[geos-commits] r4390 - in trunk: . capi tools
Sandro Santilli
strk at kbt.io
Fri Mar 31 13:10:34 PDT 2017
Author: strk
Date: 2017-03-31 13:10:34 -0700 (Fri, 31 Mar 2017)
New Revision: 4390
Added:
trunk/tools/geos_revision_cmake.h.in
Removed:
trunk/tools/geos_svn_revision_cmake.h.in
trunk/CMakeLists.txt
trunk/autogen.bat
trunk/capi/geos_ts_c.cpp
trunk/tools/repo_revision.sh
Rename GEOS_SVN_REVISION macro and cmake script to GEOS_REVISION
... even if it's still just the SVN revision that it contains
See #794
Modified: trunk/CMakeLists.txt
--- trunk/CMakeLists.txt 2017-03-31 19:44:55 UTC (rev 4389)
+++ trunk/CMakeLists.txt 2017-03-31 20:10:34 UTC (rev 4390)
@@ -288,9 +288,9 @@
endif()
if ( NOT ${Project_WC_REVISION} EQUAL 0 )
- set( GEOS_SVN_REVISION ${Project_WC_REVISION} )
+ set( GEOS_REVISION ${Project_WC_REVISION} )
configure_file (
- "${PROJECT_SOURCE_DIR}/tools/geos_svn_revision_cmake.h.in"
+ "${PROJECT_SOURCE_DIR}/tools/geos_revision_cmake.h.in"
"${PROJECT_BINARY_DIR}/geos_revision.h" )
else()
find_program(SH sh)
@@ -303,7 +303,7 @@
else()
message("*** sh-compatible command not found, cannot create geos_revision.h")
message("*** Check SVN revision and create revision header manually:")
- message("*** echo '#define GEOS_SVN_REVISION XYZ' > ${PROJECT_SOURCE_DIR}/geos_revision.h")
+ message("*** echo '#define GEOS_REVISION XYZ' > ${PROJECT_SOURCE_DIR}/geos_revision.h")
endif()
endif()
endif()
Modified: trunk/autogen.bat
--- trunk/autogen.bat 2017-03-31 19:44:55 UTC (rev 4389)
+++ trunk/autogen.bat 2017-03-31 20:10:34 UTC (rev 4390)
@@ -14,4 +14,4 @@
COPY %GEOS_HEADERS%\version.h.vc %GEOS_HEADERS%\version.h
COPY %GEOS_HEADERS%\platform.h.vc %GEOS_HEADERS%\platform.h
COPY capi\geos_c.h.in capi\geos_c.h
- at ECHO #define GEOS_SVN_REVISION 0 > geos_revision.h
\ No newline at end of file
+ at ECHO #define GEOS_REVISION 0 > geos_revision.h
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2017-03-31 19:44:55 UTC (rev 4389)
+++ trunk/capi/geos_ts_c.cpp 2017-03-31 20:10:34 UTC (rev 4390)
@@ -3796,7 +3796,7 @@
const char* GEOSversion()
static char version[256];
- sprintf(version, "%s r%d", GEOS_CAPI_VERSION, GEOS_SVN_REVISION);
+ sprintf(version, "%s r%d", GEOS_CAPI_VERSION, GEOS_REVISION);
return version;
Added: trunk/tools/geos_revision_cmake.h.in
--- trunk/tools/geos_revision_cmake.h.in (rev 0)
+++ trunk/tools/geos_revision_cmake.h.in 2017-03-31 20:10:34 UTC (rev 4390)
@@ -0,0 +1 @@
+#define GEOS_REVISION @GEOS_REVISION@
Deleted: trunk/tools/geos_svn_revision_cmake.h.in
--- trunk/tools/geos_svn_revision_cmake.h.in 2017-03-31 19:44:55 UTC (rev 4389)
+++ trunk/tools/geos_svn_revision_cmake.h.in 2017-03-31 20:10:34 UTC (rev 4390)
@@ -1 +0,0 @@
-#define GEOS_SVN_REVISION @GEOS_SVN_REVISION@
Modified: trunk/tools/repo_revision.sh
--- trunk/tools/repo_revision.sh 2017-03-31 19:44:55 UTC (rev 4389)
+++ trunk/tools/repo_revision.sh 2017-03-31 20:10:34 UTC (rev 4390)
@@ -68,14 +68,14 @@
# Do not override the file if new detected
# revision isn't zero nor different from the existing one
if test -f $rev_file; then
- oldrev=`grep GEOS_SVN_REVISION ${rev_file} | awk '{print $2}'`
+ oldrev=`grep GEOS_REVISION ${rev_file} | awk '{print $2}'`
if test "$rev" = 0 -o "$rev" = "$oldrev"; then
echo "Not updating existing rev file at $oldrev" >&2
return;
fi
fi
- echo "#define GEOS_SVN_REVISION $rev" | tee $rev_file
+ echo "#define GEOS_REVISION $rev" | tee $rev_file
echo "Wrote rev '$rev' in file '$rev_file'" >&2
More information about the geos-commits
