[geos-commits] [SCM] geos branch master updated. 1e2b2a2600c4ee31378842cc3c46d61cfad9efce
git at osgeo.org
git at osgeo.org
Thu Sep 7 08:56:24 PDT 2017
the project "geos".
via 1e2b2a2600c4ee31378842cc3c46d61cfad9efce (commit)
from 6d3f562f2935735296172dbe8a1362944b89a24a (commit)
revisions in full, below.
commit 1e2b2a2600c4ee31378842cc3c46d61cfad9efce
Author: Mateusz Loskot <mateusz at loskot.net>
Date: Thu Sep 7 17:55:57 2017 +0200
Remove option -ansi conflicting with -std=c++11
Restore C++11 detection without extensions
diff --git a/configure.ac b/configure.ac
index 3082956..f68060a 100644
--- a/configure.ac
+++ b/configure.ac
@@ -133,7 +133,7 @@ dnl --------------------------------------------------------------------
dnl - Append default C++ and C flags
-AX_CXX_COMPILE_STDCXX_11([ext],[mandatory])
+AX_CXX_COMPILE_STDCXX_11([noext],[mandatory])
WARNFLAGS=""
AC_LANG_PUSH([C++])
@@ -155,7 +155,6 @@ AC_LIBTOOL_LANG_CXX_CONFIG
# -pedantic: ISO does not support long long
# we add -Wno-long-long to avoid those messages
AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -pedantic], [dummy_cv_pedantic], [-pedantic], [], [WARNFLAGS="$WARNFLAGS -pedantic"], [])
-AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -ansi], [dummy_cv_ansi], [-ansi], [], [WARNFLAGS="$WARNFLAGS -ansi"], [])
AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wall], [dummy_cv_wall], [-Wall], [], [WARNFLAGS="$WARNFLAGS -Wall"], [])
AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wno-long-long], [dummy_cv_wno_long_long], [-Wno-long-long], [], [WARNFLAGS="$WARNFLAGS -Wno-long-long"], [])
Summary of changes:
configure.ac | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
hooks/post-receive
geos
More information about the geos-commits
