[geos-commits] [SCM] GEOS branch master updated. 264494aff6d14d534ebea29e6a940be6d47c3d03
git at osgeo.org
git at osgeo.org
Mon Aug 6 15:05:41 PDT 2018
the project "GEOS".
via 264494aff6d14d534ebea29e6a940be6d47c3d03 (commit)
via c05ad7552dab1b8a9e49bc974a9f557c4c451350 (commit)
from e7d54545d7986e2acc55af295fc498da92cd0de6 (commit)
revisions in full, below.
commit 264494aff6d14d534ebea29e6a940be6d47c3d03
Merge: e7d5454 c05ad75
Author: Kurt Schwehr <schwehr at google.com>
Date: Mon Aug 6 15:05:41 2018 -0700
Merge branch 'size-empty-849' of goatbar/geos into master
commit c05ad7552dab1b8a9e49bc974a9f557c4c451350
Date: Mon Aug 6 11:19:59 2018 -0700
size() == 0 -> empty() (#849)
clang-tidy: readability-container-size-empty size() == 0 can be replaced with empty()
https://clang.llvm.org/extra/clang-tidy/checks/readability-container-size-empty.html
diff --git a/src/geom/CoordinateArraySequence.cpp b/src/geom/CoordinateArraySequence.cpp
index f2603ec..04c786d 100644
--- a/src/geom/CoordinateArraySequence.cpp
+++ b/src/geom/CoordinateArraySequence.cpp
@@ -95,7 +95,7 @@ CoordinateArraySequence::getDimension() const
if( dimension != 0 )
return dimension;
- if( vect->size() == 0 )
+ if( vect->empty() )
return 3;
if( ISNAN((*vect)[0].z) )
diff --git a/src/geomgraph/EdgeEndStar.cpp b/src/geomgraph/EdgeEndStar.cpp
index b23b015..3310cbc 100644
--- a/src/geomgraph/EdgeEndStar.cpp
+++ b/src/geomgraph/EdgeEndStar.cpp
@@ -56,7 +56,7 @@ Coordinate&
EdgeEndStar::getCoordinate()
static Coordinate nullCoord(DoubleNotANumber, DoubleNotANumber, DoubleNotANumber);
- if (edgeMap.size()==0) return nullCoord;
+ if (edgeMap.empty()) return nullCoord;
EdgeEndStar::iterator it=begin();
EdgeEnd *e=*it;
@@ -215,7 +215,7 @@ EdgeEndStar::checkAreaLabelsConsistent(int geomIndex)
// the left side of the edge
// if no edges, trivially consistent
- if (edgeMap.size()==0) return true;
+ if (edgeMap.empty()) return true;
// initialize startLoc to location of last L side (if any)
assert(*rbegin());
@@ -366,4 +366,3 @@ operator<< (std::ostream& os, const EdgeEndStar& es)
} // namespace geos.geomgraph
} // namespace geos
diff --git a/src/operation/buffer/SubgraphDepthLocater.cpp b/src/operation/buffer/SubgraphDepthLocater.cpp
index 72a9a25..5229f5c 100644
--- a/src/operation/buffer/SubgraphDepthLocater.cpp
+++ b/src/operation/buffer/SubgraphDepthLocater.cpp
@@ -148,7 +148,7 @@ SubgraphDepthLocater::getDepth(const Coordinate& p)
findStabbedSegments(p, stabbedSegments);
// if no segments on stabbing line subgraph must be outside all others
- if (stabbedSegments.size()==0) return 0;
+ if (stabbedSegments.empty()) return 0;
sort(stabbedSegments.begin(), stabbedSegments.end(), DepthSegmentLessThen());
diff --git a/src/operation/linemerge/LineSequencer.cpp b/src/operation/linemerge/LineSequencer.cpp
index 69931ee..f55564e 100644
--- a/src/operation/linemerge/LineSequencer.cpp
+++ b/src/operation/linemerge/LineSequencer.cpp
@@ -232,7 +232,7 @@ LineSequencer::buildSequencedGeometry(const Sequences& sequences)
- if ( lines->size() == 0 ) {
+ if ( lines->empty() ) {
return nullptr;
} else {
Geometry::NonConstVect *l=lines.get();
diff --git a/src/operation/overlay/LineBuilder.cpp b/src/operation/overlay/LineBuilder.cpp
index 9994c0e..6b13d68 100644
--- a/src/operation/overlay/LineBuilder.cpp
+++ b/src/operation/overlay/LineBuilder.cpp
@@ -225,7 +225,7 @@ LineBuilder::propagateZ(CoordinateSequence *cs)
cerr<<" found "<<v3d.size()<<" 3d vertexes"<<endl;
#endif
- if ( v3d.size() == 0 )
+ if ( v3d.empty() )
#if GEOS_DEBUG
cerr<<" nothing to do"<<endl;
@@ -318,4 +318,3 @@ LineBuilder::labelIsolatedLine(Edge *e, int targetIndex)
} // namespace geos.operation.overlay
} // namespace geos
Summary of changes:
src/geom/CoordinateArraySequence.cpp | 2 +-
src/geomgraph/EdgeEndStar.cpp | 5 ++---
src/operation/buffer/SubgraphDepthLocater.cpp | 2 +-
src/operation/linemerge/LineSequencer.cpp | 2 +-
src/operation/overlay/LineBuilder.cpp | 3 +--
5 files changed, 6 insertions(+), 8 deletions(-)
hooks/post-receive
More information about the geos-commits
