[geos-commits] [SCM] geos branch master updated. 18ad844411880b3b15507ff21c7a452ab8694cc2
Sun Oct 1 12:22:52 PDT 2017
the project "geos".
       via  18ad844411880b3b15507ff21c7a452ab8694cc2 (commit)
       via  3c6391825ac5f9fbd253995f685c8bcc0f4f9d2a (commit)
      from  316c4bc51d9d860b67344e48519ef98fd3c28c16 (commit)
revisions in full, below.
commit 18ad844411880b3b15507ff21c7a452ab8694cc2
Merge: 316c4bc 3c63918
Author: Mateusz Loskot <mateusz at loskot.net>
Date:   Sun Oct 1 12:22:51 2017 -0700
    Merge branch 'ml/clarify-cpp-api-status' of mloskot/geos into master
commit 3c6391825ac5f9fbd253995f685c8bcc0f4f9d2a
Date:   Sun Oct 1 15:32:17 2017 +0200
    Clarify C++ API has not been deprecated
    Make it clear it is not a bug for client program
    to use the C++ API.
    Reverts patch submitted in https://trac.osgeo.org/geos/ticket/553
    - merged by mistake, without RFC proposal, without PSC voting and
    without public announcement.
    Related discussions occurred via the mailing lists
    https://lists.osgeo.org/pipermail/postgis-devel/2017-September/026548.html
    https://lists.osgeo.org/pipermail/geos-devel/2017-September/008043.html
diff --git a/README.md b/README.md
index 2aa28c1..4b1bc51 100644
--- a/README.md
+++ b/README.md
@@ -58,6 +58,12 @@ is required:
 ### Using the C interface (recommended)
+GEOS promises long term stability of C API
+The C library uses the C++ interface, but the C library follows
+normal ABI-change-sensitive versioning, so programs that link only
+against the C library should work without relinking when GEOS is upgraded.
 To compile programs against the C lib (recommended):
     CFLAGS += `geos-config --cflags`
@@ -68,16 +74,15 @@ Example usage:
     capi/geostest.c contains basic usage examples.
-### Using the C++ interface (discouraged)
+### Using the C++ interface (no stability promise)
+Developers who decide to use the C++ interface should be aware GEOS
+does not promise API or ABI stability of C++ API between releases.
+Moreover C++ API/ABI breaking changes may not even be announced
+or include in the NEWS file
-NB: The C++ interface should not be used directly; the GEOS project
-views it as a bug for another program to use the C++ interface or even
-to directly link against the C++ library.  The C++ library name will
-change on every minor release because it is too hard to know if there
-have been ABI changes.  (The C library uses the C++ interface, but the
-C library follows normal ABI-change-sensitive versioning, so programs
-that link only against the C library should work without relinking
-when GEOS is upgraded.)
+The C++ library name will change on every minor release because
+it is too hard to know if there have been ABI changes.
 To compile programs against the C++ lib:
diff --git a/src/Makefile.am b/src/Makefile.am
index cf3b41f..e08ed3e 100644
--- a/src/Makefile.am
+++ b/src/Makefile.am
@@ -24,8 +24,7 @@ lib_LTLIBRARIES = libgeos.la
 # libgeos uses -release because it is not feasible to know if the ABI
 # has changed between releases; the project chooses not to expend the
-# effort to determine this because depending programs should not be
-# using the C++ library.
+# effort to determine this because GEOS does not promise ABI stability.
 libgeos_la_LDFLAGS = \
     -release @VERSION_MAJOR at .@VERSION_MINOR at .@VERSION_PATCH@ \
     -no-undefined
Summary of changes:
 README.md       |   23 ++++++++++++++---------
 src/Makefile.am |    3 +--
 2 files changed, 15 insertions(+), 11 deletions(-)
hooks/post-receive
geos
More information about the geos-commits mailing list
