[geos-commits] [SCM] geos branch master updated. 6932138816c720c5b90dd7490541274e40fb50f1
git at osgeo.org
git at osgeo.org
Thu Sep 7 00:07:00 PDT 2017
the project "geos".
via 6932138816c720c5b90dd7490541274e40fb50f1 (commit)
from 16183469312aef329c096f1b8a5d95521575a9d8 (commit)
revisions in full, below.
commit 6932138816c720c5b90dd7490541274e40fb50f1
Author: Mateusz Loskot <mateusz at loskot.net>
Date: Thu Sep 7 09:06:07 2017 +0200
[CMake] Set CMAKE_CXX_EXTENSIONS to OFF (require -std=c++11)
Move C++ standard settings to top of CMakeLists.txt.
diff --git a/CMakeLists.txt b/CMakeLists.txt
index fe6d50d..5fd4c2d 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -10,7 +10,7 @@
# See the COPYING file for more information.
-cmake_minimum_required(VERSION 3.0.0)
+cmake_minimum_required(VERSION 3.1.3)
if(NOT CMAKE_VERSION)
set(CMAKE_VERSION
@@ -18,6 +18,21 @@ if(NOT CMAKE_VERSION)
endif()
+# Set GEOS project
+project(GEOS LANGUAGES C CXX)
+# Add custom GEOS modules for CMake
+list(APPEND CMAKE_MODULE_PATH "${PROJECT_SOURCE_DIR}/cmake/modules")
+# Set C++ standard
+set(CMAKE_CXX_STANDARD 11)
+set(CMAKE_CXX_STANDARD_REQUIRED ON)
+set(CMAKE_CXX_EXTENSIONS OFF)
# Setup GEOS version
@@ -48,14 +63,6 @@ if (NOT WIN32)
endif()
-# Set GEOS project
-project(GEOS LANGUAGES C CXX)
-# Add custom GEOS modules for CMake
-list(APPEND CMAKE_MODULE_PATH "${PROJECT_SOURCE_DIR}/cmake/modules")
# Check custom global options
@@ -94,10 +101,6 @@ endif()
# Setup C/C++ compiler options
-set(CMAKE_CXX_STANDARD 11)
-set(CMAKE_CXX_STANDARD_REQUIRED ON)
-#set(CMAKE_CXX_EXTENSIONS OFF)
if(NOT MSVC_IDE)
if(NOT CMAKE_BUILD_TYPE)
set(CMAKE_BUILD_TYPE Debug CACHE STRING
Summary of changes:
CMakeLists.txt | 29 ++++++++++++++++-------------
1 file changed, 16 insertions(+), 13 deletions(-)
hooks/post-receive
geos
More information about the geos-commits
