[geos-commits] [SCM] GEOS branch master updated. 3f09f50fed5514b02c366964b2b550c0e5baafb2
git at osgeo.org
git at osgeo.org
Sat Aug 18 21:11:03 PDT 2018
the project "GEOS".
via 3f09f50fed5514b02c366964b2b550c0e5baafb2 (commit)
from 83b3f4210ef30208daa966ae82aa20d12aa319a7 (commit)
revisions in full, below.
commit 3f09f50fed5514b02c366964b2b550c0e5baafb2
Author: Regina Obe <lr at pcorp.us>
Date: Sun Aug 19 00:10:52 2018 -0400
Allow building C API as static lib for CMake. References #878 for GEOS 3.7.0, closes https://github.com/libgeos/geos/pull/102
diff --git a/capi/CMakeLists.txt b/capi/CMakeLists.txt
index 77d5ff5..a40fde1 100644
--- a/capi/CMakeLists.txt
+++ b/capi/CMakeLists.txt
@@ -21,8 +21,8 @@ set(geos_c_SOURCES
file(GLOB geos_capi_HEADERS ${CMAKE_BINARY_DIR}/capi/*.h) # fix source_group issue
-if(NOT GEOS_ENABLE_MACOSX_FRAMEWORK)
- # if building OS X framework, CAPI built into C++ library
+if(NOT GEOS_ENABLE_MACOSX_FRAMEWORK AND GEOS_BUILD_SHARED)
+ # if building OS X framework or only building static libs, CAPI built into C++ library
add_library(geos_c SHARED ${geos_c_SOURCES})
target_link_libraries(geos_c geos)
@@ -57,7 +57,7 @@ else()
DESTINATION include)
endif()
install(TARGETS geos_c
RUNTIME DESTINATION bin
LIBRARY DESTINATION lib
diff --git a/src/CMakeLists.txt b/src/CMakeLists.txt
index 4a1e688..e477ed4 100644
--- a/src/CMakeLists.txt
+++ b/src/CMakeLists.txt
@@ -14,15 +14,16 @@
file(GLOB_RECURSE geos_SOURCES ${CMAKE_CURRENT_SOURCE_DIR}/*.cpp)
file(GLOB_RECURSE geos_ALL_HEADERS ${CMAKE_SOURCE_DIR}/include/*.h) # fix source_group issue
+# Include CAPI in OS X framework binary and in static libs
+set(geos_c_SOURCES
+ ${CMAKE_CURRENT_SOURCE_DIR}/../capi/geos_c.cpp
+ ${CMAKE_CURRENT_SOURCE_DIR}/../capi/geos_ts_c.cpp)
if(GEOS_ENABLE_MACOSX_FRAMEWORK)
# OS X frameworks don't have static libs
# also 1 binary, so include CAPI here
# and, make name all caps
- set(geos_c_SOURCES
- ${CMAKE_CURRENT_SOURCE_DIR}/../capi/geos_c.cpp
- ${CMAKE_CURRENT_SOURCE_DIR}/../capi/geos_ts_c.cpp)
add_library(GEOS SHARED ${geos_SOURCES} ${geos_c_SOURCES})
math(EXPR CVERSION "${VERSION_MAJOR} + 1")
@@ -77,7 +78,8 @@ else()
endif()
if(GEOS_BUILD_STATIC)
- add_library(geos-static STATIC ${geos_SOURCES} ${geos_ALL_HEADERS})
+ file(GLOB geos_capi_HEADERS ${CMAKE_CURRENT_SOURCE_DIR}/../capi/*.h) # fix source_group issue
+ add_library(geos-static STATIC ${geos_SOURCES} ${geos_c_SOURCES} ${geos_ALL_HEADERS} ${geos_capi_HEADERS})
set_target_properties(geos-static
PROPERTIES
@@ -85,6 +87,8 @@ else()
PREFIX "lib"
CLEAN_DIRECT_OUTPUT 1)
+ add_dependencies(geos-static geos_revision)
install(TARGETS geos-static
Summary of changes:
capi/CMakeLists.txt | 6 +++---
src/CMakeLists.txt | 14 +++++++++-----
2 files changed, 12 insertions(+), 8 deletions(-)
hooks/post-receive
More information about the geos-commits
