[geos-commits] [SCM] geos branch master updated. 16183469312aef329c096f1b8a5d95521575a9d8
git at osgeo.org
git at osgeo.org
Fri Sep 1 08:02:53 PDT 2017
the project "geos".
via 16183469312aef329c096f1b8a5d95521575a9d8 (commit)
via 7d44838732a17bc7267b73d7c7f23c7be1a72860 (commit)
from 64e823b26bc6a771571f39af245b0e0f4e256df8 (commit)
revisions in full, below.
commit 16183469312aef329c096f1b8a5d95521575a9d8
Author: nila <n_larsson at yahoo.com>
Date: Wed Apr 26 14:27:54 2017 +0200
Remove redundant code
Closes #832
diff --git a/src/linearref/LinearLocation.cpp b/src/linearref/LinearLocation.cpp
index e57e5a4..49de76f 100644
--- a/src/linearref/LinearLocation.cpp
+++ b/src/linearref/LinearLocation.cpp
@@ -89,17 +89,6 @@ LinearLocation::normalize()
segmentFraction = 1.0;
- if (componentIndex < 0)
- componentIndex = 0;
- segmentIndex = 0;
- segmentFraction = 0.0;
- if (segmentIndex < 0)
- segmentIndex = 0;
if (segmentFraction == 1.0)
@@ -232,11 +221,11 @@ LinearLocation::getSegment(const Geometry* linearGeom) const
bool
LinearLocation::isValid(const Geometry* linearGeom) const
- if (componentIndex < 0 || componentIndex >= linearGeom->getNumGeometries())
+ if (componentIndex >= linearGeom->getNumGeometries())
return false;
const LineString* lineComp = dynamic_cast<const LineString*> (linearGeom->getGeometryN(componentIndex));
- if (segmentIndex < 0 || segmentIndex > lineComp->getNumPoints())
+ if (segmentIndex > lineComp->getNumPoints())
return false;
if (segmentIndex == lineComp->getNumPoints() && segmentFraction != 0.0)
return false;
commit 7d44838732a17bc7267b73d7c7f23c7be1a72860
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jul 27 20:05:54 2017 +0200
Fix debug print syntax
And add more debugging lines
diff --git a/include/geos/geom/BinaryOp.h b/include/geos/geom/BinaryOp.h
index eba5b8b..af5c74b 100644
--- a/include/geos/geom/BinaryOp.h
+++ b/include/geos/geom/BinaryOp.h
@@ -198,6 +198,7 @@ check_valid(const Geometry& g, const std::string& label, bool doThrow=false, boo
<< "<A>" << std::endl
<< g.toString()
<< std::endl
+ << "</A>" << std::endl
#endif
#endif
diff --git a/src/operation/union/CascadedPolygonUnion.cpp b/src/operation/union/CascadedPolygonUnion.cpp
index 4d20a06..95b53f3 100644
--- a/src/operation/union/CascadedPolygonUnion.cpp
+++ b/src/operation/union/CascadedPolygonUnion.cpp
@@ -75,9 +75,9 @@ check_valid(const geos::geom::Geometry& g, const std::string& label, bool doThro
<< err->getCoordinate() << ")"
<< std::endl
#ifdef GEOS_DEBUG_CASCADED_UNION_PRINT_INVALID
- << "<A>" << std::endl
- << g.toString()
- << std::endl
+ << "<a>" << std::endl
+ << g.toString() << std::endl
+ << "</a>" << std::endl
#endif
#endif // GEOS_DEBUG_CASCADED_UNION
@@ -263,7 +263,19 @@ CascadedPolygonUnion::unionUsingEnvelopeIntersection(geom::Geometry* g0,
std::auto_ptr<geom::Geometry> u(unionActual(g0Int.get(), g1Int.get()));
#if GEOS_DEBUG_CASCADED_UNION
- check_valid(*u, "unionUsingEnvelopeIntersection unionActual return");
+ if ( ! check_valid(*u, "unionUsingEnvelopeIntersection unionActual return") )
+#if GEOS_DEBUG_CASCADED_UNION_PRINT_INVALID
+ std::cerr << " union between the following is invalid"
+ << *g0Int << std::endl
+ << "<b>" << std::endl
+ << *g1Int << std::endl
+ << "</b>" << std::endl
+#endif
#endif
if ( disjointPolys.empty() ) return u.release();
Summary of changes:
include/geos/geom/BinaryOp.h | 1 +
src/linearref/LinearLocation.cpp | 15 ++-------------
src/operation/union/CascadedPolygonUnion.cpp | 20 ++++++++++++++++----
3 files changed, 19 insertions(+), 17 deletions(-)
hooks/post-receive
geos
More information about the geos-commits
