[geos-commits] r4376 - trunk/tests/unit/geom/Geometry
Mateusz Loskot
mateusz at loskot.net
Sun Mar 26 16:00:49 PDT 2017
Author: mloskot
Date: 2017-03-26 16:00:49 -0700 (Sun, 26 Mar 2017)
New Revision: 4376
trunk/tests/unit/geom/Geometry/touchesTest.cpp
Adjust test comment
Modified: trunk/tests/unit/geom/Geometry/touchesTest.cpp
--- trunk/tests/unit/geom/Geometry/touchesTest.cpp 2017-03-26 22:57:16 UTC (rev 4375)
+++ trunk/tests/unit/geom/Geometry/touchesTest.cpp 2017-03-26 23:00:49 UTC (rev 4376)
@@ -157,7 +157,7 @@
GeomAutoPtr a(breader.readHEX(wkbA));
GeomAutoPtr b(breader.readHEX(wkbB));
- // almost-touching (float-point robustness issue likely)
+ // segments do not just touch, but intersect (float-point robustness issue likely)
ensure(!a->touches(b.get()));
ensure(!a->disjoint(b.get()));
ensure(a->intersects(b.get()));
More information about the geos-commits
