[geos-commits] r4384 - trunk
Mateusz Loskot
mateusz at loskot.net
Tue Mar 28 07:05:29 PDT 2017
Author: mloskot
Date: 2017-03-28 07:05:29 -0700 (Tue, 28 Mar 2017)
New Revision: 4384
trunk/CMakeLists.txt
CMake: Use CMAKE_CXX_STANDARD to require C++98
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt 2017-03-28 13:57:40 UTC (rev 4383)
+++ trunk/CMakeLists.txt 2017-03-28 14:05:29 UTC (rev 4384)
@@ -90,6 +90,8 @@
# Setup C/C++ compiler options
+set(CMAKE_CXX_STANDARD 98)
+set(CMAKE_CXX_STANDARD_REQUIRED ON)
if(NOT MSVC_IDE)
if(NOT CMAKE_BUILD_TYPE)
More information about the geos-commits
