[geos-commits] r4274 - in branches/3.6: . capi include/geos
Sandro Santilli
strk at kbt.io
Tue Oct 25 08:58:54 PDT 2016
Author: strk
Date: 2016-10-25 08:58:54 -0700 (Tue, 25 Oct 2016)
New Revision: 4274
branches/3.6/CMakeLists.txt
branches/3.6/HOWTO_RELEASE
branches/3.6/capi/geos_c.h.in
branches/3.6/configure.ac
branches/3.6/include/geos/version.h.vc
Prepare for 3.6.1
Modified: branches/3.6/CMakeLists.txt
--- branches/3.6/CMakeLists.txt 2016-10-25 15:55:09 UTC (rev 4273)
+++ branches/3.6/CMakeLists.txt 2016-10-25 15:58:54 UTC (rev 4274)
@@ -29,7 +29,7 @@
# GEOS C++ library SONAME will use these encoding ABI break at every release
set(VERSION_MAJOR 3)
set(VERSION_MINOR 6)
-set(VERSION_PATCH 0)
+set(VERSION_PATCH 1dev)
set(VERSION "${VERSION_MAJOR}.${VERSION_MINOR}.${VERSION_PATCH}")
# JTS_PORT is the version of JTS this release is bound to
@@ -38,7 +38,7 @@
# GEOS C API version
set(CAPI_INTERFACE_CURRENT 11)
-set(CAPI_INTERFACE_REVISION 0)
+set(CAPI_INTERFACE_REVISION 1)
set(CAPI_INTERFACE_AGE 10)
math(EXPR CAPI_VERSION_MAJOR "${CAPI_INTERFACE_CURRENT} - ${CAPI_INTERFACE_AGE}")
Modified: branches/3.6/HOWTO_RELEASE
--- branches/3.6/HOWTO_RELEASE 2016-10-25 15:55:09 UTC (rev 4273)
+++ branches/3.6/HOWTO_RELEASE 2016-10-25 15:58:54 UTC (rev 4274)
@@ -14,7 +14,7 @@
$ svn copy -m "Tagged release MAJOR.MINOR.PATCH" \
$base/trunk $base/tags/MAJOR.MINOR.PATCH
-7: Export the tag and 'make dist-bzip2'.
+7: Export the tag and 'make dist-bzip2'.
$ svn export $base/tags/$rev
$ cd $rev
$ ./autogen.sh && ./configure && make dist-bzip2
@@ -34,7 +34,7 @@
12: Increment release version:
- In configure.ac
- - In include/geos/version.h.vc
+ - In include/geos/version.h.vc
- In capi/geos_c.h.in
- VERSION_PATCH for bugfixes/improvements (even breaking C++ API)
- VERSION_MINOR for NEW interfaces in the C lib
@@ -48,5 +48,5 @@
- Add latest release
- Remove previos patch level release (if any)
-14: Announce
+14: Announce
Modified: branches/3.6/capi/geos_c.h.in
--- branches/3.6/capi/geos_c.h.in 2016-10-25 15:55:09 UTC (rev 4273)
+++ branches/3.6/capi/geos_c.h.in 2016-10-25 15:58:54 UTC (rev 4274)
@@ -25,7 +25,7 @@
* all returned char * (unless const).
* - Functions ending with _r are thread safe; see details in RFC 3
- * http://trac.osgeo.org/geos/wiki/RFC3.
+ * http://trac.osgeo.org/geos/wiki/RFC3.
* To avoid using by accident non _r functions,
* define GEOS_USE_ONLY_R_API before including geos_c.h
@@ -60,8 +60,8 @@
#include <geos/version.h>
#define GEOS_CAPI_VERSION_MAJOR 1
#define GEOS_CAPI_VERSION_MINOR 10
-#define GEOS_CAPI_VERSION_PATCH 0
-#define GEOS_CAPI_VERSION "3.6.0-CAPI-1.10.0"
+#define GEOS_CAPI_VERSION_PATCH 1
+#define GEOS_CAPI_VERSION "3.6.1-CAPI-1.10.1"
#else
#ifndef GEOS_VERSION_MAJOR
#define GEOS_VERSION_MAJOR @VERSION_MAJOR@
@@ -693,7 +693,7 @@
* Returns the Voronoi polygons of a set of Vertices given as input
* @param g the input geometry whose vertex will be used as sites.
* @param tolerance snapping tolerance to use for improved robustness
* @param onlyEdges whether to return only edges of the voronoi cells
@@ -701,12 +701,12 @@
* determined if NULL.
* The diagram will be clipped to the larger
* of this envelope or an envelope surrounding the sites.
* @return a newly allocated geometry, or NULL on exception.
extern GEOSGeometry GEOS_DLL * GEOSVoronoiDiagram_r(
- GEOSContextHandle_t extHandle,
- const GEOSGeometry *g,
+ GEOSContextHandle_t extHandle,
+ const GEOSGeometry *g,
const GEOSGeometry *env,
double tolerance,
int onlyEdges);
@@ -1635,7 +1635,7 @@
@@ -1643,7 +1643,7 @@
extern GEOSGeometry GEOS_DLL * GEOSVoronoiDiagram(
Modified: branches/3.6/configure.ac
--- branches/3.6/configure.ac 2016-10-25 15:55:09 UTC (rev 4273)
+++ branches/3.6/configure.ac 2016-10-25 15:58:54 UTC (rev 4274)
@@ -15,7 +15,7 @@
dnl -- Version info for the CAPI
CAPI_INTERFACE_CURRENT=11
-CAPI_INTERFACE_REVISION=0
+CAPI_INTERFACE_REVISION=1
CAPI_INTERFACE_AGE=10
dnl
@@ -24,7 +24,7 @@
dnl
VERSION_MAJOR=3
VERSION_MINOR=6
-VERSION_PATCH=0
+VERSION_PATCH=1dev
VERSION="$VERSION_MAJOR.$VERSION_MINOR.$VERSION_PATCH"
dnl CAPI_VERSION_MAJOR=$(($CAPI_INTERFACE_CURRENT-$CAPI_INTERFACE_AGE))
Modified: branches/3.6/include/geos/version.h.vc
--- branches/3.6/include/geos/version.h.vc 2016-10-25 15:55:09 UTC (rev 4273)
+++ branches/3.6/include/geos/version.h.vc 2016-10-25 15:58:54 UTC (rev 4274)
@@ -7,7 +7,7 @@
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
+ * by the Free Software Foundation.
* See the COPYING file for more information.
@@ -34,11 +34,11 @@
#endif
#ifndef GEOS_VERSION_PATCH
-#define GEOS_VERSION_PATCH 0
+#define GEOS_VERSION_PATCH 1
#endif
-#define GEOS_VERSION "3.6.0"
+#define GEOS_VERSION "3.6.1"
#endif
#ifndef GEOS_JTS_PORT
More information about the geos-commits
