[geos-commits] [SCM] geos branch master updated. 780221a5aa171f247d097f95cfbbde2049811ab2
git at osgeo.org
git at osgeo.org
Mon Sep 11 08:08:18 PDT 2017
the project "geos".
via 780221a5aa171f247d097f95cfbbde2049811ab2 (commit)
via af73ed20ed0ec0a610551090fdd8c8da8a66727d (commit)
from 6731fd9002ad2f6cfbf0c97dfc469db3527899cb (commit)
revisions in full, below.
commit 780221a5aa171f247d097f95cfbbde2049811ab2
Author: Mateusz Loskot <mateusz at loskot.net>
Date: Mon Sep 11 17:03:31 2017 +0200
[CMake] Remove checks for prehistoric versions of Visual Studio
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 9684781..8a5b2d4 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -143,16 +143,8 @@ elseif(MSVC)
#set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /W4")
string(REGEX REPLACE "/W[0-9]" "/W4" CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS}")
- if(NOT (MSVC_VERSION LESS 1400)) # Visual Studio 2005 or later
- # Option is to enable the /MP switch for Visual Studio 2005 or later
- option(GEOS_MSVC_ENABLE_MP
- "Set to ON to build GEOS with the /MP option (Visual Studio 2005 and above)." ON)
- mark_as_advanced(GEOS_MSVC_ENABLE_MP)
- if(GEOS_MSVC_ENABLE_MP)
- set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /MP")
- endif()
- message(STATUS "Setting Visual Studio 2005+ option /MP to ${GEOS_MSVC_ENABLE_MP}")
+ if(MSVC)
+ set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /MP")
add_definitions(-D_SCL_SECURE_NO_WARNINGS)
add_definitions(-D_CRT_SECURE_NO_WARNINGS)
commit af73ed20ed0ec0a610551090fdd8c8da8a66727d
Date: Mon Sep 11 17:03:09 2017 +0200
[CMake] No need to run cmake.exe in VS command prompt
[ci skip]
diff --git a/tools/build-cmake.bat b/tools/build-cmake.bat
index 4705e50..befb2ad 100644
--- a/tools/build-cmake.bat
+++ b/tools/build-cmake.bat
@@ -11,7 +11,6 @@ rem 4. Optionally, run devenv.exe {project}{32|64}.sln from command line
rem ### CONFIGURATION #####################################
rem #######################################################
-if not defined VS150COMNTOOLS goto :NoVS
if [%1]==[] goto :Usage
if [%1]==[32] goto :32
if [%1]==[64] goto :64
@@ -41,12 +40,6 @@ REM msbuild.exe geos%GEOSP%.sln /p:Configuration=Release /p:Platform=%MSBUILDP%
popd
goto :EOF
-:NoVS
- at echo build.bat
- at echo Visual Studio 2017 not found
- at echo "%%VS150COMNTOOLS%%" environment variable not defined
-exit /B 1
:Usage
@echo build.bat
@echo Usage: build.bat [32 or 64]
Summary of changes:
CMakeLists.txt | 12 ++----------
tools/build-cmake.bat | 7 -------
2 files changed, 2 insertions(+), 17 deletions(-)
hooks/post-receive
geos
More information about the geos-commits
