[geos-commits] r4348 - trunk
Mateusz Loskot
mateusz at loskot.net
Mon Mar 20 16:31:59 PDT 2017
Author: mloskot
Date: 2017-03-20 16:31:59 -0700 (Mon, 20 Mar 2017)
New Revision: 4348
trunk/appveyor.yml
AppVeyor: Fix cmake command line
Modified: trunk/appveyor.yml
--- trunk/appveyor.yml 2017-03-20 23:28:31 UTC (rev 4347)
+++ trunk/appveyor.yml 2017-03-20 23:31:59 UTC (rev 4348)
@@ -8,7 +8,7 @@
branches:
only:
- - svn-trunk
+ - svn-trunk
- svn-3.6
- svn-3.5
@@ -30,13 +30,13 @@
before_build:
- ps: |
- if ($env:PLATFORM -Match "Win32") {
+ if ($env:PLATFORM -Match "x86") {
$G="Visual Studio 14 2015"
- } elseif ($env:PLATFORM -Match "Win64") {
+ } elseif ($env:PLATFORM -Match "x64") {
$G="Visual Studio 14 2015 Win64"
Write-Host "Running CMake:" -ForegroundColor Magenta
- cmake.exe -G $G -DCMAKE_BUILD_TYPE=$env:CFG -DGEOS_ENABLE_TESTS=OFF -DGEOS_BUILD_SHARED=OFF $env:APPVEYOR_BUILD_FOLDER
+ cmake.exe -G $G -DCMAKE_BUILD_TYPE=$env:CONFIGURATION -DGEOS_ENABLE_TESTS=OFF -DGEOS_BUILD_SHARED=OFF $env:APPVEYOR_BUILD_FOLDER
Write-Host "Running MSBuild:" -ForegroundColor Magenta
- ps:
More information about the geos-commits
