[geos-commits] [SCM] geos branch master updated. a625517faf3871999fcbaee5cf0de61e0036d091
Thu Sep 7 11:15:58 PDT 2017
the project "geos".
       via  a625517faf3871999fcbaee5cf0de61e0036d091 (commit)
      from  77dfb8f781d00fb995c3481dca94bb508c4cf373 (commit)
revisions in full, below.
commit a625517faf3871999fcbaee5cf0de61e0036d091
Author: Mateusz Loskot <mateusz at loskot.net>
Date:   Thu Sep 7 20:15:18 2017 +0200
    Avoid copying of std::unique_ptr
    Prefer T::Ptr instead of std::unique_ptr<T>.
diff --git a/tests/perf/operation/buffer/IteratedBufferStressTest.cpp b/tests/perf/operation/buffer/IteratedBufferStressTest.cpp
index e661e23..1e64c6f 100644
--- a/tests/perf/operation/buffer/IteratedBufferStressTest.cpp
+++ b/tests/perf/operation/buffer/IteratedBufferStressTest.cpp
@@ -63,7 +63,7 @@ void run(const Geometry* base)
 		     << totalSW << endl; // totalSW.getTimeString() << endl;
 		dist += 1;
-		base = b2.get(); tmp = b2;
+		base = b2.get(); tmp = std::move(b2); // move as anti-optimisation?
 		if ( ! base->getNumPoints() ) break;
diff --git a/tests/perf/operation/predicate/RectangleIntersectsPerfTest.cpp b/tests/perf/operation/predicate/RectangleIntersectsPerfTest.cpp
index 654e675..400f5ac 100644
--- a/tests/perf/operation/predicate/RectangleIntersectsPerfTest.cpp
+++ b/tests/perf/operation/predicate/RectangleIntersectsPerfTest.cpp
@@ -48,7 +48,7 @@ public:
     double size = 100;
     Coordinate origin(0, 0);
-    unique_ptr<Geometry> sinePoly (
+    Geometry::Ptr sinePoly (
       createSineStar(origin, size, nPts)->getBoundary()
@@ -60,7 +60,7 @@ public:
     using geos::precision::SimpleGeometryPrecisionReducer;
     PrecisionModel pm(size/10);
     SimpleGeometryPrecisionReducer reducer(&pm);
-    unique_ptr<Geometry> sinePolyCrinkly ( reducer.reduce(sinePoly.get()) );
+    Geometry::Ptr sinePolyCrinkly ( reducer.reduce(sinePoly.get()) );
     sinePoly.reset();
     Geometry& target = *sinePolyCrinkly;
@@ -78,7 +78,7 @@ private:
   static const int NUM_LINE_PTS = 1000;
   PrecisionModel pm;
-  GeometryFactory::unique_ptr fact;
+  GeometryFactory::Ptr fact;
   void testRectangles(const Geometry& target, int nRect, double rectSize)
@@ -128,7 +128,7 @@ private:
-  unique_ptr<Polygon> createSineStar(const Coordinate& origin,
+  Polygon::Ptr createSineStar(const Coordinate& origin,
                                     double size, int nPts)
       using geos::geom::util::SineStarFactory;
@@ -139,7 +139,7 @@ private:
       gsf.setNumPoints(nPts);
       gsf.setArmLengthRatio(2);
       gsf.setNumArms(20);
-      unique_ptr<Polygon> poly = gsf.createSineStar();
+      Polygon::Ptr poly = gsf.createSineStar();
       return poly;
Summary of changes:
 tests/perf/operation/buffer/IteratedBufferStressTest.cpp     |    2 +-
 .../perf/operation/predicate/RectangleIntersectsPerfTest.cpp |   10 +++++-----
 2 files changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
geos
More information about the geos-commits mailing list
