[geos-commits] [SCM] geos branch master updated. 63410b14d1ca1117a91b2e31928d893cf78fa1fb
git at osgeo.org
git at osgeo.org
Wed Jul 19 14:59:28 PDT 2017
the project "geos".
via 63410b14d1ca1117a91b2e31928d893cf78fa1fb (commit)
from 869e009e6c9b9d0d570d09bc24e711acdffc6548 (commit)
revisions in full, below.
commit 63410b14d1ca1117a91b2e31928d893cf78fa1fb
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Jul 19 23:58:28 2017 +0200
Add support for testing prepared geometries operations in XMLTester
Add 3 more tests from JTS testsuite now that they can be run
See #694
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index 588c364..37928b0 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -62,6 +62,9 @@ SAFE_XMLTESTS=$(srcdir)/tests/testLeaksBig.xml \
$(srcdir)/tests/general/TestFunctionPL.xml \
$(srcdir)/tests/general/TestFunctionPP.xml \
$(srcdir)/tests/general/TestInteriorPoint.xml \
+ $(srcdir)/tests/general/TestPreparedPointPredicate.xml \
+ $(srcdir)/tests/general/TestPreparedPolygonPredicate.xml \
+ $(srcdir)/tests/general/TestPreparedPredicatesWithGeometryCollection.xml \
$(srcdir)/tests/general/TestRectanglePredicate.xml \
$(srcdir)/tests/general/TestRelateAA.xml \
$(srcdir)/tests/general/TestRelateLA.xml \
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index bb30b7c..d4e7d75 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -32,6 +32,8 @@
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/IntersectionMatrix.h>
#include <geos/geom/PrecisionModel.h>
+#include <geos/geom/prep/PreparedGeometry.h>
+#include <geos/geom/prep/PreparedGeometryFactory.h>
#include <geos/geom/BinaryOp.h>
#include <geos/operation/overlay/OverlayOp.h>
#include <geos/operation/overlay/snap/GeometrySnapper.h>
@@ -84,10 +86,15 @@
using namespace geos;
using namespace geos::operation::polygonize;
using namespace geos::operation::linemerge;
+using namespace geos::geom::prep;
using std::runtime_error;
namespace {
+std::auto_ptr<const PreparedGeometry> prepare( const geom::Geometry *g ) {
+ return std::auto_ptr<const PreparedGeometry> ( PreparedGeometryFactory::prepare(g) );
// Asymmetric Rounding Algorithm - equivalent to Java Math.round()
// Copy from geos/util/math.cpp
double java_math_round(double val)
@@ -469,11 +476,31 @@ XMLTester::parseRun(const TiXmlNode* node)
if ( el ) parsePrecisionModel(el);
else pm.reset(new PrecisionModel());
+ // Look for geometryOperation, if any
+ usePrepared = false;
+ el = node->FirstChildElement("geometryOperation");
+ if ( el ) {
+ const TiXmlNode* txt = el->FirstChild();
+ if ( txt ) {
+ std::string op = trimBlanks(txt->Value());
+ if ( op.find("PreparedGeometryOperation") ) {
+ usePrepared = true;
+ } else {
+ std::cerr << *curr_file
+ <<": WARNING: unknown geometryOperation: "
+ << op << std::endl;
if (verbose > 1)
- std::cerr << *curr_file <<": run: Precision Model: " << pm->toString() <<std::endl;
+ std::cerr << *curr_file <<": run: Precision Model: " << pm->toString();
+ if ( usePrepared ) std::cerr << " (prepared)";
+ std::cerr << std::endl;
factory = geom::GeometryFactory::create(pm.get());
wktreader.reset(new io::WKTReader(factory.get()));
wktwriter.reset(new io::WKTWriter());
@@ -536,7 +563,6 @@ XMLTester::parsePrecisionModel(const TiXmlElement* el)
bool
XMLTester::testValid(const geom::Geometry* g, const std::string& label)
@@ -932,8 +958,12 @@ XMLTester::parseTest(const TiXmlNode* node)
geom::Geometry *g1 = opArg1 == "B" ? gB : gA;
geom::Geometry *g2 = opArg2 == "B" ? gB : gA;
- if (g1->intersects(g2)) actual_result="true";
- else actual_result="false";
+ actual_result="false";
+ if ( prepare(g1)->intersects(g2) ) actual_result="true";
+ else if (g1->intersects(g2)) actual_result="true";
if (actual_result==opRes) success=1;
@@ -943,8 +973,12 @@ XMLTester::parseTest(const TiXmlNode* node)
- if (g1->contains(g2)) actual_result="true";
+ if ( prepare(g1)->contains(g2) ) actual_result="true";
+ else if (g1->contains(g2)) actual_result="true";
@@ -954,8 +988,12 @@ XMLTester::parseTest(const TiXmlNode* node)
- if (g1->within(g2)) actual_result="true";
+ if ( prepare(g1)->within(g2) ) actual_result="true";
+ else if (g1->within(g2)) actual_result="true";
@@ -965,8 +1003,12 @@ XMLTester::parseTest(const TiXmlNode* node)
- if (g1->covers(g2)) actual_result="true";
+ if ( prepare(g1)->covers(g2) ) actual_result="true";
+ else if (g1->covers(g2)) actual_result="true";
@@ -976,8 +1018,12 @@ XMLTester::parseTest(const TiXmlNode* node)
- if (g1->coveredBy(g2)) actual_result="true";
+ if ( prepare(g1)->coveredBy(g2) ) actual_result="true";
+ else if (g1->coveredBy(g2)) actual_result="true";
@@ -1483,6 +1529,14 @@ XMLTester::runPredicates(const geom::Geometry *gA, const geom::Geometry *gB)
std::cout << "\t Within:\tAB=" << (gA->within(gB)?"T":"F") << ", BA=" << (gB->within(gA)?"T":"F") << std::endl;
std::cout << "\t Contains:\tAB=" << (gA->contains(gB)?"T":"F") << ", BA=" << (gB->contains(gA)?"T":"F") << std::endl;
std::cout << "\t Overlaps:\tAB=" << (gA->overlaps(gB)?"T":"F") << ", BA=" << (gB->overlaps(gA)?"T":"F") << std::endl;
+ std::cout << "\t Prepared Disjoint:\tAB=" << (prepare(gA)->disjoint(gB)?"T":"F") << ", BA=" << (prepare(gB)->disjoint(gA)?"T":"F") << std::endl;
+ std::cout << "\tPrepared Intersects:\tAB=" << (prepare(gA)->intersects(gB)?"T":"F") << ", BA=" << (prepare(gB)->intersects(gA)?"T":"F") << std::endl;
+ std::cout << "\t Prepared Touches:\tAB=" << (prepare(gA)->touches(gB)?"T":"F") << ", BA=" << (prepare(gB)->touches(gA)?"T":"F") << std::endl;
+ std::cout << "\t Prepared Crosses:\tAB=" << (prepare(gA)->crosses(gB)?"T":"F") << ", BA=" << (prepare(gB)->crosses(gA)?"T":"F") << std::endl;
+ std::cout << "\t Prepared Within:\tAB=" << (prepare(gA)->within(gB)?"T":"F") << ", BA=" << (prepare(gB)->within(gA)?"T":"F") << std::endl;
+ std::cout << "\t Prepared Contains:\tAB=" << (prepare(gA)->contains(gB)?"T":"F") << ", BA=" << (prepare(gB)->contains(gA)?"T":"F") << std::endl;
+ std::cout << "\t Prepared Overlaps:\tAB=" << (prepare(gA)->overlaps(gB)?"T":"F") << ", BA=" << (prepare(gB)->overlaps(gA)?"T":"F") << std::endl;
XMLTester::~XMLTester()
diff --git a/tests/xmltester/XMLTester.h b/tests/xmltester/XMLTester.h
index 8f517f3..a867ed9 100644
--- a/tests/xmltester/XMLTester.h
+++ b/tests/xmltester/XMLTester.h
@@ -50,6 +50,7 @@ private:
geom::Geometry *gB;
geom::Geometry *gT;
+ bool usePrepared;
std::auto_ptr<geom::PrecisionModel> pm;
geom::GeometryFactory::unique_ptr factory;
std::auto_ptr<io::WKTReader> wktreader;
diff --git a/tests/xmltester/tests/general/MISSING b/tests/xmltester/tests/general/MISSING
index 9bdbb96..3928e7a 100644
--- a/tests/xmltester/tests/general/MISSING
+++ b/tests/xmltester/tests/general/MISSING
@@ -4,11 +4,3 @@ Tests found in JTS/testxml/general and not ported as of rev 3991 (Jun 30 2014)
TestDensify.xml
- requires densify::Densifier still unported
-TestPreparedPointPredicate.xml
- - requires using custom operation (PreparedGeometryOperation)
-TestPreparedPolygonPredicate.xml
-TestPreparedPredicatesWithGeometryCollection.xml
diff --git a/tests/xmltester/tests/general/TestPreparedPointPredicate.xml b/tests/xmltester/tests/general/TestPreparedPointPredicate.xml
new file mode 100644
index 0000000..5c353df
--- /dev/null
+++ b/tests/xmltester/tests/general/TestPreparedPointPredicate.xml
@@ -0,0 +1,34 @@
+<run>
+ <desc>Test cases for PreparedPoint predicates</desc>
+ <precisionModel type="FLOATING"/>
+ <geometryOperation>org.locationtech.jtstest.geomop.PreparedGeometryOperation</geometryOperation>
+<case>
+<desc> P/A - point in interior of poly</desc>
+ <a> POINT (100 100)
+ </a>
+ <b> POLYGON ((50 130, 150 130, 100 50, 50 130))
+ </b>
+<test> <op name="intersects" arg1="A" arg2="B"> true </op> </test>
+</case>
+<case>
+<desc> P/A - point on boundary of poly</desc>
+ <a> POINT (100 50)
+ </a>
+ </b>
+</case>
+<case>
+<desc> P/A - point outside poly</desc>
+ <a> POINT (200 200)
+ </a>
+ </b>
+<test> <op name="intersects" arg1="A" arg2="B"> false </op> </test>
+</case>
+</run>
diff --git a/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml b/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml
index 0000000..04ca2e6
--- /dev/null
+++ b/tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml
@@ -0,0 +1,191 @@
+<run>
+ <desc>Test cases for PreparedGeometry predicates using polygons as input</desc>
+<case>
+ <desc>A/P - point equal to start point of polygon
+ </desc>
+ <a>
+ POLYGON ((10 10, 60 100, 110 10, 10 10))
+ </a>
+ <b>
+ POINT (10 10)
+ </b>
+<test> <op name="contains" arg1="A" arg2="B"> false </op> </test>
+<test> <op name="covers" arg1="A" arg2="B"> true </op> </test>
+</case>
+<case>
+ </desc>
+ <a>
+ </a>
+ <b>
+ POINT (10 20)
+ </b>
+<test> <op name="covers" arg1="A" arg2="B"> false </op> </test>
+</case>
+<case>
+ <desc>mA/L
+ A has 2 shells touching at one vertex and one non-vertex.
+ B passes between the shells, but is wholely contained
+ </desc>
+ <a>
+ MULTIPOLYGON (((100 30, 30 110, 150 110, 100 30)),
+ ((90 110, 30 170, 140 170, 90 110)))
+ </a>
+ <b>
+ LINESTRING (90 80, 90 150)
+ </b>
+<test> <op name="contains" arg1="A" arg2="B"> true </op> </test>
+</case>
+<case>
+ <desc>mA/L
+ B passes between the shells, but is NOT contained (since it is slightly offset)
+ </desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING (90.1 80, 90 150)
+ </b>
+</case>
+<case>
+ <desc>mA/L - 2 disjoint shells with line crossing between them </desc>
+ <a>
+ MULTIPOLYGON (((50 20, 10 70, 80 70, 50 20)),
+ ((10 90, 80 90, 50 140, 10 90)))
+ </a>
+ <b>
+ LINESTRING (50 110, 50 60)
+ </b>
+</case>
+<case>
+ <desc>A/L - proper intersection crossing bdy
+ </desc>
+ <a>
+ POLYGON ((10 10, 10 100, 120 110, 120 30, 10 10))
+ </a>
+ <b>
+ LINESTRING (60 60, 70 140)
+ </b>
+</case>
+<case>
+ <desc>A/L - non-proper intersection crossing bdy
+ </desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING (60 60, 60 140)
+ </b>
+</case>
+<case>
+ <desc>A/L - wholely contained
+ </desc>
+ <a> POLYGON ((10 10, 60 100, 110 10, 10 10))
+ </a>
+ <b> LINESTRING (50 30, 70 60)
+ </b>
+</case>
+<case>
+ <desc>A/L - contained but touching bdy at interior point
+ </desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING (60 10, 70 60)
+ </b>
+</case>
+<case>
+ <desc>A/L - line in bdy - covered but not contained
+ </desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING (30 10, 90 10)
+ </b>
+</case>
+<case>
+ <desc>A/A - two equal polygons
+ </desc>
+ <a>
+ POLYGON((20 20, 20 100, 120 100, 140 20, 20 20))
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>A/L - line with repeated points
+ </desc>
+ <a>
+ </a>
+ <b>
+ LINESTRING (10 60, 50 60, 60 30, 60 30, 90 80, 90 80, 160 70)
+ </b>
+</case>
+<case>
+ <desc>A/L - polygon and line with repeated points
+ </desc>
+ <a>
+ POLYGON((20 20, 20 100, 120 100, 120 100, 120 100, 140 20, 140 20, 140 20, 20 20))
+ </a>
+ <b>
+ </b>
+</case>
+</run>
diff --git a/tests/xmltester/tests/general/TestPreparedPredicatesWithGeometryCollection.xml b/tests/xmltester/tests/general/TestPreparedPredicatesWithGeometryCollection.xml
index 0000000..9ea3821
--- /dev/null
+++ b/tests/xmltester/tests/general/TestPreparedPredicatesWithGeometryCollection.xml
@@ -0,0 +1,81 @@
+<run>
+ <desc>Test cases for PreparedGeometry predicates using GeometryCollections as test geometry.
+ This tests the various combinations of target geometry and predicate which support
+ GCs as the test geometry.
+ </desc>
+<case>
+ <desc>Box against GC
+ </desc>
+ <a>
+ POLYGON ((0 0, 0 100, 200 100, 200 0, 0 0))
+ </a>
+ <b>
+ GEOMETRYCOLLECTION (POLYGON ((50 160, 110 60, 150 160, 50 160)),
+ LINESTRING (50 40, 170 120))
+ </b>
+</case>
+<case>
+ <desc>Box against GC, with containment
+ </desc>
+ <a>
+ POLYGON ((0 0, 0 200, 200 200, 200 0, 0 0))
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>Polygon-with-hole against GC
+ </desc>
+ <a>
+ POLYGON ((0 0, 0 270, 200 270, 200 0, 0 0),
+ (30 210, 170 210, 60 20, 30 210))
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>Linestring against GC
+ </desc>
+ <a>
+ LINESTRING (20 90, 90 190, 170 50)
+ </a>
+ <b>
+ </b>
+</case>
+<case>
+ <desc>Linestring against GC, with containment
+ </desc>
+ <a>
+ LINESTRING (20 20, 100 100, 180 20)
+ </a>
+ <b>
+ GEOMETRYCOLLECTION (LINESTRING (40 40, 80 80), POINT (120 80))
+ </b>
+</case>
+</run>
Summary of changes:
tests/xmltester/Makefile.am | 3 +
tests/xmltester/XMLTester.cpp | 78 ++++++--
tests/xmltester/XMLTester.h | 1 +
tests/xmltester/tests/general/MISSING | 8 -
.../tests/general/TestPreparedPointPredicate.xml | 34 ++++
.../tests/general/TestPreparedPolygonPredicate.xml | 191 ++++++++++++++++++++
...estPreparedPredicatesWithGeometryCollection.xml | 81 +++++++++
7 files changed, 376 insertions(+), 20 deletions(-)
create mode 100644 tests/xmltester/tests/general/TestPreparedPointPredicate.xml
create mode 100644 tests/xmltester/tests/general/TestPreparedPolygonPredicate.xml
create mode 100644 tests/xmltester/tests/general/TestPreparedPredicatesWithGeometryCollection.xml
hooks/post-receive
geos
More information about the geos-commits
