[geos-commits] r4323 - branches/3.6/macros
Sandro Santilli
strk at kbt.io
Thu Jan 5 11:47:35 PST 2017
Author: strk
Date: 2017-01-05 11:47:35 -0800 (Thu, 05 Jan 2017)
New Revision: 4323
branches/3.6/macros/python.m4
Update python m4 macro, should fix #774
Modified: branches/3.6/macros/python.m4
--- branches/3.6/macros/python.m4 2017-01-05 19:47:29 UTC (rev 4322)
+++ branches/3.6/macros/python.m4 2017-01-05 19:47:35 UTC (rev 4323)
@@ -3,13 +3,13 @@
## From Andrew Dalke
## Updated by James Henstridge
-# Copyright (C) 1999, 2000, 2001, 2002, 2003, 2004, 2005
-# Free Software Foundation, Inc.
+# Copyright (C) 1999-2014 Free Software Foundation, Inc.
# This file is free software; the Free Software Foundation
# gives unlimited permission to copy and/or distribute it,
# with or without modifications, as long as this notice is preserved.
# AM_PATH_PYTHON([MINIMUM-VERSION], [ACTION-IF-FOUND], [ACTION-IF-NOT-FOUND])
# Adds support for distributing Python modules and packages. To
@@ -34,14 +34,14 @@
# numbers and dots only.
AC_DEFUN([AM_PATH_PYTHON],
- dnl Find a Python interpreter. Python versions prior to 1.5 are not
- dnl supported because the default installation locations changed from
- dnl $prefix/lib/site-python in 1.4 to $prefix/lib/python1.5/site-packages
- dnl in 1.5.
+ dnl Find a Python interpreter. Python versions prior to 2.0 are not
+ dnl supported. (2.0 was released on October 16, 2000).
m4_define_default([_AM_PYTHON_INTERPRETER_LIST],
- [python python2 python2.4 python2.3 python2.2 dnl
-python2.1 python2.0 python1.6 python1.5])
+[python python2 python3 python3.3 python3.2 python3.1 python3.0 python2.7 dnl
+ python2.6 python2.5 python2.4 python2.3 python2.2 python2.1 python2.0])
+ AC_ARG_VAR([PYTHON], [the Python interpreter])
m4_if([$1],[],[
dnl No version check is needed.
# Find any Python interpreter.
@@ -53,10 +53,11 @@
dnl A version check is needed.
if test -n "$PYTHON"; then
# If the user set $PYTHON, use it and don't search something else.
- AC_MSG_CHECKING([whether $PYTHON version >= $1])
+ AC_MSG_CHECKING([whether $PYTHON version is >= $1])
AM_PYTHON_CHECK_VERSION([$PYTHON], [$1],
- [AC_MSG_RESULT(yes)],
- [AC_MSG_ERROR(too old)])
+ [AC_MSG_RESULT([yes])],
+ [AC_MSG_RESULT([no])
+ AC_MSG_ERROR([Python interpreter is too old])])
am_display_PYTHON=$PYTHON
else
# Otherwise, try each interpreter until we find one that satisfies
@@ -87,7 +88,7 @@
dnl library.
AC_CACHE_CHECK([for $am_display_PYTHON version], [am_cv_python_version],
- [am_cv_python_version=`$PYTHON -c "import sys; print sys.version[[:3]]"`])
+ [am_cv_python_version=`$PYTHON -c "import sys; sys.stdout.write(sys.version[[:3]])"`])
AC_SUBST([PYTHON_VERSION], [$am_cv_python_version])
dnl Use the values of $prefix and $exec_prefix for the corresponding
@@ -102,9 +103,28 @@
dnl to know which OS platform Python thinks this is.
AC_CACHE_CHECK([for $am_display_PYTHON platform], [am_cv_python_platform],
- [am_cv_python_platform=`$PYTHON -c "import sys; print sys.platform"`])
+ [am_cv_python_platform=`$PYTHON -c "import sys; sys.stdout.write(sys.platform)"`])
AC_SUBST([PYTHON_PLATFORM], [$am_cv_python_platform])
+ # Just factor out some code duplication.
+ am_python_setup_sysconfig="\
+import sys
+# Prefer sysconfig over distutils.sysconfig, for better compatibility
+# with python 3.x. See automake bug#10227.
+try:
+ import sysconfig
+except ImportError:
+ can_use_sysconfig = 0
+else:
+ can_use_sysconfig = 1
+# Can't use sysconfig in CPython 2.7, since it's broken in virtualenvs:
+# <https://github.com/pypa/virtualenv/issues/118>
+try:
+ from platform import python_implementation
+ if python_implementation() == 'CPython' and sys.version[[:3]] == '2.7':
+ pass"
dnl Set up 4 directories:
@@ -112,13 +132,38 @@
dnl site-packages directory, not the python standard library
dnl directory like in previous automake betas. This behavior
dnl is more consistent with lispdir.m4 for example.
- dnl Query distutils for this directory. distutils does not exist in
- dnl Python 1.5, so we fall back to the hardcoded directory if it
- dnl doesn't work.
+ dnl Query distutils for this directory.
AC_CACHE_CHECK([for $am_display_PYTHON script directory],
[am_cv_python_pythondir],
- [am_cv_python_pythondir=`$PYTHON -c "from distutils import sysconfig; print sysconfig.get_python_lib(0,0,prefix='$PYTHON_PREFIX')" 2>/dev/null ||
- echo "$PYTHON_PREFIX/lib/python$PYTHON_VERSION/site-packages"`])
+ [if test "x$prefix" = xNONE
+ then
+ am_py_prefix=$ac_default_prefix
+ else
+ am_py_prefix=$prefix
+ fi
+ am_cv_python_pythondir=`$PYTHON -c "
+$am_python_setup_sysconfig
+if can_use_sysconfig:
+ sitedir = sysconfig.get_path('purelib', vars={'base':'$am_py_prefix'})
+else:
+ from distutils import sysconfig
+ sitedir = sysconfig.get_python_lib(0, 0, prefix='$am_py_prefix')
+sys.stdout.write(sitedir)"`
+ case $am_cv_python_pythondir in
+ $am_py_prefix*)
+ am__strip_prefix=`echo "$am_py_prefix" | sed 's|.|.|g'`
+ am_cv_python_pythondir=`echo "$am_cv_python_pythondir" | sed "s,^$am__strip_prefix,$PYTHON_PREFIX,"`
+ case $am_py_prefix in
+ /usr|/System*) ;;
+ am_cv_python_pythondir=$PYTHON_PREFIX/lib/python$PYTHON_VERSION/site-packages
+ esac
+ esac
AC_SUBST([pythondir], [$am_cv_python_pythondir])
dnl pkgpythondir -- $PACKAGE directory under pythondir. Was
@@ -129,13 +174,38 @@
dnl pyexecdir -- directory for installing python extension modules
dnl (shared libraries)
- dnl doesn't work.
AC_CACHE_CHECK([for $am_display_PYTHON extension module directory],
[am_cv_python_pyexecdir],
- [am_cv_python_pyexecdir=`$PYTHON -c "from distutils import sysconfig; print sysconfig.get_python_lib(1,0,prefix='$PYTHON_EXEC_PREFIX')" 2>/dev/null ||
- echo "${PYTHON_EXEC_PREFIX}/lib/python${PYTHON_VERSION}/site-packages"`])
+ [if test "x$exec_prefix" = xNONE
+ then
+ am_py_exec_prefix=$am_py_prefix
+ else
+ am_py_exec_prefix=$exec_prefix
+ fi
+ am_cv_python_pyexecdir=`$PYTHON -c "
+ sitedir = sysconfig.get_path('platlib', vars={'platbase':'$am_py_prefix'})
+else:
+ sitedir = sysconfig.get_python_lib(1, 0, prefix='$am_py_prefix')
+ case $am_cv_python_pyexecdir in
+ $am_py_exec_prefix*)
+ am__strip_prefix=`echo "$am_py_exec_prefix" | sed 's|.|.|g'`
+ am_cv_python_pyexecdir=`echo "$am_cv_python_pyexecdir" | sed "s,^$am__strip_prefix,$PYTHON_EXEC_PREFIX,"`
+ case $am_py_exec_prefix in
+ /usr|/System*) ;;
+ am_cv_python_pyexecdir=$PYTHON_EXEC_PREFIX/lib/python$PYTHON_VERSION/site-packages
+ esac
+ esac
AC_SUBST([pyexecdir], [$am_cv_python_pyexecdir])
dnl pkgpyexecdir -- $(pyexecdir)/$(PACKAGE)
@@ -155,14 +225,15 @@
# Run ACTION-IF-FALSE otherwise.
# This test uses sys.hexversion instead of the string equivalent (first
# word of sys.version), in order to cope with versions such as 2.2c1.
-# hexversion has been introduced in Python 1.5.2; it's probably not
-# worth to support older versions (1.5.1 was released on October 31, 1998).
+# This supports Python 2.0 or higher. (2.0 was released on October 16, 2000).
AC_DEFUN([AM_PYTHON_CHECK_VERSION],
- [prog="import sys, string
+ [prog="import sys
# split strings by '.' and convert to numeric. Append some zeros
# because we need at least 4 digits for the hex conversion.
-minver = map(int, string.split('$2', '.')) + [[0, 0, 0]]
+# map returns an iterator in Python 3.0 and a list in 2.x
+minver = list(map(int, '$2'.split('.'))) + [[0, 0, 0]]
minverhex = 0
-for i in xrange(0, 4): minverhex = (minverhex << 8) + minver[[i]]
+# xrange is not present in Python 3.0 and range returns an iterator
+for i in list(range(0, 4)): minverhex = (minverhex << 8) + minver[[i]]
sys.exit(sys.hexversion < minverhex)"
AS_IF([AM_RUN_LOG([$1 -c "$prog"])], [$3], [$4])])
More information about the geos-commits
