[geos-commits] [SCM] GEOS branch master updated. cb40f9596a9615e39df4dcaece3e1b4693180c1a
git at osgeo.org
git at osgeo.org
Sun Aug 26 19:16:48 PDT 2018
the project "GEOS".
via cb40f9596a9615e39df4dcaece3e1b4693180c1a (commit)
via 16bd141c8f9cd05f12f1d0574c4ffc89703e48d2 (commit)
from a39e412e43f8b48fd873169d9d3af2b23071126e (commit)
revisions in full, below.
commit cb40f9596a9615e39df4dcaece3e1b4693180c1a
Merge: a39e412 16bd141
Author: cvvergara <vicky at georepublic.de>
Date: Sun Aug 26 19:16:48 2018 -0700
Merge branch 'fix-cmake-version' of cvvergara/geos into master
commit 16bd141c8f9cd05f12f1d0574c4ffc89703e48d2
Date: Sun Aug 26 00:58:18 2018 +0200
Closes #921 Added new way to change version for cmake build
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 1b1f47b..3dad493 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -24,6 +24,8 @@ endif()
# Set GEOS project
project(GEOS VERSION 3.8.0 LANGUAGES C CXX)
+# OPTIONS: "", "dev", "rc1" etc.
+SET(GEOS_PATCH_WORD "dev")
# Add custom GEOS modules for CMake
list(APPEND CMAKE_MODULE_PATH "${PROJECT_SOURCE_DIR}/cmake/modules")
@@ -43,14 +45,14 @@ message(STATUS "Setting C++ requirement to C++${CMAKE_CXX_STANDARD}")
# GEOS release version
# GEOS C++ library SONAME will use these encoding ABI break at every release
-set(GEOS_VERSION "${GEOS_VERSION_MAJOR}.${GEOS_VERSION_MINOR}.${GEOS_VERSION_PATCH}")
+set(GEOS_VERSION "${GEOS_VERSION_MAJOR}.${GEOS_VERSION_MINOR}.${GEOS_VERSION_PATCH}${GEOS_PATCH_WORD}")
set(VERSION "${GEOS_VERSION}")
# Copy version components into different variable names to match those used
# by autotools for *.h.in files
-set(VERSION_MAJOR ${GEOS_VERSION_MAJOR})
-set(VERSION_MINOR ${GEOS_VERSION_MINOR})
-set(VERSION_PATCH ${GEOS_VERSION_PATCH}dev)
+set(VERSION_MAJOR "${GEOS_VERSION_MAJOR}")
+set(VERSION_MINOR "${GEOS_VERSION_MINOR}")
+set(VERSION_PATCH "${GEOS_VERSION_PATCH}${GEOS_PATCH_WORD}")
# JTS_PORT is the version of JTS this release is bound to
set(JTS_PORT 1.13.0)
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index e5c7a4b..eaf4f7b 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -36,9 +36,9 @@
- VERSION_MAJOR for SUBSTANTIAL additions or C lib ABI break
[ THIS MUST BE CAREFULLY AVOIDED ]
- In main CMakeLists.txt main one
- - CHANGE the line: project(GEOS VERSION <mayor>.<minor>.<micro> LANGUAGES C CXX)
- - CHANGE the line: set(GEOS_VERSION_PATCH "${GEOS_VERSION_PATCH}dev")
- - CAPI_INTERFACE_*
+ - On section: "# Set GEOS project"
+ - CHANGE the line: project(GEOS VERSION <mayor>.<minor>.<micro> LANGUAGES C CXX)
+ - CHANGE the line: SET(GEOS_PATCH_WORD "dev")
12. Update wiki page https://trac.osgeo.org/geos/ at Download section
- Add latest release
Summary of changes:
CMakeLists.txt | 10 ++++++----
HOWTO_RELEASE | 6 +++---
2 files changed, 9 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits
