[geos-commits] r4266 - in tags/3.6.0: . trunk
Sandro Santilli
strk at kbt.io
Tue Oct 25 08:38:37 PDT 2016
Author: strk
Date: 2016-10-25 08:38:36 -0700 (Tue, 25 Oct 2016)
New Revision: 4266
Added:
tags/3.6.0/trunk/
Tagged release 3.6.0
Property changes on: tags/3.6.0/trunk
___________________________________________________________________
Added: svn:ignore
+ aclocal.m4
autom4te.cache
compile
config.guess
config.log
config.status
config.sub
configure
depcomp
install-sh
libtool
ltmain.sh
missing
mkinstalldirs
Makefile
Makefile.in
py-compile
tags
ID
*.swp
.gdb*
CMakeFiles
*.cmake
cmake_install.*
CMakeCache.txt
_build
geos_svn_revision.h
test-driver
Added: svn:mergeinfo
+ /branches/3.4:4056
/branches/3.5:4210
More information about the geos-commits
