[geos-commits] [SCM] geos branch master updated. 8d171e4d47149666f1a10d4ee42ea445b8925c6e
git at osgeo.org
git at osgeo.org
Fri Jun 30 04:26:10 PDT 2017
the project "geos".
via 8d171e4d47149666f1a10d4ee42ea445b8925c6e (commit)
via 28826db0e67354671725506084407e73bbc98003 (commit)
from 60abce68d5eab69188072c350ed03f18a7b6418a (commit)
revisions in full, below.
commit 8d171e4d47149666f1a10d4ee42ea445b8925c6e
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Jun 30 13:25:49 2017 +0200
Optionally debug-print invalid geometry
diff --git a/include/geos/geom/BinaryOp.h b/include/geos/geom/BinaryOp.h
index 24c96cd..98f3d91 100644
--- a/include/geos/geom/BinaryOp.h
+++ b/include/geos/geom/BinaryOp.h
@@ -72,6 +72,7 @@
#include <memory> // for auto_ptr
//#define GEOS_DEBUG_BINARYOP 1
+#define GEOS_DEBUG_BINARYOP_PRINT_INVALID 1
#ifdef GEOS_DEBUG_BINARYOP
# include <iostream>
@@ -186,7 +187,13 @@ check_valid(const Geometry& g, const std::string& label, bool doThrow=false, boo
<< err->toString()
<< " (" << std::setprecision(20)
<< err->getCoordinate() << ")"
- << std::endl;
+ << std::endl
+#ifdef GEOS_DEBUG_BINARYOP_PRINT_INVALID
+ << "<A>" << std::endl
+ << g.toString()
+ << std::endl
+#endif
#endif
if ( doThrow ) {
throw geos::util::TopologyException(
commit 28826db0e67354671725506084407e73bbc98003
Date: Fri Jun 30 12:57:55 2017 +0200
Add (disabled) code to check validity of overlay op results
index 4bdd368..24c96cd 100644
@@ -88,6 +88,12 @@
#endif
+ * Check validity of operation between original geometries
+#define GEOS_CHECK_ORIGINAL_RESULT_VALIDITY 0
* Define this to use PrecisionReduction policy
* in an attempt at by-passing binary operation
* robustness problems (handles TopologyExceptions)
@@ -97,6 +103,17 @@
#endif
+ * Check validity of operation performed
+ * by precision reduction policy.
+ * Precision reduction policy reduces precision of inputs
+ * and restores it in the result. The restore phase may
+ * introduce invalidities.
+#define GEOS_CHECK_PRECISION_REDUCTION_VALIDITY 0
* Define this to use TopologyPreserving simplification policy
@@ -134,6 +151,12 @@
# define USE_SNAPPING_POLICY 1
#endif
+ * Check validity of result from SnapOp
+#define GEOS_CHECK_SNAPPINGOP_VALIDITY 0
namespace geos {
namespace geom { // geos::geom
@@ -320,6 +343,14 @@ BinaryOp(const Geometry* g0, const Geometry *g1, BinOp _Op)
std::cerr << "Trying with original input." << std::endl;
#endif
ret.reset(_Op(g0, g1));
+#if GEOS_CHECK_ORIGINAL_RESULT_VALIDITY
+ check_valid(*ret, "Overlay result between original inputs", true, true);
+#endif
+#if GEOS_DEBUG_BINARYOP
+ std::cerr << "Attempt with original input succeeded" << std::endl;
+#endif
return ret;
catch (const geos::util::TopologyException& ex)
@@ -329,18 +360,11 @@ BinaryOp(const Geometry* g0, const Geometry *g1, BinOp _Op)
std::cerr << "Original exception: " << ex.what() << std::endl;
#endif
- check_valid(*g0, "Input geom 0", true, true);
- check_valid(*g1, "Input geom 1", true, true);
-#if GEOS_DEBUG_BINARYOP
- // Should we just give up here ?
- check_valid(*g0, "Input geom 0");
- check_valid(*g1, "Input geom 1");
-#endif
#endif // USE_ORIGINAL_INPUT
+ check_valid(*g0, "Input geom 0", true, true);
+ check_valid(*g1, "Input geom 1", true, true);
#ifdef USE_COMMONBITS_POLICY
// Try removing common bits (possibly obsoleted by snapping below)
@@ -378,24 +402,13 @@ BinaryOp(const Geometry* g0, const Geometry *g1, BinOp _Op)
cbr.addCommonBits( ret.get() );
+#if GEOS_CHECK_COMMONBITS_VALIDITY
check_valid(*ret, "CBR: result (after common-bits addition)", true);
+#endif
-#if GEOS_CHECK_COMMONBITS_VALIDITY
- // check that result is a valid geometry after the
- // reshift to orginal precision (see EnhancedPrecisionOp)
- using operation::valid::IsValidOp;
- using operation::valid::TopologyValidationError;
- IsValidOp ivo(ret.get());
- if ( ! ivo.isValid() )
- TopologyValidationError* e = ivo.getValidationError();
- throw geos::util::TopologyException(
- "Result of overlay became invalid "
- "after re-addin common bits of operand "
- "coordinates: " + e->toString(),
- e->getCoordinate());
-#endif // GEOS_CHECK_COMMONBITS_VALIDITY
+ std::cerr << "Attempt with CBR succeeded" << std::endl;
+#endif
return ret;
@@ -423,8 +436,11 @@ BinaryOp(const Geometry* g0, const Geometry *g1, BinOp _Op)
try {
ret = SnapOp(g0, g1, _Op);
+#if GEOS_CHECK_SNAPPINGOP_VALIDITY
+ check_valid(*ret, "SNAP: result", true, true);
+#endif
- std::cerr << "SnapOp succeeded" << std::endl;
+ std::cerr << "SnapOp succeeded" << std::endl;
#endif
return ret;
@@ -478,6 +494,11 @@ BinaryOp(const Geometry* g0, const Geometry *g1, BinOp _Op)
GeomPtr rG0( reducer.reduce(*g0) );
GeomPtr rG1( reducer.reduce(*g1) );
+ check_valid(*rG0, "PR: geom 0 (after precision reduction)");
+ check_valid(*rG1, "PR: geom 1 (after precision reduction)");
+#endif
try
ret.reset( _Op(rG0.get(), rG1.get()) );
@@ -488,15 +509,23 @@ BinaryOp(const Geometry* g0, const Geometry *g1, BinOp _Op)
else {
ret.reset( g1->getFactory()->createGeometry(ret.get()) );
+#if GEOS_CHECK_PRECISION_REDUCTION_VALIDITY
+ check_valid(*ret, "PR: result (after restore of original precision)", true);
+#endif
+ std::cerr << "Attempt with scale " << scale << " succeeded" << std::endl;
+#endif
return ret;
- if ( scale == 1 ) throw ex;
std::cerr << "Reduced with scale (" << scale << "): "
#endif
+ if ( scale == 1 ) throw ex;
@@ -507,7 +536,7 @@ BinaryOp(const Geometry* g0, const Geometry *g1, BinOp _Op)
std::cerr << "Reduced: " << ex.what() << std::endl;
#endif
- ::geos::ignore_unused_variable_warning(ex);
+ ::geos::ignore_unused_variable_warning(ex);
#endif
@@ -566,6 +595,17 @@ BinaryOp(const Geometry* g0, const Geometry *g1, BinOp _Op)
#endif
// USE_TP_SIMPLIFY_POLICY }
+ std::cerr << "No attempts worked to union " << std::endl;
+ std::cerr << "Input geometries:" << std::endl
+ << g0->toString() << std::endl
+ << "</A>" << std::endl
+ << "<B>" << std::endl
+ << g1->toString() << std::endl
+ << "</B>" << std::endl;
+#endif
throw origException;
Summary of changes:
include/geos/geom/BinaryOp.h | 107 ++++++++++++++++++++++++++++++------------
1 file changed, 77 insertions(+), 30 deletions(-)
hooks/post-receive
geos
More information about the geos-commits
