[geos-commits] [SCM] geos branch master updated. f73910622e826b12e24fb31c7378ef8a08c07268
git at osgeo.org
git at osgeo.org
Fri Jul 14 07:06:46 PDT 2017
the project "geos".
via f73910622e826b12e24fb31c7378ef8a08c07268 (commit)
from 03073476f4a07f0fe99e804a50fcdf87e550459a (commit)
revisions in full, below.
commit f73910622e826b12e24fb31c7378ef8a08c07268
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Jul 14 15:30:57 2017 +0200
Use overlay specific result checker
The check just supports some snap-distance based tolerance
for exact match (in addition to topology equality which is
needed for some JTS tests to pass)
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index a5338dd..bb30b7c 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -34,6 +34,7 @@
#include <geos/geom/PrecisionModel.h>
#include <geos/geom/BinaryOp.h>
#include <geos/operation/overlay/OverlayOp.h>
+#include <geos/operation/overlay/snap/GeometrySnapper.h>
#include <geos/operation/buffer/BufferBuilder.h>
#include <geos/operation/buffer/BufferParameters.h>
#include <geos/operation/buffer/BufferOp.h>
@@ -202,6 +203,16 @@ normalize_filename(const std::string& str)
return newstring;
+static int
+checkOverlaySuccess(geom::Geometry const& gRes, geom::Geometry const& gRealRes)
+ double tol = operation::overlay::snap::GeometrySnapper::computeSizeBasedSnapTolerance(gRes);
+ if ( gRes.equals(&gRealRes) ) return 1;
+ std::cerr << "Using an overlay tolerance of " << tol << std::endl;
+ if ( gRes.equalsExact(&gRealRes, tol) ) return 1;
+ return 0;
/* Could be an XMLTester class private but oh well.. */
static int
checkBufferSuccess(geom::Geometry const& gRes, geom::Geometry const& gRealRes, double dist)
@@ -862,7 +873,7 @@ XMLTester::parseTest(const TiXmlNode* node)
gRealRes = gA->Union();
- if (gRes->equals(gRealRes.get())) success=1;
+ success = checkOverlaySuccess(*gRes, *gRealRes);
actual_result=printGeom(gRealRes.get());
expected_result=printGeom(gRes.get());
Summary of changes:
tests/xmltester/XMLTester.cpp | 13 ++++++++++++-
1 file changed, 12 insertions(+), 1 deletion(-)
hooks/post-receive
geos
More information about the geos-commits
