[geos-commits] [SCM] geos branch master updated. 080d94701ce900494898c5fe78c53a1db72a5f4c
git at osgeo.org
git at osgeo.org
Tue Aug 29 08:24:27 PDT 2017
the project "geos".
via 080d94701ce900494898c5fe78c53a1db72a5f4c (commit)
from ec5e78da7c79bbb1a5c413ee62f0368776deda53 (commit)
revisions in full, below.
commit 080d94701ce900494898c5fe78c53a1db72a5f4c
Author: Mateusz Loskot <mateusz at loskot.net>
Date: Tue Aug 29 17:22:59 2017 +0200
[CMake] Add LANGUAGES property to project command
Note, VERSION property components must be integers,
and cannot be added due to 'dev' suffix in VERSION_PATCH.
diff --git a/CMakeLists.txt b/CMakeLists.txt
index db77b67..fe6d50d 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -10,7 +10,6 @@
# See the COPYING file for more information.
-project(GEOS)
cmake_minimum_required(VERSION 3.0.0)
if(NOT CMAKE_VERSION)
@@ -18,9 +17,6 @@ if(NOT CMAKE_VERSION)
"${CMAKE_MAJOR_VERSION}.${CMAKE_MINOR_VERSION}.${CMAKE_PATCH_VERSION}")
endif()
-# Add custom GEOS modules for CMake
-list(APPEND CMAKE_MODULE_PATH "${PROJECT_SOURCE_DIR}/cmake/modules")
# Setup GEOS version
@@ -52,6 +48,14 @@ if (NOT WIN32)
endif()
+# Set GEOS project
+project(GEOS LANGUAGES C CXX)
+# Add custom GEOS modules for CMake
+list(APPEND CMAKE_MODULE_PATH "${PROJECT_SOURCE_DIR}/cmake/modules")
# Check custom global options
Summary of changes:
CMakeLists.txt | 12 ++++++++----
1 file changed, 8 insertions(+), 4 deletions(-)
hooks/post-receive
geos
More information about the geos-commits
