[geos-commits] r4257 - trunk/include/geos/geom
Sandro Santilli
strk at kbt.io
Wed Sep 7 06:06:53 PDT 2016
Author: strk
Date: 2016-09-07 06:06:53 -0700 (Wed, 07 Sep 2016)
New Revision: 4257
trunk/include/geos/geom/Geometry.h
trunk/include/geos/geom/LineString.h
Fix documentation typos.
Courtesy of Todd Trimble <todd.trimble at gmail.com>
Modified: trunk/include/geos/geom/Geometry.h
--- trunk/include/geos/geom/Geometry.h 2016-09-07 13:05:34 UTC (rev 4256)
+++ trunk/include/geos/geom/Geometry.h 2016-09-07 13:06:53 UTC (rev 4257)
@@ -656,7 +656,7 @@
* Performs an operation on the coordinates in this Geometry's
- * CoordinateSequences.s
+ * CoordinateSequences.
* If the filter reports that a coordinate value has been changed,
* {@link #geometryChanged} will be called automatically.
Modified: trunk/include/geos/geom/LineString.h
--- trunk/include/geos/geom/LineString.h 2016-09-07 13:05:34 UTC (rev 4256)
+++ trunk/include/geos/geom/LineString.h 2016-09-07 13:06:53 UTC (rev 4257)
@@ -60,12 +60,12 @@
* pair of consecutive vertices.
* Consecutive vertices may be equal.
* The line segments in the line may intersect each other (in other words,
- * the linestring may "curl back" in itself and self-intersect.
+ * the linestring may "curl back" in itself and self-intersect).
* Linestrings with exactly two identical points are invalid.
* A linestring must have either 0 or 2 or more points.
* If these conditions are not met, the constructors throw
- * an {@link IllegalArgumentException}
+ * an {@link IllegalArgumentException}.
class GEOS_DLL LineString: public virtual Geometry, public Lineal {
@@ -79,10 +79,11 @@
virtual ~LineString();
- * Creates and returns a full copy of this {@link LineString} object.
- * (including all coordinates contained by it).
+ * \brief
+ * Creates and returns a full copy of this {@link LineString} object
+ * (including all coordinates contained by it)
- * @return a clone of this instance
+ * @return A clone of this instance
virtual Geometry *clone() const;
@@ -164,7 +165,7 @@
* Normalizes a LineString.
* A normalized linestring
- * has the first point which is not equal to it's reflected point
+ * has the first point which is not equal to its reflected point
* less than the reflected point.
virtual void normalize();
@@ -178,7 +179,7 @@
* Creates a LineString whose coordinates are in the reverse
- * order of this objects
+ * order of this object's
* @return a LineString with coordinates in the reverse order
More information about the geos-commits
