[geos-commits] r4371 - trunk/tests/unit/geom/Geometry
Mateusz Loskot
mateusz at loskot.net
Sun Mar 26 14:31:09 PDT 2017
Author: mloskot
Date: 2017-03-26 14:31:09 -0700 (Sun, 26 Mar 2017)
New Revision: 4371
trunk/tests/unit/geom/Geometry/touchesTest.cpp
Add test of two almost and touching segments
Modified: trunk/tests/unit/geom/Geometry/touchesTest.cpp
--- trunk/tests/unit/geom/Geometry/touchesTest.cpp 2017-03-26 20:37:27 UTC (rev 4370)
+++ trunk/tests/unit/geom/Geometry/touchesTest.cpp 2017-03-26 21:31:09 UTC (rev 4371)
@@ -7,7 +7,9 @@
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/Geometry.h>
#include <geos/io/WKTReader.h>
+#include <geos/io/WKBReader.h>
// std
+#include <sstream>
#include <memory>
namespace tut {
@@ -23,10 +25,12 @@
geos::geom::GeometryFactory::unique_ptr factory;
geos::io::WKTReader reader;
+ geos::io::WKBReader breader;
test_touches_data()
: factory(GeometryFactory::create())
, reader(factory.get())
+ , breader(*factory.get())
@@ -107,4 +111,49 @@
ensure(g2->touches(g1.get()));
+template<>
+template<>
+void object::test<5>()
+ // Two T-like segments, A (horizontal), B (vertical)
+ // A: LINESTRING(-3511.75501903694 4257.47493284327,-877.546556856658 4257.47493284327)
+ // B: LINESTRING(-2119.81532027122 4257.47493284327,-2119.81532027122 2326.7198668134)
+ std::stringstream wkbA("01020000000200000010efda91826fabc0a8e5329579a1b040008633595f6c8bc0a8e5329579a1b040");
+ std::stringstream wkbB("0102000000020000005999a871a18fa0c0a8e5329579a1b0405999a871a18fa0c0180a6292702da240");
+ GeomAutoPtr a(breader.readHEX(wkbA));
+ GeomAutoPtr b(breader.readHEX(wkbB));
+ ensure(a->touches(b.get()));
+template<>
+template<>
+void object::test<6>()
+ // Two Y-like segments, A (V-part), B (|-part)
+ // A: LINESTRING(-428.533750803201 4467.01424233489,1098.10978977856 4137.73818456235,1621.95806350759 5544.64497686319)
+ // B: LINESTRING(1098.10978977856 4137.73818456235,1921.2999342099 2177.04893146225)
+ std::stringstream wkbA("010200000003000000603f483e8ac87ac092ba62a50373b1405851bb6c70289140b6d9a9f9bc29b04060a2990ed55799401226341da5a8b540");
+ std::stringstream wkbB("0102000000020000005851bb6c70289140b6d9a9f9bc29b040d019f42133059e40406c8b0d1902a140");
+template<>
+template<>
+void object::test<7>()
+ // Two T-like two segments rotated ~55 degrees counter-clockwise; A (horizontal), B (vertical)
+ // A: LINESTRING(3343.17382004585 2521.2920827699,4959.61992183829 5125.56635787996)
+ // B: LINESTRING(4151.39687094207 3823.42922032493,6112.08612404217 2461.42370862944)
+ std::stringstream wkbA("01020000000200000098e8f0fe581eaa40ea70df8b95b2a3408c9532b39e5fb340417cd4fc9005b440");
+ std::stringstream wkbB("010200000002000000ec8455996537b040b834c4c2dbdead4086a8390c16e0b740f86456f0d83aa340");
+ ensure(!a->touches(b.get()));
} // namespace tut
More information about the geos-commits
