[geos-commits] [SCM] geos branch svn-3.6 updated. 90134c68140ee9958263949a3f4f33a528d09ad0
Tue Jul 25 01:37:24 PDT 2017
the project "geos".
The branch, svn-3.6 has been updated
       via  90134c68140ee9958263949a3f4f33a528d09ad0 (commit)
      from  a12a5ecc5c8ccd41c5e4952bcb58d994e4d709e2 (commit)
revisions in full, below.
commit 90134c68140ee9958263949a3f4f33a528d09ad0
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jul 25 10:32:17 2017 +0200
    Indexed steps, configure.ac name fix
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index ac939ab..c86daa2 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -1,47 +1,48 @@
-- Verify that the versions currently set (see 10 and 11 below) make
+1. Verify that the versions currently set (see 10 and 11 below) make
    sense for this release.
-- Run 'make distcheck', fix any problem with it.
+2. Run 'make distcheck', fix any problem with it.
-- Update the NEWS file (extract most important things from the
-  repository log). Make sure to update the release date
+3. Update the NEWS file (extract most important things from the
+   repository log). Make sure to update the release date
-- Commit the changes in the NEWS file.
+4. Commit the changes in the NEWS file.
-- Tag the release:
+5. Tag the release:
    $ git tag MAJOR.MINOR.PATCH
-- Build a tarball: make dist-bzip2
+6. Run 'make dist-bzip2'.
+   $ ./autogen.sh && ./configure && make dist-bzip2
-- Verify that you can unpack and build the generated tarball
-  (and that it contains a correct ChangeLog)
+7. Verify that you can unpack and build the tarball
+   (and that it contains a correct ChangeLog)
-- Copy the tarball to upload.osgeo.org:/osgeo/download/geos
+8. Copy the tarball to upload.osgeo.org:/osgeo/download/geos
-- Increment all the version numbers for the next release, as below.
+9. Increment all the version numbers for the next release, as below.
-- Increment CAPI_INTERFACE_X in configure.in
-   - For a release with no interface changes just bump REVISION.
-     [ Even if *nothing* changed in CAPI ]
-   - Adding interfaces, bump CURRENT/AGE, set REVISION to 0.
-   - Deleting interfaces / compatibility issues - bump CURRENT, others to zero
-     [ THIS MUST BE CAREFULLY AVOIDED ]
+10. Increment CAPI_INTERFACE_X in configure.ac
+    - For a release with no interface changes just bump REVISION.
+      [ Even if *nothing* changed in CAPI ]
+    - Adding interfaces, bump CURRENT/AGE, set REVISION to 0.
+    - Deleting interfaces / compatibility issues - bump CURRENT, others to zero
+      [ THIS MUST BE CAREFULLY AVOIDED ]
-- Increment release version:
-   - In configure.in
-   - In include/geos/version.h.vc
-   - In capi/geos_c.h.in
-     - VERSION_PATCH for bugfixes/improvements (even breaking C++ API)
-     - VERSION_MINOR for NEW interfaces in the C lib
-     - VERSION_MAJOR for SUBSTANTIAL additions or C lib ABI break
-   - In main CMakeLists.txt main one
-      - VERSION_MAJOR, VERSION_MINOR, VERSION_PATCH
-      - CAPI_INTERFACE_*
+11. Increment release version:
+    - In configure.in
+    - In include/geos/version.h.vc
+    - In capi/geos_c.h.in
+      - VERSION_PATCH for bugfixes/improvements (even breaking C++ API)
+      - VERSION_MINOR for NEW interfaces in the C lib
+      - VERSION_MAJOR for SUBSTANTIAL additions or C lib ABI break
+    - In main CMakeLists.txt main one
+       - VERSION_MAJOR, VERSION_MINOR, VERSION_PATCH
+       - CAPI_INTERFACE_*
-- Update wiki page https://trac.osgeo.org/geos/ at Download section
+12. Update wiki page https://trac.osgeo.org/geos/ at Download section
     - Add latest release
     - Remove previos patch level release (if any)
-- Announce
+13. Announce
Summary of changes:
 HOWTO_RELEASE |   61 +++++++++++++++++++++++++++++----------------------------
 1 file changed, 31 insertions(+), 30 deletions(-)
hooks/post-receive
geos
More information about the geos-commits mailing list
