed virtual overloading LineString::compareTo(LineString *)
-2005-11-09 15:14 Sandro Santilli <strk at keybit.net>
+2005-11-09 15:14 Sandro Santilli <strk at kbt.io>
* [r899] source/operation/buffer/DepthSegment.cpp: Forgot to add
this
-2005-11-09 13:44 Sandro Santilli <strk at keybit.net>
+2005-11-09 13:44 Sandro Santilli <strk at kbt.io>
* [r898] source/geomgraph/Node.cpp, source/geomgraph/NodeMap.cpp,
source/headers/geos/geomgraph.h: Cleanups in Node and NodeMap.
Optimization of EdgeIntersectionLessThen.
-2005-11-09 08:57 Sandro Santilli <strk at keybit.net>
+2005-11-09 08:57 Sandro Santilli <strk at kbt.io>
* [r897] source/geom/IntersectionMatrix.cpp,
source/headers/geos/geom.h: IntersectionMatrix made a concrete
and final type.
Cleanups in class definition.
-2005-11-08 20:12 Sandro Santilli <strk at keybit.net>
+2005-11-08 20:12 Sandro Santilli <strk at kbt.io>
* [r896] NEWS, source/geom/Makefile.am, source/headers/geos/geom.h,
@@ -22435,20 +24431,20 @@
source/operation/buffer/SubgraphDepthLocater.cpp: Memory overhead
reductions in buffer operations.
-2005-11-08 12:32 Sandro Santilli <strk at keybit.net>
+2005-11-08 12:32 Sandro Santilli <strk at kbt.io>
* [r895] source/geom/DefaultCoordinateSequence.cpp: Cleanups,
::setPoint small improvement
-2005-11-08 11:33 Sandro Santilli <strk at keybit.net>
+2005-11-08 11:33 Sandro Santilli <strk at kbt.io>
* [r894] source/operation/overlay/OverlayOp.cpp: comments cleanup
-2005-11-08 10:26 Sandro Santilli <strk at keybit.net>
+2005-11-08 10:26 Sandro Santilli <strk at kbt.io>
* [r893] configure.in: Library versioning took back to 3.0.0
-2005-11-08 10:03 Sandro Santilli <strk at keybit.net>
+2005-11-08 10:03 Sandro Santilli <strk at kbt.io>
* [r892] configure.in, doc/Doxyfile.in, source/geom/Envelope.cpp,
source/geom/Geometry.cpp, source/headers/geos/geom.h: Set library
@@ -22457,12 +24453,12 @@
Inlined more Envelope methods.
Dropped deprecated Envelope::overlaps methods.
-2005-11-07 18:07 Sandro Santilli <strk at keybit.net>
+2005-11-07 18:07 Sandro Santilli <strk at kbt.io>
* [r890] configure.in: Removed VisualStudio knowledge from
configure script
-2005-11-07 18:05 Sandro Santilli <strk at keybit.net>
+2005-11-07 18:05 Sandro Santilli <strk at kbt.io>
* [r889] source/geomgraph/EdgeIntersectionList.cpp,
source/headers/geos/noding.h, source/noding/SegmentNodeList.cpp:
@@ -22480,7 +24476,7 @@
* [r886] VisualStudio/.cvsignore: obsolete
-2005-11-07 12:31 Sandro Santilli <strk at keybit.net>
+2005-11-07 12:31 Sandro Santilli <strk at kbt.io>
* [r885] NEWS, source/geomgraph/Edge.cpp,
@@ -22499,24 +24495,24 @@
to avoid dynamic allocation of initial header.
Inlined short SweepLineEvent methods.
-2005-11-07 11:32 Sandro Santilli <strk at keybit.net>
+2005-11-07 11:32 Sandro Santilli <strk at kbt.io>
* [r884] source/capi/geos_c.h.in: Added const qualifiers to
function to reflect paradigm of immutable
Geometry objects.
-2005-11-04 15:42 Sandro Santilli <strk at keybit.net>
+2005-11-04 15:42 Sandro Santilli <strk at kbt.io>
* [r883] source/geomgraph/index/SweepLineEvent.cpp: Fixed bug in
SweepLineEventLessThen functor
(didn't conform to strict weak ordering).
Note: this was introduced by previous commit.
-2005-11-04 11:06 Sandro Santilli <strk at keybit.net>
+2005-11-04 11:06 Sandro Santilli <strk at kbt.io>
* [r882] NEWS: updated
-2005-11-04 11:04 Sandro Santilli <strk at keybit.net>
+2005-11-04 11:04 Sandro Santilli <strk at kbt.io>
* [r881] source/headers/geos/opValid.h,
@@ -22529,43 +24525,43 @@
rather then actual objects, to speedup NULL tests.
Added JTS port revision when applicable.
-2005-11-04 08:28 Sandro Santilli <strk at keybit.net>
+2005-11-04 08:28 Sandro Santilli <strk at kbt.io>
* [r880] NEWS, source/operation/overlay/OverlayOp.cpp: Ported
speedup of OverlayOp::insertUniqueEdge() from JTS-1.7 (rev 1.23)
Updated NEWS file.
-2005-11-03 21:28 Sandro Santilli <strk at keybit.net>
+2005-11-03 21:28 Sandro Santilli <strk at kbt.io>
* [r878] source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
source/geomgraph/index/SimpleSweepLineIntersector.cpp: Fixed
constructors broke by previous commit
-2005-11-03 19:51 Sandro Santilli <strk at keybit.net>
+2005-11-03 19:51 Sandro Santilli <strk at kbt.io>
* [r877] source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
source/geomgraph/index/SimpleSweepLineIntersector.cpp,
source/headers/geos/geomgraphindex.h: Indentation changes, small
vector memory allocation optimization.
-2005-11-03 09:15 Sandro Santilli <strk at keybit.net>
+2005-11-03 09:15 Sandro Santilli <strk at kbt.io>
* [r876] source/headers/geos/geom.h: Removed declaration of
PointCoordinateSequence and PointCoordinateSequenceFactory
-2005-11-01 09:40 Sandro Santilli <strk at keybit.net>
+2005-11-01 09:40 Sandro Santilli <strk at kbt.io>
* [r875] source/operation/valid/IsValidOp.cpp: Replaced finite()
with FINITE() calls.
-2005-10-27 14:05 Sandro Santilli <strk at keybit.net>
+2005-10-27 14:05 Sandro Santilli <strk at kbt.io>
* [r873] source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
source/headers/geos/geomgraphindex.h: Added a
SweepLineEventLessThen functor to be used by sort algorithm.
-2005-10-24 13:28 Sandro Santilli <strk at keybit.net>
+2005-10-24 13:28 Sandro Santilli <strk at kbt.io>
* [r872] source/capi/geos_c.cpp, source/capi/geos_c.h.in,
source/capi/geostest.c: Changed constructors to take ownership of
@@ -22574,23 +24570,23 @@
GEOSCoordSeq objects.
Added GEOSGeom_clone() method.
-2005-10-21 15:13 Sandro Santilli <strk at keybit.net>
+2005-10-21 15:13 Sandro Santilli <strk at kbt.io>
* [r871] source/capi/geos_c.cpp, source/capi/geos_c.h.in: Added
GEOSGeom_clone() function
-2005-10-21 12:14 Sandro Santilli <strk at keybit.net>
+2005-10-21 12:14 Sandro Santilli <strk at kbt.io>
* [r870] source/capi/geos_c.h.in: Added missing GEOS_DLL specifiers
-2005-10-21 12:07 Sandro Santilli <strk at keybit.net>
+2005-10-21 12:07 Sandro Santilli <strk at kbt.io>
* [r869] source/capi/geos_c.cpp, source/capi/geos_c.h.in,
source/capi/geostest.c: Added fine-grained geometry constructors
and GEOSCoordSeq abstract data type.
Renamed GEOSmakeCollection to GEOSGeom_createCollection
-2005-10-21 09:02 Sandro Santilli <strk at keybit.net>
+2005-10-21 09:02 Sandro Santilli <strk at kbt.io>
* [r868] configure.in: typo fixed
@@ -22632,45 +24628,45 @@
* [r859] source/headers/geos/platform.h.vc: added
getMachineByteOrder(), convert to unix text mode
-2005-10-19 13:07 Sandro Santilli <strk at keybit.net>
+2005-10-19 13:07 Sandro Santilli <strk at kbt.io>
* [r858] source/io/WKBReader.cpp: Added support for SRID flag in
WKB (full EWKB is accepted now)
-2005-10-19 12:59 Sandro Santilli <strk at keybit.net>
+2005-10-19 12:59 Sandro Santilli <strk at kbt.io>
* [r857] source/headers/geos/io.h: Added input stream checks in
ByteOrderDataInStream, throwing ParseException on unexpected EOF
-2005-10-17 15:55 Sandro Santilli <strk at keybit.net>
+2005-10-17 15:55 Sandro Santilli <strk at kbt.io>
* [r856] source/capi/geos_c.cpp, source/capi/geos_c.h.in: Added
GetGeometryN, GetInteriorRingN, GetExteriorRing
-2005-10-17 14:37 Sandro Santilli <strk at keybit.net>
+2005-10-17 14:37 Sandro Santilli <strk at kbt.io>
* [r855] source/capi/geos_c.h.in: Added comments on exception
returns for Geometry info functions
-2005-10-17 14:33 Sandro Santilli <strk at keybit.net>
+2005-10-17 14:33 Sandro Santilli <strk at kbt.io>
* [r854] source/capi/geos_c.cpp: Added missing exception handlers
from previous commit.
Fixed GEOSGeomTypeId signatures.
-2005-10-17 12:56 Sandro Santilli <strk at keybit.net>
+2005-10-17 12:56 Sandro Santilli <strk at kbt.io>
* [r853] source/geom/Makefile.am: Removed GEOS_VERSION define
(Geometry.cpp, the only file using this will use the one in
version.h)
-2005-10-17 12:55 Sandro Santilli <strk at keybit.net>
+2005-10-17 12:55 Sandro Santilli <strk at kbt.io>
* [r852] source/capi/geos_c.h.in: Fixed GEOSGeom typedef to be
accepted by C++ compilers, added extern "C" namespace for
inclusion by C++ code (really needed?)
-2005-10-17 09:38 Sandro Santilli <strk at keybit.net>
+2005-10-17 09:38 Sandro Santilli <strk at kbt.io>
* [r851] source/capi/geos_c.cpp, source/capi/geos_c.h.in,
source/capi/geostest.c: Added GEOSDistance() function.
@@ -22679,29 +24675,29 @@
Changed WKB functions to use 'unsigned char' rather then 'char'
Added missing GEOS_setWKBOutputDims() function in header file.
-2005-09-28 16:33 Sandro Santilli <strk at keybit.net>
+2005-09-28 16:33 Sandro Santilli <strk at kbt.io>
* [r850] source/capi/geos_c.cpp: Added GEOS_setWKBOutputDims(int)
function to specify coordinate
dimension in WKB output.
-2005-09-28 10:15 Sandro Santilli <strk at keybit.net>
+2005-09-28 10:15 Sandro Santilli <strk at kbt.io>
* [r849] source/headers/geos/io.h, source/io/WKBWriter.cpp:
WKBWriter ctor out-lined (will require changes in the near
future, for higher dimensions support), added support for 3d WKB
output
-2005-09-28 09:36 Sandro Santilli <strk at keybit.net>
+2005-09-28 09:36 Sandro Santilli <strk at kbt.io>
* [r848] source/io/WKBReader.cpp: Cleanups in the printHEX function
-2005-09-27 16:29 Sandro Santilli <strk at keybit.net>
+2005-09-27 16:29 Sandro Santilli <strk at kbt.io>
* [r847] source/io/WKBReader.cpp: Ported JTS-1.7 use of
PrecisionModel in WKBReader
-2005-09-27 16:20 Sandro Santilli <strk at keybit.net>
+2005-09-27 16:20 Sandro Santilli <strk at kbt.io>
* [r846] doc/example.cpp, source/capi/geos_c.cpp,
source/headers/geos/io.h, source/io/WKBReader.cpp: Reverted
@@ -22712,7 +24708,7 @@
breaking
ABI is not a big deal at this stage).
-2005-09-27 16:00 Sandro Santilli <strk at keybit.net>
+2005-09-27 16:00 Sandro Santilli <strk at kbt.io>
* [r845] doc/example.cpp, source/capi/geos_c.cpp,
source/headers/geos/io.h, source/io/WKBReader.cpp: Fixed bug in
@@ -22721,22 +24717,22 @@
GeometryFactory
pointer parameter.
-2005-09-27 08:51 Sandro Santilli <strk at keybit.net>
+2005-09-27 08:51 Sandro Santilli <strk at kbt.io>
* [r844] source/test/Makefile.am: Added XMLTester.h in
XMLTester_SOURCES list
-2005-09-26 14:40 Sandro Santilli <strk at keybit.net>
+2005-09-26 14:40 Sandro Santilli <strk at kbt.io>
* [r843] source/io/WKBReader.cpp: Fixed handling of higher
dimensional WKB streams
-2005-09-26 13:46 Sandro Santilli <strk at keybit.net>
+2005-09-26 13:46 Sandro Santilli <strk at kbt.io>
* [r842] source/capi/Makefile.am: Modified GEOS_CAPI_VERSION to
include underlying GEOS version
-2005-09-26 13:42 Sandro Santilli <strk at keybit.net>
+2005-09-26 13:42 Sandro Santilli <strk at kbt.io>
* [r841] configure.in, source/capi/Makefile.am,
source/capi/geos_c.cpp, source/capi/geos_c.h,
@@ -22744,7 +24740,7 @@
configure.in
Added version info in geos_c.h
-2005-09-26 12:25 Sandro Santilli <strk at keybit.net>
+2005-09-26 12:25 Sandro Santilli <strk at kbt.io>
* [r840] source/capi/geos_c.cpp, source/capi/geos_c.h,
source/capi/geostest.c: Changed LineMerge interface to accept a
@@ -22752,16 +24748,16 @@
the set of merger LineStrings. Fixed leaks in geostest, fixed a
leak in GEOSRelate().
-2005-09-26 12:23 Sandro Santilli <strk at keybit.net>
+2005-09-26 12:23 Sandro Santilli <strk at kbt.io>
* [r839] source/geom/PrecisionModel.cpp: Initializzation lists in
PrecisionModel ctors
-2005-09-26 11:04 Sandro Santilli <strk at keybit.net>
+2005-09-26 11:04 Sandro Santilli <strk at kbt.io>
* [r838] NEWS: Added changes in LineMerger
-2005-09-26 11:01 Sandro Santilli <strk at keybit.net>
+2005-09-26 11:01 Sandro Santilli <strk at kbt.io>
* [r837] source/headers/geos/opLinemerge.h,
source/operation/linemerge/EdgeString.cpp,
@@ -22770,27 +24766,27 @@
source/operation/linemerge/LineMerger.cpp: Const correctness
changes in LineMerger package, and a few speedups.
-2005-09-26 08:18 Sandro Santilli <strk at keybit.net>
+2005-09-26 08:18 Sandro Santilli <strk at kbt.io>
* [r836] source/capi, source/capi/.cvsignore: Added .lo, .la and
geostest
-2005-09-26 08:17 Sandro Santilli <strk at keybit.net>
+2005-09-26 08:17 Sandro Santilli <strk at kbt.io>
* [r835] doc/example.cpp: Removed memory leak from WKB tester
-2005-09-23 17:20 Sandro Santilli <strk at keybit.net>
+2005-09-23 17:20 Sandro Santilli <strk at kbt.io>
* [r834] source/headers/geos/opLinemerge.h,
source/operation/linemerge/LineMerger.cpp: Made LineMerger graph
be a real object (rather then a pointer to it)
-2005-09-23 16:07 Sandro Santilli <strk at keybit.net>
+2005-09-23 16:07 Sandro Santilli <strk at kbt.io>
* [r833] source/capi/geos_c.cpp: Fixed export of GEOSPolygonize()
and GEOSMakeCollection()
-2005-09-23 09:49 Sandro Santilli <strk at keybit.net>
+2005-09-23 09:49 Sandro Santilli <strk at kbt.io>
* [r832] source/capi/geos_c.cpp, source/capi/geos_c.h: Added
GEOSMakeCollection.
@@ -22798,28 +24794,28 @@
Centroid can be
computed (Empty input, for example).
-2005-09-19 08:16 Sandro Santilli <strk at keybit.net>
+2005-09-19 08:16 Sandro Santilli <strk at kbt.io>
* [r831] NEWS: Added C api
-2005-09-14 15:11 Sandro Santilli <strk at keybit.net>
+2005-09-14 15:11 Sandro Santilli <strk at kbt.io>
* [r830] source/capi/geos_c.h: Removed functions returning not-new
GEOSGeom objects to avoid ambiguity
whereas when to destroy returns. Added not about memory
management.
-2005-09-14 14:55 Sandro Santilli <strk at keybit.net>
+2005-09-14 14:55 Sandro Santilli <strk at kbt.io>
* [r829] source/capi/geos_c.cpp, source/capi/geos_c.h,
source/capi/geostest.c: Added copyright notices and usage notes
-2005-09-14 14:28 Sandro Santilli <strk at keybit.net>
+2005-09-14 14:28 Sandro Santilli <strk at kbt.io>
* [r828] source/io/WKBWriter.cpp: Fixed bug writing WKB for all
Multi* geoms as Collections.
-2005-09-14 13:58 Sandro Santilli <strk at keybit.net>
+2005-09-14 13:58 Sandro Santilli <strk at kbt.io>
* [r827] configure.in, source/Makefile.am, source/capi,
source/capi/.cvsignore, source/capi/Makefile.am,
@@ -22827,11 +24823,11 @@
source/capi/geostest.c, source/capi/test.wkt: Initial abstract C
api.
-2005-09-14 13:56 Sandro Santilli <strk at keybit.net>
+2005-09-14 13:56 Sandro Santilli <strk at kbt.io>
* [r826] source/io/WKBReader.cpp: Typo fixed
-2005-09-03 21:26 Sandro Santilli <strk at keybit.net>
+2005-09-03 21:26 Sandro Santilli <strk at kbt.io>
* [r825] doc/example.cpp, source/geom/Makefile.am,
source/headers/geos/ByteOrderDataInStreamT.h,
@@ -22841,11 +24837,11 @@
source/io/WKBReader.cpp, source/io/WKBWriter.cpp: Reworked WKB
I/O to avoid use of templates and make better use of STL
-2005-08-22 13:34 Sandro Santilli <strk at keybit.net>
+2005-08-22 13:34 Sandro Santilli <strk at kbt.io>
* [r822] NEWS: Added 2.1.4 section
-2005-08-22 13:31 Sandro Santilli <strk at keybit.net>
+2005-08-22 13:31 Sandro Santilli <strk at kbt.io>
* [r821] source/geom/Geometry.cpp,
source/operation/buffer/BufferBuilder.cpp,
@@ -22853,114 +24849,114 @@
functions used with STL sort() algorithm to
implement StrictWeakOrdering semantic.
-2005-07-12 14:33 Sandro Santilli <strk at keybit.net>
+2005-07-12 14:33 Sandro Santilli <strk at kbt.io>
* [r819] NEWS: updated
-2005-07-11 16:21 Sandro Santilli <strk at keybit.net>
+2005-07-11 16:21 Sandro Santilli <strk at kbt.io>
* [r818] source/headers/geos/ByteOrderDataInStreamT.h,
source/headers/geos/WKBReaderT.h,
source/headers/geos/WKBWriterT.h: Removed '_' prefix from header
guards
-2005-07-11 12:17 Sandro Santilli <strk at keybit.net>
+2005-07-11 12:17 Sandro Santilli <strk at kbt.io>
* [r817] source/headers/geos/io.h, source/headers/geos/opOverlay.h,
source/headers/geos/platform.h.in: Cleaned up syntax
* [r816] doc/example.cpp: Commented out useless include
-2005-07-11 10:50 Sandro Santilli <strk at keybit.net>
+2005-07-11 10:50 Sandro Santilli <strk at kbt.io>
* [r815] source/geom/Geometry.cpp: Added parens suggested by
compiler
-2005-07-11 10:27 Sandro Santilli <strk at keybit.net>
+2005-07-11 10:27 Sandro Santilli <strk at kbt.io>
* [r814] source/geomgraph/Edge.cpp,
source/headers/geos/WKBReaderT.h: Cleaned up signed/unsigned
mismatches
* [r813] source/geomgraph/DirectedEdge.cpp,
source/operation/buffer/BufferOp.cpp,
source/operation/buffer/SubgraphDepthLocater.cpp: Fixed
initializzazion lists
-2005-07-11 10:26 Sandro Santilli <strk at keybit.net>
+2005-07-11 10:26 Sandro Santilli <strk at kbt.io>
* [r812] source/headers/geos/geom.h: Made
CoordinateSequence::getDimension return unsigned int instead of
int
-2005-07-11 10:23 Sandro Santilli <strk at keybit.net>
+2005-07-11 10:23 Sandro Santilli <strk at kbt.io>
* [r811] source/geom/Geometry.cpp: removed useless assignment
-2005-06-30 18:31 Sandro Santilli <strk at keybit.net>
+2005-06-30 18:31 Sandro Santilli <strk at kbt.io>
* [r807] source/headers/geos/opBuffer.h,
source/operation/buffer/BufferSubgraph.cpp,
source/operation/buffer/SubgraphDepthLocater.cpp: Ported
SubgraphDepthLocator optimizations from JTS code
-2005-06-28 21:13 Sandro Santilli <strk at keybit.net>
+2005-06-28 21:13 Sandro Santilli <strk at kbt.io>
* [r803] source/operation/buffer/SubgraphDepthLocater.cpp: Fixed a
bug introduced by LineSegment skip - made LineSegment skip a
compile-time optione
-2005-06-28 16:52 Sandro Santilli <strk at keybit.net>
+2005-06-28 16:52 Sandro Santilli <strk at kbt.io>
* [r802] source/test/XMLTester.cpp: Added number of points count as
a debugging aid
-2005-06-28 11:22 Sandro Santilli <strk at keybit.net>
+2005-06-28 11:22 Sandro Santilli <strk at kbt.io>
* [r801] NEWS: Added DepthSegmentLT bugfix
-2005-06-28 01:07 Sandro Santilli <strk at keybit.net>
+2005-06-28 01:07 Sandro Santilli <strk at kbt.io>
* [r796] source/headers/geos/opOverlay.h,
source/operation/overlay/PointBuilder.cpp: improved extraction of
result points in overlay op
-2005-06-28 00:04 Sandro Santilli <strk at keybit.net>
+2005-06-28 00:04 Sandro Santilli <strk at kbt.io>
* [r794] source/geomgraph/Node.cpp: improved
::isIncidentEdgeInResult() method
-2005-06-27 21:58 Sandro Santilli <strk at keybit.net>
+2005-06-27 21:58 Sandro Santilli <strk at kbt.io>
* [r793] source/operation/buffer/SubgraphDepthLocater.cpp: Bugfix
in DepthSegmentLT as suggested by Graeme Hiebert
-2005-06-27 21:24 Sandro Santilli <strk at keybit.net>
+2005-06-27 21:24 Sandro Santilli <strk at kbt.io>
* [r790] source/operation/buffer/SubgraphDepthLocater.cpp: Fixed
bug just-introduced with optimization.
-2005-06-27 21:21 Sandro Santilli <strk at keybit.net>
+2005-06-27 21:21 Sandro Santilli <strk at kbt.io>
* [r789] NEWS, source/operation/buffer/SubgraphDepthLocater.cpp:
Reduced Coordinate copies due to LineSegment overuse
-2005-06-25 10:20 Sandro Santilli <strk at keybit.net>
+2005-06-25 10:20 Sandro Santilli <strk at kbt.io>
* [r787] NEWS, source/geomgraph/Node.cpp,
source/operation/overlay/PointBuilder.cpp: OverlayOp speedup (JTS
port)
-2005-06-24 11:12 Sandro Santilli <strk at keybit.net>
+2005-06-24 11:12 Sandro Santilli <strk at kbt.io>
* [r786] NEWS: Added LineIntersector concrete type note
-2005-06-24 11:09 Sandro Santilli <strk at keybit.net>
+2005-06-24 11:09 Sandro Santilli <strk at kbt.io>
* [r785] source/algorithm/CGAlgorithms.cpp,
@@ -22982,7 +24978,7 @@
to avoid computing intersection point (Z) when it's not
necessary.
-2005-06-23 14:22 Sandro Santilli <strk at keybit.net>
+2005-06-23 14:22 Sandro Santilli <strk at kbt.io>
* [r784] NEWS, source/geom/GeometryCollection.cpp,
source/geom/LineString.cpp, source/geom/LinearRing.cpp,
@@ -22990,66 +24986,66 @@
source/headers/geos/geom.h: Inlined and added missing ::clone()
for Geometry subclasses
-2005-06-23 11:23 Sandro Santilli <strk at keybit.net>
+2005-06-23 11:23 Sandro Santilli <strk at kbt.io>
* [r782] NEWS, source/algorithm/CGAlgorithms.cpp: performance
improvement for CGAlgorithms::isOnLine()
-2005-06-22 00:46 Sandro Santilli <strk at keybit.net>
+2005-06-22 00:46 Sandro Santilli <strk at kbt.io>
* [r779] NEWS, source/geom/Geometry.cpp: Shortcircuit tests for
Union
* [r777] source/geom/GeometryFactory.cpp: Fixed bugus handling of
collections in ::buildGeometry
-2005-06-21 12:22 Sandro Santilli <strk at keybit.net>
+2005-06-21 12:22 Sandro Santilli <strk at kbt.io>
* [r773] NEWS, source/test/XMLTester.cpp, source/test/XMLTester.h:
XMLTester code cleanups
-2005-06-20 10:23 Sandro Santilli <strk at keybit.net>
+2005-06-20 10:23 Sandro Santilli <strk at kbt.io>
* [r772] NEWS, source/test/Makefile.am: XMLTester installed by
default
-2005-06-17 15:17 Sandro Santilli <strk at keybit.net>
+2005-06-17 15:17 Sandro Santilli <strk at kbt.io>
* [r770] ., .cvsignore, ltmain.sh: Removed ltmain.sh from
repository, will be created by autogen.sh
-2005-06-17 15:08 Sandro Santilli <strk at keybit.net>
+2005-06-17 15:08 Sandro Santilli <strk at kbt.io>
* [r766] NEWS, source/operation/polygonize/Polygonizer.cpp,
source/operation/polygonize/polygonizeEdgeRing.cpp: Polygonizer
segfault fix
-2005-06-17 14:58 Sandro Santilli <strk at keybit.net>
+2005-06-17 14:58 Sandro Santilli <strk at kbt.io>
* [r764] source/geom/GeometryFactory.cpp: Fixed segfault in
LinearRing and LineString constructors
-2005-06-14 11:57 Sandro Santilli <strk at keybit.net>
+2005-06-14 11:57 Sandro Santilli <strk at kbt.io>
* [r761] NEWS, source/test/XMLTester.cpp: Added workaround for
mingw Polygon name clash
-2005-06-10 14:04 Sandro Santilli <strk at keybit.net>
+2005-06-10 14:04 Sandro Santilli <strk at kbt.io>
* [r760] autogen.sh: Added libtoolize call
-2005-06-10 13:24 Sandro Santilli <strk at keybit.net>
+2005-06-10 13:24 Sandro Santilli <strk at kbt.io>
* [r758] source/test/XMLTester.cpp: Added use declaration to make
MingW build work
-2005-06-08 09:38 Sandro Santilli <strk at keybit.net>
+2005-06-08 09:38 Sandro Santilli <strk at kbt.io>
* [r754] INSTALL: Added GCC version requirement note
-2005-06-05 10:41 Sandro Santilli <strk at keybit.net>
+2005-06-05 10:41 Sandro Santilli <strk at kbt.io>
* [r752] CHANGES, NEWS: Changes file renamed back to NEWS, automake
insists on finding it.
@@ -23058,54 +25054,54 @@
* [r750] NEWS: Blank news file to molfify new versions of autoconf
-2005-05-24 08:42 Sandro Santilli <strk at keybit.net>
+2005-05-24 08:42 Sandro Santilli <strk at kbt.io>
* [r749] NEWS: Info moved into CHANGES file
* [r748] CHANGES: Filled in section from 2.0.0 to 2.1.1
-2005-05-24 07:48 Sandro Santilli <strk at keybit.net>
+2005-05-24 07:48 Sandro Santilli <strk at kbt.io>
* [r744] CHANGES: Initial import
-2005-05-23 16:42 Sandro Santilli <strk at keybit.net>
+2005-05-23 16:42 Sandro Santilli <strk at kbt.io>
* [r728] source/geom/Point.cpp: Added Refractions copyright
-2005-05-23 15:13 Sandro Santilli <strk at keybit.net>
+2005-05-23 15:13 Sandro Santilli <strk at kbt.io>
* [r717] source/operation/buffer/BufferSubgraph.cpp,
source/operation/buffer/SubgraphDepthLocater.cpp: Added debugging
output
-2005-05-23 15:04 Sandro Santilli <strk at keybit.net>
+2005-05-23 15:04 Sandro Santilli <strk at kbt.io>
* [r716] source/geom/LineSegment.cpp: Fixed bug in ::reverse()
-2005-05-22 17:45 Sandro Santilli <strk at keybit.net>
+2005-05-22 17:45 Sandro Santilli <strk at kbt.io>
* [r715] source/operation/buffer/BufferSubgraph.cpp: Fixed
initialization list order
-2005-05-22 17:42 Sandro Santilli <strk at keybit.net>
+2005-05-22 17:42 Sandro Santilli <strk at kbt.io>
* [r714] ChangeLog, source/headers/geos/Makefile.am: Added missing
WKBWriterT.h
-2005-05-20 16:15 Sandro Santilli <strk at keybit.net>
+2005-05-20 16:15 Sandro Santilli <strk at kbt.io>
* [r713] source/geomgraph/Position.cpp,
source/operation/buffer/SubgraphDepthLocater.cpp: Code cleanups
-2005-05-20 16:14 Sandro Santilli <strk at keybit.net>
+2005-05-20 16:14 Sandro Santilli <strk at kbt.io>
* [r712] source/operation/buffer/OffsetCurveSetBuilder.cpp: Fixed a
bug in addPolygonRing setting wrong depths on Edges
-2005-05-19 10:29 Sandro Santilli <strk at keybit.net>
+2005-05-19 10:29 Sandro Santilli <strk at kbt.io>
* [r711] source/algorithm/CentroidArea.cpp,
source/geomgraph/DirectedEdge.cpp, source/geomgraph/EdgeEnd.cpp,
@@ -23131,41 +25127,41 @@
Inlined some smaller functions encountered during bug hunting.
Updated Copyright notices in the touched files.
-2005-05-19 10:26 Sandro Santilli <strk at keybit.net>
+2005-05-19 10:26 Sandro Santilli <strk at kbt.io>
* [r710] source/test/testLeaksBig.xml: Added bogus multipolygon
buffering test
-2005-05-13 18:06 Sandro Santilli <strk at keybit.net>
+2005-05-13 18:06 Sandro Santilli <strk at kbt.io>
* [r709] source/headers/geos/geom.h: Added default tolerance
parameter for equalsExact
-2005-05-13 17:15 Sandro Santilli <strk at keybit.net>
+2005-05-13 17:15 Sandro Santilli <strk at kbt.io>
* [r708] source/geom/Point.cpp: cleanups and indentations
-2005-05-13 17:14 Sandro Santilli <strk at keybit.net>
+2005-05-13 17:14 Sandro Santilli <strk at kbt.io>
* [r707] source/geom/Geometry.cpp: Added comment about 2D-only
comparison of ::equal(Coordinate, Coordinate, double)
-2005-05-09 21:17 Sandro Santilli <strk at keybit.net>
+2005-05-09 21:17 Sandro Santilli <strk at kbt.io>
* [r706] source/headers/geos/WKBWriterT.h: Second argument to
::write made mandatory.
-2005-05-09 10:35 Sandro Santilli <strk at keybit.net>
+2005-05-09 10:35 Sandro Santilli <strk at kbt.io>
* [r705] source/algorithm/RobustLineIntersector.cpp,
source/headers/geos/geosAlgorithm.h: Ported JTS robustness
patches made by Martin on suggestions by Kevin.
-2005-05-03 15:30 Sandro Santilli <strk at keybit.net>
+2005-05-03 15:30 Sandro Santilli <strk at kbt.io>
* [r704] TODO: Added WKB TODOs
-2005-04-29 17:40 Sandro Santilli <strk at keybit.net>
+2005-04-29 17:40 Sandro Santilli <strk at kbt.io>
* [r703] source/geom/Geometry.cpp, source/headers/geos.h,
@@ -23175,18 +25171,18 @@
source/operation/overlay/OverlayOp.cpp: Updated Doxygen
documentation and some Copyright headers.
-2005-04-29 16:36 Sandro Santilli <strk at keybit.net>
+2005-04-29 16:36 Sandro Santilli <strk at kbt.io>
* [r702] source/headers/geos/io.h: Fixed biostringstream stream
output.
* [r701] doc/example.cpp: Made WKBReader use global_factory, for
having WKB reads produce
same context of input geoms.
-2005-04-29 15:34 Sandro Santilli <strk at keybit.net>
+2005-04-29 15:34 Sandro Santilli <strk at kbt.io>
* [r700] doc/example.cpp, source/headers/geos/WKBReaderT.h,
source/headers/geos/WKBWriterT.h, source/headers/geos/io.h,
@@ -23198,7 +25194,7 @@
biostringstream.
Added WKBtest in doc/example.cpp
-2005-04-29 11:52 Sandro Santilli <strk at keybit.net>
+2005-04-29 11:52 Sandro Santilli <strk at kbt.io>
* [r699] source/geom/CoordinateSequence.cpp,
@@ -23215,32 +25211,32 @@
a template class.
-2005-04-29 11:50 Sandro Santilli <strk at keybit.net>
+2005-04-29 11:50 Sandro Santilli <strk at kbt.io>
* [r698] source/headers/geos/platform.h.in: Added machine byte
order extractor
-2005-04-21 15:13 Sandro Santilli <strk at keybit.net>
+2005-04-21 15:13 Sandro Santilli <strk at kbt.io>
* [r697] configure.in: library version bumped to 3.0.0
-2005-04-21 13:43 Sandro Santilli <strk at keybit.net>
+2005-04-21 13:43 Sandro Santilli <strk at kbt.io>
* [r696] ChangeLog, NEWS: Updated chage logs
-2005-04-21 11:16 Sandro Santilli <strk at keybit.net>
+2005-04-21 11:16 Sandro Santilli <strk at kbt.io>
* [r695] source/operation/overlay/OverlayOp.cpp: Removed useless
Coordinate copies in mergeZ() - patch by Safe Software
-2005-04-20 17:56 Sandro Santilli <strk at keybit.net>
+2005-04-20 17:56 Sandro Santilli <strk at kbt.io>
* [r694] source/algorithm/NonRobustCGAlgorithms.cpp,
source/algorithm/RobustCGAlgorithms.cpp, source/geom/Makefile.am:
Removed NonRobustCGAlgorithms and RobustCGAlgorithms, already
unused (CGAlgorithms replaces both with robust implementation).
-2005-04-20 17:22 Sandro Santilli <strk at keybit.net>
+2005-04-20 17:22 Sandro Santilli <strk at kbt.io>
* [r693] source/geom/Makefile.am,
@@ -23254,27 +25250,27 @@
CoordinateSequence
taking higher dimensions into account.
-2005-04-20 17:18 Sandro Santilli <strk at keybit.net>
+2005-04-20 17:18 Sandro Santilli <strk at kbt.io>
* [r692] source/headers/geos.h: Added standard copyright header
-2005-04-19 11:49 Sandro Santilli <strk at keybit.net>
+2005-04-19 11:49 Sandro Santilli <strk at kbt.io>
* [r691] source/geom/Point.cpp: Fixed segfault in ::isEmpty
-2005-04-14 11:49 Sandro Santilli <strk at keybit.net>
+2005-04-14 11:49 Sandro Santilli <strk at kbt.io>
* [r690] source/headers/geos/io.h, source/io/StringTokenizer.cpp,
source/io/WKTReader.cpp: Applied slightly modified patch by Cheng
Shan to speedup WKT parsing.
-2005-04-07 18:43 Sandro Santilli <strk at keybit.net>
+2005-04-07 18:43 Sandro Santilli <strk at kbt.io>
* [r689] source/operation/valid/IsValidOp.cpp: Fixed bug throwing
an exception when a result could be returned instead
(ported JTS patch)
-2005-04-06 11:09 Sandro Santilli <strk at keybit.net>
+2005-04-06 11:09 Sandro Santilli <strk at kbt.io>
* [r688] ChangeLog, ltmain.sh, source/algorithm/CGAlgorithms.cpp,
@@ -23293,26 +25289,26 @@
* [r687] swig/python/setup.py: now supporting the win32 platform,
thanks to Howard Butler
-2005-03-26 08:19 Sandro Santilli <strk at keybit.net>
+2005-03-26 08:19 Sandro Santilli <strk at kbt.io>
* [r686] source/headers/geos/opPolygonize.h: Commented out
Polygonizer::LineStringAdder friendship
-2005-03-10 17:27 Sandro Santilli <strk at keybit.net>
+2005-03-10 17:27 Sandro Santilli <strk at kbt.io>
* [r685] source/io/WKBReader.cpp: ported from current JTS
-2005-03-04 07:48 Sandro Santilli <strk at keybit.net>
+2005-03-04 07:48 Sandro Santilli <strk at kbt.io>
* [r684] source/algorithm/CGAlgorithms.cpp: Removed useless copy
-2005-03-02 08:14 Sandro Santilli <strk at keybit.net>
+2005-03-02 08:14 Sandro Santilli <strk at kbt.io>
* [r683] source/headers/Makefile.am: Removed commented line,
cousing strange behaviours with autotools.
-2005-02-22 18:21 Sandro Santilli <strk at keybit.net>
+2005-02-22 18:21 Sandro Santilli <strk at kbt.io>
* [r682] source/headers/geos/noding.h,
source/index/strtree/STRtree.cpp, source/noding/SegmentNode.cpp,
@@ -23321,55 +25317,55 @@
*real* Coordinate (not a pointer) to reduce
construction costs.
-2005-02-22 17:10 Sandro Santilli <strk at keybit.net>
+2005-02-22 17:10 Sandro Santilli <strk at kbt.io>
* [r681] source/geom/CoordinateSequence.cpp,
source/geom/LineString.cpp, source/noding/MCQuadtreeNoder.cpp,
source/operation/buffer/RightmostEdgeFinder.cpp: Reduced
CoordinateSequence::getSize() calls.
-2005-02-22 16:24 Sandro Santilli <strk at keybit.net>
+2005-02-22 16:24 Sandro Santilli <strk at kbt.io>
* [r680] source/geomgraph/Edge.cpp,
source/headers/geos/geomgraph.h: cached number of points in Edge
-2005-02-22 16:23 Sandro Santilli <strk at keybit.net>
+2005-02-22 16:23 Sandro Santilli <strk at kbt.io>
* [r679] source/headers/geos/noding.h,
source/noding/SegmentString.cpp: Cached number of points in
CoordinateSequence.
-2005-02-22 15:49 Sandro Santilli <strk at keybit.net>
+2005-02-22 15:49 Sandro Santilli <strk at kbt.io>
* [r678] source/noding/SegmentString.cpp: Reduced calls to
DefaultCoordinateSequence->getSize().
-2005-02-22 15:16 Sandro Santilli <strk at keybit.net>
+2005-02-22 15:16 Sandro Santilli <strk at kbt.io>
* [r677] source/headers/geos/indexStrtree.h,
source/index/strtree/STRtree.cpp: STRtree::avg() and
STRtree::centreY() inlined.
-2005-02-22 10:55 Sandro Santilli <strk at keybit.net>
+2005-02-22 10:55 Sandro Santilli <strk at kbt.io>
* [r676] source/geomgraph/Edge.cpp: Optimized Edge::equals(Edge *e)
-2005-02-18 08:20 Sandro Santilli <strk at keybit.net>
+2005-02-18 08:20 Sandro Santilli <strk at kbt.io>
* [r675] source/test/XMLTester.cpp: Added support for
point-per-quadrant argument in buffer tests (using arg2).
-2005-02-17 09:56 Sandro Santilli <strk at keybit.net>
+2005-02-17 09:56 Sandro Santilli <strk at kbt.io>
* [r674] source/operation/buffer/OffsetCurveBuilder.cpp: Commented
out unused variable.
* [r673] source/headers/geos/geom.h: Applied patch from Jon
Schlueter using <cmath> instead of <math.h>
-2005-02-15 17:15 Sandro Santilli <strk at keybit.net>
+2005-02-15 17:15 Sandro Santilli <strk at kbt.io>
* [r672] source/algorithm/RobustLineIntersector.cpp,
source/geom/Envelope.cpp, source/geom/LineSegment.cpp,
@@ -23385,14 +25381,14 @@
reserved() memory for some vectors when
the usage was known a priori.
-2005-02-11 08:58 Sandro Santilli <strk at keybit.net>
+2005-02-11 08:58 Sandro Santilli <strk at kbt.io>
* [r671] source/geom/Makefile.am, source/headers/Makefile.am,
source/headers/geos/Makefile.am: Applied patch from Curtis
Barrett handling --includedir and --libdir
params for configure.
-2005-02-05 05:44 Sandro Santilli <strk at keybit.net>
+2005-02-05 05:44 Sandro Santilli <strk at kbt.io>
* [r670] source/algorithm/CGAlgorithms.cpp,
@@ -23419,49 +25415,49 @@
to use Coordinate pointers as keys, reduces
lots of other Coordinate copies.
-2005-02-04 23:55 Sandro Santilli <strk at keybit.net>
+2005-02-04 23:55 Sandro Santilli <strk at kbt.io>
* [r669] source/headers/geos/geom.h: Envelope destructor made
non-virtual to give compiler more static
binding options.
-2005-02-04 18:49 Sandro Santilli <strk at keybit.net>
+2005-02-04 18:49 Sandro Santilli <strk at kbt.io>
* [r668] source/headers/geos/opBuffer.h,
source/operation/buffer/BufferSubgraph.cpp: Changed
::computeDepths to use a set instead of a vector for checking
visited Edges.
-2005-02-04 14:49 Sandro Santilli <strk at keybit.net>
+2005-02-04 14:49 Sandro Santilli <strk at kbt.io>
* [r667] source/test/Makefile.am: Added rule to build
staticXMLTester (for profiling with gprof)
-2005-02-03 09:17 Sandro Santilli <strk at keybit.net>
+2005-02-03 09:17 Sandro Santilli <strk at kbt.io>
* [r666] source/geom/CoordinateSequence.cpp: more profiling label
-2005-02-01 16:09 Sandro Santilli <strk at keybit.net>
+2005-02-01 16:09 Sandro Santilli <strk at kbt.io>
* [r665] source/noding/MCQuadtreeNoder.cpp,
source/noding/Noder.cpp: more profiling labels
-2005-02-01 16:06 Sandro Santilli <strk at keybit.net>
+2005-02-01 16:06 Sandro Santilli <strk at kbt.io>
* [r664] source/geom/Envelope.cpp,
source/index/chain/indexMonotoneChain.cpp: Small optimizations.
-2005-02-01 14:18 Sandro Santilli <strk at keybit.net>
+2005-02-01 14:18 Sandro Santilli <strk at kbt.io>
* [r663] source/noding/SegmentNodeList.cpp,
source/noding/SegmentString.cpp: More profiler labels
* [r662] source/headers/geos/profiler.h, source/util/Profiler.cpp:
Made profiler start/stop inline
-2005-02-01 13:44 Sandro Santilli <strk at keybit.net>
+2005-02-01 13:44 Sandro Santilli <strk at kbt.io>
* [r661] source/geom/LineSegment.cpp,
@@ -23471,18 +25467,18 @@
source/util/Profiler.cpp: More profiling labels.
-2005-01-31 15:41 Sandro Santilli <strk at keybit.net>
+2005-01-31 15:41 Sandro Santilli <strk at kbt.io>
* [r660] source/index/strtree/AbstractSTRtree.cpp,
source/noding/MCQuadtreeNoder.cpp: Small optimizations.
-2005-01-28 10:01 Sandro Santilli <strk at keybit.net>
+2005-01-28 10:01 Sandro Santilli <strk at kbt.io>
* [r659] source/io/ParseException.cpp: substituted sprintf calls
with use of ostringstream
-2005-01-28 09:47 Sandro Santilli <strk at keybit.net>
+2005-01-28 09:47 Sandro Santilli <strk at kbt.io>
* [r658] source/examples/CustomPointCoordinateSequence.cpp,
source/geom/Dimension.cpp, source/geom/Envelope.cpp,
@@ -23499,67 +25495,67 @@
source/planargraph/planarDirectedEdge.cpp: Replaced sprintf uses
with ostringstream.
-2005-01-28 08:47 Sandro Santilli <strk at keybit.net>
+2005-01-28 08:47 Sandro Santilli <strk at kbt.io>
* [r657] source/geom/Coordinate.cpp: Removed sprintf usage,
replaced with sstream
-2005-01-28 07:58 Sandro Santilli <strk at keybit.net>
+2005-01-28 07:58 Sandro Santilli <strk at kbt.io>
* [r656] source/geom/DefaultCoordinateSequence.cpp: removed sprintf
usage, ad ::toString call Coordinate::toString
-2005-01-18 17:22 Sandro Santilli <strk at keybit.net>
+2005-01-18 17:22 Sandro Santilli <strk at kbt.io>
* [r655] source/algorithm/LineIntersector.cpp: reverted previous
change, sign was actually stored in zgap
-2005-01-18 17:09 Sandro Santilli <strk at keybit.net>
+2005-01-18 17:09 Sandro Santilli <strk at kbt.io>
* [r654] source/algorithm/RobustLineIntersector.cpp: Fixed
interpolateZ call using final intersection point instead of
HCoordinate.
-2005-01-14 08:04 Sandro Santilli <strk at keybit.net>
+2005-01-14 08:04 Sandro Santilli <strk at kbt.io>
* [r653] source/algorithm/LineIntersector.cpp: Fixed Z
interpolation to use the correct sign
-2005-01-03 16:06 Sandro Santilli <strk at keybit.net>
+2005-01-03 16:06 Sandro Santilli <strk at kbt.io>
* [r652] source/test/XMLTester.cpp: Changed polygonize op to return
a GeometryCollection
-2005-01-03 15:56 Sandro Santilli <strk at keybit.net>
+2005-01-03 15:56 Sandro Santilli <strk at kbt.io>
* [r651] source/test/XMLTester.cpp: Fixed memory leaks just
introduced for Polygonizer test case.
-2005-01-03 15:49 Sandro Santilli <strk at keybit.net>
+2005-01-03 15:49 Sandro Santilli <strk at kbt.io>
* [r650] source/test/XMLTester.cpp: Added Polygonize test handling
-2004-12-30 13:32 Sandro Santilli <strk at keybit.net>
+2004-12-30 13:32 Sandro Santilli <strk at kbt.io>
* [r649] source/test/XMLTester.cpp: Handled NULL result from
getCentroid()
-2004-12-30 13:31 Sandro Santilli <strk at keybit.net>
+2004-12-30 13:31 Sandro Santilli <strk at kbt.io>
* [r648] source/geom/Geometry.cpp: Fixed a segfault on
EMPTYGEOM->getCeontroid()
-2004-12-30 10:14 Sandro Santilli <strk at keybit.net>
+2004-12-30 10:14 Sandro Santilli <strk at kbt.io>
* [r647] source/geom/Polygon.cpp: never return LinearRing or
MultiLinearRing from getBoundary
* [r646] source/geom/GeometryFactory.cpp: input checking and class
promoting in createMultiLineString()
-2004-12-22 09:42 Sandro Santilli <strk at keybit.net>
+2004-12-22 09:42 Sandro Santilli <strk at kbt.io>
* [r645] source/geom/util/GeometryEditor.cpp: Fixed a premature
Geometry destruction, Avoided CoordinateSequence copies
@@ -23570,29 +25566,29 @@
* [r644] configure.in: Bumped minor version number for 2.1.1
release.
-2004-12-16 16:27 Sandro Santilli <strk at keybit.net>
+2004-12-16 16:27 Sandro Santilli <strk at kbt.io>
* [r643] source/geom/LinearRing.cpp, source/headers/geos/geom.h:
Fixed LinearRing::clone() to return LinearRing instead of
LineString
-2004-12-16 16:08 Sandro Santilli <strk at keybit.net>
+2004-12-16 16:08 Sandro Santilli <strk at kbt.io>
* [r642] swig/geos.i, swig/python/example.py: New patches from Niki
Spahiev <niki.spahiev at gmail.com>
(still unstable)
-2004-12-16 09:05 Sandro Santilli <strk at keybit.net>
+2004-12-16 09:05 Sandro Santilli <strk at kbt.io>
* [r641] swig/python/example.py: Added python example by Niki
-2004-12-16 08:56 Sandro Santilli <strk at keybit.net>
+2004-12-16 08:56 Sandro Santilli <strk at kbt.io>
* [r640] swig/geos.i: Applyed patches by Niki Spahiev
-2004-12-14 10:35 Sandro Santilli <strk at keybit.net>
+2004-12-14 10:35 Sandro Santilli <strk at kbt.io>
* [r638] source/headers/geos/opPolygonize.h,
source/headers/geos/planargraph.h,
@@ -23602,46 +25598,46 @@
PolygonizeGraph keeps track of generated CoordinateSequence
for delayed destruction.
-2004-12-13 13:54 Sandro Santilli <strk at keybit.net>
+2004-12-13 13:54 Sandro Santilli <strk at kbt.io>
* [r637] source/headers/geos/opPolygonize.h: Added a not about gcc
2.95.4 required friendship
-2004-12-13 13:53 Sandro Santilli <strk at keybit.net>
+2004-12-13 13:53 Sandro Santilli <strk at kbt.io>
* [r636] source/geom/TopologyException.cpp: Fixed uninitialized
Coordinate.
-2004-12-12 17:22 Sandro Santilli <strk at keybit.net>
+2004-12-12 17:22 Sandro Santilli <strk at kbt.io>
* [r635] source/headers/geos/Makefile.am: version.h and platform.h
installed again (missed when removed from dist)
-2004-12-08 14:33 Sandro Santilli <strk at keybit.net>
+2004-12-08 14:33 Sandro Santilli <strk at kbt.io>
* [r634] source/geom/MultiPolygon.cpp: Checked inner polys
getBoundary return for the single LineString case.
-2004-12-08 14:32 Sandro Santilli <strk at keybit.net>
+2004-12-08 14:32 Sandro Santilli <strk at kbt.io>
* [r633] source/geom/GeometryCollection.cpp: cleanups
-2004-12-08 14:31 Sandro Santilli <strk at keybit.net>
+2004-12-08 14:31 Sandro Santilli <strk at kbt.io>
* [r632] source/test/testLeaksBig.xml: adjusted getBoundary
expected returns to match OGC specs
* [r631] source/operation/overlay/OverlayOp.cpp: elevationMatrix
deleted by destructor
-2004-12-08 14:30 Sandro Santilli <strk at keybit.net>
+2004-12-08 14:30 Sandro Santilli <strk at kbt.io>
* [r630] source/io/Unload.cpp: Added default profiler instance
cleanup
-2004-12-08 13:54 Sandro Santilli <strk at keybit.net>
+2004-12-08 13:54 Sandro Santilli <strk at kbt.io>
* [r629] doc/example.cpp,
@@ -23682,37 +25678,37 @@
source/util/GeometricShapeFactory.cpp: gcc warnings checked and
fixed, general cleanups.
-2004-12-06 10:54 Sandro Santilli <strk at keybit.net>
+2004-12-06 10:54 Sandro Santilli <strk at kbt.io>
* [r628] source/headers/geos/Makefile.am: Added timeval.h in
distribution.
-2004-12-05 10:54 Sandro Santilli <strk at keybit.net>
+2004-12-05 10:54 Sandro Santilli <strk at kbt.io>
* [r627] VisualStudio, VisualStudio/.cvsignore: initial revision
-2004-12-05 10:50 Sandro Santilli <strk at keybit.net>
+2004-12-05 10:50 Sandro Santilli <strk at kbt.io>
* [r626] VisualStudio/Makefile.am: forgot to add
-2004-12-05 10:48 Sandro Santilli <strk at keybit.net>
+2004-12-05 10:48 Sandro Santilli <strk at kbt.io>
* [r625] debian/control, debian/libgeos-doc.doc-base, debian/rules:
Modifications by Alex Bodnaru
-2004-12-05 10:44 Sandro Santilli <strk at keybit.net>
+2004-12-05 10:44 Sandro Santilli <strk at kbt.io>
* [r624] configure.in, doc/Makefile.am, source/bigtest/Makefile.am,
source/examples/Makefile.am, source/test/Makefile.am: Applied
Norman Vine patches for cleaner win32 build.
-2004-12-04 15:56 Sandro Santilli <strk at keybit.net>
+2004-12-04 15:56 Sandro Santilli <strk at kbt.io>
* [r623] source/Makefile.am, source/headers/geos/Makefile.am: Added
source/Makefile.vc and source/headers/geos/platform.h.in in
distribution
-2004-12-04 15:31 Sandro Santilli <strk at keybit.net>
+2004-12-04 15:31 Sandro Santilli <strk at kbt.io>
* [r622] Makefile.am, configure.in,
source/headers/geos/Makefile.am: Added VisualStudio dir in
@@ -23722,7 +25718,7 @@
* [r621] source/Makefile.vc: removed dll delete
-2004-12-03 22:52 Sandro Santilli <strk at keybit.net>
+2004-12-03 22:52 Sandro Santilli <strk at kbt.io>
* [r620] source/geom/CoordinateSequence.cpp,
@@ -23754,23 +25750,23 @@
* [r615] source/headers/geos/platform.h.vc: New
-2004-11-30 16:44 Sandro Santilli <strk at keybit.net>
+2004-11-30 16:44 Sandro Santilli <strk at kbt.io>
* [r614] source/headers/geos/profiler.h,
source/headers/geos/timeval.h: Added gettimeofday implementation
for win32, curtesy of Wu Yongwei.
-2004-11-30 13:05 Sandro Santilli <strk at keybit.net>
+2004-11-30 13:05 Sandro Santilli <strk at kbt.io>
* [r613] source/headers/geos/platform.h.in: Removed inclusion of
stdio.h, which should now be useless.
-2004-11-30 13:04 Sandro Santilli <strk at keybit.net>
+2004-11-30 13:04 Sandro Santilli <strk at kbt.io>
* [r612] configure.in, source/headers/geos/platform.h.in: Added
optional inclusion of ieeefp.h on platform providing it.
-2004-11-29 16:05 Sandro Santilli <strk at keybit.net>
+2004-11-29 16:05 Sandro Santilli <strk at kbt.io>
* [r611] source/algorithm/HCoordinate.cpp,
@@ -23788,21 +25784,21 @@
Added ISNAN macro and changed ISNAN/FINITE macros to avoid
dispendious isnan() and finite() calls.
-2004-11-27 11:36 Sandro Santilli <strk at keybit.net>
+2004-11-27 11:36 Sandro Santilli <strk at kbt.io>
* [r610] debian/Makefile, debian/README.Debian, debian/changelog,
debian/control, debian/libgeos-dev.install,
debian/libgeos-dev.manpages, debian/rules, debian/shlibs.local:
Updated scripts by Alex Bodnaru, added Makefile
-2004-11-26 09:53 Sandro Santilli <strk at keybit.net>
+2004-11-26 09:53 Sandro Santilli <strk at kbt.io>
* [r609] source/algorithm/LineIntersector.cpp,
source/geomgraph/Node.cpp, source/headers/geos/platform.h.in:
Added more FINITE calls, and added inf and -inf to FINITE checks
-2004-11-26 09:22 Sandro Santilli <strk at keybit.net>
+2004-11-26 09:22 Sandro Santilli <strk at kbt.io>
* [r608] source/headers/geos/platform.h.in,
@@ -23812,27 +25808,27 @@
its use.
Made input geoms average Z computation optional in OverlayOp.
-2004-11-24 18:10 Sandro Santilli <strk at keybit.net>
+2004-11-24 18:10 Sandro Santilli <strk at kbt.io>
* [r607] source/operation/overlay/OverlayOp.cpp: Stricter handling
of USE_ELEVATION_MATRIX define
* [r606] source/algorithm/LineIntersector.cpp: Cleanup of
interpolateZ
-2004-11-24 12:29 Sandro Santilli <strk at keybit.net>
+2004-11-24 12:29 Sandro Santilli <strk at kbt.io>
* [r605] source/operation/overlay/ElevationMatrix.cpp: Handled
boundary cases in ::getCell
-2004-11-24 11:32 Sandro Santilli <strk at keybit.net>
+2004-11-24 11:32 Sandro Santilli <strk at kbt.io>
* [r604] source/operation/overlay/LineBuilder.cpp: Re-enabled Z
propagation in output lines.
-2004-11-23 19:53 Sandro Santilli <strk at keybit.net>
+2004-11-23 19:53 Sandro Santilli <strk at kbt.io>
* [r603] source/algorithm/LineIntersector.cpp,
@@ -23845,7 +25841,7 @@
source/operation/overlay/OverlayOp.cpp: Had LineIntersector
compute Z by interpolation.
-2004-11-23 16:22 Sandro Santilli <strk at keybit.net>
+2004-11-23 16:22 Sandro Santilli <strk at kbt.io>
* [r602] source/geom/DefaultCoordinateSequence.cpp,
source/geom/LineString.cpp, source/geom/Makefile.am,
@@ -23858,28 +25854,28 @@
class and components to do post-processing draping of overlayed
geometries.
-2004-11-22 15:51 Sandro Santilli <strk at keybit.net>
+2004-11-22 15:51 Sandro Santilli <strk at kbt.io>
* [r601] source/headers/geos/opOverlay.h,
source/operation/overlay/OverlayOp.cpp: Added interpolation of
containing geometry's average Z for point_in_poly case.
-2004-11-22 13:02 Sandro Santilli <strk at keybit.net>
+2004-11-22 13:02 Sandro Santilli <strk at kbt.io>
* [r600] source/algorithm/RobustLineIntersector.cpp: Fixed a bug in
Collinear intersection Z computation
* [r599] source/geomgraph/EdgeIntersectionList.cpp: Forced use if
computed intersection point in ::createSplitEdge (for Z
computation)
-2004-11-22 12:59 Sandro Santilli <strk at keybit.net>
+2004-11-22 12:59 Sandro Santilli <strk at kbt.io>
* [r598] source/geomgraph/Edge.cpp: Added debugging lines
-2004-11-22 11:34 Sandro Santilli <strk at keybit.net>
+2004-11-22 11:34 Sandro Santilli <strk at kbt.io>
* [r597] source/geomgraph/EdgeEndStar.cpp,
@@ -23888,64 +25884,64 @@
source/operation/overlay/OverlayOp.cpp: More debugging lines and
comments/indentation cleanups
* [r596] source/algorithm/RobustLineIntersector.cpp: Added Z
computation for CollinearIntersections
-2004-11-20 18:54 Sandro Santilli <strk at keybit.net>
+2004-11-20 18:54 Sandro Santilli <strk at kbt.io>
* [r595] debian/README.Debian, debian/control,
debian/libgeos-dev.install, debian/rules: Scripts updates from
Alex Bodnaru
-2004-11-20 18:17 Sandro Santilli <strk at keybit.net>
+2004-11-20 18:17 Sandro Santilli <strk at kbt.io>
* [r594] source/headers/geos/opOverlay.h,
source/operation/overlay/LineBuilder.cpp: Added Z propagation for
overlay lines output.
-2004-11-20 17:16 Sandro Santilli <strk at keybit.net>
+2004-11-20 17:16 Sandro Santilli <strk at kbt.io>
* [r593] source/headers/geos/opOverlay.h,
source/operation/overlay/OverlayOp.cpp: Handled Z merging for
point on polygon boundary case.
-2004-11-20 16:25 Sandro Santilli <strk at keybit.net>
+2004-11-20 16:25 Sandro Santilli <strk at kbt.io>
* [r592] source/operation/overlay/OverlayOp.cpp: Added Z
computation for point on line case.
-2004-11-20 15:46 Sandro Santilli <strk at keybit.net>
+2004-11-20 15:46 Sandro Santilli <strk at kbt.io>
* [r591] source/headers/geos/geomgraph.h: Added composing Z
management functions and elements for class Node
-2004-11-20 15:45 Sandro Santilli <strk at keybit.net>
+2004-11-20 15:45 Sandro Santilli <strk at kbt.io>
* [r590] source/geomgraph/NodeMap.cpp: Fixed Z merging in
addNode(Node *)
-2004-11-20 15:41 Sandro Santilli <strk at keybit.net>
+2004-11-20 15:41 Sandro Santilli <strk at kbt.io>
* [r589] source/geomgraph/NodeMap.cpp: Added Z merging in ::addNode
* [r588] source/geomgraph/Node.cpp: Added management of vector of
composing Z values.
-2004-11-20 15:40 Sandro Santilli <strk at keybit.net>
+2004-11-20 15:40 Sandro Santilli <strk at kbt.io>
* [r587] source/algorithm/RobustLineIntersector.cpp: Added Z
computation in point-segment intersection.
-2004-11-20 15:39 Sandro Santilli <strk at keybit.net>
+2004-11-20 15:39 Sandro Santilli <strk at kbt.io>
* [r586] source/algorithm/CGAlgorithms.cpp: Reduced HEAP
allocations.
-2004-11-19 16:35 Sandro Santilli <strk at keybit.net>
+2004-11-19 16:35 Sandro Santilli <strk at kbt.io>
* [r585] debian, debian/changelog, debian/compat, debian/control,
debian/copyright, debian/geos-config.1, debian/libgeos-dev.dirs,
@@ -23955,26 +25951,26 @@
debian/makedoc, debian/rules, debian/shlibs.local, debian/watch:
Added debian package builder scripts.
-2004-11-19 16:15 Sandro Santilli <strk at keybit.net>
+2004-11-19 16:15 Sandro Santilli <strk at kbt.io>
* [r584] source/index/quadtree/QuadTreeNode.cpp: Completely removed
sprintf usage, substituted by stringstream.
-2004-11-19 16:09 Sandro Santilli <strk at keybit.net>
+2004-11-19 16:09 Sandro Santilli <strk at kbt.io>
* [r583] source/index/quadtree/QuadTreeNode.cpp: Added <stdio.h>
include for sprintf recognition.
-2004-11-19 10:10 Sandro Santilli <strk at keybit.net>
+2004-11-19 10:10 Sandro Santilli <strk at kbt.io>
* [r582] source/geomgraph/Node.cpp: COMPUTE_Z re-enabled by default
-2004-11-19 09:33 Sandro Santilli <strk at keybit.net>
+2004-11-19 09:33 Sandro Santilli <strk at kbt.io>
* [r581] source/geomgraph/GeometryGraph.cpp: removed useless
CoordinateSequence copy in ::addLineString
-2004-11-17 15:09 Sandro Santilli <strk at keybit.net>
+2004-11-17 15:09 Sandro Santilli <strk at kbt.io>
* [r580] source/algorithm/RobustLineIntersector.cpp,
@@ -23982,13 +25978,13 @@
source/operation/overlay/PointBuilder.cpp: Changed COMPUTE_Z
defaults to be more conservative
-2004-11-17 08:41 Sandro Santilli <strk at keybit.net>
+2004-11-17 08:41 Sandro Santilli <strk at kbt.io>
* [r579] source/algorithm/RobustLineIntersector.cpp,
source/geomgraph/index/SegmentIntersector.cpp: Fixed a bug in Z
computation and removed debugging output by default.
-2004-11-17 08:13 Sandro Santilli <strk at keybit.net>
+2004-11-17 08:13 Sandro Santilli <strk at kbt.io>
* [r578] source/algorithm/PointLocator.cpp,
@@ -24005,23 +26001,23 @@
source/operation/overlay/PointBuilder.cpp: Indentation changes.
Some Z_COMPUTATION activated by default.
-2004-11-12 18:12 Sandro Santilli <strk at keybit.net>
+2004-11-12 18:12 Sandro Santilli <strk at kbt.io>
* [r576] source/geom/Polygon.cpp: Changed ::getBoundary() to return
LineString if polygon has no holes.
(has required to pass OGC conformance test T20)
-2004-11-09 20:22 Sandro Santilli <strk at keybit.net>
+2004-11-09 20:22 Sandro Santilli <strk at kbt.io>
* [r575] tools/geos-config.in: Removed -g -O2 from geos-config
--cflags output
-2004-11-08 18:33 Sandro Santilli <strk at keybit.net>
+2004-11-08 18:33 Sandro Santilli <strk at kbt.io>
* [r574] source/index/strtree/STRtree.cpp: Just another small
improvement.
-2004-11-08 15:58 Sandro Santilli <strk at keybit.net>
+2004-11-08 15:58 Sandro Santilli <strk at kbt.io>
* [r573] source/headers/geos/indexStrtree.h,
@@ -24029,31 +26025,31 @@
source/operation/buffer/BufferOp.cpp: More performance tuning.
-2004-11-08 13:12 Sandro Santilli <strk at keybit.net>
+2004-11-08 13:12 Sandro Santilli <strk at kbt.io>
* [r572] source/headers/geos/Makefile.am: Added profiler.h
-2004-11-08 12:15 Sandro Santilli <strk at keybit.net>
+2004-11-08 12:15 Sandro Santilli <strk at kbt.io>
* [r571] source/util/Profiler.cpp: Added number of gathered timings
in output.
-2004-11-08 11:19 Sandro Santilli <strk at keybit.net>
+2004-11-08 11:19 Sandro Santilli <strk at kbt.io>
* [r570] source/util/Profiler.cpp: Profiler::get() always return a
Profile (new if not existant).
-2004-11-08 10:58 Sandro Santilli <strk at keybit.net>
+2004-11-08 10:58 Sandro Santilli <strk at kbt.io>
* [r569] source/geom/Envelope.cpp: Optimized the ::intersect
function to avoid nested function calls.
-2004-11-08 10:57 Sandro Santilli <strk at keybit.net>
+2004-11-08 10:57 Sandro Santilli <strk at kbt.io>
* [r568] source/headers/geos/geom.h: Moved Log lines at the bottom,
and cut oldest
-2004-11-06 08:16 Sandro Santilli <strk at keybit.net>
+2004-11-06 08:16 Sandro Santilli <strk at kbt.io>
* [r567] source/algorithm/CGAlgorithms.cpp,
source/headers/geos/geosAlgorithm.h,
@@ -24061,11 +26057,11 @@
from JTS port.
Code cleanup in IsValidOp.
-2004-11-05 12:18 Sandro Santilli <strk at keybit.net>
+2004-11-05 12:18 Sandro Santilli <strk at kbt.io>
* [r566] TODO: updated
-2004-11-05 11:41 Sandro Santilli <strk at keybit.net>
+2004-11-05 11:41 Sandro Santilli <strk at kbt.io>
* [r565] source/algorithm/CGAlgorithms.cpp,
source/geomgraph/GeometryGraph.cpp,
@@ -24077,7 +26073,7 @@
as a sign of invalidity (just for Polygon geometries).
Removed leaks generated by this specific exception.
-2004-11-04 19:08 Sandro Santilli <strk at keybit.net>
+2004-11-04 19:08 Sandro Santilli <strk at kbt.io>
* [r564] source/algorithm/MinimumDiameter.cpp,
@@ -24098,33 +26094,33 @@
source/test/XMLTester.cpp: Cleanups, initializers list,
profiling.
-2004-11-04 08:49 Sandro Santilli <strk at keybit.net>
+2004-11-04 08:49 Sandro Santilli <strk at kbt.io>
* [r563] source/headers/geos/indexQuadtree.h,
source/index/quadtree/DoubleBits.cpp: Unlinked new documentation.
-2004-11-03 08:22 Sandro Santilli <strk at keybit.net>
+2004-11-03 08:22 Sandro Santilli <strk at kbt.io>
* [r562] source/index/quadtree/DoubleBits.cpp: Slightly modified
log/log2 based algo to better handle numbers in the
range 0-1.
-2004-11-02 16:38 Sandro Santilli <strk at keybit.net>
+2004-11-02 16:38 Sandro Santilli <strk at kbt.io>
* [r561] source/headers/geos/indexQuadtree.h: Fixed ieee-754
detection switch
-2004-11-02 16:31 Sandro Santilli <strk at keybit.net>
+2004-11-02 16:31 Sandro Santilli <strk at kbt.io>
* [r560] TODO: updated
-2004-11-02 16:05 Sandro Santilli <strk at keybit.net>
+2004-11-02 16:05 Sandro Santilli <strk at kbt.io>
* [r559] source/headers/geos/indexQuadtree.h: Autodetect
availability of IEEE-754 FP
-2004-11-02 15:49 Sandro Santilli <strk at keybit.net>
+2004-11-02 15:49 Sandro Santilli <strk at kbt.io>
* [r558] source/headers/geos/indexQuadtree.h,
source/index/quadtree/DoubleBits.cpp: Moved ASSUME_IEEE_DOUBLE
@@ -24132,21 +26128,21 @@
Fixed a bug in powerOf2(). Made the !IEEE version less prone to
round-offs (still has approximation errors).
-2004-11-02 14:13 Sandro Santilli <strk at keybit.net>
+2004-11-02 14:13 Sandro Santilli <strk at kbt.io>
* [r557] source/index/quadtree/DoubleBits.cpp: Fixed bug in
IEEE-based exponent and PowerOf2 computation, but disabled
at compile time.
-2004-11-02 14:11 Sandro Santilli <strk at keybit.net>
+2004-11-02 14:11 Sandro Santilli <strk at kbt.io>
* [r556] source/noding/MCQuadtreeNoder.cpp: Added more profiling.
-2004-11-02 09:38 Sandro Santilli <strk at keybit.net>
+2004-11-02 09:38 Sandro Santilli <strk at kbt.io>
* [r555] source/test/XMLTester.cpp: Added timer for buffer test.
-2004-11-01 16:43 Sandro Santilli <strk at keybit.net>
+2004-11-01 16:43 Sandro Santilli <strk at kbt.io>
* [r554] source/geom/Coordinate.cpp, source/geom/Envelope.cpp,
source/geom/Makefile.am, source/geomgraph/Edge.cpp,
@@ -24177,17 +26173,17 @@
Temporarly patched a bug in DoubleBits (must check drawbacks).
Various cleanups and speedups.
-2004-10-27 13:57 Sandro Santilli <strk at keybit.net>
+2004-10-27 13:57 Sandro Santilli <strk at kbt.io>
* [r553] source/operation/polygonize/Polygonizer.cpp,
source/operation/polygonize/polygonizeEdgeRing.cpp: Added some
debugging lines (disabled by default)
-2004-10-27 11:05 Sandro Santilli <strk at keybit.net>
+2004-10-27 11:05 Sandro Santilli <strk at kbt.io>
* [r552] TODO: updated
-2004-10-26 17:46 Sandro Santilli <strk at keybit.net>
+2004-10-26 17:46 Sandro Santilli <strk at kbt.io>
* [r551] source/headers/geos/indexBintree.h,
source/headers/geos/indexChain.h,
@@ -24195,24 +26191,24 @@
source/headers/geos/spatialIndex.h: Removed slash-stars in
comments to remove annoying compiler warnings.
-2004-10-26 17:14 Sandro Santilli <strk at keybit.net>
+2004-10-26 17:14 Sandro Santilli <strk at kbt.io>
* [r550] NEWS, configure.in: current:revision:age set to 3.0.1
(will be release 2.1.0).
added news.
-2004-10-26 16:22 Sandro Santilli <strk at keybit.net>
+2004-10-26 16:22 Sandro Santilli <strk at kbt.io>
* [r549] TODO: updated
-2004-10-26 16:09 Sandro Santilli <strk at keybit.net>
+2004-10-26 16:09 Sandro Santilli <strk at kbt.io>
* [r548] source/operation/polygonize/PolygonizeGraph.cpp,
source/operation/polygonize/polygonizeEdgeRing.cpp: Some more
intentation and envelope equality check fix.
-2004-10-21 22:29 Sandro Santilli <strk at keybit.net>
+2004-10-21 22:29 Sandro Santilli <strk at kbt.io>
* [r547] source/algorithm/LineIntersector.cpp,
@@ -24229,17 +26225,17 @@
and some more COMPUTE_Z rules
-2004-10-21 17:13 Sandro Santilli <strk at keybit.net>
+2004-10-21 17:13 Sandro Santilli <strk at kbt.io>
* [r546] source/io/WKTReader.cpp: Fixed bug introduced by previous
patch.
-2004-10-21 07:03 Sandro Santilli <strk at keybit.net>
+2004-10-21 07:03 Sandro Santilli <strk at kbt.io>
* [r545] source/io/WKTReader.cpp: Removed leak in ::readPolygonText
reported by Carlos A. Rueda
-2004-10-20 17:32 Sandro Santilli <strk at keybit.net>
+2004-10-20 17:32 Sandro Santilli <strk at kbt.io>
* [r544] source/algorithm/HCoordinate.cpp,
@@ -24258,11 +26254,11 @@
source/operation/overlay/PointBuilder.cpp: Initial approach to
2.5d intersection()
-2004-10-19 21:04 Sandro Santilli <strk at keybit.net>
+2004-10-19 21:04 Sandro Santilli <strk at kbt.io>
* [r543] TODO: updated
-2004-10-19 19:51 Sandro Santilli <strk at keybit.net>
+2004-10-19 19:51 Sandro Santilli <strk at kbt.io>
* [r542] source/geomgraph/GeometryGraph.cpp,
@@ -24279,7 +26275,7 @@
in Polygonizer.
Output still bogus.
-2004-10-18 12:43 Sandro Santilli <strk at keybit.net>
+2004-10-18 12:43 Sandro Santilli <strk at kbt.io>
* [r541] Makefile.am, configure.in, swig, swig/.cvsignore,
swig/Makefile.am, swig/python, swig/python/.cvsignore,
@@ -24289,7 +26285,7 @@
swig/python/tests/cases/Makefile.am: swig interface added to
distribution.
-2004-10-13 10:03 Sandro Santilli <strk at keybit.net>
+2004-10-13 10:03 Sandro Santilli <strk at kbt.io>
* [r540] doc/example.cpp, source/geom/CoordinateSequence.cpp,
source/geom/Makefile.am, source/geomgraph/PlanarGraph.cpp,
@@ -24316,7 +26312,7 @@
planargraph (used by them).
Some comments and indentation changes.
-2004-09-23 21:36 Sandro Santilli <strk at keybit.net>
+2004-09-23 21:36 Sandro Santilli <strk at kbt.io>
* [r539] source/geom/CoordinateSequence.cpp: Fixed a bug in
::reverse (thanks to Elliott Edwards)
@@ -24330,69 +26326,69 @@
* [r537] configure.in: Bumped minor version to 2.0.2 after 2.0.1
release.
-2004-09-21 09:47 Sandro Santilli <strk at keybit.net>
+2004-09-21 09:47 Sandro Santilli <strk at kbt.io>
* [r536] source/precision/SimpleGeometryPrecisionReducer.cpp: fixed
a mis-initialization bug in ::reduce
* [r535] source/index/quadtree/DoubleBits.cpp: Removed useless
auto_ptr usage in ::exponent
-2004-09-16 09:50 Sandro Santilli <strk at keybit.net>
+2004-09-16 09:50 Sandro Santilli <strk at kbt.io>
* [r534] TODO: updated
-2004-09-16 09:48 Sandro Santilli <strk at keybit.net>
+2004-09-16 09:48 Sandro Santilli <strk at kbt.io>
* [r533] source/geom/Geometry.cpp: Finer short-circuit tests for
equals, within, contains.
* [r532] source/geom/Envelope.cpp, source/headers/geos/geom.h:
Added Envelope::equals
-2004-09-16 07:32 Sandro Santilli <strk at keybit.net>
+2004-09-16 07:32 Sandro Santilli <strk at kbt.io>
* [r531] TODO: updated
* [r530] source/geom/Geometry.cpp: Added short-circuit tests. Can
be disabled at compile-time
-2004-09-13 12:50 Sandro Santilli <strk at keybit.net>
+2004-09-13 12:50 Sandro Santilli <strk at kbt.io>
* [r529] source/operation/valid/IsValidOp.cpp: comments cleanup
-2004-09-13 12:40 Sandro Santilli <strk at keybit.net>
+2004-09-13 12:40 Sandro Santilli <strk at kbt.io>
* [r528] TODO: updated
* [r527] configure.in: Updated version number
-2004-09-13 12:39 Sandro Santilli <strk at keybit.net>
+2004-09-13 12:39 Sandro Santilli <strk at kbt.io>
* [r526] source/test/XMLTester.cpp: Added missing newline at end of
output
* [r525] source/geom/MultiPoint.cpp, source/geom/Point.cpp,
source/headers/geos/geom.h, source/headers/geos/opValid.h,
source/operation/valid/IsValidOp.cpp: Made Point and MultiPoint
subject to Validity tests.
-2004-09-13 10:14 Sandro Santilli <strk at keybit.net>
+2004-09-13 10:14 Sandro Santilli <strk at kbt.io>
* [r524] source/operation/valid/TopologyValidationError.cpp: Added
INVALID_COORDINATE code num and error message.
-2004-09-13 10:12 Sandro Santilli <strk at keybit.net>
+2004-09-13 10:12 Sandro Santilli <strk at kbt.io>
* [r523] TODO, source/headers/geos/geosAlgorithm.h,
@@ -24400,13 +26396,13 @@
checks in IsValidOp.
Cleanups.
-2004-09-13 09:18 Sandro Santilli <strk at keybit.net>
+2004-09-13 09:18 Sandro Santilli <strk at kbt.io>
* [r522] source/headers/geos/opValid.h,
source/operation/valid/IsValidOp.cpp: Added
IsValidOp::isValid(Coordinate &)
-2004-09-13 09:07 Sandro Santilli <strk at keybit.net>
+2004-09-13 09:07 Sandro Santilli <strk at kbt.io>
* [r521] source/geom/LineString.cpp: Ported fix in
LineString::isCoordinate
@@ -24417,7 +26413,7 @@
source/geom/MultiLineString.cpp, source/geom/MultiPoint.cpp:
Casting changes to allow OS/X compilation.
-2004-09-07 08:29 Sandro Santilli <strk at keybit.net>
+2004-09-07 08:29 Sandro Santilli <strk at kbt.io>
* [r519] source/headers/geos/geom.h: Fixed doxygen malformed
comment for Coordinate class
@@ -24432,12 +26428,12 @@
* [r516] configure.in: Removed examples from build directories for
release (they don't build now).
-2004-08-04 08:26 Sandro Santilli <strk at keybit.net>
+2004-08-04 08:26 Sandro Santilli <strk at kbt.io>
* [r515] source/operation/relate/RelateComputer.cpp: comments lift,
stack allocation reduced
-2004-07-27 16:35 Sandro Santilli <strk at keybit.net>
+2004-07-27 16:35 Sandro Santilli <strk at kbt.io>
* [r514] source/algorithm/InteriorPointArea.cpp,
source/algorithm/SIRtreePointInRing.cpp,
@@ -24480,7 +26476,7 @@
swig/python/tests/cases/wkttest.py: added simple exception
handling on all method calls
-2004-07-26 16:35 Sandro Santilli <strk at keybit.net>
+2004-07-26 16:35 Sandro Santilli <strk at kbt.io>
* [r511] source/headers/geos/geom.h: Removed dangling
MultiPoint::isClosed() method definition.
@@ -24508,33 +26504,33 @@
today's CVS GEOS, and the test passes -- means that a module can
be built, installed, and imported.
-2004-07-22 16:58 Sandro Santilli <strk at keybit.net>
+2004-07-22 16:58 Sandro Santilli <strk at kbt.io>
* [r508] TODO, doc/example.cpp, source/geom/Geometry.cpp,
source/headers/geos/geom.h: runtime version extractor functions
split. geos::version() is now
geos::geosversion() and geos::jtsport()
-2004-07-22 08:45 Sandro Santilli <strk at keybit.net>
+2004-07-22 08:45 Sandro Santilli <strk at kbt.io>
* [r507] TODO, source/geom/GeometryCollection.cpp,
source/geom/LineString.cpp, source/geom/MultiLineString.cpp,
source/geom/MultiPoint.cpp, source/headers/geos/geom.h:
Documentation updates, memory leaks fixed.
-2004-07-22 07:19 Sandro Santilli <strk at keybit.net>
+2004-07-22 07:19 Sandro Santilli <strk at kbt.io>
* [r506] source/headers/geos/geom.h: Changed getCoordinatesRO
description.
-2004-07-22 07:04 Sandro Santilli <strk at keybit.net>
+2004-07-22 07:04 Sandro Santilli <strk at kbt.io>
* [r505] source/geom/Coordinate.cpp,
source/geom/GeometryCollection.cpp, source/geom/Polygon.cpp,
source/headers/geos/geom.h: Documented missing geometry
functions.
-2004-07-21 09:55 Sandro Santilli <strk at keybit.net>
+2004-07-21 09:55 Sandro Santilli <strk at kbt.io>
* [r504] source/geom/Coordinate.cpp,
source/geom/CoordinateList.cpp,
@@ -24545,15 +26541,15 @@
CoordinateSequence::atLeastNCoordinatesOrNothing definition fix.
Documentation fixes.
-2004-07-21 09:11 Sandro Santilli <strk at keybit.net>
+2004-07-21 09:11 Sandro Santilli <strk at kbt.io>
* [r503] NEWS, README, TODO: Updated
-2004-07-20 08:35 Sandro Santilli <strk at keybit.net>
+2004-07-20 08:35 Sandro Santilli <strk at kbt.io>
* [r502] doc/README: Updated doxygen rule
-2004-07-20 08:34 Sandro Santilli <strk at keybit.net>
+2004-07-20 08:34 Sandro Santilli <strk at kbt.io>
* [r501] doc/Doxyfile.in, source/geom/CoordinateList.cpp,
source/geom/Geometry.cpp, source/headers/geos/geom.h,
@@ -24567,7 +26563,7 @@
dist" friendly. (and allow autogeneration of CVS snapshot to work
again.)
-2004-07-19 13:19 Sandro Santilli <strk at keybit.net>
+2004-07-19 13:19 Sandro Santilli <strk at kbt.io>
* [r499] doc/Doxyfile.in, source/geom/Envelope.cpp,
source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
@@ -24593,184 +26589,184 @@
source/headers/geos/spatialIndex.h, source/io/WKTWriter.cpp:
Documentation fixes
-2004-07-19 10:38 Sandro Santilli <strk at keybit.net>
+2004-07-19 10:38 Sandro Santilli <strk at kbt.io>
* [r498] doc, doc/.cvsignore: Added Doxyfile
* [r497] TODO: updated
-2004-07-19 10:37 Sandro Santilli <strk at keybit.net>
+2004-07-19 10:37 Sandro Santilli <strk at kbt.io>
* [r496] doc/Makefile.am: Doxygen doc added to default build rules
* [r495] source/geom/DefaultCoordinateSequenceFactory.cpp:
defaultCoordinateSequenceFactory made module-static (use
DefaultCoordinateSequenceFactory::instance() instead)
-2004-07-19 10:35 Sandro Santilli <strk at keybit.net>
+2004-07-19 10:35 Sandro Santilli <strk at kbt.io>
* [r494] source/bigtest/GeometryTestFactory.cpp,
source/bigtest/TestSweepLineSpeed.cpp, source/bigtest/bigtest.h,
source/headers/geos/bigtest.h: bigtest.h moved to local dir
-2004-07-19 10:34 Sandro Santilli <strk at keybit.net>
+2004-07-19 10:34 Sandro Santilli <strk at kbt.io>
* [r493] source/headers/geos/geom.h: removed doxygen documentation
of removed feature
-2004-07-19 10:33 Sandro Santilli <strk at keybit.net>
+2004-07-19 10:33 Sandro Santilli <strk at kbt.io>
* [r492] source/headers/geos/io.h: Class documentation changed to
report geos.h as WKT writer/parser header file
-2004-07-19 10:30 Sandro Santilli <strk at keybit.net>
+2004-07-19 10:30 Sandro Santilli <strk at kbt.io>
* [r491] source/headers/acconfig.h,
source/headers/geos/Makefile.am, source/headers/geos/acconfig.h:
acconfig.h moved one directory up
-2004-07-19 10:28 Sandro Santilli <strk at keybit.net>
+2004-07-19 10:28 Sandro Santilli <strk at kbt.io>
* [r490] doc/Doxyfile.in: Excluded example and test dirs from input
set
-2004-07-17 10:48 Sandro Santilli <strk at keybit.net>
+2004-07-17 10:48 Sandro Santilli <strk at kbt.io>
* [r489] TODO: updated
* [r488] doc, doc/.cvsignore: added Doxyfile (generated)
* [r487] source/geom/Geometry.cpp: fixed typo in documentation
-2004-07-17 10:47 Sandro Santilli <strk at keybit.net>
+2004-07-17 10:47 Sandro Santilli <strk at kbt.io>
* [r486] configure.in, doc/Doxyfile, doc/Doxyfile.in: Doxygen
configuration created at ./configure time, for versioning.
-2004-07-17 09:19 Sandro Santilli <strk at keybit.net>
+2004-07-17 09:19 Sandro Santilli <strk at kbt.io>
* [r485] doc/example.cpp: added GEOS version report
-2004-07-17 09:18 Sandro Santilli <strk at keybit.net>
+2004-07-17 09:18 Sandro Santilli <strk at kbt.io>
* [r484] source/geom/Geometry.cpp, source/headers/geos/geom.h:
Added geos::version()
-2004-07-17 09:07 Sandro Santilli <strk at keybit.net>
+2004-07-17 09:07 Sandro Santilli <strk at kbt.io>
* [r483] tools/geos-config.in: Added --jtsport
-2004-07-17 09:06 Sandro Santilli <strk at keybit.net>
+2004-07-17 09:06 Sandro Santilli <strk at kbt.io>
* [r482] source/headers/geos/version.h.in: Added
GEOS_FIRST_INTERFACE, GEOS_LAST_INTERFACE and GEOS_JTS_PORT
-2004-07-17 09:05 Sandro Santilli <strk at keybit.net>
+2004-07-17 09:05 Sandro Santilli <strk at kbt.io>
* [r481] configure.in: Added JTS_PORT variable.
Simplified versioning settings: comments added,
major/minor/patchlevel
extracted by CURRENT,AGE,REVISION.
-2004-07-16 17:02 Sandro Santilli <strk at keybit.net>
+2004-07-16 17:02 Sandro Santilli <strk at kbt.io>
* [r480] TODO: updated
-2004-07-16 16:20 Sandro Santilli <strk at keybit.net>
+2004-07-16 16:20 Sandro Santilli <strk at kbt.io>
* [r479] configure.in, source/geom/Makefile.am: Libtool versioning
scheme adopted.
-2004-07-16 16:09 Sandro Santilli <strk at keybit.net>
+2004-07-16 16:09 Sandro Santilli <strk at kbt.io>
* [r478] doc/Makefile.am: removed useless Includedir
-2004-07-16 15:57 Sandro Santilli <strk at keybit.net>
+2004-07-16 15:57 Sandro Santilli <strk at kbt.io>
* [r477] source/headers/geos.h: made includes use <>
-2004-07-16 13:27 Sandro Santilli <strk at keybit.net>
+2004-07-16 13:27 Sandro Santilli <strk at kbt.io>
* [r476] TODO: updated
-2004-07-16 10:28 Sandro Santilli <strk at keybit.net>
+2004-07-16 10:28 Sandro Santilli <strk at kbt.io>
* [r475] source/headers/geos/util.h,
source/util/GeometricShapeFactory.cpp: Dimesions object allocated
on the heap
-2004-07-16 10:00 Sandro Santilli <strk at keybit.net>
+2004-07-16 10:00 Sandro Santilli <strk at kbt.io>
* [r474] doc/example.cpp: Bug fixed in GeometricShapeFactory
examples.
Added example of GeometricShapeFactory::createArc.
-2004-07-16 09:58 Sandro Santilli <strk at keybit.net>
+2004-07-16 09:58 Sandro Santilli <strk at kbt.io>
* [r473] TODO: updated
* [r472] doc/example.tosql: Added LINEARRING to LINESTRING
conversion
-2004-07-16 09:57 Sandro Santilli <strk at keybit.net>
+2004-07-16 09:57 Sandro Santilli <strk at kbt.io>
* [r471] source/geom/Makefile.am: Modified library version to 1.4.0
-2004-07-15 13:41 Sandro Santilli <strk at keybit.net>
+2004-07-15 13:41 Sandro Santilli <strk at kbt.io>
* [r470] doc/example.cpp: Added createRectangle example.
-2004-07-15 13:40 Sandro Santilli <strk at keybit.net>
+2004-07-15 13:40 Sandro Santilli <strk at kbt.io>
* [r469] source/util/GeometricShapeFactory.cpp: Memory leaks fixed,
CoordinateSequence use made JTS - compatible.
-2004-07-14 21:21 Sandro Santilli <strk at keybit.net>
+2004-07-14 21:21 Sandro Santilli <strk at kbt.io>
* [r468] TODO: updated
-2004-07-14 21:20 Sandro Santilli <strk at keybit.net>
+2004-07-14 21:20 Sandro Santilli <strk at kbt.io>
* [r467] source/geom/Geometry.cpp: Added GeometricShapeFactory note
on doxygen mainpage
* [r466] source/headers/geos.h: added geos/io.h and geos/unload.h
-2004-07-14 21:19 Sandro Santilli <strk at keybit.net>
+2004-07-14 21:19 Sandro Santilli <strk at kbt.io>
* [r465] source/headers/geos/util.h,
source/util/GeometricShapeFactory.cpp: GeometricShapeFactory
first pass of bug fixes
-2004-07-14 21:17 Sandro Santilli <strk at keybit.net>
+2004-07-14 21:17 Sandro Santilli <strk at kbt.io>
* [r464] source/geom/Makefile.am: added missing
* [r463] source/geom/Coordinate.cpp, source/headers/geos/geom.h:
added inequality operator for Coordinate
-2004-07-14 21:15 Sandro Santilli <strk at keybit.net>
+2004-07-14 21:15 Sandro Santilli <strk at kbt.io>
* [r462] doc/example.cpp, doc/example.tosql: Added
GeometricShapeFactory example: createCircle.
Added simple filter to send example output to a postgis table.
-2004-07-13 08:33 Sandro Santilli <strk at keybit.net>
+2004-07-13 08:33 Sandro Santilli <strk at kbt.io>
* [r461] source/geom/GeometryFactory.cpp, source/geom/Polygon.cpp,
source/headers/geos/geom.h, source/headers/geos/geomgraph.h,
@@ -24792,21 +26788,21 @@
virtual destructor to virtual classes.
Fixed implicit unsigned int -> int casts
-2004-07-12 19:16 Sandro Santilli <strk at keybit.net>
+2004-07-12 19:16 Sandro Santilli <strk at kbt.io>
* [r460] source/headers/geos/geom.h: Commented out CoordinateList
class definition.
-2004-07-12 15:42 Sandro Santilli <strk at keybit.net>
+2004-07-12 15:42 Sandro Santilli <strk at kbt.io>
* [r459] source/geom/PrecisionModel.cpp: Fixed maximumPreciseValue
scope
-2004-07-09 08:01 Sandro Santilli <strk at keybit.net>
+2004-07-09 08:01 Sandro Santilli <strk at kbt.io>
* [r458] TODO: updated
-2004-07-08 19:41 Sandro Santilli <strk at keybit.net>
+2004-07-08 19:41 Sandro Santilli <strk at kbt.io>
* [r457] source/examples/CoordinateListsExample.cpp,
source/examples/CoordinateSequencesExample.cpp,
@@ -24818,7 +26814,7 @@
source/examples/CustomPointCoordinateSequence.cpp: renamed to
reflect JTS API.
-2004-07-08 19:38 Sandro Santilli <strk at keybit.net>
+2004-07-08 19:38 Sandro Santilli <strk at kbt.io>
* [r456] source/geom/CoordinateSequence.cpp,
source/geom/CoordinateSequenceFactory.cpp,
@@ -24828,22 +26824,22 @@
source/geom/PointCoordinateSequenceFactory.cpp: renamed from
*List* equivalents
-2004-07-08 19:37 Sandro Santilli <strk at keybit.net>
+2004-07-08 19:37 Sandro Santilli <strk at kbt.io>
* [r455] source/geom/PointCoordinateList.cpp: Renamed to
* [r454] source/geom/CoordinateListFactory.cpp: Renamed to
-2004-07-08 19:36 Sandro Santilli <strk at keybit.net>
+2004-07-08 19:36 Sandro Santilli <strk at kbt.io>
* [r453] source/geom/BasicCoordinateList.cpp: Renamed to
-2004-07-08 19:34 Sandro Santilli <strk at keybit.net>
+2004-07-08 19:34 Sandro Santilli <strk at kbt.io>
* [r452] TODO, doc/example.cpp, source/Makefile.am,
@@ -24922,17 +26918,17 @@
default implementations.
Added DefaultCoordinateSequenceFactory::instance() function.
-2004-07-07 18:54 Sandro Santilli <strk at keybit.net>
+2004-07-07 18:54 Sandro Santilli <strk at kbt.io>
* [r451] TODO: updated
-2004-07-07 10:29 Sandro Santilli <strk at keybit.net>
+2004-07-07 10:29 Sandro Santilli <strk at kbt.io>
* [r450] source/algorithm/NotRepresentableException.cpp,
source/headers/geos/geosAlgorithm.h, source/headers/geos/io.h,
source/headers/geos/util.h: Adjusted exceptions documentation.
-2004-07-07 09:38 Sandro Santilli <strk at keybit.net>
+2004-07-07 09:38 Sandro Santilli <strk at kbt.io>
* [r449] NEWS, source/geom/Geometry.cpp,
source/headers/geos/geom.h, source/headers/geos/geosAlgorithm.h,
@@ -24944,14 +26940,14 @@
Updated XMLTester to respect the changes.
Main documentation page made nicer.
-2004-07-07 07:52 Sandro Santilli <strk at keybit.net>
+2004-07-07 07:52 Sandro Santilli <strk at kbt.io>
* [r448] TODO, source/operation/buffer/BufferSubgraph.cpp: Removed
note about required speedup in BufferSubgraph.
I've made tests with 'sets' and there is actually a big slow
down..
-2004-07-06 17:58 Sandro Santilli <strk at keybit.net>
+2004-07-06 17:58 Sandro Santilli <strk at kbt.io>
* [r447] source/geom/Geometry.cpp,
source/geom/GeometryCollection.cpp, source/geom/LineString.cpp,
@@ -24967,29 +26963,29 @@
of changing Geometry's factory. Reverted Geometry::factory member
to be a reference to external factory.
-2004-07-05 19:40 Sandro Santilli <strk at keybit.net>
+2004-07-05 19:40 Sandro Santilli <strk at kbt.io>
* [r446] source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
GeometryFactory::destroyGeometry(Geometry *)
-2004-07-05 15:20 Sandro Santilli <strk at keybit.net>
+2004-07-05 15:20 Sandro Santilli <strk at kbt.io>
* [r445] TODO, source/geom/Geometry.cpp,
source/headers/geos/geom.h: Documentation again.
-2004-07-05 14:23 Sandro Santilli <strk at keybit.net>
+2004-07-05 14:23 Sandro Santilli <strk at kbt.io>
* [r444] NEWS, source/geom/CoordinateList.cpp,
source/geom/GeometryFactory.cpp, source/geom/LineString.cpp,
source/geom/PrecisionModel.cpp, source/headers/geos/geom.h,
source/headers/geos/util.h: More documentation cleanups.
-2004-07-05 11:50 Sandro Santilli <strk at keybit.net>
+2004-07-05 11:50 Sandro Santilli <strk at kbt.io>
* [r443] doc/README: initial import
-2004-07-05 10:50 Sandro Santilli <strk at keybit.net>
+2004-07-05 10:50 Sandro Santilli <strk at kbt.io>
* [r442] NEWS, doc/Doxyfile, source/geom/BasicCoordinateList.cpp,
source/geom/Geometry.cpp, source/geom/GeometryCollection.cpp,
@@ -25009,12 +27005,12 @@
copy semantic (by-ref instead of by-pointer).
Cleaned up documentation.
-2004-07-03 12:54 Sandro Santilli <strk at keybit.net>
+2004-07-03 12:54 Sandro Santilli <strk at kbt.io>
* [r441] source/headers/geos, source/headers/geos/.cvsignore: more
entries
-2004-07-03 12:51 Sandro Santilli <strk at keybit.net>
+2004-07-03 12:51 Sandro Santilli <strk at kbt.io>
* [r440] source/algorithm/NotRepresentableException.cpp,
@@ -25022,18 +27018,18 @@
source/headers/geos.h, source/headers/geos/geom.h: Documentation
cleanups for DoxyGen.
-2004-07-02 17:22 Sandro Santilli <strk at keybit.net>
+2004-07-02 17:22 Sandro Santilli <strk at kbt.io>
* [r439] doc/Doxyfile, doc/Makefile.am, doc/geosDoxygen.conf:
Doxygen configuration file renamed.
-2004-07-02 14:27 Sandro Santilli <strk at keybit.net>
+2004-07-02 14:27 Sandro Santilli <strk at kbt.io>
* [r438] source/geom/GeometryFactory.cpp, source/geom/Point.cpp,
source/headers/geos/geom.h: Added deep-copy / take-ownerhship for
Point type.
-2004-07-02 13:28 Sandro Santilli <strk at keybit.net>
+2004-07-02 13:28 Sandro Santilli <strk at kbt.io>
* [r437] ChangeLog, README, configure.in, doc/Makefile.am,
doc/example.cpp, source/algorithm/CGAlgorithms.cpp,
@@ -25214,12 +27210,12 @@
lines to reflect headers layout change.
Added client application build tips in README.
-2004-07-02 13:21 Sandro Santilli <strk at keybit.net>
+2004-07-02 13:21 Sandro Santilli <strk at kbt.io>
* [r436] source/headers/geos_version.h.in: renamed to
geos/version.h.in
-2004-07-02 13:20 Sandro Santilli <strk at keybit.net>
+2004-07-02 13:20 Sandro Santilli <strk at kbt.io>
* [r435] source/headers, source/headers/.cvsignore,
source/headers/Makefile.am, source/headers/acconfig.h,
@@ -25264,18 +27260,18 @@
source/headers/spatialIndex.h, source/headers/unload.h,
source/headers/util.h: Header files moved under geos/ dir.
-2004-07-01 17:34 Sandro Santilli <strk at keybit.net>
+2004-07-01 17:34 Sandro Santilli <strk at kbt.io>
* [r434] source/geom/Geometry.cpp: GeometryFactory argument in
Geometry constructor reverted
to its copy-and-destroy semantic.
-2004-07-01 17:07 Sandro Santilli <strk at keybit.net>
+2004-07-01 17:07 Sandro Santilli <strk at kbt.io>
* [r433] doc, doc/.cvsignore, doc/Makefile.am: Added doxygen_docs
generation rule
-2004-07-01 16:49 Sandro Santilli <strk at keybit.net>
+2004-07-01 16:49 Sandro Santilli <strk at kbt.io>
* [r432] doc/geosDoxygen.conf: re-generated with doxygen 1.2.15
@@ -25284,7 +27280,7 @@
* [r431] doc/geosDoxygen.conf: Added doxygen file for better doco
generation.
-2004-07-01 14:12 Sandro Santilli <strk at keybit.net>
+2004-07-01 14:12 Sandro Santilli <strk at kbt.io>
* [r430] ChangeLog, NEWS, TODO, doc/example.cpp,
source/algorithm/ConvexHull.cpp,
@@ -25313,7 +27309,7 @@
Same functionality is available through GeometryFactory,
including buildGeometry().
-2004-06-30 20:59 Sandro Santilli <strk at keybit.net>
+2004-06-30 20:59 Sandro Santilli <strk at kbt.io>
* [r429] source/geom/Geometry.cpp,
@@ -25328,11 +27324,11 @@
GeoemtryFactory copy from geometry constructors.
Enforced const-correctness on GeometryFactory arguments.
-2004-06-28 21:58 Sandro Santilli <strk at keybit.net>
+2004-06-28 21:58 Sandro Santilli <strk at kbt.io>
* [r428] source/geom/Polygon.cpp: Constructors speedup.
-2004-06-28 21:11 Sandro Santilli <strk at keybit.net>
+2004-06-28 21:11 Sandro Santilli <strk at kbt.io>
* [r427] source/geom/GeometryCollection.cpp,
@@ -25343,34 +27339,34 @@
module.
Added holes argument check in Polygon.cpp.
-2004-06-25 14:26 Sandro Santilli <strk at keybit.net>
+2004-06-25 14:26 Sandro Santilli <strk at kbt.io>
* [r426] tools/geos-config.in: fixed --includes
-2004-06-22 16:57 Sandro Santilli <strk at keybit.net>
+2004-06-22 16:57 Sandro Santilli <strk at kbt.io>
* [r425] NEWS: Written down some news
-2004-06-22 16:56 Sandro Santilli <strk at keybit.net>
+2004-06-22 16:56 Sandro Santilli <strk at kbt.io>
* [r424] source/headers/Makefile.am, source/headers/geos.h: Added
geos.h file.
-2004-06-21 22:14 Sandro Santilli <strk at keybit.net>
+2004-06-21 22:14 Sandro Santilli <strk at kbt.io>
* [r423] source/headers, source/headers/.cvsignore: added
geos_version.h
-2004-06-21 22:13 Sandro Santilli <strk at keybit.net>
+2004-06-21 22:13 Sandro Santilli <strk at kbt.io>
* [r422] TODO: updated
* [r421] configure.in, source/headers/Makefile.am,
source/headers/geos_version.h.in: Added VERSION defines
-2004-06-16 13:13 Sandro Santilli <strk at keybit.net>
+2004-06-16 13:13 Sandro Santilli <strk at kbt.io>
* [r420] TODO, source/geom/BasicCoordinateList.cpp,
source/geom/GeometryFactory.cpp, source/geom/MultiPolygon.cpp,
@@ -25384,22 +27380,22 @@
constructors.
Other associated fixes.
-2004-06-15 21:35 Sandro Santilli <strk at keybit.net>
+2004-06-15 21:35 Sandro Santilli <strk at kbt.io>
* [r419] source/geom/GeometryFactory.cpp: fixed buildGeometry to
always return a newly allocated geometry
-2004-06-15 20:42 Sandro Santilli <strk at keybit.net>
+2004-06-15 20:42 Sandro Santilli <strk at kbt.io>
* [r418] doc/example.cpp, source/geom/LineString.cpp,
source/geom/MultiPolygon.cpp, source/geom/Polygon.cpp: updated to
respect deep-copy GeometryCollection interface
-2004-06-15 20:30 Sandro Santilli <strk at keybit.net>
+2004-06-15 20:30 Sandro Santilli <strk at kbt.io>
* [r417] source/io/WKTReader.cpp: fixed a typo
-2004-06-15 20:20 Sandro Santilli <strk at keybit.net>
+2004-06-15 20:20 Sandro Santilli <strk at kbt.io>
* [r416] source/geom/util/GeometryEditor.cpp,
source/io/WKTReader.cpp,
@@ -25407,31 +27403,31 @@
source/operation/overlay/OverlayOp.cpp: updated to respect
-2004-06-15 20:07 Sandro Santilli <strk at keybit.net>
+2004-06-15 20:07 Sandro Santilli <strk at kbt.io>
* [r415] source/geom/GeometryCollection.cpp,
source/geom/GeometryFactory.cpp, source/headers/geom.h:
GeometryCollections constructors make a deep copy of Geometry
vector argument.
-2004-06-15 20:01 Sandro Santilli <strk at keybit.net>
+2004-06-15 20:01 Sandro Santilli <strk at kbt.io>
* [r414] source/operation/buffer/BufferBuilder.cpp: Empty geometry
creation call made using NULL instead of newly created empty
vector (will be faster)
-2004-06-15 19:24 Sandro Santilli <strk at keybit.net>
+2004-06-15 19:24 Sandro Santilli <strk at kbt.io>
* [r413] tools/geos-config.in: Fixed a bug preventing geos-config
from giving correct version info
-2004-06-15 07:40 Sandro Santilli <strk at keybit.net>
+2004-06-15 07:40 Sandro Santilli <strk at kbt.io>
* [r412] source/noding/SegmentNode.cpp,
source/planargraph/planarDirectedEdge.cpp: Added missing
<stdio.h> include
* [r411] TODO: Updated
@@ -25440,83 +27436,83 @@
* [r410] source/geom/PrecisionModel.cpp: Changed rounding method to
make compilable with VC++
-2004-05-27 12:09 Sandro Santilli <strk at keybit.net>
+2004-05-27 12:09 Sandro Santilli <strk at kbt.io>
* [r409] source/test/testLeaksBig.xml: added one buffer test
-2004-05-27 10:27 Sandro Santilli <strk at keybit.net>
+2004-05-27 10:27 Sandro Santilli <strk at kbt.io>
* [r408] source/noding/SegmentNodeList.cpp,
source/noding/SegmentString.cpp: Memory leaks fixed.
-2004-05-27 10:26 Sandro Santilli <strk at keybit.net>
+2004-05-27 10:26 Sandro Santilli <strk at kbt.io>
* [r407] source/noding/nodingSegmentIntersector.cpp: set (useless?)
recordIsolated member in constructor
-2004-05-27 09:53 Sandro Santilli <strk at keybit.net>
+2004-05-27 09:53 Sandro Santilli <strk at kbt.io>
* [r406] source/headers/indexChain.h:
MonotoneChainOverlapAction::overlap(*) funx made virtual
as they are supposed to be.
-2004-05-27 08:40 Sandro Santilli <strk at keybit.net>
+2004-05-27 08:40 Sandro Santilli <strk at kbt.io>
* [r405] source/test/XMLTester.cpp: Fixed a memleak in buffer test.
-2004-05-27 08:37 Sandro Santilli <strk at keybit.net>
+2004-05-27 08:37 Sandro Santilli <strk at kbt.io>
* [r404] source/headers/opBuffer.h,
source/operation/buffer/OffsetCurveBuilder.cpp: Fixed a bug
preventing OffsetCurveBuilder point list from being reset.
-2004-05-26 19:48 Sandro Santilli <strk at keybit.net>
+2004-05-26 19:48 Sandro Santilli <strk at kbt.io>
* [r403] source/operation/buffer/OffsetCurveBuilder.cpp,
source/operation/buffer/OffsetCurveSetBuilder.cpp: Changed abs()
to fabs() when working with doubles.
Used dynamic_cast<> instead of typeid() when JTS uses instanceof.
-2004-05-26 13:12 Sandro Santilli <strk at keybit.net>
+2004-05-26 13:12 Sandro Santilli <strk at kbt.io>
* [r402] source/operation/buffer/BufferBuilder.cpp: Removed
try/catch block from ::buildSubgraphs
-2004-05-26 09:50 Sandro Santilli <strk at keybit.net>
+2004-05-26 09:50 Sandro Santilli <strk at kbt.io>
* [r401] source/headers/geomgraph.h: Added comments about
OverlayNodeFactory() ownership in NodeMap and PlanarGraph
constuctors
-2004-05-26 09:49 Sandro Santilli <strk at keybit.net>
+2004-05-26 09:49 Sandro Santilli <strk at kbt.io>
* [r400] source/headers/opBuffer.h,
source/operation/buffer/BufferBuilder.cpp: PlanarGraph made local
to ::buffer instead of Class private.
-2004-05-21 14:17 Sandro Santilli <strk at keybit.net>
+2004-05-21 14:17 Sandro Santilli <strk at kbt.io>
* [r399] TODO: updated
-2004-05-21 13:58 Sandro Santilli <strk at keybit.net>
+2004-05-21 13:58 Sandro Santilli <strk at kbt.io>
* [r398] source/geom/Geometry.cpp: ::intersection missed to
invalidate geometryCollection inputs
-2004-05-21 13:55 Sandro Santilli <strk at keybit.net>
+2004-05-21 13:55 Sandro Santilli <strk at kbt.io>
* [r397] TODO: updated
-2004-05-21 13:39 Sandro Santilli <strk at keybit.net>
+2004-05-21 13:39 Sandro Santilli <strk at kbt.io>
* [r396] source/geom/PrecisionModel.cpp: ::makePrecise make use of
nearbyint() now, to be compatible with JTS
-2004-05-21 13:37 Sandro Santilli <strk at keybit.net>
+2004-05-21 13:37 Sandro Santilli <strk at kbt.io>
* [r395] source/test/testLeaksBig.xml: first import
-2004-05-20 09:14 Sandro Santilli <strk at keybit.net>
+2004-05-20 09:14 Sandro Santilli <strk at kbt.io>
* [r394] TODO: updated
@@ -25525,23 +27521,23 @@
* [r393] source/geom/PrecisionModel.cpp: Changed rounding method to
-2004-05-19 13:40 Sandro Santilli <strk at keybit.net>
+2004-05-19 13:40 Sandro Santilli <strk at kbt.io>
* [r392] source/operation/buffer/OffsetCurveBuilder.cpp: Fixed bug
in ::addCircle
-2004-05-19 13:18 Sandro Santilli <strk at keybit.net>
+2004-05-19 13:18 Sandro Santilli <strk at kbt.io>
* [r391] source/geom/BasicCoordinateList.cpp,
source/geom/PointCoordinateList.cpp, source/headers/geom.h: made
CoordinateList::toString() a const member function
-2004-05-19 13:01 Sandro Santilli <strk at keybit.net>
+2004-05-19 13:01 Sandro Santilli <strk at kbt.io>
* [r390] source/operation/buffer/BufferOp.cpp: avoided assignment
operator calls for BufferBuilder
-2004-05-19 12:50 Sandro Santilli <strk at keybit.net>
+2004-05-19 12:50 Sandro Santilli <strk at kbt.io>
* [r389] source/operation/buffer/BufferSubgraph.cpp: Removed all
try/catch blocks transforming stack allocated-vectors to
@@ -25552,13 +27548,13 @@
* [r388] source/operation/buffer/OffsetCurveSetBuilder.cpp: Bugfix
in OffsetCurveSetBuilder::addPolygon (JTS 1.4.1)
-2004-05-18 13:49 Sandro Santilli <strk at keybit.net>
+2004-05-18 13:49 Sandro Santilli <strk at kbt.io>
* [r387] source/test/XMLTester.cpp: Output made more neat (geometry
B is not printed if not existent).
Added support for buffer tests.
-2004-05-18 13:15 Sandro Santilli <strk at keybit.net>
+2004-05-18 13:15 Sandro Santilli <strk at kbt.io>
* [r386] source/geom/CoordinateList.cpp: made ::scroll handle
already scrolled vect and more readable
@@ -25586,58 +27582,58 @@
* [r382] source/geom/CoordinateList.cpp, source/headers/geom.h:
JavaDoc updated
-2004-05-17 12:54 Sandro Santilli <strk at keybit.net>
+2004-05-17 12:54 Sandro Santilli <strk at kbt.io>
* [r381] source/io/markup/MarkupSTL.cpp: Added tab in list of blank
chars
-2004-05-17 12:53 Sandro Santilli <strk at keybit.net>
+2004-05-17 12:53 Sandro Santilli <strk at kbt.io>
* [r380] source/test/XMLTester.cpp: Expected result string trimmed
for blanks
-2004-05-17 12:37 Sandro Santilli <strk at keybit.net>
+2004-05-17 12:37 Sandro Santilli <strk at kbt.io>
* [r379] source/io/StringTokenizer.cpp: Added carriage returns and
tabs in set of blanks chars
-2004-05-17 12:36 Sandro Santilli <strk at keybit.net>
+2004-05-17 12:36 Sandro Santilli <strk at kbt.io>
* [r378] source/io/ParseException.cpp: ParseException message made
more readable
-2004-05-17 10:45 Sandro Santilli <strk at keybit.net>
+2004-05-17 10:45 Sandro Santilli <strk at kbt.io>
* [r377] source/geom/PrecisionModel.cpp: Fixed bogus FIXED
coordinate rounding
-2004-05-17 08:34 Sandro Santilli <strk at keybit.net>
+2004-05-17 08:34 Sandro Santilli <strk at kbt.io>
* [r376] source/operation/overlay/OverlayOp.cpp: reduced stack
allocations, try/catch blocks in ::overlayOp
-2004-05-17 07:42 Sandro Santilli <strk at keybit.net>
+2004-05-17 07:42 Sandro Santilli <strk at kbt.io>
* [r375] source/algorithm/CentroidArea.cpp: CentroidArea::add(const
Geometry *geom) uses dynamic_cast
-2004-05-17 07:23 Sandro Santilli <strk at keybit.net>
+2004-05-17 07:23 Sandro Santilli <strk at kbt.io>
* [r374] source/geom/Geometry.cpp: ::getCeontroid(): reduced
dynamic allocations, added missing check for isEmpty
-2004-05-14 14:47 Sandro Santilli <strk at keybit.net>
+2004-05-14 14:47 Sandro Santilli <strk at kbt.io>
* [r373]
source/operation/distance/ConnectedElementLocationFilter.cpp:
Added LinearRing support
-2004-05-14 14:45 Sandro Santilli <strk at keybit.net>
+2004-05-14 14:45 Sandro Santilli <strk at kbt.io>
* [r372] source/headers/geomUtil.h: Fixed bogus inheritance of
LinearComponentExtracter
-2004-05-14 13:42 Sandro Santilli <strk at keybit.net>
+2004-05-14 13:42 Sandro Santilli <strk at kbt.io>
* [r371] source/geom/LineSegment.cpp,
source/geom/util/LinearComponentExtracter.cpp,
@@ -25648,23 +27644,23 @@
source/operation/distance/DistanceOp.cpp: DistanceOp bug removed,
cascading errors fixed.
-2004-05-14 12:14 Sandro Santilli <strk at keybit.net>
+2004-05-14 12:14 Sandro Santilli <strk at kbt.io>
* [r370] source/geom/Geometry.cpp, source/headers/geom.h: const
correctness
-2004-05-14 12:10 Sandro Santilli <strk at keybit.net>
+2004-05-14 12:10 Sandro Santilli <strk at kbt.io>
* [r369] source/io/WKTReader.cpp: avoided leaks on malformed
LinearRing
-2004-05-14 09:20 Sandro Santilli <strk at keybit.net>
+2004-05-14 09:20 Sandro Santilli <strk at kbt.io>
* [r368] source/geom/util/LinearComponentExtracter.cpp,
source/geom/util/PointExtracter.cpp,
source/geom/util/PolygonExtracter.cpp: Mem leaks fixed
-2004-05-14 07:19 Sandro Santilli <strk at keybit.net>
+2004-05-14 07:19 Sandro Santilli <strk at kbt.io>
* [r367] source/test/XMLTester.cpp: Changed the algorythm for
finding precisionModel type (current way did
@@ -25672,32 +27668,32 @@
FIXED,
otherwise it will be FLOATING.
-2004-05-07 14:15 Sandro Santilli <strk at keybit.net>
+2004-05-07 14:15 Sandro Santilli <strk at kbt.io>
* [r366] source/io/StringTokenizer.cpp: fixed peekNextToken to
avoid incrementing string pointer
-2004-05-07 14:13 Sandro Santilli <strk at keybit.net>
+2004-05-07 14:13 Sandro Santilli <strk at kbt.io>
* [r365] source/index/bintree/Bintree.cpp: Fixed segfault in
::insert
-2004-05-07 14:12 Sandro Santilli <strk at keybit.net>
+2004-05-07 14:12 Sandro Santilli <strk at kbt.io>
* [r364] source/algorithm/InteriorPointArea.cpp: Fixed segfault in
destructor
-2004-05-07 13:23 Sandro Santilli <strk at keybit.net>
+2004-05-07 13:23 Sandro Santilli <strk at kbt.io>
* [r363] source/io/WKTReader.cpp, source/test/XMLTester.cpp: Memory
leaks fixed.
-2004-05-07 13:04 Sandro Santilli <strk at keybit.net>
+2004-05-07 13:04 Sandro Santilli <strk at kbt.io>
* [r362] source/geom/MultiLineString.cpp: leak removed in
MultiLineString::getBoundary()
-2004-05-07 09:05 Sandro Santilli <strk at keybit.net>
+2004-05-07 09:05 Sandro Santilli <strk at kbt.io>
* [r361] source/geom/Geometry.cpp,
@@ -25707,7 +27703,7 @@
correctness added. Fixed bug in GeometryFactory::createMultiPoint
to handle NULL CoordinateList.
-2004-05-07 07:57 Sandro Santilli <strk at keybit.net>
+2004-05-07 07:57 Sandro Santilli <strk at kbt.io>
* [r360] source/geom/Makefile.am, source/headers/noding.h,
source/headers/opBuffer.h, source/noding/SegmentString.cpp,
@@ -25717,7 +27713,7 @@
(takes const void *), implemented local tracking of "contexts"
in caller objects for proper destruction.
-2004-05-06 16:30 Sandro Santilli <strk at keybit.net>
+2004-05-06 16:30 Sandro Santilli <strk at kbt.io>
* [r359] source/headers/indexBintree.h,
source/headers/indexQuadtree.h, source/index/bintree/Bintree.cpp,
@@ -25725,7 +27721,7 @@
objects by ensureExtent for Bintree and Quadtree,
deleted at destruction time. doc/example.cpp runs with no leaks.
-2004-05-06 15:54 Sandro Santilli <strk at keybit.net>
+2004-05-06 15:54 Sandro Santilli <strk at kbt.io>
* [r358] source/headers/noding.h,
@@ -25736,7 +27732,7 @@
SegmentString constructor copies given Label.
Buffer operation does no more leaks for doc/example.cpp
-2004-05-06 15:00 Sandro Santilli <strk at keybit.net>
+2004-05-06 15:00 Sandro Santilli <strk at kbt.io>
* [r357] source/headers/indexStrtree.h,
@@ -25748,17 +27744,17 @@
used to keep track of created node to cleanly delete them at
destruction time.
-2004-05-06 13:58 Sandro Santilli <strk at keybit.net>
+2004-05-06 13:58 Sandro Santilli <strk at kbt.io>
* [r356] source/index/strtree/STRtree.cpp: leak removed from
createParentBoundablesFromVerticalSlices
-2004-05-06 08:59 Sandro Santilli <strk at keybit.net>
+2004-05-06 08:59 Sandro Santilli <strk at kbt.io>
* [r355] source/index/strtree/AbstractSTRtree.cpp: memory leak
fixed
-2004-05-05 17:42 Sandro Santilli <strk at keybit.net>
+2004-05-05 17:42 Sandro Santilli <strk at kbt.io>
* [r354] source/headers/indexStrtree.h,
@@ -25771,33 +27767,33 @@
appropriate
Class in the subClasses).
-2004-05-05 16:57 Sandro Santilli <strk at keybit.net>
+2004-05-05 16:57 Sandro Santilli <strk at kbt.io>
* [r353] source/headers/opBuffer.h,
source/operation/buffer/BufferBuilder.cpp: Rewritten static cga
allocation to avoid copy constructor calls.
-2004-05-05 16:51 Sandro Santilli <strk at keybit.net>
+2004-05-05 16:51 Sandro Santilli <strk at kbt.io>
* [r352] source/geom/Geometry.cpp: avoided copy constructor in
Geometry::geometryChangedFilter initializzazion
-2004-05-05 16:39 Sandro Santilli <strk at keybit.net>
+2004-05-05 16:39 Sandro Santilli <strk at kbt.io>
* [r351] source/noding/MCQuadtreeNoder.cpp: reduced explicit local
objects allocation
-2004-05-05 16:36 Sandro Santilli <strk at keybit.net>
+2004-05-05 16:36 Sandro Santilli <strk at kbt.io>
* [r350] source/operation/buffer/BufferBuilder.cpp: Avoid use of
copy c'tors on local objects initializzation
-2004-05-05 15:51 Sandro Santilli <strk at keybit.net>
+2004-05-05 15:51 Sandro Santilli <strk at kbt.io>
* [r349] source/noding/MCQuadtreeNoder.cpp: Fixed big leak in
intersectChains()
-2004-05-05 13:08 Sandro Santilli <strk at keybit.net>
+2004-05-05 13:08 Sandro Santilli <strk at kbt.io>
* [r348] source/algorithm/MinimumDiameter.cpp,
source/operation/buffer/BufferBuilder.cpp,
@@ -25805,17 +27801,17 @@
source/operation/buffer/OffsetCurveSetBuilder.cpp: Leaks fixed,
explicit allocations/deallocations reduced.
-2004-05-05 12:29 Sandro Santilli <strk at keybit.net>
+2004-05-05 12:29 Sandro Santilli <strk at kbt.io>
* [r347] source/operation/buffer/SubgraphDepthLocater.cpp: memleak
fixed in ::getDepth
-2004-05-05 12:20 Sandro Santilli <strk at keybit.net>
+2004-05-05 12:20 Sandro Santilli <strk at kbt.io>
* [r346] source/geom/util/GeometryEditor.cpp: Memory leak plugged
in editGeometryCollection
-2004-05-05 10:54 Sandro Santilli <strk at keybit.net>
+2004-05-05 10:54 Sandro Santilli <strk at kbt.io>
* [r345] source/geom/Geometry.cpp, source/headers/geom.h,
source/headers/opBuffer.h, source/io/Unload.cpp,
@@ -25823,21 +27819,21 @@
static heap explicit allocation, less cleanup done by
the unloader.
-2004-05-05 10:44 Sandro Santilli <strk at keybit.net>
+2004-05-05 10:44 Sandro Santilli <strk at kbt.io>
* [r344] TODO: updated
-2004-05-05 10:22 Sandro Santilli <strk at keybit.net>
+2004-05-05 10:22 Sandro Santilli <strk at kbt.io>
* [r343] source/operation/buffer/BufferOp.cpp: Removed dynamic
allocations.
-2004-05-05 10:03 Sandro Santilli <strk at keybit.net>
+2004-05-05 10:03 Sandro Santilli <strk at kbt.io>
* [r342] source/operation/buffer/BufferOp.cpp: Reduced dynamic
allocations in bufferOriginalPrecision and bufferFixedPrecision.
-2004-05-03 22:56 Sandro Santilli <strk at keybit.net>
+2004-05-03 22:56 Sandro Santilli <strk at kbt.io>
* [r341] source/geomgraph/EdgeList.cpp, source/headers/noding.h,
source/index/strtree/AbstractSTRtree.cpp,
@@ -25849,13 +27845,13 @@
source/operation/buffer/SubgraphDepthLocater.cpp: leaks fixed,
exception specification omitted.
-2004-05-03 20:49 Sandro Santilli <strk at keybit.net>
+2004-05-03 20:49 Sandro Santilli <strk at kbt.io>
* [r340] source/geom/util/LinearComponentExtracter.cpp,
source/noding/SegmentNodeList.cpp: Some more leaks fixed
-2004-05-03 17:15 Sandro Santilli <strk at keybit.net>
+2004-05-03 17:15 Sandro Santilli <strk at kbt.io>
* [r339] source/geom/util/GeometryEditor.cpp,
source/headers/precision.h, source/index/strtree/STRtree.cpp,
@@ -25866,7 +27862,7 @@
source/precision/SimpleGeometryPrecisionReducer.cpp: leaks on
exception fixed.
-2004-05-03 16:29 Sandro Santilli <strk at keybit.net>
+2004-05-03 16:29 Sandro Santilli <strk at kbt.io>
* [r338] source/headers/indexStrtree.h,
@@ -25877,20 +27873,20 @@
in STRtree.cpp
and SIRtree.cpp.
-2004-05-03 13:17 Sandro Santilli <strk at keybit.net>
+2004-05-03 13:17 Sandro Santilli <strk at kbt.io>
* [r337] source/headers/indexStrtree.h,
source/index/strtree/AbstractSTRtree.cpp: Fixed comparator
function to express StrictWeakOrdering.
-2004-05-03 12:09 Sandro Santilli <strk at keybit.net>
+2004-05-03 12:09 Sandro Santilli <strk at kbt.io>
* [r336] source/noding/Noder.cpp, source/noding/SegmentNode.cpp,
source/noding/nodingSegmentIntersector.cpp,
source/planargraph/planarNodeMap.cpp: newline added at end of
file
-2004-05-03 10:43 Sandro Santilli <strk at keybit.net>
+2004-05-03 10:43 Sandro Santilli <strk at kbt.io>
* [r335] source/geomgraph/DirectedEdgeStar.cpp,
@@ -25903,7 +27899,7 @@
source/planargraph/planarDirectedEdge.cpp: Exception
specification considered harmful - left as comment.
-2004-04-30 09:15 Sandro Santilli <strk at keybit.net>
+2004-04-30 09:15 Sandro Santilli <strk at kbt.io>
* [r334] source/geom/Geometry.cpp, source/headers/noding.h,
source/headers/opBuffer.h, source/noding/IteratedNoder.cpp,
@@ -25911,7 +27907,7 @@
specifications to allow for AssertionFailedException.
Added missing initializers.
-2004-04-28 14:58 Sandro Santilli <strk at keybit.net>
+2004-04-28 14:58 Sandro Santilli <strk at kbt.io>
* [r333] source/index/strtree/AbstractSTRtree.cpp: Made
AbstractSTRtree::query use dynamic_cast<> to simulate java's
@@ -25927,24 +27923,24 @@
* [r332] configure.in: Bump version number to 1.4 to indicate new
changes.
-2004-04-26 12:37 Sandro Santilli <strk at keybit.net>
+2004-04-26 12:37 Sandro Santilli <strk at kbt.io>
* [r331] source/index/strtree/AbstractSTRtree.cpp,
source/index/strtree/STRtree.cpp: Some leaks fixed.
-2004-04-23 00:02 Sandro Santilli <strk at keybit.net>
+2004-04-23 00:02 Sandro Santilli <strk at kbt.io>
* [r330] source/headers/noding.h, source/headers/opBuffer.h,
source/operation/buffer/BufferOp.cpp: const-correctness changes
-2004-04-21 14:14 Sandro Santilli <strk at keybit.net>
+2004-04-21 14:14 Sandro Santilli <strk at kbt.io>
* [r329] source/geomgraph/DirectedEdgeStar.cpp: Fixed bug in
computeDepths
-2004-04-20 13:24 Sandro Santilli <strk at keybit.net>
+2004-04-20 13:24 Sandro Santilli <strk at kbt.io>
* [r328] source/algorithm/ConvexHull.cpp,
source/algorithm/MinimumDiameter.cpp, source/geom/LineString.cpp,
@@ -25952,12 +27948,12 @@
source/operation/buffer/BufferOp.cpp,
source/operation/overlay/OverlayOp.cpp: More leaks removed.
-2004-04-20 12:47 Sandro Santilli <strk at keybit.net>
+2004-04-20 12:47 Sandro Santilli <strk at kbt.io>
* [r327] source/algorithm/MinimumDiameter.cpp,
source/headers/geosAlgorithm.h: MinimumDiameter leaks plugged.
-2004-04-20 10:58 Sandro Santilli <strk at keybit.net>
+2004-04-20 10:58 Sandro Santilli <strk at kbt.io>
* [r326] source/headers/opBuffer.h,
@@ -25965,7 +27961,7 @@
source/operation/buffer/OffsetCurveSetBuilder.cpp: More memory
leaks removed.
-2004-04-20 10:14 Sandro Santilli <strk at keybit.net>
+2004-04-20 10:14 Sandro Santilli <strk at kbt.io>
* [r325] source/algorithm/MinimumDiameter.cpp,
source/geom/Geometry.cpp, source/geom/util/GeometryEditor.cpp,
@@ -25974,7 +27970,7 @@
source/precision/SimpleGeometryPrecisionReducer.cpp: Memory leaks
removed.
-2004-04-20 08:52 Sandro Santilli <strk at keybit.net>
+2004-04-20 08:52 Sandro Santilli <strk at kbt.io>
* [r324] source/geom/GeometryCollection.cpp,
@@ -25988,7 +27984,7 @@
Memory leaks removed from SimpleGeometryPrecisionReducer
and GeometryFactory.
-2004-04-19 16:14 Sandro Santilli <strk at keybit.net>
+2004-04-19 16:14 Sandro Santilli <strk at kbt.io>
* [r323] source/headers/noding.h, source/noding/IteratedNoder.cpp,
source/noding/MCQuadtreeNoder.cpp,
@@ -25997,7 +27993,7 @@
source/operation/buffer/OffsetCurveSetBuilder.cpp: Some memory
leaks plugged in noding algorithms.
-2004-04-19 15:14 Sandro Santilli <strk at keybit.net>
+2004-04-19 15:14 Sandro Santilli <strk at kbt.io>
* [r322] source/geomgraph/PlanarGraph.cpp,
source/headers/indexQuadtree.h, source/headers/opBuffer.h,
@@ -26010,7 +28006,7 @@
virtual destructor in SpatialIndex class.
Memory leaks fixes. Const and throw specifications added.
-2004-04-19 12:51 Sandro Santilli <strk at keybit.net>
+2004-04-19 12:51 Sandro Santilli <strk at kbt.io>
* [r321] source/headers/noding.h, source/headers/opBuffer.h,
@@ -26018,126 +28014,126 @@
source/operation/buffer/BufferOp.cpp: Memory leaks fixes. Throw
-2004-04-16 14:12 Sandro Santilli <strk at keybit.net>
+2004-04-16 14:12 Sandro Santilli <strk at kbt.io>
* [r320] source/geom/Point.cpp: Memory leak fix in copy constructor
-2004-04-16 14:09 Sandro Santilli <strk at keybit.net>
+2004-04-16 14:09 Sandro Santilli <strk at kbt.io>
* [r319] source/operation/buffer/BufferOp.cpp: Leaks fixes
-2004-04-16 13:03 Sandro Santilli <strk at keybit.net>
+2004-04-16 13:03 Sandro Santilli <strk at kbt.io>
* [r318] source/operation/buffer/OffsetCurveBuilder.cpp: More leaks
fixed
-2004-04-16 12:48 Sandro Santilli <strk at keybit.net>
+2004-04-16 12:48 Sandro Santilli <strk at kbt.io>
* [r317] source/noding/IteratedNoder.cpp,
source/operation/buffer/BufferSubgraph.cpp,
source/operation/buffer/OffsetCurveBuilder.cpp: Leak fixes.
-2004-04-16 11:04 Sandro Santilli <strk at keybit.net>
+2004-04-16 11:04 Sandro Santilli <strk at kbt.io>
* [r316] source/operation/buffer/BufferOp.cpp: Memory leaks plugged
on exception thrown
-2004-04-16 10:00 Sandro Santilli <strk at keybit.net>
+2004-04-16 10:00 Sandro Santilli <strk at kbt.io>
* [r315] source/operation/buffer/BufferOp.cpp: Memory leak fixed.
-2004-04-16 09:01 Sandro Santilli <strk at keybit.net>
+2004-04-16 09:01 Sandro Santilli <strk at kbt.io>
* [r314] source/algorithm/CGAlgorithms.cpp: Removed memory leak in
CGAlgorithms::isOnline
-2004-04-16 08:52 Sandro Santilli <strk at keybit.net>
+2004-04-16 08:52 Sandro Santilli <strk at kbt.io>
* [r313] source/headers/planargraph.h, source/io/Unload.cpp:
Unload::Release final delete (static heap allocations should be
gone now)
-2004-04-16 08:35 Sandro Santilli <strk at keybit.net>
+2004-04-16 08:35 Sandro Santilli <strk at kbt.io>
* [r312] source/geom/GeometryFactory.cpp, source/geom/Point.cpp,
source/headers/geom.h: Memory leaks fixed and const correctness
applied for Point class.
-2004-04-16 07:42 Sandro Santilli <strk at keybit.net>
+2004-04-16 07:42 Sandro Santilli <strk at kbt.io>
* [r311] source/geom/PrecisionModel.cpp, source/headers/geom.h,
source/io/Unload.cpp: PrecisionModel::Type made an enum instead
of a Type.
-2004-04-15 15:11 Sandro Santilli <strk at keybit.net>
+2004-04-15 15:11 Sandro Santilli <strk at kbt.io>
* [r310] source/io/Unload.cpp: Commented out deletion that seems to
cause segfaults
-2004-04-15 14:00 Sandro Santilli <strk at keybit.net>
+2004-04-15 14:00 Sandro Santilli <strk at kbt.io>
* [r309] source/headers/geom.h, source/headers/opBuffer.h,
source/io/Unload.cpp: Added new cleanup to Unload::Release
-2004-04-14 13:56 Sandro Santilli <strk at keybit.net>
+2004-04-14 13:56 Sandro Santilli <strk at kbt.io>
* [r308] source/geom/Geometry.cpp, source/headers/geom.h: All
geometries returned by {from,to}InternalGeometry calls are
now deleted after use (unless NOT new).
Some 'commented' throw specifications in geom.h
-2004-04-14 13:14 Sandro Santilli <strk at keybit.net>
+2004-04-14 13:14 Sandro Santilli <strk at kbt.io>
* [r307] source/operation/overlay/OverlayOp.cpp: Removed deletion
of externally pointed GeometryFactory from OverlayOp destructor
-2004-04-14 12:28 Sandro Santilli <strk at keybit.net>
+2004-04-14 12:28 Sandro Santilli <strk at kbt.io>
* [r306] source/geom/GeometryCollection.cpp,
source/index/strtree/AbstractSTRtree.cpp: shouldNeverReachHere
exceptions made more verbose
-2004-04-14 11:05 Sandro Santilli <strk at keybit.net>
+2004-04-14 11:05 Sandro Santilli <strk at kbt.io>
* [r305] source/geom/util/GeometryEditor.cpp: Added support for
LinearRing in GeometryEditor
-2004-04-14 10:56 Sandro Santilli <strk at keybit.net>
+2004-04-14 10:56 Sandro Santilli <strk at kbt.io>
* [r304] source/operation/distance/DistanceOp.cpp: Uncommented
initializzazion and destruction of
DistanceOp::minDistanceLocation
-2004-04-14 09:38 Sandro Santilli <strk at keybit.net>
+2004-04-14 09:38 Sandro Santilli <strk at kbt.io>
* [r303] source/geom/PrecisionModel.cpp: PrecisionModel(double
newScale) missed to set the scale
-2004-04-14 09:30 Sandro Santilli <strk at keybit.net>
+2004-04-14 09:30 Sandro Santilli <strk at kbt.io>
* [r302] source/headers/noding.h, source/noding/IteratedNoder.cpp:
Private iterated noding funx now use int* instead of vector to
know
when it's time to stop.
-2004-04-14 09:11 Sandro Santilli <strk at keybit.net>
+2004-04-14 09:11 Sandro Santilli <strk at kbt.io>
* [r301] source/operation/buffer/BufferOp.cpp: endCapStyle was
never set in BufferOp contructor
-2004-04-14 08:38 Sandro Santilli <strk at keybit.net>
+2004-04-14 08:38 Sandro Santilli <strk at kbt.io>
* [r300] source/operation/buffer/BufferBuilder.cpp: BufferBuilder
constructor missed to initialize workingPrecisionModel
* [r299] source/operation/buffer/BufferOp.cpp: BufferOp constructor
missed to set argGeom
-2004-04-14 07:29 Sandro Santilli <strk at keybit.net>
+2004-04-14 07:29 Sandro Santilli <strk at kbt.io>
* [r298] source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
source/headers/geom.h: Fixed GeometryFactory constructors to copy
@@ -26158,42 +28154,42 @@
source/geomgraph/index/SweepLineSegment.cpp: "geomgraph/index"
committ problem fixed.
-2004-04-13 14:45 Sandro Santilli <strk at keybit.net>
+2004-04-13 14:45 Sandro Santilli <strk at kbt.io>
* [r296] source/geom/Point.cpp: Removed faulty assert in
constructor
-2004-04-13 14:33 Sandro Santilli <strk at keybit.net>
+2004-04-13 14:33 Sandro Santilli <strk at kbt.io>
* [r295] source/geom/Makefile.am: Added more source files
-2004-04-13 14:28 Sandro Santilli <strk at keybit.net>
+2004-04-13 14:28 Sandro Santilli <strk at kbt.io>
* [r294] doc/example.cpp: Removed spurious line
-2004-04-13 13:31 Sandro Santilli <strk at keybit.net>
+2004-04-13 13:31 Sandro Santilli <strk at kbt.io>
* [r293] source/headers/precision.h: prototype mismatch fixed
-2004-04-13 12:29 Sandro Santilli <strk at keybit.net>
+2004-04-13 12:29 Sandro Santilli <strk at kbt.io>
* [r292] source/headers/opDistance.h,
source/operation/distance/GeometryLocation.cpp: GeometryLocation
const-correctness.
-2004-04-13 11:04 Sandro Santilli <strk at keybit.net>
+2004-04-13 11:04 Sandro Santilli <strk at kbt.io>
* [r291] source/headers/Makefile.am: Added lost opDistance.h
-2004-04-13 11:03 Sandro Santilli <strk at keybit.net>
+2004-04-13 11:03 Sandro Santilli <strk at kbt.io>
* [r290] source/headers/Makefile.am: Added new header files
-2004-04-13 10:58 Sandro Santilli <strk at keybit.net>
+2004-04-13 10:58 Sandro Santilli <strk at kbt.io>
* [r289] source/geom/Makefile.am: Added new source files
-2004-04-13 10:05 Sandro Santilli <strk at keybit.net>
+2004-04-13 10:05 Sandro Santilli <strk at kbt.io>
* [r288] source/headers/opDistance.h,
source/operation/distance/DistanceOp.cpp,
@@ -26202,7 +28198,7 @@
Fixed erroneus down-casting in
DistanceOp::computeMinDistancePoints.
-2004-04-13 08:15 Sandro Santilli <strk at keybit.net>
+2004-04-13 08:15 Sandro Santilli <strk at kbt.io>
* [r287] source/headers/geom.h: Changed all 'long long' with int64.
Changed all 'long long' constants to end with two Ls.
@@ -26436,7 +28432,7 @@
source/headers/geom.h, source/headers/geosAlgorithm.h,
source/test/Stackwalker.h: "Algorithm" upgraded to JTS 1.4
-2004-03-01 22:04 Sandro Santilli <strk at keybit.net>
+2004-03-01 22:04 Sandro Santilli <strk at kbt.io>
* [r272] source/geom/Geometry.cpp, source/headers/geom.h,
source/headers/opBuffer.h, source/headers/opRelate.h,
@@ -26445,13 +28441,13 @@
changes by Manuel Prieto Villegas
<ManuelPrietoVillegas at telefonica.net>
-2004-02-27 17:43 Sandro Santilli <strk at keybit.net>
+2004-02-27 17:43 Sandro Santilli <strk at kbt.io>
* [r271] source/geom/Polygon.cpp: memory leak fix in
Polygon::getArea() - reported by 'Manuel Prieto Villegas'
<mprieto at dap.es>
-2004-02-27 17:42 Sandro Santilli <strk at keybit.net>
+2004-02-27 17:42 Sandro Santilli <strk at kbt.io>
* [r270] source/algorithm/CGAlgorithms.cpp,
source/headers/geosAlgorithm.h: made CGAlgorithms::signedArea()
@@ -26473,31 +28469,31 @@
to allow autoheader to work
its magic.
-2003-12-11 17:01 Sandro Santilli <strk at keybit.net>
+2003-12-11 17:01 Sandro Santilli <strk at kbt.io>
* [r266] source/operation/buffer/BufferOp.cpp: made buffer(0) back
to its *correct* semantic (empy collection)
-2003-12-11 16:01 Sandro Santilli <strk at keybit.net>
+2003-12-11 16:01 Sandro Santilli <strk at kbt.io>
* [r265] source/operation/buffer/BufferOp.cpp: made buffer
operation return a cloned input geom when called with 0 as
distance
-2003-12-11 15:53 Sandro Santilli <strk at keybit.net>
+2003-12-11 15:53 Sandro Santilli <strk at kbt.io>
* [r264] source/geom/GeometryCollection.cpp: Fixed bogus copy
constructor (making clone bogus)
-2003-11-13 11:57 Sandro Santilli <strk at keybit.net>
+2003-11-13 11:57 Sandro Santilli <strk at kbt.io>
* [r263] doc/example.cpp: bug fixed in relate call
-2003-11-12 22:03 Sandro Santilli <strk at keybit.net>
+2003-11-12 22:03 Sandro Santilli <strk at kbt.io>
* [r262] doc/example.cpp: added relational operators
-2003-11-12 18:02 Sandro Santilli <strk at keybit.net>
+2003-11-12 18:02 Sandro Santilli <strk at kbt.io>
* [r261] source/graph/PlanarGraph.cpp, source/headers/graph.h,
source/headers/opOverlay.h,
@@ -26505,41 +28501,41 @@
source/operation/overlay/PolygonBuilder.cpp: Added throw
specification. Fixed leaks on exceptions.
-2003-11-12 17:15 Sandro Santilli <strk at keybit.net>
+2003-11-12 17:15 Sandro Santilli <strk at kbt.io>
* [r260] source/geom/PrecisionModel.cpp: made sure PrecisionModel
scale is never 0
-2003-11-12 17:10 Sandro Santilli <strk at keybit.net>
+2003-11-12 17:10 Sandro Santilli <strk at kbt.io>
* [r259] source/test/XMLTester.cpp: added missing initialization
-2003-11-12 16:14 Sandro Santilli <strk at keybit.net>
+2003-11-12 16:14 Sandro Santilli <strk at kbt.io>
* [r258] source/headers/opOverlay.h,
source/operation/overlay/OverlayOp.cpp: Added some more throw
specifications and cleanup on exception (leaks removed).
-2003-11-12 15:43 Sandro Santilli <strk at keybit.net>
+2003-11-12 15:43 Sandro Santilli <strk at kbt.io>
* [r257] source/graph/DirectedEdgeStar.cpp,
source/graph/EdgeEndStar.cpp, source/graph/GeometryGraph.cpp,
source/headers/graph.h: Added some more throw specifications
-2003-11-12 15:02 Sandro Santilli <strk at keybit.net>
+2003-11-12 15:02 Sandro Santilli <strk at kbt.io>
* [r256] source/test/XMLTester.cpp: more cleanup on exception
-2003-11-12 11:08 Sandro Santilli <strk at keybit.net>
+2003-11-12 11:08 Sandro Santilli <strk at kbt.io>
* [r255] doc/example.cpp: removed old changelog, moved comments in
the nice standard frame
-2003-11-12 11:05 Sandro Santilli <strk at keybit.net>
+2003-11-12 11:05 Sandro Santilli <strk at kbt.io>
* [r254] autogen.sh: added autoheader call
-2003-11-07 17:51 Sandro Santilli <strk at keybit.net>
+2003-11-07 17:51 Sandro Santilli <strk at kbt.io>
* [r253] source/operation/buffer/BufferOp.cpp: Memory leak fix in
insertEdge()
@@ -26548,24 +28544,24 @@
* [r252] ChangeLog: Added current ChangeLog
-2003-11-07 17:45 Sandro Santilli <strk at keybit.net>
+2003-11-07 17:45 Sandro Santilli <strk at kbt.io>
* [r251] source/headers/config.h.in: will be generated with
./autogen.sh
-2003-11-07 14:21 Sandro Santilli <strk at keybit.net>
+2003-11-07 14:21 Sandro Santilli <strk at kbt.io>
* [r250] Makefile.am, configure.in, doc, doc/.cvsignore,
doc/Makefile, doc/Makefile.am: Made doc/ directory part of
distribution. Uniformed doc build script to
autotools.
-2003-11-07 14:19 Sandro Santilli <strk at keybit.net>
+2003-11-07 14:19 Sandro Santilli <strk at kbt.io>
* [r249] source/headers, source/headers/.cvsignore: added
config.h.in (missed before)
-2003-11-07 14:18 Sandro Santilli <strk at keybit.net>
+2003-11-07 14:18 Sandro Santilli <strk at kbt.io>
* [r248] source/headers, source/headers/.cvsignore: added
config.h.in
@@ -26725,62 +28721,62 @@
headers licence notices and copyrights to all cpp and h
files.
-2003-11-06 19:04 Sandro Santilli <strk at keybit.net>
+2003-11-06 19:04 Sandro Santilli <strk at kbt.io>
* [r244] source/graph/EdgeIntersectionList.cpp: removed useless
Coordinate copy in ::createSplitEdge()
-2003-11-06 18:50 Sandro Santilli <strk at keybit.net>
+2003-11-06 18:50 Sandro Santilli <strk at kbt.io>
* [r243] doc, doc/.cvsignore: first import
-2003-11-06 18:48 Sandro Santilli <strk at keybit.net>
+2003-11-06 18:48 Sandro Santilli <strk at kbt.io>
* [r242] TODO: updated
* [r241] source/operation/overlay/PolygonBuilder.cpp: added throw
information comment in PolygonBuilder
-2003-11-06 18:47 Sandro Santilli <strk at keybit.net>
+2003-11-06 18:47 Sandro Santilli <strk at kbt.io>
* [r240] source/operation/buffer/BufferOp.cpp: Added throw
specification for BufferOp's ::buildSubgraphs() and
::computeBuffer(). Cleanup on exception in computeBuffer().
-2003-11-06 18:46 Sandro Santilli <strk at keybit.net>
+2003-11-06 18:46 Sandro Santilli <strk at kbt.io>
* [r239] source/headers/opBuffer.h: Added throw specification for
BufferOp's ::buildSubgraphs() and ::computeBuffer()
-2003-11-06 18:45 Sandro Santilli <strk at keybit.net>
+2003-11-06 18:45 Sandro Santilli <strk at kbt.io>
* [r238] source/graph/DirectedEdgeStar.cpp, source/headers/graph.h:
DirectEdgeStar::linkResultDirectedEdges()
-2003-11-06 18:00 Sandro Santilli <strk at keybit.net>
+2003-11-06 18:00 Sandro Santilli <strk at kbt.io>
* [r237] source/operation/buffer/BufferOp.cpp: Cleanup on exception
in ::bufferOp()
-2003-11-06 17:59 Sandro Santilli <strk at keybit.net>
+2003-11-06 17:59 Sandro Santilli <strk at kbt.io>
* [r236] source/graph/EdgeRing.cpp: Memory leaks fixed in
::containsPoint()
-2003-11-06 17:48 Sandro Santilli <strk at keybit.net>
+2003-11-06 17:48 Sandro Santilli <strk at kbt.io>
* [r235] source/operation/buffer/BufferLineBuilder.cpp: Fixed
memory leaks in ::closePt() and ::addLineEndCap()
-2003-11-06 17:47 Sandro Santilli <strk at keybit.net>
+2003-11-06 17:47 Sandro Santilli <strk at kbt.io>
* [r234] source/operation/buffer/BufferEdgeBuilder.cpp: Added
support for LinearRing, removed memory leaks in ::addLineString
-2003-11-06 17:41 Sandro Santilli <strk at keybit.net>
+2003-11-06 17:41 Sandro Santilli <strk at kbt.io>
* [r233] doc/example.cpp: Added Buffer,Intersection,Difference and
Symdifference. Exception cleanup
@@ -26789,58 +28785,58 @@
* [r232] INSTALL: Small addition of into about LD_LIBRARY_PATH
-2003-11-05 21:52 Sandro Santilli <strk at keybit.net>
+2003-11-05 21:52 Sandro Santilli <strk at kbt.io>
* [r231] doc/Makefile, doc/example.cpp: Modified example.cpp to
make use of vectors instead of Geometry * / int
couples. Added LineString creation example. Added Makefile to
compile it.
-2003-11-03 16:09 Sandro Santilli <strk at keybit.net>
+2003-11-03 16:09 Sandro Santilli <strk at kbt.io>
* [r230] doc/example.cpp: Removed comments about segfaults, made
the simple collection creation call
cleaner by use of the clone() method.
-2003-10-31 16:36 Sandro Santilli <strk at keybit.net>
+2003-10-31 16:36 Sandro Santilli <strk at kbt.io>
* [r229] source/geom/GeometryCollection.cpp,
source/geom/LineString.cpp, source/geom/Point.cpp,
source/geom/Polygon.cpp, source/headers/geom.h: Re-introduced
clone() method. Copy constructor could not really replace it.
-2003-10-29 10:38 Sandro Santilli <strk at keybit.net>
+2003-10-29 10:38 Sandro Santilli <strk at kbt.io>
* [r228] doc/example.cpp: Added centroid computation example
* [r227] source/algorithm/CentroidLine.cpp: Added support for
LinearRing types (treated as LineString)
-2003-10-24 21:27 Sandro Santilli <strk at keybit.net>
+2003-10-24 21:27 Sandro Santilli <strk at kbt.io>
* [r226] source/headers/geom.h: Added GeometryTypeId enum and
getGeometryTypeId abstract Geometry method.
-2003-10-23 09:17 Sandro Santilli <strk at keybit.net>
+2003-10-23 09:17 Sandro Santilli <strk at kbt.io>
* [r225] source/headers, source/headers/.cvsignore: Added stamp-h2
and platform.h
-2003-10-23 09:12 Sandro Santilli <strk at keybit.net>
+2003-10-23 09:12 Sandro Santilli <strk at kbt.io>
* [r224] source/headers/util.h: Made CoordinateArrayFilter
destructor virtual.
-2003-10-22 23:58 Sandro Santilli <strk at keybit.net>
+2003-10-22 23:58 Sandro Santilli <strk at kbt.io>
* [r223] configure.in, source/headers/platform.h,
source/headers/platform.h.in: Made platform.h be created by
configure. In this way we will not have
problems of installed headers trying to include phantom config.h.
-2003-10-22 00:44 Sandro Santilli <strk at keybit.net>
+2003-10-22 00:44 Sandro Santilli <strk at kbt.io>
* [r222] source/headers/indexQuadtree.h, source/headers/platform.h,
source/index/quadtree/DoubleBits.cpp: Quadtree bitfield
@@ -26849,12 +28845,12 @@
64bits int64
will be really 32 bits and INT64_IS_REALLY32 will be defined.
-2003-10-21 23:51 Sandro Santilli <strk at keybit.net>
+2003-10-21 23:51 Sandro Santilli <strk at kbt.io>
* [r221] acsite.m4, configure.in, source/headers/acconfig.h,
source/headers/config.h.in: Added macros to find 64bit integer.
-2003-10-21 16:16 Sandro Santilli <strk at keybit.net>
+2003-10-21 16:16 Sandro Santilli <strk at kbt.io>
* [r220] doc/example.cpp: Uncommented point creation lines. Updated
comments about segfaults.
@@ -26874,27 +28870,27 @@
source/test/Makefile.am: Fix up references to header files to
'make dist' works.
-2003-10-20 17:50 Sandro Santilli <strk at keybit.net>
+2003-10-20 17:50 Sandro Santilli <strk at kbt.io>
* [r216] doc/example.cpp: added Union example
-2003-10-20 15:41 Sandro Santilli <strk at keybit.net>
+2003-10-20 15:41 Sandro Santilli <strk at kbt.io>
* [r215] source/geom/Geometry.cpp, source/headers/geom.h:
Geometry::checkNotGeometryCollection made static and
non-distructive.
-2003-10-20 14:02 Sandro Santilli <strk at keybit.net>
+2003-10-20 14:02 Sandro Santilli <strk at kbt.io>
* [r214] source/graph/EdgeRing.cpp,
source/operation/valid/ConnectedInteriorTester.cpp: more explicit
exception thrown on null Directed Edge detection
-2003-10-20 13:56 Sandro Santilli <strk at keybit.net>
+2003-10-20 13:56 Sandro Santilli <strk at kbt.io>
* [r213] source/util/AssertionFailedException.cpp: fixed typo
-2003-10-20 13:53 Sandro Santilli <strk at keybit.net>
+2003-10-20 13:53 Sandro Santilli <strk at kbt.io>
* [r212] source/graph/GeometryGraph.cpp: LinearRing handled as a
LineString in GeometryGraph::add(const Geometry *) - more
@@ -26907,34 +28903,34 @@
source/index/quadtree/DoubleBits.cpp, source/test/XMLTester.cpp:
Fixed a small memory leak.
-2003-10-16 17:41 Sandro Santilli <strk at keybit.net>
+2003-10-16 17:41 Sandro Santilli <strk at kbt.io>
* [r210] source/util/GEOSException.cpp,
source/util/UnsupportedOperationException.cpp: Fixed a bug in
GEOSException that prevented print of the type of exception
thrown.
-2003-10-16 17:33 Sandro Santilli <strk at keybit.net>
+2003-10-16 17:33 Sandro Santilli <strk at kbt.io>
* [r209] source/operation/valid/RepeatedPointTester.cpp: dropped
useless string() cast
-2003-10-16 17:05 Sandro Santilli <strk at keybit.net>
+2003-10-16 17:05 Sandro Santilli <strk at kbt.io>
* [r208] source/geom/TopologyException.cpp, source/headers/geom.h,
source/headers/util.h, source/util/IllegalArgumentException.cpp:
Made TopologyException inherit from GEOSException. Adjusted
IllegalArgumentException subclassing.
-2003-10-16 13:01 Sandro Santilli <strk at keybit.net>
+2003-10-16 13:01 Sandro Santilli <strk at kbt.io>
* [r207] source/test/XMLTester.cpp: Added call to Unload::Release()
-2003-10-16 12:09 Sandro Santilli <strk at keybit.net>
+2003-10-16 12:09 Sandro Santilli <strk at kbt.io>
* [r206] source/test/XMLTester.cpp: bug fixed in exception handling
-2003-10-16 08:50 Sandro Santilli <strk at keybit.net>
+2003-10-16 08:50 Sandro Santilli <strk at kbt.io>
* [r205] source/algorithm/CentroidArea.cpp,
source/algorithm/CentroidLine.cpp,
@@ -26953,11 +28949,11 @@
fixes. Improved performance by mean of more calls to new
getCoordinatesRO() when applicable.
-2003-10-16 08:48 Sandro Santilli <strk at keybit.net>
+2003-10-16 08:48 Sandro Santilli <strk at kbt.io>
* [r204] source/test/XMLTester.cpp: Exceptions handled
-2003-10-15 16:39 Sandro Santilli <strk at keybit.net>
+2003-10-15 16:39 Sandro Santilli <strk at kbt.io>
* [r203] source/geom/GeometryFactory.cpp, source/graph/Edge.cpp,
source/graph/EdgeList.cpp, source/graph/EdgeRing.cpp,
@@ -26974,13 +28970,13 @@
source/operation/overlay/LineBuilder.cpp: Made
Edge::getCoordinates() return a 'const' value. Adapted code set.
-2003-10-15 15:47 Sandro Santilli <strk at keybit.net>
+2003-10-15 15:47 Sandro Santilli <strk at kbt.io>
* [r202] source/algorithm/MCPointInRing.cpp,
source/algorithm/PointLocator.cpp: Adapted to new
getCoordinatesRO() interface
-2003-10-15 15:30 Sandro Santilli <strk at keybit.net>
+2003-10-15 15:30 Sandro Santilli <strk at kbt.io>
* [r201] source/graph/index/MonotoneChain.cpp,
source/graph/index/SweepLineEvent.cpp,
@@ -26991,14 +28987,14 @@
* pointers.
No more compiler warnings...
-2003-10-15 11:24 Sandro Santilli <strk at keybit.net>
+2003-10-15 11:24 Sandro Santilli <strk at kbt.io>
* [r200] source/graph/GeometryGraph.cpp,
source/operation/valid/ConnectedInteriorTester.cpp,
source/operation/valid/IsValidOp.cpp: Use getCoordinatesRO()
introduced.
-2003-10-15 11:23 Sandro Santilli <strk at keybit.net>
+2003-10-15 11:23 Sandro Santilli <strk at kbt.io>
* [r199] source/geom/BasicCoordinateList.cpp,
@@ -27006,37 +29002,37 @@
Formalized const nature of toVector() method and of first
argument to static removeRepeatedPoints().
-2003-10-15 10:17 Sandro Santilli <strk at keybit.net>
+2003-10-15 10:17 Sandro Santilli <strk at kbt.io>
* [r198] source/geom/BasicCoordinateList.cpp,
source/geom/PointCoordinateList.cpp, source/headers/geom.h: Made
setPoints() get a const vector<Coordinate>.
-2003-10-15 09:54 Sandro Santilli <strk at keybit.net>
+2003-10-15 09:54 Sandro Santilli <strk at kbt.io>
* [r197] source/geom/LineString.cpp, source/headers/geom.h: Added
getCoordinatesRO() public method.
-2003-10-15 08:52 Sandro Santilli <strk at keybit.net>
+2003-10-15 08:52 Sandro Santilli <strk at kbt.io>
* [r196] source/io/WKTReader.cpp: Memory leaks fixed.
-2003-10-15 08:51 Sandro Santilli <strk at keybit.net>
+2003-10-15 08:51 Sandro Santilli <strk at kbt.io>
* [r195] TODO: Initial import
-2003-10-15 08:08 Sandro Santilli <strk at keybit.net>
+2003-10-15 08:08 Sandro Santilli <strk at kbt.io>
* [r194] source/geom/Polygon.cpp: Memory leaks fixed. Partially due
to getCoordinates() and GeometryCollection()
changes, partially old dated.
-2003-10-14 15:58 Sandro Santilli <strk at keybit.net>
+2003-10-14 15:58 Sandro Santilli <strk at kbt.io>
* [r193] source/geom/GeometryFactory.cpp: Useless vector<Geometry
*> leaking allocations removed
-2003-10-13 21:26 Sandro Santilli <strk at keybit.net>
+2003-10-13 21:26 Sandro Santilli <strk at kbt.io>
* [r192] ., .cvsignore, macros, macros/.cvsignore, source/bigtest,
source/bigtest/.cvsignore, source/examples,
@@ -27045,47 +29041,47 @@
source/test/.cvsignore: Added build time created files to
cvsignore lists
-2003-10-13 17:54 Sandro Santilli <strk at keybit.net>
+2003-10-13 17:54 Sandro Santilli <strk at kbt.io>
* [r191] source/headers/opValid.h,
source/operation/valid/IsValidOp.cpp: IsValidOp constructor used
same name for the arg and a private element. Fixed.
-2003-10-13 17:47 Sandro Santilli <strk at keybit.net>
+2003-10-13 17:47 Sandro Santilli <strk at kbt.io>
* [r190] source/operation/overlay/MaximalEdgeRing.cpp,
source/operation/overlay/PolygonBuilder.cpp: delete statement
removed
-2003-10-13 15:39 Sandro Santilli <strk at keybit.net>
+2003-10-13 15:39 Sandro Santilli <strk at kbt.io>
* [r189] source/algorithm/CentroidArea.cpp,
source/algorithm/InteriorPointPoint.cpp,
source/headers/geosAlgorithm.h: Fixed some leak or fault flips
(forced copy of a single coordinate)
-2003-10-13 15:02 Sandro Santilli <strk at keybit.net>
+2003-10-13 15:02 Sandro Santilli <strk at kbt.io>
* [r188] source/test/XMLTester.cpp: accept input file as first
argument on cmdline
-2003-10-13 12:51 Sandro Santilli <strk at keybit.net>
+2003-10-13 12:51 Sandro Santilli <strk at kbt.io>
* [r187] source/geom/Geometry.cpp, source/headers/geom.h: removed
sortedClasses strings array from all geometries.
-2003-10-13 09:24 Sandro Santilli <strk at keybit.net>
+2003-10-13 09:24 Sandro Santilli <strk at kbt.io>
* [r186] source/headers/indexQuadtree.h,
source/index/quadtree/DoubleBits.cpp: long -> long long
enlargement of types to allow for left/rigth shift of 53 bits
-2003-10-11 03:23 Sandro Santilli <strk at keybit.net>
+2003-10-11 03:23 Sandro Santilli <strk at kbt.io>
* [r185] source/geom/LineString.cpp, source/geom/LinearRing.cpp:
fixed spurious typos
-2003-10-11 01:56 Sandro Santilli <strk at keybit.net>
+2003-10-11 01:56 Sandro Santilli <strk at kbt.io>
* [r184] source/algorithm/CGAlgorithms.cpp,
@@ -27158,46 +29154,46 @@
source/util/UniqueCoordinateArrayFilter.cpp: Code base padded
with 'const' keywords ;)
-2003-10-09 15:35 Sandro Santilli <strk at keybit.net>
+2003-10-09 15:35 Sandro Santilli <strk at kbt.io>
* [r183] source/geom/GeometryFactory.cpp, source/headers/geom.h:
added 'const' keyword to GeometryFactory constructor, Log on top
of geom.h
-2003-10-09 11:20 Sandro Santilli <strk at keybit.net>
+2003-10-09 11:20 Sandro Santilli <strk at kbt.io>
* [r182] doc/example.cpp: moved Log to a better place
-2003-10-09 11:19 Sandro Santilli <strk at keybit.net>
+2003-10-09 11:19 Sandro Santilli <strk at kbt.io>
* [r181] doc/example.cpp: added convexHull and PrecisionModel
-2003-10-09 10:14 Sandro Santilli <strk at keybit.net>
+2003-10-09 10:14 Sandro Santilli <strk at kbt.io>
* [r180] source/geom/GeometryFactory.cpp: just a style change in
top Log comment.
-2003-10-09 10:10 Sandro Santilli <strk at keybit.net>
+2003-10-09 10:10 Sandro Santilli <strk at kbt.io>
* [r179] source/geom/PrecisionModel.cpp: Throw an exception if
scale is 0. Added Log entry.
-2003-10-09 09:42 Sandro Santilli <strk at keybit.net>
+2003-10-09 09:42 Sandro Santilli <strk at kbt.io>
* [r178] source/geom/GeometryFactory.cpp: Tried to "formalize"
constant nature of the first argument given to constructor by
PrecisionModel and SRID specification. Added CVS Log on top.
-2003-10-09 08:58 Sandro Santilli <strk at keybit.net>
+2003-10-09 08:58 Sandro Santilli <strk at kbt.io>
* [r177] doc/example.cpp, source/algorithm/ConvexHull.cpp: Added
convexHull() call to example, fixed leaks in ConvexHull
-2003-10-09 00:11 Sandro Santilli <strk at keybit.net>
+2003-10-09 00:11 Sandro Santilli <strk at kbt.io>
* [r176] doc, doc/example.cpp: First reference-by-example file.
-2003-10-08 16:51 Sandro Santilli <strk at keybit.net>
+2003-10-08 16:51 Sandro Santilli <strk at kbt.io>
* [r175] source/geom/Makefile.am, source/headers/Makefile.am,
source/headers/geom.h, source/headers/graph.h,
@@ -27206,18 +29202,18 @@
source/headers/unload.h, source/io/Unload.cpp: Added xie's Unload
class with some fixes.
-2003-10-08 13:18 Sandro Santilli <strk at keybit.net>
+2003-10-08 13:18 Sandro Santilli <strk at kbt.io>
* [r174] source/headers/io.h, source/io/WKTWriter.cpp: added
missing LinearRing writing capabilities.
-2003-10-08 10:36 Sandro Santilli <strk at keybit.net>
+2003-10-08 10:36 Sandro Santilli <strk at kbt.io>
* [r173] source/geom/GeometryCollection.cpp: Constructor by
vector<Geometry *> * now makes a copy of the vector so that call
ers can safely delete it when done.
-2003-10-07 21:47 Sandro Santilli <strk at keybit.net>
+2003-10-07 21:47 Sandro Santilli <strk at kbt.io>
* [r172] source/algorithm/SimplePointInAreaLocator.cpp,
source/geom/Polygon.cpp, source/graph/EdgeRing.cpp,
@@ -27225,7 +29221,7 @@
source/operation/overlay/PolygonBuilder.cpp: had all
getCoordinates() callers free returned value.
-2003-10-07 18:58 Sandro Santilli <strk at keybit.net>
+2003-10-07 18:58 Sandro Santilli <strk at kbt.io>
* [r171] source/algorithm/PointLocator.cpp,
@@ -27241,7 +29237,7 @@
* [r170] source/geom/MultiPolygon.cpp, source/test/XMLTester.cpp:
Memory leak in Overlay fixed.
-2003-09-29 16:25 Sandro Santilli <strk at keybit.net>
+2003-09-29 16:25 Sandro Santilli <strk at kbt.io>
* [r169] macros, macros/.cvsignore, source/bigtest,
@@ -27250,17 +29246,17 @@
entries should probably not be
in the local copy
-2003-09-29 15:07 Sandro Santilli <strk at keybit.net>
+2003-09-29 15:07 Sandro Santilli <strk at kbt.io>
* [r168] ., .cvsignore: Added config.sub, config.guess and
autom4te.cache
-2003-09-29 13:15 Sandro Santilli <strk at keybit.net>
+2003-09-29 13:15 Sandro Santilli <strk at kbt.io>
* [r167] tools, tools/.cvsignore: Don't wonder about Makefile.in,
Makefile, gdal-config
-2003-09-26 17:31 Sandro Santilli <strk at keybit.net>
+2003-09-26 17:31 Sandro Santilli <strk at kbt.io>
* [r166] source/algorithm/ConvexHull.cpp: getConvexHull() made
check value returned by reduce() before deleting
More information about the geos-commits
