[geos-commits] [SCM] geos branch master updated. 316c4bc51d9d860b67344e48519ef98fd3c28c16
Sat Sep 16 01:29:14 PDT 2017
the project "geos".
       via  316c4bc51d9d860b67344e48519ef98fd3c28c16 (commit)
       via  b468a06bb0af4edde4fafec78661c8f3763b9764 (commit)
       via  8d6139637af5263595c768dab91008d143d1db0d (commit)
       via  15346db3c5a5148a6005fa842184d9fffcfeb801 (commit)
      from  07b05035b5e5b6a4e9ce47249aa28b38c668dc8b (commit)
revisions in full, below.
commit 316c4bc51d9d860b67344e48519ef98fd3c28c16
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat Sep 16 10:28:41 2017 +0200
    Mark operation::relate::EdgeEndBundle::print as override
    as suggested by compiler warning
diff --git a/include/geos/operation/relate/EdgeEndBundle.h b/include/geos/operation/relate/EdgeEndBundle.h
index c1b07fd..490cff3 100644
--- a/include/geos/operation/relate/EdgeEndBundle.h
+++ b/include/geos/operation/relate/EdgeEndBundle.h
@@ -61,7 +61,7 @@ public:
 	void updateIM(geom::IntersectionMatrix& im);
-	std::string print() const;
+	std::string print() const override;
 protected:
 	std::vector<geomgraph::EdgeEnd*> *edgeEnds;
commit b468a06bb0af4edde4fafec78661c8f3763b9764
Author: nila <n_larsson at yahoo.com>
Date:   Wed May 3 11:43:46 2017 +0200
    Suppress GEOSGeom_createCollection:test1 -Wunnamed-type-template-args warning
diff --git a/tests/unit/capi/GEOSGeom_createCollection.cpp b/tests/unit/capi/GEOSGeom_createCollection.cpp
index ade4aab..d735e44 100644
--- a/tests/unit/capi/GEOSGeom_createCollection.cpp
+++ b/tests/unit/capi/GEOSGeom_createCollection.cpp
@@ -72,7 +72,7 @@ namespace tut
         geoms[2] = GEOSGeom_createEmptyPoint_r(handle_);
         // takes ownership of individual geometries
         geom_ = GEOSGeom_createCollection_r(handle_, GEOS_MULTIPOINT, geoms, geom_size);
-        ensure_equals(GEOSGetNumGeometries_r(handle_, geom_), geom_size);
+        ensure_equals(GEOSGetNumGeometries_r(handle_, geom_), (int)geom_size);
 #if (defined(_MSC_VER) && _MSC_VER >= 1600) || __cplusplus > 199711L || defined(__GXX_EXPERIMENTAL_CXX0X__)
commit 8d6139637af5263595c768dab91008d143d1db0d
Date:   Wed May 3 11:42:16 2017 +0200
    Supress GeometryFactory::buildGeometry -Wpotentially-evaluated-expression warning
diff --git a/src/geom/GeometryFactory.cpp b/src/geom/GeometryFactory.cpp
index f60025c..896b457 100644
--- a/src/geom/GeometryFactory.cpp
+++ b/src/geom/GeometryFactory.cpp
@@ -723,7 +723,8 @@ GeometryFactory::buildGeometry(const vector<Geometry *> &fromGeoms) const
 	size_t i;
 	for (i=0; i<fromGeoms.size(); i++) {
-		string partClass(typeid(*fromGeoms[i]).name());
+		Geometry *geom = fromGeoms[i];
+		string partClass(typeid(*geom).name());
 		if (geomClass=="NULL") {
 			geomClass=partClass;
 		} else if (geomClass!=partClass) {
commit 15346db3c5a5148a6005fa842184d9fffcfeb801
Date:   Wed May 3 11:41:43 2017 +0200
    Suppress EdgeEndBundle::print -Woverloaded-virtual warning
index eaba734..c1b07fd 100644
-	std::string print();
+	std::string print() const;
 protected:
diff --git a/src/operation/relate/EdgeEndBundle.cpp b/src/operation/relate/EdgeEndBundle.cpp
index dcf4b4c..06b93ed 100644
--- a/src/operation/relate/EdgeEndBundle.cpp
+++ b/src/operation/relate/EdgeEndBundle.cpp
@@ -161,7 +161,7 @@ void EdgeEndBundle::updateIM(IntersectionMatrix& im) {
 	Edge::updateIM(label, im);
-string EdgeEndBundle::print() {
+string EdgeEndBundle::print() const {
 	string out="EdgeEndBundle--> Label: "+label.toString()+"\n";
 	for(vector<EdgeEnd*>::iterator it=edgeEnds->begin();it<edgeEnds->end();it++) {
 		EdgeEnd *e=*it;
Summary of changes:
 include/geos/operation/relate/EdgeEndBundle.h |    2 +-
 src/geom/GeometryFactory.cpp                  |    3 ++-
 src/operation/relate/EdgeEndBundle.cpp        |    2 +-
 tests/unit/capi/GEOSGeom_createCollection.cpp |    2 +-
 4 files changed, 5 insertions(+), 4 deletions(-)
hooks/post-receive
geos
More information about the geos-commits mailing list
