[geos-commits] r4386 - trunk/tests/unit
Sandro Santilli
strk at kbt.io
Tue Mar 28 12:46:12 PDT 2017
Author: strk
Date: 2017-03-28 12:46:12 -0700 (Tue, 28 Mar 2017)
New Revision: 4386
Added:
trunk/tests/unit/.editorconfig
Use spaces under tests/unit
Added: trunk/tests/unit/.editorconfig
--- trunk/tests/unit/.editorconfig (rev 0)
+++ trunk/tests/unit/.editorconfig 2017-03-28 19:46:12 UTC (rev 4386)
@@ -0,0 +1,31 @@
+# http://editorconfig.org
+# top-most EditorConfig file
+root = false
+# every file needs these
+charset = utf-8
+end_of_line = lf
+trim_trailing_whitespace = true
+insert_final_newline = true
+# C++ files want tab indentation
+[*.{h,cpp}]
+indent_style = space
+indent_size = 4
+# Makefiles want tab indentation
+[Makefile.am]
+indent_style = tab
+indent_size = 2
+# CMake configuration files
+[CMakeLists.txt]
+indent_size = 2
+# CMake modules
+[*.cmake]
+indent_size = 2
More information about the geos-commits
