[geos-commits] r4396 - in branches/3.6: . capi tools
Sandro Santilli
strk at kbt.io
Tue Apr 4 02:19:56 PDT 2017
Author: strk
Date: 2017-04-04 02:19:55 -0700 (Tue, 04 Apr 2017)
New Revision: 4396
Added:
branches/3.6/tools/geos_revision_cmake.h.in
branches/3.6/tools/repo_revision.sh
Removed:
branches/3.6/tools/geos_svn_revision_cmake.h.in
branches/3.6/tools/svn_repo_revision.sh
branches/3.6/.gitignore
branches/3.6/CMakeLists.txt
branches/3.6/Makefile.am
branches/3.6/autogen.bat
branches/3.6/capi/geos_ts_c.cpp
branches/3.6/tools/Makefile.am
Add support for GIT only revision references
Backports revisions 4388-4396 from trunk
Fixes #794 for 3.6 branch
Modified: branches/3.6/.gitignore
--- branches/3.6/.gitignore 2017-04-02 09:31:00 UTC (rev 4395)
+++ branches/3.6/.gitignore 2017-04-04 09:19:55 UTC (rev 4396)
@@ -3,7 +3,7 @@
aclocal.m4
Makefile.in
Makefile
-geos_svn_revision.h
+geos_revision.h
.libs
.deps
.vimrc
Modified: branches/3.6/CMakeLists.txt
--- branches/3.6/CMakeLists.txt 2017-04-02 09:31:00 UTC (rev 4395)
+++ branches/3.6/CMakeLists.txt 2017-04-04 09:19:55 UTC (rev 4396)
@@ -241,8 +241,8 @@
# for including build-specific version.h, platform.h and geos_c.h
include_directories(${PROJECT_BINARY_DIR}/include)
-# for geos_ts.cpp which does #include "../geos_svn_revision.h" whereas
-# CMake generates geos_svn_revision.h in build directory,
+# for geos_ts.cpp which does #include "../geos_revision.h" whereas
+# CMake generates geos_revision.h in build directory,
# to not to pollute source tree.
include_directories(${PROJECT_BINARY_DIR})
@@ -272,11 +272,11 @@
GET_SVN_REVISION()
endif()
-# geos_svn_revision.h does not exists in source or binary directory, we generate it
-if( NOT EXISTS "${PROJECT_SOURCE_DIR}/geos_svn_revision.h" AND
- NOT EXISTS "${PROJECT_BINARY_DIR}/geos_svn_revision.h")
+# geos_revision.h does not exists in source or binary directory, we generate it
+if( NOT EXISTS "${PROJECT_SOURCE_DIR}/geos_revision.h" AND
+ NOT EXISTS "${PROJECT_BINARY_DIR}/geos_revision.h")
- message(STATUS "Generating GEOS revision header in ${PROJECT_BINARY_DIR}/geos_svn_revision.h")
+ message(STATUS "Generating GEOS revision header in ${PROJECT_BINARY_DIR}/geos_revision.h")
# CI builds (Travis CI, AppVeyor, etc.) perform git clone, not svn checkout.
# So, CI environment needs a dummy revision to generate the required header.
@@ -285,22 +285,22 @@
endif()
if ( NOT ${Project_WC_REVISION} EQUAL 0 )
- set( GEOS_SVN_REVISION ${Project_WC_REVISION} )
+ set( GEOS_REVISION ${Project_WC_REVISION} )
configure_file (
- "${PROJECT_SOURCE_DIR}/tools/geos_svn_revision_cmake.h.in"
- "${PROJECT_BINARY_DIR}/geos_svn_revision.h" )
+ "${PROJECT_SOURCE_DIR}/tools/geos_revision_cmake.h.in"
+ "${PROJECT_BINARY_DIR}/geos_revision.h" )
else()
find_program(SH sh)
if(SH)
execute_process(COMMAND ${SH} -c
- "cd ${PROJECT_SOURCE_DIR} && ${PROJECT_SOURCE_DIR}/tools/svn_repo_revision.sh")
+ "cd ${PROJECT_SOURCE_DIR} && ${PROJECT_SOURCE_DIR}/tools/repo_revision.sh")
- file(RENAME "${PROJECT_SOURCE_DIR}/geos_svn_revision.h"
- "${PROJECT_BINARY_DIR}/geos_svn_revision.h")
+ file(RENAME "${PROJECT_SOURCE_DIR}/geos_revision.h"
+ "${PROJECT_BINARY_DIR}/geos_revision.h")
else()
- message("*** sh-compatible command not found, cannot create geos_svn_revision.h")
+ message("*** sh-compatible command not found, cannot create geos_revision.h")
message("*** Check SVN revision and create revision header manually:")
- message("*** echo '#define GEOS_SVN_REVISION XYZ' > ${PROJECT_SOURCE_DIR}/geos_svn_revision.h")
+ message("*** echo '#define GEOS_REVISION XYZ' > ${PROJECT_SOURCE_DIR}/geos_revision.h")
endif()
endif()
endif()
Modified: branches/3.6/Makefile.am
--- branches/3.6/Makefile.am 2017-04-02 09:31:00 UTC (rev 4395)
+++ branches/3.6/Makefile.am 2017-04-04 09:19:55 UTC (rev 4396)
@@ -22,12 +22,12 @@
tests \
tools
-BUILT_SOURCES = geos_svn_revision.h
+BUILT_SOURCES = geos_revision.h
EXTRA_DIST = acsite.m4 makefile.vc nmake.opt autogen.bat CMakeLists.txt \
cmake/modules/CheckPrototypeExists.cmake \
cmake/modules/COPYING-CMAKE-SCRIPTS \
- cmake/cmake_uninstall.cmake.in geos_svn_revision.h
+ cmake/cmake_uninstall.cmake.in geos_revision.h
ACLOCAL_AMFLAGS = -I macros
@@ -56,12 +56,12 @@
svnrebase: authors.git
cd $(srcdir) && git svn rebase --authors-file authors.git
-geos_svn_revision.h:
- top_srcdir=$(srcdir) sh $(srcdir)/tools/svn_repo_revision.sh
+geos_revision.h:
+ top_srcdir=$(srcdir) sh $(srcdir)/tools/repo_revision.sh
VALGRIND = $(LIBTOOL) --mode=execute valgrind --leak-check=full --error-exitcode=1
valgrindcheck:
$(VALGRIND) tests/unit/geos_unit
-.PHONY: geos_svn_revision.h
+.PHONY: geos_revision.h
Modified: branches/3.6/autogen.bat
--- branches/3.6/autogen.bat 2017-04-02 09:31:00 UTC (rev 4395)
+++ branches/3.6/autogen.bat 2017-04-04 09:19:55 UTC (rev 4396)
@@ -14,4 +14,4 @@
COPY %GEOS_HEADERS%\version.h.vc %GEOS_HEADERS%\version.h
COPY %GEOS_HEADERS%\platform.h.vc %GEOS_HEADERS%\platform.h
COPY capi\geos_c.h.in capi\geos_c.h
- at ECHO #define GEOS_SVN_REVISION 0 > geos_svn_revision.h
\ No newline at end of file
+ at ECHO #define GEOS_REVISION "0" > geos_revision.h
Modified: branches/3.6/capi/geos_ts_c.cpp
--- branches/3.6/capi/geos_ts_c.cpp 2017-04-02 09:31:00 UTC (rev 4395)
+++ branches/3.6/capi/geos_ts_c.cpp 2017-04-04 09:19:55 UTC (rev 4396)
@@ -103,7 +103,7 @@
#define GEOSWKBWriter_t geos::io::WKBWriter
#include "geos_c.h"
-#include "../geos_svn_revision.h"
+#include "../geos_revision.h"
// Intentional, to allow non-standard C elements like C99 functions to be
// imported through C++ headers of C library, like <cmath>.
@@ -3690,7 +3690,7 @@
const char* GEOSversion()
static char version[256];
- sprintf(version, "%s r%d", GEOS_CAPI_VERSION, GEOS_SVN_REVISION);
+ sprintf(version, "%s " GEOS_REVISION, GEOS_CAPI_VERSION);
return version;
Modified: branches/3.6/tools/Makefile.am
--- branches/3.6/tools/Makefile.am 2017-04-02 09:31:00 UTC (rev 4395)
+++ branches/3.6/tools/Makefile.am 2017-04-04 09:19:55 UTC (rev 4396)
@@ -2,4 +2,4 @@
# This file is part of project GEOS (http://trac.osgeo.org/geos/)
bin_SCRIPTS = geos-config
-EXTRA_DIST = CMakeLists.txt svn_repo_revision.sh
+EXTRA_DIST = CMakeLists.txt repo_revision.sh
Added: branches/3.6/tools/geos_revision_cmake.h.in
--- branches/3.6/tools/geos_revision_cmake.h.in (rev 0)
+++ branches/3.6/tools/geos_revision_cmake.h.in 2017-04-04 09:19:55 UTC (rev 4396)
@@ -0,0 +1 @@
+#define GEOS_REVISION "@GEOS_REVISION@"
Deleted: branches/3.6/tools/geos_svn_revision_cmake.h.in
--- branches/3.6/tools/geos_svn_revision_cmake.h.in 2017-04-02 09:31:00 UTC (rev 4395)
+++ branches/3.6/tools/geos_svn_revision_cmake.h.in 2017-04-04 09:19:55 UTC (rev 4396)
@@ -1 +0,0 @@
-#define GEOS_SVN_REVISION @GEOS_SVN_REVISION@
Copied: branches/3.6/tools/repo_revision.sh (from rev 4385, branches/3.6/tools/svn_repo_revision.sh)
--- branches/3.6/tools/repo_revision.sh (rev 0)
+++ branches/3.6/tools/repo_revision.sh 2017-04-04 09:19:55 UTC (rev 4396)
@@ -0,0 +1,96 @@
+#!/bin/sh
+LC_ALL="C" # what for ?
+[ -z "$top_srcdir" ] && top_srcdir="."
+rev_file=$top_srcdir'/geos_revision.h'
+read_rev() {
+ if test -d $top_srcdir"/.svn"; then
+ read_rev_svn
+ elif test -d $top_srcdir"/.git"; then
+ read_rev_git
+ else
+ echo "Can't fetch local revision (neither .svn nor .git found)" >&2
+ echo 0
+ fi
+read_rev_git() {
+ # TODO: test on old systems, I think I saw some `which`
+ # implementations returning "nothing found" or something
+ # like that, making the later if ( ! $svn_exe ) always false
+ git_exe=`which git`;
+ if test -z "$git_exe"; then
+ echo "Can't fetch SVN revision: no git executable found" >&2
+ echo 0;
+ fi
+ last_commit=`cd ${top_srcdir} && ${git_exe} log -1`
+ if test -z "$last_commit"; then
+ echo "Can't fetch last commit info from git log" >&2
+ echo 0
+ return
+ fi
+ svnrev=`echo "$last_commit" | grep git-svn | cut -d@ -f2 | cut -d' ' -f1`
+ if test -n "$svnrev"; then
+ # Last commit has SVN metadata, we'll use that
+ echo r$svnrev
+ return
+ fi
+ # Last commit has no SVN metadata, we'll use sha
+ sha=`cd ${top_srcdir} && ${git_exe} describe --always`
+ echo $sha
+read_rev_svn() {
+ svn_exe=`which svn`
+ if test -z "$svn_exe"; then
+ echo "Can't fetch SVN revision: no svn executable found" >&2
+ echo 0;
+ fi
+ svn_info=`"${svn_exe}" info | grep 'Last Changed Rev:' | cut -d: -f2`
+ if test -z "$svn_info"; then
+ echo "Can't fetch SVN revision with `svn info`" >&2
+ echo 0
+ else
+ echo r${svn_info}
+ fi
+write_defn() {
+ rev=$1
+ oldrev=0
+ # Do not override the file if new detected
+ # revision isn't zero nor different from the existing one
+ if test -f $rev_file; then
+ oldrev=`grep GEOS_REVISION ${rev_file} | awk '{print $2}'`
+ if test "$rev" = 0 -o "$rev" = "$oldrev"; then
+ echo "Not updating existing rev file at $oldrev" >&2
+ return;
+ fi
+ fi
+ echo "#define GEOS_REVISION \"$rev\"" | tee $rev_file
+ echo "Wrote rev '$rev' in file '$rev_file'" >&2
+# Read the svn revision number
+svn_rev=`read_rev`
+# Write it
+write_defn $svn_rev
Deleted: branches/3.6/tools/svn_repo_revision.sh
--- branches/3.6/tools/svn_repo_revision.sh 2017-04-02 09:31:00 UTC (rev 4395)
+++ branches/3.6/tools/svn_repo_revision.sh 2017-04-04 09:19:55 UTC (rev 4396)
@@ -1,86 +0,0 @@
-#!/bin/sh
-LC_ALL="C" # what for ?
-[ -z "$top_srcdir" ] && top_srcdir="."
-rev_file=$top_srcdir'/geos_svn_revision.h'
-read_rev() {
- if test -d $top_srcdir"/.svn"; then
- read_rev_svn
- elif test -d $top_srcdir"/.git"; then
- read_rev_git
- else
- echo "Can't fetch local revision (neither .svn nor .git found)" >&2
- echo 0
- fi
-read_rev_git() {
- # TODO: test on old systems, I think I saw some `which`
- # implementations returning "nothing found" or something
- # like that, making the later if ( ! $svn_exe ) always false
- git_exe=`which git`;
- if test -z "$git_exe"; then
- echo "Can't fetch SVN revision: no git executable found" >&2
- echo 0;
- fi
- rev=`cd ${top_srcdir} && ${git_exe} log --grep=git-svn -1 | grep git-svn | cut -d@ -f2 | cut -d' ' -f1`
- if test -z "$rev"; then
- echo "Can't fetch SVN revision from git log" >&2
- echo 0
- else
- echo $rev
- fi
-read_rev_svn() {
- svn_exe=`which svn`
- if test -z "$svn_exe"; then
- echo "Can't fetch SVN revision: no svn executable found" >&2
- echo 0;
- fi
- svn_info=`"${svn_exe}" info | grep 'Last Changed Rev:' | cut -d: -f2`
- if test -z "$svn_info"; then
- echo "Can't fetch SVN revision with `svn info`" >&2
- echo 0
- else
- echo ${svn_info}
- fi
-write_defn() {
- rev=$1
- oldrev=0
- # Do not override the file if new detected
- # revision isn't zero nor different from the existing one
- if test -f $rev_file; then
- oldrev=`grep GEOS_SVN_REVISION ${rev_file} | awk '{print $2}'`
- if test "$rev" = 0 -o "$rev" = "$oldrev"; then
- echo "Not updating existing rev file at $oldrev" >&2
- return;
- fi
- fi
- echo "#define GEOS_SVN_REVISION $rev" | tee $rev_file
- echo "Wrote rev '$rev' in file '$rev_file'" >&2
-# Read the svn revision number
-svn_rev=`read_rev`
-# Write it
-write_defn $svn_rev
More information about the geos-commits
