[geos-commits] [SCM] GEOS branch master updated. 434a1adf6a9b445d06b434e3d3ef0a1d4ab7f742
git at osgeo.org
git at osgeo.org
Tue Aug 28 11:51:25 PDT 2018
the project "GEOS".
via 434a1adf6a9b445d06b434e3d3ef0a1d4ab7f742 (commit)
via 7d577f9368666310f372b066c81ae44e780bcb2f (commit)
from 1be02b3644672ac97842bfa2ad4cb2810696dc75 (commit)
revisions in full, below.
commit 434a1adf6a9b445d06b434e3d3ef0a1d4ab7f742
Merge: 1be02b3 7d577f9
Author: cvvergara <vicky at georepublic.de>
Date: Tue Aug 28 11:51:24 2018 -0700
Merge branch 'rm-static-1' of cvvergara/geos into master
commit 7d577f9368666310f372b066c81ae44e780bcb2f
Date: Sat Jul 14 19:24:18 2018 -0500
Closes #897 Unifying with size_t type
This is a combination of 23 commits.
diff --git a/include/geos/algorithm/LineIntersector.h b/include/geos/algorithm/LineIntersector.h
index 2b8ae84..293a1ef 100644
--- a/include/geos/algorithm/LineIntersector.h
+++ b/include/geos/algorithm/LineIntersector.h
@@ -160,7 +160,7 @@ public:
/// This will be either 0, 1 or 2.
- int getIntersectionNum() const { return result; }
+ size_t getIntersectionNum() const { return result; }
/// Returns the intIndex'th intersection point
@@ -169,7 +169,7 @@ public:
/// @return the intIndex'th intersection point
- const geom::Coordinate& getIntersection(int intIndex) const {
+ const geom::Coordinate& getIntersection(size_t intIndex) const {
return intPt[intIndex];
@@ -241,7 +241,7 @@ public:
* @return the edge distance of the intersection point
- double getEdgeDistance(int geomIndex,int intIndex) const;
+ double getEdgeDistance(size_t geomIndex, size_t intIndex) const;
private:
@@ -257,7 +257,7 @@ private:
const geom::PrecisionModel *precisionModel;
- int result;
+ size_t result;
const geom::Coordinate *inputLines[2][2];
diff --git a/include/geos/algorithm/distance/PointPairDistance.h b/include/geos/algorithm/distance/PointPairDistance.h
index 10e51b7..e266faa 100644
--- a/include/geos/algorithm/distance/PointPairDistance.h
+++ b/include/geos/algorithm/distance/PointPairDistance.h
@@ -70,7 +70,7 @@ public:
return pt;
- const geom::Coordinate& getCoordinate(unsigned int i) const
+ const geom::Coordinate& getCoordinate(size_t i) const
assert(i<pt.size());
return pt[i];
diff --git a/include/geos/geom/CoordinateList.h b/include/geos/geom/CoordinateList.h
index 902c007..b478afb 100644
--- a/include/geos/geom/CoordinateList.h
+++ b/include/geos/geom/CoordinateList.h
@@ -58,7 +58,6 @@ public:
typedef std::list<Coordinate>::iterator iterator;
typedef std::list<Coordinate>::const_iterator const_iterator;
- typedef std::list<Coordinate>::size_type size_type;
friend std::ostream& operator<< (std::ostream& os,
const CoordinateList& cl);
@@ -84,7 +83,7 @@ public:
- size_type size() const
+ size_t size() const
return coords.size();
diff --git a/include/geos/geom/CoordinateSequence.h b/include/geos/geom/CoordinateSequence.h
index 008f891..c6e3e30 100644
--- a/include/geos/geom/CoordinateSequence.h
+++ b/include/geos/geom/CoordinateSequence.h
@@ -262,7 +262,7 @@ public:
/// FIXME: return std::size_t, using numeric_limits<std::size_t>::max
/// as 'not found' value.
- static int indexOf(const Coordinate *coordinate,
+ static size_t indexOf(const Coordinate *coordinate,
const CoordinateSequence *cl);
diff --git a/include/geos/geom/IntersectionMatrix.h b/include/geos/geom/IntersectionMatrix.h
index e7c0ec9..e225f4b 100644
--- a/include/geos/geom/IntersectionMatrix.h
+++ b/include/geos/geom/IntersectionMatrix.h
@@ -167,7 +167,7 @@ public:
* to compare the element. The order of dimension values
* from least to greatest is {DONTCARE, TRUE, FALSE, 0, 1, 2}.
- void setAtLeast(int row, int column, int minimumDimensionValue);
+ void setAtLeast(size_t row, size_t column, int minimumDimensionValue);
/** \brief
* If row >= 0 and column >= 0, changes the specified element
diff --git a/include/geos/geom/LineString.h b/include/geos/geom/LineString.h
index 30e0e64..81c6c38 100644
--- a/include/geos/geom/LineString.h
+++ b/include/geos/geom/LineString.h
@@ -92,7 +92,7 @@ public:
/// Returns a read-only pointer to internal CoordinateSequence
const CoordinateSequence* getCoordinatesRO() const;
- virtual const Coordinate& getCoordinateN(int n) const;
+ virtual const Coordinate& getCoordinateN(size_t n) const;
/// Returns line dimension (1)
Dimension::DimensionType getDimension() const override;
diff --git a/include/geos/geom/MultiPoint.h b/include/geos/geom/MultiPoint.h
index 4fc0676..ec1b718 100644
--- a/include/geos/geom/MultiPoint.h
+++ b/include/geos/geom/MultiPoint.h
@@ -112,7 +112,7 @@ protected:
MultiPoint(const MultiPoint &mp): Geometry(mp), GeometryCollection(mp) {}
- const Coordinate* getCoordinateN(int n) const;
+ const Coordinate* getCoordinateN(size_t n) const;
#ifdef _MSC_VER
diff --git a/include/geos/geomgraph/Edge.h b/include/geos/geomgraph/Edge.h
index 1583e2a..6067c7e 100644
--- a/include/geos/geomgraph/Edge.h
+++ b/include/geos/geomgraph/Edge.h
@@ -109,8 +109,8 @@ public:
~Edge() override;
- virtual int getNumPoints() const {
- return static_cast<int>(pts->getSize());
+ virtual size_t getNumPoints() const {
+ return pts->getSize();
virtual void setName(const std::string &newName) {
@@ -122,7 +122,7 @@ public:
return pts;
- virtual const geom::Coordinate& getCoordinate(int i) const {
+ virtual const geom::Coordinate& getCoordinate(size_t i) const {
testInvariant();
return pts->getAt(i);
@@ -153,7 +153,7 @@ public:
testInvariant();
- virtual int getMaximumSegmentIndex() const {
+ virtual size_t getMaximumSegmentIndex() const {
testInvariant();
return getNumPoints()-1;
@@ -196,16 +196,16 @@ public:
* Adds EdgeIntersections for one or both
* intersections found for a segment of an edge to the edge intersection list.
- virtual void addIntersections(algorithm::LineIntersector *li, int segmentIndex,
- int geomIndex);
+ virtual void addIntersections(algorithm::LineIntersector *li, size_t segmentIndex,
+ size_t geomIndex);
/// Add an EdgeIntersection for intersection intIndex.
/// An intersection that falls exactly on a vertex of the edge is normalized
/// to use the higher of the two possible segmentIndexes
- virtual void addIntersection(algorithm::LineIntersector *li, int segmentIndex,
- int geomIndex, int intIndex);
+ virtual void addIntersection(algorithm::LineIntersector *li, size_t segmentIndex,
+ size_t geomIndex, size_t intIndex);
/// Update the IM with the contribution for this component.
diff --git a/include/geos/geomgraph/EdgeIntersection.h b/include/geos/geomgraph/EdgeIntersection.h
index 4a4bffc..cc522f1 100644
--- a/include/geos/geomgraph/EdgeIntersection.h
+++ b/include/geos/geomgraph/EdgeIntersection.h
@@ -52,17 +52,17 @@ public:
double dist;
// the index of the containing line segment in the parent edge
- int segmentIndex;
+ size_t segmentIndex;
EdgeIntersection(const geom::Coordinate& newCoord,
- int newSegmentIndex, double newDist)
+ size_t newSegmentIndex, double newDist)
coord(newCoord),
dist(newDist),
segmentIndex(newSegmentIndex)
- bool isEndPoint(int maxSegmentIndex) const {
+ bool isEndPoint(size_t maxSegmentIndex) const {
if (segmentIndex==0 && dist==0.0) return true;
if (segmentIndex==maxSegmentIndex) return true;
return false;
@@ -72,7 +72,7 @@ public:
return coord;
- int getSegmentIndex() const { return segmentIndex; }
+ size_t getSegmentIndex() const { return segmentIndex; }
double getDistance() const { return dist; }
diff --git a/include/geos/geomgraph/EdgeIntersectionList.h b/include/geos/geomgraph/EdgeIntersectionList.h
index 83201c9..212f8ad 100644
--- a/include/geos/geomgraph/EdgeIntersectionList.h
+++ b/include/geos/geomgraph/EdgeIntersectionList.h
@@ -77,7 +77,7 @@ public:
* @return the EdgeIntersection found or added
EdgeIntersection* add(const geom::Coordinate& coord,
- int segmentIndex, double dist);
+ size_t segmentIndex, double dist);
iterator begin() { return nodeMap.begin(); }
iterator end() { return nodeMap.end(); }
diff --git a/include/geos/geomgraph/index/MonotoneChain.h b/include/geos/geomgraph/index/MonotoneChain.h
index f19c463..3a546ec 100644
--- a/include/geos/geomgraph/index/MonotoneChain.h
+++ b/include/geos/geomgraph/index/MonotoneChain.h
@@ -44,11 +44,11 @@ namespace index { // geos::geomgraph::index
class GEOS_DLL MonotoneChain: public SweepLineEventOBJ {
private:
MonotoneChainEdge *mce;
- int chainIndex;
+ size_t chainIndex;
public:
- MonotoneChain(MonotoneChainEdge *newMce, int newChainIndex):
+ MonotoneChain(MonotoneChainEdge *newMce, size_t newChainIndex):
mce(newMce),
chainIndex(newChainIndex)
diff --git a/include/geos/geomgraph/index/MonotoneChainEdge.h b/include/geos/geomgraph/index/MonotoneChainEdge.h
index 9c77a11..68c6341 100644
--- a/include/geos/geomgraph/index/MonotoneChainEdge.h
+++ b/include/geos/geomgraph/index/MonotoneChainEdge.h
@@ -47,15 +47,15 @@ public:
~MonotoneChainEdge();
MonotoneChainEdge(Edge *newE);
const geom::CoordinateSequence* getCoordinates();
- std::vector<int>& getStartIndexes();
- double getMinX(int chainIndex);
- double getMaxX(int chainIndex);
+ std::vector<size_t>& getStartIndexes();
+ double getMinX(size_t chainIndex);
+ double getMaxX(size_t chainIndex);
void computeIntersects(const MonotoneChainEdge &mce,
SegmentIntersector &si);
- void computeIntersectsForChain(int chainIndex0,
- const MonotoneChainEdge &mce, int chainIndex1,
+ void computeIntersectsForChain(size_t chainIndex0,
+ const MonotoneChainEdge &mce, size_t chainIndex1,
protected:
@@ -63,14 +63,14 @@ protected:
const geom::CoordinateSequence* pts; // cache a reference to the coord array, for efficiency
// the lists of start/end indexes of the monotone chains.
// Includes the end point of the edge as a sentinel
- std::vector<int> startIndex;
+ std::vector<size_t> startIndex;
// these envelopes are created once and reused
geom::Envelope env1;
geom::Envelope env2;
private:
- void computeIntersectsForChain(int start0, int end0,
+ void computeIntersectsForChain(size_t start0, size_t end0,
- int start1, int end1,
+ size_t start1, size_t end1,
SegmentIntersector &ei);
diff --git a/include/geos/geomgraph/index/MonotoneChainIndexer.h b/include/geos/geomgraph/index/MonotoneChainIndexer.h
index db72dae..1b282ee 100644
--- a/include/geos/geomgraph/index/MonotoneChainIndexer.h
+++ b/include/geos/geomgraph/index/MonotoneChainIndexer.h
@@ -16,8 +16,8 @@
#ifndef GEOS_GEOMGRAPH_INDEX_MONOTONECHAININDEXER_H
#define GEOS_GEOMGRAPH_INDEX_MONOTONECHAININDEXER_H
-#include <geos/export.h>
#include <vector>
+#include <geos/export.h>
// Forward declarations
namespace geos {
@@ -37,11 +37,11 @@ public:
MonotoneChainIndexer(){}
- void getChainStartIndices(const geom::CoordinateSequence*, std::vector<int>&);
+ void getChainStartIndices(const geom::CoordinateSequence*, std::vector<std::size_t>&);
private:
- int findChainEnd(const geom::CoordinateSequence* pts, int start);
+ std::size_t findChainEnd(const geom::CoordinateSequence* pts, std::size_t start);
diff --git a/include/geos/geomgraph/index/SegmentIntersector.h b/include/geos/geomgraph/index/SegmentIntersector.h
index e979e52..ec3bf62 100644
--- a/include/geos/geomgraph/index/SegmentIntersector.h
+++ b/include/geos/geomgraph/index/SegmentIntersector.h
@@ -78,7 +78,7 @@ private:
/// Elements are externally owned
std::vector<std::vector<Node*>*> bdyNodes;
- bool isTrivialIntersection(Edge *e0,int segIndex0,Edge *e1, int segIndex1);
+ bool isTrivialIntersection(Edge *e0, size_t segIndex0,Edge *e1, size_t segIndex1);
bool isBoundaryPoint(algorithm::LineIntersector *li,
std::vector<std::vector<Node*>*>& tstBdyNodes);
@@ -88,7 +88,7 @@ private:
public:
- static bool isAdjacentSegments(int i1,int i2);
+ static bool isAdjacentSegments(size_t i1, size_t i2);
// testing only
int numTests;
@@ -127,7 +127,7 @@ public:
bool hasProperInteriorIntersection();
- void addIntersections(Edge *e0, int segIndex0, Edge *e1, int segIndex1);
+ void addIntersections(Edge *e0, size_t segIndex0, Edge *e1, size_t segIndex1);
void setIsDoneIfProperInt(bool isDoneWhenProperInt);
diff --git a/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h b/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
index d88bdc3..4ebf526 100644
--- a/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
+++ b/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
@@ -84,7 +84,7 @@ private:
void computeIntersections(SegmentIntersector *si);
- void processOverlaps(int start, int end,
+ void processOverlaps(size_t start, size_t end,
SweepLineEvent *ev0,
diff --git a/include/geos/geomgraph/index/SimpleSweepLineIntersector.h b/include/geos/geomgraph/index/SimpleSweepLineIntersector.h
index cd8c84d..2e17652 100644
--- a/include/geos/geomgraph/index/SimpleSweepLineIntersector.h
+++ b/include/geos/geomgraph/index/SimpleSweepLineIntersector.h
@@ -81,7 +81,7 @@ private:
- void processOverlaps(int start, int end, SweepLineEvent *ev0,
+ void processOverlaps(size_t start, size_t end, SweepLineEvent *ev0,
diff --git a/include/geos/geomgraph/index/SweepLineEvent.h b/include/geos/geomgraph/index/SweepLineEvent.h
index b481184..854afe3 100644
--- a/include/geos/geomgraph/index/SweepLineEvent.h
+++ b/include/geos/geomgraph/index/SweepLineEvent.h
@@ -57,9 +57,9 @@ public:
SweepLineEvent* getInsertEvent() { return insertEvent; }
- int getDeleteEventIndex() { return deleteEventIndex; }
+ size_t getDeleteEventIndex() { return deleteEventIndex; }
- void setDeleteEventIndex(int newDeleteEventIndex) {
+ void setDeleteEventIndex(size_t newDeleteEventIndex) {
deleteEventIndex=newDeleteEventIndex;
@@ -83,7 +83,7 @@ private:
SweepLineEvent *insertEvent; // null if this is an INSERT_EVENT event
- int deleteEventIndex;
+ size_t deleteEventIndex;
class GEOS_DLL SweepLineEventLessThen {
diff --git a/include/geos/geomgraph/index/SweepLineSegment.h b/include/geos/geomgraph/index/SweepLineSegment.h
index d6c8f35..6e4b5c3 100644
--- a/include/geos/geomgraph/index/SweepLineSegment.h
+++ b/include/geos/geomgraph/index/SweepLineSegment.h
@@ -16,7 +16,7 @@
#ifndef GEOS_GEOMGRAPH_INDEX_SWEEPLINESEGMENT_H
#define GEOS_GEOMGRAPH_INDEX_SWEEPLINESEGMENT_H
+#include <cstddef>
#include <geos/geomgraph/index/SweepLineEventObj.h> // for inheritance
@@ -39,7 +39,7 @@ namespace index { // geos::geomgraph::index
class GEOS_DLL SweepLineSegment: public SweepLineEventOBJ {
public:
- SweepLineSegment(Edge *newEdge, int newPtIndex);
+ SweepLineSegment(Edge *newEdge, size_t newPtIndex);
~SweepLineSegment() override;
double getMinX();
double getMaxX();
@@ -47,7 +47,7 @@ public:
protected:
Edge *edge;
- int ptIndex;
+ size_t ptIndex;
diff --git a/include/geos/index/chain/MonotoneChainSelectAction.h b/include/geos/index/chain/MonotoneChainSelectAction.h
index 9cd1101..ec1e807 100644
--- a/include/geos/index/chain/MonotoneChainSelectAction.h
+++ b/include/geos/index/chain/MonotoneChainSelectAction.h
@@ -55,7 +55,7 @@ public:
virtual ~MonotoneChainSelectAction() {}
/// This function can be overridden if the original chain is needed
- virtual void select(MonotoneChain& mc, unsigned int start);
+ virtual void select(MonotoneChain& mc, size_t start);
* This is a convenience function which can be overridden
diff --git a/include/geos/index/quadtree/NodeBase.h b/include/geos/index/quadtree/NodeBase.h
index 3152e89..10e197c 100644
--- a/include/geos/index/quadtree/NodeBase.h
+++ b/include/geos/index/quadtree/NodeBase.h
@@ -81,9 +81,9 @@ public:
unsigned int depth() const;
- unsigned int size() const;
+ size_t size() const;
- unsigned int getNodeCount() const;
+ size_t getNodeCount() const;
virtual std::string toString() const;
diff --git a/include/geos/index/quadtree/Quadtree.h b/include/geos/index/quadtree/Quadtree.h
index d237023..0ce3746 100644
--- a/include/geos/index/quadtree/Quadtree.h
+++ b/include/geos/index/quadtree/Quadtree.h
@@ -119,7 +119,7 @@ public:
int depth();
/// Returns the number of items in the tree.
- int size();
+ size_t size();
void insert(const geom::Envelope *itemEnv, void *item) override;
diff --git a/include/geos/index/strtree/AbstractNode.h b/include/geos/index/strtree/AbstractNode.h
index 4edcf01..f1802d7 100644
--- a/include/geos/index/strtree/AbstractNode.h
+++ b/include/geos/index/strtree/AbstractNode.h
@@ -15,6 +15,7 @@
#ifndef GEOS_INDEX_STRTREE_ABSTRACTNODE_H
#define GEOS_INDEX_STRTREE_ABSTRACTNODE_H
+#include <cstddef>
#include <geos/index/strtree/Boundable.h> // for inheritance
@@ -44,7 +45,7 @@ private:
std::vector<Boundable*> childBoundables;
int level;
public:
- AbstractNode(int newLevel, int capacity=10);
+ AbstractNode(int newLevel, size_t capacity = 10);
~AbstractNode() override;
// TODO: change signature to return by ref,
diff --git a/include/geos/index/sweepline/SweepLineEvent.h b/include/geos/index/sweepline/SweepLineEvent.h
index 7e40d95..c700ea3 100644
--- a/include/geos/index/sweepline/SweepLineEvent.h
+++ b/include/geos/index/sweepline/SweepLineEvent.h
@@ -15,6 +15,7 @@
#ifndef GEOS_INDEX_SWEEPLINE_SWEEPLINEEVENT_H
#define GEOS_INDEX_SWEEPLINE_SWEEPLINEEVENT_H
+#include <cstddef>
@@ -48,9 +49,9 @@ public:
SweepLineEvent* getInsertEvent();
- int getDeleteEventIndex();
+ size_t getDeleteEventIndex();
- void setDeleteEventIndex(int newDeleteEventIndex);
+ void setDeleteEventIndex(size_t newDeleteEventIndex);
SweepLineInterval* getInterval();
@@ -73,7 +74,7 @@ private:
/// null if this is an INSERT_EVENT event
SweepLineInterval *sweepInt;
diff --git a/include/geos/index/sweepline/SweepLineIndex.h b/include/geos/index/sweepline/SweepLineIndex.h
index f4c95c6..5d885ee 100644
--- a/include/geos/index/sweepline/SweepLineIndex.h
+++ b/include/geos/index/sweepline/SweepLineIndex.h
@@ -15,9 +15,9 @@
#ifndef GEOS_INDEX_SWEEPLINE_SWEEPLINEINDEX_H
#define GEOS_INDEX_SWEEPLINE_SWEEPLINEINDEX_H
+#include <vector>
-#include <vector>
#ifdef _MSC_VER
#pragma warning(push)
@@ -73,7 +73,7 @@ private:
void buildIndex();
+ void processOverlaps(std::size_t start, std::size_t end,
SweepLineInterval *s0,
SweepLineOverlapAction *action);
diff --git a/include/geos/io/WKBWriter.h b/include/geos/io/WKBWriter.h
index 373994a..32a3914 100644
--- a/include/geos/io/WKBWriter.h
+++ b/include/geos/io/WKBWriter.h
@@ -182,7 +182,7 @@ private:
void writeCoordinateSequence(const geom::CoordinateSequence &cs, bool sized);
// throws IOException
- void writeCoordinate(const geom::CoordinateSequence &cs, int idx, bool is3d);
+ void writeCoordinate(const geom::CoordinateSequence &cs, size_t idx, bool is3d);
void writeGeometryType(int geometryType, int SRID);
diff --git a/include/geos/linearref/LinearIterator.h b/include/geos/linearref/LinearIterator.h
index 3b978ed..2aa1779 100644
--- a/include/geos/linearref/LinearIterator.h
+++ b/include/geos/linearref/LinearIterator.h
@@ -74,7 +74,7 @@ public:
* @param componentIndex the component to start at
* @param vertexIndex the vertex to start at
- LinearIterator(const geom::Geometry *linear, unsigned int componentIndex, unsigned int vertexIndex);
+ LinearIterator(const geom::Geometry *linear, size_t componentIndex, size_t vertexIndex);
* Tests whether there are any vertices left to iterator over.
@@ -100,13 +100,13 @@ public:
* The component index of the vertex the iterator is currently at.
* @return the current component index
- unsigned int getComponentIndex() const;
+ size_t getComponentIndex() const;
* The vertex index of the vertex the iterator is currently at.
* @return the current vertex index
- unsigned int getVertexIndex() const;
+ size_t getVertexIndex() const;
* Gets the {@link LineString} component the iterator is current at.
@@ -132,13 +132,13 @@ public:
private:
- static unsigned int segmentEndVertexIndex(const LinearLocation& loc);
+ static size_t segmentEndVertexIndex(const LinearLocation& loc);
const geom::LineString *currentLine;
- unsigned int vertexIndex;
- unsigned int componentIndex;
+ size_t vertexIndex;
+ size_t componentIndex;
const geom::Geometry *linear;
- const unsigned int numLines;
+ const size_t numLines;
* Invariant: currentLine <> null if the iterator is pointing
diff --git a/include/geos/linearref/LinearLocation.h b/include/geos/linearref/LinearLocation.h
index fb0a74a..c129257 100644
--- a/include/geos/linearref/LinearLocation.h
+++ b/include/geos/linearref/LinearLocation.h
@@ -43,8 +43,8 @@ namespace linearref { // geos::linearref
class LinearLocation
private:
- unsigned int segmentIndex;
double segmentFraction;
@@ -85,9 +85,9 @@ public:
* Creates a location referring to the start of a linear geometry
- LinearLocation(unsigned int segmentIndex = 0, double segmentFraction = 0.0);
+ LinearLocation(size_t segmentIndex = 0, double segmentFraction = 0.0);
- LinearLocation(unsigned int componentIndex, unsigned int segmentIndex, double segmentFraction);
+ LinearLocation(size_t componentIndex, size_t segmentIndex, double segmentFraction);
* Ensures the indexes are valid for a given linear {@link Geometry}.
@@ -128,14 +128,14 @@ public:
* @return the component index
* Gets the segment index for this location
* @return the segment index
- unsigned int getSegmentIndex() const;
+ size_t getSegmentIndex() const;
* Gets the segment fraction for this location
@@ -198,7 +198,7 @@ public:
* @return a negative integer, zero, or a positive integer as this <code>LineStringLocation</code>
* is less than, equal to, or greater than the specified locationValues
- int compareLocationValues(unsigned int componentIndex1, unsigned int segmentIndex1, double segmentFraction1) const;
+ int compareLocationValues(size_t componentIndex1, size_t segmentIndex1, double segmentFraction1) const;
* Compares two sets of location values for order.
@@ -214,8 +214,8 @@ public:
* is less than, equal to, or greater than the second set of locationValues
static int compareLocationValues(
- unsigned int componentIndex0, unsigned int segmentIndex0, double segmentFraction0,
- unsigned int componentIndex1, unsigned int segmentIndex1, double segmentFraction1);
+ size_t componentIndex0, size_t segmentIndex0, double segmentFraction0,
+ size_t componentIndex1, size_t segmentIndex1, double segmentFraction1);
* Tests whether two locations
diff --git a/include/geos/noding/BasicSegmentString.h b/include/geos/noding/BasicSegmentString.h
index 13a934c..d009744 100644
--- a/include/geos/noding/BasicSegmentString.h
+++ b/include/geos/noding/BasicSegmentString.h
@@ -68,13 +68,13 @@ public:
/// see dox in SegmentString.h
- unsigned int size() const override
+ size_t size() const override
- return static_cast<unsigned int>(pts->size());
+ return pts->size();
- const geom::Coordinate& getCoordinate(unsigned int i) const override;
+ const geom::Coordinate& getCoordinate(size_t i) const override;
geom::CoordinateSequence* getCoordinates() const override;
* Must not be the last index in the vertex list
* @return the octant of the segment at the vertex
- int getSegmentOctant(unsigned int index) const;
+ int getSegmentOctant(size_t index) const;
private:
diff --git a/include/geos/noding/IntersectionAdder.h b/include/geos/noding/IntersectionAdder.h
index e1689df..58d9090 100644
--- a/include/geos/noding/IntersectionAdder.h
+++ b/include/geos/noding/IntersectionAdder.h
@@ -81,8 +81,8 @@ private:
* Note that closed edges require a special check for the point
* shared by the beginning and end segments.
- bool isTrivialIntersection(const SegmentString* e0, int segIndex0,
- const SegmentString* e1, int segIndex1);
+ bool isTrivialIntersection(const SegmentString* e0, size_t segIndex0,
+ const SegmentString* e1, size_t segIndex1);
// Declare type as noncopyable
IntersectionAdder(const IntersectionAdder& other) = delete;
@@ -157,12 +157,12 @@ public:
* intersect (e.g. by an disjoint envelope test).
void processIntersections(
- SegmentString* e0, int segIndex0,
- SegmentString* e1, int segIndex1) override;
+ SegmentString* e0, size_t segIndex0,
+ SegmentString* e1, size_t segIndex1) override;
- static bool isAdjacentSegments(int i1, int i2) {
- return std::abs(i1 - i2) == 1;
+ static bool isAdjacentSegments(size_t i1, size_t i2) {
+ return (i1 > i2 ? i1 - i2 : i2 - i1) == 1;
diff --git a/include/geos/noding/IntersectionFinderAdder.h b/include/geos/noding/IntersectionFinderAdder.h
index 4759b39..3f2225c 100644
--- a/include/geos/noding/IntersectionFinderAdder.h
+++ b/include/geos/noding/IntersectionFinderAdder.h
@@ -79,8 +79,8 @@ public:
* (e.g. by an disjoint envelope test).
std::vector<geom::Coordinate>& getInteriorIntersections() {
return interiorIntersections;
diff --git a/include/geos/noding/NodedSegmentString.h b/include/geos/noding/NodedSegmentString.h
index 426fc5c..52b02be 100644
--- a/include/geos/noding/NodedSegmentString.h
+++ b/include/geos/noding/NodedSegmentString.h
@@ -124,7 +124,7 @@ public:
if (nextSegIndex < size())
geom::Coordinate const& nextPt =
- getCoordinate(static_cast<unsigned int>(nextSegIndex));
+ getCoordinate(nextSegIndex);
// Normalize segment index if intPt falls on vertex
// The check for point equality is 2D only - Z values are ignored
@@ -143,12 +143,12 @@ public:
const SegmentNodeList& getNodeList() const;
@@ -164,7 +164,7 @@ public:
/** \brief
* Add {SegmentNode}s for one or both
@@ -172,7 +172,7 @@ public:
* intersection list.
- unsigned int segmentIndex, int geomIndex);
+ size_t segmentIndex, size_t geomIndex);
/** \brief
* Add an SegmentNode for intersection intIndex.
@@ -182,8 +182,8 @@ public:
* to use the higher of the two possible segmentIndexes
/** \brief
@@ -193,7 +193,7 @@ public:
void addIntersection(const geom::Coordinate& intPt,
- unsigned int segmentIndex);
+ size_t segmentIndex);
private:
diff --git a/include/geos/noding/NodingValidator.h b/include/geos/noding/NodingValidator.h
index 2d161af..0aad997 100644
--- a/include/geos/noding/NodingValidator.h
+++ b/include/geos/noding/NodingValidator.h
@@ -71,8 +71,8 @@ private:
const SegmentString& ss1);
void checkInteriorIntersections(
- const SegmentString& e0, unsigned int segIndex0,
- const SegmentString& e1, unsigned int segIndex1);
+ const SegmentString& e0, size_t segIndex0,
+ const SegmentString& e1, size_t segIndex1);
* Checks for intersections between an endpoint of a segment string
diff --git a/include/geos/noding/SegmentIntersectionDetector.h b/include/geos/noding/SegmentIntersectionDetector.h
index 3de7927..6905193 100644
--- a/include/geos/noding/SegmentIntersectionDetector.h
+++ b/include/geos/noding/SegmentIntersectionDetector.h
@@ -16,6 +16,7 @@
#ifndef GEOS_GEOM_PREP_SEGMENTINTERSECTIONDETECTOR_H
#define GEOS_GEOM_PREP_SEGMENTINTERSECTIONDETECTOR_H
+#include <cstddef>
#include <geos/noding/SegmentIntersector.h>
#include <geos/algorithm/LineIntersector.h>
#include <geos/geom/Coordinate.h>
@@ -160,8 +161,8 @@ public:
* this call for segment pairs which they have determined do not intersect
- void processIntersections( noding::SegmentString * e0, int segIndex0,
- noding::SegmentString * e1, int segIndex1 ) override;
+ void processIntersections( noding::SegmentString * e0, size_t segIndex0,
+ noding::SegmentString * e1, size_t segIndex1 ) override;
diff --git a/include/geos/noding/SegmentIntersector.h b/include/geos/noding/SegmentIntersector.h
index bd90d6d..f7d4535 100644
--- a/include/geos/noding/SegmentIntersector.h
+++ b/include/geos/noding/SegmentIntersector.h
@@ -15,6 +15,7 @@
#ifndef GEOS_NODING_SEGMENTINTERSECTOR_H
#define GEOS_NODING_SEGMENTINTERSECTOR_H
+#include <cstddef>
#include <geos/inline.h>
@@ -55,8 +56,8 @@ public:
* being intersected.
virtual void processIntersections(
- SegmentString* e1, int segIndex1)=0;
+ SegmentString* e1, size_t segIndex1) = 0;
* \brief
diff --git a/include/geos/noding/SegmentNode.h b/include/geos/noding/SegmentNode.h
index b321c7a..862230f 100644
--- a/include/geos/noding/SegmentNode.h
+++ b/include/geos/noding/SegmentNode.h
@@ -61,7 +61,7 @@ public:
geom::Coordinate coord;
/// the index of the containing line segment in the parent edge
/// Construct a node on the given NodedSegmentString
SegmentNode(const NodedSegmentString& ss,
const geom::Coordinate& nCoord,
- unsigned int nSegmentIndex, int nSegmentOctant);
+ size_t nSegmentIndex, int nSegmentOctant);
~SegmentNode() {}
diff --git a/include/geos/noding/SegmentString.h b/include/geos/noding/SegmentString.h
index b9f7c84..750490e 100644
--- a/include/geos/noding/SegmentString.h
+++ b/include/geos/noding/SegmentString.h
@@ -77,9 +77,9 @@ public:
void setData(const void* data) { context=data; }
- virtual unsigned int size() const=0;
+ virtual size_t size() const=0;
- virtual const geom::Coordinate& getCoordinate(unsigned int i) const=0;
+ virtual const geom::Coordinate& getCoordinate(size_t i) const=0;
/// \brief
/// Return a pointer to the CoordinateSequence associated
diff --git a/include/geos/noding/SingleInteriorIntersectionFinder.h b/include/geos/noding/SingleInteriorIntersectionFinder.h
index aa93b1f..8a3c6c4 100644
--- a/include/geos/noding/SingleInteriorIntersectionFinder.h
+++ b/include/geos/noding/SingleInteriorIntersectionFinder.h
@@ -99,8 +99,8 @@ public:
bool isDone() const override
diff --git a/include/geos/noding/snapround/MCIndexPointSnapper.h b/include/geos/noding/snapround/MCIndexPointSnapper.h
index 7ca4ceb..2153617 100644
--- a/include/geos/noding/snapround/MCIndexPointSnapper.h
+++ b/include/geos/noding/snapround/MCIndexPointSnapper.h
@@ -19,6 +19,7 @@
#ifndef GEOS_NODING_SNAPROUND_MCINDEXPOINTSNAPPER_H
#define GEOS_NODING_SNAPROUND_MCINDEXPOINTSNAPPER_H
+#include <cstddef>
@@ -68,7 +69,7 @@ public:
* @return <code>true</code> if a node was added for this pixel
bool snap(HotPixel& hotPixel, SegmentString* parentEdge,
- unsigned int vertexIndex);
+ size_t vertexIndex);
bool snap(HotPixel& hotPixel) {
return snap(hotPixel, nullptr, 0);
diff --git a/include/geos/operation/buffer/BufferInputLineSimplifier.h b/include/geos/operation/buffer/BufferInputLineSimplifier.h
index da6934e..00ad99f 100644
--- a/include/geos/operation/buffer/BufferInputLineSimplifier.h
+++ b/include/geos/operation/buffer/BufferInputLineSimplifier.h
@@ -122,11 +122,11 @@ private:
* @return the next non-deleted index, if any
* @return inputLine.size() if there are no more non-deleted indices
- unsigned int findNextNonDeletedIndex(unsigned int index) const;
+ size_t findNextNonDeletedIndex(size_t index) const;
std::unique_ptr<geom::CoordinateSequence> collapseLine() const;
- bool isDeletable(int i0, int i1, int i2, double distanceTol) const;
+ bool isDeletable(size_t i0, size_t i1, size_t i2, double distanceTol) const;
bool isShallowConcavity(const geom::Coordinate& p0,
const geom::Coordinate& p1,
@@ -148,7 +148,7 @@ private:
bool isShallowSampled(const geom::Coordinate& p0,
const geom::Coordinate& p2,
- int i0, int i2, double distanceTol) const;
+ size_t i0, size_t i2, double distanceTol) const;
bool isShallow(const geom::Coordinate& p0,
diff --git a/include/geos/operation/distance/GeometryLocation.h b/include/geos/operation/distance/GeometryLocation.h
index 26053f5..f787fd4 100644
--- a/include/geos/operation/distance/GeometryLocation.h
+++ b/include/geos/operation/distance/GeometryLocation.h
@@ -50,7 +50,8 @@ namespace distance { // geos::operation::distance
class GEOS_DLL GeometryLocation {
private:
const geom::Geometry *component;
- int segIndex;
+ size_t segIndex;
+ bool inside_area;
geom::Coordinate pt;
public:
/** \brief
@@ -72,7 +73,7 @@ public:
* @param pt the coordinate of the location
GeometryLocation(const geom::Geometry *component,
- int segIndex, const geom::Coordinate &pt);
+ size_t segIndex, const geom::Coordinate &pt);
/** \brief
* Constructs a GeometryLocation specifying a point inside an
@@ -97,7 +98,7 @@ public:
* @return the segment index for the location, or INSIDE_AREA
- int getSegmentIndex();
+ size_t getSegmentIndex();
* Returns the geom::Coordinate of this location.
diff --git a/include/geos/simplify/TaggedLineSegment.h b/include/geos/simplify/TaggedLineSegment.h
index 325f1b7..46bd2e5 100644
--- a/include/geos/simplify/TaggedLineSegment.h
+++ b/include/geos/simplify/TaggedLineSegment.h
@@ -59,7 +59,7 @@ public:
TaggedLineSegment(const geom::Coordinate& p0,
const geom::Geometry* parent,
- unsigned int index);
+ size_t index);
const geom::Coordinate& p1);
const geom::Geometry* getParent() const;
- unsigned int getIndex() const;
+ size_t getIndex() const;
private:
const geom::Geometry* parent;
- unsigned int index;
+ size_t index;
diff --git a/src/algorithm/CGAlgorithms.cpp b/src/algorithm/CGAlgorithms.cpp
index 29154ac..f425a1b 100644
--- a/src/algorithm/CGAlgorithms.cpp
+++ b/src/algorithm/CGAlgorithms.cpp
@@ -110,28 +110,28 @@ CGAlgorithms::isCCW(const CoordinateSequence* ring)
// find highest point
const Coordinate *hiPt=&ring->getAt(0);
- int hiIndex=0;
- for (std::size_t i=1; i<=nPts; ++i)
+ size_t hiIndex = 0;
+ for (std::size_t i = 1; i <= nPts; ++i)
const Coordinate *p=&ring->getAt(i);
if (p->y > hiPt->y) {
hiPt = p;
- hiIndex = static_cast<int>(i);
+ hiIndex = i;
// find distinct point before highest point
- int iPrev = hiIndex;
+ auto iPrev = hiIndex;
do {
+ if (iPrev == 0)
+ iPrev = nPts;
iPrev = iPrev - 1;
- if (iPrev < 0)
- iPrev = static_cast<int>(nPts);
- } while (ring->getAt(iPrev)==*hiPt && iPrev!=hiIndex);
+ } while (ring->getAt(iPrev) == *hiPt && iPrev != hiIndex);
// find distinct point after highest point
- int iNext = hiIndex;
+ auto iNext = hiIndex;
do {
- iNext = (iNext + 1) % static_cast<int>(nPts);
+ iNext = (iNext + 1) % nPts;
} while (ring->getAt(iNext)==*hiPt && iNext != hiIndex);
const Coordinate *prev=&ring->getAt(iPrev);
diff --git a/src/algorithm/LineIntersector.cpp b/src/algorithm/LineIntersector.cpp
index e9320fb..0ca981a 100644
--- a/src/algorithm/LineIntersector.cpp
+++ b/src/algorithm/LineIntersector.cpp
@@ -187,7 +187,7 @@ LineIntersector::computeIntLineIndex() {
bool
LineIntersector::isIntersection(const Coordinate& pt) const
- for (int i=0;i<result;i++) {
+ for (size_t i=0; i < result; ++i) {
if (intPt[i].equals2D(pt)) {
return true;
@@ -229,7 +229,7 @@ LineIntersector::computeIntLineIndex(int segmentIndex)
/*public*/
double
-LineIntersector::getEdgeDistance(int segmentIndex,int intIndex) const
+LineIntersector::getEdgeDistance(size_t segmentIndex,size_t intIndex) const
double dist=computeEdgeDistance(intPt[intIndex],
*inputLines[segmentIndex][0],
@@ -250,7 +250,7 @@ LineIntersector::isInteriorIntersection()
bool
LineIntersector::isInteriorIntersection(int inputLineIndex)
- for (int i=0; i<result; i++)
+ for (size_t i = 0; i < result; ++i)
if (!(intPt[i].equals2D(*inputLines[inputLineIndex][0])
|| intPt[i].equals2D(*inputLines[inputLineIndex][1])))
diff --git a/src/geom/CoordinateSequence.cpp b/src/geom/CoordinateSequence.cpp
index 948a6c1..c8893dc 100644
--- a/src/geom/CoordinateSequence.cpp
+++ b/src/geom/CoordinateSequence.cpp
@@ -105,19 +105,19 @@ CoordinateSequence::minCoordinate(CoordinateSequence *cl)
return minCoord;
-int
+size_t
CoordinateSequence::indexOf(const Coordinate *coordinate,
- size_t size=cl->getSize();
- for (size_t i=0; i<size; ++i)
+ size_t size = cl->size();
+ for (size_t i=0; i < size; ++i)
if ((*coordinate)==cl->getAt(i))
- return static_cast<int>(i); // FIXME: what if we overflow the int ?
+ return i;
- return -1;
+ return std::numeric_limits<std::size_t>::max();
void
@@ -161,9 +161,9 @@ CoordinateSequence::reverse(CoordinateSequence *cl)
// FIXME: use a standard algorithm
- int last = static_cast<int>(cl->getSize()) - 1;
- int mid=last/2;
- for(int i=0;i<=mid;i++) {
+ auto last = cl->size() - 1;
+ auto mid = last / 2;
+ for(size_t i=0; i <= mid; i++) {
const Coordinate tmp=cl->getAt(i);
cl->setAt(cl->getAt(last-i),i);
cl->setAt(tmp,last-i);
@@ -227,14 +227,14 @@ CoordinateSequence::add(const CoordinateSequence *cl,
// FIXME: don't rely on negative values for 'j' (the reverse case)
- const int npts = static_cast<int>(cl->getSize());
+ const auto npts = cl->size();
if (direction) {
- for (int i=0; i<npts; i++) {
+ for (size_t i = 0; i < npts; ++i) {
add(cl->getAt(i), allowRepeated);
} else {
- for (int j=npts-1; j>=0; j--) {
- add(cl->getAt(j), allowRepeated);
+ for (auto j = npts; j > 0; --j) {
+ add(cl->getAt(j - 1), allowRepeated);
diff --git a/src/geom/IntersectionMatrix.cpp b/src/geom/IntersectionMatrix.cpp
index 824e9ba..9c391ec 100644
--- a/src/geom/IntersectionMatrix.cpp
+++ b/src/geom/IntersectionMatrix.cpp
@@ -158,22 +158,22 @@ IntersectionMatrix::set(int row, int col, int dimensionValue)
void
IntersectionMatrix::set(const string& dimensionSymbols)
- size_t limit = dimensionSymbols.length();
+ auto limit = dimensionSymbols.length();
- for (int i = 0; i < static_cast<int>(limit); i++)
+ for (size_t i = 0; i < limit; i++)
- int row = i / firstDim;
- int col = i % secondDim;
+ auto row = i / firstDim;
+ auto col = i % secondDim;
matrix[row][col] = Dimension::toDimensionValue(dimensionSymbols[i]);
/*public*/
void
-IntersectionMatrix::setAtLeast(int row, int col, int minimumDimensionValue)
+IntersectionMatrix::setAtLeast(size_t row, size_t col, int minimumDimensionValue)
- assert( row >= 0 && row < firstDim );
- assert( col >= 0 && col < secondDim );
+ assert( row < firstDim );
+ assert( col < secondDim );
if (matrix[row][col] < minimumDimensionValue)
@@ -198,12 +198,12 @@ IntersectionMatrix::setAtLeastIfValid(int row, int col, int minimumDimensionValu
void
IntersectionMatrix::setAtLeast(string minimumDimensionSymbols)
- size_t limit = minimumDimensionSymbols.length();
+ auto limit = minimumDimensionSymbols.length();
setAtLeast(row, col, Dimension::toDimensionValue(minimumDimensionSymbols[i]));
diff --git a/src/geom/LineString.cpp b/src/geom/LineString.cpp
index 0b1bcfb..244fd5d 100644
--- a/src/geom/LineString.cpp
+++ b/src/geom/LineString.cpp
@@ -127,7 +127,7 @@ LineString::getCoordinatesRO() const
const Coordinate&
-LineString::getCoordinateN(int n) const
+LineString::getCoordinateN(size_t n) const
assert(points.get());
return points->getAt(n);
@@ -202,7 +202,7 @@ LineString::isClosed() const
if (isEmpty()) {
return false;
- return getCoordinateN(0).equals2D(getCoordinateN(static_cast<int>(getNumPoints()-1)));
+ return getCoordinateN(0).equals2D(getCoordinateN(getNumPoints() - 1));
bool
diff --git a/src/geom/MultiPoint.cpp b/src/geom/MultiPoint.cpp
index 4d1fe92..f20af5b 100644
--- a/src/geom/MultiPoint.cpp
+++ b/src/geom/MultiPoint.cpp
@@ -68,7 +68,7 @@ MultiPoint::equalsExact(const Geometry *other, double tolerance) const
return GeometryCollection::equalsExact(other,tolerance);
-const Coordinate* MultiPoint::getCoordinateN(int n) const {
+const Coordinate* MultiPoint::getCoordinateN(size_t n) const {
return ((*geometries)[n])->getCoordinate();
GeometryTypeId
diff --git a/src/geom/util/GeometryTransformer.cpp b/src/geom/util/GeometryTransformer.cpp
index 87735b2..94b079c 100644
--- a/src/geom/util/GeometryTransformer.cpp
+++ b/src/geom/util/GeometryTransformer.cpp
@@ -159,7 +159,7 @@ GeometryTransformer::transformMultiPoint(
vector<Geometry*>* transGeomList = new vector<Geometry*>();
- for (unsigned int i=0, n=static_cast<unsigned int>(geom->getNumGeometries()); i<n; i++)
+ for (size_t i = 0, n = geom->getNumGeometries(); i < n; i++)
const Point* p = dynamic_cast<const Point*>(geom->getGeometryN(i));
assert(p);
@@ -232,7 +232,7 @@ GeometryTransformer::transformMultiLineString(
const LineString* l = dynamic_cast<const LineString*>(
@@ -276,7 +276,7 @@ GeometryTransformer::transformPolygon(
vector<Geometry*>* holes = new vector<Geometry*>();
- for (unsigned int i=0, n=static_cast<unsigned int>(geom->getNumInteriorRing()); i<n; i++)
+ for (size_t i = 0, n = geom->getNumInteriorRing(); i<n; i++)
const LinearRing* lr = dynamic_cast<const LinearRing*>(
geom->getInteriorRingN(i));
diff --git a/src/geomgraph/DirectedEdge.cpp b/src/geomgraph/DirectedEdge.cpp
index 8e97aff..0a4bc62 100644
--- a/src/geomgraph/DirectedEdge.cpp
+++ b/src/geomgraph/DirectedEdge.cpp
@@ -92,7 +92,7 @@ DirectedEdge::DirectedEdge(Edge *newEdge, bool newIsForward):
if (isForwardVar) {
init(edge->getCoordinate(0), edge->getCoordinate(1));
} else {
- int n=edge->getNumPoints()-1;
+ auto n = edge->getNumPoints() - 1;
init(edge->getCoordinate(n), edge->getCoordinate(n-1));
computeDirectedLabel();
diff --git a/src/geomgraph/Edge.cpp b/src/geomgraph/Edge.cpp
index 91126ee..38ebd85 100644
--- a/src/geomgraph/Edge.cpp
+++ b/src/geomgraph/Edge.cpp
@@ -131,8 +131,8 @@ Edge::isCollapsed() const
testInvariant();
if (!label.isArea()) return false;
- if (getNumPoints()!= 3) return false;
- if (pts->getAt(0)==pts->getAt(2) ) return true;
+ if (getNumPoints() != 3) return false;
+ if (pts->getAt(0) == pts->getAt(2)) return true;
return false;
@@ -148,12 +148,12 @@ Edge::getCollapsedEdge()
/*public*/
void
-Edge::addIntersections(LineIntersector *li, int segmentIndex, int geomIndex)
+Edge::addIntersections(LineIntersector *li, size_t segmentIndex, size_t geomIndex)
#if GEOS_DEBUG
cerr<<"["<<this<<"] Edge::addIntersections("<<li->toString()<<", "<<segmentIndex<<", "<<geomIndex<<") called"<<endl;
#endif
- for (int i=0; i<li->getIntersectionNum();i++) {
+ for (size_t i = 0; i < li->getIntersectionNum(); ++i) {
addIntersection(li,segmentIndex,geomIndex,i);
@@ -163,19 +163,19 @@ Edge::addIntersections(LineIntersector *li, int segmentIndex, int geomIndex)
/*public*/
void
Edge::addIntersection(LineIntersector *li,
- int segmentIndex, int geomIndex, int intIndex)
+ size_t segmentIndex, size_t geomIndex, size_t intIndex)
#if GEOS_DEBUG
std::cerr << "["<<this<<"] Edge::addIntersection("<<li->toString()<<", "<<segmentIndex<<", "<<geomIndex<<", "<<intIndex<<") called"<< std::endl;
#endif
const Coordinate& intPt=li->getIntersection(intIndex);
- unsigned int normalizedSegmentIndex=segmentIndex;
- double dist=li->getEdgeDistance(geomIndex,intIndex);
+ auto normalizedSegmentIndex = segmentIndex;
+ double dist = li->getEdgeDistance(geomIndex, intIndex);
// normalize the intersection point location
- unsigned int nextSegIndex=normalizedSegmentIndex+1;
- unsigned int npts=getNumPoints();
- if (nextSegIndex<npts)
+ auto nextSegIndex = normalizedSegmentIndex + 1;
+ auto npts = getNumPoints();
+ if (nextSegIndex < npts)
const Coordinate& nextPt=pts->getAt(nextSegIndex);
@@ -203,15 +203,15 @@ Edge::equals(const Edge& e) const
testInvariant();
- unsigned int npts1=getNumPoints();
- unsigned int npts2=e.getNumPoints();
+ auto npts1 = getNumPoints();
+ auto npts2 = e.getNumPoints();
if (npts1 != npts2 ) return false;
bool isEqualForward=true;
bool isEqualReverse=true;
- for (unsigned int i=0, iRev=npts1-1; i<npts1; ++i, --iRev)
+ for (size_t i = 0, iRev = npts1 - 1; i < npts1; ++i, --iRev)
const Coordinate &e1pi=pts->getAt(i);
const Coordinate &e2pi=e.pts->getAt(i);
@@ -233,8 +233,8 @@ Edge::isPointwiseEqual(const Edge *e) const
#if GEOS_DEBUG > 2
cerr<<"Edge::isPointwiseEqual call"<<endl;
#endif
- unsigned int enpts=e->getNumPoints();
+ auto enpts = e->getNumPoints();
if (npts!=enpts) return false;
#if GEOS_DEBUG
cerr<<"Edge::isPointwiseEqual scanning "<<enpts<<"x"<<npts<<" points"<<endl;
@@ -273,8 +273,8 @@ Edge::printReverse() const
<< " depthDelta:" << depthDelta
<< ":" << std::endl
<< " LINESTRING(";
- for (unsigned int i=npts; i>0; --i)
+ auto npts=getNumPoints();
+ for (auto i=npts; i>0; --i)
if (i<npts) os << ", ";
os << pts->getAt(i-1).toString();
@@ -291,8 +291,8 @@ Edge::getEnvelope()
if (env==nullptr)
env=new Envelope();
- for (unsigned int i = 0; i<npts; ++i)
env->expandToInclude(pts->getAt(i));
diff --git a/src/geomgraph/EdgeIntersectionList.cpp b/src/geomgraph/EdgeIntersectionList.cpp
index 6f0f09d..cc41ed7 100644
--- a/src/geomgraph/EdgeIntersectionList.cpp
+++ b/src/geomgraph/EdgeIntersectionList.cpp
@@ -63,7 +63,7 @@ EdgeIntersectionList::~EdgeIntersectionList()
EdgeIntersection*
EdgeIntersectionList::add(const Coordinate& coord,
EdgeIntersection *eiNew=new EdgeIntersection(coord, segmentIndex, dist);
@@ -100,7 +100,7 @@ EdgeIntersectionList::isIntersection(const Coordinate& pt) const
void
EdgeIntersectionList::addEndpoints()
- int maxSegIndex=edge->getNumPoints()-1;
+ auto maxSegIndex = edge->getNumPoints() - 1;
add(edge->pts->getAt(0), 0, 0.0);
add(edge->pts->getAt(maxSegIndex), maxSegIndex, 0.0);
@@ -134,7 +134,7 @@ EdgeIntersectionList::createSplitEdge(EdgeIntersection *ei0,
#if GEOS_DEBUG
cerr<<"["<<this<<"] EdgeIntersectionList::createSplitEdge()"<<endl;
#endif // GEOS_DEBUG
- int npts=ei1->segmentIndex-ei0->segmentIndex+2;
+ auto npts = ei1->segmentIndex - ei0->segmentIndex + 2;
const Coordinate& lastSegStartPt=edge->pts->getAt(ei1->segmentIndex);
@@ -155,7 +155,7 @@ EdgeIntersectionList::createSplitEdge(EdgeIntersection *ei0,
vc->reserve(npts);
vc->push_back(ei0->coord);
- for(int i=ei0->segmentIndex+1; i<=ei1->segmentIndex;i++)
+ for(auto i = ei0->segmentIndex + 1; i <= ei1->segmentIndex; ++i)
if ( ! useIntPt1 && ei1->segmentIndex == i )
diff --git a/src/geomgraph/index/MonotoneChainEdge.cpp b/src/geomgraph/index/MonotoneChainEdge.cpp
index 8d28c6d..e86ac28 100644
--- a/src/geomgraph/index/MonotoneChainEdge.cpp
+++ b/src/geomgraph/index/MonotoneChainEdge.cpp
@@ -69,14 +69,14 @@ MonotoneChainEdge::getCoordinates()
return pts;
-vector<int> &
+vector<size_t> &
MonotoneChainEdge::getStartIndexes()
return startIndex;
double
-MonotoneChainEdge::getMinX(int chainIndex)
+MonotoneChainEdge::getMinX(size_t chainIndex)
double x1=pts->getAt(startIndex[chainIndex]).x;
double x2=pts->getAt(startIndex[chainIndex+1]).x;
@@ -84,7 +84,7 @@ MonotoneChainEdge::getMinX(int chainIndex)
double
-MonotoneChainEdge::getMaxX(int chainIndex)
+MonotoneChainEdge::getMaxX(size_t chainIndex)
@@ -101,14 +101,14 @@ MonotoneChainEdge::computeIntersects(const MonotoneChainEdge &mce,
for(size_t j=0; j<J; ++j)
- computeIntersectsForChain(static_cast<int>(i),mce,static_cast<int>(j),si);
+ computeIntersectsForChain(i, mce, j, si);
void
-MonotoneChainEdge::computeIntersectsForChain(int chainIndex0,
+MonotoneChainEdge::computeIntersectsForChain(size_t chainIndex0,
computeIntersectsForChain(startIndex[chainIndex0],
@@ -119,8 +119,8 @@ MonotoneChainEdge::computeIntersectsForChain(int chainIndex0,
void
-MonotoneChainEdge::computeIntersectsForChain(int start0, int end0,
- const MonotoneChainEdge &mce, int start1, int end1,
+MonotoneChainEdge::computeIntersectsForChain(size_t start0, size_t end0,
+ const MonotoneChainEdge &mce, size_t start1, size_t end1,
// terminating condition for the recursion
@@ -141,8 +141,8 @@ MonotoneChainEdge::computeIntersectsForChain(int start0, int end0,
if (!env1.intersects(&env2)) return;
// the chains overlap, so split each in half and iterate
// (binary search)
- int mid0=(start0+end0)/2;
- int mid1=(start1+end1)/2;
+ size_t mid0 = (start0 + end0) / 2;
+ size_t mid1 = (start1 + end1) / 2;
// Assert: mid != start or end
// (since we checked above for end - start <= 1)
diff --git a/src/geomgraph/index/MonotoneChainIndexer.cpp b/src/geomgraph/index/MonotoneChainIndexer.cpp
index f1598e6..54e5b82 100644
--- a/src/geomgraph/index/MonotoneChainIndexer.cpp
+++ b/src/geomgraph/index/MonotoneChainIndexer.cpp
@@ -29,18 +29,18 @@ namespace index { // geos.geomgraph.index
void
MonotoneChainIndexer::getChainStartIndices(const CoordinateSequence* pts,
- vector<int> &startIndexList)
+ vector<size_t> &startIndexList)
// find the startpoint (and endpoints) of all monotone chains
// in this edge
- int start=0;
+ size_t start=0;
//vector<int>* startIndexList=new vector<int>();
startIndexList.push_back(start);
do {
- int last=findChainEnd(pts,start);
+ auto last = findChainEnd(pts, start);
startIndexList.push_back(last);
- start=last;
- } while(start<(int)pts->getSize()-1);
+ start = last;
+ } while(start < pts->size() - 1);
// copy list to an array of ints, for efficiency
//return startIndexList;
@@ -48,17 +48,17 @@ MonotoneChainIndexer::getChainStartIndices(const CoordinateSequence* pts,
* @return the index of the last point in the monotone chain
-int MonotoneChainIndexer::findChainEnd(const CoordinateSequence* pts,int start){
+size_t MonotoneChainIndexer::findChainEnd(const CoordinateSequence* pts, size_t start){
// determine quadrant for chain
- int chainQuad=Quadrant::quadrant(pts->getAt(start),pts->getAt(start + 1));
- int last=start+1;
- while(last<(int)pts->getSize()) {
+ auto chainQuad = Quadrant::quadrant(pts->getAt(start), pts->getAt(start + 1));
+ auto last = start + 1;
+ while(last < pts->size()) {
// compute quadrant for next possible segment in chain
- int quad=Quadrant::quadrant(pts->getAt(last - 1),pts->getAt(last));
+ auto quad=Quadrant::quadrant(pts->getAt(last - 1),pts->getAt(last));
if (quad!=chainQuad) break;
- last++;
+ ++last;
- return last-1;
+ return last - 1;
} // namespace geos.geomgraph.index
diff --git a/src/geomgraph/index/SegmentIntersector.cpp b/src/geomgraph/index/SegmentIntersector.cpp
index f728002..0e49b5f 100644
--- a/src/geomgraph/index/SegmentIntersector.cpp
+++ b/src/geomgraph/index/SegmentIntersector.cpp
@@ -44,9 +44,9 @@ namespace index { // geos.geomgraph.index
using namespace geos::algorithm;
bool
-SegmentIntersector::isAdjacentSegments(int i1,int i2)
+SegmentIntersector::isAdjacentSegments(size_t i1, size_t i2)
- return abs(i1-i2)==1;
void
@@ -115,7 +115,9 @@ SegmentIntersector::hasProperInteriorIntersection()
bool
-SegmentIntersector::isTrivialIntersection(Edge *e0,int segIndex0,Edge *e1,int segIndex1)
+SegmentIntersector::isTrivialIntersection(Edge *e0,
+ size_t segIndex0,Edge *e1,
+ size_t segIndex1)
// if (e0->equals(e1))
if (e0==e1) {
@@ -123,7 +125,7 @@ SegmentIntersector::isTrivialIntersection(Edge *e0,int segIndex0,Edge *e1,int se
if (isAdjacentSegments(segIndex0,segIndex1))
return true;
if (e0->isClosed()) {
- int maxSegIndex=e0->getNumPoints()-1;
+ auto maxSegIndex = e0->getNumPoints() - 1;
if ((segIndex0==0 && segIndex1==maxSegIndex)
|| (segIndex1==0 && segIndex0==maxSegIndex)) {
return true;
@@ -141,7 +143,7 @@ SegmentIntersector::isTrivialIntersection(Edge *e0,int segIndex0,Edge *e1,int se
* certain pairs of segments for efficiency reasons.
void
-SegmentIntersector::addIntersections(Edge *e0,int segIndex0,Edge *e1,int segIndex1)
+SegmentIntersector::addIntersections(Edge *e0, size_t segIndex0, Edge *e1, size_t segIndex1)
#if GEOS_DEBUG
diff --git a/src/geomgraph/index/SimpleEdgeSetIntersector.cpp b/src/geomgraph/index/SimpleEdgeSetIntersector.cpp
index f15f7d1..7ebdf20 100644
--- a/src/geomgraph/index/SimpleEdgeSetIntersector.cpp
+++ b/src/geomgraph/index/SimpleEdgeSetIntersector.cpp
@@ -83,12 +83,12 @@ SimpleEdgeSetIntersector::computeIntersects(Edge *e0, Edge *e1,
const CoordinateSequence *pts0=e0->getCoordinates();
const CoordinateSequence *pts1=e1->getCoordinates();
- auto npts0 = static_cast<int>(pts0->getSize());
- auto npts1 = static_cast<int>(pts1->getSize());
+ auto npts0 = pts0->size();
+ auto npts1 = pts1->size();
- for(int i0=0; i0<npts0-1; ++i0)
+ for(size_t i0 = 0; i0 < npts0 - 1; ++i0)
- for(int i1=0; i1<npts1-1; ++i1)
+ for(size_t i1 = 0; i1<npts1 - 1; ++i1)
si->addIntersections(e0, i0, e1, i1);
diff --git a/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp b/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp
index 66f1f9b..2cd5bdb 100644
--- a/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp
+++ b/src/geomgraph/index/SimpleMCSweepLineIntersector.cpp
@@ -89,16 +89,16 @@ void
SimpleMCSweepLineIntersector::add(Edge *edge, void* edgeSet)
MonotoneChainEdge *mce=edge->getMonotoneChainEdge();
- vector<int> &startIndex=mce->getStartIndexes();
- size_t n = startIndex.size()-1;
+ auto& startIndex = mce->getStartIndexes();
+ size_t n = startIndex.size() - 1;
events.reserve(events.size()+(n*2));
- for(size_t i=0; i<n; ++i)
+ for(size_t i = 0; i < n; ++i)
GEOS_CHECK_FOR_INTERRUPTS();
- MonotoneChain *mc=new MonotoneChain(mce, static_cast<int>(i));
- SweepLineEvent *insertEvent=new SweepLineEvent(edgeSet,mce->getMinX(static_cast<int>(i)),nullptr,mc);
+ MonotoneChain *mc=new MonotoneChain(mce, i);
+ SweepLineEvent *insertEvent=new SweepLineEvent(edgeSet, mce->getMinX(i), nullptr, mc);
events.push_back(insertEvent);
- events.push_back(new SweepLineEvent(edgeSet,mce->getMaxX(static_cast<int>(i)),insertEvent,mc));
+ events.push_back(new SweepLineEvent(edgeSet, mce->getMaxX(i), insertEvent, mc));
@@ -117,7 +117,7 @@ SimpleMCSweepLineIntersector::prepareEvents()
SweepLineEvent *ev=events[i];
if (ev->isDelete())
- ev->getInsertEvent()->setDeleteEventIndex(static_cast<int>(i));
+ ev->getInsertEvent()->setDeleteEventIndex(i);
@@ -133,7 +133,7 @@ SimpleMCSweepLineIntersector::computeIntersections(SegmentIntersector *si)
if (ev->isInsert())
- processOverlaps(static_cast<int>(i),ev->getDeleteEventIndex(),ev,si);
+ processOverlaps(i, ev->getDeleteEventIndex(), ev, si);
if (si->getIsDone())
@@ -143,7 +143,7 @@ SimpleMCSweepLineIntersector::computeIntersections(SegmentIntersector *si)
void
-SimpleMCSweepLineIntersector::processOverlaps(int start, int end,
+SimpleMCSweepLineIntersector::processOverlaps(size_t start, size_t end,
SweepLineEvent *ev0, SegmentIntersector *si)
MonotoneChain *mc0=(MonotoneChain*) ev0->getObject();
@@ -153,7 +153,7 @@ SimpleMCSweepLineIntersector::processOverlaps(int start, int end,
* include current insert event object in list of event objects to test.
* Last index can be skipped, because it must be a Delete event.
- for(int i=start; i<end; ++i)
+ for(auto i = start; i < end; ++i)
SweepLineEvent *ev1=events[i];
if (ev1->isInsert())
diff --git a/src/geomgraph/index/SimpleSweepLineIntersector.cpp b/src/geomgraph/index/SimpleSweepLineIntersector.cpp
index c785c36..6893d35 100644
--- a/src/geomgraph/index/SimpleSweepLineIntersector.cpp
+++ b/src/geomgraph/index/SimpleSweepLineIntersector.cpp
@@ -89,7 +89,7 @@ SimpleSweepLineIntersector::add(Edge *edge, void* edgeSet)
std::size_t n=pts->getSize()-1;
for(std::size_t i=0; i<n; ++i)
- SweepLineSegment *ss=new SweepLineSegment(edge, static_cast<int>(i));
+ SweepLineSegment *ss=new SweepLineSegment(edge, i);
SweepLineEvent *insertEvent=new SweepLineEvent(edgeSet, ss->getMinX(), nullptr, ss);
events.push_back(new SweepLineEvent(edgeSet, ss->getMaxX(), insertEvent, ss));
@@ -131,7 +131,7 @@ SimpleSweepLineIntersector::computeIntersections(SegmentIntersector *si)
void
-SimpleSweepLineIntersector::processOverlaps(int start,int end,SweepLineEvent *ev0,
+SimpleSweepLineIntersector::processOverlaps(size_t start, size_t end,SweepLineEvent *ev0,
@@ -142,7 +142,7 @@ SimpleSweepLineIntersector::processOverlaps(int start,int end,SweepLineEvent *ev
diff --git a/src/geomgraph/index/SweepLineSegment.cpp b/src/geomgraph/index/SweepLineSegment.cpp
index e389f06..2a72b70 100644
--- a/src/geomgraph/index/SweepLineSegment.cpp
+++ b/src/geomgraph/index/SweepLineSegment.cpp
@@ -25,7 +25,7 @@ namespace geos {
namespace geomgraph { // geos.geomgraph
-SweepLineSegment::SweepLineSegment(Edge *newEdge, int newPtIndex):
+SweepLineSegment::SweepLineSegment(Edge *newEdge, size_t newPtIndex):
edge(newEdge),
pts(newEdge->getCoordinates()),
ptIndex(newPtIndex)
diff --git a/src/index/chain/MonotoneChain.cpp b/src/index/chain/MonotoneChain.cpp
index ea2232d..3a9e689 100644
--- a/src/index/chain/MonotoneChain.cpp
+++ b/src/index/chain/MonotoneChain.cpp
@@ -92,14 +92,14 @@ MonotoneChain::computeSelect(const Envelope& searchEnv,
if(end0-start0==1)
//Debug.println("computeSelect:"+p0+p1);
- mcs.select(*this, static_cast<unsigned int>(start0));
+ mcs.select(*this, start0);
return;
// nothing to do if the envelopes don't overlap
if (!searchEnv.intersects(mcs.tempEnv1))
return;
// the chains overlap,so split each in half and iterate (binary search)
- unsigned int mid= static_cast<unsigned int>((start0 + end0) / 2);
+ size_t mid = (start0 + end0) / 2;
// Assert: mid != start or end (since we checked above for end-start <= 1)
// check terminating conditions before recursing
diff --git a/src/index/chain/MonotoneChainSelectAction.cpp b/src/index/chain/MonotoneChainSelectAction.cpp
index 66ace46..ac505a1 100644
--- a/src/index/chain/MonotoneChainSelectAction.cpp
+++ b/src/index/chain/MonotoneChainSelectAction.cpp
@@ -28,7 +28,7 @@ namespace index { // geos.index
namespace chain { // geos.index.chain
void
-MonotoneChainSelectAction::select(MonotoneChain& mc, unsigned int start)
+MonotoneChainSelectAction::select(MonotoneChain& mc, size_t start)
mc.getLineSegment(start, selectedSegment);
diff --git a/src/index/quadtree/NodeBase.cpp b/src/index/quadtree/NodeBase.cpp
index a492046..5d2a841 100644
--- a/src/index/quadtree/NodeBase.cpp
+++ b/src/index/quadtree/NodeBase.cpp
@@ -151,10 +151,10 @@ NodeBase::depth() const
return maxSubDepth + 1;
-unsigned int
+size_t
NodeBase::size() const
- unsigned int subSize=0;
+ size_t subSize = 0;
for(int i=0; i<4; i++)
if (subnode[i] != nullptr)
@@ -162,13 +162,13 @@ NodeBase::size() const
subSize += subnode[i]->size();
- return subSize + static_cast<unsigned int>(items.size());
+ return subSize + items.size();
-unsigned int
+size_t
NodeBase::getNodeCount() const
for(int i=0; i<4; ++i)
diff --git a/src/index/quadtree/Quadtree.cpp b/src/index/quadtree/Quadtree.cpp
index a58bdcf..e8e02ef 100644
--- a/src/index/quadtree/Quadtree.cpp
+++ b/src/index/quadtree/Quadtree.cpp
@@ -80,7 +80,7 @@ Quadtree::depth()
/*public*/
-int
+size_t
Quadtree::size()
return root.size();
diff --git a/src/index/strtree/AbstractNode.cpp b/src/index/strtree/AbstractNode.cpp
index 4000231..f0d64d9 100644
--- a/src/index/strtree/AbstractNode.cpp
+++ b/src/index/strtree/AbstractNode.cpp
@@ -30,7 +30,7 @@ namespace strtree { // geos.index.strtree
* @param level 0 if this node is a leaf, 1 if a parent of a leaf, and so on;
* the root node will have the highest level
-AbstractNode::AbstractNode(int newLevel, int capacity) {
+AbstractNode::AbstractNode(int newLevel, size_t capacity) {
childBoundables.reserve(capacity);
bounds=nullptr;
level=newLevel;
diff --git a/src/index/strtree/SIRtree.cpp b/src/index/strtree/SIRtree.cpp
index b5a2cbd..3ba538f 100644
--- a/src/index/strtree/SIRtree.cpp
+++ b/src/index/strtree/SIRtree.cpp
@@ -86,7 +86,7 @@ SIRtree::~SIRtree() {
class SIRAbstractNode: public AbstractNode {
public:
- SIRAbstractNode(int level, int capacity)
+ SIRAbstractNode(int level, size_t capacity)
AbstractNode(level, capacity)
@@ -119,7 +119,7 @@ protected:
AbstractNode*
SIRtree::createNode(int level)
- AbstractNode *an = new SIRAbstractNode(level, static_cast<int>(nodeCapacity));
+ AbstractNode *an = new SIRAbstractNode(level, nodeCapacity);
nodes->push_back(an);
return an;
diff --git a/src/index/strtree/STRtree.cpp b/src/index/strtree/STRtree.cpp
index b9f5e68..59d808c 100644
--- a/src/index/strtree/STRtree.cpp
+++ b/src/index/strtree/STRtree.cpp
@@ -277,7 +277,7 @@ std::pair<const void*, const void*> STRtree::nearestNeighbour(BoundablePair* ini
class STRAbstractNode: public AbstractNode{
public:
- STRAbstractNode(int level, int capacity)
+ STRAbstractNode(int level, size_t capacity)
@@ -314,7 +314,7 @@ protected:
AbstractNode*
STRtree::createNode(int level)
- AbstractNode *an = new STRAbstractNode(level, static_cast<int>(nodeCapacity));
+ AbstractNode *an = new STRAbstractNode(level, nodeCapacity);
return an;
diff --git a/src/index/sweepline/SweepLineEvent.cpp b/src/index/sweepline/SweepLineEvent.cpp
index f0c1b20..6e9aeb9 100644
--- a/src/index/sweepline/SweepLineEvent.cpp
+++ b/src/index/sweepline/SweepLineEvent.cpp
@@ -49,14 +49,14 @@ SweepLineEvent::getInsertEvent()
return insertEvent;
-int
+size_t
SweepLineEvent::getDeleteEventIndex()
void
-SweepLineEvent::setDeleteEventIndex(int newDeleteEventIndex)
+SweepLineEvent::setDeleteEventIndex(size_t newDeleteEventIndex)
diff --git a/src/index/sweepline/SweepLineIndex.cpp b/src/index/sweepline/SweepLineIndex.cpp
index 89037da..33db463 100644
--- a/src/index/sweepline/SweepLineIndex.cpp
+++ b/src/index/sweepline/SweepLineIndex.cpp
@@ -62,7 +62,7 @@ SweepLineIndex::buildIndex()
if (ev->isDelete())
indexBuilt = true;
@@ -77,12 +77,12 @@ SweepLineIndex::computeOverlaps(SweepLineOverlapAction *action)
buildIndex();
const std::vector<SweepLineEvent*>::size_type n=events.size();
- for(std::vector<SweepLineEvent*>::size_type i=0; i<n; i++)
+ for(size_t i = 0; i < n; i++)
if (ev->isInsert())
ev->getInterval(), action);
@@ -90,7 +90,7 @@ SweepLineIndex::computeOverlaps(SweepLineOverlapAction *action)
void
-SweepLineIndex::processOverlaps(int start, int end,
+SweepLineIndex::processOverlaps(size_t start, size_t end,
SweepLineInterval *s0, SweepLineOverlapAction *action)
@@ -98,7 +98,7 @@ SweepLineIndex::processOverlaps(int start, int end,
- for(int i=start; i<end; i++)
+ for(auto i = start; i < end; i++)
if (ev->isInsert()) {
diff --git a/src/io/WKBWriter.cpp b/src/io/WKBWriter.cpp
index 72c0aa8..dbc0d4c 100644
--- a/src/io/WKBWriter.cpp
+++ b/src/io/WKBWriter.cpp
@@ -283,11 +283,11 @@ WKBWriter::writeCoordinateSequence(const CoordinateSequence &cs,
if ( outputDimension > 2) is3d = true;
if (sized) writeInt(static_cast<int>(size));
- for (std::size_t i=0; i<size; i++) writeCoordinate(cs, static_cast<int>(i), is3d);
+ for (std::size_t i = 0; i < size; i++) writeCoordinate(cs, i, is3d);
void
-WKBWriter::writeCoordinate(const CoordinateSequence &cs, int idx,
+WKBWriter::writeCoordinate(const CoordinateSequence &cs, size_t idx,
bool is3d)
#if DEBUG_WKB_WRITER
diff --git a/src/io/WKTWriter.cpp b/src/io/WKTWriter.cpp
index fae7135..a5cf1b0 100644
--- a/src/io/WKTWriter.cpp
+++ b/src/io/WKTWriter.cpp
@@ -77,7 +77,7 @@ WKTWriter::toLineString(const CoordinateSequence& seq)
stringstream buf(ios_base::in|ios_base::out);
buf << "LINESTRING ";
- unsigned int npts = static_cast<unsigned int>(seq.getSize());
+ auto npts = seq.size();
if ( npts == 0 )
buf << "EMPTY";
@@ -85,7 +85,7 @@ WKTWriter::toLineString(const CoordinateSequence& seq)
else
buf << "(";
- for (unsigned int i=0; i<npts; ++i)
if (i) buf << ", ";
buf << seq.getX(i) << " " << seq.getY(i);
@@ -360,7 +360,7 @@ WKTWriter::appendLineStringText(const LineString *lineString, int level,
writer->write(", ");
if (i%10==0) indent(level + 2, writer);
- appendCoordinate(&(lineString->getCoordinateN(static_cast<int>(i))), writer);
+ appendCoordinate(&(lineString->getCoordinateN(i)), writer);
writer->write(")");
@@ -394,13 +394,11 @@ WKTWriter::appendMultiPointText(const MultiPoint *multiPoint,
writer->write("EMPTY");
} else {
writer->write("(");
- for (unsigned int i=0, n=static_cast<unsigned int>(multiPoint->getNumGeometries());
- i<n; i++)
+ for (size_t i = 0, n = multiPoint->getNumGeometries();
+ i < n; ++i)
- if (i > 0)
- writer->write(", ");
+ if (i > 0) writer->write(", ");
appendCoordinate(
dynamic_cast<const Point*>(multiPoint->getGeometryN(i))->getCoordinate(),
writer);
@@ -417,8 +415,8 @@ void WKTWriter::appendMultiLineStringText(const MultiLineString *multiLineString
int level2=level;
bool doIndent=indentFirst;
writer->write("(");
- for (unsigned int i=0, n=static_cast<unsigned int>(multiLineString->getNumGeometries());
- i<n; i++)
+ for (size_t i = 0, n = multiLineString->getNumGeometries();
+ i < n; ++i)
if (i>0) {
@@ -441,8 +439,8 @@ void WKTWriter::appendMultiPolygonText(const MultiPolygon *multiPolygon, int lev
int level2=level;
bool doIndent=false;
writer->write("(");
- for (unsigned int i=0, n=static_cast<unsigned int>(multiPolygon->getNumGeometries());
- i < n; i++)
+ for (size_t i = 0, n = multiPolygon->getNumGeometries();
+ i < n; ++i)
if (i>0) {
@@ -469,8 +467,8 @@ WKTWriter::appendGeometryCollectionText(
} else {
int level2=level;
writer->write("(");
- for (unsigned int i=0, n=static_cast<unsigned int>(geometryCollection->getNumGeometries());
- i < n ; ++i)
+ for (size_t i = 0, n = geometryCollection->getNumGeometries();
+ i < n; ++i)
if (i>0) {
diff --git a/src/linearref/ExtractLineByLocation.cpp b/src/linearref/ExtractLineByLocation.cpp
index 0cc960c..11ec0e0 100644
--- a/src/linearref/ExtractLineByLocation.cpp
+++ b/src/linearref/ExtractLineByLocation.cpp
@@ -90,15 +90,15 @@ LineString* ExtractLineByLocation::computeLine(const LinearLocation& start, cons
CoordinateSequence* coordinates = line->getCoordinates();
CoordinateArraySequence newCoordinateArray;
- const unsigned int indexStep = 1;
- unsigned int startSegmentIndex = start.getSegmentIndex();
+ const size_t indexStep = 1;
+ auto startSegmentIndex = start.getSegmentIndex();
if (start.getSegmentFraction() > 0.0)
startSegmentIndex += indexStep;
- unsigned int lastSegmentIndex = end.getSegmentIndex();
+ auto lastSegmentIndex = end.getSegmentIndex();
if (end.getSegmentFraction() == 1.0)
lastSegmentIndex += indexStep;
@@ -107,7 +107,7 @@ LineString* ExtractLineByLocation::computeLine(const LinearLocation& start, cons
if (lastSegmentIndex >= coordinates->size())
assert(coordinates->size() > 0);
- lastSegmentIndex = static_cast<unsigned int>(coordinates->size() - indexStep);
+ lastSegmentIndex = coordinates->size() - indexStep;
if (! start.isVertex())
@@ -115,7 +115,7 @@ LineString* ExtractLineByLocation::computeLine(const LinearLocation& start, cons
newCoordinateArray.add(start.getCoordinate(line));
- for (unsigned int i = startSegmentIndex; i <= lastSegmentIndex; i++)
+ for (auto i = startSegmentIndex; i <= lastSegmentIndex; i++)
newCoordinateArray.add((*coordinates)[i]);
diff --git a/src/linearref/LengthLocationMap.cpp b/src/linearref/LengthLocationMap.cpp
index b3ef79d..c60fafe 100644
--- a/src/linearref/LengthLocationMap.cpp
+++ b/src/linearref/LengthLocationMap.cpp
@@ -97,8 +97,8 @@ LengthLocationMap::getLocationForward(double length) const
if (it.isEndOfLine()) {
if (totalLength == length) {
- unsigned int compIndex = it.getComponentIndex();
- unsigned int segIndex = it.getVertexIndex();
+ auto compIndex = it.getComponentIndex();
+ auto segIndex = it.getVertexIndex();
return LinearLocation(compIndex, segIndex, 0.0);
@@ -110,8 +110,8 @@ LengthLocationMap::getLocationForward(double length) const
if (totalLength + segLen > length)
double frac = (length - totalLength) / segLen;
return LinearLocation(compIndex, segIndex, frac);
totalLength += segLen;
@@ -129,7 +129,7 @@ LengthLocationMap::resolveHigher(const LinearLocation& loc) const
if (! loc.isEndpoint(*linearGeom)) return loc;
- unsigned int compIndex = loc.getComponentIndex();
+ auto compIndex = loc.getComponentIndex();
// if last component can't resolve any higher
if (compIndex >= linearGeom->getNumGeometries() - 1) return loc;
diff --git a/src/linearref/LinearIterator.cpp b/src/linearref/LinearIterator.cpp
index b7dd762..a1cd0b4 100644
--- a/src/linearref/LinearIterator.cpp
+++ b/src/linearref/LinearIterator.cpp
@@ -31,7 +31,7 @@ namespace geos
namespace linearref // geos.linearref
-unsigned int LinearIterator::segmentEndVertexIndex(const LinearLocation& loc)
+size_t LinearIterator::segmentEndVertexIndex(const LinearLocation& loc)
if (loc.getSegmentFraction() > 0.0)
return loc.getSegmentIndex() + 1;
@@ -42,7 +42,7 @@ LinearIterator::LinearIterator(const Geometry* linear) :
vertexIndex(0),
componentIndex(0),
linear(linear),
- numLines(static_cast<unsigned int>(linear->getNumGeometries()))
+ numLines(linear->getNumGeometries())
loadCurrentLine();
@@ -52,16 +52,16 @@ LinearIterator::LinearIterator(const Geometry* linear, const LinearLocation& sta
vertexIndex(segmentEndVertexIndex(start)),
componentIndex(start.getComponentIndex()),
linear(linear),
loadCurrentLine();
-LinearIterator::LinearIterator(const Geometry* linear, unsigned int componentIndex, unsigned int vertexIndex) :
+LinearIterator::LinearIterator(const Geometry* linear, size_t componentIndex, size_t vertexIndex) :
vertexIndex(vertexIndex),
componentIndex(componentIndex),
linear(linear),
loadCurrentLine();
@@ -112,12 +112,12 @@ bool LinearIterator::isEndOfLine() const
return true;
-unsigned int LinearIterator::getComponentIndex() const
+size_t LinearIterator::getComponentIndex() const
return componentIndex;
-unsigned int LinearIterator::getVertexIndex() const
+size_t LinearIterator::getVertexIndex() const
return vertexIndex;
diff --git a/src/linearref/LinearLocation.cpp b/src/linearref/LinearLocation.cpp
index fdcebb2..16bd4b3 100644
--- a/src/linearref/LinearLocation.cpp
+++ b/src/linearref/LinearLocation.cpp
@@ -56,7 +56,7 @@ LinearLocation::pointAlongSegmentByFraction(const Coordinate& p0, const Coordina
/* public */
-LinearLocation::LinearLocation(unsigned int segmentIndex,
+LinearLocation::LinearLocation(size_t segmentIndex,
componentIndex(0),
@@ -66,8 +66,8 @@ LinearLocation::LinearLocation(unsigned int segmentIndex,
/* public */
-LinearLocation::LinearLocation(unsigned int componentIndex,
- unsigned int segmentIndex, double segmentFraction)
+LinearLocation::LinearLocation(size_t componentIndex,
+ size_t segmentIndex, double segmentFraction)
segmentIndex(segmentIndex),
@@ -108,7 +108,7 @@ LinearLocation::clamp(const Geometry* linear)
if (segmentIndex >= linear->getNumPoints())
const LineString* line = dynamic_cast<const LineString*> (linear->getGeometryN(componentIndex));
- segmentIndex = static_cast<unsigned int>(line->getNumPoints() - 1);
+ segmentIndex = line->getNumPoints() - 1;
segmentFraction = 1.0;
@@ -139,9 +139,9 @@ LinearLocation::getSegmentLength(const Geometry* linearGeom) const
const LineString* lineComp = dynamic_cast<const LineString*> (linearGeom->getGeometryN(componentIndex));
// ensure segment index is valid
- unsigned int segIndex = segmentIndex;
+ size_t segIndex = segmentIndex;
if (segmentIndex >= lineComp->getNumPoints() - 1)
- segIndex = static_cast<unsigned int>(lineComp->getNumPoints() - 2);
+ segIndex = lineComp->getNumPoints() - 2;
Coordinate p0 = lineComp->getCoordinateN(segIndex);
Coordinate p1 = lineComp->getCoordinateN(segIndex + 1);
@@ -152,21 +152,21 @@ LinearLocation::getSegmentLength(const Geometry* linearGeom) const
void
LinearLocation::setToEnd(const Geometry* linear)
- componentIndex = static_cast<unsigned int>(linear->getNumGeometries() - 1);
+ componentIndex = linear->getNumGeometries() - 1;
const LineString* lastLine = dynamic_cast<const LineString*>(linear->getGeometryN(componentIndex));
- segmentIndex = static_cast<unsigned int>(lastLine->getNumPoints() - 1);
+ segmentIndex = lastLine->getNumPoints() - 1;
/* public */
-unsigned int
+size_t
LinearLocation::getComponentIndex() const
/* public */
-unsigned int
+size_t
LinearLocation::getSegmentIndex() const
return segmentIndex;
@@ -210,7 +210,7 @@ LinearLocation::getSegment(const Geometry* linearGeom) const
// check for endpoint - return last segment of the line if so
- Coordinate prev = lineComp->getCoordinateN(static_cast<int>(lineComp->getNumPoints() - 2));
+ Coordinate prev = lineComp->getCoordinateN(lineComp->getNumPoints() - 2);
return std::unique_ptr<LineSegment>(new LineSegment(prev, p0));
Coordinate p1 = lineComp->getCoordinateN(segmentIndex + 1);
@@ -254,8 +254,8 @@ LinearLocation::compareTo(const LinearLocation& other) const
/* public */
int
-LinearLocation::compareLocationValues(unsigned int componentIndex1,
- unsigned int segmentIndex1, double segmentFraction1) const
+LinearLocation::compareLocationValues(size_t componentIndex1,
+ size_t segmentIndex1, double segmentFraction1) const
// compare component indices
if (componentIndex < componentIndex1) return -1;
@@ -274,9 +274,9 @@ LinearLocation::compareLocationValues(unsigned int componentIndex1,
/* public static */
int
diff --git a/src/linearref/LocationIndexOfLine.cpp b/src/linearref/LocationIndexOfLine.cpp
index f2c5240..7b00513 100644
--- a/src/linearref/LocationIndexOfLine.cpp
+++ b/src/linearref/LocationIndexOfLine.cpp
@@ -50,7 +50,7 @@ LocationIndexOfLine::indicesOf(const Geometry* subLine) const
Coordinate startPt = dynamic_cast<const LineString*> (subLine->getGeometryN(0))->getCoordinateN(0);
const LineString* lastLine = dynamic_cast<const LineString*> (subLine->getGeometryN(subLine->getNumGeometries() - 1));
- Coordinate endPt = lastLine->getCoordinateN(static_cast<int>(lastLine->getNumPoints() - 1));
+ Coordinate endPt = lastLine->getCoordinateN(lastLine->getNumPoints() - 1);
LocationIndexOfPoint locPt(linearGeom);
LinearLocation *subLineLoc = new LinearLocation[2];
diff --git a/src/linearref/LocationIndexOfPoint.cpp b/src/linearref/LocationIndexOfPoint.cpp
index 8ddf0dd..bed28d5 100644
--- a/src/linearref/LocationIndexOfPoint.cpp
+++ b/src/linearref/LocationIndexOfPoint.cpp
@@ -42,8 +42,8 @@ LocationIndexOfPoint::indexOfFromStart(const Coordinate& inputPt,
const LinearLocation* minIndex) const
double minDistance = numeric_limits<double>::max();
- int minComponentIndex = 0;
- int minSegmentIndex = 0;
+ size_t minComponentIndex = 0;
+ size_t minSegmentIndex = 0;
double minFrac = -1.0;
LineSegment seg;
@@ -57,8 +57,8 @@ LocationIndexOfPoint::indexOfFromStart(const Coordinate& inputPt,
double segDistance = seg.distance(inputPt);
double segFrac = seg.segmentFraction(inputPt);
- int candidateComponentIndex = it.getComponentIndex();
- int candidateSegmentIndex = it.getVertexIndex();
+ auto candidateComponentIndex = it.getComponentIndex();
+ auto candidateSegmentIndex = it.getVertexIndex();
if (segDistance < minDistance)
// ensure after minLocation, if any
diff --git a/src/noding/BasicSegmentString.cpp b/src/noding/BasicSegmentString.cpp
index 3e341ea..9717094 100644
--- a/src/noding/BasicSegmentString.cpp
+++ b/src/noding/BasicSegmentString.cpp
@@ -40,7 +40,7 @@ namespace noding { // geos.noding
/*public*/
int
-BasicSegmentString::getSegmentOctant(unsigned int index) const
+BasicSegmentString::getSegmentOctant(size_t index) const
if (index >= size() - 1) return -1;
return Octant::octant(getCoordinate(index), getCoordinate(index+1));
@@ -48,7 +48,7 @@ BasicSegmentString::getSegmentOctant(unsigned int index) const
/* virtual public */
-BasicSegmentString::getCoordinate(unsigned int i) const
+BasicSegmentString::getCoordinate(size_t i) const
return pts->getAt(i);
diff --git a/src/noding/IntersectionAdder.cpp b/src/noding/IntersectionAdder.cpp
index 35faa91..2288261 100644
--- a/src/noding/IntersectionAdder.cpp
+++ b/src/noding/IntersectionAdder.cpp
@@ -30,7 +30,7 @@ namespace noding { // geos.noding
/*private*/
bool
IntersectionAdder::isTrivialIntersection(const SegmentString* e0,
- int segIndex0, const SegmentString* e1, int segIndex1)
+ size_t segIndex0, const SegmentString* e1, size_t segIndex1)
if (e0 != e1) return false;
@@ -40,7 +40,7 @@ IntersectionAdder::isTrivialIntersection(const SegmentString* e0,
if (! e0->isClosed()) return false;
- int maxSegIndex = e0->size() - 1;
+ auto maxSegIndex = e0->size() - 1;
if ( (segIndex0 == 0 && segIndex1 == maxSegIndex)
|| (segIndex1 == 0 && segIndex0 == maxSegIndex) )
@@ -53,8 +53,8 @@ IntersectionAdder::isTrivialIntersection(const SegmentString* e0,
/*public*/
void
IntersectionAdder::processIntersections(
// don't bother intersecting a segment with itself
if (e0 == e1 && segIndex0 == segIndex1) return;
diff --git a/src/noding/IntersectionFinderAdder.cpp b/src/noding/IntersectionFinderAdder.cpp
index bf8f555..a777f39 100644
--- a/src/noding/IntersectionFinderAdder.cpp
+++ b/src/noding/IntersectionFinderAdder.cpp
@@ -31,8 +31,8 @@ namespace noding { // geos.noding
void
IntersectionFinderAdder::processIntersections(
@@ -49,7 +49,7 @@ IntersectionFinderAdder::processIntersections(
if (li.isInteriorIntersection())
- for (int intIndex=0, n=li.getIntersectionNum(); intIndex<n; intIndex++)
+ for (size_t intIndex = 0, n = li.getIntersectionNum(); intIndex < n; ++intIndex)
interiorIntersections.push_back(li.getIntersection(intIndex));
diff --git a/src/noding/MCIndexNoder.cpp b/src/noding/MCIndexNoder.cpp
index 9bcb2a8..aefae13 100644
--- a/src/noding/MCIndexNoder.cpp
+++ b/src/noding/MCIndexNoder.cpp
@@ -151,7 +151,7 @@ MCIndexNoder::SegmentOverlapAction::overlap(MonotoneChain& mc1, size_t start1,
assert(ss2);
- si.processIntersections(ss1, static_cast<int>(start1), ss2, static_cast<int>(start2));
+ si.processIntersections(ss1, start1, ss2, start2);
diff --git a/src/noding/MCIndexSegmentSetMutualIntersector.cpp b/src/noding/MCIndexSegmentSetMutualIntersector.cpp
index b04ba4c..e837b5c 100644
--- a/src/noding/MCIndexSegmentSetMutualIntersector.cpp
+++ b/src/noding/MCIndexSegmentSetMutualIntersector.cpp
@@ -167,7 +167,7 @@ MCIndexSegmentSetMutualIntersector::SegmentOverlapAction::overlap(
SegmentString * ss1 = (SegmentString *)(mc1.getContext());
SegmentString * ss2 = (SegmentString *)(mc2.getContext());
} // geos::noding
diff --git a/src/noding/NodedSegmentString.cpp b/src/noding/NodedSegmentString.cpp
index 693594f..712b722 100644
--- a/src/noding/NodedSegmentString.cpp
+++ b/src/noding/NodedSegmentString.cpp
@@ -52,7 +52,7 @@ NodedSegmentString::safeOctant(const Coordinate& p0, const Coordinate& p1)
/*public*/
int
-NodedSegmentString::getSegmentOctant(unsigned int index) const
+NodedSegmentString::getSegmentOctant(size_t index) const
return safeOctant(getCoordinate(index), getCoordinate(index+1));
@@ -61,10 +61,10 @@ NodedSegmentString::getSegmentOctant(unsigned int index) const
/*public*/
void
-NodedSegmentString::addIntersections(LineIntersector *li, unsigned int
- segmentIndex, int geomIndex)
+NodedSegmentString::addIntersections(LineIntersector *li,
- for (int i=0, n=li->getIntersectionNum(); i<n; ++i) {
+ for (size_t i = 0, n = li->getIntersectionNum(); i < n; ++i) {
addIntersection(li, segmentIndex, geomIndex, i);
@@ -72,8 +72,8 @@ NodedSegmentString::addIntersections(LineIntersector *li, unsigned int
/*public*/
void
NodedSegmentString::addIntersection(LineIntersector *li,
- int geomIndex, int intIndex)
+ size_t geomIndex, size_t intIndex)
::geos::ignore_unused_variable_warning(geomIndex);
@@ -84,9 +84,9 @@ NodedSegmentString::addIntersection(LineIntersector *li,
/*public*/
void
NodedSegmentString::addIntersection(const Coordinate& intPt,
- unsigned int normalizedSegmentIndex = segmentIndex;
+ size_t normalizedSegmentIndex = segmentIndex;
if ( segmentIndex > size()-2 )
@@ -94,7 +94,7 @@ NodedSegmentString::addIntersection(const Coordinate& intPt,
- unsigned int nextSegIndex = normalizedSegmentIndex + 1;
const Coordinate& nextPt = pts->getAt(nextSegIndex);
@@ -147,7 +147,7 @@ NodedSegmentString::getNodedSubstrings(
-NodedSegmentString::getCoordinate(unsigned int i) const
+NodedSegmentString::getCoordinate(size_t i) const
diff --git a/src/noding/NodingValidator.cpp b/src/noding/NodingValidator.cpp
index a230565..906294d 100644
--- a/src/noding/NodingValidator.cpp
+++ b/src/noding/NodingValidator.cpp
@@ -62,7 +62,7 @@ void
NodingValidator::checkCollapses(const SegmentString& ss) const
const CoordinateSequence& pts = *(ss.getCoordinates());
- for (unsigned int i=0, n = static_cast<unsigned int>(pts.getSize() - 2); i < n; ++i)
+ for (size_t i = 0, n = pts.size() - 2; i < n; ++i)
checkCollapse(pts[i], pts[i + 1], pts[i + 2]);
@@ -108,8 +108,8 @@ NodingValidator::checkInteriorIntersections(const SegmentString& ss0,
const CoordinateSequence& pts0 = *(ss0.getCoordinates());
const CoordinateSequence& pts1 = *(ss1.getCoordinates());
- for (unsigned int i0=0, n0 = static_cast<unsigned int>(pts0.size()); i0 < n0 - 1; i0++) {
- for (unsigned int i1=0, n1 = static_cast<unsigned int>(pts1.size()); i1 < n1 - 1; i1++) {
+ for (size_t i0 = 0, n0 = pts0.size(); i0 < n0 - 1; ++i0) {
+ for (size_t i1 = 0, n1 = pts1.size(); i1 < n1 - 1; ++i1) {
checkInteriorIntersections(ss0, i0, ss1, i1);
@@ -119,8 +119,8 @@ NodingValidator::checkInteriorIntersections(const SegmentString& ss0,
/* private */
void
if (&e0 == &e1 && segIndex0 == segIndex1) return;
const Coordinate& p00 = e0.getCoordinates()->getAt(segIndex0);
@@ -171,7 +171,7 @@ NodingValidator::checkEndPtVertexIntersections(const Coordinate& testPt,
const SegmentString* ss0 = *it;
const CoordinateSequence& pts = *(ss0->getCoordinates());
- for (unsigned int j=1, n=static_cast<unsigned int>(pts.size()-1); j < n; ++j)
+ for (size_t j = 1, n=pts.size() - 1; j < n; ++j)
if (pts[j].equals(testPt))
@@ -193,7 +193,7 @@ bool
NodingValidator::hasInteriorIntersection(const LineIntersector& aLi,
const Coordinate& p0, const Coordinate& p1) const
- for (int i=0, n=aLi.getIntersectionNum(); i<n; i++)
+ for (size_t i=0, n = aLi.getIntersectionNum(); i < n; ++i)
const Coordinate &intPt=aLi.getIntersection(i);
if (!(intPt==p0 || intPt==p1))
diff --git a/src/noding/SegmentIntersectionDetector.cpp b/src/noding/SegmentIntersectionDetector.cpp
index b4800e6..e7fd399 100644
--- a/src/noding/SegmentIntersectionDetector.cpp
+++ b/src/noding/SegmentIntersectionDetector.cpp
@@ -29,8 +29,8 @@ namespace noding { // geos::noding
void
SegmentIntersectionDetector::
- noding::SegmentString * e0, int segIndex0,
+ noding::SegmentString * e0, size_t segIndex0,
diff --git a/src/noding/SegmentNode.cpp b/src/noding/SegmentNode.cpp
index eb27ae5..5d3bbce 100644
--- a/src/noding/SegmentNode.cpp
+++ b/src/noding/SegmentNode.cpp
@@ -39,7 +39,7 @@ namespace noding { // geos.noding
/*public*/
SegmentNode::SegmentNode(const NodedSegmentString& ss, const Coordinate& nCoord,
segString(ss),
segmentOctant(nSegmentOctant),
diff --git a/src/noding/SegmentNodeList.cpp b/src/noding/SegmentNodeList.cpp
index 59a13da..1799a84 100644
--- a/src/noding/SegmentNodeList.cpp
+++ b/src/noding/SegmentNodeList.cpp
@@ -60,8 +60,8 @@ SegmentNodeList::~SegmentNodeList()
SegmentNode*
SegmentNodeList::add(const Coordinate& intPt, size_t segmentIndex)
- SegmentNode *eiNew=new SegmentNode(edge, intPt, static_cast<unsigned int>(segmentIndex),
- edge.getSegmentOctant(static_cast<unsigned int>(segmentIndex)));
+ SegmentNode *eiNew=new SegmentNode(edge, intPt, segmentIndex,
+ edge.getSegmentOctant(segmentIndex));
std::pair<SegmentNodeList::iterator,bool> p = nodeMap.insert(eiNew);
if ( p.second ) { // new SegmentNode inserted
@@ -78,7 +78,7 @@ SegmentNodeList::add(const Coordinate& intPt, size_t segmentIndex)
void SegmentNodeList::addEndpoints()
- int maxSegIndex = edge.size() - 1;
+ size_t maxSegIndex = edge.size() - 1;
add(&(edge.getCoordinate(0)), 0);
add(&(edge.getCoordinate(maxSegIndex)), maxSegIndex);
@@ -98,7 +98,7 @@ SegmentNodeList::addCollapsedNodes()
e=collapsedVertexIndexes.end();
i != e; ++i)
- auto vertexIndex = static_cast<unsigned int>(*i);
+ auto vertexIndex = *i;
add(edge.getCoordinate(vertexIndex), vertexIndex);
@@ -113,8 +113,8 @@ SegmentNodeList::findCollapsesFromExistingVertices(
for (size_t i=0, n=edge.size()-2; i<n; ++i)
- const Coordinate& p0 = edge.getCoordinate(static_cast<unsigned int>(i));
- const Coordinate& p2 = edge.getCoordinate(static_cast<unsigned int>(i + 2));
+ const Coordinate& p0 = edge.getCoordinate(i);
+ const Coordinate& p2 = edge.getCoordinate(i + 2);
if (p0.equals2D(p2)) {
// add base of collapse as node
collapsedVertexIndexes.push_back(i + 1);
@@ -151,10 +151,11 @@ bool
SegmentNodeList::findCollapseIndex(SegmentNode& ei0, SegmentNode& ei1,
size_t& collapsedVertexIndex)
+ assert(ei1.segmentIndex >= ei0.segmentIndex);
// only looking for equal nodes
if (! ei0.coord.equals2D(ei1.coord)) return false;
- int numVerticesBetween = ei1.segmentIndex - ei0.segmentIndex;
+ auto numVerticesBetween = ei1.segmentIndex - ei0.segmentIndex;
if (! ei1.isInterior()) {
numVerticesBetween--;
@@ -271,7 +272,7 @@ SegmentNodeList::createSplitEdge(SegmentNode *ei0, SegmentNode *ei1)
pts->setAt(ei0->coord, ipt++);
for (size_t i=ei0->segmentIndex+1; i<=ei1->segmentIndex; i++)
- pts->setAt(edge.getCoordinate(static_cast<unsigned int>(i)),ipt++);
+ pts->setAt(edge.getCoordinate(i),ipt++);
if (useIntPt1) pts->setAt(ei1->coord, ipt++);
diff --git a/src/noding/SimpleNoder.cpp b/src/noding/SimpleNoder.cpp
index 77c501b..8bc6fb5 100644
--- a/src/noding/SimpleNoder.cpp
+++ b/src/noding/SimpleNoder.cpp
@@ -35,8 +35,8 @@ SimpleNoder::computeIntersects(SegmentString* e0, SegmentString* e1)
const CoordinateSequence* pts0 = e0->getCoordinates();
const CoordinateSequence* pts1 = e1->getCoordinates();
- for (unsigned int i0=0, n0=static_cast<unsigned int>(pts0->getSize()-1); i0<n0; i0++) {
- for (unsigned int i1=0, n1=static_cast<unsigned int>(pts1->getSize()-1); i1<n1; i1++) {
+ for (size_t i0=0, n0 = pts0->getSize() - 1; i0 < n0; i0++) {
+ for (size_t i1=0, n1 = pts1->getSize() - 1; i1 < n1; i1++) {
segInt->processIntersections(e0, i0, e1, i1);
diff --git a/src/noding/SingleInteriorIntersectionFinder.cpp b/src/noding/SingleInteriorIntersectionFinder.cpp
index a7798a4..e735ea0 100644
--- a/src/noding/SingleInteriorIntersectionFinder.cpp
+++ b/src/noding/SingleInteriorIntersectionFinder.cpp
@@ -29,8 +29,8 @@ namespace noding { // geos.noding
/*public (override) */
void
SingleInteriorIntersectionFinder::processIntersections(
- SegmentString* e0, int segIndex0,
+ SegmentString* e0, size_t segIndex0,
using geos::geom::Coordinate;
diff --git a/src/noding/snapround/HotPixel.cpp b/src/noding/snapround/HotPixel.cpp
index a1f75eb..bc7156d 100644
--- a/src/noding/snapround/HotPixel.cpp
+++ b/src/noding/snapround/HotPixel.cpp
@@ -174,13 +174,13 @@ HotPixel::intersectsPixelClosure(const Coordinate& p0,
bool
HotPixel::addSnappedNode(NodedSegmentString& segStr, size_t segIndex)
- const Coordinate& p0 = segStr.getCoordinate(static_cast<unsigned int>(segIndex));
- const Coordinate& p1 = segStr.getCoordinate(static_cast<unsigned int>(segIndex + 1));
+ const Coordinate& p0 = segStr.getCoordinate(segIndex);
+ const Coordinate& p1 = segStr.getCoordinate(segIndex + 1);
if (intersects(p0, p1))
//cout << "snapped: " << snapPt << endl;
- segStr.addIntersection(getCoordinate(), static_cast<unsigned int>(segIndex));
+ segStr.addIntersection(getCoordinate(), segIndex);
return true;
return false;
diff --git a/src/noding/snapround/MCIndexPointSnapper.cpp b/src/noding/snapround/MCIndexPointSnapper.cpp
index cf3e050..accfd94 100644
--- a/src/noding/snapround/MCIndexPointSnapper.cpp
+++ b/src/noding/snapround/MCIndexPointSnapper.cpp
@@ -42,7 +42,7 @@ public:
HotPixelSnapAction(HotPixel& nHotPixel,
SegmentString* nParentEdge,
- unsigned int nVertexIndex)
+ size_t nVertexIndex)
MonotoneChainSelectAction(),
hotPixel(nHotPixel),
@@ -53,7 +53,7 @@ public:
bool isNodeAdded() const { return isNodeAddedVar; }
- void select(chain::MonotoneChain& mc, unsigned int startIndex) override
+ void select(chain::MonotoneChain& mc, size_t startIndex) override
// This is casting away 'constness'!
NodedSegmentString& ss = *(static_cast<NodedSegmentString*>(mc.getContext()));
@@ -76,7 +76,7 @@ public:
private:
HotPixel& hotPixel;
SegmentString* parentEdge;
- unsigned int vertexIndex;
+ size_t vertexIndex;
bool isNodeAddedVar;
// Declare type as noncopyable
@@ -114,7 +114,7 @@ private:
bool
MCIndexPointSnapper::snap(HotPixel& hotPixel,
const Envelope& pixelEnv = hotPixel.getSafeEnvelope();
HotPixelSnapAction hotPixelSnapAction(hotPixel, parentEdge, vertexIndex);
diff --git a/src/noding/snapround/MCIndexSnapRounder.cpp b/src/noding/snapround/MCIndexSnapRounder.cpp
index 7075f11..b756c1b 100644
--- a/src/noding/snapround/MCIndexSnapRounder.cpp
+++ b/src/noding/snapround/MCIndexSnapRounder.cpp
@@ -69,7 +69,7 @@ void
MCIndexSnapRounder::computeVertexSnaps(NodedSegmentString* e)
CoordinateSequence& pts0 = *(e->getCoordinates());
- for (unsigned int i=0, n=static_cast<unsigned int>(pts0.size()-1); i<n; ++i)
+ for (size_t i = 0, n = pts0.size() - 1; i < n; ++i)
HotPixel hotPixel(pts0[i], scaleFactor, li);
bool isNodeAdded = pointSnapper->snap(hotPixel, e, i);
diff --git a/src/noding/snapround/SimpleSnapRounder.cpp b/src/noding/snapround/SimpleSnapRounder.cpp
index 716bc0b..ba3ff60 100644
--- a/src/noding/snapround/SimpleSnapRounder.cpp
+++ b/src/noding/snapround/SimpleSnapRounder.cpp
@@ -136,7 +136,7 @@ SimpleSnapRounder::computeSnaps(NodedSegmentString* ss, vector<Coordinate>& snap
const Coordinate& snapPt = *it;
HotPixel hotPixel(snapPt, scaleFactor, li);
- for (int i=0, n=ss->size()-1; i<n; ++i) {
+ for (size_t i = 0, n = ss->size() - 1; i < n; ++i) {
hotPixel.addSnappedNode(*ss, i);
@@ -149,12 +149,12 @@ SimpleSnapRounder::computeVertexSnaps(NodedSegmentString* e0, NodedSegmentString
+ for (size_t i0 = 0, n0 = pts0->getSize() - 1; i0 < n0; ++i0)
const Coordinate& p0 = pts0->getAt(i0);
HotPixel hotPixel(p0, scaleFactor, li);
- for (unsigned int i1=1, n1=static_cast<unsigned int>(pts1->getSize()-1); i1<n1; i1++)
+ for (size_t i1 = 1, n1 = pts1->getSize()-1; i1 < n1; ++i1)
// don't snap a vertex to itself
if (i0 == i1 && e0 == e1) {
diff --git a/src/operation/IsSimpleOp.cpp b/src/operation/IsSimpleOp.cpp
index 7ae0038..520f751 100644
--- a/src/operation/IsSimpleOp.cpp
+++ b/src/operation/IsSimpleOp.cpp
@@ -200,7 +200,7 @@ IsSimpleOp::hasNonEndpointIntersection(GeometryGraph &graph)
vector<Edge*> *edges=graph.getEdges();
for (vector<Edge*>::iterator i=edges->begin();i<edges->end();i++) {
Edge *e=*i;
- int maxSegmentIndex=e->getMaximumSegmentIndex();
+ auto maxSegmentIndex = e->getMaximumSegmentIndex();
EdgeIntersectionList &eiL=e->getEdgeIntersectionList();
for ( EdgeIntersectionList::iterator eiIt=eiL.begin(),
eiEnd=eiL.end(); eiIt!=eiEnd; ++eiIt )
diff --git a/src/operation/buffer/BufferInputLineSimplifier.cpp b/src/operation/buffer/BufferInputLineSimplifier.cpp
index bc56c29..6b9d147 100644
--- a/src/operation/buffer/BufferInputLineSimplifier.cpp
+++ b/src/operation/buffer/BufferInputLineSimplifier.cpp
@@ -79,10 +79,10 @@ BufferInputLineSimplifier::deleteShallowConcavities()
* Do not simplify end line segments of the line string.
* This ensures that end caps are generated consistently.
- unsigned int index = 1;
+ size_t index = 1;
- unsigned int midIndex = findNextNonDeletedIndex(index);
- unsigned int lastIndex = findNextNonDeletedIndex(midIndex);
+ auto midIndex = findNextNonDeletedIndex(index);
+ auto lastIndex = findNextNonDeletedIndex(midIndex);
bool isChanged = false;
while (lastIndex < inputLine.size())
@@ -109,14 +109,14 @@ BufferInputLineSimplifier::deleteShallowConcavities()
/* private */
-unsigned int
-BufferInputLineSimplifier::findNextNonDeletedIndex(unsigned int index) const
+size_t
+BufferInputLineSimplifier::findNextNonDeletedIndex(size_t index) const
std::size_t next = index + 1;
const std::size_t len = inputLine.size();
while (next < len && isDeleted[next] == DELETE)
next++;
- return static_cast<unsigned int>(next);
+ return next;
/* private */
@@ -137,7 +137,7 @@ BufferInputLineSimplifier::collapseLine() const
/* private */
bool
-BufferInputLineSimplifier::isDeletable(int i0, int i1, int i2,
+BufferInputLineSimplifier::isDeletable(size_t i0, size_t i1, size_t i2,
const Coordinate& p0 = inputLine[i0];
@@ -173,14 +173,14 @@ BufferInputLineSimplifier::isShallowConcavity(const geom::Coordinate& p0,
bool
BufferInputLineSimplifier::isShallowSampled(const geom::Coordinate& p0,
- int i0, int i2,
// check every n'th point to see if it is within tolerance
- int inc = (i2 - i0) / NUM_PTS_TO_CHECK;
+ auto inc = (i2 - i0) / NUM_PTS_TO_CHECK;
if (inc <= 0) inc = 1;
- for (int i = i0; i < i2; i += inc) {
+ for (size_t i = i0; i < i2; i += inc) {
if (! isShallow(p0, p2, inputLine[i], distanceTol))
return false;
diff --git a/src/operation/buffer/OffsetCurveBuilder.cpp b/src/operation/buffer/OffsetCurveBuilder.cpp
index c3f1804..a9cd15f 100644
--- a/src/operation/buffer/OffsetCurveBuilder.cpp
+++ b/src/operation/buffer/OffsetCurveBuilder.cpp
@@ -128,12 +128,12 @@ OffsetCurveBuilder::getSingleSidedLineCurve(const CoordinateSequence* inputPts,
const CoordinateSequence& simp1 = *simp1_;
- int n1 = static_cast<int>(simp1.size()) - 1;
+ auto n1 = simp1.size() - 1;
if ( ! n1 )
throw util::IllegalArgumentException("Cannot get offset of single-vertex line");
segGen->initSideSegments(simp1[0], simp1[1], Position::LEFT);
segGen->addFirstSegment();
- for (int i = 2; i <= n1; ++i) {
+ for (size_t i = 2; i <= n1; ++i) {
segGen->addNextSegment(simp1[i], true);
segGen->addLastSegment();
@@ -147,13 +147,13 @@ OffsetCurveBuilder::getSingleSidedLineCurve(const CoordinateSequence* inputPts,
BufferInputLineSimplifier::simplify( *inputPts, -distTol );
const CoordinateSequence& simp2 = *simp2_;
- int n2 = static_cast<int>(simp2.size()) - 1;
+ auto n2 = simp2.size() - 1;
if ( ! n2 )
segGen->initSideSegments(simp2[n2], simp2[n2-1], Position::LEFT);
- for (int i = n2-2; i >= 0; --i) {
- segGen->addNextSegment(simp2[i], true);
+ for (size_t i = n2 - 1; i > 0; --i) {
+ segGen->addNextSegment(simp2[i - 1], true);
@@ -207,9 +207,9 @@ OffsetCurveBuilder::computeLineBufferCurve(const CoordinateSequence& inputPts,
segGen.initSideSegments(simp1[0], simp1[1], Position::LEFT);
segGen.addNextSegment(simp1[i], true);
segGen.addLastSegment();
@@ -222,10 +222,10 @@ OffsetCurveBuilder::computeLineBufferCurve(const CoordinateSequence& inputPts,
BufferInputLineSimplifier::simplify(inputPts, -distTol);
segGen.initSideSegments(simp2[n2], simp2[n2-1], Position::LEFT);
- segGen.addNextSegment(simp2[i], true);
+ segGen.addNextSegment(simp2[i - 1], true);
// add line cap for start of line
@@ -248,9 +248,9 @@ OffsetCurveBuilder::computeRingBufferCurve(const CoordinateSequence& inputPts,
BufferInputLineSimplifier::simplify(inputPts, distTol);
const CoordinateSequence& simp = *simp_;
- int n = static_cast<int>(simp.size())-1;
+ auto n = simp.size() - 1;
segGen.initSideSegments(simp[n-1], simp[0], side);
- for (int i = 1; i <= n; i++) {
+ for (size_t i = 1; i <= n; i++) {
bool addStartPoint = i != 1;
segGen.addNextSegment(simp[i], addStartPoint);
@@ -276,11 +276,11 @@ OffsetCurveBuilder::computeSingleSidedBufferCurve(
segGen.addFirstSegment();
} else {
@@ -294,10 +294,10 @@ OffsetCurveBuilder::computeSingleSidedBufferCurve(
diff --git a/src/operation/buffer/OffsetCurveSetBuilder.cpp b/src/operation/buffer/OffsetCurveSetBuilder.cpp
index 6fe3572..f384d42 100644
--- a/src/operation/buffer/OffsetCurveSetBuilder.cpp
+++ b/src/operation/buffer/OffsetCurveSetBuilder.cpp
@@ -172,7 +172,7 @@ OffsetCurveSetBuilder::add(const Geometry& g)
void
OffsetCurveSetBuilder::addCollection(const GeometryCollection *gc)
- for (int i=0, n=static_cast<int>(gc->getNumGeometries()); i<n; i++) {
+ for (size_t i = 0, n = gc->getNumGeometries(); i < n; i++) {
const Geometry *g=gc->getGeometryN(i);
add(*g);
diff --git a/src/operation/buffer/OffsetSegmentGenerator.cpp b/src/operation/buffer/OffsetSegmentGenerator.cpp
index 523b003..b67e177 100644
--- a/src/operation/buffer/OffsetSegmentGenerator.cpp
+++ b/src/operation/buffer/OffsetSegmentGenerator.cpp
@@ -324,7 +324,7 @@ OffsetSegmentGenerator::addCollinear(bool addStartPoint)
li.computeIntersection(s0,s1,s1,s2);
- int numInt=li.getIntersectionNum();
+ auto numInt = li.getIntersectionNum();
* if numInt is<2, the lines are parallel and in the same direction.
diff --git a/src/operation/buffer/SubgraphDepthLocater.cpp b/src/operation/buffer/SubgraphDepthLocater.cpp
index 5229f5c..51c23e7 100644
--- a/src/operation/buffer/SubgraphDepthLocater.cpp
+++ b/src/operation/buffer/SubgraphDepthLocater.cpp
@@ -234,8 +234,8 @@ SubgraphDepthLocater::findStabbedSegments(
#define SKIP_LS 1
- int n = static_cast<int>(pts->getSize())-1;
- for (int i=0; i<n; ++i) {
+ auto n = pts->getSize() - 1;
+ for (size_t i = 0; i < n; ++i) {
#ifndef SKIP_LS
seg.p0=pts->getAt(i);
seg.p1=pts->getAt(i + 1);
diff --git a/src/operation/distance/DistanceOp.cpp b/src/operation/distance/DistanceOp.cpp
index f365633..0a62068 100644
--- a/src/operation/distance/DistanceOp.cpp
+++ b/src/operation/distance/DistanceOp.cpp
@@ -569,9 +569,9 @@ DistanceOp::computeMinDistance(
delete closestPt;
delete locGeom[0];
- locGeom[0] = new GeometryLocation(line0, static_cast<int>(i), *c1);
+ locGeom[0] = new GeometryLocation(line0, i, *c1);
delete locGeom[1];
- locGeom[1] = new GeometryLocation(line1, static_cast<int>(j), *c2);
+ locGeom[1] = new GeometryLocation(line1, j, *c2);
if (minDistance<=terminateDistance) return;
@@ -607,7 +607,7 @@ DistanceOp::computeMinDistance(const LineString *line,
seg.closestPoint(*coord, segClosestPoint);
delete locGeom[0];
- locGeom[0] = new GeometryLocation(line, static_cast<int>(i), segClosestPoint);
+ locGeom[0] = new GeometryLocation(line, i, segClosestPoint);
delete locGeom[1];
locGeom[1] = new GeometryLocation(pt, 0, *coord);
diff --git a/src/operation/distance/GeometryLocation.cpp b/src/operation/distance/GeometryLocation.cpp
index 4aef6f6..4a8116c 100644
--- a/src/operation/distance/GeometryLocation.cpp
+++ b/src/operation/distance/GeometryLocation.cpp
@@ -29,10 +29,11 @@ namespace distance { // geos.operation.distance
* Constructs a GeometryLocation specifying a point on a geometry, as well as the
* segment that the point is on (or INSIDE_AREA if the point is not on a segment).
-GeometryLocation::GeometryLocation(const Geometry *newComponent, int newSegIndex, const Coordinate &newPt)
+GeometryLocation::GeometryLocation(const Geometry *newComponent, size_t newSegIndex, const Coordinate &newPt)
component = newComponent;
segIndex = newSegIndex;
+ inside_area = false;
pt = newPt;
@@ -42,6 +43,7 @@ GeometryLocation::GeometryLocation(const Geometry *newComponent, int newSegIndex
GeometryLocation::GeometryLocation(const Geometry *newComponent, const Coordinate &newPt)
+ inside_area = true;
segIndex = INSIDE_AREA;
pt = newPt;
@@ -58,7 +60,7 @@ const Geometry* GeometryLocation::getGeometryComponent() {
* @return the segment index for the location, or INSIDE_AREA
-int
+size_t
GeometryLocation::getSegmentIndex()
return segIndex;
@@ -73,7 +75,7 @@ GeometryLocation::getCoordinate()
bool GeometryLocation::isInsideArea() {
- return segIndex == INSIDE_AREA;
+ return inside_area;
} // namespace geos.operation.distance
diff --git a/src/operation/intersection/RectangleIntersection.cpp b/src/operation/intersection/RectangleIntersection.cpp
index 04f5615..aba0408 100644
--- a/src/operation/intersection/RectangleIntersection.cpp
+++ b/src/operation/intersection/RectangleIntersection.cpp
@@ -126,7 +126,7 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString * gi,
using namespace geos::geom;
- int n = static_cast<int>(gi->getNumPoints());
+ auto n = gi->getNumPoints();
if(gi == nullptr || n<1)
return false;
@@ -148,7 +148,7 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString * gi,
// Start iterating
- int i = 0;
+ size_t i = 0;
while(i<n)
@@ -257,7 +257,7 @@ RectangleIntersection::clip_linestring_parts(const geom::LineString * gi,
// outside. We may have to output partial linestrings
// while iterating until we go strictly outside
- int start_index = i; // 1st valid original point
+ auto start_index = i; // 1st valid original point
bool go_outside = false;
while(!go_outside && ++i<n)
@@ -423,7 +423,7 @@ RectangleIntersection::clip_polygon_to_linestrings(const geom::Polygon * g,
// - Clipped ones become linestrings
// - Intact ones become new polygons without holes
- for(int i=0, n= static_cast<int>(g->getNumInteriorRing()); i<n; ++i)
+ for(size_t i = 0, n = g->getNumInteriorRing(); i < n; ++i)
if(clip_linestring_parts(g->getInteriorRingN(i), parts, rect))
@@ -499,7 +499,7 @@ RectangleIntersection::clip_polygon_to_polygons(const geom::Polygon * g,
// - Intact ones become holes in new polygons formed by exterior parts
- for(int i=0, n = static_cast<int>(g->getNumInteriorRing()); i<n; ++i)
RectangleIntersectionBuilder holeparts(*_gf);
const LineString *hole = g->getInteriorRingN(i);
@@ -584,7 +584,7 @@ RectangleIntersection::clip_multipoint(const geom::MultiPoint * g,
if(g == nullptr || g->isEmpty())
return;
- for(int i=0, n=static_cast<int>(g->getNumGeometries()); i<n; ++i)
+ for(size_t i = 0, n = g->getNumGeometries(); i < n; ++i)
clip_point(dynamic_cast<const geom::Point *>(g->getGeometryN(i)),
parts, rect);
@@ -599,7 +599,7 @@ RectangleIntersection::clip_multilinestring(const geom::MultiLineString * g,
return;
- for(int i=0, n = static_cast<int>(g->getNumGeometries()); i<n; ++i)
clip_linestring(dynamic_cast<const geom::LineString *>(g->getGeometryN(i)),
parts, rect);
@@ -615,7 +615,7 @@ RectangleIntersection::clip_multipolygon(const geom::MultiPolygon * g,
return;
clip_polygon(dynamic_cast<const geom::Polygon *>(g->getGeometryN(i)),
parts, rect, keep_polygons);
@@ -629,10 +629,9 @@ RectangleIntersection::clip_geometrycollection(
const Rectangle & rect,
bool keep_polygons)
- if(g == nullptr || g->isEmpty())
- return;
+ if(g == nullptr || g->isEmpty()) return;
clip_geom(g->getGeometryN(i),
diff --git a/src/operation/intersection/RectangleIntersectionBuilder.cpp b/src/operation/intersection/RectangleIntersectionBuilder.cpp
index 5bd0c4e..777b246 100644
--- a/src/operation/intersection/RectangleIntersectionBuilder.cpp
+++ b/src/operation/intersection/RectangleIntersectionBuilder.cpp
@@ -258,7 +258,7 @@ double distance(const Rectangle & rect,
* \brief Reverse given segment in a coordinate vector
-void reverse_points(std::vector<Coordinate> &v, int start, int end)
+void reverse_points(std::vector<Coordinate> &v, size_t start, size_t end)
geom::Coordinate p1;
geom::Coordinate p2;
@@ -284,9 +284,9 @@ normalize_ring(std::vector<Coordinate> &ring)
// Find the "smallest" coordinate
- int best_pos = 0;
- int n = static_cast<int>(ring.size());
- for(int pos = 0; pos<n; ++pos)
+ size_t best_pos = 0;
+ auto n = ring.size();
+ for(size_t pos = 0; pos < n; ++pos)
// TODO: use CoordinateLessThan ?
if(ring[pos].x < ring[best_pos].x)
@@ -297,15 +297,14 @@ normalize_ring(std::vector<Coordinate> &ring)
// Quick exit if the ring is already normalized
- if(best_pos == 0)
- return;
+ if(best_pos == 0) return;
// Flip hands -algorithm to the part without the
// duplicate last coordinate at n-1:
- reverse_points(ring,0,best_pos-1);
- reverse_points(ring,best_pos,n-2);
- reverse_points(ring,0,n-2);
+ reverse_points(ring,0, best_pos - 1);
+ reverse_points(ring,best_pos, n - 2);
+ reverse_points(ring,0, n - 2);
// And make sure the ring is valid by duplicating the first coordinate
// at the end:
diff --git a/src/operation/linemerge/LineSequencer.cpp b/src/operation/linemerge/LineSequencer.cpp
index f55564e..5bd9407 100644
--- a/src/operation/linemerge/LineSequencer.cpp
+++ b/src/operation/linemerge/LineSequencer.cpp
@@ -74,7 +74,7 @@ LineSequencer::isSequenced(const Geometry* geom)
const Coordinate* startNode = &(line.getCoordinateN(0));
- const Coordinate* endNode = &(line.getCoordinateN(static_cast<int>(line.getNumPoints() - 1)));
+ const Coordinate* endNode = &(line.getCoordinateN(line.getNumPoints() - 1));
* If this linestring is connected to a previous subgraph,
diff --git a/src/operation/polygonize/PolygonizeGraph.cpp b/src/operation/polygonize/PolygonizeGraph.cpp
index 682e9cd..c64cb44 100644
--- a/src/operation/polygonize/PolygonizeGraph.cpp
+++ b/src/operation/polygonize/PolygonizeGraph.cpp
@@ -382,9 +382,9 @@ PolygonizeGraph::computeNextCCWEdges(Node *node, long label)
* Must use a SIGNED int here to allow for beak condition
* to be true.
- for(int i=static_cast<int>(edges.size())-1; i>=0; --i)
+ for(auto i = edges.size(); i > 0; --i)
- PolygonizeDirectedEdge *de=(PolygonizeDirectedEdge*)edges[i];
+ PolygonizeDirectedEdge *de=(PolygonizeDirectedEdge*)edges[i - 1];
PolygonizeDirectedEdge *sym=(PolygonizeDirectedEdge*) de->getSym();
PolygonizeDirectedEdge *outDE=nullptr;
if (de->getLabel()==label) outDE=de;
diff --git a/src/operation/predicate/RectangleContains.cpp b/src/operation/predicate/RectangleContains.cpp
index 530df13..fedc255 100644
--- a/src/operation/predicate/RectangleContains.cpp
+++ b/src/operation/predicate/RectangleContains.cpp
@@ -55,7 +55,7 @@ RectangleContains::isContainedInBoundary(const Geometry& geom)
if (const LineString *l=dynamic_cast<const LineString *>(&geom))
return isLineStringContainedInBoundary(*l);
- for (unsigned i=0, n=static_cast<unsigned>(geom.getNumGeometries()); i<n; ++i)
+ for (size_t i = 0, n = geom.getNumGeometries(); i < n; ++i)
const Geometry &comp = *(geom.getGeometryN(i));
if ( !isContainedInBoundary(comp) )
@@ -93,7 +93,7 @@ bool
RectangleContains::isLineStringContainedInBoundary(const LineString& line)
const CoordinateSequence &seq = *(line.getCoordinatesRO());
- for (unsigned int i=0, n=static_cast<unsigned int>(seq.getSize()-1); i<n; ++i) {
+ for (size_t i = 0, n =seq.size() - 1; i < n; ++i) {
const Coordinate& p0=seq.getAt(i);
const Coordinate& p1=seq.getAt(i+1);
if (! isLineSegmentContainedInBoundary(p0, p1))
diff --git a/src/operation/relate/EdgeEndBuilder.cpp b/src/operation/relate/EdgeEndBuilder.cpp
index 6c09e91..ca171dd 100644
--- a/src/operation/relate/EdgeEndBuilder.cpp
+++ b/src/operation/relate/EdgeEndBuilder.cpp
@@ -93,7 +93,7 @@ void
EdgeEndBuilder::createEdgeEndForPrev(Edge *edge, vector<EdgeEnd*> *l,
EdgeIntersection *eiCurr, EdgeIntersection *eiPrev)
- int iPrev=eiCurr->segmentIndex;
+ auto iPrev = eiCurr->segmentIndex;
if (eiCurr->dist==0.0) {
// if at the start of the edge there is no previous edge
if (iPrev==0) return;
@@ -123,7 +123,7 @@ void
EdgeEndBuilder::createEdgeEndForNext(Edge *edge, vector<EdgeEnd*> *l,
EdgeIntersection *eiCurr, EdgeIntersection *eiNext)
- int iNext=eiCurr->segmentIndex + 1;
+ size_t iNext = eiCurr->segmentIndex + 1;
// if there is no next edge there is nothing to do
if (iNext>=edge->getNumPoints() && eiNext==nullptr) return;
Coordinate pNext(edge->getCoordinate(iNext));
diff --git a/src/operation/valid/IsValidOp.cpp b/src/operation/valid/IsValidOp.cpp
index 5ce171d..c8d8165 100644
--- a/src/operation/valid/IsValidOp.cpp
+++ b/src/operation/valid/IsValidOp.cpp
@@ -70,7 +70,7 @@ IsValidOp::findPtNotNode(const CoordinateSequence *testCoords,
// find a point in the testCoords which is not a node of the searchRing
EdgeIntersectionList &eiList=searchEdge->getEdgeIntersectionList();
// somewhat inefficient - is there a better way? (Use a node map, for instance?)
- unsigned int npts = static_cast<int>(testCoords->getSize());
+ auto npts = testCoords->getSize();
for(unsigned int i=0; i<npts; ++i)
const Coordinate& pt=testCoords->getAt(i);
@@ -231,10 +231,10 @@ IsValidOp::checkValid(const Polygon *g)
void
IsValidOp::checkValid(const MultiPolygon *g)
- unsigned int ngeoms = static_cast<unsigned int>(g->getNumGeometries());
+ auto ngeoms = g->getNumGeometries();
vector<const Polygon *>polys(ngeoms);
- for (unsigned int i=0; i<ngeoms; ++i)
+ for (size_t i=0; i < ngeoms; ++i)
const Polygon *p = dynamic_cast<const Polygon *>(g->getGeometryN(i));
@@ -284,7 +284,7 @@ IsValidOp::checkValid(const MultiPolygon *g)
void
IsValidOp::checkValid(const GeometryCollection *gc)
- for(unsigned int i=0, ngeoms=static_cast<unsigned int>(gc->getNumGeometries()); i<ngeoms; ++i)
+ for(size_t i = 0, ngeoms=gc->getNumGeometries(); i < ngeoms; ++i)
checkValid(g);
@@ -382,11 +382,11 @@ IsValidOp::checkHolesInShell(const Polygon *p, GeometryGraph *graph)
const LinearRing *shell=static_cast<const LinearRing*>(
p->getExteriorRing());
- int nholes = static_cast<int>(p->getNumInteriorRing());
+ auto nholes = p->getNumInteriorRing();
if(shell->isEmpty())
- for(int i=0; i<nholes; ++i)
+ for(size_t i = 0; i < nholes; ++i)
assert(dynamic_cast<const LinearRing*>(
p->getInteriorRingN(i)));
@@ -409,7 +409,7 @@ IsValidOp::checkHolesInShell(const Polygon *p, GeometryGraph *graph)
//SIRtreePointInRing pir(shell);
MCPointInRing pir(shell);
@@ -446,8 +446,8 @@ IsValidOp::checkHolesNotNested(const Polygon *p, GeometryGraph *graph)
//QuadtreeNestedRingTester nestedTester(graph);
IndexedNestedRingTester nestedTester(graph);
@@ -474,7 +474,7 @@ IsValidOp::checkHolesNotNested(const Polygon *p, GeometryGraph *graph)
void
IsValidOp::checkShellsNotNested(const MultiPolygon *mp, GeometryGraph *graph)
- for(unsigned int i=0, ngeoms = static_cast<int>(mp->getNumGeometries()); i<ngeoms; ++i)
+ for(size_t i = 0, ngeoms = mp->getNumGeometries(); i < ngeoms; ++i)
const Polygon *p=dynamic_cast<const Polygon *>(
mp->getGeometryN(i));
@@ -484,7 +484,7 @@ IsValidOp::checkShellsNotNested(const MultiPolygon *mp, GeometryGraph *graph)
assert(shell);
- for(unsigned int j=0; j<ngeoms; ++j)
+ for(size_t j = 0; j < ngeoms; ++j)
if (i==j) continue;
@@ -524,7 +524,7 @@ IsValidOp::checkShellNotNested(const LinearRing *shell, const Polygon *p,
if (!insidePolyShell) return;
// if no holes, this is an error!
if (nholes<=0) {
validErr=new TopologyValidationError(
TopologyValidationError::eNestedShells,
@@ -540,7 +540,7 @@ IsValidOp::checkShellNotNested(const LinearRing *shell, const Polygon *p,
* an error.
const Coordinate *badNestedPt=nullptr;
- for(int i=0; i<nholes; ++i) {
+ for(size_t i = 0; i < nholes; ++i) {
const LinearRing *hole=static_cast<const LinearRing*>(
@@ -604,8 +604,8 @@ IsValidOp::checkConnectedInteriors(GeometryGraph &graph)
void
IsValidOp::checkInvalidCoordinates(const CoordinateSequence *cs)
- unsigned int size = static_cast<unsigned int>(cs->getSize());
- for (unsigned int i=0; i<size; ++i)
+ auto size = cs->size();
+ for (size_t i = 0; i < size; ++i)
if (! isValid(cs->getAt(i)) )
@@ -625,8 +625,8 @@ IsValidOp::checkInvalidCoordinates(const Polygon *poly)
checkInvalidCoordinates(poly->getExteriorRing()->getCoordinatesRO());
if (validErr != nullptr) return;
- int nholes = static_cast<int>(poly->getNumInteriorRing());
- for (int i=0; i<nholes; ++i)
+ auto nholes = poly->getNumInteriorRing();
+ for (size_t i = 0; i < nholes; ++i)
poly->getInteriorRingN(i)->getCoordinatesRO()
@@ -643,8 +643,8 @@ IsValidOp::checkClosedRings(const Polygon *poly)
checkClosedRing(lr);
if (validErr) return;
lr=(const LinearRing *)poly->getInteriorRingN(i);
diff --git a/src/precision/PrecisionReducerCoordinateOperation.cpp b/src/precision/PrecisionReducerCoordinateOperation.cpp
index 799f71b..211d9db 100644
--- a/src/precision/PrecisionReducerCoordinateOperation.cpp
+++ b/src/precision/PrecisionReducerCoordinateOperation.cpp
@@ -37,14 +37,14 @@ CoordinateSequence*
PrecisionReducerCoordinateOperation::edit(const CoordinateSequence *cs,
const Geometry *geom)
- unsigned int csSize = static_cast<unsigned int>(cs->getSize());
+ auto csSize = cs->size();
if ( csSize == 0 ) return nullptr;
vector<Coordinate> *vc = new vector<Coordinate>(csSize);
// copy coordinates and reduce
- for (unsigned int i=0; i<csSize; ++i) {
+ for (size_t i = 0; i < csSize; ++i) {
Coordinate coord=cs->getAt(i);
targetPM.makePrecise(&coord);
(*vc)[i] = coord;
diff --git a/src/precision/SimpleGeometryPrecisionReducer.cpp b/src/precision/SimpleGeometryPrecisionReducer.cpp
index 7112cd5..8cc2757 100644
--- a/src/precision/SimpleGeometryPrecisionReducer.cpp
+++ b/src/precision/SimpleGeometryPrecisionReducer.cpp
@@ -70,7 +70,7 @@ PrecisionReducerCoordinateOperation::edit(const CoordinateSequence *cs,
if (cs->getSize()==0) return nullptr;
- unsigned int csSize=static_cast<unsigned int>(cs->getSize());
diff --git a/src/simplify/TaggedLineSegment.cpp b/src/simplify/TaggedLineSegment.cpp
index 3c4e5aa..343d09e 100644
--- a/src/simplify/TaggedLineSegment.cpp
+++ b/src/simplify/TaggedLineSegment.cpp
@@ -34,7 +34,7 @@ namespace simplify { // geos::simplify
TaggedLineSegment::TaggedLineSegment(const geom::Coordinate& p0,
const geom::Coordinate& p1,
const geom::Geometry* nParent,
- unsigned int nIndex)
+ size_t nIndex)
LineSegment(p0, p1),
parent(nParent),
@@ -65,7 +65,7 @@ TaggedLineSegment::getParent() const
return parent;
-unsigned int
+size_t
TaggedLineSegment::getIndex() const
return index;
diff --git a/src/simplify/TaggedLineString.cpp b/src/simplify/TaggedLineString.cpp
index 0c2bfdc..f7b94fa 100644
--- a/src/simplify/TaggedLineString.cpp
+++ b/src/simplify/TaggedLineString.cpp
@@ -88,7 +88,7 @@ TaggedLineString::init()
TaggedLineSegment* seg = new TaggedLineSegment(
pts->getAt(i),
pts->getAt(i+1),
- parentLine, static_cast<unsigned int>(i));
+ parentLine, i);
segs.push_back(seg);
diff --git a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
index d05386e..bed1152 100644
--- a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
+++ b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
@@ -174,8 +174,8 @@ QuadEdgeSubdivision::locateFromEdge(const Vertex &v,
::geos::ignore_unused_variable_warning(startEdge);
- int iter = 0;
- int maxIter = static_cast<int>(quadEdges.size());
+ size_t iter = 0;
+ auto maxIter = quadEdges.size();
QuadEdge *e = startingEdges[0];
diff --git a/tests/unit/algorithm/RobustLineIntersectionTest.cpp b/tests/unit/algorithm/RobustLineIntersectionTest.cpp
index e398274..f3c248d 100644
--- a/tests/unit/algorithm/RobustLineIntersectionTest.cpp
+++ b/tests/unit/algorithm/RobustLineIntersectionTest.cpp
@@ -56,19 +56,19 @@ namespace tut
* elements
void checkIntersection(const std::vector<Coordinate>& pt,
- int expectedIntersectionNum,
+ size_t expectedIntersectionNum,
const std::vector<Coordinate>& intPt,
double distanceTolerance)
geos::algorithm::LineIntersector li;
li.computeIntersection(pt[0], pt[1], pt[2], pt[3]);
- int intNum = li.getIntersectionNum();
+ auto intNum = li.getIntersectionNum();
ensure_equals(intNum, expectedIntersectionNum);
if ( intPt.empty() ) return;
- ensure_equals(intPt.size(), static_cast<std::vector<Coordinate>::size_type>(intNum));
+ ensure_equals(intPt.size(), intNum);
// test that both points are represented here
//bool isIntPointsCorrect = true;
diff --git a/tests/unit/algorithm/RobustLineIntersectorTest.cpp b/tests/unit/algorithm/RobustLineIntersectorTest.cpp
index 0f45798..bcdb065 100644
--- a/tests/unit/algorithm/RobustLineIntersectorTest.cpp
+++ b/tests/unit/algorithm/RobustLineIntersectorTest.cpp
@@ -66,8 +66,8 @@ namespace tut
Coordinate x(15, 15);
i.computeIntersection(p1, p2, q1, q2);
- ensure_equals(i.getIntersectionNum(), (int)LineIntersector::POINT_INTERSECTION);
- ensure_equals(i.getIntersectionNum(), 1);
+ ensure_equals(i.getIntersectionNum(), LineIntersector::POINT_INTERSECTION);
+ ensure_equals(i.getIntersectionNum(), 1UL);
ensure_equals(i.getIntersection(0), x);
ensure("isProper", i.isProper());
ensure("hasIntersection", i.hasIntersection());
@@ -85,8 +85,8 @@ namespace tut
Coordinate q2(30, 10);
- ensure_equals(i.getIntersectionNum(), (int)LineIntersector::NO_INTERSECTION);
- ensure_equals(i.getIntersectionNum(), 0);
+ ensure_equals(i.getIntersectionNum(), LineIntersector::NO_INTERSECTION);
+ ensure_equals(i.getIntersectionNum(), 0UL);
ensure("!isProper", !i.isProper());
ensure("!hasIntersection", !i.hasIntersection());
@@ -103,8 +103,8 @@ namespace tut
@@ -121,8 +121,8 @@ namespace tut
- ensure_equals(i.getIntersectionNum(), (int)LineIntersector::COLLINEAR_INTERSECTION);
- ensure_equals(i.getIntersectionNum(), 2);
+ ensure_equals(i.getIntersectionNum(), LineIntersector::COLLINEAR_INTERSECTION);
+ ensure_equals(i.getIntersectionNum(), 2UL);
@@ -139,8 +139,8 @@ namespace tut
@@ -153,7 +153,7 @@ namespace tut
i.computeIntersection(Coordinate(100, 100), Coordinate(10, 100),
Coordinate(100, 10), Coordinate(100, 100));
// 7 - testEndpointIntersection2
@@ -164,7 +164,7 @@ namespace tut
i.computeIntersection(Coordinate(190, 50), Coordinate(120, 100),
Coordinate(120, 100), Coordinate(50, 150));
ensure_equals(i.getIntersection(1), Coordinate(120, 100));
@@ -176,7 +176,7 @@ namespace tut
i.computeIntersection(Coordinate(180, 200), Coordinate(160, 180),
Coordinate(220, 240), Coordinate(140, 160));
// 9 - testIsProper1
@@ -187,7 +187,7 @@ namespace tut
i.computeIntersection(Coordinate(30, 10), Coordinate(30, 30),
Coordinate(10, 10), Coordinate(90, 11));
@@ -199,7 +199,7 @@ namespace tut
i.computeIntersection(Coordinate(10, 30), Coordinate(10, 0),
Coordinate(11, 90), Coordinate(10, 10));
Summary of changes:
include/geos/algorithm/LineIntersector.h | 8 ++---
.../geos/algorithm/distance/PointPairDistance.h | 2 +-
include/geos/geom/CoordinateList.h | 3 +-
include/geos/geom/CoordinateSequence.h | 2 +-
include/geos/geom/IntersectionMatrix.h | 2 +-
include/geos/geom/LineString.h | 2 +-
include/geos/geom/MultiPoint.h | 2 +-
include/geos/geomgraph/Edge.h | 16 ++++-----
include/geos/geomgraph/EdgeIntersection.h | 8 ++---
include/geos/geomgraph/EdgeIntersectionList.h | 2 +-
include/geos/geomgraph/index/MonotoneChain.h | 4 +--
include/geos/geomgraph/index/MonotoneChainEdge.h | 16 ++++-----
.../geos/geomgraph/index/MonotoneChainIndexer.h | 6 ++--
include/geos/geomgraph/index/SegmentIntersector.h | 6 ++--
.../geomgraph/index/SimpleMCSweepLineIntersector.h | 2 +-
.../geomgraph/index/SimpleSweepLineIntersector.h | 2 +-
include/geos/geomgraph/index/SweepLineEvent.h | 6 ++--
include/geos/geomgraph/index/SweepLineSegment.h | 6 ++--
.../geos/index/chain/MonotoneChainSelectAction.h | 2 +-
include/geos/index/quadtree/NodeBase.h | 4 +--
include/geos/index/quadtree/Quadtree.h | 2 +-
include/geos/index/strtree/AbstractNode.h | 3 +-
include/geos/index/sweepline/SweepLineEvent.h | 7 ++--
include/geos/index/sweepline/SweepLineIndex.h | 4 +--
include/geos/io/WKBWriter.h | 2 +-
include/geos/linearref/LinearIterator.h | 14 ++++----
include/geos/linearref/LinearLocation.h | 18 +++++-----
include/geos/noding/BasicSegmentString.h | 8 ++---
include/geos/noding/IntersectionAdder.h | 12 +++----
include/geos/noding/IntersectionFinderAdder.h | 4 +--
include/geos/noding/NodedSegmentString.h | 18 +++++-----
include/geos/noding/NodingValidator.h | 4 +--
include/geos/noding/SegmentIntersectionDetector.h | 5 +--
include/geos/noding/SegmentIntersector.h | 5 +--
include/geos/noding/SegmentNode.h | 4 +--
include/geos/noding/SegmentString.h | 4 +--
.../geos/noding/SingleInteriorIntersectionFinder.h | 4 +--
.../geos/noding/snapround/MCIndexPointSnapper.h | 3 +-
.../operation/buffer/BufferInputLineSimplifier.h | 6 ++--
include/geos/operation/distance/GeometryLocation.h | 7 ++--
include/geos/simplify/TaggedLineSegment.h | 6 ++--
src/algorithm/CGAlgorithms.cpp | 18 +++++-----
src/algorithm/LineIntersector.cpp | 6 ++--
src/geom/CoordinateSequence.cpp | 24 +++++++-------
src/geom/IntersectionMatrix.cpp | 22 ++++++-------
src/geom/LineString.cpp | 4 +--
src/geom/MultiPoint.cpp | 2 +-
src/geom/util/GeometryTransformer.cpp | 6 ++--
src/geomgraph/DirectedEdge.cpp | 2 +-
src/geomgraph/Edge.cpp | 38 +++++++++++-----------
src/geomgraph/EdgeIntersectionList.cpp | 8 ++---
src/geomgraph/index/MonotoneChainEdge.cpp | 20 ++++++------
src/geomgraph/index/MonotoneChainIndexer.cpp | 24 +++++++-------
src/geomgraph/index/SegmentIntersector.cpp | 12 ++++---
src/geomgraph/index/SimpleEdgeSetIntersector.cpp | 8 ++---
.../index/SimpleMCSweepLineIntersector.cpp | 20 ++++++------
src/geomgraph/index/SimpleSweepLineIntersector.cpp | 6 ++--
src/geomgraph/index/SweepLineSegment.cpp | 2 +-
src/index/chain/MonotoneChain.cpp | 4 +--
src/index/chain/MonotoneChainSelectAction.cpp | 2 +-
src/index/quadtree/NodeBase.cpp | 10 +++---
src/index/quadtree/Quadtree.cpp | 2 +-
src/index/strtree/AbstractNode.cpp | 2 +-
src/index/strtree/SIRtree.cpp | 4 +--
src/index/strtree/STRtree.cpp | 4 +--
src/index/sweepline/SweepLineEvent.cpp | 4 +--
src/index/sweepline/SweepLineIndex.cpp | 10 +++---
src/io/WKBWriter.cpp | 4 +--
src/io/WKTWriter.cpp | 28 ++++++++--------
src/linearref/ExtractLineByLocation.cpp | 10 +++---
src/linearref/LengthLocationMap.cpp | 10 +++---
src/linearref/LinearIterator.cpp | 14 ++++----
src/linearref/LinearLocation.cpp | 30 ++++++++---------
src/linearref/LocationIndexOfLine.cpp | 2 +-
src/linearref/LocationIndexOfPoint.cpp | 8 ++---
src/noding/BasicSegmentString.cpp | 4 +--
src/noding/IntersectionAdder.cpp | 8 ++---
src/noding/IntersectionFinderAdder.cpp | 6 ++--
src/noding/MCIndexNoder.cpp | 2 +-
src/noding/MCIndexSegmentSetMutualIntersector.cpp | 2 +-
src/noding/NodedSegmentString.cpp | 20 ++++++------
src/noding/NodingValidator.cpp | 14 ++++----
src/noding/SegmentIntersectionDetector.cpp | 4 +--
src/noding/SegmentNode.cpp | 2 +-
src/noding/SegmentNodeList.cpp | 17 +++++-----
src/noding/SimpleNoder.cpp | 4 +--
src/noding/SingleInteriorIntersectionFinder.cpp | 4 +--
src/noding/snapround/HotPixel.cpp | 6 ++--
src/noding/snapround/MCIndexPointSnapper.cpp | 8 ++---
src/noding/snapround/MCIndexSnapRounder.cpp | 2 +-
src/noding/snapround/SimpleSnapRounder.cpp | 6 ++--
src/operation/IsSimpleOp.cpp | 2 +-
src/operation/buffer/BufferInputLineSimplifier.cpp | 20 ++++++------
src/operation/buffer/OffsetCurveBuilder.cpp | 34 +++++++++----------
src/operation/buffer/OffsetCurveSetBuilder.cpp | 2 +-
src/operation/buffer/OffsetSegmentGenerator.cpp | 2 +-
src/operation/buffer/SubgraphDepthLocater.cpp | 4 +--
src/operation/distance/DistanceOp.cpp | 6 ++--
src/operation/distance/GeometryLocation.cpp | 8 +++--
.../intersection/RectangleIntersection.cpp | 21 ++++++------
.../intersection/RectangleIntersectionBuilder.cpp | 17 +++++-----
src/operation/linemerge/LineSequencer.cpp | 2 +-
src/operation/polygonize/PolygonizeGraph.cpp | 4 +--
src/operation/predicate/RectangleContains.cpp | 4 +--
src/operation/relate/EdgeEndBuilder.cpp | 4 +--
src/operation/valid/IsValidOp.cpp | 38 +++++++++++-----------
.../PrecisionReducerCoordinateOperation.cpp | 4 +--
src/precision/SimpleGeometryPrecisionReducer.cpp | 2 +-
src/simplify/TaggedLineSegment.cpp | 4 +--
src/simplify/TaggedLineString.cpp | 2 +-
src/triangulate/quadedge/QuadEdgeSubdivision.cpp | 4 +--
.../unit/algorithm/RobustLineIntersectionTest.cpp | 6 ++--
tests/unit/algorithm/RobustLineIntersectorTest.cpp | 30 ++++++++---------
113 files changed, 473 insertions(+), 467 deletions(-)
hooks/post-receive
More information about the geos-commits
