[geos-commits] r4361 - trunk/src/geom/util
Mateusz Loskot
mateusz at loskot.net
Tue Mar 21 04:53:10 PDT 2017
Author: mloskot
Date: 2017-03-21 04:53:10 -0700 (Tue, 21 Mar 2017)
New Revision: 4361
trunk/src/geom/util/GeometryEditor.cpp
trunk/src/geom/util/GeometryTransformer.cpp
trunk/src/geom/util/ShortCircuitedGeometryVisitor.cpp
Fix warning about signed/unsigned int mismatch.
Modified: trunk/src/geom/util/GeometryEditor.cpp
--- trunk/src/geom/util/GeometryEditor.cpp 2017-03-21 11:23:03 UTC (rev 4360)
+++ trunk/src/geom/util/GeometryEditor.cpp 2017-03-21 11:53:10 UTC (rev 4361)
@@ -1,4 +1,4 @@
* GEOS - Geometry Engine Open Source
* http://geos.osgeo.org
@@ -155,7 +155,7 @@
GeometryCollection *newCollection = dynamic_cast<GeometryCollection*>( operation->edit(collection,factory) );
vector<Geometry*> *geometries = new vector<Geometry*>();
- for (unsigned int i=0, n=newCollection->getNumGeometries(); i<n; i++)
+ for (std::size_t i=0, n=newCollection->getNumGeometries(); i<n; i++)
Geometry *geometry = edit(newCollection->getGeometryN(i),
operation);
Modified: trunk/src/geom/util/GeometryTransformer.cpp
--- trunk/src/geom/util/GeometryTransformer.cpp 2017-03-21 11:23:03 UTC (rev 4360)
+++ trunk/src/geom/util/GeometryTransformer.cpp 2017-03-21 11:53:10 UTC (rev 4361)
@@ -1,4 +1,4 @@
@@ -335,7 +335,7 @@
auto_ptr< vector<Geometry*> > transGeomList( new vector<Geometry*>() );
- for (unsigned int i=0, n=geom->getNumGeometries(); i<n; i++)
+ for (std::size_t i=0, n=geom->getNumGeometries(); i<n; i++)
const Polygon* p = dynamic_cast<const Polygon*>(
geom->getGeometryN(i));
@@ -366,7 +366,7 @@
vector<Geometry*>* transGeomList = new vector<Geometry*>();
Geometry::AutoPtr transformGeom = transform(
geom->getGeometryN(i)); // no parent ?
Modified: trunk/src/geom/util/ShortCircuitedGeometryVisitor.cpp
--- trunk/src/geom/util/ShortCircuitedGeometryVisitor.cpp 2017-03-21 11:23:03 UTC (rev 4360)
+++ trunk/src/geom/util/ShortCircuitedGeometryVisitor.cpp 2017-03-21 11:53:10 UTC (rev 4361)
@@ -1,4 +1,4 @@
@@ -30,7 +30,7 @@
void
ShortCircuitedGeometryVisitor::applyTo(const Geometry &geom)
- for (unsigned int i=0, n=geom.getNumGeometries(); i<n; ++i)
+ for (std::size_t i=0, n=geom.getNumGeometries(); i<n; ++i)
const Geometry *element = geom.getGeometryN(i);
if (dynamic_cast<const GeometryCollection*>(element))
More information about the geos-commits
