[geos-commits] [SCM] geos branch master updated. 3818e56d78dde30c1849341eabe67a5b809b74e2
Wed Oct 4 04:10:24 PDT 2017
the project "geos".
       via  3818e56d78dde30c1849341eabe67a5b809b74e2 (commit)
      from  312ef8a895c81dce85e386500e6938fe9470810e (commit)
revisions in full, below.
commit 3818e56d78dde30c1849341eabe67a5b809b74e2
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Oct 4 13:09:05 2017 +0200
    Remove line feeds from left-over files
    This is a style only change.
    The line feed matched th [[:space:]] character class, which
    is why it was spotted.
    Hopefully these are the last LF that'll ever enter the codebase
diff --git a/include/geos/noding/OrientedCoordinateArray.h b/include/geos/noding/OrientedCoordinateArray.h
index a25d85c..d8061aa 100644
--- a/include/geos/noding/OrientedCoordinateArray.h
+++ b/include/geos/noding/OrientedCoordinateArray.h
@@ -1,115 +1,115 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2009    Sandro Santilli <strk at kbt.io>
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * Last port: noding/OrientedCoordinateArray.java rev. 1.1 (JTS-1.9)
-#ifndef GEOS_NODING_ORIENTEDCOORDINATEARRAY_H
-#define GEOS_NODING_ORIENTEDCOORDINATEARRAY_H
-#include <geos/export.h>
-//#include <vector>
-//#include <iostream>
-//#include <geos/inline.h>
-// Forward declarations
-namespace geos {
-	namespace geom {
-		class CoordinateSequence;
-	namespace noding {
-		//class SegmentString;
-namespace geos {
-namespace noding { // geos.noding
-/** \brief
- * Allows comparing {@link geom::CoordinateSequence}s
- * in an orientation-independent way.
-class GEOS_DLL OrientedCoordinateArray
-public:
-	 * Creates a new {@link OrientedCoordinateArray}
-	 * for the given {@link geom::CoordinateSequence}.
-	 * @param pts the coordinates to orient
-	OrientedCoordinateArray(const geom::CoordinateSequence& pts)
-		pts(&pts),
-		orientationVar(orientation(pts))
-	/** \brief
-	 * Compares two {@link OrientedCoordinateArray}s for their
-	 * relative order
-	 * @return -1 this one is smaller
-	 * @return 0 the two objects are equal
-	 * @return 1 this one is greater
-	 * In JTS, this is used automatically by ordered lists.
-	 * In C++, operator< would be used instead....
-	int compareTo(const OrientedCoordinateArray& o1) const;
-private:
-	static int compareOriented(const geom::CoordinateSequence& pts1,
-                                     bool orientation1,
-                                     const geom::CoordinateSequence& pts2,
-                                     bool orientation2);
-	 * Computes the canonical orientation for a coordinate array.
-	 * @param pts the array to test
-	 * @return <code>true</code> if the points are oriented forwards
-	 * @return <code>false</code if the points are oriented in reverse
-	static bool orientation(const geom::CoordinateSequence& pts);
-	/// Externally owned
-	const geom::CoordinateSequence* pts;
-	bool orientationVar;
-/// Strict weak ordering operator for OrientedCoordinateArray
-/// This is the C++ equivalent of JTS's compareTo
-inline bool operator< ( const OrientedCoordinateArray& oca1,
-                        const OrientedCoordinateArray& oca2 )
-  return oca1.compareTo(oca2)<0;
-} // namespace geos.noding
-#endif // GEOS_NODING_ORIENTEDCOORDINATEARRAY_H
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2009    Sandro Santilli <strk at kbt.io>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: noding/OrientedCoordinateArray.java rev. 1.1 (JTS-1.9)
+#ifndef GEOS_NODING_ORIENTEDCOORDINATEARRAY_H
+#define GEOS_NODING_ORIENTEDCOORDINATEARRAY_H
+#include <geos/export.h>
+//#include <vector>
+//#include <iostream>
+//#include <geos/inline.h>
+// Forward declarations
+namespace geos {
+	namespace geom {
+		class CoordinateSequence;
+	namespace noding {
+		//class SegmentString;
+namespace geos {
+namespace noding { // geos.noding
+/** \brief
+ * Allows comparing {@link geom::CoordinateSequence}s
+ * in an orientation-independent way.
+class GEOS_DLL OrientedCoordinateArray
+public:
+	 * Creates a new {@link OrientedCoordinateArray}
+	 * for the given {@link geom::CoordinateSequence}.
+	 * @param pts the coordinates to orient
+	OrientedCoordinateArray(const geom::CoordinateSequence& pts)
+		pts(&pts),
+		orientationVar(orientation(pts))
+	/** \brief
+	 * Compares two {@link OrientedCoordinateArray}s for their
+	 * relative order
+	 * @return -1 this one is smaller
+	 * @return 0 the two objects are equal
+	 * @return 1 this one is greater
+	 * In JTS, this is used automatically by ordered lists.
+	 * In C++, operator< would be used instead....
+	int compareTo(const OrientedCoordinateArray& o1) const;
+private:
+	static int compareOriented(const geom::CoordinateSequence& pts1,
+                                     bool orientation1,
+                                     const geom::CoordinateSequence& pts2,
+                                     bool orientation2);
+	 * Computes the canonical orientation for a coordinate array.
+	 * @param pts the array to test
+	 * @return <code>true</code> if the points are oriented forwards
+	 * @return <code>false</code if the points are oriented in reverse
+	static bool orientation(const geom::CoordinateSequence& pts);
+	/// Externally owned
+	const geom::CoordinateSequence* pts;
+	bool orientationVar;
+/// Strict weak ordering operator for OrientedCoordinateArray
+/// This is the C++ equivalent of JTS's compareTo
+inline bool operator< ( const OrientedCoordinateArray& oca1,
+                        const OrientedCoordinateArray& oca2 )
+  return oca1.compareTo(oca2)<0;
+} // namespace geos.noding
+#endif // GEOS_NODING_ORIENTEDCOORDINATEARRAY_H
diff --git a/src/noding/OrientedCoordinateArray.cpp b/src/noding/OrientedCoordinateArray.cpp
index 88d5cc7..98fb474 100644
--- a/src/noding/OrientedCoordinateArray.cpp
+++ b/src/noding/OrientedCoordinateArray.cpp
@@ -1,98 +1,98 @@
-//#include <cmath>
-//#include <sstream>
-#include <geos/noding/OrientedCoordinateArray.h>
-//#include <geos/util/IllegalArgumentException.h>
-//#include <geos/noding/Octant.h>
-//#include <geos/geom/Coordinate.h>
-#include <geos/geom/CoordinateSequence.h>
-//using namespace std;
-using namespace geos::geom;
-#ifdef _MSC_VER
-#pragma warning(disable : 4127)
-#endif
-namespace geos {
-/* private static */
-bool
-OrientedCoordinateArray::orientation(const CoordinateSequence& pts)
-	return CoordinateSequence::increasingDirection(pts) == 1;
-int
-OrientedCoordinateArray::compareTo(const OrientedCoordinateArray& oca) const
-	int comp = compareOriented(*pts, orientationVar,
-                               *oca.pts, oca.orientationVar);
-#if 0 // MD - testing only
-    int oldComp = SegmentStringDissolver.ptsComp.compare(pts, oca.pts);
-    if ((oldComp == 0 || comp == 0) && oldComp != comp) {
-      System.out.println("bidir mismatch");
-      boolean orient1 = orientation(pts);
-      boolean orient2 = orientation(oca.pts);
-      int comp2 = compareOriented(pts, orientation,
-                               oca.pts, oca.orientation);
-      int oldComp2 = SegmentStringDissolver.ptsComp.compare(pts, oca.pts);
-#endif
-	return comp;
-int
-OrientedCoordinateArray::compareOriented(const geom::CoordinateSequence& pts1,
-    int dir1 = orientation1 ? 1 : -1;
-    int dir2 = orientation2 ? 1 : -1;
-    int limit1 = orientation1 ? pts1.size() : -1;
-    int limit2 = orientation2 ? pts2.size() : -1;
-    int i1 = orientation1 ? 0 : pts1.size() - 1;
-    int i2 = orientation2 ? 0 : pts2.size() - 1;
-    //int comp = 0; // unused, but is in JTS ...
-    while (true) {
-      int compPt = pts1[i1].compareTo(pts2[i2]);
-      if (compPt != 0)
-        return compPt;
-      i1 += dir1;
-      i2 += dir2;
-      bool done1 = i1 == limit1;
-      bool done2 = i2 == limit2;
-      if (done1 && ! done2) return -1;
-      if (! done1 && done2) return 1;
-      if (done1 && done2) return 0;
+//#include <cmath>
+//#include <sstream>
+#include <geos/noding/OrientedCoordinateArray.h>
+//#include <geos/util/IllegalArgumentException.h>
+//#include <geos/noding/Octant.h>
+//#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateSequence.h>
+//using namespace std;
+using namespace geos::geom;
+#ifdef _MSC_VER
+#pragma warning(disable : 4127)
+#endif
+namespace geos {
+/* private static */
+bool
+OrientedCoordinateArray::orientation(const CoordinateSequence& pts)
+	return CoordinateSequence::increasingDirection(pts) == 1;
+int
+OrientedCoordinateArray::compareTo(const OrientedCoordinateArray& oca) const
+	int comp = compareOriented(*pts, orientationVar,
+                               *oca.pts, oca.orientationVar);
+#if 0 // MD - testing only
+    int oldComp = SegmentStringDissolver.ptsComp.compare(pts, oca.pts);
+    if ((oldComp == 0 || comp == 0) && oldComp != comp) {
+      System.out.println("bidir mismatch");
+      boolean orient1 = orientation(pts);
+      boolean orient2 = orientation(oca.pts);
+      int comp2 = compareOriented(pts, orientation,
+                               oca.pts, oca.orientation);
+      int oldComp2 = SegmentStringDissolver.ptsComp.compare(pts, oca.pts);
+#endif
+	return comp;
+int
+OrientedCoordinateArray::compareOriented(const geom::CoordinateSequence& pts1,
+    int dir1 = orientation1 ? 1 : -1;
+    int dir2 = orientation2 ? 1 : -1;
+    int limit1 = orientation1 ? pts1.size() : -1;
+    int limit2 = orientation2 ? pts2.size() : -1;
+    int i1 = orientation1 ? 0 : pts1.size() - 1;
+    int i2 = orientation2 ? 0 : pts2.size() - 1;
+    //int comp = 0; // unused, but is in JTS ...
+    while (true) {
+      int compPt = pts1[i1].compareTo(pts2[i2]);
+      if (compPt != 0)
+        return compPt;
+      i1 += dir1;
+      i2 += dir2;
+      bool done1 = i1 == limit1;
+      bool done2 = i2 == limit2;
+      if (done1 && ! done2) return -1;
+      if (! done1 && done2) return 1;
+      if (done1 && done2) return 0;
diff --git a/tests/unit/capi/GEOSConvexHullTest.cpp b/tests/unit/capi/GEOSConvexHullTest.cpp
index d557ead..18b7fc3 100644
--- a/tests/unit/capi/GEOSConvexHullTest.cpp
+++ b/tests/unit/capi/GEOSConvexHullTest.cpp
@@ -1,81 +1,81 @@
-// Test Suite for C-API GEOSConvexHull
-#include <tut/tut.hpp>
-// geos
-#include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-namespace tut
-    // Test Group
-    // Common data used in test cases.
-    struct test_capigeosconvexhull_data
-        GEOSGeometry* input_;
-        GEOSGeometry* expected_;
-        static void notice(const char *fmt, ...)
-            std::fprintf( stdout, "NOTICE: ");
-            va_list ap;
-            va_start(ap, fmt);
-            std::vfprintf(stdout, fmt, ap);
-            va_end(ap);
-            std::fprintf(stdout, "\n");
-        test_capigeosconvexhull_data()
-            : input_(nullptr), expected_(nullptr)
-            initGEOS(notice, notice);
-        ~test_capigeosconvexhull_data()
-            GEOSGeom_destroy(input_);
-            GEOSGeom_destroy(expected_);
-            input_ = nullptr;
-            expected_ = nullptr;
-            finishGEOS();
-    typedef test_group<test_capigeosconvexhull_data> group;
-    typedef group::object object;
-    group test_capigeosconvexhull_group("capi::GEOSConvexHull");
-    // Test Cases
-    template<>
-    template<>
-    void object::test<1>()
-        input_ = GEOSGeomFromWKT("MULTIPOINT (130 240, 130 240, 130 240, 570 240, 570 240, 570 240, 650 240)");
-        ensure( nullptr != input_ );
-        expected_ = GEOSGeomFromWKT("LINESTRING (130 240, 650 240, 130 240)");
-        ensure( nullptr != expected_ );
-        GEOSGeometry* output = GEOSConvexHull(input_);
-        ensure( nullptr != output );
-        ensure( 0 == GEOSisEmpty(output) );
-        // TODO
-        //ensure( 0 != GEOSEquals(output, expected_));
-        GEOSGeom_destroy(output);
-} // namespace tut
+// Test Suite for C-API GEOSConvexHull
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+namespace tut
+    // Test Group
+    // Common data used in test cases.
+    struct test_capigeosconvexhull_data
+        GEOSGeometry* input_;
+        GEOSGeometry* expected_;
+        static void notice(const char *fmt, ...)
+            std::fprintf( stdout, "NOTICE: ");
+            va_list ap;
+            va_start(ap, fmt);
+            std::vfprintf(stdout, fmt, ap);
+            va_end(ap);
+            std::fprintf(stdout, "\n");
+        test_capigeosconvexhull_data()
+            : input_(nullptr), expected_(nullptr)
+            initGEOS(notice, notice);
+        ~test_capigeosconvexhull_data()
+            GEOSGeom_destroy(input_);
+            GEOSGeom_destroy(expected_);
+            input_ = nullptr;
+            expected_ = nullptr;
+            finishGEOS();
+    typedef test_group<test_capigeosconvexhull_data> group;
+    typedef group::object object;
+    group test_capigeosconvexhull_group("capi::GEOSConvexHull");
+    // Test Cases
+    template<>
+    template<>
+    void object::test<1>()
+        input_ = GEOSGeomFromWKT("MULTIPOINT (130 240, 130 240, 130 240, 570 240, 570 240, 570 240, 650 240)");
+        ensure( nullptr != input_ );
+        expected_ = GEOSGeomFromWKT("LINESTRING (130 240, 650 240, 130 240)");
+        ensure( nullptr != expected_ );
+        GEOSGeometry* output = GEOSConvexHull(input_);
+        ensure( nullptr != output );
+        ensure( 0 == GEOSisEmpty(output) );
+        // TODO
+        //ensure( 0 != GEOSEquals(output, expected_));
+        GEOSGeom_destroy(output);
+} // namespace tut
diff --git a/tests/unit/capi/GEOSIntersectionTest.cpp b/tests/unit/capi/GEOSIntersectionTest.cpp
index 3d4a83e..6c51ab2 100644
--- a/tests/unit/capi/GEOSIntersectionTest.cpp
+++ b/tests/unit/capi/GEOSIntersectionTest.cpp
@@ -1,142 +1,142 @@
-// Test Suite for C-API GEOSintersection
-// geos
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-namespace tut
-	// Test Group
-	struct test_capigeosintersection_data
-		GEOSWKTWriter* wktw_;
-		GEOSGeometry* geom1_;
-		GEOSGeometry* geom2_;
-		GEOSGeometry* geom3_;
-			std::fprintf(stdout, "NOTICE: ");
-			va_list ap;
-			va_end(ap);
-		test_capigeosintersection_data()
-			: geom1_(nullptr), geom2_(nullptr), geom3_(nullptr)
-			wktw_ = GEOSWKTWriter_create();
-			GEOSWKTWriter_setTrim(wktw_, 1);
-			GEOSWKTWriter_setOutputDimension(wktw_, 3);
-		std::string toWKT(GEOSGeometry* g)
-			char* wkt = GEOSWKTWriter_write(wktw_, g);
-			std::string ret(wkt);
-			GEOSFree(wkt);
-			return ret;
-		~test_capigeosintersection_data()
-			GEOSWKTWriter_destroy(wktw_);
-			GEOSGeom_destroy(geom1_);
-			GEOSGeom_destroy(geom2_);
-			GEOSGeom_destroy(geom3_);
-			geom1_ = nullptr;
-			geom2_ = nullptr;
-			geom3_ = nullptr;
-			finishGEOS();
-	typedef test_group<test_capigeosintersection_data> group;
-	group test_capigeosintersection_group("capi::GEOSIntersection");
-	// Test Cases
-	template<>
-	template<>
-		geom1_ = GEOSGeomFromWKT("POLYGON EMPTY");
-		geom2_ = GEOSGeomFromWKT("POLYGON EMPTY");
-		ensure(nullptr != geom1_);
-		ensure(nullptr != geom2_);
-		geom3_ = GEOSIntersection(geom1_, geom2_);
-		ensure(nullptr != geom3_);
-		ensure_equals(toWKT(geom3_), std::string("GEOMETRYCOLLECTION EMPTY"));
-	template<>
-	template<>
-	void object::test<2>()
-		geom1_ = GEOSGeomFromWKT("POLYGON((1 1,1 5,5 5,5 1,1 1))");
-		geom2_ = GEOSGeomFromWKT("POINT(2 2)");
-		ensure_equals(toWKT(geom3_), std::string("POINT (2 2)"));
-	template<>
-	template<>
-	void object::test<3>()
-		geom1_ = GEOSGeomFromWKT("MULTIPOLYGON(((0 0,0 10,10 10,10 0,0 0)))");
-		geom2_ = GEOSGeomFromWKT("POLYGON((-1 1,-1 2,2 2,2 1,-1 1))");
-		ensure_equals(toWKT(geom3_), std::string("POLYGON ((0 1, 0 2, 2 2, 2 1, 0 1))"));
-  /* See http://trac.osgeo.org/geos/ticket/719 */
-	template<>
-	template<>
-	void object::test<4>()
-		geom1_ = GEOSGeomFromWKT("MULTIPOLYGON(((0 0,5 10,10 0,0 0),(1 1,1 2,2 2,2 1,1 1),(100 100,100 102,102 102,102 100,100 100)))");
-		geom2_ = GEOSGeomFromWKT("POLYGON((0 1,0 2,10 2,10 1,0 1))");
-		ensure_equals(toWKT(geom3_), std::string("GEOMETRYCOLLECTION (LINESTRING (1 2, 2 2), LINESTRING (2 1, 1 1), POLYGON ((0.5 1, 1 2, 1 1, 0.5 1)), POLYGON ((9 2, 9.5 1, 2 1, 2 2, 9 2)))"));
-} // namespace tut
+// Test Suite for C-API GEOSintersection
+// geos
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+namespace tut
+	// Test Group
+	struct test_capigeosintersection_data
+		GEOSWKTWriter* wktw_;
+		GEOSGeometry* geom1_;
+		GEOSGeometry* geom2_;
+		GEOSGeometry* geom3_;
+			std::fprintf(stdout, "NOTICE: ");
+			va_list ap;
+			va_end(ap);
+		test_capigeosintersection_data()
+			: geom1_(nullptr), geom2_(nullptr), geom3_(nullptr)
+			wktw_ = GEOSWKTWriter_create();
+			GEOSWKTWriter_setTrim(wktw_, 1);
+			GEOSWKTWriter_setOutputDimension(wktw_, 3);
+		std::string toWKT(GEOSGeometry* g)
+			char* wkt = GEOSWKTWriter_write(wktw_, g);
+			std::string ret(wkt);
+			GEOSFree(wkt);
+			return ret;
+		~test_capigeosintersection_data()
+			GEOSWKTWriter_destroy(wktw_);
+			GEOSGeom_destroy(geom1_);
+			GEOSGeom_destroy(geom2_);
+			GEOSGeom_destroy(geom3_);
+			geom1_ = nullptr;
+			geom2_ = nullptr;
+			geom3_ = nullptr;
+			finishGEOS();
+	typedef test_group<test_capigeosintersection_data> group;
+	group test_capigeosintersection_group("capi::GEOSIntersection");
+	// Test Cases
+	template<>
+	template<>
+		geom1_ = GEOSGeomFromWKT("POLYGON EMPTY");
+		geom2_ = GEOSGeomFromWKT("POLYGON EMPTY");
+		ensure(nullptr != geom1_);
+		ensure(nullptr != geom2_);
+		geom3_ = GEOSIntersection(geom1_, geom2_);
+		ensure(nullptr != geom3_);
+		ensure_equals(toWKT(geom3_), std::string("GEOMETRYCOLLECTION EMPTY"));
+	template<>
+	template<>
+	void object::test<2>()
+		geom1_ = GEOSGeomFromWKT("POLYGON((1 1,1 5,5 5,5 1,1 1))");
+		geom2_ = GEOSGeomFromWKT("POINT(2 2)");
+		ensure_equals(toWKT(geom3_), std::string("POINT (2 2)"));
+	template<>
+	template<>
+	void object::test<3>()
+		geom1_ = GEOSGeomFromWKT("MULTIPOLYGON(((0 0,0 10,10 10,10 0,0 0)))");
+		geom2_ = GEOSGeomFromWKT("POLYGON((-1 1,-1 2,2 2,2 1,-1 1))");
+		ensure_equals(toWKT(geom3_), std::string("POLYGON ((0 1, 0 2, 2 2, 2 1, 0 1))"));
+  /* See http://trac.osgeo.org/geos/ticket/719 */
+	template<>
+	template<>
+	void object::test<4>()
+		geom1_ = GEOSGeomFromWKT("MULTIPOLYGON(((0 0,5 10,10 0,0 0),(1 1,1 2,2 2,2 1,1 1),(100 100,100 102,102 102,102 100,100 100)))");
+		geom2_ = GEOSGeomFromWKT("POLYGON((0 1,0 2,10 2,10 1,0 1))");
+		ensure_equals(toWKT(geom3_), std::string("GEOMETRYCOLLECTION (LINESTRING (1 2, 2 2), LINESTRING (2 1, 1 1), POLYGON ((0.5 1, 1 2, 1 1, 0.5 1)), POLYGON ((9 2, 9.5 1, 2 1, 2 2, 9 2)))"));
+} // namespace tut
diff --git a/tests/unit/capi/GEOSisClosedTest.cpp b/tests/unit/capi/GEOSisClosedTest.cpp
index 9338688..1fcdf93 100644
--- a/tests/unit/capi/GEOSisClosedTest.cpp
+++ b/tests/unit/capi/GEOSisClosedTest.cpp
@@ -1,95 +1,95 @@
-// Test Suite for C-API GEOSisClosed
-// geos
-// std
-#include <cctype>
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <cstring>
-namespace tut
-    // Test Group
-    struct test_capiisclosed_data
-        GEOSGeometry* geom_;
-            va_list ap;
-            va_end(ap);
-        test_capiisclosed_data() : geom_(nullptr)
-        ~test_capiisclosed_data()
-            GEOSGeom_destroy(geom_);
-            finishGEOS();
-    typedef test_group<test_capiisclosed_data> group;
-    group test_capiisclosed_group("capi::GEOSisClosed");
-    // Test Cases
-    template<>
-    template<>
-        geom_ = GEOSGeomFromWKT("LINESTRING(0 0, 1 0, 1 1)");
-        int r = GEOSisClosed(geom_);
-        ensure_equals(r, 0);
-    template<>
-    template<>
-        geom_ = GEOSGeomFromWKT("LINESTRING(0 0, 0 1, 1 1, 0 0)");
-        ensure_equals(r, 1);
-    template<>
-    template<>
-        geom_ = GEOSGeomFromWKT("MULTILINESTRING ((1 1, 1 2, 2 2, 1 1), (0 0, 0 1, 1 1))");
-    template<>
-    template<>
-        geom_ = GEOSGeomFromWKT("MULTILINESTRING ((1 1, 1 2, 2 2, 1 1), (0 0, 0 1, 1 1, 0 0))");
-} // namespace tut
+// Test Suite for C-API GEOSisClosed
+// geos
+// std
+#include <cctype>
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <cstring>
+namespace tut
+    // Test Group
+    struct test_capiisclosed_data
+        GEOSGeometry* geom_;
+            va_list ap;
+            va_end(ap);
+        test_capiisclosed_data() : geom_(nullptr)
+        ~test_capiisclosed_data()
+            GEOSGeom_destroy(geom_);
+            finishGEOS();
+    typedef test_group<test_capiisclosed_data> group;
+    group test_capiisclosed_group("capi::GEOSisClosed");
+    // Test Cases
+    template<>
+    template<>
+        geom_ = GEOSGeomFromWKT("LINESTRING(0 0, 1 0, 1 1)");
+        int r = GEOSisClosed(geom_);
+        ensure_equals(r, 0);
+    template<>
+    template<>
+        geom_ = GEOSGeomFromWKT("LINESTRING(0 0, 0 1, 1 1, 0 0)");
+        ensure_equals(r, 1);
+    template<>
+    template<>
+        geom_ = GEOSGeomFromWKT("MULTILINESTRING ((1 1, 1 2, 2 2, 1 1), (0 0, 0 1, 1 1))");
+    template<>
+    template<>
+        geom_ = GEOSGeomFromWKT("MULTILINESTRING ((1 1, 1 2, 2 2, 1 1), (0 0, 0 1, 1 1, 0 0))");
+} // namespace tut
diff --git a/tests/unit/geom/Geometry/touchesTest.cpp b/tests/unit/geom/Geometry/touchesTest.cpp
index ee65382..3e23c4a 100644
--- a/tests/unit/geom/Geometry/touchesTest.cpp
+++ b/tests/unit/geom/Geometry/touchesTest.cpp
@@ -1,166 +1,166 @@
-// Test Suite for Geometry's touches() functions
-// tut
-// geos
-#include <geos/geom/GeometryFactory.h>
-#include <geos/geom/Geometry.h>
-#include <geos/io/WKTReader.h>
-#include <geos/io/WKBReader.h>
-// std
-#include <sstream>
-#include <memory>
-namespace tut {
-// Test Group
-struct test_touches_data
-    typedef std::unique_ptr<geos::geom::Geometry> GeomPtr;
-    typedef geos::geom::GeometryFactory GeometryFactory;
-    geos::geom::GeometryFactory::Ptr factory;
-    geos::io::WKTReader reader;
-    geos::io::WKBReader breader;
-    test_touches_data()
-        : factory(GeometryFactory::create())
-        , reader(factory.get())
-        , breader(*factory.get())
-typedef test_group<test_touches_data> group;
-typedef group::object object;
-group test_touches_data("geos::geom::Geometry::touches");
-// Test Cases
-// 1 - Point/Point do not touch
-template<>
-template<>
-void object::test<1>()
-    GeomPtr g1(reader.read(
-        "POINT (0 0)"
-    GeomPtr g2(reader.read(
-        "POINT (0 0)"
-    ensure(!g1->touches(g2.get()));
-    ensure(!g2->touches(g1.get()));
-// 2 - Line/Point do not touch if point is not on boundary
-template<>
-template<>
-void object::test<2>()
-        "LINESTRING(0 0, 1 1, 0 2)"
-        "POINT (1 1)"
-// 3 - Line/Point touch
-template<>
-template<>
-void object::test<3>()
-        "POINT (0 2)"
-    ensure(g1->touches(g2.get()));
-    ensure(g2->touches(g1.get()));
-// 4 - Line/Point touch (FP coordinates)
-template<>
-template<>
-void object::test<4>()
-        "LINESTRING (-612844.96290006 279079.117329031,-257704.820935236 574364.179187424)"
-        "POINT (-257704.820935236 574364.179187424)"
-template<>
-template<>
-void object::test<5>()
-    // Two T-like segments, A (horizontal), B (vertical)
-    // A: LINESTRING(-3511.75501903694 4257.47493284327,-877.546556856658 4257.47493284327)
-    // B: LINESTRING(-2119.81532027122 4257.47493284327,-2119.81532027122 2326.7198668134)
-    std::stringstream wkbA("01020000000200000010efda91826fabc0a8e5329579a1b040008633595f6c8bc0a8e5329579a1b040");
-    std::stringstream wkbB("0102000000020000005999a871a18fa0c0a8e5329579a1b0405999a871a18fa0c0180a6292702da240");
-    GeomPtr a(breader.readHEX(wkbA));
-    GeomPtr b(breader.readHEX(wkbB));
-    ensure(a->touches(b.get()));
-    ensure(!a->disjoint(b.get()));
-    ensure(a->intersects(b.get()));
-template<>
-template<>
-void object::test<6>()
-    // Two Y-like segments, A (V-part), B (|-part)
-    // A: LINESTRING(-428.533750803201 4467.01424233489,1098.10978977856 4137.73818456235,1621.95806350759 5544.64497686319)
-    // B: LINESTRING(1098.10978977856 4137.73818456235,1921.2999342099 2177.04893146225)
-    std::stringstream wkbA("010200000003000000603f483e8ac87ac092ba62a50373b1405851bb6c70289140b6d9a9f9bc29b04060a2990ed55799401226341da5a8b540");
-    std::stringstream wkbB("0102000000020000005851bb6c70289140b6d9a9f9bc29b040d019f42133059e40406c8b0d1902a140");
-template<>
-template<>
-void object::test<7>()
-    // Two T-like two segments rotated ~55 degrees counter-clockwise; A (horizontal), B (vertical)
-    // A: LINESTRING(3343.17382004585 2521.2920827699,4959.61992183829 5125.56635787996)
-    // B: LINESTRING(4151.39687094207 3823.42922032493,6112.08612404217 2461.42370862944)
-    std::stringstream wkbA("01020000000200000098e8f0fe581eaa40ea70df8b95b2a3408c9532b39e5fb340417cd4fc9005b440");
-    std::stringstream wkbB("010200000002000000ec8455996537b040b834c4c2dbdead4086a8390c16e0b740f86456f0d83aa340");
-    // segments do not just touch, but intersect (float-point robustness issue likely)
-    ensure(!a->touches(b.get()));
-} // namespace tut
+// Test Suite for Geometry's touches() functions
+// tut
+// geos
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Geometry.h>
+#include <geos/io/WKTReader.h>
+#include <geos/io/WKBReader.h>
+// std
+#include <sstream>
+#include <memory>
+namespace tut {
+// Test Group
+struct test_touches_data
+    typedef std::unique_ptr<geos::geom::Geometry> GeomPtr;
+    typedef geos::geom::GeometryFactory GeometryFactory;
+    geos::geom::GeometryFactory::Ptr factory;
+    geos::io::WKTReader reader;
+    geos::io::WKBReader breader;
+    test_touches_data()
+        : factory(GeometryFactory::create())
+        , reader(factory.get())
+        , breader(*factory.get())
+typedef test_group<test_touches_data> group;
+typedef group::object object;
+group test_touches_data("geos::geom::Geometry::touches");
+// Test Cases
+// 1 - Point/Point do not touch
+template<>
+template<>
+void object::test<1>()
+    GeomPtr g1(reader.read(
+        "POINT (0 0)"
+    GeomPtr g2(reader.read(
+        "POINT (0 0)"
+    ensure(!g1->touches(g2.get()));
+    ensure(!g2->touches(g1.get()));
+// 2 - Line/Point do not touch if point is not on boundary
+template<>
+template<>
+void object::test<2>()
+        "LINESTRING(0 0, 1 1, 0 2)"
+        "POINT (1 1)"
+// 3 - Line/Point touch
+template<>
+template<>
+void object::test<3>()
+        "POINT (0 2)"
+    ensure(g1->touches(g2.get()));
+    ensure(g2->touches(g1.get()));
+// 4 - Line/Point touch (FP coordinates)
+template<>
+template<>
+void object::test<4>()
+        "LINESTRING (-612844.96290006 279079.117329031,-257704.820935236 574364.179187424)"
+        "POINT (-257704.820935236 574364.179187424)"
+template<>
+template<>
+void object::test<5>()
+    // Two T-like segments, A (horizontal), B (vertical)
+    // A: LINESTRING(-3511.75501903694 4257.47493284327,-877.546556856658 4257.47493284327)
+    // B: LINESTRING(-2119.81532027122 4257.47493284327,-2119.81532027122 2326.7198668134)
+    std::stringstream wkbA("01020000000200000010efda91826fabc0a8e5329579a1b040008633595f6c8bc0a8e5329579a1b040");
+    std::stringstream wkbB("0102000000020000005999a871a18fa0c0a8e5329579a1b0405999a871a18fa0c0180a6292702da240");
+    GeomPtr a(breader.readHEX(wkbA));
+    GeomPtr b(breader.readHEX(wkbB));
+    ensure(a->touches(b.get()));
+    ensure(!a->disjoint(b.get()));
+    ensure(a->intersects(b.get()));
+template<>
+template<>
+void object::test<6>()
+    // Two Y-like segments, A (V-part), B (|-part)
+    // A: LINESTRING(-428.533750803201 4467.01424233489,1098.10978977856 4137.73818456235,1621.95806350759 5544.64497686319)
+    // B: LINESTRING(1098.10978977856 4137.73818456235,1921.2999342099 2177.04893146225)
+    std::stringstream wkbA("010200000003000000603f483e8ac87ac092ba62a50373b1405851bb6c70289140b6d9a9f9bc29b04060a2990ed55799401226341da5a8b540");
+    std::stringstream wkbB("0102000000020000005851bb6c70289140b6d9a9f9bc29b040d019f42133059e40406c8b0d1902a140");
+template<>
+template<>
+void object::test<7>()
+    // Two T-like two segments rotated ~55 degrees counter-clockwise; A (horizontal), B (vertical)
+    // A: LINESTRING(3343.17382004585 2521.2920827699,4959.61992183829 5125.56635787996)
+    // B: LINESTRING(4151.39687094207 3823.42922032493,6112.08612404217 2461.42370862944)
+    std::stringstream wkbA("01020000000200000098e8f0fe581eaa40ea70df8b95b2a3408c9532b39e5fb340417cd4fc9005b440");
+    std::stringstream wkbB("010200000002000000ec8455996537b040b834c4c2dbdead4086a8390c16e0b740f86456f0d83aa340");
+    // segments do not just touch, but intersect (float-point robustness issue likely)
+    ensure(!a->touches(b.get()));
+} // namespace tut
diff --git a/tests/unit/geom/GeometryComponentFilterTest.cpp b/tests/unit/geom/GeometryComponentFilterTest.cpp
index 9f6a220..0aa7eb4 100644
--- a/tests/unit/geom/GeometryComponentFilterTest.cpp
+++ b/tests/unit/geom/GeometryComponentFilterTest.cpp
@@ -1,95 +1,95 @@
-// Test Suite for geos::geom::GeometryComponentFilter class.
-// geos
-#include <geos/geom/GeometryComponentFilter.h>
-// std
-#include <memory>
-#include <vector>
-namespace tut
-struct test_geometrycomponentfilter_data
-    typedef geos::geom::Geometry::Ptr GeometryPtr; // owner
-    typedef std::vector<geos::geom::Geometry const*> GeometryRefArray; // observer
-    geos::geom::GeometryFactory::Ptr gf;
-    test_geometrycomponentfilter_data()
-        : gf(geos::geom::GeometryFactory::create())
-        , reader(gf.get())
-typedef test_group<test_geometrycomponentfilter_data> group;
-group test_geometrycomponentfilter_group("geos::geom::GeometryComponentFilter");
-// Test Cases
-// Split components into two categories: Lineal and all other types
-template<>
-template<>
-    // collection of 4 geometries
-    GeometryPtr g(reader.read("GEOMETRYCOLLECTION("
-        "POINT(0 0),"
-        "LINESTRING(0 0,1 1,1 2),"
-        "POLYGON((0 0,4 0,4 4,0 4,0 0)),"
-        "MULTILINESTRING((0 0,1 1,1 2),(2 3,3 2,5 4)))"));
-    struct GeometryComponentSplitter : public geos::geom::GeometryComponentFilter
-        GeometryRefArray& lineal;
-        GeometryRefArray& nonlineal;
-        GeometryComponentSplitter(GeometryRefArray& lineal, GeometryRefArray& nonlineal)
-            : lineal(lineal), nonlineal(nonlineal)
-            ensure(lineal.empty());
-            ensure(nonlineal.empty());
-        void filter_ro(geos::geom::Geometry const* g) override
-            if (dynamic_cast<geos::geom::Lineal const*>(g))
-                lineal.push_back(g);
-            else
-                nonlineal.push_back(g);
-        void filter_rw(geos::geom::Geometry*) override {}
-    GeometryRefArray lineal;
-    GeometryRefArray nonlineal;
-    GeometryComponentSplitter splitter(lineal, nonlineal);
-    g->apply_ro(&splitter);
-    // TODO: Verify the actual results
-    // lineal:
-    //   0: LineString
-    //   1: LinearRing
-    //   2: MultiLineString
-    //   3: LineString
-    //   4: LineString
-    // nonlineal:
-    //   0: GeometryCollection
-    //   1: Point
-    //   2: Polygon
-    ensure_equals(lineal.size(), 5); // TODO: Why MultiLineString is in?
-    // TODO: shouldn't be 1 for POLYGON?
-    ensure_equals(nonlineal.size(), 3);
-    // TODO: is 8 right?
-    ensure_equals(lineal.size() + nonlineal.size(), 8);
-} // namespace tut
+// Test Suite for geos::geom::GeometryComponentFilter class.
+// geos
+#include <geos/geom/GeometryComponentFilter.h>
+// std
+#include <memory>
+#include <vector>
+namespace tut
+struct test_geometrycomponentfilter_data
+    typedef geos::geom::Geometry::Ptr GeometryPtr; // owner
+    typedef std::vector<geos::geom::Geometry const*> GeometryRefArray; // observer
+    geos::geom::GeometryFactory::Ptr gf;
+    test_geometrycomponentfilter_data()
+        : gf(geos::geom::GeometryFactory::create())
+        , reader(gf.get())
+typedef test_group<test_geometrycomponentfilter_data> group;
+group test_geometrycomponentfilter_group("geos::geom::GeometryComponentFilter");
+// Test Cases
+// Split components into two categories: Lineal and all other types
+template<>
+template<>
+    // collection of 4 geometries
+    GeometryPtr g(reader.read("GEOMETRYCOLLECTION("
+        "POINT(0 0),"
+        "LINESTRING(0 0,1 1,1 2),"
+        "POLYGON((0 0,4 0,4 4,0 4,0 0)),"
+        "MULTILINESTRING((0 0,1 1,1 2),(2 3,3 2,5 4)))"));
+    struct GeometryComponentSplitter : public geos::geom::GeometryComponentFilter
+        GeometryRefArray& lineal;
+        GeometryRefArray& nonlineal;
+        GeometryComponentSplitter(GeometryRefArray& lineal, GeometryRefArray& nonlineal)
+            : lineal(lineal), nonlineal(nonlineal)
+            ensure(lineal.empty());
+            ensure(nonlineal.empty());
+        void filter_ro(geos::geom::Geometry const* g) override
+            if (dynamic_cast<geos::geom::Lineal const*>(g))
+                lineal.push_back(g);
+            else
+                nonlineal.push_back(g);
+        void filter_rw(geos::geom::Geometry*) override {}
+    GeometryRefArray lineal;
+    GeometryRefArray nonlineal;
+    GeometryComponentSplitter splitter(lineal, nonlineal);
+    g->apply_ro(&splitter);
+    // TODO: Verify the actual results
+    // lineal:
+    //   0: LineString
+    //   1: LinearRing
+    //   2: MultiLineString
+    //   3: LineString
+    //   4: LineString
+    // nonlineal:
+    //   0: GeometryCollection
+    //   1: Point
+    //   2: Polygon
+    ensure_equals(lineal.size(), 5); // TODO: Why MultiLineString is in?
+    // TODO: shouldn't be 1 for POLYGON?
+    ensure_equals(nonlineal.size(), 3);
+    // TODO: is 8 right?
+    ensure_equals(lineal.size() + nonlineal.size(), 8);
+} // namespace tut
diff --git a/tests/unit/geom/GeometryFilterTest.cpp b/tests/unit/geom/GeometryFilterTest.cpp
index 99afe5e..8f048bd 100644
--- a/tests/unit/geom/GeometryFilterTest.cpp
+++ b/tests/unit/geom/GeometryFilterTest.cpp
@@ -1,96 +1,96 @@
-// Test Suite for geos::geom::GeometryFilter class.
-// geos
-#include <geos/geom/GeometryFilter.h>
-// std
-#include <memory>
-#include <vector>
-namespace tut
-struct test_geometryfilter_data
-    test_geometryfilter_data()
-typedef test_group<test_geometryfilter_data> group;
-group test_geometryfilter_group("geos::geom::GeometryFilter");
-// Test Cases
-// Split geometries into two categories: Lineal and all other types
-template<>
-template<>
-        "POINT(0 0),"
-    struct GeometrySplitter : public geos::geom::GeometryFilter
-        GeometrySplitter(GeometryRefArray& lineal, GeometryRefArray& nonlineal)
-            else
-    GeometrySplitter splitter(lineal, nonlineal);
-    // lineal:
-    //   0: LineString
-    //   1: MultiLineString
-    //   2: LineString
-    //   3: LineString
-    // nonlineal:
-    //   1: Point
-    //   2: Polygon
-    ensure_equals(lineal.size(), 4);
-    // TODO: is 7, shouldn't be not 4?
-    //ensure_equals(lineal.size() + nonlineal.size(), g->getNumGeometries());
-    ensure_equals(g->getNumGeometries(), 4);
-    ensure_equals(lineal.size() + nonlineal.size(), 7);
-} // namespace tut
+// Test Suite for geos::geom::GeometryFilter class.
+// geos
+#include <geos/geom/GeometryFilter.h>
+// std
+#include <memory>
+#include <vector>
+namespace tut
+struct test_geometryfilter_data
+    test_geometryfilter_data()
+typedef test_group<test_geometryfilter_data> group;
+group test_geometryfilter_group("geos::geom::GeometryFilter");
+// Test Cases
+// Split geometries into two categories: Lineal and all other types
+template<>
+template<>
+        "POINT(0 0),"
+    struct GeometrySplitter : public geos::geom::GeometryFilter
+        GeometrySplitter(GeometryRefArray& lineal, GeometryRefArray& nonlineal)
+            else
+    GeometrySplitter splitter(lineal, nonlineal);
+    // lineal:
+    //   0: LineString
+    //   1: MultiLineString
+    //   2: LineString
+    //   3: LineString
+    // nonlineal:
+    //   1: Point
+    //   2: Polygon
+    ensure_equals(lineal.size(), 4);
+    // TODO: is 7, shouldn't be not 4?
+    //ensure_equals(lineal.size() + nonlineal.size(), g->getNumGeometries());
+    ensure_equals(g->getNumGeometries(), 4);
+    ensure_equals(lineal.size() + nonlineal.size(), 7);
+} // namespace tut
diff --git a/tests/unit/geom/prep/PreparedGeometry/touchesTest.cpp b/tests/unit/geom/prep/PreparedGeometry/touchesTest.cpp
index d6589ed..97c2c3b 100644
--- a/tests/unit/geom/prep/PreparedGeometry/touchesTest.cpp
+++ b/tests/unit/geom/prep/PreparedGeometry/touchesTest.cpp
@@ -1,134 +1,134 @@
-// Test Suite for PreparedGeometry's touches() functions
-// tut
-#include <utility.h>
-// geos
-#include <geos/geom/prep/PreparedGeometryFactory.h>
-#include <geos/geom/prep/PreparedGeometry.h>
-// std
-#include <memory>
-namespace tut {
-// Test Group
-struct test_preparedgeometrytouches_data
-    typedef std::unique_ptr<geos::geom::prep::PreparedGeometry> PrepGeomAutoPtr;
-    GeometryPtr g1;
-    GeometryPtr g2;
-    PreparedGeometryPtr pg1;
-    PreparedGeometryPtr pg2;
-    test_preparedgeometrytouches_data()
-        , g1(nullptr)
-        , g2(nullptr)
-        , pg1(nullptr)
-        , pg2(nullptr)
-    ~test_preparedgeometrytouches_data()
-        prep::PreparedGeometryFactory::destroy(pg1);
-        prep::PreparedGeometryFactory::destroy(pg2);
-        factory->destroyGeometry(g1);
-        factory->destroyGeometry(g2);
-typedef test_group<test_preparedgeometrytouches_data> group;
-group test_preparedgeometrytouches_data("geos::geom::prep::PreparedGeometry::touches");
-// Test Cases
-template<>
-template<>
-    g1 = reader.read(
-        "POINT (0 0)"
-    g2 = reader.read(
-        "POINT (0 0)"
-    pg1 = prep::PreparedGeometryFactory::prepare(g1);
-    pg2 = prep::PreparedGeometryFactory::prepare(g2);
-    ensure(!pg1->touches(g2));
-    ensure(!pg2->touches(g1));
-template<>
-template<>
-    g1 = reader.read(
-    g2 = reader.read(
-        "POINT (1 1)"
-template<>
-template<>
-    g1 = reader.read(
-    g2 = reader.read(
-        "POINT (0 2)"
-    ensure(pg1->touches(g2));
-    ensure(pg2->touches(g1));
-template<>
-template<>
-    g1 = reader.read(
-    g2 = reader.read(
-} // namespace tut
+// Test Suite for PreparedGeometry's touches() functions
+// tut
+#include <utility.h>
+// geos
+#include <geos/geom/prep/PreparedGeometryFactory.h>
+#include <geos/geom/prep/PreparedGeometry.h>
+// std
+#include <memory>
+namespace tut {
+// Test Group
+struct test_preparedgeometrytouches_data
+    typedef std::unique_ptr<geos::geom::prep::PreparedGeometry> PrepGeomAutoPtr;
+    GeometryPtr g1;
+    GeometryPtr g2;
+    PreparedGeometryPtr pg1;
+    PreparedGeometryPtr pg2;
+    test_preparedgeometrytouches_data()
+        , g1(nullptr)
+        , g2(nullptr)
+        , pg1(nullptr)
+        , pg2(nullptr)
+    ~test_preparedgeometrytouches_data()
+        prep::PreparedGeometryFactory::destroy(pg1);
+        prep::PreparedGeometryFactory::destroy(pg2);
+        factory->destroyGeometry(g1);
+        factory->destroyGeometry(g2);
+typedef test_group<test_preparedgeometrytouches_data> group;
+group test_preparedgeometrytouches_data("geos::geom::prep::PreparedGeometry::touches");
+// Test Cases
+template<>
+template<>
+    g1 = reader.read(
+        "POINT (0 0)"
+    g2 = reader.read(
+        "POINT (0 0)"
+    pg1 = prep::PreparedGeometryFactory::prepare(g1);
+    pg2 = prep::PreparedGeometryFactory::prepare(g2);
+    ensure(!pg1->touches(g2));
+    ensure(!pg2->touches(g1));
+template<>
+template<>
+    g1 = reader.read(
+    g2 = reader.read(
+        "POINT (1 1)"
+template<>
+template<>
+    g1 = reader.read(
+    g2 = reader.read(
+        "POINT (0 2)"
+    ensure(pg1->touches(g2));
+    ensure(pg2->touches(g1));
+template<>
+template<>
+    g1 = reader.read(
+    g2 = reader.read(
+} // namespace tut
diff --git a/tests/unit/operation/buffer/BufferBuilderTest.cpp b/tests/unit/operation/buffer/BufferBuilderTest.cpp
index 6e44d8b..dc65453 100644
--- a/tests/unit/operation/buffer/BufferBuilderTest.cpp
+++ b/tests/unit/operation/buffer/BufferBuilderTest.cpp
@@ -1,130 +1,130 @@
-// Test Suite for geos::operation::buffer::BufferBuilder class.
-// tut
-// geos
-#include <geos/operation/buffer/BufferBuilder.h>
-#include <geos/operation/buffer/BufferParameters.h>
-#include <geos/platform.h>
-#include <geos/geom/Coordinate.h>
-#include <geos/geom/LineString.h>
-#include <geos/algorithm/PointLocator.h>
-#include <geos/algorithm/CGAlgorithms.h>
-// std
-#include <memory>
-#include <string>
-#include <vector>
-namespace tut
-    // Test Group
-    // Common data used by tests
-    struct test_bufferbuilder_data
-        const geos::geom::GeometryFactory &gf;
-        geos::io::WKTReader wktreader;
-        int const default_quadrant_segments;
-        typedef geos::geom::Geometry::Ptr GeomPtr;
-        typedef std::unique_ptr<geos::geom::CoordinateSequence> CSPtr;
-        test_bufferbuilder_data()
-            : gf(*geos::geom::GeometryFactory::getDefaultInstance())
-            , wktreader(&gf)
-            , default_quadrant_segments(geos::operation::buffer::BufferParameters::DEFAULT_QUADRANT_SEGMENTS)
-            ensure_equals(default_quadrant_segments, int(8));
-    private:
-        // noncopyable
-        test_bufferbuilder_data(test_bufferbuilder_data const& other);
-        test_bufferbuilder_data& operator=(test_bufferbuilder_data const& rhs);
-    typedef test_group<test_bufferbuilder_data> group;
-    group test_bufferbuilder_group("geos::operation::buffer::BufferBuilder");
-    // Test Cases
-    // Left-side and right-side offset curve
-    // See http://trac.osgeo.org/geos/ticket/633
-    template<>
-    template<>
-        using geos::operation::buffer::BufferBuilder;
-        using geos::operation::buffer::BufferParameters;
-        using geos::algorithm::CGAlgorithms;
-        using geos::geom::LineString;
-        // Original input from test in ticket #633
-        //std::string wkt0("LINESTRING ("
-        //    "665.7317504882812500 133.0762634277343700,"
-        //    "1774.4752197265625000 19.9391822814941410,"
-        //    "756.2413940429687500 466.8306579589843700,"
-        //    "626.1337890625000000 1898.0147705078125000,"
-        //    "433.8007202148437500 404.6052856445312500)");
-        //double const distance = 57.164000837203;
-        // Simplified equivalent input
-        std::string wkt0("LINESTRING(0 0, 50 -10, 10 10, 0 50, -10 10)");
-        double const distance = 5;
-        GeomPtr g0(wktreader.read(wkt0));
-        ensure(nullptr != g0.get());
-        ensure_equals(g0->getNumPoints(), std::size_t(5));
-        BufferParameters params;
-        params.setEndCapStyle(BufferParameters::CAP_FLAT);
-        params.setQuadrantSegments(8);
-        params.setJoinStyle(BufferParameters::JOIN_MITRE);
-        params.setMitreLimit(5.57F);
-        //params.setSingleSided(true); // DO NOT switch for non-areal input, see ticket #633
-        BufferBuilder builder(params);
-        ensure(distance > 0);
-        // left-side
-            GeomPtr gB(builder.bufferLineSingleSided(g0.get(), distance, true));
-            ensure(nullptr != gB.get());
-            ensure_equals(gB->getGeometryTypeId(), geos::geom::GEOS_LINESTRING);
-            // Left-side offset curve expected with 5+ vertices
-            ensure(gB->getNumPoints() >= g0->getNumPoints());
-            // For left-side offset curve, the offset will be at the left side of the input line
-            // and retain the same direction.
-            ensure_equals(
-                CGAlgorithms::isCCW(dynamic_cast<LineString*>(g0.get())->getCoordinatesRO()),
-                CGAlgorithms::isCCW(dynamic_cast<LineString*>(gB.get())->getCoordinatesRO()));
-        // right-side
-            GeomPtr gB(builder.bufferLineSingleSided(g0.get(), distance, false));
-            // Right-side offset curve expected with 5+ vertices
-            // For right-side offset curve, it'll be at the right side
-            // and in the opposite direction.
-            ensure_equals(
-                !CGAlgorithms::isCCW(dynamic_cast<LineString*>(gB.get())->getCoordinatesRO()));
-} // namespace tut
+// Test Suite for geos::operation::buffer::BufferBuilder class.
+// tut
+// geos
+#include <geos/operation/buffer/BufferBuilder.h>
+#include <geos/operation/buffer/BufferParameters.h>
+#include <geos/platform.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/LineString.h>
+#include <geos/algorithm/PointLocator.h>
+#include <geos/algorithm/CGAlgorithms.h>
+// std
+#include <memory>
+#include <string>
+#include <vector>
+namespace tut
+    // Test Group
+    // Common data used by tests
+    struct test_bufferbuilder_data
+        const geos::geom::GeometryFactory &gf;
+        geos::io::WKTReader wktreader;
+        int const default_quadrant_segments;
+        typedef geos::geom::Geometry::Ptr GeomPtr;
+        typedef std::unique_ptr<geos::geom::CoordinateSequence> CSPtr;
+        test_bufferbuilder_data()
+            : gf(*geos::geom::GeometryFactory::getDefaultInstance())
+            , wktreader(&gf)
+            , default_quadrant_segments(geos::operation::buffer::BufferParameters::DEFAULT_QUADRANT_SEGMENTS)
+            ensure_equals(default_quadrant_segments, int(8));
+    private:
+        // noncopyable
+        test_bufferbuilder_data(test_bufferbuilder_data const& other);
+        test_bufferbuilder_data& operator=(test_bufferbuilder_data const& rhs);
+    typedef test_group<test_bufferbuilder_data> group;
+    group test_bufferbuilder_group("geos::operation::buffer::BufferBuilder");
+    // Test Cases
+    // Left-side and right-side offset curve
+    // See http://trac.osgeo.org/geos/ticket/633
+    template<>
+    template<>
+        using geos::operation::buffer::BufferBuilder;
+        using geos::operation::buffer::BufferParameters;
+        using geos::algorithm::CGAlgorithms;
+        using geos::geom::LineString;
+        // Original input from test in ticket #633
+        //std::string wkt0("LINESTRING ("
+        //    "665.7317504882812500 133.0762634277343700,"
+        //    "1774.4752197265625000 19.9391822814941410,"
+        //    "756.2413940429687500 466.8306579589843700,"
+        //    "626.1337890625000000 1898.0147705078125000,"
+        //    "433.8007202148437500 404.6052856445312500)");
+        //double const distance = 57.164000837203;
+        // Simplified equivalent input
+        std::string wkt0("LINESTRING(0 0, 50 -10, 10 10, 0 50, -10 10)");
+        double const distance = 5;
+        GeomPtr g0(wktreader.read(wkt0));
+        ensure(nullptr != g0.get());
+        ensure_equals(g0->getNumPoints(), std::size_t(5));
+        BufferParameters params;
+        params.setEndCapStyle(BufferParameters::CAP_FLAT);
+        params.setQuadrantSegments(8);
+        params.setJoinStyle(BufferParameters::JOIN_MITRE);
+        params.setMitreLimit(5.57F);
+        //params.setSingleSided(true); // DO NOT switch for non-areal input, see ticket #633
+        BufferBuilder builder(params);
+        ensure(distance > 0);
+        // left-side
+            GeomPtr gB(builder.bufferLineSingleSided(g0.get(), distance, true));
+            ensure(nullptr != gB.get());
+            ensure_equals(gB->getGeometryTypeId(), geos::geom::GEOS_LINESTRING);
+            // Left-side offset curve expected with 5+ vertices
+            ensure(gB->getNumPoints() >= g0->getNumPoints());
+            // For left-side offset curve, the offset will be at the left side of the input line
+            // and retain the same direction.
+            ensure_equals(
+                CGAlgorithms::isCCW(dynamic_cast<LineString*>(g0.get())->getCoordinatesRO()),
+                CGAlgorithms::isCCW(dynamic_cast<LineString*>(gB.get())->getCoordinatesRO()));
+        // right-side
+            GeomPtr gB(builder.bufferLineSingleSided(g0.get(), distance, false));
+            // Right-side offset curve expected with 5+ vertices
+            // For right-side offset curve, it'll be at the right side
+            // and in the opposite direction.
+            ensure_equals(
+                !CGAlgorithms::isCCW(dynamic_cast<LineString*>(gB.get())->getCoordinatesRO()));
+} // namespace tut
Summary of changes:
 include/geos/noding/OrientedCoordinateArray.h      |  230 +++++++-------
 src/noding/OrientedCoordinateArray.cpp             |  196 ++++++------
 tests/unit/capi/GEOSConvexHullTest.cpp             |  162 +++++-----
 tests/unit/capi/GEOSIntersectionTest.cpp           |  284 ++++++++---------
 tests/unit/capi/GEOSisClosedTest.cpp               |  190 +++++------
 tests/unit/geom/Geometry/touchesTest.cpp           |  332 ++++++++++----------
 tests/unit/geom/GeometryComponentFilterTest.cpp    |  190 +++++------
 tests/unit/geom/GeometryFilterTest.cpp             |  192 +++++------
 .../geom/prep/PreparedGeometry/touchesTest.cpp     |  268 ++++++++--------
 tests/unit/operation/buffer/BufferBuilderTest.cpp  |  260 +++++++--------
 10 files changed, 1152 insertions(+), 1152 deletions(-)
hooks/post-receive
geos
More information about the geos-commits mailing list
