the project "GEOS".
via 67b3af0b798cd6b7a36ac217923137602deba578 (commit)
from 6845c86cdf9a0b6e72294d72c77eff6b557ecef7 (commit)
revisions in full, below.
commit 67b3af0b798cd6b7a36ac217923137602deba578
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Dec 7 11:54:13 2018 -0800
Partially harmonize with JTS 8e6abedeca3f3c1905c2f58c0a2dccc77f1f2f12
Support for ISO WKB types for higher dimensions as well as
old SFSQL high-bit flags for Z. Commented out support for M
for a future date when M support is added to GEOS.
diff --git a/src/io/WKBReader.cpp b/src/io/WKBReader.cpp
index 615e8df..7b1265a 100644
--- a/src/io/WKBReader.cpp
+++ b/src/io/WKBReader.cpp
@@ -188,13 +188,21 @@ WKBReader::readGeometry()
dis.setOrder(ByteOrderValues::ENDIAN_BIG);
int typeInt = dis.readInt();
- int geometryType = typeInt & 0xff;
+ /* Pick up both ISO and SFSQL geometry type */
+ int geometryType = (typeInt & 0xffff) % 1000;
+ /* ISO type range 1000 is Z, 2000 is M, 3000 is ZM */
+ int isoTypeRange = (typeInt & 0xffff) / 1000;
+ int isoHasZ = (isoTypeRange == 1) || (isoTypeRange == 3);
+ //int isoHasM = (isoTypeRange == 2) || (isoTypeRange == 3);
+ /* SFSQL high bit flag for Z, next bit for M */
+ int sfsqlHasZ = (typeInt & 0x80000000) != 0;
+ //int sfsqlHasM = (typeInt & 0x40000000) != 0;
#if DEBUG_WKB_READER
cout<<"WKB geometryType: "<<geometryType<<endl;
#endif
- bool hasZ = ((typeInt & 0x80000000) != 0);
+ bool hasZ = sfsqlHasZ || isoHasZ;
if (hasZ) inputDimension = 3;
else inputDimension = 2; // doesn't handle M currently
diff --git a/tests/unit/io/WKBReaderTest.cpp b/tests/unit/io/WKBReaderTest.cpp
index b500765..c555d27 100644
--- a/tests/unit/io/WKBReaderTest.cpp
+++ b/tests/unit/io/WKBReaderTest.cpp
@@ -51,6 +51,16 @@ namespace tut
wktreader(gf.get())
+ void testInputNdr(const std::string& WKT,
+ const std::string& ndrWKB)
+ GeomPtr gWKT(wktreader.read(WKT));
+ // NDR input
+ std::stringstream ndr_in(ndrWKB);
+ GeomPtr gWKB_ndr(wkbreader.readHEX(ndr_in));
+ ensure("NDR input", gWKB_ndr->equalsExact(gWKT.get()) );
void testInputOutput(const std::string& WKT,
const std::string& ndrWKB,
const std::string& xdrWKB)
@@ -277,6 +287,83 @@ namespace tut
ensure_equals(gWKB->getCoordinateDimension(), 3);
+ // 10 - Extended WKB with Z
+ template<>
+ template<>
+ void object::test<10>()
+ testInputNdr(
+ // WKT
+ "POINT Z(1 2 3)",
+ // NDR HEXWKB
+ "01010000A0E6100000000000000000F03F00000000000000400000000000000840"
+ // 11 - Extended WKB with Z
+ template<>
+ template<>
+ void object::test<11>()
+ testInputNdr(
+ // WKT
+ "LINESTRING Z(1 2 3, 4 5 6)",
+ // NDR HEXWKB
+ "01020000A0E610000002000000000000000000F03F00000000000000400000000000000840000000000000104000000000000014400000000000001840"
+ // 12 - Extended WKB with Z
+ template<>
+ template<>
+ void object::test<12>()
+ testInputNdr(
+ // WKT
+ "POLYGON Z((0 0 100,0 10 100,10 10 100,10 0 100,0 0 100),(1 1 100,1 9 100,9 9 100,9 1 100,1 1 100))",
+ // NDR HEXWKB
+ "01030000A0E6100000020000000500000000000000000000000000000000000000000000000000594000000000000000000000000000002440000000000000594000000000000024400000000000002440000000000000594000000000000024400000000000000000000000000000594000000000000000000000000000000000000000000000594005000000000000000000F03F000000000000F03F0000000000005940000000000000F03F000000000000224000000000000059400000000000002240000000000000224000000000000059400000000000002240000000000000F03F0000000000005940000000000000F03F000000000000F03F0000000000005940"
+ // 13 - Extended WKB with Z
+ template<>
+ template<>
+ void object::test<13>()
+ testInputNdr(
+ // WKT
+ "MULTIPOINT Z(0 1 2, 3 4 5)",
+ // NDR HEXWKB
+ "01040000A0E61000000200000001010000800000000000000000000000000000F03F00000000000000400101000080000000000000084000000000000010400000000000001440"
+ // 14 - Extended WKB with Z
+ template<>
+ template<>
+ void object::test<14>()
+ testInputNdr(
+ // WKT
+ "MULTILINESTRING Z((0 1 2,3 4 5),(6 7 8,9 10 11))",
+ // NDR HEXWKB
+ "01050000A0E6100000020000000102000080020000000000000000000000000000000000F03F000000000000004000000000000008400000000000001040000000000000144001020000800200000000000000000018400000000000001C400000000000002040000000000000224000000000000024400000000000002640"
+ // 15 - Extended WKB with Z
+ template<>
+ template<>
+ void object::test<15>()
+ testInputNdr(
+ // WKT
+ "MULTIPOLYGON Z(((0 0 100,0 10 100,10 10 100,10 0 100,0 0 100),(1 1 100,1 9 100,9 9 100,9 1 100,1 1 100)),((-9 0 50,-9 10 50,-1 10 50,-1 0 50,-9 0 50)))",
+ // NDR HEXWKB
+ "01060000A0E6100000020000000103000080020000000500000000000000000000000000000000000000000000000000594000000000000000000000000000002440000000000000594000000000000024400000000000002440000000000000594000000000000024400000000000000000000000000000594000000000000000000000000000000000000000000000594005000000000000000000F03F000000000000F03F0000000000005940000000000000F03F000000000000224000000000000059400000000000002240000000000000224000000000000059400000000000002240000000000000F03F0000000000005940000000000000F03F000000000000F03F00000000000059400103000080010000000500000000000000000022C00000000000000000000000000000494000000000000022C000000000000024400000000000004940000000000000F0BF00000000000024400000000000004940000000000000F0BF0000000000000000000000000000494000000000000022C000000000000000000000000000004940"
} // namespace tut
Summary of changes:
src/io/WKBReader.cpp | 12 +++++-
tests/unit/io/WKBReaderTest.cpp | 87 +++++++++++++++++++++++++++++++++++++++++
2 files changed, 97 insertions(+), 2 deletions(-)
hooks/post-receive
