[geos-commits] r4331 - in trunk/src: geom/util index/strtree linearref operation/union
Sandro Santilli
strk at kbt.io
Wed Feb 1 09:29:04 PST 2017
Author: strk
Date: 2017-02-01 09:29:04 -0800 (Wed, 01 Feb 2017)
New Revision: 4331
trunk/src/geom/util/GeometryEditor.cpp
trunk/src/index/strtree/AbstractSTRtree.cpp
trunk/src/linearref/ExtractLineByLocation.cpp
trunk/src/operation/union/CascadedPolygonUnion.cpp
trunk/src/operation/union/CascadedUnion.cpp
Add static_assert<bool> to strings inside of assert calls
Allows compiling with -Wpointer-bool-conversion.
Patch by Kurt Schwehr <schwehr at google.com>
Closes #638
Modified: trunk/src/geom/util/GeometryEditor.cpp
--- trunk/src/geom/util/GeometryEditor.cpp 2017-01-31 20:01:40 UTC (rev 4330)
+++ trunk/src/geom/util/GeometryEditor.cpp 2017-02-01 17:29:04 UTC (rev 4331)
@@ -99,7 +99,7 @@
// Unsupported Geometry classes should be caught in the GeometryEditorOperation.
- assert(!"SHOULD NEVER GET HERE");
+ assert(!static_cast<bool>("SHOULD NEVER GET HERE"));
return NULL;
Modified: trunk/src/index/strtree/AbstractSTRtree.cpp
--- trunk/src/index/strtree/AbstractSTRtree.cpp 2017-01-31 20:01:40 UTC (rev 4330)
+++ trunk/src/index/strtree/AbstractSTRtree.cpp 2017-02-01 17:29:04 UTC (rev 4331)
@@ -370,7 +370,7 @@
static_cast<ItemBoundable*>(childBoundable)->getItem());
else {
- assert(!"should never be reached");
+ assert(!static_cast<bool>("should never be reached"));
if (valuesTreeForNode->empty())
@@ -395,4 +395,3 @@
} // namespace geos.index.strtree
} // namespace geos
Modified: trunk/src/linearref/ExtractLineByLocation.cpp
--- trunk/src/linearref/ExtractLineByLocation.cpp 2017-01-31 20:01:40 UTC (rev 4330)
+++ trunk/src/linearref/ExtractLineByLocation.cpp 2017-02-01 17:29:04 UTC (rev 4331)
@@ -79,7 +79,7 @@
else
- assert(!"non-linear geometry encountered");
+ assert(!static_cast<bool>("non-linear geometry encountered"));
return 0;
Modified: trunk/src/operation/union/CascadedPolygonUnion.cpp
--- trunk/src/operation/union/CascadedPolygonUnion.cpp 2017-01-31 20:01:40 UTC (rev 4330)
+++ trunk/src/operation/union/CascadedPolygonUnion.cpp 2017-02-01 17:29:04 UTC (rev 4331)
@@ -139,7 +139,7 @@
geoms->push_back(reinterpret_cast<geom::Geometry*>((*i).get_geometry()));
else {
@@ -247,4 +247,3 @@
} // namespace geos.operation.union
} // namespace geos
Modified: trunk/src/operation/union/CascadedUnion.cpp
--- trunk/src/operation/union/CascadedUnion.cpp 2017-01-31 20:01:40 UTC (rev 4330)
+++ trunk/src/operation/union/CascadedUnion.cpp 2017-02-01 17:29:04 UTC (rev 4331)
@@ -116,7 +116,7 @@
else {
@@ -195,4 +195,3 @@
} // namespace geos
More information about the geos-commits
