[geos-commits] [SCM] geos branch svn-3.5 updated. 5c47024ce7bf530221e678bdb5db210296a4151c
git at osgeo.org
git at osgeo.org
Tue Nov 28 10:53:35 PST 2017
the project "geos".
The branch, svn-3.5 has been updated
via 5c47024ce7bf530221e678bdb5db210296a4151c (commit)
via 710ddbe48177c215f98dd5e90fb64460b35401a7 (commit)
from 8f35d3bafd3f96b850b460b8e23fd3df3afd168a (commit)
revisions in full, below.
commit 5c47024ce7bf530221e678bdb5db210296a4151c
Merge: 8f35d3b 710ddbe
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Nov 28 10:53:35 2017 -0800
Merge branch 'trac-741_geos-3.5' of sebastic/geos into svn-3.5
commit 710ddbe48177c215f98dd5e90fb64460b35401a7
Date: Fri Dec 2 13:58:45 2016 +0000
Fix empty GEOSSimplify return on inner ring collapse
Patch by Even Rouault
See #741
git-svn-id: http://svn.osgeo.org/geos/trunk@4311 5242fede-7e19-0410-aef8-94bd7d2200fb
diff --git a/include/geos/geom/util/GeometryTransformer.h b/include/geos/geom/util/GeometryTransformer.h
index c2e93ba..f1467b9 100644
--- a/include/geos/geom/util/GeometryTransformer.h
+++ b/include/geos/geom/util/GeometryTransformer.h
@@ -99,6 +99,8 @@ public:
std::auto_ptr<Geometry> transform(const Geometry* nInputGeom);
+ void setSkipTransformedInvalidInteriorRings(bool b);
protected:
const GeometryFactory* factory;
@@ -178,9 +180,14 @@ private:
bool preserveType;
- // Declare type as noncopyable
- GeometryTransformer(const GeometryTransformer& other);
- GeometryTransformer& operator=(const GeometryTransformer& rhs);
+ * <code>true</code> if transformed invalid interior rings should be skipped
+ bool skipTransformedInvalidInteriorRings;
+ // Declare type as noncopyable
+ GeometryTransformer(const GeometryTransformer& other);
+ GeometryTransformer& operator=(const GeometryTransformer& rhs);
diff --git a/src/geom/util/GeometryTransformer.cpp b/src/geom/util/GeometryTransformer.cpp
index 67fb91d..c027126 100644
--- a/src/geom/util/GeometryTransformer.cpp
+++ b/src/geom/util/GeometryTransformer.cpp
@@ -59,13 +59,19 @@ GeometryTransformer::GeometryTransformer()
pruneEmptyGeometry(true),
preserveGeometryCollectionType(true),
preserveCollections(false),
- preserveType(false)
+ preserveType(false),
+ skipTransformedInvalidInteriorRings(false)
GeometryTransformer::~GeometryTransformer()
+void GeometryTransformer::setSkipTransformedInvalidInteriorRings(bool b)
+ skipTransformedInvalidInteriorRings = b;
/*public*/
auto_ptr<Geometry>
GeometryTransformer::transform(const Geometry* nInputGeom)
@@ -283,6 +289,8 @@ GeometryTransformer::transformPolygon(
if ( ! dynamic_cast<LinearRing*>(hole.get()) )
+ if ( skipTransformedInvalidInteriorRings )
+ continue;
isAllValidLinearRings = false;
diff --git a/src/simplify/DouglasPeuckerSimplifier.cpp b/src/simplify/DouglasPeuckerSimplifier.cpp
index 64be39a..e963cd9 100644
--- a/src/simplify/DouglasPeuckerSimplifier.cpp
+++ b/src/simplify/DouglasPeuckerSimplifier.cpp
@@ -89,6 +89,7 @@ DPTransformer::DPTransformer(double t)
distanceTolerance(t)
+ setSkipTransformedInvalidInteriorRings(true);
Geometry::AutoPtr
diff --git a/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp b/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
index 8720158..4bb14e8 100644
--- a/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
+++ b/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
@@ -335,5 +335,26 @@ namespace tut
//std::string const simplifiedWkt2 = wktwriter.write(simplified2.get());
+ // 13 - Polygon with inner ring whose extent is less than the simplify distance (#741)
+ template<>
+ template<>
+ void object::test<13>()
+ std::string wkt_in("POLYGON ((0 0,0 1,1 1,0 0),(0.1 0.1,0.2 0.1,0.2 0.2,0.1 0.1))");
+ std::string wkt_ex("POLYGON ((0 0,0 1,1 1,0 0))");
+ GeomPtr g(wktreader.read(wkt_in));
+ GeomPtr expected(wktreader.read(wkt_ex));
+ GeomPtr simplified = DouglasPeuckerSimplifier::simplify(
+ g.get(), 0.5);
+ ensure( simplified->isValid() );
+ ensure( simplified->equalsExact(expected.get()) );
} // namespace tut
Summary of changes:
include/geos/geom/util/GeometryTransformer.h | 13 +++++++++---
src/geom/util/GeometryTransformer.cpp | 10 +++++++++-
src/simplify/DouglasPeuckerSimplifier.cpp | 1 +
.../unit/simplify/DouglasPeuckerSimplifierTest.cpp | 21 ++++++++++++++++++++
4 files changed, 41 insertions(+), 4 deletions(-)
hooks/post-receive
geos
More information about the geos-commits
