[geos-commits] r4338 - trunk/tests/unit/geom
Mateusz Loskot
mateusz at loskot.net
Wed Feb 15 14:31:02 PST 2017
Author: mloskot
Date: 2017-02-15 14:31:02 -0800 (Wed, 15 Feb 2017)
New Revision: 4338
trunk/tests/unit/geom/PolygonTest.cpp
Add basic test of convex Polygon::buffer(0) result.
Modified: trunk/tests/unit/geom/PolygonTest.cpp
--- trunk/tests/unit/geom/PolygonTest.cpp 2017-02-14 16:38:04 UTC (rev 4337)
+++ trunk/tests/unit/geom/PolygonTest.cpp 2017-02-15 22:31:02 UTC (rev 4338)
@@ -1,4 +1,4 @@
// Test Suite for geos::geom::Polygon class.
#include <tut.hpp>
@@ -43,7 +43,7 @@
PolygonPtr poly_;
const size_t poly_size_;
- test_polygon_data()
+ test_polygon_data()
: pm_(1)
, factory_(GeometryFactory::create(&pm_, 0))
, reader_(factory_.get())
@@ -55,7 +55,7 @@
poly_ = dynamic_cast<PolygonPtr>(geo);
- ~test_polygon_data()
+ ~test_polygon_data()
// FREE MEMORY
factory_->destroyGeometry(poly_);
@@ -110,11 +110,11 @@
// Exterior (clone is required here because Polygon takes ownership)
GeometryPtr geo = ring.clone();
LinearRingPtr exterior = dynamic_cast<LinearRingPtr>(geo);
// Create non-empty Polygon
//geos::geom::Polygon poly(exterior, 0, &factory_);
PolygonAutoPtr poly(factory_->createPolygon(exterior, 0));
ensure( !poly->isEmpty() );
ensure( poly->isSimple() );
ensure( poly->isValid() );
@@ -186,7 +186,7 @@
template<>
void object::test<7>()
- GeometryPtr boundary = empty_poly_->getBoundary();
+ GeometryPtr boundary = empty_poly_->getBoundary();
ensure( boundary != 0 );
ensure( boundary->isEmpty() );
factory_->destroyGeometry(boundary);
@@ -197,7 +197,7 @@
template<>
void object::test<8>()
- GeometryPtr hull = empty_poly_->convexHull();
+ GeometryPtr hull = empty_poly_->convexHull();
ensure( hull != 0 );
ensure( hull->isEmpty() );
factory_->destroyGeometry(hull);
@@ -225,7 +225,7 @@
void object::test<11>()
ensure_equals( empty_poly_->getBoundaryDimension(), geos::geom::Dimension::L );
// Test of getNumPoints() for empty Polygon
template<>
@@ -250,7 +250,7 @@
ensure_equals( empty_poly_->getArea(), 0.0 );
// Test of isEmpty() for non-empty Polygon
template<>
template<>
@@ -267,7 +267,7 @@
ensure( poly_ != 0 );
- GeometryPtr envelope = poly_->getEnvelope();
+ GeometryPtr envelope = poly_->getEnvelope();
ensure( envelope != 0 );
ensure( !envelope->isEmpty() );
ensure_equals( envelope->getDimension(), geos::geom::Dimension::A );
@@ -283,7 +283,7 @@
- GeometryPtr boundary = poly_->getBoundary();
+ GeometryPtr boundary = poly_->getBoundary();
// OGC 05-126, Version: 1.1.0, Chapter 6.1.10 Surface
@@ -300,7 +300,7 @@
- GeometryPtr hull = poly_->convexHull();
+ GeometryPtr hull = poly_->convexHull();
ensure( !hull->isEmpty() );
ensure_equals( hull->getGeometryTypeId(), geos::geom::GEOS_POLYGON );
@@ -368,7 +368,7 @@
ensure( poly_->getArea() != 0.0 );
// Test of getCoordinates() for non-empty Polygon
template<>
template<>
@@ -433,7 +433,7 @@
geo = reader_.read("POLYGON ((0 0, 100 0, 100 100, 0 100, 0 0), (1 1, 1 10, 10 10, 10 1, 1 1) )");
ensure( geo != 0 );
ensure_equals( geo->getGeometryTypeId(), geos::geom::GEOS_POLYGON );
PolygonPtr poly = dynamic_cast<PolygonPtr>(geo);
ensure( poly != 0 );
ensure_equals( poly->getNumInteriorRing(), holesNum );
@@ -501,7 +501,7 @@
template<>
template<>
void object::test<34>()
PointPtr point = empty_poly_->getCentroid();
ensure( point == 0 );
@@ -510,7 +510,7 @@
template<>
template<>
void object::test<35>()
geos::geom::Coordinate centroid;
bool isCentroid = empty_poly_->getCentroid(centroid);
ensure( !isCentroid );
@@ -534,7 +534,7 @@
template<>
template<>
void object::test<37>()
bool isCentroid = poly_->getCentroid(centroid);
ensure( isCentroid );
@@ -566,5 +566,16 @@
ensure_equals( "Check Polygon::getCentroid() functions.", coordCentr, pointCentr );
+ // Test of Geometry::buffer(0) with convex polygon
+ template<>
+ template<>
+ void object::test<39>()
+ GeometryPtr gBuffer(poly_->buffer(0));
+ ensure_not(gBuffer->isEmpty());
+ ensure(gBuffer->isValid());
+ ensure_equals(gBuffer->getGeometryTypeId(), geos::geom::GEOS_POLYGON);
+ ensure(gBuffer->getNumPoints() == poly_->getNumPoints());
} // namespace tut
More information about the geos-commits
